1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
/* SCCSid "$SunId$ LBL" */ |
4 |
5 |
6 |
* Header file for MGF interpreter |
7 |
8 |
9 |
/* must include stdio.h before us */ |
10 |
11 |
/* Entities (order doesn't really matter) */ |
12 |
#define MG_E_COMMENT 0 |
13 |
#define MG_E_COLOR 1 |
14 |
#define MG_E_CONE 2 |
15 |
#define MG_E_CMIX 3 |
16 |
#define MG_E_CSPEC 4 |
17 |
#define MG_E_CXY 5 |
18 |
#define MG_E_CYL 6 |
19 |
#define MG_E_ED 7 |
20 |
#define MG_E_FACE 8 |
21 |
#define MG_E_INCLUDE 9 |
22 |
#define MG_E_IES 10 |
23 |
#define MG_E_MATERIAL 11 |
24 |
#define MG_E_NORMAL 12 |
25 |
#define MG_E_OBJECT 13 |
26 |
#define MG_E_POINT 14 |
27 |
#define MG_E_PRISM 15 |
28 |
#define MG_E_RD 16 |
29 |
#define MG_E_RING 17 |
30 |
#define MG_E_RS 18 |
31 |
#define MG_E_SIDES 19 |
32 |
#define MG_E_SPH 20 |
33 |
#define MG_E_TD 21 |
34 |
#define MG_E_TORUS 22 |
35 |
#define MG_E_TS 23 |
36 |
#define MG_E_VERTEX 24 |
37 |
#define MG_E_XF 25 |
38 |
39 |
#define MG_NENTITIES 26 |
40 |
41 |
#define MG_NAMELIST {"#","c","cone","cmix","cspec","cxy","cyl","ed","f",\ |
42 |
"i","ies","m","n","o","p","prism","rd","ring","rs",\ |
43 |
"sides","sph","td","torus","ts","v","xf"} |
44 |
45 |
#define MG_MAXELEN 6 |
46 |
47 |
extern char mg_ename[MG_NENTITIES][MG_MAXELEN]; |
48 |
49 |
/* Handler routines for each entity */ |
50 |
51 |
#ifdef NOPROTO |
52 |
extern int (*mg_ehand[MG_NENTITIES])(); |
53 |
#else |
54 |
extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv); |
55 |
#endif |
56 |
57 |
/* Error codes */ |
58 |
#define MG_OK 0 /* normal return value */ |
59 |
#define MG_EUNK 1 /* unknown entity */ |
60 |
#define MG_EARGC 2 /* wrong number of arguments */ |
61 |
#define MG_ETYPE 3 /* argument type error */ |
62 |
#define MG_EILL 4 /* illegal argument value */ |
63 |
#define MG_EUNDEF 5 /* undefined reference */ |
64 |
#define MG_ENOFILE 6 /* cannot open input file */ |
65 |
#define MG_EINCL 7 /* error in included file */ |
66 |
#define MG_EMEM 8 /* out of memory */ |
67 |
#define MG_ESEEK 9 /* file seek error */ |
68 |
#define MG_EBADMAT 10 /* bad material specification */ |
69 |
70 |
#define MG_NERRS 11 |
71 |
72 |
extern char *mg_err[MG_NERRS]; |
73 |
74 |
75 |
* The general process for running the parser is to fill in the mg_ehand |
76 |
* array with handlers for each entity you know how to handle. |
77 |
* Then, call mg_init to fill in the rest. This function will report |
78 |
* an error and quit if you try to support an inconsistent set of entities. |
79 |
* For each file you want to parse, call mg_load with the file name. |
80 |
* To read from standard input, use NULL as the file name. |
81 |
* For additional control over error reporting and file management, |
82 |
* use mg_open, mg_read, mg_parse and mg_close instead of mg_load. |
83 |
* To pass an entity of your own construction to the parser, use |
84 |
* the mg_handle function rather than the mg_ehand routines directly. |
85 |
* (The first argument to mg_handle is the entity #, or -1.) |
86 |
* To free any data structures and clear the parser, use mg_clear. |
87 |
* If there is an error, mg_load, mg_open, mg_parse, and mg_rewind |
88 |
* will return an error from the list above. In addition, mg_load |
89 |
* will report the error to stderr. The mg_read routine returns 0 |
90 |
* when the end of file has been reached. |
91 |
92 |
93 |
#define MG_MAXLINE 512 /* maximum input line length */ |
94 |
#define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */ |
95 |
96 |
typedef struct mg_fctxt { |
97 |
char fname[96]; /* file name */ |
98 |
FILE *fp; /* stream pointer */ |
99 |
int fid; /* unique file context id */ |
100 |
char inpline[MG_MAXLINE]; /* input line */ |
101 |
int lineno; /* line number */ |
102 |
struct mg_fctxt *prev; /* previous context */ |
103 |
} MG_FCTXT; |
104 |
105 |
typedef struct { |
106 |
int fid; /* file this position is for */ |
107 |
int lineno; /* line number in file */ |
108 |
long offset; /* offset from beginning */ |
109 |
} MG_FPOS; |
110 |
111 |
extern MG_FCTXT *mg_file; /* current file context */ |
112 |
113 |
#ifdef NOPROTO |
114 |
extern void mg_init(); /* fill in mg_ehand array */ |
115 |
extern int mg_load(); /* parse a file */ |
116 |
extern int mg_open(); /* open new input file */ |
117 |
extern int mg_read(); /* read next line */ |
118 |
extern int mg_parse(); /* parse current line */ |
119 |
extern void mg_fgetpos(); /* get position on input file */ |
120 |
extern int mg_fgoto(); /* go to position on input file */ |
121 |
extern void mg_close(); /* close input file */ |
122 |
extern void mg_clear(); /* clear parser */ |
123 |
extern int mg_handle(); /* handle an entity */ |
124 |
#else |
125 |
extern void mg_init(void); /* fill in mg_ehand array */ |
126 |
extern int mg_load(char *); /* parse a file */ |
127 |
extern int mg_open(MG_FCTXT *, char *); /* open new input file */ |
128 |
extern int mg_read(void); /* read next line */ |
129 |
extern int mg_parse(void); /* parse current line */ |
130 |
extern void mg_fgetpos(MG_FPOS *); /* get position on input file */ |
131 |
extern int mg_fgoto(MG_FPOS *); /* go to position on input file */ |
132 |
extern void mg_close(void); /* close input file */ |
133 |
extern void mg_clear(void); /* clear parser */ |
134 |
extern int mg_handle(int, int, char **); /* handle an entity */ |
135 |
#endif |
136 |
137 |
#ifndef MG_NQCD |
138 |
#define MG_NQCD 5 /* default number of divisions */ |
139 |
#endif |
140 |
141 |
extern int mg_nqcdivs; /* divisions per quarter circle */ |
142 |
143 |
144 |
* The following library routines are included for your convenience: |
145 |
146 |
147 |
#ifdef NOPROTO |
148 |
extern int mg_entity(); /* get entity number from its name */ |
149 |
extern int isint(); /* non-zero if integer format */ |
150 |
extern int isflt(); /* non-zero if floating point format */ |
151 |
#else |
152 |
extern int mg_entity(char *); /* get entity number from its name */ |
153 |
extern int isint(char *); /* non-zero if integer format */ |
154 |
extern int isflt(char *); /* non-zero if floating point format */ |
155 |
#endif |
156 |
157 |
158 |
* Definitions for 3-d vector manipulation functions |
159 |
160 |
161 |
#ifdef SMLFLT |
162 |
#define FLOAT float |
163 |
#define FTINY (1e-3) |
164 |
#else |
165 |
#define FLOAT double |
166 |
#define FTINY (1e-6) |
167 |
#endif |
168 |
#define FHUGE (1e10) |
169 |
170 |
typedef FLOAT FVECT[3]; |
171 |
172 |
#define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2]) |
173 |
#define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2]) |
174 |
#define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \ |
175 |
(vr)[1]=(v1)[1]+(f)*(v2)[1], \ |
176 |
(vr)[2]=(v1)[2]+(f)*(v2)[2]) |
177 |
178 |
#define is0vect(v) (DOT(v,v) <= FTINY*FTINY) |
179 |
180 |
#define round0(x) if (x <= FTINY && x >= -FTINY) x = 0 |
181 |
182 |
#ifdef NOPROTO |
183 |
extern double normalize(); /* normalize a vector */ |
184 |
#else |
185 |
extern double normalize(FVECT); /* normalize a vector */ |
186 |
#endif |
187 |
188 |
189 |
* Definitions for context handling routines |
190 |
* (materials, colors, vectors) |
191 |
192 |
193 |
#define C_CMINWL 380 /* minimum wavelength */ |
194 |
#define C_CMAXWL 780 /* maximum wavelength */ |
195 |
#define C_CNSS 41 /* number of spectral samples */ |
196 |
#define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1)) |
197 |
#define C_CMAXV 10000 /* nominal maximum sample value */ |
198 |
199 |
#define C_CSSPEC 01 /* flag if spectrum is set */ |
200 |
#define C_CDSPEC 02 /* flag if defined w/ spectrum */ |
201 |
#define C_CSXY 04 /* flag if xy is set */ |
202 |
#define C_CDXY 010 /* flag if defined w/ xy */ |
203 |
204 |
typedef struct { |
205 |
int clock; /* incremented each change */ |
206 |
short flags; /* what's been set */ |
207 |
short ssamp[C_CNSS]; /* spectral samples, min wl to max */ |
208 |
long ssum; /* straight sum of spectral values */ |
209 |
float cx, cy; /* xy chromaticity value */ |
210 |
} C_COLOR; |
211 |
212 |
#define C_DEFCOLOR { 1, C_CDXY|C_CSXY|C_CSSPEC,\ |
213 |
{C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ |
214 |
C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ |
215 |
216 |
217 |
218 |
219 |
C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ |
220 |
(long)C_CNSS*C_CMAXV, 1./3., 1./3. } |
221 |
222 |
#define C_CIEX { 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ |
223 |
{14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ |
224 |
320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ |
225 |
10622,10026,8544,6424,4479,2835,1649,874,468,227,\ |
226 |
114,58,29,14,7,3,2,1,0}, 106836L, .735, .265 } |
227 |
228 |
#define C_CIEY { 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ |
229 |
{0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ |
230 |
5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ |
231 |
5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ |
232 |
5,2,1,1,0,0}, 106856L, .274, .717 } |
233 |
234 |
#define C_CIEZ { 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ |
235 |
{65,201,679,2074,6456,13856,17471,17721,16692,\ |
236 |
12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ |
237 |
11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\ |
238 |
106770L, .167, .009 } |
239 |
240 |
#define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->sum) |
241 |
242 |
typedef struct { |
243 |
int clock; /* incremented each change -- resettable */ |
244 |
int sided; /* 1 if surface is 1-sided, 0 for 2-sided */ |
245 |
float rd; /* diffuse reflectance */ |
246 |
C_COLOR rd_c; /* diffuse reflectance color */ |
247 |
float td; /* diffuse transmittance */ |
248 |
C_COLOR td_c; /* diffuse transmittance color */ |
249 |
float ed; /* diffuse emittance */ |
250 |
C_COLOR ed_c; /* diffuse emittance color */ |
251 |
float rs; /* specular reflectance */ |
252 |
C_COLOR rs_c; /* specular reflectance color */ |
253 |
float rs_a; /* specular reflectance roughness */ |
254 |
float ts; /* specular transmittance */ |
255 |
C_COLOR ts_c; /* specular transmittance color */ |
256 |
float ts_a; /* specular transmittance roughness */ |
257 |
} C_MATERIAL; /* material context */ |
258 |
259 |
typedef struct { |
260 |
261 |
FVECT p, n; /* point and normal */ |
262 |
} C_VERTEX; /* vertex context */ |
263 |
264 |
#define C_DEFMATERIAL {1,0,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ |
265 |
0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} |
266 |
#define C_DEFVERTEX {1,{0.,0.,0.},{0.,0.,0.}} |
267 |
268 |
extern C_COLOR *c_ccolor; /* the current color */ |
269 |
extern char *c_ccname; /* current color name */ |
270 |
extern C_MATERIAL *c_cmaterial; /* the current material */ |
271 |
extern char *c_cmname; /* current material name */ |
272 |
extern C_VERTEX *c_cvertex; /* the current vertex */ |
273 |
extern char *c_cvname; /* current vertex name */ |
274 |
275 |
#ifdef NOPROTO |
276 |
extern int c_hcolor(); /* handle color entity */ |
277 |
extern int c_hmaterial(); /* handle material entity */ |
278 |
extern int c_hvertex(); /* handle vertex entity */ |
279 |
extern void c_clearall(); /* clear context tables */ |
280 |
extern C_MATERIAL *c_getmaterial(); /* get a named material */ |
281 |
extern C_VERTEX *c_getvert(); /* get a named vertex */ |
282 |
extern C_COLOR *c_getcolor(); /* get a named color */ |
283 |
extern void c_ccvt(); /* fix color representation */ |
284 |
extern int c_isgrey(); /* check if color is grey */ |
285 |
#else |
286 |
extern int c_hcolor(int, char **); /* handle color entity */ |
287 |
extern int c_hmaterial(int, char **); /* handle material entity */ |
288 |
extern int c_hvertex(int, char **); /* handle vertex entity */ |
289 |
extern void c_clearall(void); /* clear context tables */ |
290 |
extern C_MATERIAL *c_getmaterial(char *); /* get a named material */ |
291 |
extern C_VERTEX *c_getvert(char *); /* get a named vertex */ |
292 |
extern C_COLOR *c_getcolor(char *); /* get a named color */ |
293 |
extern void c_ccvt(C_COLOR *, int); /* fix color representation */ |
294 |
extern int c_isgrey(C_COLOR *); /* check if color is grey */ |
295 |
#endif |
296 |
297 |
298 |
* Definitions for hierarchical object name handler |
299 |
300 |
301 |
extern int obj_nnames; /* depth of name hierarchy */ |
302 |
extern char **obj_name; /* names in hierarchy */ |
303 |
304 |
#ifdef NOPROTO |
305 |
extern int obj_handler(); /* handle an object entity */ |
306 |
extern void obj_clear(); /* clear object stack */ |
307 |
#else |
308 |
extern int obj_handler(int, char **); /* handle an object entity */ |
309 |
extern void obj_clear(void); /* clear object stack */ |
310 |
#endif |
311 |
312 |
313 |
* Definitions for hierarchical transformation handler |
314 |
315 |
316 |
typedef FLOAT MAT4[4][4]; |
317 |
318 |
#ifdef BSD |
319 |
#define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4)) |
320 |
#else |
321 |
#define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4)) |
322 |
#endif |
323 |
324 |
#define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \ |
325 |
{0.,0.,1.,0.}, {0.,0.,0.,1.} } |
326 |
327 |
extern MAT4 m4ident; |
328 |
329 |
#define setident4(m4) copymat4(m4, m4ident) |
330 |
331 |
/* regular transformation */ |
332 |
typedef struct { |
333 |
MAT4 xfm; /* transform matrix */ |
334 |
FLOAT sca; /* scalefactor */ |
335 |
} XF; |
336 |
337 |
#define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0) |
338 |
339 |
#define XF_MAXDIM 8 /* maximum array dimensions */ |
340 |
341 |
struct xf_array { |
342 |
MG_FPOS spos; /* starting position on input */ |
343 |
int ndim; /* number of array dimensions */ |
344 |
struct { |
345 |
short i, n; /* current count and maximum */ |
346 |
char arg[8]; /* string argument value */ |
347 |
} aarg[XF_MAXDIM]; |
348 |
349 |
350 |
typedef struct xf_spec { |
351 |
long xid; /* unique transform id */ |
352 |
short xav0; /* zeroeth argument in xf_argv array */ |
353 |
short xac; /* transform argument count */ |
354 |
XF xf; /* cumulative transformation */ |
355 |
struct xf_array *xarr; /* transformation array pointer */ |
356 |
struct xf_spec *prev; /* previous transformation context */ |
357 |
} XF_SPEC; /* followed by argument buffer */ |
358 |
359 |
extern int xf_argc; /* total # transform args. */ |
360 |
extern char **xf_argv; /* transform arguments */ |
361 |
extern XF_SPEC *xf_context; /* current context */ |
362 |
363 |
364 |
* The transformation handler should do most of the work that needs |
365 |
* doing. Just pass it any xf entities, then use the associated |
366 |
* functions to transform and translate points, transform vectors |
367 |
* (without translation), rotate vectors (without scaling) and scale |
368 |
* values appropriately. |
369 |
370 |
* The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two |
371 |
* 3-D vectors (which may be identical), transforms the second and |
372 |
* puts the result into the first. |
373 |
374 |
375 |
#ifdef NOPROTO |
376 |
377 |
extern int xf_handler(); /* handle xf entity */ |
378 |
extern void xf_xfmpoint(); /* transform point */ |
379 |
extern void xf_xfmvect(); /* transform vector */ |
380 |
extern void xf_rotvect(); /* rotate vector */ |
381 |
extern double xf_scale(); /* scale a value */ |
382 |
extern void xf_clear(); /* clear xf stack */ |
383 |
384 |
/* The following are support routines you probably won't call directly */ |
385 |
386 |
extern void multmat4(); /* m4a = m4b X m4c */ |
387 |
extern void multv3(); /* v3a = v3b X m4 (vectors) */ |
388 |
extern void multp3(); /* p3a = p3b X m4 (points) */ |
389 |
extern int xf(); /* interpret transform spec. */ |
390 |
391 |
#else |
392 |
393 |
extern int xf_handler(int, char **); /* handle xf entity */ |
394 |
extern void xf_xfmpoint(FVECT, FVECT); /* transform point */ |
395 |
extern void xf_xfmvect(FVECT, FVECT); /* transform vector */ |
396 |
extern void xf_rotvect(FVECT, FVECT); /* rotate vector */ |
397 |
extern double xf_scale(double); /* scale a value */ |
398 |
extern void xf_clear(void); /* clear xf stack */ |
399 |
400 |
401 |
402 |
extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */ |
403 |
extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */ |
404 |
extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */ |
405 |
extern int xf(XF *, int, char **); /* interpret transform spec. */ |
406 |
407 |
#endif |
408 |
409 |
410 |
* Miscellaneous definitions |
411 |
412 |
413 |
#ifdef M_PI |
414 |
#define PI M_PI |
415 |
#else |
416 |
#define PI 3.14159265358979323846 |
417 |
#endif |
418 |
419 |
#ifdef DCL_ATOF |
420 |
extern double atof(); |
421 |
#endif |
422 |
423 |
#ifndef MEM_PTR |
424 |
#define MEM_PTR void * |
425 |
#endif |
426 |
427 |
extern MEM_PTR malloc(); |
428 |
extern MEM_PTR calloc(); |
429 |
extern MEM_PTR realloc(); |
430 |
extern void free(); |
