--- ray/src/cv/mgflib/parser.h 1994/06/23 07:48:36 1.4 +++ ray/src/cv/mgflib/parser.h 1994/06/24 09:32:55 1.5 @@ -12,30 +12,34 @@ #define MG_E_COMMENT 0 #define MG_E_COLOR 1 #define MG_E_CONE 2 -#define MG_E_CXY 3 -#define MG_E_CYL 4 -#define MG_E_ED 5 -#define MG_E_FACE 6 -#define MG_E_INCLUDE 7 -#define MG_E_IES 8 -#define MG_E_MATERIAL 9 -#define MG_E_NORMAL 10 -#define MG_E_OBJECT 11 -#define MG_E_POINT 12 -#define MG_E_RD 13 -#define MG_E_RING 14 -#define MG_E_RS 15 -#define MG_E_SPH 16 -#define MG_E_TD 17 -#define MG_E_TORUS 18 -#define MG_E_TS 19 -#define MG_E_VERTEX 20 -#define MG_E_XF 21 +#define MG_E_CMIX 3 +#define MG_E_CXY 4 +#define MG_E_CSPEC 5 +#define MG_E_CYL 6 +#define MG_E_ED 7 +#define MG_E_FACE 8 +#define MG_E_INCLUDE 9 +#define MG_E_IES 10 +#define MG_E_MATERIAL 11 +#define MG_E_NORMAL 12 +#define MG_E_OBJECT 13 +#define MG_E_POINT 14 +#define MG_E_PRISM 15 +#define MG_E_RD 16 +#define MG_E_RING 17 +#define MG_E_RS 18 +#define MG_E_SPH 19 +#define MG_E_TD 20 +#define MG_E_TORUS 21 +#define MG_E_TS 22 +#define MG_E_VERTEX 23 +#define MG_E_XF 24 -#define MG_NENTITIES 22 +#define MG_NENTITIES 25 -#define MG_NAMELIST {"#","c","cone","cxy","cyl","ed","f","i","ies",\ - "m","n","o","p","rd","ring","rs","sph","td","torus","ts","v","xf"} +#define MG_NAMELIST {"#","c","cone","cmix","cspec","cxy","cyl","ed","f",\ + "i","ies","m","n","o","p","prism","rd","ring","rs",\ + "sph","td","torus","ts","v","xf"} #define MG_MAXELEN 6 @@ -173,11 +177,61 @@ extern double normalize(FVECT); /* normalize a vector * (materials, colors, vectors) */ +/* The following structure will change when we add spectral data support */ typedef struct { float cx, cy; /* XY chromaticity coordinates */ } C_COLOR; /* color context */ +#ifdef later + +#define C_CMAXWL 780 /* maximum wavelength */ +#define C_CMINWL 380 /* minimum wavelength */ +#define C_CNSS 41 /* number of spectral samples */ +#define C_WLINC ((C_MAXWL-C_MINWL)/(C_NSS-1)) /* 10 nm increment */ +#define C_CMAXV 10000 /* nominal maximum sample value */ + +#define C_CXY 1 /* flag if has xy chromaticity */ +#define C_CSPEC 2 /* flag if has spectrum */ + typedef struct { + short flags; /* what's been set */ + float cx, cy; /* xy chromaticity value */ + short ssamp[C_CNSS]; /* spectral samples, min wl to max */ + long ssum; /* straight sum of spectral values */ +} C_COLOR; + +#define C_DEFCOLOR { C_CXY|C_CSPEC, 1./3., 1./3., + {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ + (long)C_CNSS*C_MAXV } + +#define C_CIEX { C_CXY|C_CSPEC, ???, ???, + {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ + 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ + 10622,10026,8544,6424,4479,2835,1649,874,468,227,\ + 114,58,29,14,7,3,2,1,0}, 106836L } + +#define C_CIEY { C_CXY|C_CSPEC, ???, ???, + {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ + 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ + 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ + 5,2,1,1,0,0}, 106856L } + +#define C_CIEZ { C_CXY|C_CSPEC, ???, ???, + {65,201,679,2074,6456,13856,17471,17721,16692,\ + 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ + 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, 106770L } + +#define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_WLINC] / (c)->sum) + +#endif + +typedef struct { char *name; /* material name */ int clock; /* incremented each change -- resettable */ float rd; /* diffuse reflectance */ @@ -198,8 +252,8 @@ typedef struct { FVECT p, n; /* point and normal */ } C_VERTEX; /* vertex context */ -#define isgrey(cxy) ((cxy)->cx > .31 && (cxy)->cx < .35 && \ - (cxy)->cy > .31 && (cxy)->cy < .35) +#define isgrey(cxy) ((cxy)->cx > .32 && (cxy)->cx < .34 && \ + (cxy)->cy > .32 && (cxy)->cy < .34) #define C_DEFCOLOR {.333,.333} #define C_DEFMATERIAL {NULL,1,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\
