--- ray/src/cv/mgflib/parser.h 1994/09/02 16:04:16 1.16 +++ ray/src/cv/mgflib/parser.h 1995/02/24 16:50:05 1.17 @@ -90,7 +90,7 @@ extern char *mg_err[MG_NERRS]; * returns 0 when the end of file has been reached. */ -#define MG_MAXLINE 512 /* maximum input line length */ +#define MG_MAXLINE 4096 /* maximum input line length */ #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */ typedef struct mg_fctxt { @@ -205,9 +205,9 @@ extern double normalize(FVECT); /* normalize a vector typedef struct { int clock; /* incremented each change */ - short flags; /* what's been set */ - short ssamp[C_CNSS]; /* spectral samples, min wl to max */ - long ssum; /* straight sum of spectral values */ + unsigned short flags; /* what's been set */ + unsigned short ssamp[C_CNSS]; /* spectral samples, min wl to max */ + unsigned long ssum; /* straight sum of spectral values */ float cx, cy; /* xy chromaticity value */ float eff; /* efficacy (lumens/watt) */ } C_COLOR; @@ -226,19 +226,19 @@ typedef struct { {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ 10622,10026,8544,6424,4479,2835,1649,874,468,227,\ - 114,58,29,14,7,3,2,1,0}, 106836L, .735, .265, 362.230 } + 114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230 } #define C_CIEY { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ - 5,2,1,1,0,0}, 106856L, .274, .717, 493.525 } + 5,2,1,1,0,0}, 106856L, .398, .542, 493.525 } #define C_CIEZ { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ {65,201,679,2074,6456,13856,17471,17721,16692,\ 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\ - 106770L, .167, .009, 54.363 } + 106770L, .147, .077, 54.363 } #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum)
