--- ray/src/cv/mgflib/parser.h 1995/03/07 14:53:17 1.18 +++ ray/src/cv/mgflib/parser.h 2003/06/26 00:58:09 1.35 @@ -1,60 +1,74 @@ -/* Copyright (c) 1994 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: parser.h,v 1.35 2003/06/26 00:58:09 schorsch Exp $ */ /* * Header file for MGF interpreter */ +#ifndef _MGF_PARSER_H_ +#define _MGF_PARSER_H_ +#ifdef __cplusplus +extern "C" { +#endif -/* must include stdio.h before us */ - /* Entities (order doesn't really matter) */ -#define MG_E_COMMENT 0 -#define MG_E_COLOR 1 -#define MG_E_CCT 2 -#define MG_E_CONE 3 -#define MG_E_CMIX 4 -#define MG_E_CSPEC 5 -#define MG_E_CXY 6 -#define MG_E_CYL 7 -#define MG_E_ED 8 -#define MG_E_FACE 9 -#define MG_E_INCLUDE 10 -#define MG_E_IES 11 -#define MG_E_MATERIAL 12 -#define MG_E_NORMAL 13 -#define MG_E_OBJECT 14 -#define MG_E_POINT 15 -#define MG_E_PRISM 16 -#define MG_E_RD 17 -#define MG_E_RING 18 -#define MG_E_RS 19 -#define MG_E_SIDES 20 -#define MG_E_SPH 21 -#define MG_E_TD 22 -#define MG_E_TORUS 23 -#define MG_E_TS 24 -#define MG_E_VERTEX 25 -#define MG_E_XF 26 +#ifndef MG_VMAJOR -#define MG_NENTITIES 27 +/* must include stdio.h and stdlib.h before us */ +#define MG_VMAJOR 2 /* major version number */ +#define MG_VMINOR 0 /* minor version number */ + + /* Entities (list is only appended, never modified) */ +#define MG_E_COMMENT 0 /* # */ +#define MG_E_COLOR 1 /* c */ +#define MG_E_CCT 2 /* cct */ +#define MG_E_CONE 3 /* cone */ +#define MG_E_CMIX 4 /* cmix */ +#define MG_E_CSPEC 5 /* cspec */ +#define MG_E_CXY 6 /* cxy */ +#define MG_E_CYL 7 /* cyl */ +#define MG_E_ED 8 /* ed */ +#define MG_E_FACE 9 /* f */ +#define MG_E_INCLUDE 10 /* i */ +#define MG_E_IES 11 /* ies */ +#define MG_E_IR 12 /* ir */ +#define MG_E_MATERIAL 13 /* m */ +#define MG_E_NORMAL 14 /* n */ +#define MG_E_OBJECT 15 /* o */ +#define MG_E_POINT 16 /* p */ +#define MG_E_PRISM 17 /* prism */ +#define MG_E_RD 18 /* rd */ +#define MG_E_RING 19 /* ring */ +#define MG_E_RS 20 /* rs */ +#define MG_E_SIDES 21 /* sides */ +#define MG_E_SPH 22 /* sph */ +#define MG_E_TD 23 /* td */ +#define MG_E_TORUS 24 /* torus */ +#define MG_E_TS 25 /* ts */ +#define MG_E_VERTEX 26 /* v */ +#define MG_E_XF 27 /* xf */ + /* end of Version 1 entities */ +#define MG_E_FACEH 28 /* fh */ + /* end of Version 2 entities */ + +#define MG_NENTITIES 29 /* total # entities */ + +#define MG_NELIST {28,29} /* entity count for version 1 and up */ + #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\ - "f","i","ies","m","n","o","p","prism","rd","ring",\ - "rs","sides","sph","td","torus","ts","v","xf"} + "f","i","ies","ir","m","n","o","p","prism","rd",\ + "ring","rs","sides","sph","td","torus","ts","v","xf",\ + "fh"} #define MG_MAXELEN 6 extern char mg_ename[MG_NENTITIES][MG_MAXELEN]; - /* Handler routines for each entity */ - -#ifdef NOPROTO -extern int (*mg_ehand[MG_NENTITIES])(); -#else + /* Handler routines for each entity and unknown ones */ extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv); -#endif +extern int (*mg_uhand)(int argc, char **argv); +extern int mg_defuhand(int, char **); +extern unsigned mg_nunknown; /* count of unknown entities */ + /* Error codes */ #define MG_OK 0 /* normal return value */ #define MG_EUNK 1 /* unknown entity */ @@ -67,10 +81,12 @@ extern int (*mg_ehand[MG_NENTITIES])(int argc, char ** #define MG_EMEM 8 /* out of memory */ #define MG_ESEEK 9 /* file seek error */ #define MG_EBADMAT 10 /* bad material specification */ +#define MG_ELINE 11 /* input line too long */ +#define MG_ECNTXT 12 /* unmatched context close */ -#define MG_NERRS 11 +#define MG_NERRS 13 -extern char *mg_err[MG_NERRS]; +extern char *mg_err[MG_NERRS]; /* list of error messages */ /* * The general process for running the parser is to fill in the mg_ehand @@ -86,7 +102,7 @@ extern char *mg_err[MG_NERRS]; * (The first argument to mg_handle is the entity #, or -1.) * To free any data structures and clear the parser, use mg_clear. * If there is an error, mg_load, mg_open, mg_parse, mg_handle and - * mg_rewind will return an error from the list above. In addition, + * mg_fgoto will return an error from the list above. In addition, * mg_load will report the error to stderr. The mg_read routine * returns 0 when the end of file has been reached. */ @@ -111,18 +127,6 @@ typedef struct { extern MG_FCTXT *mg_file; /* current file context */ -#ifdef NOPROTO -extern void mg_init(); /* fill in mg_ehand array */ -extern int mg_load(); /* parse a file */ -extern int mg_open(); /* open new input file */ -extern int mg_read(); /* read next line */ -extern int mg_parse(); /* parse current line */ -extern void mg_fgetpos(); /* get position on input file */ -extern int mg_fgoto(); /* go to position on input file */ -extern void mg_close(); /* close input file */ -extern void mg_clear(); /* clear parser */ -extern int mg_handle(); /* handle an entity */ -#else extern void mg_init(void); /* fill in mg_ehand array */ extern int mg_load(char *); /* parse a file */ extern int mg_open(MG_FCTXT *, char *); /* open new input file */ @@ -133,7 +137,6 @@ extern int mg_fgoto(MG_FPOS *); /* go to position on i extern void mg_close(void); /* close input file */ extern void mg_clear(void); /* clear parser */ extern int mg_handle(int, int, char **); /* handle an entity */ -#endif #ifndef MG_NQCD #define MG_NQCD 5 /* default number of divisions */ @@ -145,30 +148,37 @@ extern int mg_nqcdivs; /* divisions per quarter circl * The following library routines are included for your convenience: */ -#ifdef NOPROTO -extern int mg_entity(); /* get entity number from its name */ -extern int isint(); /* non-zero if integer format */ -extern int isflt(); /* non-zero if floating point format */ -#else extern int mg_entity(char *); /* get entity number from its name */ extern int isint(char *); /* non-zero if integer format */ +extern int isintd(char *, char *); /* same with delimiter set */ extern int isflt(char *); /* non-zero if floating point format */ -#endif +extern int isfltd(char *, char *); /* same with delimiter set */ +extern int isname(char *); /* non-zero if legal identifier name */ +extern int badarg(int, char **, char *);/* check argument format */ +extern int e_include(int, char **); /* expand include entity */ +extern int e_pipe(int, char **); /* expand piped command */ +extern int e_sph(int, char **); /* expand sphere as other entities */ +extern int e_torus(int, char **); /* expand torus as other entities */ +extern int e_cyl(int, char **); /* expand cylinder as other entities */ +extern int e_ring(int, char **); /* expand ring as other entities */ +extern int e_cone(int, char **); /* expand cone as other entities */ +extern int e_prism(int, char **); /* expand prism as other entities */ +extern int e_faceh(int, char **); /* expand face w/ holes as face */ /************************************************************************ * Definitions for 3-d vector manipulation functions */ #ifdef SMLFLT -#define FLOAT float +#define RREAL float #define FTINY (1e-3) #else -#define FLOAT double +#define RREAL double #define FTINY (1e-6) #endif #define FHUGE (1e10) -typedef FLOAT FVECT[3]; +typedef RREAL FVECT[3]; #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2]) #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2]) @@ -180,11 +190,8 @@ typedef FLOAT FVECT[3]; #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0 -#ifdef NOPROTO -extern double normalize(); /* normalize a vector */ -#else extern double normalize(FVECT); /* normalize a vector */ -#endif +extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */ /************************************************************************ * Definitions for context handling routines @@ -205,15 +212,16 @@ extern double normalize(FVECT); /* normalize a vector #define C_CSEFF 020 /* flag if efficacy set */ typedef struct { - int clock; /* incremented each change */ - unsigned short flags; /* what's been set */ - unsigned short ssamp[C_CNSS]; /* spectral samples, min wl to max */ - unsigned long ssum; /* straight sum of spectral values */ - float cx, cy; /* xy chromaticity value */ - float eff; /* efficacy (lumens/watt) */ + int clock; /* incremented each change */ + char *client_data; /* pointer to private client-owned data */ + short flags; /* what's been set */ + short ssamp[C_CNSS]; /* spectral samples, min wl to max */ + long ssum; /* straight sum of spectral values */ + float cx, cy; /* xy chromaticity value */ + float eff; /* efficacy (lumens/watt) */ } C_COLOR; -#define C_DEFCOLOR { 1, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\ +#define C_DEFCOLOR { 1, NULL, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\ {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ @@ -223,29 +231,15 @@ typedef struct { C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 } -#define C_CIEX { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ - 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ - 10622,10026,8544,6424,4479,2835,1649,874,468,227,\ - 114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230 } - -#define C_CIEY { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ - 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ - 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ - 5,2,1,1,0,0}, 106856L, .398, .542, 493.525 } - -#define C_CIEZ { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {65,201,679,2074,6456,13856,17471,17721,16692,\ - 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ - 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\ - 106770L, .147, .077, 54.363 } - #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum) +#define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */ + typedef struct { int clock; /* incremented each change -- resettable */ + char *client_data; /* pointer to private client-owned data */ int sided; /* 1 if surface is 1-sided, 0 for 2-sided */ + float nr, ni; /* index of refraction, real and imaginary */ float rd; /* diffuse reflectance */ C_COLOR rd_c; /* diffuse reflectance color */ float td; /* diffuse transmittance */ @@ -262,12 +256,13 @@ typedef struct { typedef struct { int clock; /* incremented each change -- resettable */ + char *client_data; /* pointer to private client-owned data */ FVECT p, n; /* point and normal */ } C_VERTEX; /* vertex context */ -#define C_DEFMATERIAL {1,0,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ - 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} -#define C_DEFVERTEX {1,{0.,0.,0.},{0.,0.,0.}} +#define C_DEFMATERIAL {1,NULL,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,\ + C_DEFCOLOR,0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} +#define C_DEFVERTEX {1,NULL,{0.,0.,0.},{0.,0.,0.}} extern C_COLOR *c_ccolor; /* the current color */ extern char *c_ccname; /* current color name */ @@ -276,17 +271,6 @@ extern char *c_cmname; /* current material name */ extern C_VERTEX *c_cvertex; /* the current vertex */ extern char *c_cvname; /* current vertex name */ -#ifdef NOPROTO -extern int c_hcolor(); /* handle color entity */ -extern int c_hmaterial(); /* handle material entity */ -extern int c_hvertex(); /* handle vertex entity */ -extern void c_clearall(); /* clear context tables */ -extern C_MATERIAL *c_getmaterial(); /* get a named material */ -extern C_VERTEX *c_getvert(); /* get a named vertex */ -extern C_COLOR *c_getcolor(); /* get a named color */ -extern void c_ccvt(); /* fix color representation */ -extern int c_isgrey(); /* check if color is grey */ -#else extern int c_hcolor(int, char **); /* handle color entity */ extern int c_hmaterial(int, char **); /* handle material entity */ extern int c_hvertex(int, char **); /* handle vertex entity */ @@ -296,7 +280,6 @@ extern C_VERTEX *c_getvert(char *); /* get a named ve extern C_COLOR *c_getcolor(char *); /* get a named color */ extern void c_ccvt(C_COLOR *, int); /* fix color representation */ extern int c_isgrey(C_COLOR *); /* check if color is grey */ -#endif /************************************************************************* * Definitions for hierarchical object name handler @@ -305,19 +288,14 @@ extern int c_isgrey(C_COLOR *); /* check if color is extern int obj_nnames; /* depth of name hierarchy */ extern char **obj_name; /* names in hierarchy */ -#ifdef NOPROTO -extern int obj_handler(); /* handle an object entity */ -extern void obj_clear(); /* clear object stack */ -#else extern int obj_handler(int, char **); /* handle an object entity */ extern void obj_clear(void); /* clear object stack */ -#endif /************************************************************************** * Definitions for hierarchical transformation handler */ -typedef FLOAT MAT4[4][4]; +typedef RREAL MAT4[4][4]; #ifdef BSD #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4)) @@ -335,7 +313,7 @@ extern MAT4 m4ident; /* regular transformation */ typedef struct { MAT4 xfm; /* transform matrix */ - FLOAT sca; /* scalefactor */ + RREAL sca; /* scalefactor */ } XF; #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0) @@ -353,18 +331,22 @@ struct xf_array { typedef struct xf_spec { long xid; /* unique transform id */ - short xav0; /* zeroeth argument in xf_argv array */ - short xac; /* transform argument count */ + short xac; /* context argument count */ short rev; /* boolean true if vertices reversed */ XF xf; /* cumulative transformation */ struct xf_array *xarr; /* transformation array pointer */ struct xf_spec *prev; /* previous transformation context */ } XF_SPEC; /* followed by argument buffer */ -extern int xf_argc; /* total # transform args. */ -extern char **xf_argv; /* transform arguments */ -extern XF_SPEC *xf_context; /* current context */ +extern XF_SPEC *xf_context; /* current transform context */ +extern char **xf_argend; /* last transform argument */ +#define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac) +#define xf_av(xf) (xf_argend - (xf)->xac) + +#define xf_argc xf_ac(xf_context) +#define xf_argv xf_av(xf_context) + /* * The transformation handler should do most of the work that needs * doing. Just pass it any xf entities, then use the associated @@ -377,24 +359,7 @@ extern XF_SPEC *xf_context; /* current context */ * puts the result into the first. */ -#ifdef NOPROTO -extern int xf_handler(); /* handle xf entity */ -extern void xf_xfmpoint(); /* transform point */ -extern void xf_xfmvect(); /* transform vector */ -extern void xf_rotvect(); /* rotate vector */ -extern double xf_scale(); /* scale a value */ -extern void xf_clear(); /* clear xf stack */ - -/* The following are support routines you probably won't call directly */ - -extern void multmat4(); /* m4a = m4b X m4c */ -extern void multv3(); /* v3a = v3b X m4 (vectors) */ -extern void multp3(); /* p3a = p3b X m4 (points) */ -extern int xf(); /* interpret transform spec. */ - -#else - extern int xf_handler(int, char **); /* handle xf entity */ extern void xf_xfmpoint(FVECT, FVECT); /* transform point */ extern void xf_xfmvect(FVECT, FVECT); /* transform vector */ @@ -404,32 +369,37 @@ extern void xf_clear(void); /* clear xf stack */ /* The following are support routines you probably won't call directly */ +XF_SPEC *new_xf(int, char **); /* allocate new transform */ +void free_xf(XF_SPEC *); /* free a transform */ +int xf_aname(struct xf_array *); /* name this instance */ +long comp_xfid(MAT4); /* compute unique ID */ extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */ extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */ extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */ extern int xf(XF *, int, char **); /* interpret transform spec. */ -#endif /************************************************************************ * Miscellaneous definitions */ +#ifndef PI #ifdef M_PI -#define PI M_PI +#define PI ((double)M_PI) #else #define PI 3.14159265358979323846 #endif - -#ifdef DCL_ATOF -extern double atof(); #endif #ifndef MEM_PTR #define MEM_PTR void * #endif -extern MEM_PTR malloc(); -extern MEM_PTR calloc(); -extern MEM_PTR realloc(); -extern void free(); +#endif /*MG_VMAJOR*/ + + +#ifdef __cplusplus +} +#endif +#endif /* _MGF_PARSER_H_ */ +
