--- ray/src/cv/mgflib/parser.h 1995/05/11 21:48:42 1.25 +++ ray/src/cv/mgflib/parser.h 1997/03/18 11:05:40 1.30 @@ -6,9 +6,11 @@ * Header file for MGF interpreter */ +#ifndef MG_VMAJOR + /* must include stdio.h before us */ -#define MG_VMAJOR 1 /* major version number */ +#define MG_VMAJOR 2 /* major version number */ #define MG_VMINOR 0 /* minor version number */ /* Entities (list is only appended, never modified) */ @@ -41,14 +43,17 @@ #define MG_E_VERTEX 26 /* v */ #define MG_E_XF 27 /* xf */ /* end of Version 1 entities */ +#define MG_E_FACEH 28 /* fh */ + /* end of Version 2 entities */ -#define MG_NENTITIES 28 /* total # entities */ +#define MG_NENTITIES 29 /* total # entities */ -#define MG_NELIST {28} /* entity count for version 1 and up */ +#define MG_NELIST {28,29} /* entity count for version 1 and up */ #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\ "f","i","ies","ir","m","n","o","p","prism","rd",\ - "ring","rs","sides","sph","td","torus","ts","v","xf"} + "ring","rs","sides","sph","td","torus","ts","v","xf",\ + "fh"} #define MG_MAXELEN 6 @@ -79,8 +84,10 @@ extern unsigned mg_nunknown; /* count of unknown enti #define MG_EMEM 8 /* out of memory */ #define MG_ESEEK 9 /* file seek error */ #define MG_EBADMAT 10 /* bad material specification */ +#define MG_ELINE 11 /* input line too long */ +#define MG_ECNTXT 12 /* unmatched context close */ -#define MG_NERRS 11 +#define MG_NERRS 13 extern char *mg_err[MG_NERRS]; /* list of error messages */ @@ -160,13 +167,35 @@ extern int mg_nqcdivs; /* divisions per quarter circl #ifdef NOPROTO extern int mg_entity(); /* get entity number from its name */ extern int isint(); /* non-zero if integer format */ +extern int isintd(); /* same with delimiter set */ extern int isflt(); /* non-zero if floating point format */ +extern int isfltd(); /* same with delimiter set */ extern int isname(); /* non-zero if legal identifier name */ +extern int badarg(); /* check argument format */ +extern int e_include(); /* expand include entity */ +extern int e_sph(); /* expand sphere as other entities */ +extern int e_torus(); /* expand torus as other entities */ +extern int e_cyl(); /* expand cylinder as other entities */ +extern int e_ring(); /* expand ring as other entities */ +extern int e_cone(); /* expand cone as other entities */ +extern int e_prism(); /* expand prism as other entities */ +extern int e_faceh(); /* expand face w/ holes as face */ #else extern int mg_entity(char *); /* get entity number from its name */ extern int isint(char *); /* non-zero if integer format */ +extern int isintd(char *, char *); /* same with delimiter set */ extern int isflt(char *); /* non-zero if floating point format */ +extern int isfltd(char *, char *); /* same with delimiter set */ extern int isname(char *); /* non-zero if legal identifier name */ +extern int badarg(int, char **, char *);/* check argument format */ +extern int e_include(int, char **); /* expand include entity */ +extern int e_sph(int, char **); /* expand sphere as other entities */ +extern int e_torus(int, char **); /* expand torus as other entities */ +extern int e_cyl(int, char **); /* expand cylinder as other entities */ +extern int e_ring(int, char **); /* expand ring as other entities */ +extern int e_cone(int, char **); /* expand cone as other entities */ +extern int e_prism(int, char **); /* expand prism as other entities */ +extern int e_faceh(int, char **); /* expand face w/ holes as face */ #endif /************************************************************************ @@ -198,6 +227,7 @@ typedef FLOAT FVECT[3]; extern double normalize(); /* normalize a vector */ #else extern double normalize(FVECT); /* normalize a vector */ +extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */ #endif /************************************************************************ @@ -362,10 +392,10 @@ typedef struct xf_spec { extern XF_SPEC *xf_context; /* current transform context */ extern char **xf_argend; /* last transform argument */ -#define xf_ac(xf) ((xf)->xac) +#define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac) #define xf_av(xf) (xf_argend - (xf)->xac) -#define xf_argc (xf_context==NULL ? 0 : xf_ac(xf_context)) +#define xf_argc xf_ac(xf_context) #define xf_argv xf_av(xf_context) /* @@ -391,6 +421,10 @@ extern void xf_clear(); /* clear xf stack */ /* The following are support routines you probably won't call directly */ +XF_SPEC *new_xf(); /* allocate new transform */ +void free_xf(); /* free a transform */ +int xf_aname(); /* name this instance */ +long comp_xfid(); /* compute unique ID */ extern void multmat4(); /* m4a = m4b X m4c */ extern void multv3(); /* v3a = v3b X m4 (vectors) */ extern void multp3(); /* p3a = p3b X m4 (points) */ @@ -407,6 +441,10 @@ extern void xf_clear(void); /* clear xf stack */ /* The following are support routines you probably won't call directly */ +XF_SPEC *new_xf(int, char **); /* allocate new transform */ +void free_xf(XF_SPEC *); /* free a transform */ +int xf_aname(struct xf_array *); /* name this instance */ +long comp_xfid(MAT4); /* compute unique ID */ extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */ extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */ extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */ @@ -418,11 +456,13 @@ extern int xf(XF *, int, char **); /* interpret trans * Miscellaneous definitions */ +#ifndef PI #ifdef M_PI #define PI M_PI #else #define PI 3.14159265358979323846 #endif +#endif #ifdef DCL_ATOF extern double atof(); @@ -436,3 +476,5 @@ extern MEM_PTR malloc(); extern MEM_PTR calloc(); extern MEM_PTR realloc(); extern void free(); + +#endif /*MG_VMAJOR*/
