root/Development/ray/src/cv/mgflib/parser.h
Revision: 1.3
Committed: Wed Jun 22 17:15:46 1994 UTC (31 years, 4 months ago) by greg
Changes since 1.2: +19 -3 lines
more bug fixes
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for MGF interpreter
7 */
8
9 /* must include stdio.h before us */
10
11 /* Entities (order doesn't really matter) */
12 #define MG_E_COMMENT 0
13 #define MG_E_COLOR 1
14 #define MG_E_CONE 2
15 #define MG_E_CXY 3
16 #define MG_E_CYL 4
17 #define MG_E_ED 5
18 #define MG_E_FACE 6
19 #define MG_E_INCLUDE 7
20 #define MG_E_IES 8
21 #define MG_E_MATERIAL 9
22 #define MG_E_NORMAL 10
23 #define MG_E_OBJECT 11
24 #define MG_E_POINT 12
25 #define MG_E_RD 13
26 #define MG_E_RING 14
27 #define MG_E_RS 15
28 #define MG_E_SPH 16
29 #define MG_E_TD 17
30 #define MG_E_TORUS 18
31 #define MG_E_TS 19
32 #define MG_E_VERTEX 20
33 #define MG_E_XF 21
34
35 #define MG_NENTITIES 22
36
37 #define MG_NAMELIST {"#","c","cone","cxy","cyl","ed","f","i","ies",\
38 "m","n","o","p","rd","ring","rs","sph","td","torus","ts","v","xf"}
39
40 #define MG_MAXELEN 6
41
42 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
43
44 /* Handler routines for each entity */
45
46 #ifdef NOPROTO
47 extern int (*mg_ehand[MG_NENTITIES])();
48 #else
49 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
50 #endif
51
52 /* Error codes */
53 #define MG_OK 0 /* normal return value */
54 #define MG_EUNK 1 /* unknown entity */
55 #define MG_EARGC 2 /* wrong number of arguments */
56 #define MG_ETYPE 3 /* argument type error */
57 #define MG_EILL 4 /* illegal argument value */
58 #define MG_EUNDEF 5 /* undefined reference */
59 #define MG_ENOFILE 6 /* cannot open input file */
60 #define MG_EINCL 7 /* error in included file */
61 #define MG_EMEM 8 /* out of memory */
62 #define MG_ESEEK 9 /* file seek error */
63 #define MG_EBADMAT 10 /* bad material specification */
64
65 #define MG_NERRS 11
66
67 extern char *mg_err[MG_NERRS];
68
69 /*
70 * The general process for running the parser is to fill in the mg_ehand
71 * array with handlers for each entity you know how to handle.
72 * Then, call mg_init to fill in the rest. This function will report
73 * an error and quit if you try to support an inconsistent set of entities.
74 * For each file you want to parse, call mg_load with the file name.
75 * To read from standard input, use NULL as the file name.
76 * For additional control over error reporting and file management,
77 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
78 * To free any data structures and clear the parser, use mg_clear.
79 * If there is an error, mg_load, mg_open, mg_parse, and mg_rewind
80 * will return an error from the list above. In addition, mg_load
81 * will report the error to stderr. The mg_read routine returns 0
82 * when the end of file has been reached.
83 */
84
85 #define MG_MAXLINE 512 /* maximum input line length */
86 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
87
88 typedef struct mg_fctxt {
89 char *fname; /* file name */
90 FILE *fp; /* stream pointer */
91 char inpline[MG_MAXLINE]; /* input line */
92 int lineno; /* line number */
93 struct mg_fctxt *prev; /* previous context */
94 } MG_FCTXT;
95
96 extern MG_FCTXT *mg_file; /* current file context */
97
98 #ifdef NOPROTO
99 extern void mg_init(); /* fill in mg_ehand array */
100 extern int mg_load(); /* parse a file */
101 extern int mg_open(); /* open new input file */
102 extern int mg_read(); /* read next line */
103 extern int mg_parse(); /* parse current line */
104 extern int mg_rewind(); /* rewind input file */
105 extern void mg_close(); /* close input file */
106 extern void mg_clear(); /* clear parser */
107 extern int mg_iterate();
108 #else
109 extern void mg_init(void); /* fill in mg_ehand array */
110 extern int mg_load(char *); /* parse a file */
111 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
112 extern int mg_read(void); /* read next line */
113 extern int mg_parse(void); /* parse current line */
114 extern int mg_rewind(void); /* rewind input file */
115 extern void mg_close(void); /* close input file */
116 extern void mg_clear(void); /* clear parser */
117 extern int mg_iterate(int, char **, int (*)(void));
118 #endif
119
120 #ifndef MG_NQCD
121 #define MG_NQCD 5 /* default number of divisions */
122 #endif
123
124 extern int mg_nqcdivs; /* divisions per quarter circle */
125
126 /*
127 * The following library routines are included for your convenience:
128 */
129
130 #ifdef NOPROTO
131 extern int mg_entity(); /* get entity number from its name */
132 extern int isint(); /* non-zero if integer format */
133 extern int isflt(); /* non-zero if floating point format */
134 #else
135 extern int mg_entity(char *); /* get entity number from its name */
136 extern int isint(char *); /* non-zero if integer format */
137 extern int isflt(char *); /* non-zero if floating point format */
138 #endif
139
140 /************************************************************************
141 * Definitions for 3-d vector manipulation functions
142 */
143
144 #ifdef SMLFLT
145 #define FLOAT float
146 #define FTINY (1e-3)
147 #else
148 #define FLOAT double
149 #define FTINY (1e-6)
150 #endif
151 #define FHUGE (1e10)
152
153 typedef FLOAT FVECT[3];
154
155 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
156 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
157 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
158 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
159 (vr)[2]=(v1)[2]+(f)*(v2)[2])
160
161 #define is0vect(v) (DOT(v,v) < FTINY*FTINY)
162
163 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
164
165 #ifdef NOPROTO
166 extern double normalize(); /* normalize a vector */
167 #else
168 extern double normalize(FVECT); /* normalize a vector */
169 #endif
170
171 /************************************************************************
172 * Definitions for context handling routines
173 * (materials, colors, vectors)
174 */
175
176 typedef struct {
177 float cx, cy; /* XY chromaticity coordinates */
178 } C_COLOR; /* color context */
179
180 typedef struct {
181 char *name; /* material name */
182 int clock; /* incremented each change -- resettable */
183 float rd; /* diffuse reflectance */
184 C_COLOR rd_c; /* diffuse reflectance color */
185 float td; /* diffuse transmittance */
186 C_COLOR td_c; /* diffuse transmittance color */
187 float ed; /* diffuse emittance */
188 C_COLOR ed_c; /* diffuse emittance color */
189 float rs; /* specular reflectance */
190 C_COLOR rs_c; /* specular reflectance color */
191 float rs_a; /* specular reflectance roughness */
192 float ts; /* specular transmittance */
193 C_COLOR ts_c; /* specular transmittance color */
194 float ts_a; /* specular transmittance roughness */
195 } C_MATERIAL; /* material context */
196
197 typedef struct {
198 FVECT p, n; /* point and normal */
199 } C_VERTEX; /* vertex context */
200
201 #define isgrey(cxy) ((cxy)->cx > .31 && (cxy)->cx < .35 && \
202 (cxy)->cy > .31 && (cxy)->cy < .35)
203
204 #define C_DEFCOLOR {.333,.333}
205 #define C_DEFMATERIAL {NULL,1,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\
206 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
207 #define C_DEFVERTEX {{0.,0.,0.},{0.,0.,0.}}
208
209 extern C_COLOR *c_ccolor; /* the current color */
210 extern C_MATERIAL *c_cmaterial; /* the current material */
211 extern C_VERTEX *c_cvertex; /* the current vertex */
212
213 #ifdef NOPROTO
214 extern int c_hcolor(); /* handle color entity */
215 extern int c_hmaterial(); /* handle material entity */
216 extern int c_hvertex(); /* handle vertex entity */
217 extern void c_clearall(); /* clear context tables */
218 extern C_VERTEX *c_getvert(); /* get a named vertex */
219 #else
220 extern int c_hcolor(int, char **); /* handle color entity */
221 extern int c_hmaterial(int, char **); /* handle material entity */
222 extern int c_hvertex(int, char **); /* handle vertex entity */
223 extern void c_clearall(void); /* clear context tables */
224 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
225 #endif
226
227 /*************************************************************************
228 * Definitions for hierarchical object name handler
229 */
230
231 extern int obj_nnames; /* depth of name hierarchy */
232 extern char **obj_name; /* names in hierarchy */
233
234 #ifdef NOPROTO
235 extern int obj_handler(); /* handle an object entity */
236 extern void obj_clear(); /* clear object stack */
237 #else
238 extern int obj_handler(int, char **); /* handle an object entity */
239 extern void obj_clear(void); /* clear object stack */
240 #endif
241
242 /**************************************************************************
243 * Definitions for hierarchical transformation handler
244 */
245
246 typedef FLOAT MAT4[4][4];
247
248 #ifdef BSD
249 #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4))
250 #else
251 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
252 extern char *memcpy();
253 #endif
254
255 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
256 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
257
258 extern MAT4 m4ident;
259
260 #define setident4(m4) copymat4(m4, m4ident)
261
262 /* regular transformation */
263 typedef struct {
264 MAT4 xfm; /* transform matrix */
265 FLOAT sca; /* scalefactor */
266 } XF;
267
268 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
269
270 typedef struct xf_spec {
271 short xac; /* transform argument count */
272 short xav0; /* zeroeth argument in xf_argv array */
273 XF xf; /* cumulative transformation */
274 struct xf_spec *prev; /* previous transformation context */
275 } XF_SPEC;
276
277 extern int xf_argc; /* total # transform args. */
278 extern char **xf_argv; /* transform arguments */
279 extern XF_SPEC *xf_context; /* current context */
280
281 /*
282 * The transformation handler should do most of the work that needs
283 * doing. Just pass it any xf entities, then use the associated
284 * functions to transform and translate points, transform vectors
285 * (without translation), rotate vectors (without scaling) and scale
286 * values appropriately.
287 *
288 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
289 * 3-D vectors (which may be identical), transforms the second and
290 * puts the result into the first.
291 */
292
293 #ifdef NOPROTO
294
295 extern int xf_handler(); /* handle xf entity */
296 extern void xf_xfmpoint(); /* transform point */
297 extern void xf_xfmvect(); /* transform vector */
298 extern void xf_rotvect(); /* rotate vector */
299 extern double xf_scale(); /* scale a value */
300 extern void xf_clear(); /* clear xf stack */
301
302 /* The following are support routines you probably won't call directly */
303
304 extern void multmat4(); /* m4a = m4b X m4c */
305 extern void multv3(); /* v3a = v3b X m4 (vectors) */
306 extern void multp3(); /* p3a = p3b X m4 (points) */
307 extern int xf(); /* interpret transform spec. */
308
309 #else
310
311 extern int xf_handler(int, char **); /* handle xf entity */
312 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
313 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
314 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
315 extern double xf_scale(double); /* scale a value */
316 extern void xf_clear(void); /* clear xf stack */
317
318 /* The following are support routines you probably won't call directly */
319
320 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
321 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
322 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
323 extern int xf(XF, int, char **); /* interpret transform spec. */
324
325 #endif
326
327 /************************************************************************
328 * Miscellaneous definitions
329 */
330
331 #ifdef M_PI
332 #define PI M_PI
333 #else
334 #define PI 3.14159265358979323846
335 #endif
336
337 #ifdef DCL_ATOF
338 extern double atof();
339 #endif
340
341 #ifndef MEM_PTR
342 #define MEM_PTR void *
343 #endif
344
345 extern MEM_PTR malloc();
346 extern MEM_PTR calloc();
347 extern MEM_PTR realloc();
