root/radiance/ray/src/cv/mgflib/parser.h
Revision: 1.32
Committed: Fri Jan 16 10:47:27 1998 UTC (26 years, 5 months ago) by gregl
changed M_PI definition to ward off long double problems
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for MGF interpreter
7 */
8
9 #ifndef MG_VMAJOR
10
11 /* must include stdio.h before us */
12
13 #define MG_VMAJOR 2 /* major version number */
14 #define MG_VMINOR 0 /* minor version number */
15
16 /* Entities (list is only appended, never modified) */
17 #define MG_E_COMMENT 0 /* # */
18 #define MG_E_COLOR 1 /* c */
19 #define MG_E_CCT 2 /* cct */
20 #define MG_E_CONE 3 /* cone */
21 #define MG_E_CMIX 4 /* cmix */
22 #define MG_E_CSPEC 5 /* cspec */
23 #define MG_E_CXY 6 /* cxy */
24 #define MG_E_CYL 7 /* cyl */
25 #define MG_E_ED 8 /* ed */
26 #define MG_E_FACE 9 /* f */
27 #define MG_E_INCLUDE 10 /* i */
28 #define MG_E_IES 11 /* ies */
29 #define MG_E_IR 12 /* ir */
30 #define MG_E_MATERIAL 13 /* m */
31 #define MG_E_NORMAL 14 /* n */
32 #define MG_E_OBJECT 15 /* o */
33 #define MG_E_POINT 16 /* p */
34 #define MG_E_PRISM 17 /* prism */
35 #define MG_E_RD 18 /* rd */
36 #define MG_E_RING 19 /* ring */
37 #define MG_E_RS 20 /* rs */
38 #define MG_E_SIDES 21 /* sides */
39 #define MG_E_SPH 22 /* sph */
40 #define MG_E_TD 23 /* td */
41 #define MG_E_TORUS 24 /* torus */
42 #define MG_E_TS 25 /* ts */
43 #define MG_E_VERTEX 26 /* v */
44 #define MG_E_XF 27 /* xf */
45 /* end of Version 1 entities */
46 #define MG_E_FACEH 28 /* fh */
47 /* end of Version 2 entities */
48
49 #define MG_NENTITIES 29 /* total # entities */
50
51 #define MG_NELIST {28,29} /* entity count for version 1 and up */
52
53 #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\
54 "f","i","ies","ir","m","n","o","p","prism","rd",\
55 "ring","rs","sides","sph","td","torus","ts","v","xf",\
56 "fh"}
57
58 #define MG_MAXELEN 6
59
60 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
61
62 /* Handler routines for each entity and unknown ones */
63 #ifdef NOPROTO
64 extern int (*mg_ehand[MG_NENTITIES])();
65 extern int (*mg_uhand)();
66 extern int mg_defuhand();
67 #else
68 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
69 extern int (*mg_uhand)(int argc, char **argv);
70 extern int mg_defuhand(int, char **);
71 #endif
72
73 extern unsigned mg_nunknown; /* count of unknown entities */
74
75 /* Error codes */
76 #define MG_OK 0 /* normal return value */
77 #define MG_EUNK 1 /* unknown entity */
78 #define MG_EARGC 2 /* wrong number of arguments */
79 #define MG_ETYPE 3 /* argument type error */
80 #define MG_EILL 4 /* illegal argument value */
81 #define MG_EUNDEF 5 /* undefined reference */
82 #define MG_ENOFILE 6 /* cannot open input file */
83 #define MG_EINCL 7 /* error in included file */
84 #define MG_EMEM 8 /* out of memory */
85 #define MG_ESEEK 9 /* file seek error */
86 #define MG_EBADMAT 10 /* bad material specification */
87 #define MG_ELINE 11 /* input line too long */
88 #define MG_ECNTXT 12 /* unmatched context close */
89
90 #define MG_NERRS 13
91
92 extern char *mg_err[MG_NERRS]; /* list of error messages */
93
94 /*
95 * The general process for running the parser is to fill in the mg_ehand
96 * array with handlers for each entity you know how to handle.
97 * Then, call mg_init to fill in the rest. This function will report
98 * an error and quit if you try to support an inconsistent set of entities.
99 * For each file you want to parse, call mg_load with the file name.
100 * To read from standard input, use NULL as the file name.
101 * For additional control over error reporting and file management,
102 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
103 * To pass an entity of your own construction to the parser, use
104 * the mg_handle function rather than the mg_ehand routines directly.
105 * (The first argument to mg_handle is the entity #, or -1.)
106 * To free any data structures and clear the parser, use mg_clear.
107 * If there is an error, mg_load, mg_open, mg_parse, mg_handle and
108 * mg_fgoto will return an error from the list above. In addition,
109 * mg_load will report the error to stderr. The mg_read routine
110 * returns 0 when the end of file has been reached.
111 */
112
113 #define MG_MAXLINE 4096 /* maximum input line length */
114 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
115
116 typedef struct mg_fctxt {
117 char fname[96]; /* file name */
118 FILE *fp; /* stream pointer */
119 int fid; /* unique file context id */
120 char inpline[MG_MAXLINE]; /* input line */
121 int lineno; /* line number */
122 struct mg_fctxt *prev; /* previous context */
123 } MG_FCTXT;
124
125 typedef struct {
126 int fid; /* file this position is for */
127 int lineno; /* line number in file */
128 long offset; /* offset from beginning */
129 } MG_FPOS;
130
131 extern MG_FCTXT *mg_file; /* current file context */
132
133 #ifdef NOPROTO
134 extern void mg_init(); /* fill in mg_ehand array */
135 extern int mg_load(); /* parse a file */
136 extern int mg_open(); /* open new input file */
137 extern int mg_read(); /* read next line */
138 extern int mg_parse(); /* parse current line */
139 extern void mg_fgetpos(); /* get position on input file */
140 extern int mg_fgoto(); /* go to position on input file */
141 extern void mg_close(); /* close input file */
142 extern void mg_clear(); /* clear parser */
143 extern int mg_handle(); /* handle an entity */
144 #else
145 extern void mg_init(void); /* fill in mg_ehand array */
146 extern int mg_load(char *); /* parse a file */
147 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
148 extern int mg_read(void); /* read next line */
149 extern int mg_parse(void); /* parse current line */
150 extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
151 extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
152 extern void mg_close(void); /* close input file */
153 extern void mg_clear(void); /* clear parser */
154 extern int mg_handle(int, int, char **); /* handle an entity */
155 #endif
156
157 #ifndef MG_NQCD
158 #define MG_NQCD 5 /* default number of divisions */
159 #endif
160
161 extern int mg_nqcdivs; /* divisions per quarter circle */
162
163 /*
164 * The following library routines are included for your convenience:
165 */
166
167 #ifdef NOPROTO
168 extern int mg_entity(); /* get entity number from its name */
169 extern int isint(); /* non-zero if integer format */
170 extern int isintd(); /* same with delimiter set */
171 extern int isflt(); /* non-zero if floating point format */
172 extern int isfltd(); /* same with delimiter set */
173 extern int isname(); /* non-zero if legal identifier name */
174 extern int badarg(); /* check argument format */
175 extern int e_include(); /* expand include entity */
176 extern int e_pipe(); /* expand piped command */
177 extern int e_sph(); /* expand sphere as other entities */
178 extern int e_torus(); /* expand torus as other entities */
179 extern int e_cyl(); /* expand cylinder as other entities */
180 extern int e_ring(); /* expand ring as other entities */
181 extern int e_cone(); /* expand cone as other entities */
182 extern int e_prism(); /* expand prism as other entities */
183 extern int e_faceh(); /* expand face w/ holes as face */
184 #else
185 extern int mg_entity(char *); /* get entity number from its name */
186 extern int isint(char *); /* non-zero if integer format */
187 extern int isintd(char *, char *); /* same with delimiter set */
188 extern int isflt(char *); /* non-zero if floating point format */
189 extern int isfltd(char *, char *); /* same with delimiter set */
190 extern int isname(char *); /* non-zero if legal identifier name */
191 extern int badarg(int, char **, char *);/* check argument format */
192 extern int e_include(int, char **); /* expand include entity */
193 extern int e_pipe(int, char **); /* expand piped command */
194 extern int e_sph(int, char **); /* expand sphere as other entities */
195 extern int e_torus(int, char **); /* expand torus as other entities */
196 extern int e_cyl(int, char **); /* expand cylinder as other entities */
197 extern int e_ring(int, char **); /* expand ring as other entities */
198 extern int e_cone(int, char **); /* expand cone as other entities */
199 extern int e_prism(int, char **); /* expand prism as other entities */
200 extern int e_faceh(int, char **); /* expand face w/ holes as face */
201 #endif
202
203 /************************************************************************
204 * Definitions for 3-d vector manipulation functions
205 */
206
207 #ifdef SMLFLT
208 #define FLOAT float
209 #define FTINY (1e-3)
210 #else
211 #define FLOAT double
212 #define FTINY (1e-6)
213 #endif
214 #define FHUGE (1e10)
215
216 typedef FLOAT FVECT[3];
217
218 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
219 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
220 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
221 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
222 (vr)[2]=(v1)[2]+(f)*(v2)[2])
223
224 #define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
225
226 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
227
228 #ifdef NOPROTO
229 extern double normalize(); /* normalize a vector */
230 #else
231 extern double normalize(FVECT); /* normalize a vector */
232 extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */
233 #endif
234
235 /************************************************************************
236 * Definitions for context handling routines
237 * (materials, colors, vectors)
238 */
239
240 #define C_CMINWL 380 /* minimum wavelength */
241 #define C_CMAXWL 780 /* maximum wavelength */
242 #define C_CNSS 41 /* number of spectral samples */
243 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
244 #define C_CMAXV 10000 /* nominal maximum sample value */
245 #define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
246
247 #define C_CSSPEC 01 /* flag if spectrum is set */
248 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
249 #define C_CSXY 04 /* flag if xy is set */
250 #define C_CDXY 010 /* flag if defined w/ xy */
251 #define C_CSEFF 020 /* flag if efficacy set */
252
253 typedef struct {
254 int clock; /* incremented each change */
255 char *client_data; /* pointer to private client-owned data */
256 short flags; /* what's been set */
257 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
258 long ssum; /* straight sum of spectral values */
259 float cx, cy; /* xy chromaticity value */
260 float eff; /* efficacy (lumens/watt) */
261 } C_COLOR;
262
263 #define C_DEFCOLOR { 1, NULL, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\
264 {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
265 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
266 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
267 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
268 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
269 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
270 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\
271 (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 }
272
273 #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum)
274
275 #define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
276
277 typedef struct {
278 int clock; /* incremented each change -- resettable */
279 char *client_data; /* pointer to private client-owned data */
280 int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
281 float nr, ni; /* index of refraction, real and imaginary */
282 float rd; /* diffuse reflectance */
283 C_COLOR rd_c; /* diffuse reflectance color */
284 float td; /* diffuse transmittance */
285 C_COLOR td_c; /* diffuse transmittance color */
286 float ed; /* diffuse emittance */
287 C_COLOR ed_c; /* diffuse emittance color */
288 float rs; /* specular reflectance */
289 C_COLOR rs_c; /* specular reflectance color */
290 float rs_a; /* specular reflectance roughness */
291 float ts; /* specular transmittance */
292 C_COLOR ts_c; /* specular transmittance color */
293 float ts_a; /* specular transmittance roughness */
294 } C_MATERIAL; /* material context */
295
296 typedef struct {
297 int clock; /* incremented each change -- resettable */
298 char *client_data; /* pointer to private client-owned data */
299 FVECT p, n; /* point and normal */
300 } C_VERTEX; /* vertex context */
301
302 #define C_DEFMATERIAL {1,NULL,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,\
303 C_DEFCOLOR,0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
304 #define C_DEFVERTEX {1,NULL,{0.,0.,0.},{0.,0.,0.}}
305
306 extern C_COLOR *c_ccolor; /* the current color */
307 extern char *c_ccname; /* current color name */
308 extern C_MATERIAL *c_cmaterial; /* the current material */
309 extern char *c_cmname; /* current material name */
310 extern C_VERTEX *c_cvertex; /* the current vertex */
311 extern char *c_cvname; /* current vertex name */
312
313 #ifdef NOPROTO
314 extern int c_hcolor(); /* handle color entity */
315 extern int c_hmaterial(); /* handle material entity */
316 extern int c_hvertex(); /* handle vertex entity */
317 extern void c_clearall(); /* clear context tables */
318 extern C_MATERIAL *c_getmaterial(); /* get a named material */
319 extern C_VERTEX *c_getvert(); /* get a named vertex */
320 extern C_COLOR *c_getcolor(); /* get a named color */
321 extern void c_ccvt(); /* fix color representation */
322 extern int c_isgrey(); /* check if color is grey */
323 #else
324 extern int c_hcolor(int, char **); /* handle color entity */
325 extern int c_hmaterial(int, char **); /* handle material entity */
326 extern int c_hvertex(int, char **); /* handle vertex entity */
327 extern void c_clearall(void); /* clear context tables */
328 extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
329 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
330 extern C_COLOR *c_getcolor(char *); /* get a named color */
331 extern void c_ccvt(C_COLOR *, int); /* fix color representation */
332 extern int c_isgrey(C_COLOR *); /* check if color is grey */
333 #endif
334
335 /*************************************************************************
336 * Definitions for hierarchical object name handler
337 */
338
339 extern int obj_nnames; /* depth of name hierarchy */
340 extern char **obj_name; /* names in hierarchy */
341
342 #ifdef NOPROTO
343 extern int obj_handler(); /* handle an object entity */
344 extern void obj_clear(); /* clear object stack */
345 #else
346 extern int obj_handler(int, char **); /* handle an object entity */
347 extern void obj_clear(void); /* clear object stack */
348 #endif
349
350 /**************************************************************************
351 * Definitions for hierarchical transformation handler
352 */
353
354 typedef FLOAT MAT4[4][4];
355
356 #ifdef BSD
357 #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4))
358 #else
359 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
360 #endif
361
362 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
363 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
364
365 extern MAT4 m4ident;
366
367 #define setident4(m4) copymat4(m4, m4ident)
368
369 /* regular transformation */
370 typedef struct {
371 MAT4 xfm; /* transform matrix */
372 FLOAT sca; /* scalefactor */
373 } XF;
374
375 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
376
377 #define XF_MAXDIM 8 /* maximum array dimensions */
378
379 struct xf_array {
380 MG_FPOS spos; /* starting position on input */
381 int ndim; /* number of array dimensions */
382 struct {
383 short i, n; /* current count and maximum */
384 char arg[8]; /* string argument value */
385 } aarg[XF_MAXDIM];
386 };
387
388 typedef struct xf_spec {
389 long xid; /* unique transform id */
390 short xac; /* context argument count */
391 short rev; /* boolean true if vertices reversed */
392 XF xf; /* cumulative transformation */
393 struct xf_array *xarr; /* transformation array pointer */
394 struct xf_spec *prev; /* previous transformation context */
395 } XF_SPEC; /* followed by argument buffer */
396
397 extern XF_SPEC *xf_context; /* current transform context */
398 extern char **xf_argend; /* last transform argument */
399
400 #define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac)
401 #define xf_av(xf) (xf_argend - (xf)->xac)
402
403 #define xf_argc xf_ac(xf_context)
404 #define xf_argv xf_av(xf_context)
405
406 /*
407 * The transformation handler should do most of the work that needs
408 * doing. Just pass it any xf entities, then use the associated
409 * functions to transform and translate points, transform vectors
410 * (without translation), rotate vectors (without scaling) and scale
411 * values appropriately.
412 *
413 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
414 * 3-D vectors (which may be identical), transforms the second and
415 * puts the result into the first.
416 */
417
418 #ifdef NOPROTO
419
420 extern int xf_handler(); /* handle xf entity */
421 extern void xf_xfmpoint(); /* transform point */
422 extern void xf_xfmvect(); /* transform vector */
423 extern void xf_rotvect(); /* rotate vector */
424 extern double xf_scale(); /* scale a value */
425 extern void xf_clear(); /* clear xf stack */
426
427 /* The following are support routines you probably won't call directly */
428
429 XF_SPEC *new_xf(); /* allocate new transform */
430 void free_xf(); /* free a transform */
431 int xf_aname(); /* name this instance */
432 long comp_xfid(); /* compute unique ID */
433 extern void multmat4(); /* m4a = m4b X m4c */
434 extern void multv3(); /* v3a = v3b X m4 (vectors) */
435 extern void multp3(); /* p3a = p3b X m4 (points) */
436 extern int xf(); /* interpret transform spec. */
437
438 #else
439
440 extern int xf_handler(int, char **); /* handle xf entity */
441 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
442 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
443 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
444 extern double xf_scale(double); /* scale a value */
445 extern void xf_clear(void); /* clear xf stack */
446
447 /* The following are support routines you probably won't call directly */
448
449 XF_SPEC *new_xf(int, char **); /* allocate new transform */
450 void free_xf(XF_SPEC *); /* free a transform */
451 int xf_aname(struct xf_array *); /* name this instance */
452 long comp_xfid(MAT4); /* compute unique ID */
453 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
454 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
455 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
456 extern int xf(XF *, int, char **); /* interpret transform spec. */
457
458 #endif
459
460 /************************************************************************
461 * Miscellaneous definitions
462 */
463
464 #ifndef PI
465 #ifdef M_PI
466 #define PI ((double)M_PI)
467 #else
468 #define PI 3.14159265358979323846
469 #endif
470 #endif
471
472 #ifdef DCL_ATOF
473 extern double atof();
474 #endif
475
476 #ifndef MEM_PTR
477 #define MEM_PTR void *
478 #endif
479
480 extern MEM_PTR malloc();
481 extern MEM_PTR calloc();
482 extern MEM_PTR realloc();
483 extern void free();
484
485 #endif /*MG_VMAJOR*/
