root/Development/ray/src/cv/mgflib/parser.h
Revision: 1.11
Committed: Thu Jun 30 11:07:38 1994 UTC (31 years, 2 months ago) by greg
added c_getmaterial() call
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for MGF interpreter
7 */
8
9 /* must include stdio.h before us */
10
11 /* Entities (order doesn't really matter) */
12 #define MG_E_COMMENT 0
13 #define MG_E_COLOR 1
14 #define MG_E_CONE 2
15 #define MG_E_CMIX 3
16 #define MG_E_CSPEC 4
17 #define MG_E_CXY 5
18 #define MG_E_CYL 6
19 #define MG_E_ED 7
20 #define MG_E_FACE 8
21 #define MG_E_INCLUDE 9
22 #define MG_E_IES 10
23 #define MG_E_MATERIAL 11
24 #define MG_E_NORMAL 12
25 #define MG_E_OBJECT 13
26 #define MG_E_POINT 14
27 #define MG_E_PRISM 15
28 #define MG_E_RD 16
29 #define MG_E_RING 17
30 #define MG_E_RS 18
31 #define MG_E_SPH 19
32 #define MG_E_TD 20
33 #define MG_E_TORUS 21
34 #define MG_E_TS 22
35 #define MG_E_VERTEX 23
36 #define MG_E_XF 24
37
38 #define MG_NENTITIES 25
39
40 #define MG_NAMELIST {"#","c","cone","cmix","cspec","cxy","cyl","ed","f",\
41 "i","ies","m","n","o","p","prism","rd","ring","rs",\
42 "sph","td","torus","ts","v","xf"}
43
44 #define MG_MAXELEN 6
45
46 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
47
48 /* Handler routines for each entity */
49
50 #ifdef NOPROTO
51 extern int (*mg_ehand[MG_NENTITIES])();
52 #else
53 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
54 #endif
55
56 /* Error codes */
57 #define MG_OK 0 /* normal return value */
58 #define MG_EUNK 1 /* unknown entity */
59 #define MG_EARGC 2 /* wrong number of arguments */
60 #define MG_ETYPE 3 /* argument type error */
61 #define MG_EILL 4 /* illegal argument value */
62 #define MG_EUNDEF 5 /* undefined reference */
63 #define MG_ENOFILE 6 /* cannot open input file */
64 #define MG_EINCL 7 /* error in included file */
65 #define MG_EMEM 8 /* out of memory */
66 #define MG_ESEEK 9 /* file seek error */
67 #define MG_EBADMAT 10 /* bad material specification */
68
69 #define MG_NERRS 11
70
71 extern char *mg_err[MG_NERRS];
72
73 /*
74 * The general process for running the parser is to fill in the mg_ehand
75 * array with handlers for each entity you know how to handle.
76 * Then, call mg_init to fill in the rest. This function will report
77 * an error and quit if you try to support an inconsistent set of entities.
78 * For each file you want to parse, call mg_load with the file name.
79 * To read from standard input, use NULL as the file name.
80 * For additional control over error reporting and file management,
81 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
82 * To pass an entity of your own construction to the parser, use
83 * the mg_handle function rather than the mg_ehand routines directly.
84 * (The first argument to mg_handle is the entity #, or -1.)
85 * To free any data structures and clear the parser, use mg_clear.
86 * If there is an error, mg_load, mg_open, mg_parse, and mg_rewind
87 * will return an error from the list above. In addition, mg_load
88 * will report the error to stderr. The mg_read routine returns 0
89 * when the end of file has been reached.
90 */
91
92 #define MG_MAXLINE 512 /* maximum input line length */
93 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
94
95 typedef struct mg_fctxt {
96 char fname[96]; /* file name */
97 FILE *fp; /* stream pointer */
98 int fid; /* unique file context id */
99 char inpline[MG_MAXLINE]; /* input line */
100 int lineno; /* line number */
101 struct mg_fctxt *prev; /* previous context */
102 } MG_FCTXT;
103
104 typedef struct {
105 int fid; /* file this position is for */
106 int lineno; /* line number in file */
107 long offset; /* offset from beginning */
108 } MG_FPOS;
109
110 extern MG_FCTXT *mg_file; /* current file context */
111
112 #ifdef NOPROTO
113 extern void mg_init(); /* fill in mg_ehand array */
114 extern int mg_load(); /* parse a file */
115 extern int mg_open(); /* open new input file */
116 extern int mg_read(); /* read next line */
117 extern int mg_parse(); /* parse current line */
118 extern void mg_fgetpos(); /* get position on input file */
119 extern int mg_fgoto(); /* go to position on input file */
120 extern void mg_close(); /* close input file */
121 extern void mg_clear(); /* clear parser */
122 extern int mg_handle(); /* handle an entity */
123 #else
124 extern void mg_init(void); /* fill in mg_ehand array */
125 extern int mg_load(char *); /* parse a file */
126 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
127 extern int mg_read(void); /* read next line */
128 extern int mg_parse(void); /* parse current line */
129 extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
130 extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
131 extern void mg_close(void); /* close input file */
132 extern void mg_clear(void); /* clear parser */
133 extern int mg_handle(int, int, char **); /* handle an entity */
134 #endif
135
136 #ifndef MG_NQCD
137 #define MG_NQCD 5 /* default number of divisions */
138 #endif
139
140 extern int mg_nqcdivs; /* divisions per quarter circle */
141
142 /*
143 * The following library routines are included for your convenience:
144 */
145
146 #ifdef NOPROTO
147 extern int mg_entity(); /* get entity number from its name */
148 extern int isint(); /* non-zero if integer format */
149 extern int isflt(); /* non-zero if floating point format */
150 #else
151 extern int mg_entity(char *); /* get entity number from its name */
152 extern int isint(char *); /* non-zero if integer format */
153 extern int isflt(char *); /* non-zero if floating point format */
154 #endif
155
156 /************************************************************************
157 * Definitions for 3-d vector manipulation functions
158 */
159
160 #ifdef SMLFLT
161 #define FLOAT float
162 #define FTINY (1e-3)
163 #else
164 #define FLOAT double
165 #define FTINY (1e-6)
166 #endif
167 #define FHUGE (1e10)
168
169 typedef FLOAT FVECT[3];
170
171 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
172 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
173 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
174 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
175 (vr)[2]=(v1)[2]+(f)*(v2)[2])
176
177 #define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
178
179 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
180
181 #ifdef NOPROTO
182 extern double normalize(); /* normalize a vector */
183 #else
184 extern double normalize(FVECT); /* normalize a vector */
185 #endif
186
187 /************************************************************************
188 * Definitions for context handling routines
189 * (materials, colors, vectors)
190 */
191
192 #define C_CMINWL 380 /* minimum wavelength */
193 #define C_CMAXWL 780 /* maximum wavelength */
194 #define C_CNSS 41 /* number of spectral samples */
195 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
196 #define C_CMAXV 10000 /* nominal maximum sample value */
197
198 #define C_CSSPEC 01 /* flag if spectrum is set */
199 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
200 #define C_CSXY 04 /* flag if xy is set */
201 #define C_CDXY 010 /* flag if defined w/ xy */
202
203 typedef struct {
204 char *name; /* material name */
205 int clock; /* incremented each change */
206 short flags; /* what's been set */
207 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
208 long ssum; /* straight sum of spectral values */
209 float cx, cy; /* xy chromaticity value */
210 } C_COLOR;
211
212 #define C_DEFCOLOR { NULL, 0, C_CDXY|C_CSXY|C_CSSPEC,\
213 {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
214 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
215 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
216 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
217 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
218 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
219 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\
220 (long)C_CNSS*C_CMAXV, 1./3., 1./3. }
221
222 #define C_CIEX { "_cie_x", 0, C_CDSPEC|C_CSSPEC|C_CSXY,\
223 {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\
224 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\
225 10622,10026,8544,6424,4479,2835,1649,874,468,227,\
226 114,58,29,14,7,3,2,1,0}, 106836L, .735, .265 }
227
228 #define C_CIEY { "_cie_y", 0, C_CDSPEC|C_CSSPEC|C_CSXY,\
229 {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\
230 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\
231 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\
232 5,2,1,1,0,0}, 106856L, .274, .717 }
233
234 #define C_CIEZ { "_cie_z", 0, C_CDSPEC|C_CSSPEC|C_CSXY,\
235 {65,201,679,2074,6456,13856,17471,17721,16692,\
236 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\
237 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\
238 106770L, .167, .009 }
239
240 #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->sum)
241
242 typedef struct {
243 char *name; /* material name */
244 int clock; /* incremented each change -- resettable */
245 float rd; /* diffuse reflectance */
246 C_COLOR rd_c; /* diffuse reflectance color */
247 float td; /* diffuse transmittance */
248 C_COLOR td_c; /* diffuse transmittance color */
249 float ed; /* diffuse emittance */
250 C_COLOR ed_c; /* diffuse emittance color */
251 float rs; /* specular reflectance */
252 C_COLOR rs_c; /* specular reflectance color */
253 float rs_a; /* specular reflectance roughness */
254 float ts; /* specular transmittance */
255 C_COLOR ts_c; /* specular transmittance color */
256 float ts_a; /* specular transmittance roughness */
257 } C_MATERIAL; /* material context */
258
259 typedef struct {
260 char *name; /* vector name */
261 int clock; /* incremented each change -- resettable */
262 FVECT p, n; /* point and normal */
263 } C_VERTEX; /* vertex context */
264
265 #define C_DEFMATERIAL {NULL,0,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\
266 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
267 #define C_DEFVERTEX {NULL,0,{0.,0.,0.},{0.,0.,0.}}
268
269 extern C_COLOR *c_ccolor; /* the current color */
270 extern C_MATERIAL *c_cmaterial; /* the current material */
271 extern C_VERTEX *c_cvertex; /* the current vertex */
272
273 #ifdef NOPROTO
274 extern int c_hcolor(); /* handle color entity */
275 extern int c_hmaterial(); /* handle material entity */
276 extern int c_hvertex(); /* handle vertex entity */
277 extern void c_clearall(); /* clear context tables */
278 extern C_MATERIAL *c_getmaterial(); /* get a named material */
279 extern C_VERTEX *c_getvert(); /* get a named vertex */
280 extern C_COLOR *c_getcolor(); /* get a named color */
281 extern void c_ccvt(); /* fix color representation */
282 extern int c_isgrey(); /* check if color is grey */
283 #else
284 extern int c_hcolor(int, char **); /* handle color entity */
285 extern int c_hmaterial(int, char **); /* handle material entity */
286 extern int c_hvertex(int, char **); /* handle vertex entity */
287 extern void c_clearall(void); /* clear context tables */
288 extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
289 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
290 extern C_COLOR *c_getcolor(char *); /* get a named color */
291 extern void c_ccvt(C_COLOR *, int); /* fix color representation */
292 extern int c_isgrey(C_COLOR *); /* check if color is grey */
293 #endif
294
295 /*************************************************************************
296 * Definitions for hierarchical object name handler
297 */
298
299 extern int obj_nnames; /* depth of name hierarchy */
300 extern char **obj_name; /* names in hierarchy */
301
302 #ifdef NOPROTO
303 extern int obj_handler(); /* handle an object entity */
304 extern void obj_clear(); /* clear object stack */
305 #else
306 extern int obj_handler(int, char **); /* handle an object entity */
307 extern void obj_clear(void); /* clear object stack */
308 #endif
309
310 /**************************************************************************
311 * Definitions for hierarchical transformation handler
312 */
313
314 typedef FLOAT MAT4[4][4];
315
316 #ifdef BSD
317 #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4))
318 #else
319 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
320 #endif
321
322 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
323 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
324
325 extern MAT4 m4ident;
326
327 #define setident4(m4) copymat4(m4, m4ident)
328
329 /* regular transformation */
330 typedef struct {
331 MAT4 xfm; /* transform matrix */
332 FLOAT sca; /* scalefactor */
333 } XF;
334
335 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
336
337 #define XF_MAXDIM 8 /* maximum array dimensions */
338
339 struct xf_array {
340 MG_FPOS spos; /* starting position on input */
341 int ndim; /* number of array dimensions */
342 struct {
343 short i, n; /* current count and maximum */
344 char arg[8]; /* string argument value */
345 } aarg[XF_MAXDIM];
346 };
347
348 typedef struct xf_spec {
349 long xid; /* unique transform id */
350 short xav0; /* zeroeth argument in xf_argv array */
351 short xac; /* transform argument count */
352 XF xf; /* cumulative transformation */
353 struct xf_array *xarr; /* transformation array pointer */
354 struct xf_spec *prev; /* previous transformation context */
355 } XF_SPEC; /* followed by argument buffer */
356
357 extern int xf_argc; /* total # transform args. */
358 extern char **xf_argv; /* transform arguments */
359 extern XF_SPEC *xf_context; /* current context */
360
361 /*
362 * The transformation handler should do most of the work that needs
363 * doing. Just pass it any xf entities, then use the associated
364 * functions to transform and translate points, transform vectors
365 * (without translation), rotate vectors (without scaling) and scale
366 * values appropriately.
367 *
368 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
369 * 3-D vectors (which may be identical), transforms the second and
370 * puts the result into the first.
371 */
372
373 #ifdef NOPROTO
374
375 extern int xf_handler(); /* handle xf entity */
376 extern void xf_xfmpoint(); /* transform point */
377 extern void xf_xfmvect(); /* transform vector */
378 extern void xf_rotvect(); /* rotate vector */
379 extern double xf_scale(); /* scale a value */
380 extern void xf_clear(); /* clear xf stack */
381
382 /* The following are support routines you probably won't call directly */
383
384 extern void multmat4(); /* m4a = m4b X m4c */
385 extern void multv3(); /* v3a = v3b X m4 (vectors) */
386 extern void multp3(); /* p3a = p3b X m4 (points) */
387 extern int xf(); /* interpret transform spec. */
388
389 #else
390
391 extern int xf_handler(int, char **); /* handle xf entity */
392 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
393 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
394 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
395 extern double xf_scale(double); /* scale a value */
396 extern void xf_clear(void); /* clear xf stack */
397
398 /* The following are support routines you probably won't call directly */
399
400 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
401 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
402 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
403 extern int xf(XF *, int, char **); /* interpret transform spec. */
404
405 #endif
406
407 /************************************************************************
408 * Miscellaneous definitions
409 */
410
411 #ifdef M_PI
412 #define PI M_PI
413 #else
414 #define PI 3.14159265358979323846
415 #endif
416
417 #ifdef DCL_ATOF
418 extern double atof();
419 #endif
420
421 #ifndef MEM_PTR
422 #define MEM_PTR void *
423 #endif
424
425 extern MEM_PTR malloc();
426 extern MEM_PTR calloc();
427 extern MEM_PTR realloc();
428 extern void free();
