--- ray/src/cv/mgflib/parser.h 1994/06/22 17:15:46 1.3 +++ ray/src/cv/mgflib/parser.h 1994/06/25 16:33:17 1.9 @@ -12,30 +12,34 @@ #define MG_E_COMMENT 0 #define MG_E_COLOR 1 #define MG_E_CONE 2 -#define MG_E_CXY 3 -#define MG_E_CYL 4 -#define MG_E_ED 5 -#define MG_E_FACE 6 -#define MG_E_INCLUDE 7 -#define MG_E_IES 8 -#define MG_E_MATERIAL 9 -#define MG_E_NORMAL 10 -#define MG_E_OBJECT 11 -#define MG_E_POINT 12 -#define MG_E_RD 13 -#define MG_E_RING 14 -#define MG_E_RS 15 -#define MG_E_SPH 16 -#define MG_E_TD 17 -#define MG_E_TORUS 18 -#define MG_E_TS 19 -#define MG_E_VERTEX 20 -#define MG_E_XF 21 +#define MG_E_CMIX 3 +#define MG_E_CSPEC 4 +#define MG_E_CXY 5 +#define MG_E_CYL 6 +#define MG_E_ED 7 +#define MG_E_FACE 8 +#define MG_E_INCLUDE 9 +#define MG_E_IES 10 +#define MG_E_MATERIAL 11 +#define MG_E_NORMAL 12 +#define MG_E_OBJECT 13 +#define MG_E_POINT 14 +#define MG_E_PRISM 15 +#define MG_E_RD 16 +#define MG_E_RING 17 +#define MG_E_RS 18 +#define MG_E_SPH 19 +#define MG_E_TD 20 +#define MG_E_TORUS 21 +#define MG_E_TS 22 +#define MG_E_VERTEX 23 +#define MG_E_XF 24 -#define MG_NENTITIES 22 +#define MG_NENTITIES 25 -#define MG_NAMELIST {"#","c","cone","cxy","cyl","ed","f","i","ies",\ - "m","n","o","p","rd","ring","rs","sph","td","torus","ts","v","xf"} +#define MG_NAMELIST {"#","c","cone","cmix","cspec","cxy","cyl","ed","f",\ + "i","ies","m","n","o","p","prism","rd","ring","rs",\ + "sph","td","torus","ts","v","xf"} #define MG_MAXELEN 6 @@ -86,7 +90,7 @@ extern char *mg_err[MG_NERRS]; #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */ typedef struct mg_fctxt { - char *fname; /* file name */ + char fname[96]; /* file name */ FILE *fp; /* stream pointer */ char inpline[MG_MAXLINE]; /* input line */ int lineno; /* line number */ @@ -158,7 +162,7 @@ typedef FLOAT FVECT[3]; (vr)[1]=(v1)[1]+(f)*(v2)[1], \ (vr)[2]=(v1)[2]+(f)*(v2)[2]) -#define is0vect(v) (DOT(v,v) < FTINY*FTINY) +#define is0vect(v) (DOT(v,v) <= FTINY*FTINY) #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0 @@ -173,10 +177,56 @@ extern double normalize(FVECT); /* normalize a vector * (materials, colors, vectors) */ +#define C_CMINWL 380 /* minimum wavelength */ +#define C_CMAXWL 780 /* maximum wavelength */ +#define C_CNSS 41 /* number of spectral samples */ +#define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1)) +#define C_CMAXV 10000 /* nominal maximum sample value */ + +#define C_CSSPEC 01 /* flag if spectrum is set */ +#define C_CDSPEC 02 /* flag if defined w/ spectrum */ +#define C_CSXY 04 /* flag if xy is set */ +#define C_CDXY 010 /* flag if defined w/ xy */ + typedef struct { - float cx, cy; /* XY chromaticity coordinates */ -} C_COLOR; /* color context */ + char *name; /* material name */ + int clock; /* incremented each change */ + short flags; /* what's been set */ + short ssamp[C_CNSS]; /* spectral samples, min wl to max */ + long ssum; /* straight sum of spectral values */ + float cx, cy; /* xy chromaticity value */ +} C_COLOR; +#define C_DEFCOLOR { NULL, 0, C_CDXY|C_CSXY|C_CSSPEC,\ + {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ + C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ + (long)C_CNSS*C_CMAXV, 1./3., 1./3. } + +#define C_CIEX { "_cie_x", 0, C_CDSPEC|C_CSSPEC|C_CSXY,\ + {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ + 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ + 10622,10026,8544,6424,4479,2835,1649,874,468,227,\ + 114,58,29,14,7,3,2,1,0}, 106836L, .735, .265 } + +#define C_CIEY { "_cie_y", 0, C_CDSPEC|C_CSSPEC|C_CSXY,\ + {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ + 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ + 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ + 5,2,1,1,0,0}, 106856L, .274, .717 } + +#define C_CIEZ { "_cie_z", 0, C_CDSPEC|C_CSSPEC|C_CSXY,\ + {65,201,679,2074,6456,13856,17471,17721,16692,\ + 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ + 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\ + 106770L, .167, .009 } + +#define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->sum) + typedef struct { char *name; /* material name */ int clock; /* incremented each change -- resettable */ @@ -195,16 +245,14 @@ typedef struct { } C_MATERIAL; /* material context */ typedef struct { + char *name; /* vector name */ + int clock; /* incremented each change -- resettable */ FVECT p, n; /* point and normal */ } C_VERTEX; /* vertex context */ -#define isgrey(cxy) ((cxy)->cx > .31 && (cxy)->cx < .35 && \ - (cxy)->cy > .31 && (cxy)->cy < .35) - -#define C_DEFCOLOR {.333,.333} -#define C_DEFMATERIAL {NULL,1,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ +#define C_DEFMATERIAL {NULL,0,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} -#define C_DEFVERTEX {{0.,0.,0.},{0.,0.,0.}} +#define C_DEFVERTEX {NULL,0,{0.,0.,0.},{0.,0.,0.}} extern C_COLOR *c_ccolor; /* the current color */ extern C_MATERIAL *c_cmaterial; /* the current material */ @@ -216,12 +264,18 @@ extern int c_hmaterial(); /* handle material entity extern int c_hvertex(); /* handle vertex entity */ extern void c_clearall(); /* clear context tables */ extern C_VERTEX *c_getvert(); /* get a named vertex */ +extern C_COLOR *c_getcolor(); /* get a named color */ +extern void c_ccvt(); /* fix color representation */ +extern int c_isgrey(); /* check if color is grey */ #else extern int c_hcolor(int, char **); /* handle color entity */ extern int c_hmaterial(int, char **); /* handle material entity */ extern int c_hvertex(int, char **); /* handle vertex entity */ extern void c_clearall(void); /* clear context tables */ extern C_VERTEX *c_getvert(char *); /* get a named vertex */ +extern C_COLOR *c_getcolor(char *); /* get a named color */ +extern void c_ccvt(C_COLOR *, int); /* fix color representation */ +extern int c_isgrey(C_COLOR *); /* check if color is grey */ #endif /************************************************************************* @@ -249,7 +303,6 @@ typedef FLOAT MAT4[4][4]; #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4)) #else #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4)) -extern char *memcpy(); #endif #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \ @@ -268,6 +321,7 @@ typedef struct { #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0) typedef struct xf_spec { + long xid; /* unique transform id */ short xac; /* transform argument count */ short xav0; /* zeroeth argument in xf_argv array */ XF xf; /* cumulative transformation */ @@ -320,7 +374,7 @@ extern void xf_clear(void); /* clear xf stack */ extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */ extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */ extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */ -extern int xf(XF, int, char **); /* interpret transform spec. */ +extern int xf(XF *, int, char **); /* interpret transform spec. */ #endif @@ -345,3 +399,4 @@ extern double atof(); extern MEM_PTR malloc(); extern MEM_PTR calloc(); extern MEM_PTR realloc(); +extern void free();
