--- ray/src/cv/mgflib/parser.h 1995/03/07 14:53:17 1.18 +++ ray/src/cv/mgflib/parser.h 1995/05/11 09:12:12 1.23 @@ -1,4 +1,4 @@ -/* Copyright (c) 1994 Regents of the University of California */ +/* Copyright (c) 1995 Regents of the University of California */ /* SCCSid "$SunId$ LBL" */ @@ -9,39 +9,40 @@ /* must include stdio.h before us */ /* Entities (order doesn't really matter) */ -#define MG_E_COMMENT 0 -#define MG_E_COLOR 1 -#define MG_E_CCT 2 -#define MG_E_CONE 3 -#define MG_E_CMIX 4 -#define MG_E_CSPEC 5 -#define MG_E_CXY 6 -#define MG_E_CYL 7 -#define MG_E_ED 8 -#define MG_E_FACE 9 -#define MG_E_INCLUDE 10 -#define MG_E_IES 11 -#define MG_E_MATERIAL 12 -#define MG_E_NORMAL 13 -#define MG_E_OBJECT 14 -#define MG_E_POINT 15 -#define MG_E_PRISM 16 -#define MG_E_RD 17 -#define MG_E_RING 18 -#define MG_E_RS 19 -#define MG_E_SIDES 20 -#define MG_E_SPH 21 -#define MG_E_TD 22 -#define MG_E_TORUS 23 -#define MG_E_TS 24 -#define MG_E_VERTEX 25 -#define MG_E_XF 26 +#define MG_E_COMMENT 0 /* # */ +#define MG_E_COLOR 1 /* c */ +#define MG_E_CCT 2 /* cct */ +#define MG_E_CONE 3 /* cone */ +#define MG_E_CMIX 4 /* cmix */ +#define MG_E_CSPEC 5 /* cspec */ +#define MG_E_CXY 6 /* cxy */ +#define MG_E_CYL 7 /* cyl */ +#define MG_E_ED 8 /* ed */ +#define MG_E_FACE 9 /* f */ +#define MG_E_INCLUDE 10 /* i */ +#define MG_E_IES 11 /* ies */ +#define MG_E_IR 12 /* ir */ +#define MG_E_MATERIAL 13 /* m */ +#define MG_E_NORMAL 14 /* n */ +#define MG_E_OBJECT 15 /* o */ +#define MG_E_POINT 16 /* p */ +#define MG_E_PRISM 17 /* prism */ +#define MG_E_RD 18 /* rd */ +#define MG_E_RING 19 /* ring */ +#define MG_E_RS 20 /* rs */ +#define MG_E_SIDES 21 /* sides */ +#define MG_E_SPH 22 /* sph */ +#define MG_E_TD 23 /* td */ +#define MG_E_TORUS 24 /* torus */ +#define MG_E_TS 25 /* ts */ +#define MG_E_VERTEX 26 /* v */ +#define MG_E_XF 27 /* xf */ -#define MG_NENTITIES 27 +#define MG_NENTITIES 28 /* total # entities */ #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\ - "f","i","ies","m","n","o","p","prism","rd","ring",\ - "rs","sides","sph","td","torus","ts","v","xf"} + "f","i","ies","ir","m","n","o","p","prism","rd",\ + "ring","rs","sides","sph","td","torus","ts","v","xf"} #define MG_MAXELEN 6 @@ -86,7 +87,7 @@ extern char *mg_err[MG_NERRS]; * (The first argument to mg_handle is the entity #, or -1.) * To free any data structures and clear the parser, use mg_clear. * If there is an error, mg_load, mg_open, mg_parse, mg_handle and - * mg_rewind will return an error from the list above. In addition, + * mg_fgoto will return an error from the list above. In addition, * mg_load will report the error to stderr. The mg_read routine * returns 0 when the end of file has been reached. */ @@ -149,10 +150,12 @@ extern int mg_nqcdivs; /* divisions per quarter circl extern int mg_entity(); /* get entity number from its name */ extern int isint(); /* non-zero if integer format */ extern int isflt(); /* non-zero if floating point format */ +extern int isname(); /* non-zero if legal identifier name */ #else extern int mg_entity(char *); /* get entity number from its name */ extern int isint(char *); /* non-zero if integer format */ extern int isflt(char *); /* non-zero if floating point format */ +extern int isname(char *); /* non-zero if legal identifier name */ #endif /************************************************************************ @@ -206,9 +209,9 @@ extern double normalize(FVECT); /* normalize a vector typedef struct { int clock; /* incremented each change */ - unsigned short flags; /* what's been set */ - unsigned short ssamp[C_CNSS]; /* spectral samples, min wl to max */ - unsigned long ssum; /* straight sum of spectral values */ + short flags; /* what's been set */ + short ssamp[C_CNSS]; /* spectral samples, min wl to max */ + long ssum; /* straight sum of spectral values */ float cx, cy; /* xy chromaticity value */ float eff; /* efficacy (lumens/watt) */ } C_COLOR; @@ -223,29 +226,14 @@ typedef struct { C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 } -#define C_CIEX { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ - 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ - 10622,10026,8544,6424,4479,2835,1649,874,468,227,\ - 114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230 } - -#define C_CIEY { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ - 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ - 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ - 5,2,1,1,0,0}, 106856L, .398, .542, 493.525 } - -#define C_CIEZ { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {65,201,679,2074,6456,13856,17471,17721,16692,\ - 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ - 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\ - 106770L, .147, .077, 54.363 } - #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum) +#define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */ + typedef struct { int clock; /* incremented each change -- resettable */ int sided; /* 1 if surface is 1-sided, 0 for 2-sided */ + float nr, ni; /* index of refraction, real and imaginary */ float rd; /* diffuse reflectance */ C_COLOR rd_c; /* diffuse reflectance color */ float td; /* diffuse transmittance */ @@ -265,7 +253,7 @@ typedef struct { FVECT p, n; /* point and normal */ } C_VERTEX; /* vertex context */ -#define C_DEFMATERIAL {1,0,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ +#define C_DEFMATERIAL {1,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} #define C_DEFVERTEX {1,{0.,0.,0.},{0.,0.,0.}} @@ -353,17 +341,21 @@ struct xf_array { typedef struct xf_spec { long xid; /* unique transform id */ - short xav0; /* zeroeth argument in xf_argv array */ - short xac; /* transform argument count */ + short xac; /* context argument count */ short rev; /* boolean true if vertices reversed */ XF xf; /* cumulative transformation */ struct xf_array *xarr; /* transformation array pointer */ struct xf_spec *prev; /* previous transformation context */ } XF_SPEC; /* followed by argument buffer */ -extern int xf_argc; /* total # transform args. */ -extern char **xf_argv; /* transform arguments */ -extern XF_SPEC *xf_context; /* current context */ +extern XF_SPEC *xf_context; /* current transform context */ +extern char **xf_argend; /* last transform argument */ + +#define xf_ac(xf) ((xf)->xac) +#define xf_av(xf) (xf_argend - (xf)->xac) + +#define xf_argc (xf_context==NULL ? 0 : xf_ac(xf_context)) +#define xf_argv xf_av(xf_context) /* * The transformation handler should do most of the work that needs
