--- ray/src/cv/mgflib/parser.h 1994/07/01 18:06:53 1.13 +++ ray/src/cv/mgflib/parser.h 1995/05/10 17:46:05 1.22 @@ -1,4 +1,4 @@ -/* Copyright (c) 1994 Regents of the University of California */ +/* Copyright (c) 1995 Regents of the University of California */ /* SCCSid "$SunId$ LBL" */ @@ -9,38 +9,40 @@ /* must include stdio.h before us */ /* Entities (order doesn't really matter) */ -#define MG_E_COMMENT 0 -#define MG_E_COLOR 1 -#define MG_E_CONE 2 -#define MG_E_CMIX 3 -#define MG_E_CSPEC 4 -#define MG_E_CXY 5 -#define MG_E_CYL 6 -#define MG_E_ED 7 -#define MG_E_FACE 8 -#define MG_E_INCLUDE 9 -#define MG_E_IES 10 -#define MG_E_MATERIAL 11 -#define MG_E_NORMAL 12 -#define MG_E_OBJECT 13 -#define MG_E_POINT 14 -#define MG_E_PRISM 15 -#define MG_E_RD 16 -#define MG_E_RING 17 -#define MG_E_RS 18 -#define MG_E_SIDES 19 -#define MG_E_SPH 20 -#define MG_E_TD 21 -#define MG_E_TORUS 22 -#define MG_E_TS 23 -#define MG_E_VERTEX 24 -#define MG_E_XF 25 +#define MG_E_COMMENT 0 /* # */ +#define MG_E_COLOR 1 /* c */ +#define MG_E_CCT 2 /* cct */ +#define MG_E_CONE 3 /* cone */ +#define MG_E_CMIX 4 /* cmix */ +#define MG_E_CSPEC 5 /* cspec */ +#define MG_E_CXY 6 /* cxy */ +#define MG_E_CYL 7 /* cyl */ +#define MG_E_ED 8 /* ed */ +#define MG_E_FACE 9 /* f */ +#define MG_E_INCLUDE 10 /* i */ +#define MG_E_IES 11 /* ies */ +#define MG_E_IR 12 /* ir */ +#define MG_E_MATERIAL 13 /* m */ +#define MG_E_NORMAL 14 /* n */ +#define MG_E_OBJECT 15 /* o */ +#define MG_E_POINT 16 /* p */ +#define MG_E_PRISM 17 /* prism */ +#define MG_E_RD 18 /* rd */ +#define MG_E_RING 19 /* ring */ +#define MG_E_RS 20 /* rs */ +#define MG_E_SIDES 21 /* sides */ +#define MG_E_SPH 22 /* sph */ +#define MG_E_TD 23 /* td */ +#define MG_E_TORUS 24 /* torus */ +#define MG_E_TS 25 /* ts */ +#define MG_E_VERTEX 26 /* v */ +#define MG_E_XF 27 /* xf */ -#define MG_NENTITIES 26 +#define MG_NENTITIES 28 /* total # entities */ -#define MG_NAMELIST {"#","c","cone","cmix","cspec","cxy","cyl","ed","f",\ - "i","ies","m","n","o","p","prism","rd","ring","rs",\ - "sides","sph","td","torus","ts","v","xf"} +#define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\ + "f","i","ies","ir","m","n","o","p","prism","rd",\ + "ring","rs","sides","sph","td","torus","ts","v","xf"} #define MG_MAXELEN 6 @@ -84,13 +86,13 @@ extern char *mg_err[MG_NERRS]; * the mg_handle function rather than the mg_ehand routines directly. * (The first argument to mg_handle is the entity #, or -1.) * To free any data structures and clear the parser, use mg_clear. - * If there is an error, mg_load, mg_open, mg_parse, and mg_rewind - * will return an error from the list above. In addition, mg_load - * will report the error to stderr. The mg_read routine returns 0 - * when the end of file has been reached. + * If there is an error, mg_load, mg_open, mg_parse, mg_handle and + * mg_fgoto will return an error from the list above. In addition, + * mg_load will report the error to stderr. The mg_read routine + * returns 0 when the end of file has been reached. */ -#define MG_MAXLINE 512 /* maximum input line length */ +#define MG_MAXLINE 4096 /* maximum input line length */ #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */ typedef struct mg_fctxt { @@ -148,10 +150,12 @@ extern int mg_nqcdivs; /* divisions per quarter circl extern int mg_entity(); /* get entity number from its name */ extern int isint(); /* non-zero if integer format */ extern int isflt(); /* non-zero if floating point format */ +extern int isname(); /* non-zero if legal identifier name */ #else extern int mg_entity(char *); /* get entity number from its name */ extern int isint(char *); /* non-zero if integer format */ extern int isflt(char *); /* non-zero if floating point format */ +extern int isname(char *); /* non-zero if legal identifier name */ #endif /************************************************************************ @@ -195,11 +199,13 @@ extern double normalize(FVECT); /* normalize a vector #define C_CNSS 41 /* number of spectral samples */ #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1)) #define C_CMAXV 10000 /* nominal maximum sample value */ +#define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */ #define C_CSSPEC 01 /* flag if spectrum is set */ #define C_CDSPEC 02 /* flag if defined w/ spectrum */ #define C_CSXY 04 /* flag if xy is set */ #define C_CDXY 010 /* flag if defined w/ xy */ +#define C_CSEFF 020 /* flag if efficacy set */ typedef struct { int clock; /* incremented each change */ @@ -207,9 +213,10 @@ typedef struct { short ssamp[C_CNSS]; /* spectral samples, min wl to max */ long ssum; /* straight sum of spectral values */ float cx, cy; /* xy chromaticity value */ + float eff; /* efficacy (lumens/watt) */ } C_COLOR; -#define C_DEFCOLOR { 1, C_CDXY|C_CSXY|C_CSSPEC,\ +#define C_DEFCOLOR { 1, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\ {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ @@ -217,31 +224,16 @@ typedef struct { C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ - (long)C_CNSS*C_CMAXV, 1./3., 1./3. } + (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 } -#define C_CIEX { 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ - {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ - 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ - 10622,10026,8544,6424,4479,2835,1649,874,468,227,\ - 114,58,29,14,7,3,2,1,0}, 106836L, .735, .265 } +#define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum) -#define C_CIEY { 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ - {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ - 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ - 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ - 5,2,1,1,0,0}, 106856L, .274, .717 } +#define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */ -#define C_CIEZ { 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ - {65,201,679,2074,6456,13856,17471,17721,16692,\ - 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ - 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\ - 106770L, .167, .009 } - -#define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->sum) - typedef struct { int clock; /* incremented each change -- resettable */ int sided; /* 1 if surface is 1-sided, 0 for 2-sided */ + float nr, ni; /* index of refraction, real and imaginary */ float rd; /* diffuse reflectance */ C_COLOR rd_c; /* diffuse reflectance color */ float td; /* diffuse transmittance */ @@ -261,7 +253,7 @@ typedef struct { FVECT p, n; /* point and normal */ } C_VERTEX; /* vertex context */ -#define C_DEFMATERIAL {1,0,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ +#define C_DEFMATERIAL {1,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} #define C_DEFVERTEX {1,{0.,0.,0.},{0.,0.,0.}} @@ -330,8 +322,8 @@ extern MAT4 m4ident; /* regular transformation */ typedef struct { - MAT4 xfm; /* transform matrix */ - FLOAT sca; /* scalefactor */ + MAT4 xfm; /* transform matrix */ + FLOAT sca; /* scalefactor */ } XF; #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0) @@ -351,6 +343,7 @@ typedef struct xf_spec { long xid; /* unique transform id */ short xav0; /* zeroeth argument in xf_argv array */ short xac; /* transform argument count */ + short rev; /* boolean true if vertices reversed */ XF xf; /* cumulative transformation */ struct xf_array *xarr; /* transformation array pointer */ struct xf_spec *prev; /* previous transformation context */
