--- ray/src/cv/mgflib/parser.h 1994/09/02 16:04:16 1.16 +++ ray/src/cv/mgflib/parser.h 1996/02/08 16:29:33 1.29 @@ -1,4 +1,4 @@ -/* Copyright (c) 1994 Regents of the University of California */ +/* Copyright (c) 1995 Regents of the University of California */ /* SCCSid "$SunId$ LBL" */ @@ -8,52 +8,65 @@ /* must include stdio.h before us */ - /* Entities (order doesn't really matter) */ -#define MG_E_COMMENT 0 -#define MG_E_COLOR 1 -#define MG_E_CONE 2 -#define MG_E_CMIX 3 -#define MG_E_CSPEC 4 -#define MG_E_CXY 5 -#define MG_E_CYL 6 -#define MG_E_ED 7 -#define MG_E_FACE 8 -#define MG_E_INCLUDE 9 -#define MG_E_IES 10 -#define MG_E_MATERIAL 11 -#define MG_E_NORMAL 12 -#define MG_E_OBJECT 13 -#define MG_E_POINT 14 -#define MG_E_PRISM 15 -#define MG_E_RD 16 -#define MG_E_RING 17 -#define MG_E_RS 18 -#define MG_E_SIDES 19 -#define MG_E_SPH 20 -#define MG_E_TD 21 -#define MG_E_TORUS 22 -#define MG_E_TS 23 -#define MG_E_VERTEX 24 -#define MG_E_XF 25 +#define MG_VMAJOR 1 /* major version number */ +#define MG_VMINOR 1 /* minor version number */ -#define MG_NENTITIES 26 + /* Entities (list is only appended, never modified) */ +#define MG_E_COMMENT 0 /* # */ +#define MG_E_COLOR 1 /* c */ +#define MG_E_CCT 2 /* cct */ +#define MG_E_CONE 3 /* cone */ +#define MG_E_CMIX 4 /* cmix */ +#define MG_E_CSPEC 5 /* cspec */ +#define MG_E_CXY 6 /* cxy */ +#define MG_E_CYL 7 /* cyl */ +#define MG_E_ED 8 /* ed */ +#define MG_E_FACE 9 /* f */ +#define MG_E_INCLUDE 10 /* i */ +#define MG_E_IES 11 /* ies */ +#define MG_E_IR 12 /* ir */ +#define MG_E_MATERIAL 13 /* m */ +#define MG_E_NORMAL 14 /* n */ +#define MG_E_OBJECT 15 /* o */ +#define MG_E_POINT 16 /* p */ +#define MG_E_PRISM 17 /* prism */ +#define MG_E_RD 18 /* rd */ +#define MG_E_RING 19 /* ring */ +#define MG_E_RS 20 /* rs */ +#define MG_E_SIDES 21 /* sides */ +#define MG_E_SPH 22 /* sph */ +#define MG_E_TD 23 /* td */ +#define MG_E_TORUS 24 /* torus */ +#define MG_E_TS 25 /* ts */ +#define MG_E_VERTEX 26 /* v */ +#define MG_E_XF 27 /* xf */ + /* end of Version 1 entities */ -#define MG_NAMELIST {"#","c","cone","cmix","cspec","cxy","cyl","ed","f",\ - "i","ies","m","n","o","p","prism","rd","ring","rs",\ - "sides","sph","td","torus","ts","v","xf"} +#define MG_NENTITIES 28 /* total # entities */ +#define MG_NELIST {28} /* entity count for version 1 and up */ + +#define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\ + "f","i","ies","ir","m","n","o","p","prism","rd",\ + "ring","rs","sides","sph","td","torus","ts","v","xf"} + #define MG_MAXELEN 6 extern char mg_ename[MG_NENTITIES][MG_MAXELEN]; - /* Handler routines for each entity */ - + /* Handler routines for each entity and unknown ones */ #ifdef NOPROTO extern int (*mg_ehand[MG_NENTITIES])(); +extern int (*mg_uhand)(); +extern int mg_defuhand(); #else extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv); +extern int (*mg_uhand)(int argc, char **argv); +extern int mg_defuhand(int, char **); #endif +extern unsigned mg_nunknown; /* count of unknown entities */ + /* Error codes */ #define MG_OK 0 /* normal return value */ #define MG_EUNK 1 /* unknown entity */ @@ -66,10 +79,12 @@ extern int (*mg_ehand[MG_NENTITIES])(int argc, char ** #define MG_EMEM 8 /* out of memory */ #define MG_ESEEK 9 /* file seek error */ #define MG_EBADMAT 10 /* bad material specification */ +#define MG_ELINE 11 /* input line too long */ +#define MG_ECNTXT 12 /* unmatched context close */ -#define MG_NERRS 11 +#define MG_NERRS 13 -extern char *mg_err[MG_NERRS]; +extern char *mg_err[MG_NERRS]; /* list of error messages */ /* * The general process for running the parser is to fill in the mg_ehand @@ -85,12 +100,12 @@ extern char *mg_err[MG_NERRS]; * (The first argument to mg_handle is the entity #, or -1.) * To free any data structures and clear the parser, use mg_clear. * If there is an error, mg_load, mg_open, mg_parse, mg_handle and - * mg_rewind will return an error from the list above. In addition, + * mg_fgoto will return an error from the list above. In addition, * mg_load will report the error to stderr. The mg_read routine * returns 0 when the end of file has been reached. */ -#define MG_MAXLINE 512 /* maximum input line length */ +#define MG_MAXLINE 4096 /* maximum input line length */ #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */ typedef struct mg_fctxt { @@ -148,10 +163,12 @@ extern int mg_nqcdivs; /* divisions per quarter circl extern int mg_entity(); /* get entity number from its name */ extern int isint(); /* non-zero if integer format */ extern int isflt(); /* non-zero if floating point format */ +extern int isname(); /* non-zero if legal identifier name */ #else extern int mg_entity(char *); /* get entity number from its name */ extern int isint(char *); /* non-zero if integer format */ extern int isflt(char *); /* non-zero if floating point format */ +extern int isname(char *); /* non-zero if legal identifier name */ #endif /************************************************************************ @@ -222,29 +239,14 @@ typedef struct { C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 } -#define C_CIEX { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ - 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ - 10622,10026,8544,6424,4479,2835,1649,874,468,227,\ - 114,58,29,14,7,3,2,1,0}, 106836L, .735, .265, 362.230 } - -#define C_CIEY { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ - 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ - 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ - 5,2,1,1,0,0}, 106856L, .274, .717, 493.525 } - -#define C_CIEZ { 1, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,\ - {65,201,679,2074,6456,13856,17471,17721,16692,\ - 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ - 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\ - 106770L, .167, .009, 54.363 } - #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum) +#define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */ + typedef struct { int clock; /* incremented each change -- resettable */ int sided; /* 1 if surface is 1-sided, 0 for 2-sided */ + float nr, ni; /* index of refraction, real and imaginary */ float rd; /* diffuse reflectance */ C_COLOR rd_c; /* diffuse reflectance color */ float td; /* diffuse transmittance */ @@ -264,7 +266,7 @@ typedef struct { FVECT p, n; /* point and normal */ } C_VERTEX; /* vertex context */ -#define C_DEFMATERIAL {1,0,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ +#define C_DEFMATERIAL {1,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} #define C_DEFVERTEX {1,{0.,0.,0.},{0.,0.,0.}} @@ -352,18 +354,22 @@ struct xf_array { typedef struct xf_spec { long xid; /* unique transform id */ - short xav0; /* zeroeth argument in xf_argv array */ - short xac; /* transform argument count */ + short xac; /* context argument count */ short rev; /* boolean true if vertices reversed */ XF xf; /* cumulative transformation */ struct xf_array *xarr; /* transformation array pointer */ struct xf_spec *prev; /* previous transformation context */ } XF_SPEC; /* followed by argument buffer */ -extern int xf_argc; /* total # transform args. */ -extern char **xf_argv; /* transform arguments */ -extern XF_SPEC *xf_context; /* current context */ +extern XF_SPEC *xf_context; /* current transform context */ +extern char **xf_argend; /* last transform argument */ +#define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac) +#define xf_av(xf) (xf_argend - (xf)->xac) + +#define xf_argc xf_ac(xf_context) +#define xf_argv xf_av(xf_context) + /* * The transformation handler should do most of the work that needs * doing. Just pass it any xf entities, then use the associated @@ -387,6 +393,10 @@ extern void xf_clear(); /* clear xf stack */ /* The following are support routines you probably won't call directly */ +XF_SPEC *new_xf(); /* allocate new transform */ +void free_xf(); /* free a transform */ +int xf_aname(); /* name this instance */ +long comp_xfid(); /* compute unique ID */ extern void multmat4(); /* m4a = m4b X m4c */ extern void multv3(); /* v3a = v3b X m4 (vectors) */ extern void multp3(); /* p3a = p3b X m4 (points) */ @@ -403,6 +413,10 @@ extern void xf_clear(void); /* clear xf stack */ /* The following are support routines you probably won't call directly */ +XF_SPEC *new_xf(int, char **); /* allocate new transform */ +void free_xf(XF_SPEC *); /* free a transform */ +int xf_aname(struct xf_array *); /* name this instance */ +long comp_xfid(MAT4); /* compute unique ID */ extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */ extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */ extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */ @@ -414,10 +428,12 @@ extern int xf(XF *, int, char **); /* interpret trans * Miscellaneous definitions */ +#ifndef PI #ifdef M_PI #define PI M_PI #else #define PI 3.14159265358979323846 +#endif #endif #ifdef DCL_ATOF
