root/radiance/ray/src/cv/mgflib/parser.h
Revision: 1.34
Committed: Sat Jun 7 01:11:17 2003 UTC (22 years ago) by schorsch
Changes since 1.33: +14 -82 lines
Removed NOPROTO sections.
1 /* RCSid: $Id: parser.h,v 1.33 2003/02/28 20:11:29 greg Exp $ */
2 /*
3 * Header file for MGF interpreter
4 */
5 #ifndef _MGF_PARSER_H_
6 #define _MGF_PARSER_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11
12 #ifndef MG_VMAJOR
13
14 /* must include stdio.h and stdlib.h before us */
15
16 #define MG_VMAJOR 2 /* major version number */
17 #define MG_VMINOR 0 /* minor version number */
18
19 /* Entities (list is only appended, never modified) */
20 #define MG_E_COMMENT 0 /* # */
21 #define MG_E_COLOR 1 /* c */
22 #define MG_E_CCT 2 /* cct */
23 #define MG_E_CONE 3 /* cone */
24 #define MG_E_CMIX 4 /* cmix */
25 #define MG_E_CSPEC 5 /* cspec */
26 #define MG_E_CXY 6 /* cxy */
27 #define MG_E_CYL 7 /* cyl */
28 #define MG_E_ED 8 /* ed */
29 #define MG_E_FACE 9 /* f */
30 #define MG_E_INCLUDE 10 /* i */
31 #define MG_E_IES 11 /* ies */
32 #define MG_E_IR 12 /* ir */
33 #define MG_E_MATERIAL 13 /* m */
34 #define MG_E_NORMAL 14 /* n */
35 #define MG_E_OBJECT 15 /* o */
36 #define MG_E_POINT 16 /* p */
37 #define MG_E_PRISM 17 /* prism */
38 #define MG_E_RD 18 /* rd */
39 #define MG_E_RING 19 /* ring */
40 #define MG_E_RS 20 /* rs */
41 #define MG_E_SIDES 21 /* sides */
42 #define MG_E_SPH 22 /* sph */
43 #define MG_E_TD 23 /* td */
44 #define MG_E_TORUS 24 /* torus */
45 #define MG_E_TS 25 /* ts */
46 #define MG_E_VERTEX 26 /* v */
47 #define MG_E_XF 27 /* xf */
48 /* end of Version 1 entities */
49 #define MG_E_FACEH 28 /* fh */
50 /* end of Version 2 entities */
51
52 #define MG_NENTITIES 29 /* total # entities */
53
54 #define MG_NELIST {28,29} /* entity count for version 1 and up */
55
56 #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\
57 "f","i","ies","ir","m","n","o","p","prism","rd",\
58 "ring","rs","sides","sph","td","torus","ts","v","xf",\
59 "fh"}
60
61 #define MG_MAXELEN 6
62
63 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
64
65 /* Handler routines for each entity and unknown ones */
66 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
67 extern int (*mg_uhand)(int argc, char **argv);
68 extern int mg_defuhand(int, char **);
69
70 extern unsigned mg_nunknown; /* count of unknown entities */
71
72 /* Error codes */
73 #define MG_OK 0 /* normal return value */
74 #define MG_EUNK 1 /* unknown entity */
75 #define MG_EARGC 2 /* wrong number of arguments */
76 #define MG_ETYPE 3 /* argument type error */
77 #define MG_EILL 4 /* illegal argument value */
78 #define MG_EUNDEF 5 /* undefined reference */
79 #define MG_ENOFILE 6 /* cannot open input file */
80 #define MG_EINCL 7 /* error in included file */
81 #define MG_EMEM 8 /* out of memory */
82 #define MG_ESEEK 9 /* file seek error */
83 #define MG_EBADMAT 10 /* bad material specification */
84 #define MG_ELINE 11 /* input line too long */
85 #define MG_ECNTXT 12 /* unmatched context close */
86
87 #define MG_NERRS 13
88
89 extern char *mg_err[MG_NERRS]; /* list of error messages */
90
91 /*
92 * The general process for running the parser is to fill in the mg_ehand
93 * array with handlers for each entity you know how to handle.
94 * Then, call mg_init to fill in the rest. This function will report
95 * an error and quit if you try to support an inconsistent set of entities.
96 * For each file you want to parse, call mg_load with the file name.
97 * To read from standard input, use NULL as the file name.
98 * For additional control over error reporting and file management,
99 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
100 * To pass an entity of your own construction to the parser, use
101 * the mg_handle function rather than the mg_ehand routines directly.
102 * (The first argument to mg_handle is the entity #, or -1.)
103 * To free any data structures and clear the parser, use mg_clear.
104 * If there is an error, mg_load, mg_open, mg_parse, mg_handle and
105 * mg_fgoto will return an error from the list above. In addition,
106 * mg_load will report the error to stderr. The mg_read routine
107 * returns 0 when the end of file has been reached.
108 */
109
110 #define MG_MAXLINE 4096 /* maximum input line length */
111 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
112
113 typedef struct mg_fctxt {
114 char fname[96]; /* file name */
115 FILE *fp; /* stream pointer */
116 int fid; /* unique file context id */
117 char inpline[MG_MAXLINE]; /* input line */
118 int lineno; /* line number */
119 struct mg_fctxt *prev; /* previous context */
120 } MG_FCTXT;
121
122 typedef struct {
123 int fid; /* file this position is for */
124 int lineno; /* line number in file */
125 long offset; /* offset from beginning */
126 } MG_FPOS;
127
128 extern MG_FCTXT *mg_file; /* current file context */
129
130 extern void mg_init(void); /* fill in mg_ehand array */
131 extern int mg_load(char *); /* parse a file */
132 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
133 extern int mg_read(void); /* read next line */
134 extern int mg_parse(void); /* parse current line */
135 extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
136 extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
137 extern void mg_close(void); /* close input file */
138 extern void mg_clear(void); /* clear parser */
139 extern int mg_handle(int, int, char **); /* handle an entity */
140
141 #ifndef MG_NQCD
142 #define MG_NQCD 5 /* default number of divisions */
143 #endif
144
145 extern int mg_nqcdivs; /* divisions per quarter circle */
146
147 /*
148 * The following library routines are included for your convenience:
149 */
150
151 extern int mg_entity(char *); /* get entity number from its name */
152 extern int isint(char *); /* non-zero if integer format */
153 extern int isintd(char *, char *); /* same with delimiter set */
154 extern int isflt(char *); /* non-zero if floating point format */
155 extern int isfltd(char *, char *); /* same with delimiter set */
156 extern int isname(char *); /* non-zero if legal identifier name */
157 extern int badarg(int, char **, char *);/* check argument format */
158 extern int e_include(int, char **); /* expand include entity */
159 extern int e_pipe(int, char **); /* expand piped command */
160 extern int e_sph(int, char **); /* expand sphere as other entities */
161 extern int e_torus(int, char **); /* expand torus as other entities */
162 extern int e_cyl(int, char **); /* expand cylinder as other entities */
163 extern int e_ring(int, char **); /* expand ring as other entities */
164 extern int e_cone(int, char **); /* expand cone as other entities */
165 extern int e_prism(int, char **); /* expand prism as other entities */
166 extern int e_faceh(int, char **); /* expand face w/ holes as face */
167
168 /************************************************************************
169 * Definitions for 3-d vector manipulation functions
170 */
171
172 #ifdef SMLFLT
173 #define FLOAT float
174 #define FTINY (1e-3)
175 #else
176 #define FLOAT double
177 #define FTINY (1e-6)
178 #endif
179 #define FHUGE (1e10)
180
181 typedef FLOAT FVECT[3];
182
183 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
184 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
185 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
186 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
187 (vr)[2]=(v1)[2]+(f)*(v2)[2])
188
189 #define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
190
191 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
192
193 extern double normalize(FVECT); /* normalize a vector */
194 extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */
195
196 /************************************************************************
197 * Definitions for context handling routines
198 * (materials, colors, vectors)
199 */
200
201 #define C_CMINWL 380 /* minimum wavelength */
202 #define C_CMAXWL 780 /* maximum wavelength */
203 #define C_CNSS 41 /* number of spectral samples */
204 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
205 #define C_CMAXV 10000 /* nominal maximum sample value */
206 #define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
207
208 #define C_CSSPEC 01 /* flag if spectrum is set */
209 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
210 #define C_CSXY 04 /* flag if xy is set */
211 #define C_CDXY 010 /* flag if defined w/ xy */
212 #define C_CSEFF 020 /* flag if efficacy set */
213
214 typedef struct {
215 int clock; /* incremented each change */
216 char *client_data; /* pointer to private client-owned data */
217 short flags; /* what's been set */
218 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
219 long ssum; /* straight sum of spectral values */
220 float cx, cy; /* xy chromaticity value */
221 float eff; /* efficacy (lumens/watt) */
222 } C_COLOR;
223
224 #define C_DEFCOLOR { 1, NULL, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\
225 {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
226 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
227 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
228 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
229 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
230 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
231 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\
232 (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 }
233
234 #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum)
235
236 #define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
237
238 typedef struct {
239 int clock; /* incremented each change -- resettable */
240 char *client_data; /* pointer to private client-owned data */
241 int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
242 float nr, ni; /* index of refraction, real and imaginary */
243 float rd; /* diffuse reflectance */
244 C_COLOR rd_c; /* diffuse reflectance color */
245 float td; /* diffuse transmittance */
246 C_COLOR td_c; /* diffuse transmittance color */
247 float ed; /* diffuse emittance */
248 C_COLOR ed_c; /* diffuse emittance color */
249 float rs; /* specular reflectance */
250 C_COLOR rs_c; /* specular reflectance color */
251 float rs_a; /* specular reflectance roughness */
252 float ts; /* specular transmittance */
253 C_COLOR ts_c; /* specular transmittance color */
254 float ts_a; /* specular transmittance roughness */
255 } C_MATERIAL; /* material context */
256
257 typedef struct {
258 int clock; /* incremented each change -- resettable */
259 char *client_data; /* pointer to private client-owned data */
260 FVECT p, n; /* point and normal */
261 } C_VERTEX; /* vertex context */
262
263 #define C_DEFMATERIAL {1,NULL,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,\
264 C_DEFCOLOR,0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
265 #define C_DEFVERTEX {1,NULL,{0.,0.,0.},{0.,0.,0.}}
266
267 extern C_COLOR *c_ccolor; /* the current color */
268 extern char *c_ccname; /* current color name */
269 extern C_MATERIAL *c_cmaterial; /* the current material */
270 extern char *c_cmname; /* current material name */
271 extern C_VERTEX *c_cvertex; /* the current vertex */
272 extern char *c_cvname; /* current vertex name */
273
274 extern int c_hcolor(int, char **); /* handle color entity */
275 extern int c_hmaterial(int, char **); /* handle material entity */
276 extern int c_hvertex(int, char **); /* handle vertex entity */
277 extern void c_clearall(void); /* clear context tables */
278 extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
279 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
280 extern C_COLOR *c_getcolor(char *); /* get a named color */
281 extern void c_ccvt(C_COLOR *, int); /* fix color representation */
282 extern int c_isgrey(C_COLOR *); /* check if color is grey */
283
284 /*************************************************************************
285 * Definitions for hierarchical object name handler
286 */
287
288 extern int obj_nnames; /* depth of name hierarchy */
289 extern char **obj_name; /* names in hierarchy */
290
291 extern int obj_handler(int, char **); /* handle an object entity */
292 extern void obj_clear(void); /* clear object stack */
293
294 /**************************************************************************
295 * Definitions for hierarchical transformation handler
296 */
297
298 typedef FLOAT MAT4[4][4];
299
300 #ifdef BSD
301 #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4))
302 #else
303 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
304 #endif
305
306 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
307 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
308
309 extern MAT4 m4ident;
310
311 #define setident4(m4) copymat4(m4, m4ident)
312
313 /* regular transformation */
314 typedef struct {
315 MAT4 xfm; /* transform matrix */
316 FLOAT sca; /* scalefactor */
317 } XF;
318
319 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
320
321 #define XF_MAXDIM 8 /* maximum array dimensions */
322
323 struct xf_array {
324 MG_FPOS spos; /* starting position on input */
325 int ndim; /* number of array dimensions */
326 struct {
327 short i, n; /* current count and maximum */
328 char arg[8]; /* string argument value */
329 } aarg[XF_MAXDIM];
330 };
331
332 typedef struct xf_spec {
333 long xid; /* unique transform id */
334 short xac; /* context argument count */
335 short rev; /* boolean true if vertices reversed */
336 XF xf; /* cumulative transformation */
337 struct xf_array *xarr; /* transformation array pointer */
338 struct xf_spec *prev; /* previous transformation context */
339 } XF_SPEC; /* followed by argument buffer */
340
341 extern XF_SPEC *xf_context; /* current transform context */
342 extern char **xf_argend; /* last transform argument */
343
344 #define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac)
345 #define xf_av(xf) (xf_argend - (xf)->xac)
346
347 #define xf_argc xf_ac(xf_context)
348 #define xf_argv xf_av(xf_context)
349
350 /*
351 * The transformation handler should do most of the work that needs
352 * doing. Just pass it any xf entities, then use the associated
353 * functions to transform and translate points, transform vectors
354 * (without translation), rotate vectors (without scaling) and scale
355 * values appropriately.
356 *
357 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
358 * 3-D vectors (which may be identical), transforms the second and
359 * puts the result into the first.
360 */
361
362
363 extern int xf_handler(int, char **); /* handle xf entity */
364 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
365 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
366 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
367 extern double xf_scale(double); /* scale a value */
368 extern void xf_clear(void); /* clear xf stack */
369
370 /* The following are support routines you probably won't call directly */
371
372 XF_SPEC *new_xf(int, char **); /* allocate new transform */
373 void free_xf(XF_SPEC *); /* free a transform */
374 int xf_aname(struct xf_array *); /* name this instance */
375 long comp_xfid(MAT4); /* compute unique ID */
376 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
377 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
378 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
379 extern int xf(XF *, int, char **); /* interpret transform spec. */
380
381
382 /************************************************************************
383 * Miscellaneous definitions
384 */
385
386 #ifndef PI
387 #ifdef M_PI
388 #define PI ((double)M_PI)
389 #else
390 #define PI 3.14159265358979323846
391 #endif
392 #endif
393
394 #ifndef MEM_PTR
395 #define MEM_PTR void *
396 #endif
397
398 #endif /*MG_VMAJOR*/
399
400
401 #ifdef __cplusplus
402 }
403 #endif
404 #endif /* _MGF_PARSER_H_ */
405
