root/radiance/ray/src/cv/mgflib/parser.h
Revision: 1.19
Committed: Fri Mar 10 15:16:42 1995 UTC (29 years, 3 months ago) by greg
Changes since 1.18: +3 -21 lines
moved CIE definitions to context.c
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for MGF interpreter
7 */
8
9 /* must include stdio.h before us */
10
11 /* Entities (order doesn't really matter) */
12 #define MG_E_COMMENT 0
13 #define MG_E_COLOR 1
14 #define MG_E_CCT 2
15 #define MG_E_CONE 3
16 #define MG_E_CMIX 4
17 #define MG_E_CSPEC 5
18 #define MG_E_CXY 6
19 #define MG_E_CYL 7
20 #define MG_E_ED 8
21 #define MG_E_FACE 9
22 #define MG_E_INCLUDE 10
23 #define MG_E_IES 11
24 #define MG_E_MATERIAL 12
25 #define MG_E_NORMAL 13
26 #define MG_E_OBJECT 14
27 #define MG_E_POINT 15
28 #define MG_E_PRISM 16
29 #define MG_E_RD 17
30 #define MG_E_RING 18
31 #define MG_E_RS 19
32 #define MG_E_SIDES 20
33 #define MG_E_SPH 21
34 #define MG_E_TD 22
35 #define MG_E_TORUS 23
36 #define MG_E_TS 24
37 #define MG_E_VERTEX 25
38 #define MG_E_XF 26
39
40 #define MG_NENTITIES 27
41
42 #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\
43 "f","i","ies","m","n","o","p","prism","rd","ring",\
44 "rs","sides","sph","td","torus","ts","v","xf"}
45
46 #define MG_MAXELEN 6
47
48 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
49
50 /* Handler routines for each entity */
51
52 #ifdef NOPROTO
53 extern int (*mg_ehand[MG_NENTITIES])();
54 #else
55 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
56 #endif
57
58 /* Error codes */
59 #define MG_OK 0 /* normal return value */
60 #define MG_EUNK 1 /* unknown entity */
61 #define MG_EARGC 2 /* wrong number of arguments */
62 #define MG_ETYPE 3 /* argument type error */
63 #define MG_EILL 4 /* illegal argument value */
64 #define MG_EUNDEF 5 /* undefined reference */
65 #define MG_ENOFILE 6 /* cannot open input file */
66 #define MG_EINCL 7 /* error in included file */
67 #define MG_EMEM 8 /* out of memory */
68 #define MG_ESEEK 9 /* file seek error */
69 #define MG_EBADMAT 10 /* bad material specification */
70
71 #define MG_NERRS 11
72
73 extern char *mg_err[MG_NERRS];
74
75 /*
76 * The general process for running the parser is to fill in the mg_ehand
77 * array with handlers for each entity you know how to handle.
78 * Then, call mg_init to fill in the rest. This function will report
79 * an error and quit if you try to support an inconsistent set of entities.
80 * For each file you want to parse, call mg_load with the file name.
81 * To read from standard input, use NULL as the file name.
82 * For additional control over error reporting and file management,
83 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
84 * To pass an entity of your own construction to the parser, use
85 * the mg_handle function rather than the mg_ehand routines directly.
86 * (The first argument to mg_handle is the entity #, or -1.)
87 * To free any data structures and clear the parser, use mg_clear.
88 * If there is an error, mg_load, mg_open, mg_parse, mg_handle and
89 * mg_rewind will return an error from the list above. In addition,
90 * mg_load will report the error to stderr. The mg_read routine
91 * returns 0 when the end of file has been reached.
92 */
93
94 #define MG_MAXLINE 4096 /* maximum input line length */
95 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
96
97 typedef struct mg_fctxt {
98 char fname[96]; /* file name */
99 FILE *fp; /* stream pointer */
100 int fid; /* unique file context id */
101 char inpline[MG_MAXLINE]; /* input line */
102 int lineno; /* line number */
103 struct mg_fctxt *prev; /* previous context */
104 } MG_FCTXT;
105
106 typedef struct {
107 int fid; /* file this position is for */
108 int lineno; /* line number in file */
109 long offset; /* offset from beginning */
110 } MG_FPOS;
111
112 extern MG_FCTXT *mg_file; /* current file context */
113
114 #ifdef NOPROTO
115 extern void mg_init(); /* fill in mg_ehand array */
116 extern int mg_load(); /* parse a file */
117 extern int mg_open(); /* open new input file */
118 extern int mg_read(); /* read next line */
119 extern int mg_parse(); /* parse current line */
120 extern void mg_fgetpos(); /* get position on input file */
121 extern int mg_fgoto(); /* go to position on input file */
122 extern void mg_close(); /* close input file */
123 extern void mg_clear(); /* clear parser */
124 extern int mg_handle(); /* handle an entity */
125 #else
126 extern void mg_init(void); /* fill in mg_ehand array */
127 extern int mg_load(char *); /* parse a file */
128 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
129 extern int mg_read(void); /* read next line */
130 extern int mg_parse(void); /* parse current line */
131 extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
132 extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
133 extern void mg_close(void); /* close input file */
134 extern void mg_clear(void); /* clear parser */
135 extern int mg_handle(int, int, char **); /* handle an entity */
136 #endif
137
138 #ifndef MG_NQCD
139 #define MG_NQCD 5 /* default number of divisions */
140 #endif
141
142 extern int mg_nqcdivs; /* divisions per quarter circle */
143
144 /*
145 * The following library routines are included for your convenience:
146 */
147
148 #ifdef NOPROTO
149 extern int mg_entity(); /* get entity number from its name */
150 extern int isint(); /* non-zero if integer format */
151 extern int isflt(); /* non-zero if floating point format */
152 #else
153 extern int mg_entity(char *); /* get entity number from its name */
154 extern int isint(char *); /* non-zero if integer format */
155 extern int isflt(char *); /* non-zero if floating point format */
156 #endif
157
158 /************************************************************************
159 * Definitions for 3-d vector manipulation functions
160 */
161
162 #ifdef SMLFLT
163 #define FLOAT float
164 #define FTINY (1e-3)
165 #else
166 #define FLOAT double
167 #define FTINY (1e-6)
168 #endif
169 #define FHUGE (1e10)
170
171 typedef FLOAT FVECT[3];
172
173 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
174 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
175 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
176 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
177 (vr)[2]=(v1)[2]+(f)*(v2)[2])
178
179 #define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
180
181 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
182
183 #ifdef NOPROTO
184 extern double normalize(); /* normalize a vector */
185 #else
186 extern double normalize(FVECT); /* normalize a vector */
187 #endif
188
189 /************************************************************************
190 * Definitions for context handling routines
191 * (materials, colors, vectors)
192 */
193
194 #define C_CMINWL 380 /* minimum wavelength */
195 #define C_CMAXWL 780 /* maximum wavelength */
196 #define C_CNSS 41 /* number of spectral samples */
197 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
198 #define C_CMAXV 10000 /* nominal maximum sample value */
199 #define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
200
201 #define C_CSSPEC 01 /* flag if spectrum is set */
202 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
203 #define C_CSXY 04 /* flag if xy is set */
204 #define C_CDXY 010 /* flag if defined w/ xy */
205 #define C_CSEFF 020 /* flag if efficacy set */
206
207 typedef struct {
208 int clock; /* incremented each change */
209 short flags; /* what's been set */
210 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
211 long ssum; /* straight sum of spectral values */
212 float cx, cy; /* xy chromaticity value */
213 float eff; /* efficacy (lumens/watt) */
214 } C_COLOR;
215
216 #define C_DEFCOLOR { 1, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\
217 {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
218 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
219 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
220 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
221 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
222 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
223 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\
224 (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 }
225
226 #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum)
227
228 typedef struct {
229 int clock; /* incremented each change -- resettable */
230 int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
231 float rd; /* diffuse reflectance */
232 C_COLOR rd_c; /* diffuse reflectance color */
233 float td; /* diffuse transmittance */
234 C_COLOR td_c; /* diffuse transmittance color */
235 float ed; /* diffuse emittance */
236 C_COLOR ed_c; /* diffuse emittance color */
237 float rs; /* specular reflectance */
238 C_COLOR rs_c; /* specular reflectance color */
239 float rs_a; /* specular reflectance roughness */
240 float ts; /* specular transmittance */
241 C_COLOR ts_c; /* specular transmittance color */
242 float ts_a; /* specular transmittance roughness */
243 } C_MATERIAL; /* material context */
244
245 typedef struct {
246 int clock; /* incremented each change -- resettable */
247 FVECT p, n; /* point and normal */
248 } C_VERTEX; /* vertex context */
249
250 #define C_DEFMATERIAL {1,0,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\
251 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
252 #define C_DEFVERTEX {1,{0.,0.,0.},{0.,0.,0.}}
253
254 extern C_COLOR *c_ccolor; /* the current color */
255 extern char *c_ccname; /* current color name */
256 extern C_MATERIAL *c_cmaterial; /* the current material */
257 extern char *c_cmname; /* current material name */
258 extern C_VERTEX *c_cvertex; /* the current vertex */
259 extern char *c_cvname; /* current vertex name */
260
261 #ifdef NOPROTO
262 extern int c_hcolor(); /* handle color entity */
263 extern int c_hmaterial(); /* handle material entity */
264 extern int c_hvertex(); /* handle vertex entity */
265 extern void c_clearall(); /* clear context tables */
266 extern C_MATERIAL *c_getmaterial(); /* get a named material */
267 extern C_VERTEX *c_getvert(); /* get a named vertex */
268 extern C_COLOR *c_getcolor(); /* get a named color */
269 extern void c_ccvt(); /* fix color representation */
270 extern int c_isgrey(); /* check if color is grey */
271 #else
272 extern int c_hcolor(int, char **); /* handle color entity */
273 extern int c_hmaterial(int, char **); /* handle material entity */
274 extern int c_hvertex(int, char **); /* handle vertex entity */
275 extern void c_clearall(void); /* clear context tables */
276 extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
277 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
278 extern C_COLOR *c_getcolor(char *); /* get a named color */
279 extern void c_ccvt(C_COLOR *, int); /* fix color representation */
280 extern int c_isgrey(C_COLOR *); /* check if color is grey */
281 #endif
282
283 /*************************************************************************
284 * Definitions for hierarchical object name handler
285 */
286
287 extern int obj_nnames; /* depth of name hierarchy */
288 extern char **obj_name; /* names in hierarchy */
289
290 #ifdef NOPROTO
291 extern int obj_handler(); /* handle an object entity */
292 extern void obj_clear(); /* clear object stack */
293 #else
294 extern int obj_handler(int, char **); /* handle an object entity */
295 extern void obj_clear(void); /* clear object stack */
296 #endif
297
298 /**************************************************************************
299 * Definitions for hierarchical transformation handler
300 */
301
302 typedef FLOAT MAT4[4][4];
303
304 #ifdef BSD
305 #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4))
306 #else
307 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
308 #endif
309
310 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
311 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
312
313 extern MAT4 m4ident;
314
315 #define setident4(m4) copymat4(m4, m4ident)
316
317 /* regular transformation */
318 typedef struct {
319 MAT4 xfm; /* transform matrix */
320 FLOAT sca; /* scalefactor */
321 } XF;
322
323 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
324
325 #define XF_MAXDIM 8 /* maximum array dimensions */
326
327 struct xf_array {
328 MG_FPOS spos; /* starting position on input */
329 int ndim; /* number of array dimensions */
330 struct {
331 short i, n; /* current count and maximum */
332 char arg[8]; /* string argument value */
333 } aarg[XF_MAXDIM];
334 };
335
336 typedef struct xf_spec {
337 long xid; /* unique transform id */
338 short xav0; /* zeroeth argument in xf_argv array */
339 short xac; /* transform argument count */
340 short rev; /* boolean true if vertices reversed */
341 XF xf; /* cumulative transformation */
342 struct xf_array *xarr; /* transformation array pointer */
343 struct xf_spec *prev; /* previous transformation context */
344 } XF_SPEC; /* followed by argument buffer */
345
346 extern int xf_argc; /* total # transform args. */
347 extern char **xf_argv; /* transform arguments */
348 extern XF_SPEC *xf_context; /* current context */
349
350 /*
351 * The transformation handler should do most of the work that needs
352 * doing. Just pass it any xf entities, then use the associated
353 * functions to transform and translate points, transform vectors
354 * (without translation), rotate vectors (without scaling) and scale
355 * values appropriately.
356 *
357 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
358 * 3-D vectors (which may be identical), transforms the second and
359 * puts the result into the first.
360 */
361
362 #ifdef NOPROTO
363
364 extern int xf_handler(); /* handle xf entity */
365 extern void xf_xfmpoint(); /* transform point */
366 extern void xf_xfmvect(); /* transform vector */
367 extern void xf_rotvect(); /* rotate vector */
368 extern double xf_scale(); /* scale a value */
369 extern void xf_clear(); /* clear xf stack */
370
371 /* The following are support routines you probably won't call directly */
372
373 extern void multmat4(); /* m4a = m4b X m4c */
374 extern void multv3(); /* v3a = v3b X m4 (vectors) */
375 extern void multp3(); /* p3a = p3b X m4 (points) */
376 extern int xf(); /* interpret transform spec. */
377
378 #else
379
380 extern int xf_handler(int, char **); /* handle xf entity */
381 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
382 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
383 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
384 extern double xf_scale(double); /* scale a value */
385 extern void xf_clear(void); /* clear xf stack */
386
387 /* The following are support routines you probably won't call directly */
388
389 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
390 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
391 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
392 extern int xf(XF *, int, char **); /* interpret transform spec. */
393
394 #endif
395
396 /************************************************************************
397 * Miscellaneous definitions
398 */
399
400 #ifdef M_PI
401 #define PI M_PI
402 #else
403 #define PI 3.14159265358979323846
404 #endif
405
406 #ifdef DCL_ATOF
407 extern double atof();
408 #endif
409
410 #ifndef MEM_PTR
411 #define MEM_PTR void *
412 #endif
413
414 extern MEM_PTR malloc();
415 extern MEM_PTR calloc();
416 extern MEM_PTR realloc();
417 extern void free();
