--- ray/src/cv/mgflib/parser.h 1994/06/24 16:28:12 1.6 +++ ray/src/cv/mgflib/parser.h 1994/06/25 11:55:42 1.8 @@ -90,7 +90,7 @@ extern char *mg_err[MG_NERRS]; #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */ typedef struct mg_fctxt { - char *fname; /* file name */ + char fname[96]; /* file name */ FILE *fp; /* stream pointer */ char inpline[MG_MAXLINE]; /* input line */ int lineno; /* line number */ @@ -189,13 +189,15 @@ extern double normalize(FVECT); /* normalize a vector #define C_CDXY 010 /* flag if defined w/ xy */ typedef struct { + char *name; /* material name */ + int clock; /* incremented each change */ short flags; /* what's been set */ short ssamp[C_CNSS]; /* spectral samples, min wl to max */ long ssum; /* straight sum of spectral values */ float cx, cy; /* xy chromaticity value */ } C_COLOR; -#define C_DEFCOLOR { C_CDXY|C_CSXY|C_CSSPEC,\ +#define C_DEFCOLOR { NULL, 1, C_CDXY|C_CSXY|C_CSSPEC,\ {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\ @@ -205,19 +207,19 @@ typedef struct { C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\ (long)C_CNSS*C_CMAXV, 1./3., 1./3. } -#define C_CIEX { C_CDSPEC|C_CSSPEC|C_CSXY,\ +#define C_CIEX { "_cie_x", 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ {14,42,143,435,1344,2839,3483,3362,2908,1954,956,\ 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,\ 10622,10026,8544,6424,4479,2835,1649,874,468,227,\ 114,58,29,14,7,3,2,1,0}, 106836L, .735, .265 } -#define C_CIEY { C_CDSPEC|C_CSSPEC|C_CSXY,\ +#define C_CIEY { "_cie_y", 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,\ 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,\ 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,\ 5,2,1,1,0,0}, 106856L, .274, .717 } -#define C_CIEZ { C_CDSPEC|C_CSSPEC|C_CSXY,\ +#define C_CIEZ { "_cie_z", 1, C_CDSPEC|C_CSSPEC|C_CSXY,\ {65,201,679,2074,6456,13856,17471,17721,16692,\ 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,\ 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},\ @@ -243,12 +245,14 @@ typedef struct { } C_MATERIAL; /* material context */ typedef struct { + char *name; /* vector name */ + int clock; /* incremented each change -- resettable */ FVECT p, n; /* point and normal */ } C_VERTEX; /* vertex context */ #define C_DEFMATERIAL {NULL,1,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\ 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.} -#define C_DEFVERTEX {{0.,0.,0.},{0.,0.,0.}} +#define C_DEFVERTEX {NULL,1,{0.,0.,0.},{0.,0.,0.}} extern C_COLOR *c_ccolor; /* the current color */ extern C_MATERIAL *c_cmaterial; /* the current material */ @@ -260,6 +264,7 @@ extern int c_hmaterial(); /* handle material entity extern int c_hvertex(); /* handle vertex entity */ extern void c_clearall(); /* clear context tables */ extern C_VERTEX *c_getvert(); /* get a named vertex */ +extern C_COLOR *c_getcolor(); /* get a named color */ extern void c_ccvt(); /* fix color representation */ extern int c_isgrey(); /* check if color is grey */ #else @@ -268,6 +273,7 @@ extern int c_hmaterial(int, char **); /* handle materi extern int c_hvertex(int, char **); /* handle vertex entity */ extern void c_clearall(void); /* clear context tables */ extern C_VERTEX *c_getvert(char *); /* get a named vertex */ +extern C_COLOR *c_getcolor(char *); /* get a named color */ extern void c_ccvt(C_COLOR *, int); /* fix color representation */ extern int c_isgrey(C_COLOR *); /* check if color is grey */ #endif
