--- ray/src/cv/mgflib/parser.h 2003/06/07 01:11:17 1.34 +++ ray/src/cv/mgflib/parser.h 2003/11/15 17:54:06 1.37 @@ -1,4 +1,4 @@ -/* RCSid: $Id: parser.h,v 1.34 2003/06/07 01:11:17 schorsch Exp $ */ +/* RCSid: $Id: parser.h,v 1.37 2003/11/15 17:54:06 schorsch Exp $ */ /* * Header file for MGF interpreter */ @@ -170,15 +170,15 @@ extern int e_faceh(int, char **); /* expand face w/ ho */ #ifdef SMLFLT -#define FLOAT float +#define RREAL float #define FTINY (1e-3) #else -#define FLOAT double +#define RREAL double #define FTINY (1e-6) #endif #define FHUGE (1e10) -typedef FLOAT FVECT[3]; +typedef RREAL FVECT[3]; #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2]) #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2]) @@ -295,13 +295,9 @@ extern void obj_clear(void); /* clear object stack */ * Definitions for hierarchical transformation handler */ -typedef FLOAT MAT4[4][4]; +typedef RREAL MAT4[4][4]; -#ifdef BSD -#define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4)) -#else #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4)) -#endif #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \ {0.,0.,1.,0.}, {0.,0.,0.,1.} } @@ -313,7 +309,7 @@ extern MAT4 m4ident; /* regular transformation */ typedef struct { MAT4 xfm; /* transform matrix */ - FLOAT sca; /* scalefactor */ + RREAL sca; /* scalefactor */ } XF; #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0) @@ -377,6 +373,9 @@ extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */ extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */ extern int xf(XF *, int, char **); /* interpret transform spec. */ + + /* cvrgb.c */ +extern void mgf2rgb(C_COLOR *cin, double intensity, float cout[3]); /************************************************************************
