--- ray/src/cv/mgflib/parser.h 1995/11/08 09:40:26 1.26 +++ ray/src/cv/mgflib/parser.h 1996/02/08 16:29:33 1.29 @@ -9,7 +9,7 @@ /* must include stdio.h before us */ #define MG_VMAJOR 1 /* major version number */ -#define MG_VMINOR 0 /* minor version number */ +#define MG_VMINOR 1 /* minor version number */ /* Entities (list is only appended, never modified) */ #define MG_E_COMMENT 0 /* # */ @@ -80,8 +80,9 @@ extern unsigned mg_nunknown; /* count of unknown enti #define MG_ESEEK 9 /* file seek error */ #define MG_EBADMAT 10 /* bad material specification */ #define MG_ELINE 11 /* input line too long */ +#define MG_ECNTXT 12 /* unmatched context close */ -#define MG_NERRS 12 +#define MG_NERRS 13 extern char *mg_err[MG_NERRS]; /* list of error messages */ @@ -363,10 +364,10 @@ typedef struct xf_spec { extern XF_SPEC *xf_context; /* current transform context */ extern char **xf_argend; /* last transform argument */ -#define xf_ac(xf) ((xf)->xac) +#define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac) #define xf_av(xf) (xf_argend - (xf)->xac) -#define xf_argc (xf_context==NULL ? 0 : xf_ac(xf_context)) +#define xf_argc xf_ac(xf_context) #define xf_argv xf_av(xf_context) /* @@ -392,6 +393,10 @@ extern void xf_clear(); /* clear xf stack */ /* The following are support routines you probably won't call directly */ +XF_SPEC *new_xf(); /* allocate new transform */ +void free_xf(); /* free a transform */ +int xf_aname(); /* name this instance */ +long comp_xfid(); /* compute unique ID */ extern void multmat4(); /* m4a = m4b X m4c */ extern void multv3(); /* v3a = v3b X m4 (vectors) */ extern void multp3(); /* p3a = p3b X m4 (points) */ @@ -408,6 +413,10 @@ extern void xf_clear(void); /* clear xf stack */ /* The following are support routines you probably won't call directly */ +XF_SPEC *new_xf(int, char **); /* allocate new transform */ +void free_xf(XF_SPEC *); /* free a transform */ +int xf_aname(struct xf_array *); /* name this instance */ +long comp_xfid(MAT4); /* compute unique ID */ extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */ extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */ extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */ @@ -419,10 +428,12 @@ extern int xf(XF *, int, char **); /* interpret trans * Miscellaneous definitions */ +#ifndef PI #ifdef M_PI #define PI M_PI #else #define PI 3.14159265358979323846 +#endif #endif #ifdef DCL_ATOF
