root/radiance/ray/src/cv/mgflib/parser.h
Revision: 1.40
Committed: Tue Feb 22 15:58:42 2011 UTC (13 years, 3 months ago) by greg
Changes since 1.39: +1 -1 lines
State: FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
1 /* RCSid: $Id: parser.h,v 1.39 2011/01/14 05:46:12 greg Exp $ */
2 /*
3 * Header file for MGF interpreter
4 */
5 #ifndef _MGF_PARSER_H_
6 #define _MGF_PARSER_H_
7
8 /* must include stdio.h and stdlib.h before us */
9
10 #include "ccolor.h"
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15
16 #define MG_VMAJOR 2 /* major version number */
17 #define MG_VMINOR 0 /* minor version number */
18
19 /* Entities (list is only appended, never modified) */
20 #define MG_E_COMMENT 0 /* # */
21 #define MG_E_COLOR 1 /* c */
22 #define MG_E_CCT 2 /* cct */
23 #define MG_E_CONE 3 /* cone */
24 #define MG_E_CMIX 4 /* cmix */
25 #define MG_E_CSPEC 5 /* cspec */
26 #define MG_E_CXY 6 /* cxy */
27 #define MG_E_CYL 7 /* cyl */
28 #define MG_E_ED 8 /* ed */
29 #define MG_E_FACE 9 /* f */
30 #define MG_E_INCLUDE 10 /* i */
31 #define MG_E_IES 11 /* ies */
32 #define MG_E_IR 12 /* ir */
33 #define MG_E_MATERIAL 13 /* m */
34 #define MG_E_NORMAL 14 /* n */
35 #define MG_E_OBJECT 15 /* o */
36 #define MG_E_POINT 16 /* p */
37 #define MG_E_PRISM 17 /* prism */
38 #define MG_E_RD 18 /* rd */
39 #define MG_E_RING 19 /* ring */
40 #define MG_E_RS 20 /* rs */
41 #define MG_E_SIDES 21 /* sides */
42 #define MG_E_SPH 22 /* sph */
43 #define MG_E_TD 23 /* td */
44 #define MG_E_TORUS 24 /* torus */
45 #define MG_E_TS 25 /* ts */
46 #define MG_E_VERTEX 26 /* v */
47 #define MG_E_XF 27 /* xf */
48 /* end of Version 1 entities */
49 #define MG_E_FACEH 28 /* fh */
50 /* end of Version 2 entities */
51
52 #define MG_NENTITIES 29 /* total # entities */
53
54 #define MG_NELIST {28,29} /* entity count for version 1 and up */
55
56 #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\
57 "f","i","ies","ir","m","n","o","p","prism","rd",\
58 "ring","rs","sides","sph","td","torus","ts","v","xf",\
59 "fh"}
60
61 #define MG_MAXELEN 6
62
63 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
64
65 /* Handler routines for each entity and unknown ones */
66 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
67 extern int (*mg_uhand)(int argc, char **argv);
68 extern int mg_defuhand(int, char **);
69
70 extern unsigned mg_nunknown; /* count of unknown entities */
71
72 /* Error codes */
73 #define MG_OK 0 /* normal return value */
74 #define MG_EUNK 1 /* unknown entity */
75 #define MG_EARGC 2 /* wrong number of arguments */
76 #define MG_ETYPE 3 /* argument type error */
77 #define MG_EILL 4 /* illegal argument value */
78 #define MG_EUNDEF 5 /* undefined reference */
79 #define MG_ENOFILE 6 /* cannot open input file */
80 #define MG_EINCL 7 /* error in included file */
81 #define MG_EMEM 8 /* out of memory */
82 #define MG_ESEEK 9 /* file seek error */
83 #define MG_EBADMAT 10 /* bad material specification */
84 #define MG_ELINE 11 /* input line too long */
85 #define MG_ECNTXT 12 /* unmatched context close */
86
87 #define MG_NERRS 13
88
89 extern char *mg_err[MG_NERRS]; /* list of error messages */
90
91 /*
92 * The general process for running the parser is to fill in the mg_ehand
93 * array with handlers for each entity you know how to handle.
94 * Then, call mg_init to fill in the rest. This function will report
95 * an error and quit if you try to support an inconsistent set of entities.
96 * For each file you want to parse, call mg_load with the file name.
97 * To read from standard input, use NULL as the file name.
98 * For additional control over error reporting and file management,
99 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
100 * To pass an entity of your own construction to the parser, use
101 * the mg_handle function rather than the mg_ehand routines directly.
102 * (The first argument to mg_handle is the entity #, or -1.)
103 * To free any data structures and clear the parser, use mg_clear.
104 * If there is an error, mg_load, mg_open, mg_parse, mg_handle and
105 * mg_fgoto will return an error from the list above. In addition,
106 * mg_load will report the error to stderr. The mg_read routine
107 * returns 0 when the end of file has been reached.
108 */
109
110 #define MG_MAXLINE 4096 /* maximum input line length */
111 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
112
113 typedef struct mg_fctxt {
114 char fname[96]; /* file name */
115 FILE *fp; /* stream pointer */
116 int fid; /* unique file context id */
117 char inpline[MG_MAXLINE]; /* input line */
118 int lineno; /* line number */
119 struct mg_fctxt *prev; /* previous context */
120 } MG_FCTXT;
121
122 typedef struct {
123 int fid; /* file this position is for */
124 int lineno; /* line number in file */
125 long offset; /* offset from beginning */
126 } MG_FPOS;
127
128 extern MG_FCTXT *mg_file; /* current file context */
129
130 extern void mg_init(void); /* fill in mg_ehand array */
131 extern int mg_load(char *); /* parse a file */
132 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
133 extern int mg_read(void); /* read next line */
134 extern int mg_parse(void); /* parse current line */
135 extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
136 extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
137 extern void mg_close(void); /* close input file */
138 extern void mg_clear(void); /* clear parser */
139 extern int mg_handle(int, int, char **); /* handle an entity */
140
141 #ifndef MG_NQCD
142 #define MG_NQCD 5 /* default number of divisions */
143 #endif
144
145 extern int mg_nqcdivs; /* divisions per quarter circle */
146
147 /*
148 * The following library routines are included for your convenience:
149 */
150
151 extern int mg_entity(char *); /* get entity number from its name */
152 extern int isint(char *); /* non-zero if integer format */
153 extern int isintd(char *, char *); /* same with delimiter set */
154 extern int isflt(char *); /* non-zero if floating point format */
155 extern int isfltd(char *, char *); /* same with delimiter set */
156 extern int isname(char *); /* non-zero if legal identifier name */
157 extern int badarg(int, char **, char *);/* check argument format */
158 extern int e_include(int, char **); /* expand include entity */
159 extern int e_pipe(int, char **); /* expand piped command */
160 extern int e_sph(int, char **); /* expand sphere as other entities */
161 extern int e_torus(int, char **); /* expand torus as other entities */
162 extern int e_cyl(int, char **); /* expand cylinder as other entities */
163 extern int e_ring(int, char **); /* expand ring as other entities */
164 extern int e_cone(int, char **); /* expand cone as other entities */
165 extern int e_prism(int, char **); /* expand prism as other entities */
166 extern int e_faceh(int, char **); /* expand face w/ holes as face */
167
168 /************************************************************************
169 * Definitions for 3-d vector manipulation functions
170 */
171
172 #ifdef SMLFLT
173 #define RREAL float
174 #define FTINY (1e-3)
175 #else
176 #define RREAL double
177 #define FTINY (1e-6)
178 #endif
179 #define FHUGE (1e10)
180
181 typedef RREAL FVECT[3];
182
183 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
184 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
185 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
186 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
187 (vr)[2]=(v1)[2]+(f)*(v2)[2])
188
189 #define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
190
191 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
192
193 extern double normalize(FVECT); /* normalize a vector */
194 extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */
195
196 /************************************************************************
197 * Definitions for context handling routines
198 * (materials, colors, vectors)
199 */
200
201 #define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
202
203 typedef struct {
204 int clock; /* incremented each change -- resettable */
205 void *client_data; /* pointer to private client-owned data */
206 int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
207 float nr, ni; /* index of refraction, real and imaginary */
208 float rd; /* diffuse reflectance */
209 C_COLOR rd_c; /* diffuse reflectance color */
210 float td; /* diffuse transmittance */
211 C_COLOR td_c; /* diffuse transmittance color */
212 float ed; /* diffuse emittance */
213 C_COLOR ed_c; /* diffuse emittance color */
214 float rs; /* specular reflectance */
215 C_COLOR rs_c; /* specular reflectance color */
216 float rs_a; /* specular reflectance roughness */
217 float ts; /* specular transmittance */
218 C_COLOR ts_c; /* specular transmittance color */
219 float ts_a; /* specular transmittance roughness */
220 } C_MATERIAL; /* material context */
221
222 typedef struct {
223 int clock; /* incremented each change -- resettable */
224 void *client_data; /* pointer to private client-owned data */
225 FVECT p, n; /* point and normal */
226 } C_VERTEX; /* vertex context */
227
228 #define C_DEFMATERIAL {1,NULL,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,\
229 C_DEFCOLOR,0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
230 #define C_DEFVERTEX {1,NULL,{0.,0.,0.},{0.,0.,0.}}
231
232 extern C_COLOR *c_ccolor; /* the current color */
233 extern char *c_ccname; /* current color name */
234 extern C_MATERIAL *c_cmaterial; /* the current material */
235 extern char *c_cmname; /* current material name */
236 extern C_VERTEX *c_cvertex; /* the current vertex */
237 extern char *c_cvname; /* current vertex name */
238
239 extern int c_hcolor(int, char **); /* handle color entity */
240 extern int c_hmaterial(int, char **); /* handle material entity */
241 extern int c_hvertex(int, char **); /* handle vertex entity */
242 extern void c_clearall(void); /* clear context tables */
243 extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
244 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
245 extern C_COLOR *c_getcolor(char *); /* get a named color */
246
247 /*************************************************************************
248 * Definitions for hierarchical object name handler
249 */
250
251 extern int obj_nnames; /* depth of name hierarchy */
252 extern char **obj_name; /* names in hierarchy */
253
254 extern int obj_handler(int, char **); /* handle an object entity */
255 extern void obj_clear(void); /* clear object stack */
256
257 /**************************************************************************
258 * Definitions for hierarchical transformation handler
259 */
260
261 typedef RREAL MAT4[4][4];
262
263 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
264
265 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
266 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
267
268 extern MAT4 m4ident;
269
270 #define setident4(m4) copymat4(m4, m4ident)
271
272 /* regular transformation */
273 typedef struct {
274 MAT4 xfm; /* transform matrix */
275 RREAL sca; /* scalefactor */
276 } XF;
277
278 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
279
280 #define XF_MAXDIM 8 /* maximum array dimensions */
281
282 struct xf_array {
283 MG_FPOS spos; /* starting position on input */
284 int ndim; /* number of array dimensions */
285 struct {
286 short i, n; /* current count and maximum */
287 char arg[8]; /* string argument value */
288 } aarg[XF_MAXDIM];
289 };
290
291 typedef struct xf_spec {
292 long xid; /* unique transform id */
293 short xac; /* context argument count */
294 short rev; /* boolean true if vertices reversed */
295 XF xf; /* cumulative transformation */
296 struct xf_array *xarr; /* transformation array pointer */
297 struct xf_spec *prev; /* previous transformation context */
298 } XF_SPEC; /* followed by argument buffer */
299
300 extern XF_SPEC *xf_context; /* current transform context */
301 extern char **xf_argend; /* last transform argument */
302
303 #define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac)
304 #define xf_av(xf) (xf_argend - (xf)->xac)
305
306 #define xf_argc xf_ac(xf_context)
307 #define xf_argv xf_av(xf_context)
308
309 /*
310 * The transformation handler should do most of the work that needs
311 * doing. Just pass it any xf entities, then use the associated
312 * functions to transform and translate points, transform vectors
313 * (without translation), rotate vectors (without scaling) and scale
314 * values appropriately.
315 *
316 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
317 * 3-D vectors (which may be identical), transforms the second and
318 * puts the result into the first.
319 */
320
321
322 extern int xf_handler(int, char **); /* handle xf entity */
323 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
324 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
325 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
326 extern double xf_scale(double); /* scale a value */
327 extern void xf_clear(void); /* clear xf stack */
328
329 /* The following are support routines you probably won't call directly */
330
331 XF_SPEC *new_xf(int, char **); /* allocate new transform */
332 void free_xf(XF_SPEC *); /* free a transform */
333 int xf_aname(struct xf_array *); /* name this instance */
334 long comp_xfid(MAT4); /* compute unique ID */
335 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
336 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
337 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
338 extern int xf(XF *, int, char **); /* interpret transform spec. */
339
340 /* cvrgb.c */
341 extern void mgf2rgb(C_COLOR *cin, double intensity, float cout[3]);
342
343 /************************************************************************
344 * Miscellaneous definitions
345 */
346
347 #ifndef PI
348 #ifdef M_PI
349 #define PI ((double)M_PI)
350 #else
351 #define PI 3.14159265358979323846
352 #endif
353 #endif
354
355 #ifdef __cplusplus
356 }
357 #endif
358 #endif /* _MGF_PARSER_H_ */
359
