root/radiance/ray/src/cv/mgflib/parser.h
Revision: 1.38
Committed: Mon Jan 3 20:30:21 2011 UTC (13 years, 5 months ago) by greg
Changes since 1.37: +3 -44 lines
Separated color manipulation routines
1 /* RCSid: $Id: parser.h,v 1.37 2003/11/15 17:54:06 schorsch Exp $ */
2 /*
3 * Header file for MGF interpreter
4 */
5 #ifndef _MGF_PARSER_H_
6 #define _MGF_PARSER_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11 /* must include stdio.h and stdlib.h before us */
12
13 #include "ccolor.h"
14
15 #define MG_VMAJOR 2 /* major version number */
16 #define MG_VMINOR 0 /* minor version number */
17
18 /* Entities (list is only appended, never modified) */
19 #define MG_E_COMMENT 0 /* # */
20 #define MG_E_COLOR 1 /* c */
21 #define MG_E_CCT 2 /* cct */
22 #define MG_E_CONE 3 /* cone */
23 #define MG_E_CMIX 4 /* cmix */
24 #define MG_E_CSPEC 5 /* cspec */
25 #define MG_E_CXY 6 /* cxy */
26 #define MG_E_CYL 7 /* cyl */
27 #define MG_E_ED 8 /* ed */
28 #define MG_E_FACE 9 /* f */
29 #define MG_E_INCLUDE 10 /* i */
30 #define MG_E_IES 11 /* ies */
31 #define MG_E_IR 12 /* ir */
32 #define MG_E_MATERIAL 13 /* m */
33 #define MG_E_NORMAL 14 /* n */
34 #define MG_E_OBJECT 15 /* o */
35 #define MG_E_POINT 16 /* p */
36 #define MG_E_PRISM 17 /* prism */
37 #define MG_E_RD 18 /* rd */
38 #define MG_E_RING 19 /* ring */
39 #define MG_E_RS 20 /* rs */
40 #define MG_E_SIDES 21 /* sides */
41 #define MG_E_SPH 22 /* sph */
42 #define MG_E_TD 23 /* td */
43 #define MG_E_TORUS 24 /* torus */
44 #define MG_E_TS 25 /* ts */
45 #define MG_E_VERTEX 26 /* v */
46 #define MG_E_XF 27 /* xf */
47 /* end of Version 1 entities */
48 #define MG_E_FACEH 28 /* fh */
49 /* end of Version 2 entities */
50
51 #define MG_NENTITIES 29 /* total # entities */
52
53 #define MG_NELIST {28,29} /* entity count for version 1 and up */
54
55 #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\
56 "f","i","ies","ir","m","n","o","p","prism","rd",\
57 "ring","rs","sides","sph","td","torus","ts","v","xf",\
58 "fh"}
59
60 #define MG_MAXELEN 6
61
62 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
63
64 /* Handler routines for each entity and unknown ones */
65 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
66 extern int (*mg_uhand)(int argc, char **argv);
67 extern int mg_defuhand(int, char **);
68
69 extern unsigned mg_nunknown; /* count of unknown entities */
70
71 /* Error codes */
72 #define MG_OK 0 /* normal return value */
73 #define MG_EUNK 1 /* unknown entity */
74 #define MG_EARGC 2 /* wrong number of arguments */
75 #define MG_ETYPE 3 /* argument type error */
76 #define MG_EILL 4 /* illegal argument value */
77 #define MG_EUNDEF 5 /* undefined reference */
78 #define MG_ENOFILE 6 /* cannot open input file */
79 #define MG_EINCL 7 /* error in included file */
80 #define MG_EMEM 8 /* out of memory */
81 #define MG_ESEEK 9 /* file seek error */
82 #define MG_EBADMAT 10 /* bad material specification */
83 #define MG_ELINE 11 /* input line too long */
84 #define MG_ECNTXT 12 /* unmatched context close */
85
86 #define MG_NERRS 13
87
88 extern char *mg_err[MG_NERRS]; /* list of error messages */
89
90 /*
91 * The general process for running the parser is to fill in the mg_ehand
92 * array with handlers for each entity you know how to handle.
93 * Then, call mg_init to fill in the rest. This function will report
94 * an error and quit if you try to support an inconsistent set of entities.
95 * For each file you want to parse, call mg_load with the file name.
96 * To read from standard input, use NULL as the file name.
97 * For additional control over error reporting and file management,
98 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
99 * To pass an entity of your own construction to the parser, use
100 * the mg_handle function rather than the mg_ehand routines directly.
101 * (The first argument to mg_handle is the entity #, or -1.)
102 * To free any data structures and clear the parser, use mg_clear.
103 * If there is an error, mg_load, mg_open, mg_parse, mg_handle and
104 * mg_fgoto will return an error from the list above. In addition,
105 * mg_load will report the error to stderr. The mg_read routine
106 * returns 0 when the end of file has been reached.
107 */
108
109 #define MG_MAXLINE 4096 /* maximum input line length */
110 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
111
112 typedef struct mg_fctxt {
113 char fname[96]; /* file name */
114 FILE *fp; /* stream pointer */
115 int fid; /* unique file context id */
116 char inpline[MG_MAXLINE]; /* input line */
117 int lineno; /* line number */
118 struct mg_fctxt *prev; /* previous context */
119 } MG_FCTXT;
120
121 typedef struct {
122 int fid; /* file this position is for */
123 int lineno; /* line number in file */
124 long offset; /* offset from beginning */
125 } MG_FPOS;
126
127 extern MG_FCTXT *mg_file; /* current file context */
128
129 extern void mg_init(void); /* fill in mg_ehand array */
130 extern int mg_load(char *); /* parse a file */
131 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
132 extern int mg_read(void); /* read next line */
133 extern int mg_parse(void); /* parse current line */
134 extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
135 extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
136 extern void mg_close(void); /* close input file */
137 extern void mg_clear(void); /* clear parser */
138 extern int mg_handle(int, int, char **); /* handle an entity */
139
140 #ifndef MG_NQCD
141 #define MG_NQCD 5 /* default number of divisions */
142 #endif
143
144 extern int mg_nqcdivs; /* divisions per quarter circle */
145
146 /*
147 * The following library routines are included for your convenience:
148 */
149
150 extern int mg_entity(char *); /* get entity number from its name */
151 extern int isint(char *); /* non-zero if integer format */
152 extern int isintd(char *, char *); /* same with delimiter set */
153 extern int isflt(char *); /* non-zero if floating point format */
154 extern int isfltd(char *, char *); /* same with delimiter set */
155 extern int isname(char *); /* non-zero if legal identifier name */
156 extern int badarg(int, char **, char *);/* check argument format */
157 extern int e_include(int, char **); /* expand include entity */
158 extern int e_pipe(int, char **); /* expand piped command */
159 extern int e_sph(int, char **); /* expand sphere as other entities */
160 extern int e_torus(int, char **); /* expand torus as other entities */
161 extern int e_cyl(int, char **); /* expand cylinder as other entities */
162 extern int e_ring(int, char **); /* expand ring as other entities */
163 extern int e_cone(int, char **); /* expand cone as other entities */
164 extern int e_prism(int, char **); /* expand prism as other entities */
165 extern int e_faceh(int, char **); /* expand face w/ holes as face */
166
167 /************************************************************************
168 * Definitions for 3-d vector manipulation functions
169 */
170
171 #ifdef SMLFLT
172 #define RREAL float
173 #define FTINY (1e-3)
174 #else
175 #define RREAL double
176 #define FTINY (1e-6)
177 #endif
178 #define FHUGE (1e10)
179
180 typedef RREAL FVECT[3];
181
182 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
183 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
184 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
185 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
186 (vr)[2]=(v1)[2]+(f)*(v2)[2])
187
188 #define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
189
190 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
191
192 extern double normalize(FVECT); /* normalize a vector */
193 extern void fcross(FVECT,FVECT,FVECT);/* cross product of two vectors */
194
195 /************************************************************************
196 * Definitions for context handling routines
197 * (materials, colors, vectors)
198 */
199
200 #define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
201
202 typedef struct {
203 int clock; /* incremented each change -- resettable */
204 char *client_data; /* pointer to private client-owned data */
205 int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
206 float nr, ni; /* index of refraction, real and imaginary */
207 float rd; /* diffuse reflectance */
208 C_COLOR rd_c; /* diffuse reflectance color */
209 float td; /* diffuse transmittance */
210 C_COLOR td_c; /* diffuse transmittance color */
211 float ed; /* diffuse emittance */
212 C_COLOR ed_c; /* diffuse emittance color */
213 float rs; /* specular reflectance */
214 C_COLOR rs_c; /* specular reflectance color */
215 float rs_a; /* specular reflectance roughness */
216 float ts; /* specular transmittance */
217 C_COLOR ts_c; /* specular transmittance color */
218 float ts_a; /* specular transmittance roughness */
219 } C_MATERIAL; /* material context */
220
221 typedef struct {
222 int clock; /* incremented each change -- resettable */
223 char *client_data; /* pointer to private client-owned data */
224 FVECT p, n; /* point and normal */
225 } C_VERTEX; /* vertex context */
226
227 #define C_DEFMATERIAL {1,NULL,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,\
228 C_DEFCOLOR,0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
229 #define C_DEFVERTEX {1,NULL,{0.,0.,0.},{0.,0.,0.}}
230
231 extern C_COLOR *c_ccolor; /* the current color */
232 extern char *c_ccname; /* current color name */
233 extern C_MATERIAL *c_cmaterial; /* the current material */
234 extern char *c_cmname; /* current material name */
235 extern C_VERTEX *c_cvertex; /* the current vertex */
236 extern char *c_cvname; /* current vertex name */
237
238 extern int c_hcolor(int, char **); /* handle color entity */
239 extern int c_hmaterial(int, char **); /* handle material entity */
240 extern int c_hvertex(int, char **); /* handle vertex entity */
241 extern void c_clearall(void); /* clear context tables */
242 extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
243 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
244 extern C_COLOR *c_getcolor(char *); /* get a named color */
245
246 /*************************************************************************
247 * Definitions for hierarchical object name handler
248 */
249
250 extern int obj_nnames; /* depth of name hierarchy */
251 extern char **obj_name; /* names in hierarchy */
252
253 extern int obj_handler(int, char **); /* handle an object entity */
254 extern void obj_clear(void); /* clear object stack */
255
256 /**************************************************************************
257 * Definitions for hierarchical transformation handler
258 */
259
260 typedef RREAL MAT4[4][4];
261
262 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
263
264 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
265 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
266
267 extern MAT4 m4ident;
268
269 #define setident4(m4) copymat4(m4, m4ident)
270
271 /* regular transformation */
272 typedef struct {
273 MAT4 xfm; /* transform matrix */
274 RREAL sca; /* scalefactor */
275 } XF;
276
277 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
278
279 #define XF_MAXDIM 8 /* maximum array dimensions */
280
281 struct xf_array {
282 MG_FPOS spos; /* starting position on input */
283 int ndim; /* number of array dimensions */
284 struct {
285 short i, n; /* current count and maximum */
286 char arg[8]; /* string argument value */
287 } aarg[XF_MAXDIM];
288 };
289
290 typedef struct xf_spec {
291 long xid; /* unique transform id */
292 short xac; /* context argument count */
293 short rev; /* boolean true if vertices reversed */
294 XF xf; /* cumulative transformation */
295 struct xf_array *xarr; /* transformation array pointer */
296 struct xf_spec *prev; /* previous transformation context */
297 } XF_SPEC; /* followed by argument buffer */
298
299 extern XF_SPEC *xf_context; /* current transform context */
300 extern char **xf_argend; /* last transform argument */
301
302 #define xf_ac(xf) ((xf)==NULL ? 0 : (xf)->xac)
303 #define xf_av(xf) (xf_argend - (xf)->xac)
304
305 #define xf_argc xf_ac(xf_context)
306 #define xf_argv xf_av(xf_context)
307
308 /*
309 * The transformation handler should do most of the work that needs
310 * doing. Just pass it any xf entities, then use the associated
311 * functions to transform and translate points, transform vectors
312 * (without translation), rotate vectors (without scaling) and scale
313 * values appropriately.
314 *
315 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
316 * 3-D vectors (which may be identical), transforms the second and
317 * puts the result into the first.
318 */
319
320
321 extern int xf_handler(int, char **); /* handle xf entity */
322 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
323 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
324 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
325 extern double xf_scale(double); /* scale a value */
326 extern void xf_clear(void); /* clear xf stack */
327
328 /* The following are support routines you probably won't call directly */
329
330 XF_SPEC *new_xf(int, char **); /* allocate new transform */
331 void free_xf(XF_SPEC *); /* free a transform */
332 int xf_aname(struct xf_array *); /* name this instance */
333 long comp_xfid(MAT4); /* compute unique ID */
334 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
335 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
336 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
337 extern int xf(XF *, int, char **); /* interpret transform spec. */
338
339 /* cvrgb.c */
340 extern void mgf2rgb(C_COLOR *cin, double intensity, float cout[3]);
341
342
343 /************************************************************************
344 * Miscellaneous definitions
345 */
346
347 #ifndef PI
348 #ifdef M_PI
349 #define PI ((double)M_PI)
350 #else
351 #define PI 3.14159265358979323846
352 #endif
353 #endif
354
355 #ifndef MEM_PTR
356 #define MEM_PTR void *
357 #endif
358
359 #ifdef __cplusplus
360 }
361 #endif
362 #endif /* _MGF_PARSER_H_ */
363
