root/radiance/ray/src/cv/mgflib/parser.h
Revision: 1.27
Committed: Wed Nov 29 16:45:13 1995 UTC (29 years, 5 months ago) by greg
Changes since 1.26: +2 -1 lines
added error for unmatched xf or o context close
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for MGF interpreter
7 */
8
9 /* must include stdio.h before us */
10
11 #define MG_VMAJOR 1 /* major version number */
12 #define MG_VMINOR 0 /* minor version number */
13
14 /* Entities (list is only appended, never modified) */
15 #define MG_E_COMMENT 0 /* # */
16 #define MG_E_COLOR 1 /* c */
17 #define MG_E_CCT 2 /* cct */
18 #define MG_E_CONE 3 /* cone */
19 #define MG_E_CMIX 4 /* cmix */
20 #define MG_E_CSPEC 5 /* cspec */
21 #define MG_E_CXY 6 /* cxy */
22 #define MG_E_CYL 7 /* cyl */
23 #define MG_E_ED 8 /* ed */
24 #define MG_E_FACE 9 /* f */
25 #define MG_E_INCLUDE 10 /* i */
26 #define MG_E_IES 11 /* ies */
27 #define MG_E_IR 12 /* ir */
28 #define MG_E_MATERIAL 13 /* m */
29 #define MG_E_NORMAL 14 /* n */
30 #define MG_E_OBJECT 15 /* o */
31 #define MG_E_POINT 16 /* p */
32 #define MG_E_PRISM 17 /* prism */
33 #define MG_E_RD 18 /* rd */
34 #define MG_E_RING 19 /* ring */
35 #define MG_E_RS 20 /* rs */
36 #define MG_E_SIDES 21 /* sides */
37 #define MG_E_SPH 22 /* sph */
38 #define MG_E_TD 23 /* td */
39 #define MG_E_TORUS 24 /* torus */
40 #define MG_E_TS 25 /* ts */
41 #define MG_E_VERTEX 26 /* v */
42 #define MG_E_XF 27 /* xf */
43 /* end of Version 1 entities */
44
45 #define MG_NENTITIES 28 /* total # entities */
46
47 #define MG_NELIST {28} /* entity count for version 1 and up */
48
49 #define MG_NAMELIST {"#","c","cct","cone","cmix","cspec","cxy","cyl","ed",\
50 "f","i","ies","ir","m","n","o","p","prism","rd",\
51 "ring","rs","sides","sph","td","torus","ts","v","xf"}
52
53 #define MG_MAXELEN 6
54
55 extern char mg_ename[MG_NENTITIES][MG_MAXELEN];
56
57 /* Handler routines for each entity and unknown ones */
58 #ifdef NOPROTO
59 extern int (*mg_ehand[MG_NENTITIES])();
60 extern int (*mg_uhand)();
61 extern int mg_defuhand();
62 #else
63 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
64 extern int (*mg_uhand)(int argc, char **argv);
65 extern int mg_defuhand(int, char **);
66 #endif
67
68 extern unsigned mg_nunknown; /* count of unknown entities */
69
70 /* Error codes */
71 #define MG_OK 0 /* normal return value */
72 #define MG_EUNK 1 /* unknown entity */
73 #define MG_EARGC 2 /* wrong number of arguments */
74 #define MG_ETYPE 3 /* argument type error */
75 #define MG_EILL 4 /* illegal argument value */
76 #define MG_EUNDEF 5 /* undefined reference */
77 #define MG_ENOFILE 6 /* cannot open input file */
78 #define MG_EINCL 7 /* error in included file */
79 #define MG_EMEM 8 /* out of memory */
80 #define MG_ESEEK 9 /* file seek error */
81 #define MG_EBADMAT 10 /* bad material specification */
82 #define MG_ELINE 11 /* input line too long */
83 #define MG_ECNTXT 12 /* unmatched context close */
84
85 #define MG_NERRS 13
86
87 extern char *mg_err[MG_NERRS]; /* list of error messages */
88
89 /*
90 * The general process for running the parser is to fill in the mg_ehand
91 * array with handlers for each entity you know how to handle.
92 * Then, call mg_init to fill in the rest. This function will report
93 * an error and quit if you try to support an inconsistent set of entities.
94 * For each file you want to parse, call mg_load with the file name.
95 * To read from standard input, use NULL as the file name.
96 * For additional control over error reporting and file management,
97 * use mg_open, mg_read, mg_parse and mg_close instead of mg_load.
98 * To pass an entity of your own construction to the parser, use
99 * the mg_handle function rather than the mg_ehand routines directly.
100 * (The first argument to mg_handle is the entity #, or -1.)
101 * To free any data structures and clear the parser, use mg_clear.
102 * If there is an error, mg_load, mg_open, mg_parse, mg_handle and
103 * mg_fgoto will return an error from the list above. In addition,
104 * mg_load will report the error to stderr. The mg_read routine
105 * returns 0 when the end of file has been reached.
106 */
107
108 #define MG_MAXLINE 4096 /* maximum input line length */
109 #define MG_MAXARGC (MG_MAXLINE/4) /* maximum argument count */
110
111 typedef struct mg_fctxt {
112 char fname[96]; /* file name */
113 FILE *fp; /* stream pointer */
114 int fid; /* unique file context id */
115 char inpline[MG_MAXLINE]; /* input line */
116 int lineno; /* line number */
117 struct mg_fctxt *prev; /* previous context */
118 } MG_FCTXT;
119
120 typedef struct {
121 int fid; /* file this position is for */
122 int lineno; /* line number in file */
123 long offset; /* offset from beginning */
124 } MG_FPOS;
125
126 extern MG_FCTXT *mg_file; /* current file context */
127
128 #ifdef NOPROTO
129 extern void mg_init(); /* fill in mg_ehand array */
130 extern int mg_load(); /* parse a file */
131 extern int mg_open(); /* open new input file */
132 extern int mg_read(); /* read next line */
133 extern int mg_parse(); /* parse current line */
134 extern void mg_fgetpos(); /* get position on input file */
135 extern int mg_fgoto(); /* go to position on input file */
136 extern void mg_close(); /* close input file */
137 extern void mg_clear(); /* clear parser */
138 extern int mg_handle(); /* handle an entity */
139 #else
140 extern void mg_init(void); /* fill in mg_ehand array */
141 extern int mg_load(char *); /* parse a file */
142 extern int mg_open(MG_FCTXT *, char *); /* open new input file */
143 extern int mg_read(void); /* read next line */
144 extern int mg_parse(void); /* parse current line */
145 extern void mg_fgetpos(MG_FPOS *); /* get position on input file */
146 extern int mg_fgoto(MG_FPOS *); /* go to position on input file */
147 extern void mg_close(void); /* close input file */
148 extern void mg_clear(void); /* clear parser */
149 extern int mg_handle(int, int, char **); /* handle an entity */
150 #endif
151
152 #ifndef MG_NQCD
153 #define MG_NQCD 5 /* default number of divisions */
154 #endif
155
156 extern int mg_nqcdivs; /* divisions per quarter circle */
157
158 /*
159 * The following library routines are included for your convenience:
160 */
161
162 #ifdef NOPROTO
163 extern int mg_entity(); /* get entity number from its name */
164 extern int isint(); /* non-zero if integer format */
165 extern int isflt(); /* non-zero if floating point format */
166 extern int isname(); /* non-zero if legal identifier name */
167 #else
168 extern int mg_entity(char *); /* get entity number from its name */
169 extern int isint(char *); /* non-zero if integer format */
170 extern int isflt(char *); /* non-zero if floating point format */
171 extern int isname(char *); /* non-zero if legal identifier name */
172 #endif
173
174 /************************************************************************
175 * Definitions for 3-d vector manipulation functions
176 */
177
178 #ifdef SMLFLT
179 #define FLOAT float
180 #define FTINY (1e-3)
181 #else
182 #define FLOAT double
183 #define FTINY (1e-6)
184 #endif
185 #define FHUGE (1e10)
186
187 typedef FLOAT FVECT[3];
188
189 #define VCOPY(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1],(v1)[2]=(v2)[2])
190 #define DOT(v1,v2) ((v1)[0]*(v2)[0]+(v1)[1]*(v2)[1]+(v1)[2]*(v2)[2])
191 #define VSUM(vr,v1,v2,f) ((vr)[0]=(v1)[0]+(f)*(v2)[0], \
192 (vr)[1]=(v1)[1]+(f)*(v2)[1], \
193 (vr)[2]=(v1)[2]+(f)*(v2)[2])
194
195 #define is0vect(v) (DOT(v,v) <= FTINY*FTINY)
196
197 #define round0(x) if (x <= FTINY && x >= -FTINY) x = 0
198
199 #ifdef NOPROTO
200 extern double normalize(); /* normalize a vector */
201 #else
202 extern double normalize(FVECT); /* normalize a vector */
203 #endif
204
205 /************************************************************************
206 * Definitions for context handling routines
207 * (materials, colors, vectors)
208 */
209
210 #define C_CMINWL 380 /* minimum wavelength */
211 #define C_CMAXWL 780 /* maximum wavelength */
212 #define C_CNSS 41 /* number of spectral samples */
213 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
214 #define C_CMAXV 10000 /* nominal maximum sample value */
215 #define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
216
217 #define C_CSSPEC 01 /* flag if spectrum is set */
218 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
219 #define C_CSXY 04 /* flag if xy is set */
220 #define C_CDXY 010 /* flag if defined w/ xy */
221 #define C_CSEFF 020 /* flag if efficacy set */
222
223 typedef struct {
224 int clock; /* incremented each change */
225 short flags; /* what's been set */
226 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
227 long ssum; /* straight sum of spectral values */
228 float cx, cy; /* xy chromaticity value */
229 float eff; /* efficacy (lumens/watt) */
230 } C_COLOR;
231
232 #define C_DEFCOLOR { 1, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\
233 {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
234 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
235 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
236 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
237 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
238 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
239 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\
240 (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 }
241
242 #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum)
243
244 #define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
245
246 typedef struct {
247 int clock; /* incremented each change -- resettable */
248 int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
249 float nr, ni; /* index of refraction, real and imaginary */
250 float rd; /* diffuse reflectance */
251 C_COLOR rd_c; /* diffuse reflectance color */
252 float td; /* diffuse transmittance */
253 C_COLOR td_c; /* diffuse transmittance color */
254 float ed; /* diffuse emittance */
255 C_COLOR ed_c; /* diffuse emittance color */
256 float rs; /* specular reflectance */
257 C_COLOR rs_c; /* specular reflectance color */
258 float rs_a; /* specular reflectance roughness */
259 float ts; /* specular transmittance */
260 C_COLOR ts_c; /* specular transmittance color */
261 float ts_a; /* specular transmittance roughness */
262 } C_MATERIAL; /* material context */
263
264 typedef struct {
265 int clock; /* incremented each change -- resettable */
266 FVECT p, n; /* point and normal */
267 } C_VERTEX; /* vertex context */
268
269 #define C_DEFMATERIAL {1,0,1.,0.,0.,C_DEFCOLOR,0.,C_DEFCOLOR,0.,C_DEFCOLOR,\
270 0.,C_DEFCOLOR,0.,0.,C_DEFCOLOR,0.}
271 #define C_DEFVERTEX {1,{0.,0.,0.},{0.,0.,0.}}
272
273 extern C_COLOR *c_ccolor; /* the current color */
274 extern char *c_ccname; /* current color name */
275 extern C_MATERIAL *c_cmaterial; /* the current material */
276 extern char *c_cmname; /* current material name */
277 extern C_VERTEX *c_cvertex; /* the current vertex */
278 extern char *c_cvname; /* current vertex name */
279
280 #ifdef NOPROTO
281 extern int c_hcolor(); /* handle color entity */
282 extern int c_hmaterial(); /* handle material entity */
283 extern int c_hvertex(); /* handle vertex entity */
284 extern void c_clearall(); /* clear context tables */
285 extern C_MATERIAL *c_getmaterial(); /* get a named material */
286 extern C_VERTEX *c_getvert(); /* get a named vertex */
287 extern C_COLOR *c_getcolor(); /* get a named color */
288 extern void c_ccvt(); /* fix color representation */
289 extern int c_isgrey(); /* check if color is grey */
290 #else
291 extern int c_hcolor(int, char **); /* handle color entity */
292 extern int c_hmaterial(int, char **); /* handle material entity */
293 extern int c_hvertex(int, char **); /* handle vertex entity */
294 extern void c_clearall(void); /* clear context tables */
295 extern C_MATERIAL *c_getmaterial(char *); /* get a named material */
296 extern C_VERTEX *c_getvert(char *); /* get a named vertex */
297 extern C_COLOR *c_getcolor(char *); /* get a named color */
298 extern void c_ccvt(C_COLOR *, int); /* fix color representation */
299 extern int c_isgrey(C_COLOR *); /* check if color is grey */
300 #endif
301
302 /*************************************************************************
303 * Definitions for hierarchical object name handler
304 */
305
306 extern int obj_nnames; /* depth of name hierarchy */
307 extern char **obj_name; /* names in hierarchy */
308
309 #ifdef NOPROTO
310 extern int obj_handler(); /* handle an object entity */
311 extern void obj_clear(); /* clear object stack */
312 #else
313 extern int obj_handler(int, char **); /* handle an object entity */
314 extern void obj_clear(void); /* clear object stack */
315 #endif
316
317 /**************************************************************************
318 * Definitions for hierarchical transformation handler
319 */
320
321 typedef FLOAT MAT4[4][4];
322
323 #ifdef BSD
324 #define copymat4(m4a,m4b) bcopy((char *)m4b,(char *)m4a,sizeof(MAT4))
325 #else
326 #define copymat4(m4a,m4b) (void)memcpy((char *)m4a,(char *)m4b,sizeof(MAT4))
327 #endif
328
329 #define MAT4IDENT { {1.,0.,0.,0.}, {0.,1.,0.,0.}, \
330 {0.,0.,1.,0.}, {0.,0.,0.,1.} }
331
332 extern MAT4 m4ident;
333
334 #define setident4(m4) copymat4(m4, m4ident)
335
336 /* regular transformation */
337 typedef struct {
338 MAT4 xfm; /* transform matrix */
339 FLOAT sca; /* scalefactor */
340 } XF;
341
342 #define identxf(xp) (void)(setident4((xp)->xfm),(xp)->sca=1.0)
343
344 #define XF_MAXDIM 8 /* maximum array dimensions */
345
346 struct xf_array {
347 MG_FPOS spos; /* starting position on input */
348 int ndim; /* number of array dimensions */
349 struct {
350 short i, n; /* current count and maximum */
351 char arg[8]; /* string argument value */
352 } aarg[XF_MAXDIM];
353 };
354
355 typedef struct xf_spec {
356 long xid; /* unique transform id */
357 short xac; /* context argument count */
358 short rev; /* boolean true if vertices reversed */
359 XF xf; /* cumulative transformation */
360 struct xf_array *xarr; /* transformation array pointer */
361 struct xf_spec *prev; /* previous transformation context */
362 } XF_SPEC; /* followed by argument buffer */
363
364 extern XF_SPEC *xf_context; /* current transform context */
365 extern char **xf_argend; /* last transform argument */
366
367 #define xf_ac(xf) ((xf)->xac)
368 #define xf_av(xf) (xf_argend - (xf)->xac)
369
370 #define xf_argc (xf_context==NULL ? 0 : xf_ac(xf_context))
371 #define xf_argv xf_av(xf_context)
372
373 /*
374 * The transformation handler should do most of the work that needs
375 * doing. Just pass it any xf entities, then use the associated
376 * functions to transform and translate points, transform vectors
377 * (without translation), rotate vectors (without scaling) and scale
378 * values appropriately.
379 *
380 * The routines xf_xfmpoint, xf_xfmvect and xf_rotvect take two
381 * 3-D vectors (which may be identical), transforms the second and
382 * puts the result into the first.
383 */
384
385 #ifdef NOPROTO
386
387 extern int xf_handler(); /* handle xf entity */
388 extern void xf_xfmpoint(); /* transform point */
389 extern void xf_xfmvect(); /* transform vector */
390 extern void xf_rotvect(); /* rotate vector */
391 extern double xf_scale(); /* scale a value */
392 extern void xf_clear(); /* clear xf stack */
393
394 /* The following are support routines you probably won't call directly */
395
396 extern void multmat4(); /* m4a = m4b X m4c */
397 extern void multv3(); /* v3a = v3b X m4 (vectors) */
398 extern void multp3(); /* p3a = p3b X m4 (points) */
399 extern int xf(); /* interpret transform spec. */
400
401 #else
402
403 extern int xf_handler(int, char **); /* handle xf entity */
404 extern void xf_xfmpoint(FVECT, FVECT); /* transform point */
405 extern void xf_xfmvect(FVECT, FVECT); /* transform vector */
406 extern void xf_rotvect(FVECT, FVECT); /* rotate vector */
407 extern double xf_scale(double); /* scale a value */
408 extern void xf_clear(void); /* clear xf stack */
409
410 /* The following are support routines you probably won't call directly */
411
412 extern void multmat4(MAT4, MAT4, MAT4); /* m4a = m4b X m4c */
413 extern void multv3(FVECT, FVECT, MAT4); /* v3a = v3b X m4 (vectors) */
414 extern void multp3(FVECT, FVECT, MAT4); /* p3a = p3b X m4 (points) */
415 extern int xf(XF *, int, char **); /* interpret transform spec. */
416
417 #endif
418
419 /************************************************************************
420 * Miscellaneous definitions
421 */
422
423 #ifdef M_PI
424 #define PI M_PI
425 #else
426 #define PI 3.14159265358979323846
427 #endif
428
429 #ifdef DCL_ATOF
430 extern double atof();
431 #endif
432
433 #ifndef MEM_PTR
434 #define MEM_PTR void *
435 #endif
436
437 extern MEM_PTR malloc();
438 extern MEM_PTR calloc();
439 extern MEM_PTR realloc();
440 extern void free();
