root/radiance/ray/src/cv/mgflib/parser.c
Revision: 1.23
Committed: Wed Jun 19 22:34:59 1996 UTC (27 years, 11 months ago) by greg
Changes since 1.22: +17 -19 lines
made some support handlers external symbols
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Parse an MGF file, converting or discarding unsupported entities
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <ctype.h>
14 #include <string.h>
15 #include "parser.h"
16 #include "lookup.h"
17 #include "messages.h"
18
19 /*
20 * Global definitions of variables declared in parser.h
21 */
22 /* entity names */
23
24 char mg_ename[MG_NENTITIES][MG_MAXELEN] = MG_NAMELIST;
25
26 /* Handler routines for each entity */
27
28 int (*mg_ehand[MG_NENTITIES])();
29
30 /* Handler routine for unknown entities */
31
32 int (*mg_uhand)() = mg_defuhand;
33
34 unsigned mg_nunknown; /* count of unknown entities */
35
36 /* error messages */
37
38 char *mg_err[MG_NERRS] = MG_ERRLIST;
39
40 MG_FCTXT *mg_file; /* current file context pointer */
41
42 int mg_nqcdivs = MG_NQCD; /* number of divisions per quarter circle */
43
44 /*
45 * The idea with this parser is to compensate for any missing entries in
46 * mg_ehand with alternate handlers that express these entities in terms
47 * of others that the calling program can handle.
48 *
49 * In some cases, no alternate handler is possible because the entity
50 * has no approximate equivalent. These entities are simply discarded.
51 *
52 * Certain entities are dependent on others, and mg_init() will fail
53 * if the supported entities are not consistent.
54 *
55 * Some alternate entity handlers require that earlier entities be
56 * noted in some fashion, and we therefore keep another array of
57 * parallel support handlers to assist in this effort.
58 */
59
60 /* temporary settings for testing */
61 #define e_ies e_any_toss
62 /* alternate handler routines */
63
64 static int e_any_toss(), /* discard unneeded entity */
65 e_ies(), /* IES luminaire file */
66 e_cct(), /* color temperature */
67 e_cmix(), /* color mixtures */
68 e_cspec(); /* color spectra */
69
70 int e_include(), /* include file */
71 e_sph(), /* sphere */
72 e_cyl(), /* cylinder */
73 e_cone(), /* cone */
74 e_prism(), /* prism */
75 e_ring(), /* ring */
76 e_torus(); /* torus */
77
78 /* alternate handler support functions */
79
80 static int (*e_supp[MG_NENTITIES])();
81
82 static char FLTFMT[] = "%.12g";
83
84 static int warpconends; /* hack for generating good normals */
85
86
87 void
88 mg_init() /* initialize alternate entity handlers */
89 {
90 unsigned long ineed = 0, uneed = 0;
91 register int i;
92 /* pick up slack */
93 if (mg_ehand[MG_E_IES] == NULL)
94 mg_ehand[MG_E_IES] = e_ies;
95 if (mg_ehand[MG_E_INCLUDE] == NULL)
96 mg_ehand[MG_E_INCLUDE] = e_include;
97 if (mg_ehand[MG_E_SPH] == NULL) {
98 mg_ehand[MG_E_SPH] = e_sph;
99 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
100 } else
101 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
102 if (mg_ehand[MG_E_CYL] == NULL) {
103 mg_ehand[MG_E_CYL] = e_cyl;
104 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
105 } else
106 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
107 if (mg_ehand[MG_E_CONE] == NULL) {
108 mg_ehand[MG_E_CONE] = e_cone;
109 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
110 } else
111 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
112 if (mg_ehand[MG_E_RING] == NULL) {
113 mg_ehand[MG_E_RING] = e_ring;
114 ineed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX;
115 } else
116 uneed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX|1L<<MG_E_XF;
117 if (mg_ehand[MG_E_PRISM] == NULL) {
118 mg_ehand[MG_E_PRISM] = e_prism;
119 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
120 } else
121 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
122 if (mg_ehand[MG_E_TORUS] == NULL) {
123 mg_ehand[MG_E_TORUS] = e_torus;
124 ineed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX;
125 } else
126 uneed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX|1L<<MG_E_XF;
127 if (mg_ehand[MG_E_COLOR] != NULL) {
128 if (mg_ehand[MG_E_CMIX] == NULL) {
129 mg_ehand[MG_E_CMIX] = e_cmix;
130 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
131 }
132 if (mg_ehand[MG_E_CSPEC] == NULL) {
133 mg_ehand[MG_E_CSPEC] = e_cspec;
134 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
135 }
136 if (mg_ehand[MG_E_CCT] == NULL) {
137 mg_ehand[MG_E_CCT] = e_cct;
138 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
139 }
140 }
141 /* check for consistency */
142 if (mg_ehand[MG_E_FACE] != NULL)
143 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
144 if (mg_ehand[MG_E_CXY] != NULL || mg_ehand[MG_E_CSPEC] != NULL ||
145 mg_ehand[MG_E_CMIX] != NULL)
146 uneed |= 1L<<MG_E_COLOR;
147 if (mg_ehand[MG_E_RD] != NULL || mg_ehand[MG_E_TD] != NULL ||
148 mg_ehand[MG_E_IR] != NULL ||
149 mg_ehand[MG_E_ED] != NULL ||
150 mg_ehand[MG_E_RS] != NULL ||
151 mg_ehand[MG_E_TS] != NULL ||
152 mg_ehand[MG_E_SIDES] != NULL)
153 uneed |= 1L<<MG_E_MATERIAL;
154 for (i = 0; i < MG_NENTITIES; i++)
155 if (uneed & 1L<<i && mg_ehand[i] == NULL) {
156 fprintf(stderr, "Missing support for \"%s\" entity\n",
157 mg_ename[i]);
158 exit(1);
159 }
160 /* add support as needed */
161 if (ineed & 1L<<MG_E_VERTEX && mg_ehand[MG_E_VERTEX] != c_hvertex)
162 e_supp[MG_E_VERTEX] = c_hvertex;
163 if (ineed & 1L<<MG_E_POINT && mg_ehand[MG_E_POINT] != c_hvertex)
164 e_supp[MG_E_POINT] = c_hvertex;
165 if (ineed & 1L<<MG_E_NORMAL && mg_ehand[MG_E_NORMAL] != c_hvertex)
166 e_supp[MG_E_NORMAL] = c_hvertex;
167 if (ineed & 1L<<MG_E_COLOR && mg_ehand[MG_E_COLOR] != c_hcolor)
168 e_supp[MG_E_COLOR] = c_hcolor;
169 if (ineed & 1L<<MG_E_CXY && mg_ehand[MG_E_CXY] != c_hcolor)
170 e_supp[MG_E_CXY] = c_hcolor;
171 if (ineed & 1L<<MG_E_CSPEC && mg_ehand[MG_E_CSPEC] != c_hcolor)
172 e_supp[MG_E_CSPEC] = c_hcolor;
173 if (ineed & 1L<<MG_E_CMIX && mg_ehand[MG_E_CMIX] != c_hcolor)
174 e_supp[MG_E_CMIX] = c_hcolor;
175 if (ineed & 1L<<MG_E_CCT && mg_ehand[MG_E_CCT] != c_hcolor)
176 e_supp[MG_E_CCT] = c_hcolor;
177 /* discard remaining entities */
178 for (i = 0; i < MG_NENTITIES; i++)
179 if (mg_ehand[i] == NULL)
180 mg_ehand[i] = e_any_toss;
181 }
182
183
184 int
185 mg_entity(name) /* get entity number from its name */
186 char *name;
187 {
188 static LUTAB ent_tab = LU_SINIT(NULL,NULL); /* lookup table */
189 register char *cp;
190
191 if (!ent_tab.tsiz) { /* initialize hash table */
192 if (!lu_init(&ent_tab, MG_NENTITIES))
193 return(-1); /* what to do? */
194 for (cp = mg_ename[MG_NENTITIES-1]; cp >= mg_ename[0];
195 cp -= sizeof(mg_ename[0]))
196 lu_find(&ent_tab, cp)->key = cp;
197 }
198 cp = lu_find(&ent_tab, name)->key;
199 if (cp == NULL)
200 return(-1);
201 return((cp - mg_ename[0])/sizeof(mg_ename[0]));
202 }
203
204
205 int
206 mg_handle(en, ac, av) /* pass entity to appropriate handler */
207 register int en;
208 int ac;
209 char **av;
210 {
211 int rv;
212
213 if (en < 0 && (en = mg_entity(av[0])) < 0) { /* unknown entity */
214 if (mg_uhand != NULL)
215 return((*mg_uhand)(ac, av));
216 return(MG_EUNK);
217 }
218 if (e_supp[en] != NULL) { /* support handler */
219 if ((rv = (*e_supp[en])(ac, av)) != MG_OK)
220 return(rv);
221 }
222 return((*mg_ehand[en])(ac, av)); /* assigned handler */
223 }
224
225
226 int
227 mg_open(ctx, fn) /* open new input file */
228 register MG_FCTXT *ctx;
229 char *fn;
230 {
231 static int nfids;
232 register char *cp;
233
234 ctx->fid = ++nfids;
235 ctx->lineno = 0;
236 if (fn == NULL) {
237 strcpy(ctx->fname, "<stdin>");
238 ctx->fp = stdin;
239 ctx->prev = mg_file;
240 mg_file = ctx;
241 return(MG_OK);
242 }
243 /* get name relative to this context */
244 if (mg_file != NULL && (cp = strrchr(mg_file->fname, '/')) != NULL) {
245 strcpy(ctx->fname, mg_file->fname);
246 strcpy(ctx->fname+(cp-mg_file->fname+1), fn);
247 } else
248 strcpy(ctx->fname, fn);
249 ctx->fp = fopen(ctx->fname, "r");
250 if (ctx->fp == NULL)
251 return(MG_ENOFILE);
252 ctx->prev = mg_file; /* establish new context */
253 mg_file = ctx;
254 return(MG_OK);
255 }
256
257
258 void
259 mg_close() /* close input file */
260 {
261 register MG_FCTXT *ctx = mg_file;
262
263 mg_file = ctx->prev; /* restore enclosing context */
264 if (ctx->fp != stdin) /* close file if it's a file */
265 fclose(ctx->fp);
266 }
267
268
269 void
270 mg_fgetpos(pos) /* get current position in input file */
271 register MG_FPOS *pos;
272 {
273 extern long ftell();
274
275 pos->fid = mg_file->fid;
276 pos->lineno = mg_file->lineno;
277 pos->offset = ftell(mg_file->fp);
278 }
279
280
281 int
282 mg_fgoto(pos) /* reposition input file pointer */
283 register MG_FPOS *pos;
284 {
285 if (pos->fid != mg_file->fid)
286 return(MG_ESEEK);
287 if (pos->lineno == mg_file->lineno)
288 return(MG_OK);
289 if (mg_file->fp == stdin)
290 return(MG_ESEEK); /* cannot seek on standard input */
291 if (fseek(mg_file->fp, pos->offset, 0) == EOF)
292 return(MG_ESEEK);
293 mg_file->lineno = pos->lineno;
294 return(MG_OK);
295 }
296
297
298 int
299 mg_read() /* read next line from file */
300 {
301 register int len = 0;
302
303 do {
304 if (fgets(mg_file->inpline+len,
305 MG_MAXLINE-len, mg_file->fp) == NULL)
306 return(len);
307 len += strlen(mg_file->inpline+len);
308 if (len >= MG_MAXLINE-1)
309 return(len);
310 mg_file->lineno++;
311 } while (len > 1 && mg_file->inpline[len-2] == '\\');
312
313 return(len);
314 }
315
316
317 int
318 mg_parse() /* parse current input line */
319 {
320 char abuf[MG_MAXLINE];
321 char *argv[MG_MAXARGC];
322 int en;
323 register char *cp, *cp2, **ap;
324 /* copy line, removing escape chars */
325 cp = abuf; cp2 = mg_file->inpline;
326 while ((*cp++ = *cp2++))
327 if (cp2[0] == '\n' && cp2[-1] == '\\')
328 cp--;
329 cp = abuf; ap = argv; /* break into words */
330 for ( ; ; ) {
331 while (isspace(*cp))
332 *cp++ = '\0';
333 if (!*cp)
334 break;
335 if (ap - argv >= MG_MAXARGC-1)
336 return(MG_EARGC);
337 *ap++ = cp;
338 while (*++cp && !isspace(*cp))
339 ;
340 }
341 if (ap == argv)
342 return(MG_OK); /* no words in line */
343 *ap = NULL;
344 /* else handle it */
345 return(mg_handle(-1, ap-argv, argv));
346 }
347
348
349 int
350 mg_load(fn) /* load an MGF file */
351 char *fn;
352 {
353 MG_FCTXT cntxt;
354 int rval;
355 register int nbr;
356
357 if ((rval = mg_open(&cntxt, fn)) != MG_OK) {
358 fprintf(stderr, "%s: %s\n", fn, mg_err[rval]);
359 return(rval);
360 }
361 while ((nbr = mg_read()) > 0) { /* parse each line */
362 if (nbr >= MG_MAXLINE-1) {
363 fprintf(stderr, "%s: %d: %s\n", cntxt.fname,
364 cntxt.lineno, mg_err[rval=MG_ELINE]);
365 break;
366 }
367 if ((rval = mg_parse()) != MG_OK) {
368 fprintf(stderr, "%s: %d: %s:\n%s", cntxt.fname,
369 cntxt.lineno, mg_err[rval],
370 cntxt.inpline);
371 break;
372 }
373 }
374 mg_close();
375 return(rval);
376 }
377
378
379 int
380 mg_defuhand(ac, av) /* default handler for unknown entities */
381 int ac;
382 char **av;
383 {
384 if (mg_nunknown++ == 0) /* report first incident */
385 fprintf(stderr, "%s: %d: %s: %s\n", mg_file->fname,
386 mg_file->lineno, mg_err[MG_EUNK], av[0]);
387 return(MG_OK);
388 }
389
390
391 void
392 mg_clear() /* clear parser history */
393 {
394 c_clearall(); /* clear context tables */
395 while (mg_file != NULL) /* reset our file context */
396 mg_close();
397 }
398
399
400 /****************************************************************************
401 * The following routines handle unsupported entities
402 */
403
404
405 static int
406 e_any_toss(ac, av) /* discard an unwanted entity */
407 int ac;
408 char **av;
409 {
410 return(MG_OK);
411 }
412
413
414 int
415 e_include(ac, av) /* include file */
416 int ac;
417 char **av;
418 {
419 char *xfarg[MG_MAXARGC];
420 MG_FCTXT ictx;
421 XF_SPEC *xf_orig = xf_context;
422 register int rv;
423
424 if (ac < 2)
425 return(MG_EARGC);
426 if ((rv = mg_open(&ictx, av[1])) != MG_OK)
427 return(rv);
428 if (ac > 2) {
429 register int i;
430
431 xfarg[0] = mg_ename[MG_E_XF];
432 for (i = 1; i < ac-1; i++)
433 xfarg[i] = av[i+1];
434 xfarg[ac-1] = NULL;
435 if ((rv = mg_handle(MG_E_XF, ac-1, xfarg)) != MG_OK) {
436 mg_close();
437 return(rv);
438 }
439 }
440 do {
441 while ((rv = mg_read()) > 0) {
442 if (rv >= MG_MAXLINE-1) {
443 fprintf(stderr, "%s: %d: %s\n", ictx.fname,
444 ictx.lineno, mg_err[MG_ELINE]);
445 mg_close();
446 return(MG_EINCL);
447 }
448 if ((rv = mg_parse()) != MG_OK) {
449 fprintf(stderr, "%s: %d: %s:\n%s", ictx.fname,
450 ictx.lineno, mg_err[rv],
451 ictx.inpline);
452 mg_close();
453 return(MG_EINCL);
454 }
455 }
456 if (ac > 2)
457 if ((rv = mg_handle(MG_E_XF, 1, xfarg)) != MG_OK) {
458 mg_close();
459 return(rv);
460 }
461 } while (xf_context != xf_orig);
462 mg_close();
463 return(MG_OK);
464 }
465
466
467 static void
468 make_axes(u, v, w) /* compute u and v given w (normalized) */
469 FVECT u, v, w;
470 {
471 register int i;
472
473 v[0] = v[1] = v[2] = 0.;
474 for (i = 0; i < 3; i++)
475 if (w[i] < .6 && w[i] > -.6)
476 break;
477 v[i] = 1.;
478 fcross(u, v, w);
479 normalize(u);
480 fcross(v, w, u);
481 }
482
483
484 int
485 e_sph(ac, av) /* expand a sphere into cones */
486 int ac;
487 char **av;
488 {
489 static char p2x[24], p2y[24], p2z[24], r1[24], r2[24];
490 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_sv1","=","_sv2"};
491 static char *v2ent[4] = {mg_ename[MG_E_VERTEX],"_sv2","="};
492 static char *p2ent[5] = {mg_ename[MG_E_POINT],p2x,p2y,p2z};
493 static char *conent[6] = {mg_ename[MG_E_CONE],"_sv1",r1,"_sv2",r2};
494 register C_VERTEX *cv;
495 register int i;
496 int rval;
497 double rad;
498 double theta;
499
500 if (ac != 3)
501 return(MG_EARGC);
502 if ((cv = c_getvert(av[1])) == NULL)
503 return(MG_EUNDEF);
504 if (!isflt(av[2]))
505 return(MG_ETYPE);
506 rad = atof(av[2]);
507 /* initialize */
508 warpconends = 1;
509 if ((rval = mg_handle(MG_E_VERTEX, 3, v2ent)) != MG_OK)
510 return(rval);
511 sprintf(p2x, FLTFMT, cv->p[0]);
512 sprintf(p2y, FLTFMT, cv->p[1]);
513 sprintf(p2z, FLTFMT, cv->p[2]+rad);
514 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
515 return(rval);
516 r2[0] = '0'; r2[1] = '\0';
517 for (i = 1; i <= 2*mg_nqcdivs; i++) {
518 theta = i*(PI/2)/mg_nqcdivs;
519 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
520 return(rval);
521 sprintf(p2z, FLTFMT, cv->p[2]+rad*cos(theta));
522 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
523 return(rval);
524 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
525 return(rval);
526 strcpy(r1, r2);
527 sprintf(r2, FLTFMT, rad*sin(theta));
528 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
529 return(rval);
530 }
531 warpconends = 0;
532 return(MG_OK);
533 }
534
535
536 int
537 e_torus(ac, av) /* expand a torus into cones */
538 int ac;
539 char **av;
540 {
541 static char p2[3][24], r1[24], r2[24];
542 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_tv1","=","_tv2"};
543 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_tv2","="};
544 static char *p2ent[5] = {mg_ename[MG_E_POINT],p2[0],p2[1],p2[2]};
545 static char *conent[6] = {mg_ename[MG_E_CONE],"_tv1",r1,"_tv2",r2};
546 register C_VERTEX *cv;
547 register int i, j;
548 int rval;
549 int sgn;
550 double minrad, maxrad, avgrad;
551 double theta;
552
553 if (ac != 4)
554 return(MG_EARGC);
555 if ((cv = c_getvert(av[1])) == NULL)
556 return(MG_EUNDEF);
557 if (is0vect(cv->n))
558 return(MG_EILL);
559 if (!isflt(av[2]) || !isflt(av[3]))
560 return(MG_ETYPE);
561 minrad = atof(av[2]);
562 round0(minrad);
563 maxrad = atof(av[3]);
564 /* check orientation */
565 if (minrad > 0.)
566 sgn = 1;
567 else if (minrad < 0.)
568 sgn = -1;
569 else if (maxrad > 0.)
570 sgn = 1;
571 else if (maxrad < 0.)
572 sgn = -1;
573 else
574 return(MG_EILL);
575 if (sgn*(maxrad-minrad) <= 0.)
576 return(MG_EILL);
577 /* initialize */
578 warpconends = 1;
579 v2ent[3] = av[1];
580 for (j = 0; j < 3; j++)
581 sprintf(p2[j], FLTFMT, cv->p[j] +
582 .5*sgn*(maxrad-minrad)*cv->n[j]);
583 if ((rval = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
584 return(rval);
585 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
586 return(rval);
587 sprintf(r2, FLTFMT, avgrad=.5*(minrad+maxrad));
588 /* run outer section */
589 for (i = 1; i <= 2*mg_nqcdivs; i++) {
590 theta = i*(PI/2)/mg_nqcdivs;
591 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
592 return(rval);
593 for (j = 0; j < 3; j++)
594 sprintf(p2[j], FLTFMT, cv->p[j] +
595 .5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]);
596 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
597 return(rval);
598 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
599 return(rval);
600 strcpy(r1, r2);
601 sprintf(r2, FLTFMT, avgrad + .5*(maxrad-minrad)*sin(theta));
602 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
603 return(rval);
604 }
605 /* run inner section */
606 sprintf(r2, FLTFMT, -.5*(minrad+maxrad));
607 for ( ; i <= 4*mg_nqcdivs; i++) {
608 theta = i*(PI/2)/mg_nqcdivs;
609 for (j = 0; j < 3; j++)
610 sprintf(p2[j], FLTFMT, cv->p[j] +
611 .5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]);
612 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
613 return(rval);
614 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
615 return(rval);
616 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
617 return(rval);
618 strcpy(r1, r2);
619 sprintf(r2, FLTFMT, -avgrad - .5*(maxrad-minrad)*sin(theta));
620 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
621 return(rval);
622 }
623 warpconends = 0;
624 return(MG_OK);
625 }
626
627
628 int
629 e_cyl(ac, av) /* replace a cylinder with equivalent cone */
630 int ac;
631 char **av;
632 {
633 static char *avnew[6] = {mg_ename[MG_E_CONE]};
634
635 if (ac != 4)
636 return(MG_EARGC);
637 avnew[1] = av[1];
638 avnew[2] = av[2];
639 avnew[3] = av[3];
640 avnew[4] = av[2];
641 return(mg_handle(MG_E_CONE, 5, avnew));
642 }
643
644
645 int
646 e_ring(ac, av) /* turn a ring into polygons */
647 int ac;
648 char **av;
649 {
650 static char p3[3][24], p4[3][24];
651 static char *nzent[5] = {mg_ename[MG_E_NORMAL],"0","0","0"};
652 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_rv1","="};
653 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_rv2","=","_rv3"};
654 static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_rv3","="};
655 static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]};
656 static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_rv4","="};
657 static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]};
658 static char *fent[6] = {mg_ename[MG_E_FACE],"_rv1","_rv2","_rv3","_rv4"};
659 register C_VERTEX *cv;
660 register int i, j;
661 FVECT u, v;
662 double minrad, maxrad;
663 int rv;
664 double theta, d;
665
666 if (ac != 4)
667 return(MG_EARGC);
668 if ((cv = c_getvert(av[1])) == NULL)
669 return(MG_EUNDEF);
670 if (is0vect(cv->n))
671 return(MG_EILL);
672 if (!isflt(av[2]) || !isflt(av[3]))
673 return(MG_ETYPE);
674 minrad = atof(av[2]);
675 round0(minrad);
676 maxrad = atof(av[3]);
677 if (minrad < 0. || maxrad <= minrad)
678 return(MG_EILL);
679 /* initialize */
680 make_axes(u, v, cv->n);
681 for (j = 0; j < 3; j++)
682 sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*u[j]);
683 if ((rv = mg_handle(MG_E_VERTEX, 3, v3ent)) != MG_OK)
684 return(rv);
685 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
686 return(rv);
687 if (minrad == 0.) { /* closed */
688 v1ent[3] = av[1];
689 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
690 return(rv);
691 if ((rv = mg_handle(MG_E_NORMAL, 4, nzent)) != MG_OK)
692 return(rv);
693 for (i = 1; i <= 4*mg_nqcdivs; i++) {
694 theta = i*(PI/2)/mg_nqcdivs;
695 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
696 return(rv);
697 for (j = 0; j < 3; j++)
698 sprintf(p3[j], FLTFMT, cv->p[j] +
699 maxrad*u[j]*cos(theta) +
700 maxrad*v[j]*sin(theta));
701 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
702 return(rv);
703 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
704 return(rv);
705 if ((rv = mg_handle(MG_E_FACE, 4, fent)) != MG_OK)
706 return(rv);
707 }
708 } else { /* open */
709 if ((rv = mg_handle(MG_E_VERTEX, 3, v4ent)) != MG_OK)
710 return(rv);
711 for (j = 0; j < 3; j++)
712 sprintf(p4[j], FLTFMT, cv->p[j] + minrad*u[j]);
713 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
714 return(rv);
715 v1ent[3] = "_rv4";
716 for (i = 1; i <= 4*mg_nqcdivs; i++) {
717 theta = i*(PI/2)/mg_nqcdivs;
718 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
719 return(rv);
720 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
721 return(rv);
722 for (j = 0; j < 3; j++) {
723 d = u[j]*cos(theta) + v[j]*sin(theta);
724 sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*d);
725 sprintf(p4[j], FLTFMT, cv->p[j] + minrad*d);
726 }
727 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
728 return(rv);
729 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
730 return(rv);
731 if ((rv = mg_handle(MG_E_VERTEX, 2, v4ent)) != MG_OK)
732 return(rv);
733 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
734 return(rv);
735 if ((rv = mg_handle(MG_E_FACE, 5, fent)) != MG_OK)
736 return(rv);
737 }
738 }
739 return(MG_OK);
740 }
741
742
743 int
744 e_cone(ac, av) /* turn a cone into polygons */
745 int ac;
746 char **av;
747 {
748 static char p3[3][24], p4[3][24], n3[3][24], n4[3][24];
749 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_cv1","="};
750 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_cv2","=","_cv3"};
751 static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_cv3","="};
752 static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]};
753 static char *n3ent[5] = {mg_ename[MG_E_NORMAL],n3[0],n3[1],n3[2]};
754 static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_cv4","="};
755 static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]};
756 static char *n4ent[5] = {mg_ename[MG_E_NORMAL],n4[0],n4[1],n4[2]};
757 static char *fent[6] = {mg_ename[MG_E_FACE],"_cv1","_cv2","_cv3","_cv4"};
758 char *v1n;
759 register C_VERTEX *cv1, *cv2;
760 register int i, j;
761 FVECT u, v, w;
762 double rad1, rad2;
763 int sgn;
764 double n1off, n2off;
765 double d;
766 int rv;
767 double theta;
768
769 if (ac != 5)
770 return(MG_EARGC);
771 if ((cv1 = c_getvert(av[1])) == NULL ||
772 (cv2 = c_getvert(av[3])) == NULL)
773 return(MG_EUNDEF);
774 v1n = av[1];
775 if (!isflt(av[2]) || !isflt(av[4]))
776 return(MG_ETYPE);
777 rad1 = atof(av[2]);
778 round0(rad1);
779 rad2 = atof(av[4]);
780 round0(rad2);
781 if (rad1 == 0.) {
782 if (rad2 == 0.)
783 return(MG_EILL);
784 } else if (rad2 != 0.) {
785 if (rad1 < 0. ^ rad2 < 0.)
786 return(MG_EILL);
787 } else { /* swap */
788 C_VERTEX *cv;
789
790 cv = cv1;
791 cv1 = cv2;
792 cv2 = cv;
793 v1n = av[3];
794 d = rad1;
795 rad1 = rad2;
796 rad2 = d;
797 }
798 sgn = rad2 < 0. ? -1 : 1;
799 /* initialize */
800 for (j = 0; j < 3; j++)
801 w[j] = cv1->p[j] - cv2->p[j];
802 if ((d = normalize(w)) == 0.)
803 return(MG_EILL);
804 n1off = n2off = (rad2 - rad1)/d;
805 if (warpconends) { /* hack for e_sph and e_torus */
806 d = atan(n2off) - (PI/4)/mg_nqcdivs;
807 if (d <= -PI/2+FTINY)
808 n2off = -FHUGE;
809 else
810 n2off = tan(d);
811 }
812 make_axes(u, v, w);
813 for (j = 0; j < 3; j++) {
814 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*u[j]);
815 if (n2off <= -FHUGE)
816 sprintf(n3[j], FLTFMT, -w[j]);
817 else
818 sprintf(n3[j], FLTFMT, u[j] + w[j]*n2off);
819 }
820 if ((rv = mg_handle(MG_E_VERTEX, 3, v3ent)) != MG_OK)
821 return(rv);
822 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
823 return(rv);
824 if ((rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
825 return(rv);
826 if (rad1 == 0.) { /* triangles */
827 v1ent[3] = v1n;
828 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
829 return(rv);
830 for (j = 0; j < 3; j++)
831 sprintf(n4[j], FLTFMT, w[j]);
832 if ((rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
833 return(rv);
834 for (i = 1; i <= 4*mg_nqcdivs; i++) {
835 theta = sgn*i*(PI/2)/mg_nqcdivs;
836 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
837 return(rv);
838 for (j = 0; j < 3; j++) {
839 d = u[j]*cos(theta) + v[j]*sin(theta);
840 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d);
841 if (n2off > -FHUGE)
842 sprintf(n3[j], FLTFMT, d + w[j]*n2off);
843 }
844 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
845 return(rv);
846 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
847 return(rv);
848 if (n2off > -FHUGE &&
849 (rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
850 return(rv);
851 if ((rv = mg_handle(MG_E_FACE, 4, fent)) != MG_OK)
852 return(rv);
853 }
854 } else { /* quads */
855 v1ent[3] = "_cv4";
856 if (warpconends) { /* hack for e_sph and e_torus */
857 d = atan(n1off) + (PI/4)/mg_nqcdivs;
858 if (d >= PI/2-FTINY)
859 n1off = FHUGE;
860 else
861 n1off = tan(atan(n1off)+(PI/4)/mg_nqcdivs);
862 }
863 for (j = 0; j < 3; j++) {
864 sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*u[j]);
865 if (n1off >= FHUGE)
866 sprintf(n4[j], FLTFMT, w[j]);
867 else
868 sprintf(n4[j], FLTFMT, u[j] + w[j]*n1off);
869 }
870 if ((rv = mg_handle(MG_E_VERTEX, 3, v4ent)) != MG_OK)
871 return(rv);
872 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
873 return(rv);
874 if ((rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
875 return(rv);
876 for (i = 1; i <= 4*mg_nqcdivs; i++) {
877 theta = sgn*i*(PI/2)/mg_nqcdivs;
878 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
879 return(rv);
880 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
881 return(rv);
882 for (j = 0; j < 3; j++) {
883 d = u[j]*cos(theta) + v[j]*sin(theta);
884 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d);
885 if (n2off > -FHUGE)
886 sprintf(n3[j], FLTFMT, d + w[j]*n2off);
887 sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*d);
888 if (n1off < FHUGE)
889 sprintf(n4[j], FLTFMT, d + w[j]*n1off);
890 }
891 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
892 return(rv);
893 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
894 return(rv);
895 if (n2off > -FHUGE &&
896 (rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
897 return(rv);
898 if ((rv = mg_handle(MG_E_VERTEX, 2, v4ent)) != MG_OK)
899 return(rv);
900 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
901 return(rv);
902 if (n1off < FHUGE &&
903 (rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
904 return(rv);
905 if ((rv = mg_handle(MG_E_FACE, 5, fent)) != MG_OK)
906 return(rv);
907 }
908 }
909 return(MG_OK);
910 }
911
912
913 int
914 e_prism(ac, av) /* turn a prism into polygons */
915 int ac;
916 char **av;
917 {
918 static char p[3][24];
919 static char *vent[5] = {mg_ename[MG_E_VERTEX],NULL,"="};
920 static char *pent[5] = {mg_ename[MG_E_POINT],p[0],p[1],p[2]};
921 static char *znorm[5] = {mg_ename[MG_E_NORMAL],"0","0","0"};
922 char *newav[MG_MAXARGC], nvn[MG_MAXARGC-1][8];
923 double length;
924 int hasnorm;
925 FVECT v1, v2, v3, norm;
926 register C_VERTEX *cv;
927 C_VERTEX *cv0;
928 int rv;
929 register int i, j;
930 /* check arguments */
931 if (ac < 5)
932 return(MG_EARGC);
933 if (!isflt(av[ac-1]))
934 return(MG_ETYPE);
935 length = atof(av[ac-1]);
936 if (length <= FTINY && length >= -FTINY)
937 return(MG_EILL);
938 /* compute face normal */
939 if ((cv0 = c_getvert(av[1])) == NULL)
940 return(MG_EUNDEF);
941 hasnorm = 0;
942 norm[0] = norm[1] = norm[2] = 0.;
943 v1[0] = v1[1] = v1[2] = 0.;
944 for (i = 2; i < ac-1; i++) {
945 if ((cv = c_getvert(av[i])) == NULL)
946 return(MG_EUNDEF);
947 hasnorm += !is0vect(cv->n);
948 v2[0] = cv->p[0] - cv0->p[0];
949 v2[1] = cv->p[1] - cv0->p[1];
950 v2[2] = cv->p[2] - cv0->p[2];
951 fcross(v3, v1, v2);
952 norm[0] += v3[0];
953 norm[1] += v3[1];
954 norm[2] += v3[2];
955 VCOPY(v1, v2);
956 }
957 if (normalize(norm) == 0.)
958 return(MG_EILL);
959 /* create moved vertices */
960 for (i = 1; i < ac-1; i++) {
961 sprintf(nvn[i-1], "_pv%d", i);
962 vent[1] = nvn[i-1];
963 vent[3] = av[i];
964 if ((rv = mg_handle(MG_E_VERTEX, 4, vent)) != MG_OK)
965 return(rv);
966 cv = c_getvert(av[i]); /* checked above */
967 for (j = 0; j < 3; j++)
968 sprintf(p[j], FLTFMT, cv->p[j] - length*norm[j]);
969 if ((rv = mg_handle(MG_E_POINT, 4, pent)) != MG_OK)
970 return(rv);
971 }
972 /* make faces */
973 newav[0] = mg_ename[MG_E_FACE];
974 /* do the side faces */
975 newav[5] = NULL;
976 newav[3] = av[ac-2];
977 newav[4] = nvn[ac-3];
978 for (i = 1; i < ac-1; i++) {
979 newav[1] = nvn[i-1];
980 newav[2] = av[i];
981 if ((rv = mg_handle(MG_E_FACE, 5, newav)) != MG_OK)
982 return(rv);
983 newav[3] = newav[2];
984 newav[4] = newav[1];
985 }
986 /* do top face */
987 for (i = 1; i < ac-1; i++) {
988 if (hasnorm) { /* zero normals */
989 vent[1] = nvn[i-1];
990 if ((rv = mg_handle(MG_E_VERTEX, 2, vent)) != MG_OK)
991 return(rv);
992 if ((rv = mg_handle(MG_E_NORMAL, 4, znorm)) != MG_OK)
993 return(rv);
994 }
995 newav[ac-1-i] = nvn[i-1]; /* reverse */
996 }
997 if ((rv = mg_handle(MG_E_FACE, ac-1, newav)) != MG_OK)
998 return(rv);
999 /* do bottom face */
1000 if (hasnorm)
1001 for (i = 1; i < ac-1; i++) {
1002 vent[1] = nvn[i-1];
1003 vent[3] = av[i];
1004 if ((rv = mg_handle(MG_E_VERTEX, 4, vent)) != MG_OK)
1005 return(rv);
1006 if ((rv = mg_handle(MG_E_NORMAL, 4, znorm)) != MG_OK)
1007 return(rv);
1008 newav[i] = nvn[i-1];
1009 }
1010 else
1011 for (i = 1; i < ac-1; i++)
1012 newav[i] = av[i];
1013 newav[i] = NULL;
1014 if ((rv = mg_handle(MG_E_FACE, i, newav)) != MG_OK)
1015 return(rv);
1016 return(MG_OK);
1017 }
1018
1019
1020 static int
1021 put_cxy() /* put out current xy chromaticities */
1022 {
1023 static char xbuf[24], ybuf[24];
1024 static char *ccom[4] = {mg_ename[MG_E_CXY], xbuf, ybuf};
1025
1026 sprintf(xbuf, "%.4f", c_ccolor->cx);
1027 sprintf(ybuf, "%.4f", c_ccolor->cy);
1028 return(mg_handle(MG_E_CXY, 3, ccom));
1029 }
1030
1031
1032 static int
1033 put_cspec() /* put out current color spectrum */
1034 {
1035 char wl[2][6], vbuf[C_CNSS][24];
1036 char *newav[C_CNSS+4];
1037 double sf;
1038 register int i;
1039
1040 if (mg_ehand[MG_E_CSPEC] != c_hcolor) {
1041 sprintf(wl[0], "%d", C_CMINWL);
1042 sprintf(wl[1], "%d", C_CMAXWL);
1043 newav[0] = mg_ename[MG_E_CSPEC];
1044 newav[1] = wl[0];
1045 newav[2] = wl[1];
1046 sf = (double)C_CNSS / c_ccolor->ssum;
1047 for (i = 0; i < C_CNSS; i++) {
1048 sprintf(vbuf[i], "%.4f", sf*c_ccolor->ssamp[i]);
1049 newav[i+3] = vbuf[i];
1050 }
1051 newav[C_CNSS+3] = NULL;
1052 if ((i = mg_handle(MG_E_CSPEC, C_CNSS+3, newav)) != MG_OK)
1053 return(i);
1054 }
1055 return(MG_OK);
1056 }
1057
1058
1059 static int
1060 e_cspec(ac, av) /* handle spectral color */
1061 int ac;
1062 char **av;
1063 {
1064 /* convert to xy chromaticity */
1065 c_ccvt(c_ccolor, C_CSXY);
1066 /* if it's really their handler, use it */
1067 if (mg_ehand[MG_E_CXY] != c_hcolor)
1068 return(put_cxy());
1069 return(MG_OK);
1070 }
1071
1072
1073 static int
1074 e_cmix(ac, av) /* handle mixing of colors */
1075 int ac;
1076 char **av;
1077 {
1078 /*
1079 * Contorted logic works as follows:
1080 * 1. the colors are already mixed in c_hcolor() support function
1081 * 2. if we would handle a spectral result, make sure it's not
1082 * 3. if c_hcolor() would handle a spectral result, don't bother
1083 * 4. otherwise, make cspec entity and pass it to their handler
1084 * 5. if we have only xy results, handle it as c_spec() would
1085 */
1086 if (mg_ehand[MG_E_CSPEC] == e_cspec)
1087 c_ccvt(c_ccolor, C_CSXY);
1088 else if (c_ccolor->flags & C_CDSPEC)
1089 return(put_cspec());
1090 if (mg_ehand[MG_E_CXY] != c_hcolor)
1091 return(put_cxy());
1092 return(MG_OK);
1093 }
1094
1095
1096 static int
1097 e_cct(ac, av) /* handle color temperature */
1098 int ac;
1099 char **av;
1100 {
1101 /*
1102 * Logic is similar to e_cmix here. Support handler has already
1103 * converted temperature to spectral color. Put it out as such
1104 * if they support it, otherwise convert to xy chromaticity and
1105 * put it out if they handle it.
1106 */
1107 if (mg_ehand[MG_E_CSPEC] != e_cspec)
1108 return(put_cspec());
1109 c_ccvt(c_ccolor, C_CSXY);
1110 if (mg_ehand[MG_E_CXY] != c_hcolor)
1111 return(put_cxy());
1112 return(MG_OK);
1113 }
