root/radiance/ray/src/cv/mgflib/parser.c
Revision: 1.2
Committed: Wed Jun 22 15:33:47 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.1: +9 -3 lines
various enhancements and fixes
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Parse an MGF file, converting or discarding unsupported entities
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <ctype.h>
14 #include <string.h>
15 #include "parser.h"
16 #include "lookup.h"
17 #include "messages.h"
18
19 /*
20 * Global definitions of variables declared in parser.h
21 */
22 /* entity names */
23
24 char mg_ename[MG_NENTITIES][MG_MAXELEN] = MG_NAMELIST;
25
26 /* Handler routines for each entity */
27
28 int (*mg_ehand[MG_NENTITIES])();
29
30 /* error messages */
31
32 char *mg_err[MG_NERRS] = MG_ERRLIST;
33
34 MG_FCTXT *mg_file; /* current file context pointer */
35
36 int mg_nqcdivs = MG_NQCD; /* number of divisions per quarter circle */
37
38 /*
39 * The idea with this parser is to compensate for any missing entries in
40 * mg_ehand with alternate handlers that express these entities in terms
41 * of others that the calling program can handle.
42 *
43 * In some cases, no alternate handler is possible because the entity
44 * has no approximate equivalent. These entities are simply discarded.
45 *
46 * Certain entities are dependent on others, and mg_init() will fail
47 * if the supported entities are not consistent.
48 *
49 * Some alternate entity handlers require that earlier entities be
50 * noted in some fashion, and we therefore keep another array of
51 * parallel support handlers to assist in this effort.
52 */
53
54 /* temporary settings for testing */
55 #define e_ies e_any_toss
56 /* alternate handler routines */
57
58 static int e_any_toss(), /* discard unneeded entity */
59 e_ies(), /* IES luminaire file */
60 e_include(), /* include file */
61 e_sph(), /* sphere */
62 e_cyl(), /* cylinder */
63 e_cone(), /* cone */
64 e_ring(), /* ring */
65 e_torus(); /* torus */
66
67 /* alternate handler support functions */
68
69 static int (*e_supp[MG_NENTITIES])();
70
71 static char FLTFMT[] = "%.12g";
72
73 static int warpconends; /* hack for generating good normals */
74
75
76 void
77 mg_init() /* initialize alternate entity handlers */
78 {
79 unsigned long ineed = 0, uneed = 0;
80 register int i;
81 /* pick up slack */
82 if (mg_ehand[MG_E_IES] == NULL)
83 mg_ehand[MG_E_IES] = e_ies;
84 if (mg_ehand[MG_E_INCLUDE] == NULL)
85 mg_ehand[MG_E_INCLUDE] = e_include;
86 if (mg_ehand[MG_E_SPH] == NULL) {
87 mg_ehand[MG_E_SPH] = e_sph;
88 ineed |= 1<<MG_E_POINT|1<<MG_E_VERTEX;
89 } else
90 uneed |= 1<<MG_E_POINT|1<<MG_E_VERTEX|1<<MG_E_XF;
91 if (mg_ehand[MG_E_CYL] == NULL) {
92 mg_ehand[MG_E_CYL] = e_cyl;
93 ineed |= 1<<MG_E_POINT|1<<MG_E_VERTEX;
94 } else
95 uneed |= 1<<MG_E_POINT|1<<MG_E_VERTEX|1<<MG_E_XF;
96 if (mg_ehand[MG_E_CONE] == NULL) {
97 mg_ehand[MG_E_CONE] = e_cone;
98 ineed |= 1<<MG_E_POINT|1<<MG_E_VERTEX;
99 } else
100 uneed |= 1<<MG_E_POINT|1<<MG_E_VERTEX|1<<MG_E_XF;
101 if (mg_ehand[MG_E_RING] == NULL) {
102 mg_ehand[MG_E_RING] = e_ring;
103 ineed |= 1<<MG_E_POINT|1<<MG_E_NORMAL|1<<MG_E_VERTEX;
104 } else
105 uneed |= 1<<MG_E_POINT|1<<MG_E_NORMAL|1<<MG_E_VERTEX|1<<MG_E_XF;
106 if (mg_ehand[MG_E_TORUS] == NULL) {
107 mg_ehand[MG_E_TORUS] = e_torus;
108 ineed |= 1<<MG_E_POINT|1<<MG_E_NORMAL|1<<MG_E_VERTEX;
109 } else
110 uneed |= 1<<MG_E_POINT|1<<MG_E_NORMAL|1<<MG_E_VERTEX|1<<MG_E_XF;
111 /* check for consistency */
112 if (mg_ehand[MG_E_FACE] != NULL)
113 uneed |= 1<<MG_E_POINT|1<<MG_E_VERTEX|1<<MG_E_XF;
114 if (mg_ehand[MG_E_CXY] != NULL)
115 uneed |= 1<<MG_E_COLOR;
116 if (mg_ehand[MG_E_RD] != NULL || mg_ehand[MG_E_TD] != NULL ||
117 mg_ehand[MG_E_ED] != NULL ||
118 mg_ehand[MG_E_RS] != NULL ||
119 mg_ehand[MG_E_TS] != NULL)
120 uneed |= 1<<MG_E_MATERIAL;
121 for (i = 0; i < MG_NENTITIES; i++)
122 if (uneed & 1<<i && mg_ehand[i] == NULL) {
123 fprintf(stderr, "Missing support for \"%s\" entity\n",
124 mg_ename[i]);
125 exit(1);
126 }
127 /* add support as needed */
128 if (ineed & 1<<MG_E_VERTEX && mg_ehand[MG_E_VERTEX] != c_hvertex)
129 e_supp[MG_E_VERTEX] = c_hvertex;
130 if (ineed & 1<<MG_E_POINT && mg_ehand[MG_E_POINT] != c_hvertex)
131 e_supp[MG_E_POINT] = c_hvertex;
132 if (ineed & 1<<MG_E_NORMAL && mg_ehand[MG_E_NORMAL] != c_hvertex)
133 e_supp[MG_E_NORMAL] = c_hvertex;
134 /* discard remaining entities */
135 for (i = 0; i < MG_NENTITIES; i++)
136 if (mg_ehand[i] == NULL)
137 mg_ehand[i] = e_any_toss;
138 }
139
140
141
142 int
143 mg_entity(name) /* get entity number from its name */
144 char *name;
145 {
146 static LUTAB ent_tab; /* entity lookup table */
147 register char *cp;
148
149 if (!ent_tab.tsiz) { /* initialize hash table */
150 if (!lu_init(&ent_tab, MG_NENTITIES))
151 return(-1); /* what to do? */
152 for (cp = mg_ename[MG_NENTITIES-1]; cp >= mg_ename[0];
153 cp -= sizeof(mg_ename[0]))
154 lu_find(&ent_tab, cp)->key = cp;
155 }
156 cp = lu_find(&ent_tab, name)->key;
157 if (cp == NULL)
158 return(-1);
159 return((cp - mg_ename[0])/sizeof(mg_ename[0]));
160 }
161
162
163 static int
164 handle_it(en, ac, av) /* pass entity to appropriate handler */
165 register int en;
166 int ac;
167 char **av;
168 {
169 int rv;
170
171 if (en < 0 && (en = mg_entity(av[0])) < 0)
172 return(MG_EUNK);
173 if (e_supp[en] != NULL) {
174 if ((rv = (*e_supp[en])(ac, av)) != MG_OK)
175 return(rv);
176 }
177 return((*mg_ehand[en])(ac, av));
178 }
179
180
181 int
182 mg_open(ctx, fn) /* open new input file */
183 register MG_FCTXT *ctx;
184 char *fn;
185 {
186 int olen;
187 register char *cp;
188
189 ctx->lineno = 0;
190 if (fn == NULL) {
191 ctx->fname = "<stdin>";
192 ctx->fp = stdin;
193 ctx->prev = mg_file;
194 mg_file = ctx;
195 return(MG_OK);
196 }
197 /* get name relative to this context */
198 if (mg_file != NULL &&
199 (cp = strrchr(mg_file->fname, '/')) != NULL)
200 olen = cp - mg_file->fname + 1;
201 else
202 olen = 0;
203 ctx->fname = (char *)malloc(olen+strlen(fn)+1);
204 if (ctx->fname == NULL)
205 return(MG_EMEM);
206 if (olen)
207 strcpy(ctx->fname, mg_file->fname);
208 strcpy(ctx->fname+olen, fn);
209 ctx->fp = fopen(ctx->fname, "r");
210 if (ctx->fp == NULL) {
211 free((MEM_PTR)ctx->fname);
212 return(MG_ENOFILE);
213 }
214 ctx->prev = mg_file; /* establish new context */
215 mg_file = ctx;
216 return(MG_OK);
217 }
218
219
220 void
221 mg_close() /* close input file */
222 {
223 register MG_FCTXT *ctx = mg_file;
224
225 mg_file = ctx->prev; /* restore enclosing context */
226 if (ctx->fp == stdin)
227 return; /* don't close standard input */
228 fclose(ctx->fp);
229 free((MEM_PTR)ctx->fname);
230 }
231
232
233 int
234 mg_rewind() /* rewind input file */
235 {
236 if (mg_file->lineno == 0)
237 return(MG_OK);
238 if (mg_file->fp == stdin)
239 return(MG_ESEEK); /* cannot seek on standard input */
240 if (fseek(mg_file->fp, 0L, 0) == EOF)
241 return(MG_ESEEK);
242 mg_file->lineno = 0;
243 return(MG_OK);
244 }
245
246
247 int
248 mg_read() /* read next line from file */
249 {
250 register int len = 0;
251
252 do {
253 if (fgets(mg_file->inpline+len,
254 MG_MAXLINE-len, mg_file->fp) == NULL)
255 return(len);
256 mg_file->lineno++;
257 len += strlen(mg_file->inpline+len);
258 if (len > 1 && mg_file->inpline[len-2] == '\\')
259 mg_file->inpline[--len-1] = ' ';
260 } while (mg_file->inpline[len]);
261
262 return(len);
263 }
264
265
266 int
267 mg_parse() /* parse current input line */
268 {
269 char abuf[MG_MAXLINE];
270 char *argv[MG_MAXARGC];
271 int en;
272 register char *cp, **ap;
273
274 strcpy(cp=abuf, mg_file->inpline);
275 ap = argv; /* break into words */
276 for ( ; ; ) {
277 while (isspace(*cp))
278 *cp++ = '\0';
279 if (!*cp)
280 break;
281 if (ap - argv >= MG_MAXARGC-1)
282 return(MG_EARGC);
283 *ap++ = cp;
284 while (*++cp && !isspace(*cp))
285 ;
286 }
287 if (ap == argv)
288 return(MG_OK); /* no words in line */
289 *ap = NULL;
290 /* else handle it */
291 return(handle_it(-1, ap-argv, argv));
292 }
293
294
295 int
296 mg_load(fn) /* load an MGF file */
297 char *fn;
298 {
299 MG_FCTXT cntxt;
300 int rval;
301
302 if ((rval = mg_open(&cntxt, fn)) != MG_OK) {
303 fprintf(stderr, "%s: %s\n", fn, mg_err[rval]);
304 return(rval);
305 }
306 while (mg_read()) /* parse each line */
307 if ((rval = mg_parse()) != MG_OK) {
308 fprintf(stderr, "%s: %d: %s:\n%s", cntxt.fname,
309 cntxt.lineno, mg_err[rval],
310 cntxt.inpline);
311 break;
312 }
313 mg_close();
314 return(rval);
315 }
316
317
318 void
319 mg_clear() /* clear parser history */
320 {
321 c_clearall(); /* clear context tables */
322 mg_file = NULL; /* reset our context */
323 }
324
325
326 int
327 mg_iterate(ac, av, f) /* iterate on statement */
328 int ac;
329 register char **av;
330 int (*f)();
331 {
332 int niter, rval;
333 register int i, j;
334 char *argv[MG_MAXARGC];
335 char cntbuf[10];
336 /* build partial transformation */
337 for (i = 0; i < ac; i++) {
338 if (av[i][0] == '-' && av[i][1] == 'a' && av[i][2] == '\0')
339 break;
340 argv[i+1] = av[i];
341 }
342 argv[i+1] = NULL;
343 if (i) { /* handle transformation */
344 argv[0] = mg_ename[MG_E_XF];
345 if ((rval = handle_it(MG_E_XF, i+1, argv)) != MG_OK)
346 return(rval);
347 }
348 if (i < ac) { /* run array */
349 if (i+1 >= ac || !isint(av[i+1]))
350 return(MG_ETYPE);
351 niter = atoi(av[i+1]);
352 argv[0] = mg_ename[MG_E_OBJECT];
353 argv[1] = cntbuf;
354 for (j = 2; j+i < ac; j++)
355 argv[j] = av[j+i];
356 argv[j] = NULL;
357 for (j = 0; j < niter; j++) {
358 sprintf(cntbuf, "%d", j);
359 if ((rval = handle_it(MG_E_OBJECT, 2, argv)) != MG_OK)
360 return(rval);
361 argv[0] = "-i";
362 if ((rval = mg_iterate(ac-i, argv, f)) != MG_OK)
363 return(rval);
364 argv[0] = mg_ename[MG_E_OBJECT];
365 if ((rval = handle_it(MG_E_OBJECT, 1, argv)) != MG_OK)
366 return(rval);
367 }
368 } else if ((rval = (*f)()) != MG_OK) /* else do this instance */
369 return(rval);
370 if (i) { /* reset the transform */
371 argv[0] = mg_ename[MG_E_XF];
372 argv[1] = NULL;
373 (void)handle_it(MG_E_XF, 1, argv);
374 }
375 return(MG_OK);
376 }
377
378
379 /****************************************************************************
380 * The following routines handle unsupported entities
381 */
382
383
384 static int
385 e_any_toss(ac, av) /* discard an unwanted entity */
386 int ac;
387 char **av;
388 {
389 return(MG_OK);
390 }
391
392
393 static int
394 reload_file() /* reload current MGF file */
395 {
396 register int rval;
397
398 if ((rval = mg_rewind()) != MG_OK)
399 return(rval);
400 while (mg_read())
401 if ((rval = mg_parse()) != MG_OK)
402 return(rval);
403 return(MG_OK);
404 }
405
406
407 static int
408 e_include(ac, av) /* include file */
409 int ac;
410 char **av;
411 {
412 MG_FCTXT ictx;
413 int rv;
414
415 if (ac < 2)
416 return(MG_EARGC);
417 if ((rv = mg_open(&ictx, av[1])) != MG_OK)
418 return(rv);
419 if ((rv = mg_iterate(ac-2, av+2, reload_file)) != MG_OK) {
420 fprintf(stderr, "%s: %d: %s:\n%s", ictx.fname,
421 ictx.lineno, mg_err[rv], ictx.inpline);
422 mg_close();
423 return(MG_EINCL);
424 }
425 mg_close();
426 return(MG_OK);
427 }
428
429
430 static void
431 make_axes(u, v, w) /* compute u and v given w (normalized) */
432 FVECT u, v, w;
433 {
434 register int i;
435
436 v[0] = v[1] = v[2] = 0.;
437 for (i = 0; i < 3; i++)
438 if (w[i] < .6 && w[i] > -.6)
439 break;
440 v[i] = 1.;
441 fcross(u, v, w);
442 normalize(u);
443 fcross(v, w, u);
444 }
445
446
447 static int
448 e_sph(ac, av) /* expand a sphere into cones */
449 int ac;
450 char **av;
451 {
452 static char p2x[24], p2y[24], p2z[24], r1[24], r2[24];
453 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_sv1","=","_sv2"};
454 static char *v2ent[4] = {mg_ename[MG_E_VERTEX],"_sv2","="};
455 static char *p2ent[5] = {mg_ename[MG_E_POINT],p2x,p2y,p2z};
456 static char *conent[6] = {mg_ename[MG_E_CONE],"_sv1",r1,"_sv2",r2};
457 register C_VERTEX *cv;
458 register int i;
459 int rval;
460 double rad;
461 double theta;
462
463 if (ac != 3)
464 return(MG_EARGC);
465 if ((cv = c_getvert(av[1])) == NULL)
466 return(MG_EUNDEF);
467 if (!isflt(av[2]))
468 return(MG_ETYPE);
469 rad = atof(av[2]);
470 /* initialize */
471 warpconends = 1;
472 if ((rval = handle_it(MG_E_VERTEX, 3, v2ent)) != MG_OK)
473 return(rval);
474 sprintf(p2x, FLTFMT, cv->p[0]);
475 sprintf(p2y, FLTFMT, cv->p[1]);
476 sprintf(p2z, FLTFMT, cv->p[2]+rad);
477 if ((rval = handle_it(MG_E_POINT, 4, p2ent)) != MG_OK)
478 return(rval);
479 r2[0] = '0'; r2[1] = '\0';
480 for (i = 1; i <= 2*mg_nqcdivs; i++) {
481 theta = i*(PI/2)/mg_nqcdivs;
482 if ((rval = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK)
483 return(rval);
484 sprintf(p2z, FLTFMT, cv->p[2]+rad*cos(theta));
485 if ((rval = handle_it(MG_E_VERTEX, 2, v2ent)) != MG_OK)
486 return(rval);
487 if ((rval = handle_it(MG_E_POINT, 4, p2ent)) != MG_OK)
488 return(rval);
489 strcpy(r1, r2);
490 sprintf(r2, FLTFMT, rad*sin(theta));
491 if ((rval = handle_it(MG_E_CONE, 5, conent)) != MG_OK)
492 return(rval);
493 }
494 warpconends = 0;
495 return(MG_OK);
496 }
497
498
499 static int
500 e_torus(ac, av) /* expand a torus into cones */
501 int ac;
502 char **av;
503 {
504 static char p2[3][24], r1[24], r2[24];
505 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_tv1","=","_tv2"};
506 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_tv2","="};
507 static char *p2ent[5] = {mg_ename[MG_E_POINT],p2[0],p2[1],p2[2]};
508 static char *conent[6] = {mg_ename[MG_E_CONE],"_tv1",r1,"_tv2",r2};
509 register C_VERTEX *cv;
510 register int i, j;
511 int rval;
512 int sgn;
513 double minrad, maxrad, avgrad;
514 double theta;
515
516 if (ac != 4)
517 return(MG_EARGC);
518 if ((cv = c_getvert(av[1])) == NULL)
519 return(MG_EUNDEF);
520 if (cv->n[0]==0. && cv->n[1]==0. && cv->n[2]==0.)
521 return(MG_EILL);
522 if (!isflt(av[2]) || !isflt(av[3]))
523 return(MG_ETYPE);
524 minrad = atof(av[2]);
525 maxrad = atof(av[3]);
526 /* check orientation */
527 if (minrad > 0.)
528 sgn = 1;
529 else if (minrad < 0.)
530 sgn = -1;
531 else if (maxrad > 0.)
532 sgn = 1;
533 else if (maxrad < 0.)
534 sgn = -1;
535 else
536 return(MG_EILL);
537 if (sgn*(maxrad-minrad) <= 0.)
538 return(MG_EILL);
539 /* initialize */
540 warpconends = 1;
541 v2ent[3] = av[1];
542 for (j = 0; j < 3; j++)
543 sprintf(p2[j], FLTFMT, cv->p[j] +
544 .5*sgn*(maxrad-minrad)*cv->n[j]);
545 if ((rval = handle_it(MG_E_VERTEX, 4, v2ent)) != MG_OK)
546 return(rval);
547 if ((rval = handle_it(MG_E_POINT, 4, p2ent)) != MG_OK)
548 return(rval);
549 sprintf(r2, FLTFMT, avgrad=.5*(minrad+maxrad));
550 /* run outer section */
551 for (i = 1; i <= 2*mg_nqcdivs; i++) {
552 theta = i*(PI/2)/mg_nqcdivs;
553 if ((rval = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK)
554 return(rval);
555 for (j = 0; j < 3; j++)
556 sprintf(p2[j], FLTFMT, cv->p[j] +
557 .5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]);
558 if ((rval = handle_it(MG_E_VERTEX, 2, v2ent)) != MG_OK)
559 return(rval);
560 if ((rval = handle_it(MG_E_POINT, 4, p2ent)) != MG_OK)
561 return(rval);
562 strcpy(r1, r2);
563 sprintf(r2, FLTFMT, avgrad + .5*(maxrad-minrad)*sin(theta));
564 if ((rval = handle_it(MG_E_CONE, 5, conent)) != MG_OK)
565 return(rval);
566 }
567 /* run inner section */
568 sprintf(r2, FLTFMT, -.5*(minrad+maxrad));
569 for ( ; i <= 4*mg_nqcdivs; i++) {
570 theta = i*(PI/2)/mg_nqcdivs;
571 for (j = 0; j < 3; j++)
572 sprintf(p2[j], FLTFMT, cv->p[j] +
573 .5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]);
574 if ((rval = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK)
575 return(rval);
576 if ((rval = handle_it(MG_E_VERTEX, 2, v2ent)) != MG_OK)
577 return(rval);
578 if ((rval = handle_it(MG_E_POINT, 4, p2ent)) != MG_OK)
579 return(rval);
580 strcpy(r1, r2);
581 sprintf(r2, FLTFMT, -avgrad - .5*(maxrad-minrad)*sin(theta));
582 if ((rval = handle_it(MG_E_CONE, 5, conent)) != MG_OK)
583 return(rval);
584 }
585 warpconends = 0;
586 return(MG_OK);
587 }
588
589
590 static int
591 e_cyl(ac, av) /* replace a cylinder with equivalent cone */
592 int ac;
593 char **av;
594 {
595 static char *avnew[6] = {mg_ename[MG_E_CONE]};
596
597 if (ac != 4)
598 return(MG_EARGC);
599 avnew[1] = av[1];
600 avnew[2] = av[2];
601 avnew[3] = av[3];
602 avnew[4] = av[2];
603 return(handle_it(MG_E_CONE, 5, avnew));
604 }
605
606
607 static int
608 e_ring(ac, av) /* turn a ring into polygons */
609 int ac;
610 char **av;
611 {
612 static char p3[3][24], p4[3][24];
613 static char *nzent[5] = {mg_ename[MG_E_NORMAL],"0","0","0"};
614 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_rv1","="};
615 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_rv2","=","_rv3"};
616 static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_rv3","="};
617 static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]};
618 static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_rv4","="};
619 static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]};
620 static char *fent[6] = {mg_ename[MG_E_FACE],"_rv1","_rv2","_rv3","_rv4"};
621 register C_VERTEX *cv;
622 register int i, j;
623 FVECT u, v;
624 double minrad, maxrad;
625 int rv;
626 double theta, d;
627
628 if (ac != 4)
629 return(MG_EARGC);
630 if ((cv = c_getvert(av[1])) == NULL)
631 return(MG_EUNDEF);
632 if (cv->n[0]==0. && cv->n[1]==0. && cv->n[2]==0.)
633 return(MG_EILL);
634 if (!isflt(av[2]) || !isflt(av[3]))
635 return(MG_ETYPE);
636 minrad = atof(av[2]);
637 maxrad = atof(av[3]);
638 if (minrad < 0. || maxrad <= minrad)
639 return(MG_EILL);
640 /* initialize */
641 make_axes(u, v, cv->n);
642 for (j = 0; j < 3; j++)
643 sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*u[j]);
644 if ((rv = handle_it(MG_E_VERTEX, 3, v3ent)) != MG_OK)
645 return(rv);
646 if ((rv = handle_it(MG_E_POINT, 4, p3ent)) != MG_OK)
647 return(rv);
648 if (minrad == 0.) { /* closed */
649 v1ent[3] = av[1];
650 if ((rv = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK)
651 return(rv);
652 if ((rv = handle_it(MG_E_NORMAL, 4, nzent)) != MG_OK)
653 return(rv);
654 for (i = 1; i <= 4*mg_nqcdivs; i++) {
655 theta = i*(PI/2)/mg_nqcdivs;
656 if ((rv = handle_it(MG_E_VERTEX, 4, v2ent)) != MG_OK)
657 return(rv);
658 for (j = 0; j < 3; j++)
659 sprintf(p3[j], FLTFMT, cv->p[j] +
660 maxrad*u[j]*cos(theta) +
661 maxrad*v[j]*sin(theta));
662 if ((rv = handle_it(MG_E_VERTEX, 3, v3ent)) != MG_OK)
663 return(rv);
664 if ((rv = handle_it(MG_E_POINT, 4, p3ent)) != MG_OK)
665 return(rv);
666 if ((rv = handle_it(MG_E_FACE, 4, fent)) != MG_OK)
667 return(rv);
668 }
669 } else { /* open */
670 if ((rv = handle_it(MG_E_VERTEX, 3, v4ent)) != MG_OK)
671 return(rv);
672 for (j = 0; j < 3; j++)
673 sprintf(p4[j], FLTFMT, cv->p[j] + minrad*u[j]);
674 if ((rv = handle_it(MG_E_POINT, 4, p4ent)) != MG_OK)
675 return(rv);
676 v1ent[3] = "_rv4";
677 for (i = 1; i <= 4*mg_nqcdivs; i++) {
678 theta = i*(PI/2)/mg_nqcdivs;
679 if ((rv = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK)
680 return(rv);
681 if ((rv = handle_it(MG_E_VERTEX, 4, v2ent)) != MG_OK)
682 return(rv);
683 for (j = 0; j < 3; j++) {
684 d = u[j]*cos(theta) + v[j]*sin(theta);
685 sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*d);
686 sprintf(p4[j], FLTFMT, cv->p[j] + minrad*d);
687 }
688 if ((rv = handle_it(MG_E_VERTEX, 3, v3ent)) != MG_OK)
689 return(rv);
690 if ((rv = handle_it(MG_E_POINT, 4, p3ent)) != MG_OK)
691 return(rv);
692 if ((rv = handle_it(MG_E_VERTEX, 3, v4ent)) != MG_OK)
693 return(rv);
694 if ((rv = handle_it(MG_E_POINT, 4, p4ent)) != MG_OK)
695 return(rv);
696 if ((rv = handle_it(MG_E_FACE, 5, fent)) != MG_OK)
697 return(rv);
698 }
699 }
700 return(MG_OK);
701 }
702
703
704 static int
705 e_cone(ac, av) /* turn a cone into polygons */
706 int ac;
707 char **av;
708 {
709 static char p3[3][24], p4[3][24], n3[3][24], n4[3][24];
710 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_cv1","="};
711 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_cv2","=","_cv3"};
712 static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_cv3","="};
713 static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]};
714 static char *n3ent[5] = {mg_ename[MG_E_NORMAL],n3[0],n3[1],n3[2]};
715 static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_cv4","="};
716 static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]};
717 static char *n4ent[5] = {mg_ename[MG_E_NORMAL],n4[0],n4[1],n4[2]};
718 static char *fent[6] = {mg_ename[MG_E_FACE],"_cv1","_cv2","_cv3","_cv4"};
719 register C_VERTEX *cv1, *cv2;
720 register int i, j;
721 FVECT u, v, w;
722 double rad1, rad2;
723 int sgn;
724 double n1off, n2off;
725 double d;
726 int rv;
727 double theta;
728
729 if (ac != 5)
730 return(MG_EARGC);
731 if ((cv1 = c_getvert(av[1])) == NULL ||
732 (cv2 = c_getvert(av[3])) == NULL)
733 return(MG_EUNDEF);
734 if (!isflt(av[2]) || !isflt(av[4]))
735 return(MG_ETYPE);
736 rad1 = atof(av[2]);
737 rad2 = atof(av[4]);
738 if (rad1 == 0.) {
739 if (rad2 == 0.)
740 return(MG_EILL);
741 } else if (rad2 != 0.) {
742 if (rad1 < 0. ^ rad2 < 0.)
743 return(MG_EILL);
744 } else { /* swap */
745 C_VERTEX *cv;
746
747 cv = cv1;
748 cv1 = cv2;
749 cv2 = cv;
750 d = rad1;
751 rad1 = rad2;
752 rad2 = d;
753 }
754 sgn = rad2 < 0. ? -1 : 1;
755 /* initialize */
756 for (j = 0; j < 3; j++)
757 w[j] = cv1->p[j] - cv2->p[j];
758 if ((d = normalize(w)) == 0.)
759 return(MG_EILL);
760 n1off = n2off = (rad2 - rad1)/d;
761 if (warpconends) /* hack for e_sph and e_torus */
762 n2off = tan(atan(n2off)-(PI/4)/mg_nqcdivs);
763 n2off = sgn*n2off;
764 make_axes(u, v, w);
765 for (j = 0; j < 3; j++) {
766 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*u[j]);
767 sprintf(n3[j], FLTFMT, u[j] + w[j]*n2off);
768 }
769 if ((rv = handle_it(MG_E_VERTEX, 3, v3ent)) != MG_OK)
770 return(rv);
771 if ((rv = handle_it(MG_E_POINT, 4, p3ent)) != MG_OK)
772 return(rv);
773 if ((rv = handle_it(MG_E_NORMAL, 4, n3ent)) != MG_OK)
774 return(rv);
775 if (rad1 == 0.) { /* triangles */
776 v1ent[3] = av[1];
777 if ((rv = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK)
778 return(rv);
779 for (j = 0; j < 3; j++)
780 sprintf(n4[j], FLTFMT, w[j]);
781 if ((rv = handle_it(MG_E_NORMAL, 4, n4ent)) != MG_OK)
782 return(rv);
783 for (i = 1; i <= 4*mg_nqcdivs; i++) {
784 theta = sgn*i*(PI/2)/mg_nqcdivs;
785 if ((rv = handle_it(MG_E_VERTEX, 4, v2ent)) != MG_OK)
786 return(rv);
787 for (j = 0; j < 3; j++) {
788 d = u[j]*cos(theta) + v[j]*sin(theta);
789 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d);
790 sprintf(n3[j], FLTFMT, d + w[j]*n2off);
791 }
792 if ((rv = handle_it(MG_E_VERTEX, 3, v3ent)) != MG_OK)
793 return(rv);
794 if ((rv = handle_it(MG_E_POINT, 4, p3ent)) != MG_OK)
795 return(rv);
796 if ((rv = handle_it(MG_E_NORMAL, 4, n3ent)) != MG_OK)
797 return(rv);
798 if ((rv = handle_it(MG_E_FACE, 4, fent)) != MG_OK)
799 return(rv);
800 }
801 } else { /* quads */
802 v1ent[3] = "_cv4";
803 if (warpconends) /* hack for e_sph and e_torus */
804 n1off = tan(atan(n1off)+(PI/4)/mg_nqcdivs);
805 n1off = sgn*n1off;
806 for (j = 0; j < 3; j++) {
807 sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*u[j]);
808 sprintf(n4[j], FLTFMT, u[j] + w[j]*n1off);
809 }
810 if ((rv = handle_it(MG_E_VERTEX, 3, v4ent)) != MG_OK)
811 return(rv);
812 if ((rv = handle_it(MG_E_POINT, 4, p4ent)) != MG_OK)
813 return(rv);
814 if ((rv = handle_it(MG_E_NORMAL, 4, n4ent)) != MG_OK)
815 return(rv);
816 for (i = 1; i <= 4*mg_nqcdivs; i++) {
817 theta = sgn*i*(PI/2)/mg_nqcdivs;
818 if ((rv = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK)
819 return(rv);
820 if ((rv = handle_it(MG_E_VERTEX, 4, v2ent)) != MG_OK)
821 return(rv);
822 for (j = 0; j < 3; j++) {
823 d = u[j]*cos(theta) + v[j]*sin(theta);
824 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d);
825 sprintf(n3[j], FLTFMT, d + w[j]*n2off);
826 sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*d);
827 sprintf(n4[j], FLTFMT, d + w[j]*n1off);
828 }
829 if ((rv = handle_it(MG_E_VERTEX, 3, v3ent)) != MG_OK)
830 return(rv);
831 if ((rv = handle_it(MG_E_POINT, 4, p3ent)) != MG_OK)
832 return(rv);
833 if ((rv = handle_it(MG_E_NORMAL, 4, n3ent)) != MG_OK)
834 return(rv);
835 if ((rv = handle_it(MG_E_VERTEX, 3, v4ent)) != MG_OK)
836 return(rv);
837 if ((rv = handle_it(MG_E_POINT, 4, p4ent)) != MG_OK)
838 return(rv);
839 if ((rv = handle_it(MG_E_NORMAL, 4, n4ent)) != MG_OK)
840 return(rv);
841 if ((rv = handle_it(MG_E_FACE, 5, fent)) != MG_OK)
842 return(rv);
843 }
844 }
845 return(MG_OK);
846 }
