root/Development/ray/src/cv/mgflib/parser.c
Revision: 1.19
Committed: Fri Oct 27 15:47:18 1995 UTC (29 years, 11 months ago) by greg
Changes since 1.18: +4 -1 lines
fixed bug in e_cone
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Parse an MGF file, converting or discarding unsupported entities
9 */
10
11 #include <stdio.h>
12 #include <math.h>
13 #include <ctype.h>
14 #include <string.h>
15 #include "parser.h"
16 #include "lookup.h"
17 #include "messages.h"
18
19 /*
20 * Global definitions of variables declared in parser.h
21 */
22 /* entity names */
23
24 char mg_ename[MG_NENTITIES][MG_MAXELEN] = MG_NAMELIST;
25
26 /* Handler routines for each entity */
27
28 int (*mg_ehand[MG_NENTITIES])();
29
30 /* Handler routine for unknown entities */
31
32 int (*mg_uhand)() = mg_defuhand;
33
34 unsigned mg_nunknown; /* count of unknown entities */
35
36 /* error messages */
37
38 char *mg_err[MG_NERRS] = MG_ERRLIST;
39
40 MG_FCTXT *mg_file; /* current file context pointer */
41
42 int mg_nqcdivs = MG_NQCD; /* number of divisions per quarter circle */
43
44 /*
45 * The idea with this parser is to compensate for any missing entries in
46 * mg_ehand with alternate handlers that express these entities in terms
47 * of others that the calling program can handle.
48 *
49 * In some cases, no alternate handler is possible because the entity
50 * has no approximate equivalent. These entities are simply discarded.
51 *
52 * Certain entities are dependent on others, and mg_init() will fail
53 * if the supported entities are not consistent.
54 *
55 * Some alternate entity handlers require that earlier entities be
56 * noted in some fashion, and we therefore keep another array of
57 * parallel support handlers to assist in this effort.
58 */
59
60 /* temporary settings for testing */
61 #define e_ies e_any_toss
62 /* alternate handler routines */
63
64 static int e_any_toss(), /* discard unneeded entity */
65 e_ies(), /* IES luminaire file */
66 e_include(), /* include file */
67 e_sph(), /* sphere */
68 e_cct(), /* color temperature */
69 e_cmix(), /* color mixtures */
70 e_cspec(), /* color spectra */
71 e_cyl(), /* cylinder */
72 e_cone(), /* cone */
73 e_prism(), /* prism */
74 e_ring(), /* ring */
75 e_torus(); /* torus */
76
77 /* alternate handler support functions */
78
79 static int (*e_supp[MG_NENTITIES])();
80
81 static char FLTFMT[] = "%.12g";
82
83 static int warpconends; /* hack for generating good normals */
84
85
86 void
87 mg_init() /* initialize alternate entity handlers */
88 {
89 unsigned long ineed = 0, uneed = 0;
90 register int i;
91 /* pick up slack */
92 if (mg_ehand[MG_E_IES] == NULL)
93 mg_ehand[MG_E_IES] = e_ies;
94 if (mg_ehand[MG_E_INCLUDE] == NULL)
95 mg_ehand[MG_E_INCLUDE] = e_include;
96 if (mg_ehand[MG_E_SPH] == NULL) {
97 mg_ehand[MG_E_SPH] = e_sph;
98 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
99 } else
100 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
101 if (mg_ehand[MG_E_CYL] == NULL) {
102 mg_ehand[MG_E_CYL] = e_cyl;
103 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
104 } else
105 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
106 if (mg_ehand[MG_E_CONE] == NULL) {
107 mg_ehand[MG_E_CONE] = e_cone;
108 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
109 } else
110 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
111 if (mg_ehand[MG_E_RING] == NULL) {
112 mg_ehand[MG_E_RING] = e_ring;
113 ineed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX;
114 } else
115 uneed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX|1L<<MG_E_XF;
116 if (mg_ehand[MG_E_PRISM] == NULL) {
117 mg_ehand[MG_E_PRISM] = e_prism;
118 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
119 } else
120 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
121 if (mg_ehand[MG_E_TORUS] == NULL) {
122 mg_ehand[MG_E_TORUS] = e_torus;
123 ineed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX;
124 } else
125 uneed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX|1L<<MG_E_XF;
126 if (mg_ehand[MG_E_COLOR] != NULL) {
127 if (mg_ehand[MG_E_CMIX] == NULL) {
128 mg_ehand[MG_E_CMIX] = e_cmix;
129 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
130 }
131 if (mg_ehand[MG_E_CSPEC] == NULL) {
132 mg_ehand[MG_E_CSPEC] = e_cspec;
133 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
134 }
135 if (mg_ehand[MG_E_CCT] == NULL) {
136 mg_ehand[MG_E_CCT] = e_cct;
137 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
138 }
139 }
140 /* check for consistency */
141 if (mg_ehand[MG_E_FACE] != NULL)
142 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
143 if (mg_ehand[MG_E_CXY] != NULL || mg_ehand[MG_E_CSPEC] != NULL ||
144 mg_ehand[MG_E_CMIX] != NULL)
145 uneed |= 1L<<MG_E_COLOR;
146 if (mg_ehand[MG_E_RD] != NULL || mg_ehand[MG_E_TD] != NULL ||
147 mg_ehand[MG_E_IR] != NULL ||
148 mg_ehand[MG_E_ED] != NULL ||
149 mg_ehand[MG_E_RS] != NULL ||
150 mg_ehand[MG_E_TS] != NULL ||
151 mg_ehand[MG_E_SIDES] != NULL)
152 uneed |= 1L<<MG_E_MATERIAL;
153 for (i = 0; i < MG_NENTITIES; i++)
154 if (uneed & 1L<<i && mg_ehand[i] == NULL) {
155 fprintf(stderr, "Missing support for \"%s\" entity\n",
156 mg_ename[i]);
157 exit(1);
158 }
159 /* add support as needed */
160 if (ineed & 1L<<MG_E_VERTEX && mg_ehand[MG_E_VERTEX] != c_hvertex)
161 e_supp[MG_E_VERTEX] = c_hvertex;
162 if (ineed & 1L<<MG_E_POINT && mg_ehand[MG_E_POINT] != c_hvertex)
163 e_supp[MG_E_POINT] = c_hvertex;
164 if (ineed & 1L<<MG_E_NORMAL && mg_ehand[MG_E_NORMAL] != c_hvertex)
165 e_supp[MG_E_NORMAL] = c_hvertex;
166 if (ineed & 1L<<MG_E_COLOR && mg_ehand[MG_E_COLOR] != c_hcolor)
167 e_supp[MG_E_COLOR] = c_hcolor;
168 if (ineed & 1L<<MG_E_CXY && mg_ehand[MG_E_CXY] != c_hcolor)
169 e_supp[MG_E_CXY] = c_hcolor;
170 if (ineed & 1L<<MG_E_CSPEC && mg_ehand[MG_E_CSPEC] != c_hcolor)
171 e_supp[MG_E_CSPEC] = c_hcolor;
172 if (ineed & 1L<<MG_E_CMIX && mg_ehand[MG_E_CMIX] != c_hcolor)
173 e_supp[MG_E_CMIX] = c_hcolor;
174 if (ineed & 1L<<MG_E_CCT && mg_ehand[MG_E_CCT] != c_hcolor)
175 e_supp[MG_E_CCT] = c_hcolor;
176 /* discard remaining entities */
177 for (i = 0; i < MG_NENTITIES; i++)
178 if (mg_ehand[i] == NULL)
179 mg_ehand[i] = e_any_toss;
180 }
181
182
183 int
184 mg_entity(name) /* get entity number from its name */
185 char *name;
186 {
187 static LUTAB ent_tab = LU_SINIT(NULL,NULL); /* lookup table */
188 register char *cp;
189
190 if (!ent_tab.tsiz) { /* initialize hash table */
191 if (!lu_init(&ent_tab, MG_NENTITIES))
192 return(-1); /* what to do? */
193 for (cp = mg_ename[MG_NENTITIES-1]; cp >= mg_ename[0];
194 cp -= sizeof(mg_ename[0]))
195 lu_find(&ent_tab, cp)->key = cp;
196 }
197 cp = lu_find(&ent_tab, name)->key;
198 if (cp == NULL)
199 return(-1);
200 return((cp - mg_ename[0])/sizeof(mg_ename[0]));
201 }
202
203
204 int
205 mg_handle(en, ac, av) /* pass entity to appropriate handler */
206 register int en;
207 int ac;
208 char **av;
209 {
210 int rv;
211
212 if (en < 0 && (en = mg_entity(av[0])) < 0) { /* unknown entity */
213 if (mg_uhand != NULL)
214 return((*mg_uhand)(ac, av));
215 return(MG_EUNK);
216 }
217 if (e_supp[en] != NULL) { /* support handler */
218 if ((rv = (*e_supp[en])(ac, av)) != MG_OK)
219 return(rv);
220 }
221 return((*mg_ehand[en])(ac, av)); /* assigned handler */
222 }
223
224
225 int
226 mg_open(ctx, fn) /* open new input file */
227 register MG_FCTXT *ctx;
228 char *fn;
229 {
230 static int nfids;
231 register char *cp;
232
233 ctx->fid = ++nfids;
234 ctx->lineno = 0;
235 if (fn == NULL) {
236 strcpy(ctx->fname, "<stdin>");
237 ctx->fp = stdin;
238 ctx->prev = mg_file;
239 mg_file = ctx;
240 return(MG_OK);
241 }
242 /* get name relative to this context */
243 if (mg_file != NULL && (cp = strrchr(mg_file->fname, '/')) != NULL) {
244 strcpy(ctx->fname, mg_file->fname);
245 strcpy(ctx->fname+(cp-mg_file->fname+1), fn);
246 } else
247 strcpy(ctx->fname, fn);
248 ctx->fp = fopen(ctx->fname, "r");
249 if (ctx->fp == NULL)
250 return(MG_ENOFILE);
251 ctx->prev = mg_file; /* establish new context */
252 mg_file = ctx;
253 return(MG_OK);
254 }
255
256
257 void
258 mg_close() /* close input file */
259 {
260 register MG_FCTXT *ctx = mg_file;
261
262 mg_file = ctx->prev; /* restore enclosing context */
263 if (ctx->fp == stdin)
264 return; /* don't close standard input */
265 fclose(ctx->fp);
266 }
267
268
269 void
270 mg_fgetpos(pos) /* get current position in input file */
271 register MG_FPOS *pos;
272 {
273 extern long ftell();
274
275 pos->fid = mg_file->fid;
276 pos->lineno = mg_file->lineno;
277 pos->offset = ftell(mg_file->fp);
278 }
279
280
281 int
282 mg_fgoto(pos) /* reposition input file pointer */
283 register MG_FPOS *pos;
284 {
285 if (pos->fid != mg_file->fid)
286 return(MG_ESEEK);
287 if (pos->lineno == mg_file->lineno)
288 return(MG_OK);
289 if (mg_file->fp == stdin)
290 return(MG_ESEEK); /* cannot seek on standard input */
291 if (fseek(mg_file->fp, pos->offset, 0) == EOF)
292 return(MG_ESEEK);
293 mg_file->lineno = pos->lineno;
294 return(MG_OK);
295 }
296
297
298 int
299 mg_read() /* read next line from file */
300 {
301 register int len = 0;
302
303 do {
304 if (fgets(mg_file->inpline+len,
305 MG_MAXLINE-len, mg_file->fp) == NULL)
306 return(len);
307 mg_file->lineno++;
308 len += strlen(mg_file->inpline+len);
309 if (len > 1 && mg_file->inpline[len-2] == '\\')
310 mg_file->inpline[--len-1] = ' ';
311 } while (mg_file->inpline[len]);
312
313 return(len);
314 }
315
316
317 int
318 mg_parse() /* parse current input line */
319 {
320 char abuf[MG_MAXLINE];
321 char *argv[MG_MAXARGC];
322 int en;
323 register char *cp, **ap;
324
325 strcpy(cp=abuf, mg_file->inpline);
326 ap = argv; /* break into words */
327 for ( ; ; ) {
328 while (isspace(*cp))
329 *cp++ = '\0';
330 if (!*cp)
331 break;
332 if (ap - argv >= MG_MAXARGC-1)
333 return(MG_EARGC);
334 *ap++ = cp;
335 while (*++cp && !isspace(*cp))
336 ;
337 }
338 if (ap == argv)
339 return(MG_OK); /* no words in line */
340 *ap = NULL;
341 /* else handle it */
342 return(mg_handle(-1, ap-argv, argv));
343 }
344
345
346 int
347 mg_load(fn) /* load an MGF file */
348 char *fn;
349 {
350 MG_FCTXT cntxt;
351 int rval;
352
353 if ((rval = mg_open(&cntxt, fn)) != MG_OK) {
354 fprintf(stderr, "%s: %s\n", fn, mg_err[rval]);
355 return(rval);
356 }
357 while (mg_read()) /* parse each line */
358 if ((rval = mg_parse()) != MG_OK) {
359 fprintf(stderr, "%s: %d: %s:\n%s", cntxt.fname,
360 cntxt.lineno, mg_err[rval],
361 cntxt.inpline);
362 break;
363 }
364 mg_close();
365 return(rval);
366 }
367
368
369 int
370 mg_defuhand(ac, av) /* default handler for unknown entities */
371 int ac;
372 char **av;
373 {
374 if (mg_nunknown++ == 0) /* report first incident */
375 fprintf(stderr, "%s: %d: %s: %s\n", mg_file->fname,
376 mg_file->lineno, mg_err[MG_EUNK], av[0]);
377 return(MG_OK);
378 }
379
380
381 void
382 mg_clear() /* clear parser history */
383 {
384 c_clearall(); /* clear context tables */
385 mg_file = NULL; /* reset our context */
386 }
387
388
389 /****************************************************************************
390 * The following routines handle unsupported entities
391 */
392
393
394 static int
395 e_any_toss(ac, av) /* discard an unwanted entity */
396 int ac;
397 char **av;
398 {
399 return(MG_OK);
400 }
401
402
403 static int
404 e_include(ac, av) /* include file */
405 int ac;
406 char **av;
407 {
408 char *xfarg[MG_MAXARGC];
409 MG_FCTXT ictx;
410 XF_SPEC *xf_orig = xf_context;
411 int rv;
412
413 if (ac < 2)
414 return(MG_EARGC);
415 if ((rv = mg_open(&ictx, av[1])) != MG_OK)
416 return(rv);
417 if (ac > 2) {
418 register int i;
419
420 xfarg[0] = mg_ename[MG_E_XF];
421 for (i = 1; i < ac-1; i++)
422 xfarg[i] = av[i+1];
423 xfarg[ac-1] = NULL;
424 if ((rv = mg_handle(MG_E_XF, ac-1, xfarg)) != MG_OK)
425 return(rv);
426 }
427 do {
428 while (mg_read())
429 if ((rv = mg_parse()) != MG_OK) {
430 fprintf(stderr, "%s: %d: %s:\n%s", ictx.fname,
431 ictx.lineno, mg_err[rv],
432 ictx.inpline);
433 mg_close();
434 return(MG_EINCL);
435 }
436 if (ac > 2)
437 if ((rv = mg_handle(MG_E_XF, 1, xfarg)) != MG_OK)
438 return(rv);
439 } while (xf_context != xf_orig);
440 mg_close();
441 return(MG_OK);
442 }
443
444
445 static void
446 make_axes(u, v, w) /* compute u and v given w (normalized) */
447 FVECT u, v, w;
448 {
449 register int i;
450
451 v[0] = v[1] = v[2] = 0.;
452 for (i = 0; i < 3; i++)
453 if (w[i] < .6 && w[i] > -.6)
454 break;
455 v[i] = 1.;
456 fcross(u, v, w);
457 normalize(u);
458 fcross(v, w, u);
459 }
460
461
462 static int
463 e_sph(ac, av) /* expand a sphere into cones */
464 int ac;
465 char **av;
466 {
467 static char p2x[24], p2y[24], p2z[24], r1[24], r2[24];
468 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_sv1","=","_sv2"};
469 static char *v2ent[4] = {mg_ename[MG_E_VERTEX],"_sv2","="};
470 static char *p2ent[5] = {mg_ename[MG_E_POINT],p2x,p2y,p2z};
471 static char *conent[6] = {mg_ename[MG_E_CONE],"_sv1",r1,"_sv2",r2};
472 register C_VERTEX *cv;
473 register int i;
474 int rval;
475 double rad;
476 double theta;
477
478 if (ac != 3)
479 return(MG_EARGC);
480 if ((cv = c_getvert(av[1])) == NULL)
481 return(MG_EUNDEF);
482 if (!isflt(av[2]))
483 return(MG_ETYPE);
484 rad = atof(av[2]);
485 /* initialize */
486 warpconends = 1;
487 if ((rval = mg_handle(MG_E_VERTEX, 3, v2ent)) != MG_OK)
488 return(rval);
489 sprintf(p2x, FLTFMT, cv->p[0]);
490 sprintf(p2y, FLTFMT, cv->p[1]);
491 sprintf(p2z, FLTFMT, cv->p[2]+rad);
492 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
493 return(rval);
494 r2[0] = '0'; r2[1] = '\0';
495 for (i = 1; i <= 2*mg_nqcdivs; i++) {
496 theta = i*(PI/2)/mg_nqcdivs;
497 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
498 return(rval);
499 sprintf(p2z, FLTFMT, cv->p[2]+rad*cos(theta));
500 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
501 return(rval);
502 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
503 return(rval);
504 strcpy(r1, r2);
505 sprintf(r2, FLTFMT, rad*sin(theta));
506 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
507 return(rval);
508 }
509 warpconends = 0;
510 return(MG_OK);
511 }
512
513
514 static int
515 e_torus(ac, av) /* expand a torus into cones */
516 int ac;
517 char **av;
518 {
519 static char p2[3][24], r1[24], r2[24];
520 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_tv1","=","_tv2"};
521 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_tv2","="};
522 static char *p2ent[5] = {mg_ename[MG_E_POINT],p2[0],p2[1],p2[2]};
523 static char *conent[6] = {mg_ename[MG_E_CONE],"_tv1",r1,"_tv2",r2};
524 register C_VERTEX *cv;
525 register int i, j;
526 int rval;
527 int sgn;
528 double minrad, maxrad, avgrad;
529 double theta;
530
531 if (ac != 4)
532 return(MG_EARGC);
533 if ((cv = c_getvert(av[1])) == NULL)
534 return(MG_EUNDEF);
535 if (is0vect(cv->n))
536 return(MG_EILL);
537 if (!isflt(av[2]) || !isflt(av[3]))
538 return(MG_ETYPE);
539 minrad = atof(av[2]);
540 round0(minrad);
541 maxrad = atof(av[3]);
542 /* check orientation */
543 if (minrad > 0.)
544 sgn = 1;
545 else if (minrad < 0.)
546 sgn = -1;
547 else if (maxrad > 0.)
548 sgn = 1;
549 else if (maxrad < 0.)
550 sgn = -1;
551 else
552 return(MG_EILL);
553 if (sgn*(maxrad-minrad) <= 0.)
554 return(MG_EILL);
555 /* initialize */
556 warpconends = 1;
557 v2ent[3] = av[1];
558 for (j = 0; j < 3; j++)
559 sprintf(p2[j], FLTFMT, cv->p[j] +
560 .5*sgn*(maxrad-minrad)*cv->n[j]);
561 if ((rval = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
562 return(rval);
563 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
564 return(rval);
565 sprintf(r2, FLTFMT, avgrad=.5*(minrad+maxrad));
566 /* run outer section */
567 for (i = 1; i <= 2*mg_nqcdivs; i++) {
568 theta = i*(PI/2)/mg_nqcdivs;
569 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
570 return(rval);
571 for (j = 0; j < 3; j++)
572 sprintf(p2[j], FLTFMT, cv->p[j] +
573 .5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]);
574 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
575 return(rval);
576 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
577 return(rval);
578 strcpy(r1, r2);
579 sprintf(r2, FLTFMT, avgrad + .5*(maxrad-minrad)*sin(theta));
580 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
581 return(rval);
582 }
583 /* run inner section */
584 sprintf(r2, FLTFMT, -.5*(minrad+maxrad));
585 for ( ; i <= 4*mg_nqcdivs; i++) {
586 theta = i*(PI/2)/mg_nqcdivs;
587 for (j = 0; j < 3; j++)
588 sprintf(p2[j], FLTFMT, cv->p[j] +
589 .5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]);
590 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
591 return(rval);
592 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
593 return(rval);
594 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
595 return(rval);
596 strcpy(r1, r2);
597 sprintf(r2, FLTFMT, -avgrad - .5*(maxrad-minrad)*sin(theta));
598 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
599 return(rval);
600 }
601 warpconends = 0;
602 return(MG_OK);
603 }
604
605
606 static int
607 e_cyl(ac, av) /* replace a cylinder with equivalent cone */
608 int ac;
609 char **av;
610 {
611 static char *avnew[6] = {mg_ename[MG_E_CONE]};
612
613 if (ac != 4)
614 return(MG_EARGC);
615 avnew[1] = av[1];
616 avnew[2] = av[2];
617 avnew[3] = av[3];
618 avnew[4] = av[2];
619 return(mg_handle(MG_E_CONE, 5, avnew));
620 }
621
622
623 static int
624 e_ring(ac, av) /* turn a ring into polygons */
625 int ac;
626 char **av;
627 {
628 static char p3[3][24], p4[3][24];
629 static char *nzent[5] = {mg_ename[MG_E_NORMAL],"0","0","0"};
630 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_rv1","="};
631 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_rv2","=","_rv3"};
632 static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_rv3","="};
633 static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]};
634 static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_rv4","="};
635 static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]};
636 static char *fent[6] = {mg_ename[MG_E_FACE],"_rv1","_rv2","_rv3","_rv4"};
637 register C_VERTEX *cv;
638 register int i, j;
639 FVECT u, v;
640 double minrad, maxrad;
641 int rv;
642 double theta, d;
643
644 if (ac != 4)
645 return(MG_EARGC);
646 if ((cv = c_getvert(av[1])) == NULL)
647 return(MG_EUNDEF);
648 if (is0vect(cv->n))
649 return(MG_EILL);
650 if (!isflt(av[2]) || !isflt(av[3]))
651 return(MG_ETYPE);
652 minrad = atof(av[2]);
653 round0(minrad);
654 maxrad = atof(av[3]);
655 if (minrad < 0. || maxrad <= minrad)
656 return(MG_EILL);
657 /* initialize */
658 make_axes(u, v, cv->n);
659 for (j = 0; j < 3; j++)
660 sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*u[j]);
661 if ((rv = mg_handle(MG_E_VERTEX, 3, v3ent)) != MG_OK)
662 return(rv);
663 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
664 return(rv);
665 if (minrad == 0.) { /* closed */
666 v1ent[3] = av[1];
667 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
668 return(rv);
669 if ((rv = mg_handle(MG_E_NORMAL, 4, nzent)) != MG_OK)
670 return(rv);
671 for (i = 1; i <= 4*mg_nqcdivs; i++) {
672 theta = i*(PI/2)/mg_nqcdivs;
673 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
674 return(rv);
675 for (j = 0; j < 3; j++)
676 sprintf(p3[j], FLTFMT, cv->p[j] +
677 maxrad*u[j]*cos(theta) +
678 maxrad*v[j]*sin(theta));
679 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
680 return(rv);
681 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
682 return(rv);
683 if ((rv = mg_handle(MG_E_FACE, 4, fent)) != MG_OK)
684 return(rv);
685 }
686 } else { /* open */
687 if ((rv = mg_handle(MG_E_VERTEX, 3, v4ent)) != MG_OK)
688 return(rv);
689 for (j = 0; j < 3; j++)
690 sprintf(p4[j], FLTFMT, cv->p[j] + minrad*u[j]);
691 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
692 return(rv);
693 v1ent[3] = "_rv4";
694 for (i = 1; i <= 4*mg_nqcdivs; i++) {
695 theta = i*(PI/2)/mg_nqcdivs;
696 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
697 return(rv);
698 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
699 return(rv);
700 for (j = 0; j < 3; j++) {
701 d = u[j]*cos(theta) + v[j]*sin(theta);
702 sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*d);
703 sprintf(p4[j], FLTFMT, cv->p[j] + minrad*d);
704 }
705 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
706 return(rv);
707 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
708 return(rv);
709 if ((rv = mg_handle(MG_E_VERTEX, 2, v4ent)) != MG_OK)
710 return(rv);
711 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
712 return(rv);
713 if ((rv = mg_handle(MG_E_FACE, 5, fent)) != MG_OK)
714 return(rv);
715 }
716 }
717 return(MG_OK);
718 }
719
720
721 static int
722 e_cone(ac, av) /* turn a cone into polygons */
723 int ac;
724 char **av;
725 {
726 static char p3[3][24], p4[3][24], n3[3][24], n4[3][24];
727 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_cv1","="};
728 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_cv2","=","_cv3"};
729 static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_cv3","="};
730 static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]};
731 static char *n3ent[5] = {mg_ename[MG_E_NORMAL],n3[0],n3[1],n3[2]};
732 static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_cv4","="};
733 static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]};
734 static char *n4ent[5] = {mg_ename[MG_E_NORMAL],n4[0],n4[1],n4[2]};
735 static char *fent[6] = {mg_ename[MG_E_FACE],"_cv1","_cv2","_cv3","_cv4"};
736 char *v1n;
737 register C_VERTEX *cv1, *cv2;
738 register int i, j;
739 FVECT u, v, w;
740 double rad1, rad2;
741 int sgn;
742 double n1off, n2off;
743 double d;
744 int rv;
745 double theta;
746
747 if (ac != 5)
748 return(MG_EARGC);
749 if ((cv1 = c_getvert(av[1])) == NULL ||
750 (cv2 = c_getvert(av[3])) == NULL)
751 return(MG_EUNDEF);
752 v1n = av[1];
753 if (!isflt(av[2]) || !isflt(av[4]))
754 return(MG_ETYPE);
755 rad1 = atof(av[2]);
756 round0(rad1);
757 rad2 = atof(av[4]);
758 round0(rad2);
759 if (rad1 == 0.) {
760 if (rad2 == 0.)
761 return(MG_EILL);
762 } else if (rad2 != 0.) {
763 if (rad1 < 0. ^ rad2 < 0.)
764 return(MG_EILL);
765 } else { /* swap */
766 C_VERTEX *cv;
767
768 cv = cv1;
769 cv1 = cv2;
770 cv2 = cv;
771 v1n = av[3];
772 d = rad1;
773 rad1 = rad2;
774 rad2 = d;
775 }
776 sgn = rad2 < 0. ? -1 : 1;
777 /* initialize */
778 for (j = 0; j < 3; j++)
779 w[j] = cv1->p[j] - cv2->p[j];
780 if ((d = normalize(w)) == 0.)
781 return(MG_EILL);
782 n1off = n2off = (rad2 - rad1)/d;
783 if (warpconends) { /* hack for e_sph and e_torus */
784 d = atan(n2off) - (PI/4)/mg_nqcdivs;
785 if (d <= -PI/2+FTINY)
786 n2off = -FHUGE;
787 else
788 n2off = tan(d);
789 }
790 make_axes(u, v, w);
791 for (j = 0; j < 3; j++) {
792 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*u[j]);
793 if (n2off <= -FHUGE)
794 sprintf(n3[j], FLTFMT, -w[j]);
795 else
796 sprintf(n3[j], FLTFMT, u[j] + w[j]*n2off);
797 }
798 if ((rv = mg_handle(MG_E_VERTEX, 3, v3ent)) != MG_OK)
799 return(rv);
800 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
801 return(rv);
802 if ((rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
803 return(rv);
804 if (rad1 == 0.) { /* triangles */
805 v1ent[3] = v1n;
806 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
807 return(rv);
808 for (j = 0; j < 3; j++)
809 sprintf(n4[j], FLTFMT, w[j]);
810 if ((rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
811 return(rv);
812 for (i = 1; i <= 4*mg_nqcdivs; i++) {
813 theta = sgn*i*(PI/2)/mg_nqcdivs;
814 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
815 return(rv);
816 for (j = 0; j < 3; j++) {
817 d = u[j]*cos(theta) + v[j]*sin(theta);
818 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d);
819 if (n2off > -FHUGE)
820 sprintf(n3[j], FLTFMT, d + w[j]*n2off);
821 }
822 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
823 return(rv);
824 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
825 return(rv);
826 if (n2off > -FHUGE &&
827 (rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
828 return(rv);
829 if ((rv = mg_handle(MG_E_FACE, 4, fent)) != MG_OK)
830 return(rv);
831 }
832 } else { /* quads */
833 v1ent[3] = "_cv4";
834 if (warpconends) { /* hack for e_sph and e_torus */
835 d = atan(n1off) + (PI/4)/mg_nqcdivs;
836 if (d >= PI/2-FTINY)
837 n1off = FHUGE;
838 else
839 n1off = tan(atan(n1off)+(PI/4)/mg_nqcdivs);
840 }
841 for (j = 0; j < 3; j++) {
842 sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*u[j]);
843 if (n1off >= FHUGE)
844 sprintf(n4[j], FLTFMT, w[j]);
845 else
846 sprintf(n4[j], FLTFMT, u[j] + w[j]*n1off);
847 }
848 if ((rv = mg_handle(MG_E_VERTEX, 3, v4ent)) != MG_OK)
849 return(rv);
850 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
851 return(rv);
852 if ((rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
853 return(rv);
854 for (i = 1; i <= 4*mg_nqcdivs; i++) {
855 theta = sgn*i*(PI/2)/mg_nqcdivs;
856 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
857 return(rv);
858 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
859 return(rv);
860 for (j = 0; j < 3; j++) {
861 d = u[j]*cos(theta) + v[j]*sin(theta);
862 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d);
863 if (n2off > -FHUGE)
864 sprintf(n3[j], FLTFMT, d + w[j]*n2off);
865 sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*d);
866 if (n1off < FHUGE)
867 sprintf(n4[j], FLTFMT, d + w[j]*n1off);
868 }
869 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
870 return(rv);
871 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
872 return(rv);
873 if (n2off > -FHUGE &&
874 (rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
875 return(rv);
876 if ((rv = mg_handle(MG_E_VERTEX, 2, v4ent)) != MG_OK)
877 return(rv);
878 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
879 return(rv);
880 if (n1off < FHUGE &&
881 (rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
882 return(rv);
883 if ((rv = mg_handle(MG_E_FACE, 5, fent)) != MG_OK)
884 return(rv);
885 }
886 }
887 return(MG_OK);
888 }
889
890
891 static int
892 e_prism(ac, av) /* turn a prism into polygons */
893 int ac;
894 char **av;
895 {
896 static char p[3][24];
897 static char *vent[5] = {mg_ename[MG_E_VERTEX],NULL,"="};
898 static char *pent[5] = {mg_ename[MG_E_POINT],p[0],p[1],p[2]};
899 static char *znorm[5] = {mg_ename[MG_E_NORMAL],"0","0","0"};
900 char *newav[MG_MAXARGC], nvn[MG_MAXARGC-1][8];
901 double length;
902 int hasnorm;
903 FVECT v1, v2, v3, norm;
904 register C_VERTEX *cv;
905 C_VERTEX *cv0;
906 int rv;
907 register int i, j;
908 /* check arguments */
909 if (ac < 5)
910 return(MG_EARGC);
911 if (!isflt(av[ac-1]))
912 return(MG_ETYPE);
913 length = atof(av[ac-1]);
914 if (length <= FTINY && length >= -FTINY)
915 return(MG_EILL);
916 /* compute face normal */
917 if ((cv0 = c_getvert(av[1])) == NULL)
918 return(MG_EUNDEF);
919 hasnorm = 0;
920 norm[0] = norm[1] = norm[2] = 0.;
921 v1[0] = v1[1] = v1[2] = 0.;
922 for (i = 2; i < ac-1; i++) {
923 if ((cv = c_getvert(av[i])) == NULL)
924 return(MG_EUNDEF);
925 hasnorm += !is0vect(cv->n);
926 v2[0] = cv->p[0] - cv0->p[0];
927 v2[1] = cv->p[1] - cv0->p[1];
928 v2[2] = cv->p[2] - cv0->p[2];
929 fcross(v3, v1, v2);
930 norm[0] += v3[0];
931 norm[1] += v3[1];
932 norm[2] += v3[2];
933 VCOPY(v1, v2);
934 }
935 if (normalize(norm) == 0.)
936 return(MG_EILL);
937 /* create moved vertices */
938 for (i = 1; i < ac-1; i++) {
939 sprintf(nvn[i-1], "_pv%d", i);
940 vent[1] = nvn[i-1];
941 vent[3] = av[i];
942 if ((rv = mg_handle(MG_E_VERTEX, 4, vent)) != MG_OK)
943 return(rv);
944 cv = c_getvert(av[i]); /* checked above */
945 for (j = 0; j < 3; j++)
946 sprintf(p[j], FLTFMT, cv->p[j] - length*norm[j]);
947 if ((rv = mg_handle(MG_E_POINT, 4, pent)) != MG_OK)
948 return(rv);
949 }
950 /* make faces */
951 newav[0] = mg_ename[MG_E_FACE];
952 /* do the side faces */
953 newav[5] = NULL;
954 newav[3] = av[ac-2];
955 newav[4] = nvn[ac-3];
956 for (i = 1; i < ac-1; i++) {
957 newav[1] = nvn[i-1];
958 newav[2] = av[i];
959 if ((rv = mg_handle(MG_E_FACE, 5, newav)) != MG_OK)
960 return(rv);
961 newav[3] = newav[2];
962 newav[4] = newav[1];
963 }
964 /* do top face */
965 for (i = 1; i < ac-1; i++) {
966 if (hasnorm) { /* zero normals */
967 vent[1] = nvn[i-1];
968 if ((rv = mg_handle(MG_E_VERTEX, 2, vent)) != MG_OK)
969 return(rv);
970 if ((rv = mg_handle(MG_E_NORMAL, 4, znorm)) != MG_OK)
971 return(rv);
972 }
973 newav[ac-1-i] = nvn[i-1]; /* reverse */
974 }
975 if ((rv = mg_handle(MG_E_FACE, ac-1, newav)) != MG_OK)
976 return(rv);
977 /* do bottom face */
978 if (hasnorm)
979 for (i = 1; i < ac-1; i++) {
980 vent[1] = nvn[i-1];
981 vent[3] = av[i];
982 if ((rv = mg_handle(MG_E_VERTEX, 4, vent)) != MG_OK)
983 return(rv);
984 if ((rv = mg_handle(MG_E_NORMAL, 4, znorm)) != MG_OK)
985 return(rv);
986 newav[i] = nvn[i-1];
987 }
988 else
989 for (i = 1; i < ac-1; i++)
990 newav[i] = av[i];
991 newav[i] = NULL;
992 if ((rv = mg_handle(MG_E_FACE, i, newav)) != MG_OK)
993 return(rv);
994 return(MG_OK);
995 }
996
997
998 static int
999 put_cxy() /* put out current xy chromaticities */
1000 {
1001 static char xbuf[24], ybuf[24];
1002 static char *ccom[4] = {mg_ename[MG_E_CXY], xbuf, ybuf};
1003 int rv;
1004
1005 sprintf(xbuf, "%.4f", c_ccolor->cx);
1006 sprintf(ybuf, "%.4f", c_ccolor->cy);
1007 if ((rv = mg_handle(MG_E_CXY, 3, ccom)) != MG_OK)
1008 return(rv);
1009 return(MG_OK);
1010 }
1011
1012
1013 static int
1014 put_cspec() /* put out current color spectrum */
1015 {
1016 char wl[2][6], vbuf[C_CNSS][24];
1017 char *newav[C_CNSS+4];
1018 double sf;
1019 register int i;
1020
1021 if (mg_ehand[MG_E_CSPEC] != c_hcolor) {
1022 sprintf(wl[0], "%d", C_CMINWL);
1023 sprintf(wl[1], "%d", C_CMAXWL);
1024 newav[0] = mg_ename[MG_E_CSPEC];
1025 newav[1] = wl[0];
1026 newav[2] = wl[1];
1027 sf = (double)C_CNSS / c_ccolor->ssum;
1028 for (i = 0; i < C_CNSS; i++) {
1029 sprintf(vbuf[i], "%.4f", sf*c_ccolor->ssamp[i]);
1030 newav[i+3] = vbuf[i];
1031 }
1032 newav[C_CNSS+3] = NULL;
1033 if ((i = mg_handle(MG_E_CSPEC, C_CNSS+3, newav)) != MG_OK)
1034 return(i);
1035 }
1036 return(MG_OK);
1037 }
1038
1039
1040 static int
1041 e_cspec(ac, av) /* handle spectral color */
1042 int ac;
1043 char **av;
1044 {
1045 /* convert to xy chromaticity */
1046 c_ccvt(c_ccolor, C_CSXY);
1047 /* if it's really their handler, use it */
1048 if (mg_ehand[MG_E_CXY] != c_hcolor)
1049 return(put_cxy());
1050 return(MG_OK);
1051 }
1052
1053
1054 static int
1055 e_cmix(ac, av) /* handle mixing of colors */
1056 int ac;
1057 char **av;
1058 {
1059 /*
1060 * Contorted logic works as follows:
1061 * 1. the colors are already mixed in c_hcolor() support function
1062 * 2. if we would handle a spectral result, make sure it's not
1063 * 3. if c_hcolor() would handle a spectral result, don't bother
1064 * 4. otherwise, make cspec entity and pass it to their handler
1065 * 5. if we have only xy results, handle it as c_spec() would
1066 */
1067 if (mg_ehand[MG_E_CSPEC] == e_cspec)
1068 c_ccvt(c_ccolor, C_CSXY);
1069 else if (c_ccolor->flags & C_CDSPEC)
1070 return(put_cspec());
1071 if (mg_ehand[MG_E_CXY] != c_hcolor)
1072 return(put_cxy());
1073 return(MG_OK);
1074 }
1075
1076
1077 static int
1078 e_cct(ac, av) /* handle color temperature */
1079 int ac;
1080 char **av;
1081 {
1082 /*
1083 * Logic is similar to e_cmix here. Support handler has already
1084 * converted temperature to spectral color. Put it out as such
1085 * if they support it, otherwise convert to xy chromaticity and
1086 * put it out if they handle it.
1087 */
1088 if (mg_ehand[MG_E_CSPEC] != e_cspec)
1089 return(put_cspec());
1090 c_ccvt(c_ccolor, C_CSXY);
1091 if (mg_ehand[MG_E_CXY] != c_hcolor)
1092 return(put_cxy());
1093 return(MG_OK);
1094 }
