1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Parse an MGF file, converting or discarding unsupported entities |
9 |
10 |
11 |
#include <stdio.h> |
12 |
#include <math.h> |
13 |
#include <ctype.h> |
14 |
#include <string.h> |
15 |
#include "parser.h" |
16 |
#include "lookup.h" |
17 |
#include "messages.h" |
18 |
19 |
20 |
* Global definitions of variables declared in parser.h |
21 |
22 |
/* entity names */ |
23 |
24 |
char mg_ename[MG_NENTITIES][MG_MAXELEN] = MG_NAMELIST; |
25 |
26 |
/* Handler routines for each entity */ |
27 |
28 |
int (*mg_ehand[MG_NENTITIES])(); |
29 |
30 |
/* error messages */ |
31 |
32 |
char *mg_err[MG_NERRS] = MG_ERRLIST; |
33 |
34 |
MG_FCTXT *mg_file; /* current file context pointer */ |
35 |
36 |
int mg_nqcdivs = MG_NQCD; /* number of divisions per quarter circle */ |
37 |
38 |
39 |
* The idea with this parser is to compensate for any missing entries in |
40 |
* mg_ehand with alternate handlers that express these entities in terms |
41 |
* of others that the calling program can handle. |
42 |
43 |
* In some cases, no alternate handler is possible because the entity |
44 |
* has no approximate equivalent. These entities are simply discarded. |
45 |
46 |
* Certain entities are dependent on others, and mg_init() will fail |
47 |
* if the supported entities are not consistent. |
48 |
49 |
* Some alternate entity handlers require that earlier entities be |
50 |
* noted in some fashion, and we therefore keep another array of |
51 |
* parallel support handlers to assist in this effort. |
52 |
53 |
54 |
/* temporary settings for testing */ |
55 |
#define e_ies e_any_toss |
56 |
#define e_cmix e_any_toss |
57 |
#define e_cspec e_any_toss |
58 |
/* alternate handler routines */ |
59 |
60 |
static int e_any_toss(), /* discard unneeded entity */ |
61 |
e_ies(), /* IES luminaire file */ |
62 |
e_include(), /* include file */ |
63 |
e_sph(), /* sphere */ |
64 |
e_cmix(), /* color mixtures */ |
65 |
e_cspec(); /* color spectra */ |
66 |
e_cyl(), /* cylinder */ |
67 |
e_cone(), /* cone */ |
68 |
e_prism(), /* prism */ |
69 |
e_ring(), /* ring */ |
70 |
e_torus(); /* torus */ |
71 |
72 |
/* alternate handler support functions */ |
73 |
74 |
static int (*e_supp[MG_NENTITIES])(); |
75 |
76 |
static char FLTFMT[] = "%.12g"; |
77 |
78 |
static int warpconends; /* hack for generating good normals */ |
79 |
80 |
81 |
void |
82 |
mg_init() /* initialize alternate entity handlers */ |
83 |
84 |
unsigned long ineed = 0, uneed = 0; |
85 |
register int i; |
86 |
/* pick up slack */ |
87 |
if (mg_ehand[MG_E_IES] == NULL) |
88 |
mg_ehand[MG_E_IES] = e_ies; |
89 |
if (mg_ehand[MG_E_INCLUDE] == NULL) |
90 |
mg_ehand[MG_E_INCLUDE] = e_include; |
91 |
if (mg_ehand[MG_E_SPH] == NULL) { |
92 |
mg_ehand[MG_E_SPH] = e_sph; |
93 |
ineed |= 1<<MG_E_POINT|1<<MG_E_VERTEX; |
94 |
} else |
95 |
uneed |= 1<<MG_E_POINT|1<<MG_E_VERTEX|1<<MG_E_XF; |
96 |
if (mg_ehand[MG_E_CYL] == NULL) { |
97 |
mg_ehand[MG_E_CYL] = e_cyl; |
98 |
99 |
} else |
100 |
101 |
if (mg_ehand[MG_E_CONE] == NULL) { |
102 |
mg_ehand[MG_E_CONE] = e_cone; |
103 |
104 |
} else |
105 |
106 |
if (mg_ehand[MG_E_RING] == NULL) { |
107 |
mg_ehand[MG_E_RING] = e_ring; |
108 |
ineed |= 1<<MG_E_POINT|1<<MG_E_NORMAL|1<<MG_E_VERTEX; |
109 |
} else |
110 |
uneed |= 1<<MG_E_POINT|1<<MG_E_NORMAL|1<<MG_E_VERTEX|1<<MG_E_XF; |
111 |
if (mg_ehand[MG_E_PRISM] == NULL) { |
112 |
mg_ehand[MG_E_PRISM] = e_prism; |
113 |
114 |
} else |
115 |
116 |
if (mg_ehand[MG_E_TORUS] == NULL) { |
117 |
mg_ehand[MG_E_TORUS] = e_torus; |
118 |
119 |
} else |
120 |
121 |
if (mg_ehand[MG_E_COLOR] != NULL) { |
122 |
if (mg_ehand[MG_E_CMIX] == NULL) |
123 |
mg_ehand[MG_E_CMIX] = e_cmix; |
124 |
if (mg_ehand[MG_E_CSPEC] == NULL) |
125 |
mg_ehand[MG_E_CSPEC] = e_cspec; |
126 |
127 |
/* check for consistency */ |
128 |
if (mg_ehand[MG_E_FACE] != NULL) |
129 |
130 |
if (mg_ehand[MG_E_CXY] != NULL) |
131 |
uneed |= 1<<MG_E_COLOR; |
132 |
if (mg_ehand[MG_E_RD] != NULL || mg_ehand[MG_E_TD] != NULL || |
133 |
mg_ehand[MG_E_ED] != NULL || |
134 |
mg_ehand[MG_E_RS] != NULL || |
135 |
mg_ehand[MG_E_TS] != NULL) |
136 |
uneed |= 1<<MG_E_MATERIAL; |
137 |
for (i = 0; i < MG_NENTITIES; i++) |
138 |
if (uneed & 1<<i && mg_ehand[i] == NULL) { |
139 |
fprintf(stderr, "Missing support for \"%s\" entity\n", |
140 |
mg_ename[i]); |
141 |
exit(1); |
142 |
143 |
/* add support as needed */ |
144 |
if (ineed & 1<<MG_E_VERTEX && mg_ehand[MG_E_VERTEX] != c_hvertex) |
145 |
e_supp[MG_E_VERTEX] = c_hvertex; |
146 |
if (ineed & 1<<MG_E_POINT && mg_ehand[MG_E_POINT] != c_hvertex) |
147 |
e_supp[MG_E_POINT] = c_hvertex; |
148 |
if (ineed & 1<<MG_E_NORMAL && mg_ehand[MG_E_NORMAL] != c_hvertex) |
149 |
e_supp[MG_E_NORMAL] = c_hvertex; |
150 |
/* discard remaining entities */ |
151 |
152 |
if (mg_ehand[i] == NULL) |
153 |
mg_ehand[i] = e_any_toss; |
154 |
155 |
156 |
157 |
158 |
int |
159 |
mg_entity(name) /* get entity number from its name */ |
160 |
char *name; |
161 |
162 |
static LUTAB ent_tab; /* entity lookup table */ |
163 |
register char *cp; |
164 |
165 |
if (!ent_tab.tsiz) { /* initialize hash table */ |
166 |
if (!lu_init(&ent_tab, MG_NENTITIES)) |
167 |
return(-1); /* what to do? */ |
168 |
for (cp = mg_ename[MG_NENTITIES-1]; cp >= mg_ename[0]; |
169 |
cp -= sizeof(mg_ename[0])) |
170 |
lu_find(&ent_tab, cp)->key = cp; |
171 |
172 |
cp = lu_find(&ent_tab, name)->key; |
173 |
if (cp == NULL) |
174 |
return(-1); |
175 |
return((cp - mg_ename[0])/sizeof(mg_ename[0])); |
176 |
177 |
178 |
179 |
static int |
180 |
handle_it(en, ac, av) /* pass entity to appropriate handler */ |
181 |
register int en; |
182 |
int ac; |
183 |
char **av; |
184 |
185 |
int rv; |
186 |
187 |
if (en < 0 && (en = mg_entity(av[0])) < 0) |
188 |
return(MG_EUNK); |
189 |
if (e_supp[en] != NULL) { |
190 |
if ((rv = (*e_supp[en])(ac, av)) != MG_OK) |
191 |
return(rv); |
192 |
193 |
return((*mg_ehand[en])(ac, av)); |
194 |
195 |
196 |
197 |
int |
198 |
mg_open(ctx, fn) /* open new input file */ |
199 |
register MG_FCTXT *ctx; |
200 |
char *fn; |
201 |
202 |
int olen; |
203 |
204 |
205 |
ctx->lineno = 0; |
206 |
if (fn == NULL) { |
207 |
ctx->fname = "<stdin>"; |
208 |
ctx->fp = stdin; |
209 |
ctx->prev = mg_file; |
210 |
mg_file = ctx; |
211 |
return(MG_OK); |
212 |
213 |
/* get name relative to this context */ |
214 |
if (mg_file != NULL && |
215 |
(cp = strrchr(mg_file->fname, '/')) != NULL) |
216 |
olen = cp - mg_file->fname + 1; |
217 |
else |
218 |
olen = 0; |
219 |
ctx->fname = (char *)malloc(olen+strlen(fn)+1); |
220 |
if (ctx->fname == NULL) |
221 |
return(MG_EMEM); |
222 |
if (olen) |
223 |
strcpy(ctx->fname, mg_file->fname); |
224 |
strcpy(ctx->fname+olen, fn); |
225 |
ctx->fp = fopen(ctx->fname, "r"); |
226 |
if (ctx->fp == NULL) { |
227 |
free((MEM_PTR)ctx->fname); |
228 |
return(MG_ENOFILE); |
229 |
230 |
ctx->prev = mg_file; /* establish new context */ |
231 |
mg_file = ctx; |
232 |
return(MG_OK); |
233 |
234 |
235 |
236 |
void |
237 |
mg_close() /* close input file */ |
238 |
239 |
register MG_FCTXT *ctx = mg_file; |
240 |
241 |
mg_file = ctx->prev; /* restore enclosing context */ |
242 |
if (ctx->fp == stdin) |
243 |
return; /* don't close standard input */ |
244 |
fclose(ctx->fp); |
245 |
246 |
247 |
248 |
249 |
int |
250 |
mg_rewind() /* rewind input file */ |
251 |
252 |
if (mg_file->lineno == 0) |
253 |
return(MG_OK); |
254 |
if (mg_file->fp == stdin) |
255 |
return(MG_ESEEK); /* cannot seek on standard input */ |
256 |
if (fseek(mg_file->fp, 0L, 0) == EOF) |
257 |
return(MG_ESEEK); |
258 |
mg_file->lineno = 0; |
259 |
return(MG_OK); |
260 |
261 |
262 |
263 |
int |
264 |
mg_read() /* read next line from file */ |
265 |
266 |
register int len = 0; |
267 |
268 |
do { |
269 |
if (fgets(mg_file->inpline+len, |
270 |
MG_MAXLINE-len, mg_file->fp) == NULL) |
271 |
return(len); |
272 |
mg_file->lineno++; |
273 |
len += strlen(mg_file->inpline+len); |
274 |
if (len > 1 && mg_file->inpline[len-2] == '\\') |
275 |
mg_file->inpline[--len-1] = ' '; |
276 |
} while (mg_file->inpline[len]); |
277 |
278 |
return(len); |
279 |
280 |
281 |
282 |
int |
283 |
mg_parse() /* parse current input line */ |
284 |
285 |
char abuf[MG_MAXLINE]; |
286 |
char *argv[MG_MAXARGC]; |
287 |
int en; |
288 |
register char *cp, **ap; |
289 |
290 |
strcpy(cp=abuf, mg_file->inpline); |
291 |
ap = argv; /* break into words */ |
292 |
for ( ; ; ) { |
293 |
while (isspace(*cp)) |
294 |
*cp++ = '\0'; |
295 |
if (!*cp) |
296 |
break; |
297 |
if (ap - argv >= MG_MAXARGC-1) |
298 |
return(MG_EARGC); |
299 |
*ap++ = cp; |
300 |
while (*++cp && !isspace(*cp)) |
301 |
302 |
303 |
if (ap == argv) |
304 |
return(MG_OK); /* no words in line */ |
305 |
*ap = NULL; |
306 |
/* else handle it */ |
307 |
return(handle_it(-1, ap-argv, argv)); |
308 |
309 |
310 |
311 |
int |
312 |
mg_load(fn) /* load an MGF file */ |
313 |
char *fn; |
314 |
315 |
MG_FCTXT cntxt; |
316 |
int rval; |
317 |
318 |
if ((rval = mg_open(&cntxt, fn)) != MG_OK) { |
319 |
fprintf(stderr, "%s: %s\n", fn, mg_err[rval]); |
320 |
return(rval); |
321 |
322 |
while (mg_read()) /* parse each line */ |
323 |
if ((rval = mg_parse()) != MG_OK) { |
324 |
fprintf(stderr, "%s: %d: %s:\n%s", cntxt.fname, |
325 |
cntxt.lineno, mg_err[rval], |
326 |
cntxt.inpline); |
327 |
break; |
328 |
329 |
mg_close(); |
330 |
return(rval); |
331 |
332 |
333 |
334 |
void |
335 |
mg_clear() /* clear parser history */ |
336 |
337 |
c_clearall(); /* clear context tables */ |
338 |
mg_file = NULL; /* reset our context */ |
339 |
340 |
341 |
342 |
int |
343 |
mg_iterate(ac, av, f) /* iterate on statement */ |
344 |
int ac; |
345 |
register char **av; |
346 |
int (*f)(); |
347 |
348 |
int niter, rval; |
349 |
register int i, j; |
350 |
351 |
char cntbuf[10]; |
352 |
/* build partial transformation */ |
353 |
for (i = 0; i < ac; i++) { |
354 |
if (av[i][0] == '-' && av[i][1] == 'a' && av[i][2] == '\0') |
355 |
break; |
356 |
argv[i+1] = av[i]; |
357 |
358 |
argv[i+1] = NULL; |
359 |
if (i) { /* handle transformation */ |
360 |
argv[0] = mg_ename[MG_E_XF]; |
361 |
if ((rval = handle_it(MG_E_XF, i+1, argv)) != MG_OK) |
362 |
return(rval); |
363 |
364 |
if (i < ac) { /* run array */ |
365 |
if (i+1 >= ac || !isint(av[i+1])) |
366 |
return(MG_ETYPE); |
367 |
niter = atoi(av[i+1]); |
368 |
argv[0] = mg_ename[MG_E_OBJECT]; |
369 |
argv[1] = cntbuf; |
370 |
for (j = 2; j+i < ac; j++) |
371 |
argv[j] = av[j+i]; |
372 |
argv[j] = NULL; |
373 |
for (j = 0; j < niter; j++) { |
374 |
sprintf(cntbuf, "%d", j); |
375 |
if ((rval = handle_it(MG_E_OBJECT, 2, argv)) != MG_OK) |
376 |
return(rval); |
377 |
argv[0] = "-i"; |
378 |
if ((rval = mg_iterate(ac-i, argv, f)) != MG_OK) |
379 |
return(rval); |
380 |
381 |
if ((rval = handle_it(MG_E_OBJECT, 1, argv)) != MG_OK) |
382 |
return(rval); |
383 |
384 |
} else if ((rval = (*f)()) != MG_OK) /* else do this instance */ |
385 |
return(rval); |
386 |
if (i) { /* reset the transform */ |
387 |
388 |
argv[1] = NULL; |
389 |
(void)handle_it(MG_E_XF, 1, argv); |
390 |
391 |
return(MG_OK); |
392 |
393 |
394 |
395 |
396 |
* The following routines handle unsupported entities |
397 |
398 |
399 |
400 |
static int |
401 |
e_any_toss(ac, av) /* discard an unwanted entity */ |
402 |
int ac; |
403 |
char **av; |
404 |
405 |
return(MG_OK); |
406 |
407 |
408 |
409 |
static int |
410 |
reload_file() /* reload current MGF file */ |
411 |
412 |
register int rval; |
413 |
414 |
if ((rval = mg_rewind()) != MG_OK) |
415 |
return(rval); |
416 |
while (mg_read()) |
417 |
if ((rval = mg_parse()) != MG_OK) |
418 |
return(rval); |
419 |
return(MG_OK); |
420 |
421 |
422 |
423 |
static int |
424 |
e_include(ac, av) /* include file */ |
425 |
int ac; |
426 |
char **av; |
427 |
428 |
MG_FCTXT ictx; |
429 |
int rv; |
430 |
431 |
if (ac < 2) |
432 |
return(MG_EARGC); |
433 |
if ((rv = mg_open(&ictx, av[1])) != MG_OK) |
434 |
return(rv); |
435 |
if ((rv = mg_iterate(ac-2, av+2, reload_file)) != MG_OK) { |
436 |
fprintf(stderr, "%s: %d: %s:\n%s", ictx.fname, |
437 |
ictx.lineno, mg_err[rv], ictx.inpline); |
438 |
mg_close(); |
439 |
return(MG_EINCL); |
440 |
441 |
mg_close(); |
442 |
return(MG_OK); |
443 |
444 |
445 |
446 |
static void |
447 |
make_axes(u, v, w) /* compute u and v given w (normalized) */ |
448 |
FVECT u, v, w; |
449 |
450 |
register int i; |
451 |
452 |
v[0] = v[1] = v[2] = 0.; |
453 |
for (i = 0; i < 3; i++) |
454 |
if (w[i] < .6 && w[i] > -.6) |
455 |
break; |
456 |
v[i] = 1.; |
457 |
fcross(u, v, w); |
458 |
normalize(u); |
459 |
fcross(v, w, u); |
460 |
461 |
462 |
463 |
static int |
464 |
e_sph(ac, av) /* expand a sphere into cones */ |
465 |
int ac; |
466 |
char **av; |
467 |
468 |
static char p2x[24], p2y[24], p2z[24], r1[24], r2[24]; |
469 |
static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_sv1","=","_sv2"}; |
470 |
static char *v2ent[4] = {mg_ename[MG_E_VERTEX],"_sv2","="}; |
471 |
static char *p2ent[5] = {mg_ename[MG_E_POINT],p2x,p2y,p2z}; |
472 |
static char *conent[6] = {mg_ename[MG_E_CONE],"_sv1",r1,"_sv2",r2}; |
473 |
register C_VERTEX *cv; |
474 |
register int i; |
475 |
int rval; |
476 |
double rad; |
477 |
double theta; |
478 |
479 |
if (ac != 3) |
480 |
return(MG_EARGC); |
481 |
if ((cv = c_getvert(av[1])) == NULL) |
482 |
return(MG_EUNDEF); |
483 |
if (!isflt(av[2])) |
484 |
return(MG_ETYPE); |
485 |
rad = atof(av[2]); |
486 |
/* initialize */ |
487 |
warpconends = 1; |
488 |
if ((rval = handle_it(MG_E_VERTEX, 3, v2ent)) != MG_OK) |
489 |
return(rval); |
490 |
sprintf(p2x, FLTFMT, cv->p[0]); |
491 |
sprintf(p2y, FLTFMT, cv->p[1]); |
492 |
sprintf(p2z, FLTFMT, cv->p[2]+rad); |
493 |
if ((rval = handle_it(MG_E_POINT, 4, p2ent)) != MG_OK) |
494 |
return(rval); |
495 |
r2[0] = '0'; r2[1] = '\0'; |
496 |
for (i = 1; i <= 2*mg_nqcdivs; i++) { |
497 |
theta = i*(PI/2)/mg_nqcdivs; |
498 |
if ((rval = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK) |
499 |
return(rval); |
500 |
sprintf(p2z, FLTFMT, cv->p[2]+rad*cos(theta)); |
501 |
if ((rval = handle_it(MG_E_VERTEX, 2, v2ent)) != MG_OK) |
502 |
return(rval); |
503 |
504 |
return(rval); |
505 |
strcpy(r1, r2); |
506 |
sprintf(r2, FLTFMT, rad*sin(theta)); |
507 |
if ((rval = handle_it(MG_E_CONE, 5, conent)) != MG_OK) |
508 |
return(rval); |
509 |
510 |
warpconends = 0; |
511 |
return(MG_OK); |
512 |
513 |
514 |
515 |
static int |
516 |
e_torus(ac, av) /* expand a torus into cones */ |
517 |
int ac; |
518 |
char **av; |
519 |
520 |
static char p2[3][24], r1[24], r2[24]; |
521 |
static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_tv1","=","_tv2"}; |
522 |
static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_tv2","="}; |
523 |
static char *p2ent[5] = {mg_ename[MG_E_POINT],p2[0],p2[1],p2[2]}; |
524 |
static char *conent[6] = {mg_ename[MG_E_CONE],"_tv1",r1,"_tv2",r2}; |
525 |
526 |
527 |
int rval; |
528 |
int sgn; |
529 |
double minrad, maxrad, avgrad; |
530 |
double theta; |
531 |
532 |
if (ac != 4) |
533 |
return(MG_EARGC); |
534 |
535 |
536 |
if (is0vect(cv->n)) |
537 |
return(MG_EILL); |
538 |
if (!isflt(av[2]) || !isflt(av[3])) |
539 |
return(MG_ETYPE); |
540 |
minrad = atof(av[2]); |
541 |
round0(minrad); |
542 |
maxrad = atof(av[3]); |
543 |
/* check orientation */ |
544 |
if (minrad > 0.) |
545 |
sgn = 1; |
546 |
else if (minrad < 0.) |
547 |
sgn = -1; |
548 |
else if (maxrad > 0.) |
549 |
sgn = 1; |
550 |
else if (maxrad < 0.) |
551 |
sgn = -1; |
552 |
else |
553 |
return(MG_EILL); |
554 |
if (sgn*(maxrad-minrad) <= 0.) |
555 |
return(MG_EILL); |
556 |
/* initialize */ |
557 |
warpconends = 1; |
558 |
v2ent[3] = av[1]; |
559 |
for (j = 0; j < 3; j++) |
560 |
sprintf(p2[j], FLTFMT, cv->p[j] + |
561 |
.5*sgn*(maxrad-minrad)*cv->n[j]); |
562 |
if ((rval = handle_it(MG_E_VERTEX, 4, v2ent)) != MG_OK) |
563 |
return(rval); |
564 |
565 |
return(rval); |
566 |
sprintf(r2, FLTFMT, avgrad=.5*(minrad+maxrad)); |
567 |
/* run outer section */ |
568 |
569 |
570 |
571 |
return(rval); |
572 |
573 |
574 |
.5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]); |
575 |
576 |
return(rval); |
577 |
578 |
return(rval); |
579 |
strcpy(r1, r2); |
580 |
sprintf(r2, FLTFMT, avgrad + .5*(maxrad-minrad)*sin(theta)); |
581 |
582 |
return(rval); |
583 |
584 |
/* run inner section */ |
585 |
sprintf(r2, FLTFMT, -.5*(minrad+maxrad)); |
586 |
for ( ; i <= 4*mg_nqcdivs; i++) { |
587 |
588 |
589 |
590 |
591 |
592 |
return(rval); |
593 |
594 |
return(rval); |
595 |
596 |
return(rval); |
597 |
strcpy(r1, r2); |
598 |
sprintf(r2, FLTFMT, -avgrad - .5*(maxrad-minrad)*sin(theta)); |
599 |
600 |
return(rval); |
601 |
602 |
warpconends = 0; |
603 |
return(MG_OK); |
604 |
605 |
606 |
607 |
static int |
608 |
e_cyl(ac, av) /* replace a cylinder with equivalent cone */ |
609 |
int ac; |
610 |
char **av; |
611 |
612 |
static char *avnew[6] = {mg_ename[MG_E_CONE]}; |
613 |
614 |
if (ac != 4) |
615 |
return(MG_EARGC); |
616 |
avnew[1] = av[1]; |
617 |
avnew[2] = av[2]; |
618 |
avnew[3] = av[3]; |
619 |
avnew[4] = av[2]; |
620 |
return(handle_it(MG_E_CONE, 5, avnew)); |
621 |
622 |
623 |
624 |
static int |
625 |
e_ring(ac, av) /* turn a ring into polygons */ |
626 |
int ac; |
627 |
char **av; |
628 |
629 |
static char p3[3][24], p4[3][24]; |
630 |
static char *nzent[5] = {mg_ename[MG_E_NORMAL],"0","0","0"}; |
631 |
static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_rv1","="}; |
632 |
static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_rv2","=","_rv3"}; |
633 |
static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_rv3","="}; |
634 |
static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]}; |
635 |
static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_rv4","="}; |
636 |
static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]}; |
637 |
static char *fent[6] = {mg_ename[MG_E_FACE],"_rv1","_rv2","_rv3","_rv4"}; |
638 |
639 |
640 |
FVECT u, v; |
641 |
double minrad, maxrad; |
642 |
int rv; |
643 |
double theta, d; |
644 |
645 |
if (ac != 4) |
646 |
return(MG_EARGC); |
647 |
648 |
649 |
650 |
return(MG_EILL); |
651 |
652 |
return(MG_ETYPE); |
653 |
654 |
round0(minrad); |
655 |
656 |
if (minrad < 0. || maxrad <= minrad) |
657 |
return(MG_EILL); |
658 |
/* initialize */ |
659 |
make_axes(u, v, cv->n); |
660 |
661 |
sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*u[j]); |
662 |
if ((rv = handle_it(MG_E_VERTEX, 3, v3ent)) != MG_OK) |
663 |
return(rv); |
664 |
if ((rv = handle_it(MG_E_POINT, 4, p3ent)) != MG_OK) |
665 |
return(rv); |
666 |
if (minrad == 0.) { /* closed */ |
667 |
v1ent[3] = av[1]; |
668 |
if ((rv = handle_it(MG_E_VERTEX, 4, v1ent)) != MG_OK) |
669 |
return(rv); |
670 |
if ((rv = handle_it(MG_E_NORMAL, 4, nzent)) != MG_OK) |
671 |
return(rv); |
672 |
for (i = 1; i <= 4*mg_nqcdivs; i++) { |
673 |
674 |
if ((rv = handle_it(MG_E_VERTEX, 4, v2ent)) != MG_OK) |
675 |
return(rv); |
676 |
677 |
sprintf(p3[j], FLTFMT, cv->p[j] + |
678 |
maxrad*u[j]*cos(theta) + |
679 |
maxrad*v[j]*sin(theta)); |
680 |
if ((rv = handle_it(MG_E_VERTEX, 2, v3ent)) != MG_OK) |
681 |
return(rv); |
682 |
683 |
return(rv); |
684 |
if ((rv = handle_it(MG_E_FACE, 4, fent)) != MG_OK) |
685 |
return(rv); |
686 |
687 |
} else { /* open */ |
688 |
if ((rv = handle_it(MG_E_VERTEX, 3, v4ent)) != MG_OK) |
689 |
return(rv); |
690 |
691 |
sprintf(p4[j], FLTFMT, cv->p[j] + minrad*u[j]); |
692 |
if ((rv = handle_it(MG_E_POINT, 4, p4ent)) != MG_OK) |
693 |
return(rv); |
694 |
v1ent[3] = "_rv4"; |
695 |
696 |
697 |
698 |
return(rv); |
699 |
700 |
return(rv); |
701 |
for (j = 0; j < 3; j++) { |
702 |
d = u[j]*cos(theta) + v[j]*sin(theta); |
703 |
sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*d); |
704 |
sprintf(p4[j], FLTFMT, cv->p[j] + minrad*d); |
705 |
706 |
707 |
return(rv); |
708 |
709 |
return(rv); |
710 |
if ((rv = handle_it(MG_E_VERTEX, 2, v4ent)) != MG_OK) |
711 |
return(rv); |
712 |
713 |
return(rv); |
714 |
if ((rv = handle_it(MG_E_FACE, 5, fent)) != MG_OK) |
715 |
return(rv); |
716 |
717 |
718 |
return(MG_OK); |
719 |
720 |
721 |
722 |
static int |
723 |
e_cone(ac, av) /* turn a cone into polygons */ |
724 |
int ac; |
725 |
char **av; |
726 |
727 |
static char p3[3][24], p4[3][24], n3[3][24], n4[3][24]; |
728 |
static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_cv1","="}; |
729 |
static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_cv2","=","_cv3"}; |
730 |
static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_cv3","="}; |
731 |
732 |
static char *n3ent[5] = {mg_ename[MG_E_NORMAL],n3[0],n3[1],n3[2]}; |
733 |
static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_cv4","="}; |
734 |
735 |
static char *n4ent[5] = {mg_ename[MG_E_NORMAL],n4[0],n4[1],n4[2]}; |
736 |
static char *fent[6] = {mg_ename[MG_E_FACE],"_cv1","_cv2","_cv3","_cv4"}; |
737 |
register C_VERTEX *cv1, *cv2; |
738 |
739 |
FVECT u, v, w; |
740 |
double rad1, rad2; |
741 |
int sgn; |
742 |
double n1off, n2off; |
743 |
double d; |
744 |
int rv; |
745 |
double theta; |
746 |
747 |
if (ac != 5) |
748 |
return(MG_EARGC); |
749 |
if ((cv1 = c_getvert(av[1])) == NULL || |
750 |
(cv2 = c_getvert(av[3])) == NULL) |
751 |
752 |
if (!isflt(av[2]) || !isflt(av[4])) |
753 |
return(MG_ETYPE); |
754 |
rad1 = atof(av[2]); |
755 |
round0(rad1); |
756 |
rad2 = atof(av[4]); |
757 |
round0(rad2); |
758 |
if (rad1 == 0.) { |
759 |
if (rad2 == 0.) |
760 |
return(MG_EILL); |
761 |
} else if (rad2 != 0.) { |
762 |
if (rad1 < 0. ^ rad2 < 0.) |
763 |
return(MG_EILL); |
764 |
} else { /* swap */ |
765 |
C_VERTEX *cv; |
766 |
767 |
cv = cv1; |
768 |
cv1 = cv2; |
769 |
cv2 = cv; |
770 |
d = rad1; |
771 |
rad1 = rad2; |
772 |
rad2 = d; |
773 |
774 |
sgn = rad2 < 0. ? -1 : 1; |
775 |
/* initialize */ |
776 |
777 |
w[j] = cv1->p[j] - cv2->p[j]; |
778 |
if ((d = normalize(w)) == 0.) |
779 |
return(MG_EILL); |
780 |
n1off = n2off = (rad2 - rad1)/d; |
781 |
if (warpconends) { /* hack for e_sph and e_torus */ |
782 |
d = atan(n2off) - (PI/4)/mg_nqcdivs; |
783 |
if (d <= -PI/2+FTINY) |
784 |
n2off = -FHUGE; |
785 |
else |
786 |
n2off = tan(d); |
787 |
788 |
make_axes(u, v, w); |
789 |
790 |
sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*u[j]); |
791 |
if (n2off <= -FHUGE) |
792 |
sprintf(n3[j], FLTFMT, -w[j]); |
793 |
else |
794 |
sprintf(n3[j], FLTFMT, u[j] + w[j]*n2off); |
795 |
796 |
797 |
return(rv); |
798 |
799 |
return(rv); |
800 |
if ((rv = handle_it(MG_E_NORMAL, 4, n3ent)) != MG_OK) |
801 |
return(rv); |
802 |
if (rad1 == 0.) { /* triangles */ |
803 |
v1ent[3] = av[1]; |
804 |
805 |
return(rv); |
806 |
807 |
sprintf(n4[j], FLTFMT, w[j]); |
808 |
if ((rv = handle_it(MG_E_NORMAL, 4, n4ent)) != MG_OK) |
809 |
return(rv); |
810 |
811 |
theta = sgn*i*(PI/2)/mg_nqcdivs; |
812 |
813 |
return(rv); |
814 |
815 |
816 |
sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d); |
817 |
if (n2off > -FHUGE) |
818 |
sprintf(n3[j], FLTFMT, d + w[j]*n2off); |
819 |
820 |
821 |
return(rv); |
822 |
823 |
return(rv); |
824 |
if (n2off > -FHUGE && |
825 |
826 |
return(rv); |
827 |
828 |
return(rv); |
829 |
830 |
} else { /* quads */ |
831 |
v1ent[3] = "_cv4"; |
832 |
833 |
d = atan(n1off) + (PI/4)/mg_nqcdivs; |
834 |
if (d >= PI/2-FTINY) |
835 |
n1off = FHUGE; |
836 |
else |
837 |
n1off = tan(atan(n1off)+(PI/4)/mg_nqcdivs); |
838 |
839 |
840 |
sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*u[j]); |
841 |
if (n1off >= FHUGE) |
842 |
843 |
else |
844 |
sprintf(n4[j], FLTFMT, u[j] + w[j]*n1off); |
845 |
846 |
847 |
return(rv); |
848 |
849 |
return(rv); |
850 |
851 |
return(rv); |
852 |
853 |
854 |
855 |
return(rv); |
856 |
857 |
return(rv); |
858 |
859 |
860 |
861 |
862 |
863 |
sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*d); |
864 |
if (n1off < FHUGE) |
865 |
sprintf(n4[j], FLTFMT, d + w[j]*n1off); |
866 |
867 |
868 |
return(rv); |
869 |
870 |
return(rv); |
871 |
872 |
873 |
return(rv); |
874 |
875 |
return(rv); |
876 |
877 |
return(rv); |
878 |
if (n1off < FHUGE && |
879 |
880 |
return(rv); |
881 |
882 |
return(rv); |
883 |
884 |
885 |
return(MG_OK); |
886 |
887 |
888 |
889 |
static int |
890 |
e_prism(ac, av) /* turn a prism into polygons */ |
891 |
int ac; |
892 |
char **av; |
893 |
894 |
static char p[3][24]; |
895 |
static char *vent[4] = {mg_ename[MG_E_VERTEX],NULL,"="}; |
896 |
static char *pent[5] = {mg_ename[MG_E_POINT],p[0],p[1],p[2]}; |
897 |
char *newav[MG_MAXARGC], nvn[MG_MAXARGC-1][8]; |
898 |
double length; |
899 |
FVECT v1, v2, v3, norm; |
900 |
901 |
C_VERTEX *cv0; |
902 |
int rv; |
903 |
904 |
905 |
if (ac < 5) |
906 |
return(MG_EARGC); |
907 |
if (!isflt(av[ac-1])) |
908 |
return(MG_ETYPE); |
909 |
length = atof(av[ac-1]); |
910 |
if (length <= FTINY && length >= -FTINY) |
911 |
return(MG_EILL); |
912 |
/* do bottom face */ |
913 |
newav[0] = mg_ename[MG_E_FACE]; |
914 |
for (i = 1; i < ac-1; i++) |
915 |
newav[i] = av[i]; |
916 |
newav[i] = NULL; |
917 |
if ((rv = handle_it(MG_E_FACE, i, newav)) != MG_OK) |
918 |
return(rv); |
919 |
/* compute face normal */ |
920 |
if ((cv0 = c_getvert(av[2])) == NULL) |
921 |
922 |
norm[0] = norm[1] = norm[2] = 0.; |
923 |
v1[0] = v1[1] = v1[2] = 0.; |
924 |
for (i = 2; i < ac-1; i++) { |
925 |
if ((cv = c_getvert(av[i])) == NULL) |
926 |
927 |
v2[0] = cv->p[0] - cv0->p[0]; |
928 |
v2[1] = cv->p[1] - cv0->p[1]; |
929 |
v2[2] = cv->p[2] - cv0->p[2]; |
930 |
fcross(v3, v1, v2); |
931 |
norm[0] += v3[0]; |
932 |
norm[1] += v3[1]; |
933 |
norm[2] += v3[2]; |
934 |
VCOPY(v1, v2); |
935 |
936 |
if (normalize(norm) == 0.) |
937 |
return(MG_EILL); |
938 |
/* create moved vertices */ |
939 |
for (i = 1; i < ac-1; i++) { |
940 |
sprintf(nvn[i-1], "_pv%d", i); |
941 |
vent[1] = nvn[i-1]; |
942 |
if ((rv = handle_it(MG_E_VERTEX, 3, vent)) != MG_OK) |
943 |
return(rv); |
944 |
cv = c_getvert(av[i]); /* checked above */ |
945 |
946 |
sprintf(p[j], FLTFMT, cv->p[j] - length*norm[j]); |
947 |
if ((rv = handle_it(MG_E_POINT, 4, pent)) != MG_OK) |
948 |
return(rv); |
949 |
newav[ac-1-i] = nvn[i-1]; /* reverse */ |
950 |
951 |
/* do top face */ |
952 |
if ((rv = handle_it(MG_E_FACE, ac-1, newav)) != MG_OK) |
953 |
return(rv); |
954 |
/* do the side faces */ |
955 |
newav[5] = NULL; |
956 |
newav[3] = av[ac-2]; |
957 |
newav[4] = nvn[ac-3]; |
958 |
959 |
newav[1] = nvn[i-1]; |
960 |
newav[2] = av[i]; |
961 |
if ((rv = handle_it(MG_E_FACE, 5, newav)) != MG_OK) |
962 |
return(rv); |
963 |
newav[3] = newav[2]; |
964 |
newav[4] = newav[1]; |
965 |
966 |
return(MG_OK); |
967 |
