root/Development/ray/src/cv/mgflib/parser.c
Sat Nov 15 17:54:06 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 1.27: +96 -70 lines
Diff to previous 1.27 , to selected 1.26
Fri Feb 28 20:11:29 2003 UTC (22 years, 9 months ago) by greg
Changes since 1.26: +4 -6 lines
Diff to previous 1.26
Updates for 3.5 release
Revision 1.26 - (view) (download) (annotate) - [selected]
Mon Dec 15 09:41:37 1997 UTC (28 years ago) by gregl
Changes since 1.25: +1 -2 lines
Diff to previous 1.25
added stdlib.h for better reliability on some systems
Fri Mar 21 12:32:41 1997 UTC (28 years, 9 months ago) by greg
Changes since 1.24: +1 -2 lines
Diff to previous 1.24 , to selected 1.26
small cleanup suggested by Philippe B.
Tue Mar 18 11:17:24 1997 UTC (28 years, 9 months ago) by greg
Changes since 1.23: +36 -8 lines
Diff to previous 1.23 , to selected 1.26
added fh entity and general cleanup
Wed Jun 19 22:34:59 1996 UTC (29 years, 6 months ago) by greg
Changes since 1.22: +17 -19 lines
Diff to previous 1.22 , to selected 1.26
made some support handlers external symbols
Fri Dec 1 11:03:57 1995 UTC (30 years ago) by greg
Changes since 1.21: +13 -10 lines
Diff to previous 1.21 , to selected 1.26
made it so the stored input line includes escaped newlines
Wed Nov 29 19:14:49 1995 UTC (30 years ago) by greg
Changes since 1.20: +10 -5 lines
Diff to previous 1.20 , to selected 1.26
added error for unmatched xf or o context close
fixed potential bug in mg_load() in case MG_OK != 0 in future
Wed Nov 8 09:40:22 1995 UTC (30 years, 1 month ago) by greg
Changes since 1.19: +17 -4 lines
Diff to previous 1.19 , to selected 1.26
added check for input line exceeding MG_MAXLINE
Fri Oct 27 15:47:18 1995 UTC (30 years, 2 months ago) by greg
Changes since 1.18: +4 -1 lines
Diff to previous 1.18 , to selected 1.26
fixed bug in e_cone
Thu May 11 20:17:33 1995 UTC (30 years, 7 months ago) by greg
Changes since 1.17: +24 -3 lines
Diff to previous 1.17 , to selected 1.26
added default handling of undefined entities
Tue May 9 14:38:22 1995 UTC (30 years, 7 months ago) by greg
Changes since 1.16: +27 -27 lines
Diff to previous 1.16 , to selected 1.26
precautions against 16-bit architectures
Tue Apr 18 15:53:26 1995 UTC (30 years, 8 months ago) by greg
Changes since 1.15: +8 -11 lines
Diff to previous 1.15 , to selected 1.26
bug fix for empty include files
Thu Apr 13 12:11:30 1995 UTC (30 years, 8 months ago) by greg
Changes since 1.14: +1 -0 lines
Diff to previous 1.14 , to selected 1.26
added material index of refraction
Fri Mar 10 15:16:07 1995 UTC (30 years, 9 months ago) by greg
Diff to previous 1.13 , to selected 1.26
reduced significant digits in spectrum output
Tue Mar 7 14:53:23 1995 UTC (30 years, 9 months ago) by greg
Changes since 1.12: +77 -45 lines
Diff to previous 1.12 , to selected 1.26
added cct entity
Fri Jul 22 09:58:49 1994 UTC (31 years, 5 months ago) by greg
Changes since 1.11: +42 -16 lines
Diff to previous 1.11 , to selected 1.26
added surface normal interpolation to prism's
Fri Jul 1 18:06:58 1994 UTC (31 years, 5 months ago) by greg
Changes since 1.10: +2 -1 lines
Diff to previous 1.10 , to selected 1.26
added "sides" entity for one- vs. two-sided surfaces
Wed Jun 29 16:15:20 1994 UTC (31 years, 5 months ago) by greg
Changes since 1.9: +111 -143 lines
Diff to previous 1.9 , to selected 1.26
made the -a (array) option work within files as well
Sat Jun 25 16:33:09 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 1.8 , to selected 1.26
bug fixes and enhancements
Sat Jun 25 09:48:03 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.7: +2 -8 lines
Diff to previous 1.7 , to selected 1.26
minor fixes and enhancements
Fri Jun 24 17:15:49 1994 UTC (31 years, 6 months ago) by greg
Diff to previous 1.6 , to selected 1.26
minor bug fix
Fri Jun 24 16:28:18 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.5: +90 -6 lines
Diff to previous 1.5 , to selected 1.26
added cspec and cmix entities
Fri Jun 24 09:40:29 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.4: +7 -7 lines
Diff to previous 1.4 , to selected 1.26
changed prism length from first argument to last
Fri Jun 24 09:32:51 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.3: +97 -0 lines
Diff to previous 1.3 , to selected 1.26
added prism entity and minor changes
Wed Jun 22 17:15:49 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.2: +46 -22 lines
Diff to previous 1.2 , to selected 1.26
more bug fixes
Wed Jun 22 15:33:47 1994 UTC (31 years, 6 months ago) by greg
Changes since 1.1: +9 -3 lines
Diff to previous 1.1 , to selected 1.26
various enhancements and fixes
Tue Jun 21 14:45:46 1994 UTC (31 years, 6 months ago) by greg
Diff to selected 1.26
