root/radiance/ray/src/cv/mgflib/mgfdoc.tr
Revision 1.20 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Feb 28 20:11:29 2003 UTC (21 years, 2 months ago) by greg
CVS Tags: HEAD, rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 1.19
Updates for 3.5 release
Revision 1.19 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 16 11:42:25 1997 UTC (26 years, 6 months ago) by gregl
Changes since 1.18: +20 -1 lines
Diff to previous 1.18
Added client data pointers to context structures (vertex, color, material).
Revision 1.18 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Mar 21 12:32:30 1997 UTC (27 years, 1 month ago) by greg
Changes since 1.17: +15 -0 lines
Diff to previous 1.17
small cleanup suggested by Philippe B.
Revision 1.17 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 18 12:57:07 1997 UTC (27 years, 1 month ago) by greg
Changes since 1.16: +4 -3 lines
Diff to previous 1.16
added fh entity and general cleanup
Revision 1.16 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Mar 18 11:43:22 1997 UTC (27 years, 1 month ago) by greg
Changes since 1.15: +64 -4 lines
Diff to previous 1.15
Revision 1.15 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Apr 5 16:35:25 1996 UTC (28 years, 1 month ago) by greg
Diff to previous 1.14
corrected specular power conversion
Revision 1.14 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 21 15:46:44 1996 UTC (28 years, 2 months ago) by greg
Changes since 1.13: +5 -5 lines
Diff to previous 1.13
minor fixes
Revision 1.13 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 21 14:26:43 1996 UTC (28 years, 2 months ago) by greg
Changes since 1.12: +119 -9 lines
Diff to previous 1.12
added 3ds2mgf program and updated for release 1.1
Revision 1.12 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Dec 4 12:27:04 1995 UTC (28 years, 5 months ago) by greg
Changes since 1.11: +59 -5 lines
Diff to previous 1.11
added mgf2inv
Revision 1.11 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Dec 1 11:07:51 1995 UTC (28 years, 5 months ago) by greg
Diff to previous 1.10
made it so the stored input line includes escaped newlines
Revision 1.10 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 29 16:45:15 1995 UTC (28 years, 5 months ago) by greg
Diff to previous 1.9
added error for unmatched xf or o context close
Revision 1.9 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Nov 22 12:23:27 1995 UTC (28 years, 5 months ago) by greg
Changes since 1.8: +5 -1 lines
Diff to previous 1.8
made mgfilt expand included files for version conformancy
Wed Nov 8 09:53:41 1995 UTC (28 years, 6 months ago) by greg
Changes since 1.7: +5 -1 lines
Diff to previous 1.7
added check for input line exceeding MG_MAXLINE
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 20 10:07:10 1995 UTC (28 years, 7 months ago) by greg
Diff to previous 1.6
fixed mislabeled entry
Mon Aug 28 16:45:59 1995 UTC (28 years, 8 months ago) by greg
Changes since 1.5: +2 -1 lines
Diff to previous 1.5
allow for negative spectral components
Thu Aug 24 12:28:13 1995 UTC (28 years, 8 months ago) by greg
Diff to previous 1.4
fix in clyinder man page
Thu Jun 29 14:40:18 1995 UTC (28 years, 10 months ago) by greg
Changes since 1.3: +14 -17 lines
Diff to previous 1.3
minor formatting fixes
Mon May 15 14:42:30 1995 UTC (28 years, 11 months ago) by greg
Changes since 1.2: +3 -4 lines
Diff to previous 1.2
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 12 21:42:42 1995 UTC (28 years, 11 months ago) by greg
Changes since 1.1: +14 -10 lines
fixed minor problems
Fri May 12 14:26:12 1995 UTC (28 years, 11 months ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R9: (view) (download) (as text) (annotate)
