root/radiance/ray/src/cv/mgflib/mgfdoc.tr
Revision: 1.4
Committed: Thu Jun 29 14:40:18 1995 UTC (30 years ago) by greg
Content type: application/x-troff
Changes since 1.3: +14 -17 lines
minor formatting fixes
1 .\" SCCSid "$SunId$ LBL"
2 .nr PS 11
3 .ps 11
4 .nr VS 12
5 .vs 12
6 .nr PD .5v
7 .ds LF MGF
8 .ds RF Version 1.0
9 .DA May 1995
10 .TL
11 The Materials and Geometry Format
12 .AU
13 Greg Ward
14 .br
15 Lawrence Berkeley Laboratory
16 .NH
17 Introduction
18 .LP
19 The Materials and Geometry Format (referred to henceforth as MGF)
20 is a description language for 3-dimensional environments expressly
21 suited to visible light simulation and rendering.
22 The materials are physically-based and rely on standard and
23 well-accepted definitions of color, reflectance and transmittance
24 for good accuracy and reproducibility.
25 The geometry is based on boundary representation using simple
26 geometric primitives such as polygons, spheres and cones.
27 The file format itself is terse but human-readable ASCII text.
28 .NH 2
29 What makes MGF special?
30 .LP
31 There are three principal reasons to use MGF as an input language for
32 lighting simulation and physically-based rendering:
33 .RS
34 .IP 1.
35 It's the only existing format that describes materials physically.
36 .IP 2.
37 It is endorsed by the Illuminating Engineering Society of North
38 America (IESNA) as part of their LM-63-1995 standard for luminaire data.
39 .IP 3.
40 It's easy and fun to support since it comes with a standard parser
41 and sample scenes and objects at the web site,
42 "http://radsite.lbl.gov/mgf/HOME.html".
43 .RE
44 .LP
45 The standard parser provides both immediate and a long-term
46 benefits, since it presents a programming interface that is more
47 stable even than the language itself.
48 Unlike AutoCAD DXF and other de facto standards, a change to the
49 language will not break existing programs.
50 This is because the parser gives the calling software only those
51 entities it can handle.
52 If the translator understands only polygons, it will be given only
53 polygons.
54 If a new geometric primitive is included in a later version of the
55 standard, the new parser that comes with it will still be able to
56 express this entity as polygons.
57 Thus, the urgency of modifying code to support a changing standard
58 is removed, and long-term stability is assured.
59 .LP
60 This notion of
61 .I extensibility
62 is a cornerstone of the format, and it goes well beyond the
63 extensibility of other languages because is guarantees that new
64 versions of the standard will not break existing programs, and the
65 new information will be used as much as possible.
66 Other languages either require that all translators stay up to date
67 with the latest standard, or allow forward compatibility by simply
68 .I ignoring
69 new entities.
70 In MGF, if NURBS are added at some point and the translator or
71 loader does not handle them directly, the new version of the parser
72 will automatically convert them to smoothed polygons without
73 changing a single line of the calling program.
74 It is merely necessary to link to the new library, and all the new
75 entities are supported\(dg.
76 .FS
77 \(dgIf an old version of the parser encounters new entities it does
78 not recognize, the default action is to ignore them, printing a warning
79 message.
80 This may be overridden to support custom entities, but such
81 practice is discouraged because it weakens the standard.
82 .FE
83 .NH 2
84 What does MGF look like?
85 .LP
86 MGF has a simple entity-per-line structure, with a similar
87 appearance to Wavefront's .OBJ format.
88 Each entity is specified by a short keyword, and
89 arguments are separated by white space (tabs and/or spaces).
90 A newline may be escaped with a backslash ('\\'), in which case it
91 counts as a space.
92 Lines and continued lines may have up to 4096 characters, including
93 newlines, tabs and spaces.
94 A comment is an ignored entity whose keyword is the pound sign ('#').
95 .LP
96 Here is an MGF file that describes a simple two-drawer file cabinet:
97 .DS
98 # Conversion from inches to meters
99 xf -s .0254
100 # Surface material
101 m burgundy_formica =
102 c
103 cxy .362 .283
104 rd .0402
105 c
106 rs .0284 .05
107 sides 1
108 # Cabinet vertices
109 v fc.xy =
110 p .05 0 0
111 v fc.xY =
112 p .05 18 0
113 v fc.XY =
114 p 35.95 18 0
115 v fc.Xy =
116 p 35.95 0 0
117 # Cabinet
118 prism fc.xy fc.xY fc.XY fc.Xy 24
119 # Drawer vertices
120 v fcd.Xz =
121 p 34 0 0
122 v fcd.XZ =
123 p 34 0 10
124 v fcd.xZ =
125 p 0 0 10
126 v fcd.xz =
127 p 0 0 0
128 # Two drawers
129 o drawer
130 xf -t 1 18.1 2 -a 2 -t 0 0 11
131 prism fcd.xz fcd.Xz fcd.XZ fcd.xZ .9
132 xf
133 o
134 # End of units conversion
135 xf
136 .DE
137 .NH 2
138 MGF's place in the world of standards
139 .LP
140 MGF was developed initially to support detailed geometric
141 description of light fixtures for the IESNA luminaire data standard,
142 publication LM-63\(dg.
143 .FS
144 \(dgTo obtain the latest version of this standard, write to:
145 Illuminating Engineering Society of North America,
146 345 East 47th St.,
147 New York, NY 10017.
148 .FE
149 Existing standards for geometric description were either too
150 cumbersome (e.g.
151 .I Radiance)
152 or did not include physical materials (e.g. IGES).
153 It was noted early on that a standard able to fully describe
154 luminaires would necessarily be
155 capable of describing other objects as well; indeed whole
156 environments could be defined this way.
157 Since the descriptions would be physical, they could serve as input
158 to both lighting simulation and rendering software.
159 A standard language for describing the appearance of physical
160 objects has been lacking for some time, and current efforts in this
161 direction (i.e. STEP) seem several years away from fruition.
162 (There are other languages for describing realistic scenes
163 that deserve mention here, such as VRML and the Manchester Scene
164 Description Language, but none give specific attention to physical
165 material properties and are thus unsuitable for lighting
166 simulation.)\0
167 .LP
168 In short, we saw this as an opportunity to offer the lighting and
169 rendering community a simple and easy-to-support standard for
170 describing environments in a physically valid way.
171 Our hope is that this will promote sharing color, material and object
172 libraries as well as complete scene descriptions.
173 Sharing libraries is of obvious benefit to users and software
174 developers alike.
175 Sharing scenes should also permit
176 comparisons between rendering systems and
177 intervalidation of lighting calculations.
178 As anyone who works in this field knows, modeling is the most
179 difficult step in creating any simulation or rendering, and there is
180 no excuse for this data being held prisoner by a proprietary data
181 format.
182 .NH
183 MGF Basics
184 .LP
185 The default coordinate system in MGF is right-handed with
186 distances given in meters, though this can be effectively changed
187 by specifying a global transformation.
188 The transformation context is affected by the
189 .UL xf
190 entity, and the whole of MGF can be understood in terms of entities
191 and contexts.
192 .NH 2
193 Entities and Contexts
194 .LP
195 An
196 .I entity
197 in MGF is any non-blank line, which must be one of a finite set of
198 command keywords followed by zero or more arguments.
199 (As mentioned previously, an entity may continue over multiple lines
200 by escaping the newline with a backslash.)\0
201 Table 1 gives a list of entities and their expected arguments.
202 Section 3 gives more detailed information on each entity.
203 .KF
204 .TS
205 expand, box;
206 l l l.
207 Keyword Arguments Interpretation
208 = = =
209 # [anything ...] a comment
210 o [name] begin/end object context
211 xf [xform] begin/end transformation context
212 i pathname [xform] include file (with transformation)
213 ies pathname [-m f][xform] include IES luminaire (with transformation)
214 _ _ _
215 c [id [= [template]]] get/set color context
216 cxy x y set CIE (x,y) chromaticity for current color
217 cspec l_min l_max v1 v2 ... set relative spectrum for current color
218 cct temperature set spectrum based on black body temperature
219 cmix w1 c1 w2 c2 ... mix named colors to make current color
220 _ _ _
221 m [id [= [template]]] get/set material context
222 sides {1|2} set number of sides for current material
223 rd rho_d set diffuse reflectance for current material
224 td tau_d set diffuse transmittance for current material
225 ed epsilon_d set diffuse emittance for current material
226 rs rho_s alpha_r set specular reflectance for current material
227 ts tau_s alpha_t set specular transmittance for current material
228 ir n_real n_imag set index of refraction for current material
229 _ _ _
230 v [id [= [template]]] get/set vertex context
231 p x y z set point position for current vertex
232 n dx dy dz set surface normal for current vertex
233 _ _ _
234 f v1 v2 v3 ... polygon using current material, spec. vertices
235 sph vc radius sphere
236 cyl v1 radius v2 truncated right cylinder (open-ended)
237 cone v1 rad1 v2 rad2 truncated right cone (open-ended)
238 prism v1 v2 v3 ... length truncated right prism (closed solid)
239 ring vc rmin rmax circular ring with inner and outer radii
240 torus vc rmin rmax circular torus with inner and outer radii
241 .TE
242 .QP
243 .B "Table 1".
244 MGF entities and their arguments.
245 Arguments in brackets are optional.
246 Arguments in curly braces mean one of the given choices must
247 appear.
248 Ellipsis (...) mean that any number of arguments may be given.
249 .sp
250 .KE
251 .LP
252 A
253 .I context
254 describes the current state of the interpreter, and affects or is
255 affected by certain entities as they are read in.
256 MGF contexts can be divided into two types,
257 .I "hierarchical contexts"
258 and
259 .I "named contexts".
260 .LP
261 Hierarchical contexts are manipulated by a single entity and
262 have an associated "stack" onto which new
263 contexts are "pushed" using the entity.
264 The last context may be "popped" by giving the entity again with no
265 arguments.
266 The two hierarchical contexts in MGF are the current transformation,
267 manipulated with the
268 .UL xf
269 entity, and the current object, manipulated with the
270 .UL o
271 entity.
272 .KF
273 .TS
274 expand, allbox;
275 l c l l l.
276 Context Cntl. Entity Default Value Field Entities Affects
277 = = = = =
278 Object o - - -
279 Transform xf - - T{
280 f, sph, cyl, cone,
281 ring, torus, prism
282 T}
283 Material m 2-sided black T{
284 sides, rd, td,
285 ed, rs, ts
286 T} T{
287 f, sph, cyl, cone,
288 ring, torus, prism
289 T}
290 Color c neutral grey T{
291 cxy, cspec, cct, cmix
292 T} T{
293 rd, td, ed, rs, ts
294 T}
295 Vertex v T{
296 (0,0,0),
297 no normal
298 T} p, n T{
299 f, sph, cyl, cone,
300 ring, torus, prism
301 T}
302 .TE
303 .QP
304 .B "Table 2".
305 MGF contexts and their related entities and default values.
306 .sp
307 .KE
308 .LP
309 Named contexts in contrast hold sets of values that are swapped
310 in and out one at a time.
311 There are three named contexts in MGF, the current material, the
312 current color and the current vertex.
313 Each one may be associated with an identifier (any non-white
314 sequence of printing ASCII characters beginning with a letter),
315 and one of each is in effect at any given time.
316 Initially, these contexts are unnamed, and invoking an unnamed
317 context always returns to the original (default) values.
318 (See Table 2 for a list of contexts, their related
319 entities and defaults.)\0
320 .LP
321 It is easiest to think of a context as a "scratch space" where
322 values are written by some entities and read by others.
323 Naming a context allows us to reestablish the same scratch space
324 later, usually for reference but it can be altered as well.
325 Let us say we wanted to create a smooth blue plastic material with a
326 diffuse reflectance of 20% and a specular reflectance of 4%:
327 .DS
328 # Establish a new material context called "blue_plastic"
329 m blue_plastic =
330 # Reestablish a previous color context called "blue"
331 c blue
332 # Set the diffuse reflectance, which uses the above color
333 rd .20
334 # Get the unnamed color context (always starts out grey)
335 c
336 # Set the specular reflectance, which is uncolored
337 rs .04 0
338 # We're done, the current material context is now "blue_plastic"
339 .DE
340 Note that the above assumes that we have previously defined a color
341 context named "blue".
342 If we forgot to do that, the above description would generate an
343 "undefined" error.
344 The color context affects the material context indirectly because it
345 is read by the specular and diffuse reflectance entities, which are
346 in turn written to the current material.
347 It is not necessary to indent the entities that affect the material
348 definition, but it improves readability.
349 Note also that there is no explicit end to the material definition.
350 As long as a context remains in effect, its contents may be altered
351 by its field entities.
352 This will not affect previous uses of the context, however.
353 For example, a surface entity following the above definition will
354 have the specified color and reflectance, and later changes to the
355 material "blue_plastic" will have no effect on it.
356 .LP
357 Each of the three named contexts has an associated entity that
358 controls it.
359 The material context is controlled by the
360 .UL m
361 entity, the color context is controlled by the
362 .UL c
363 entity, and the vertex context is controlled by the
364 .UL v
365 entity.
366 There are exactly four forms for each entity.
367 The first form is the keyword by itself, which establishes
368 an unnamed context with predetermined default values.
369 This is a useful way to set values without worrying about saving
370 them for recall later.
371 The second form is to give the keyword with a previously defined
372 name.
373 This reestablishes a prior context for reuse.
374 The third form is to give the keyword with a name followed by an
375 equals sign.
376 (There must be a space between the name and the equals sign, since
377 it is a separate argument.)\0
378 This establishes a new context and assigns it the same default
379 values as the unnamed context.
380 The fourth and final form gives the keyword followed by a name then
381 an equals then the name of a previous context definition.
382 This establishes a new context for the first name, assigning the
383 values from the second named context rather than the usual defaults.
384 This is a convenient way create an alias or
385 to modify a context under a new name (i.e. "save as").
386 .NH 2
387 Hierarchical Contexts and Transformations
388 .LP
389 As mentioned in the last subsection, there are two hierarchical
390 contexts in MGF, the current object and the current transformation.
391 We will start by discussing the current object, since it is
392 the simpler of the two.
393 .NH 3
394 Objects
395 .LP
396 There is no particular need in lighting simulation or rendering to
397 name objects, but it may help the user
398 to know what object a particular surface is associated with.
399 The
400 .UL o
401 entity provides a convenient mechanism for associating names with
402 surfaces.
403 The basic use of this entity is as follows:
404 .DS
405 o object_name
406 [object entities...]
407 o subobject_name
408 [subobject entities...]
409 o
410 [more object entities and subobjects...]
411 o
412 .DE
413 The
414 .UL o
415 keyword by itself marks the end of an object context.
416 Any number of hierarchical context levels are supported, and there are no
417 rules governing the choice of object names except that they begin
418 with a letter and be made up of printing, non-white ASCII characters.
419 Indentation is not necessary of course, but it does improve
420 readability.
421 .NH 3
422 Transformations
423 .LP
424 MGF supports only rigid-body (i.e. non-distorting) transformations
425 with uniform scaling.
426 Unlike the other contexts, transformations have no associated
427 name, only arguments.
428 Thus, there is no way to reestablish a previous transformation other
429 than to give the same arguments over again.
430 Since the arguments are concise and self-explanatory, this was thought
431 sufficient.
432 The following transformation flags and
433 parameters are defined:
434 .TS
435 center;
436 l l.
437 -t dx dy dz translate objects along the given vector
438 -rx degrees rotate objects about the X-axis
439 -ry degrees rotate objects about the Y-axis
440 -rz degrees rotate objects about the Z-axis
441 -s scalefactor scale objects by the given factor
442 -mx mirror objects about the Y-Z plane
443 -my mirror objects about the X-Z plane
444 -mz mirror objects about the X-Y plane
445 -i N repeat the following arguments N times
446 -a N make an array of N geometric instances
447 .TE
448 Transform arguments have a cumulative effect.
449 That is, a rotation
450 about X of 20 degrees followed by a rotation about X of -50 degrees
451 results in a total rotation of -30 degrees.
452 However, if the two
453 rotations are separated by some translation vector, the cumulative
454 effect is quite different.
455 It is best to think of each argument as
456 acting on the included geometric objects, and each subsequent transformation
457 argument affects the objects relative to their new position/orientation.
458 .LP
459 For example, rotating an object about its center is most easily done
460 by translating
461 the object back to the origin, applying the desired rotation, and translating
462 it again back to its original position, like so:
463 .DS
464 # rotate an included object 20 degrees clockwise looking down
465 # an axis parallel to Y and passing through the point (15,0,-35)
466 xf -t -15 0 35 -ry -20 -t 15 0 -35
467 i object.mgf
468 xf
469 .DE
470 Note that the include entity,
471 .UL i,
472 permits a transformation to be given with it, so the above could
473 have been written more compactly as:
474 .DS
475 i object.mgf -t -15 0 35 -ry -20 -t 15 0 -35
476 .DE
477 .LP
478 Rotations are given in degrees counter-clockwise about a principal axis.
479 That is, with the thumb of the right hand pointing in the direction
480 of the axis, rotation follows the curl of the fingers.
481 .LP
482 The transform entity itself is cumulative, but in the reverse
483 order to its arguments.
484 That is, later transformations (i.e. enclosed transformations)
485 are prepended to existing (i.e. enclosing) ones.
486 A transform command
487 with no arguments is used to return to the previous condition.
488 It is
489 necessary that transforms and their end statements ("xf" by itself) be
490 balanced in a file, so that later or enclosing files are not affected.
491 .LP
492 Transformations apply only to geometric types, e.g. polygons, spheres, etc.
493 Vertices and the components that go into geometry are not directly affected.
494 This is to avoid confusion and the inadvertent multiple application of a
495 given transformation.
496 For example:
497 .DS
498 xf -t 5 0 0
499 v v1 =
500 p 0 10 0
501 n 0 0 1
502 xf -rx 180
503 # Transform now in effect is "-rx 180 -t 5 0 0"
504 ring v1 0 2
505 xf
506 xf
507 .DE
508 The final ring center is (5,-10,0) -- note that the vertex itself is
509 not affected by the transformation, only the geometry that calls on
510 it.
511 The normal orientation is (0,0,-1) due to the rotation about X,
512 which also reversed the sign of the central Y coordinate.
513 .NH 3
514 Arrays
515 .LP
516 The -a N transform specification causes the following transform
517 arguments to be repeated along with the contents of the included
518 objects N times.
519 The first instance of the geometry will be in its
520 initial location; the second instance will be repositioned according
521 to the named transformation; the third instance will be repositioned by
522 applying this transformation twice, and so on up to N-1 applications.
523 .LP
524 Multi-dimensional arrays may be specified with a single include
525 entity by giving multiple array commands separated by their
526 corresponding transforms.
527 A final transformation may be given
528 by preceding it with a -i 1 specification.
529 In other words, the
530 scope of an array command continues until the next -i or -a option.
531 .LP
532 The following MGF description places 60 spheres at a one unit spacing
533 in a 3x4x5 array, then moves the whole thing to an origin of
534 (15,30,45):
535 .DS
536 v v0 =
537 p 0 0 0
538 xf -a 3 -t 1 0 0 -a 4 -t 0 1 0 -a 5 -t 0 0 1 -i 1 -t 15 30 45
539 sph v0 0.1
540 xf
541 .DE
542 Note the "-i 1" in the specification, which marks the end of the
543 third array arguments before the final translation.
544 .NH 2
545 Detailed MGF Example
546 .LP
547 The following example of a simple room with a single door
548 and six file cabinets shows MGF in action, with copious comments to
549 help explain what's going on.
550 .LP
551 .DS
552 # "ceiling_tile" is a diffuse white surface with 75% reflectance:
553 # Create new named material context and clear it
554 m ceiling_tile =
555 # Specify one-sided material so we can see through from above
556 sides 1
557 # Set neutral color
558 c
559 # Set diffuse reflectance
560 rd .75
561 # "stainless_steel" is a mostly specular surface with 70% reflectance:
562 m stainless_steel =
563 sides 1
564 c
565 # Set specular reflectance to 50%, .08 roughness
566 rs .5 .08
567 # Other 20% reflectance is diffuse
568 rd .2
569
570 # The following materials were measured with a spectrophotometer:
571 m beige_paint =
572 sides 1
573 # Set diffuse spectral reflectance
574 c
575 # Spectrum measured in 10 nm increments from 400 to 700 nm
576 cspec 400 700 35.29 44.87 47.25 47.03 46.87 47.00 47.09 \\\\
577 47.15 46.80 46.17 46.26 48.74 51.08 51.31 51.10 \\\\
578 51.11 50.52 50.36 51.72 53.61 53.95 52.08 49.49 \\\\
579 48.30 48.75 49.99 51.35 52.75 54.44 56.34 58.00
580 rd 0.5078
581 # Neutral (grey) specular component
582 c
583 rs 0.0099 0.08000
584 m mottled_carpet =
585 sides 1
586 c
587 cspec 400 700 11.23 11.28 11.39 11.49 11.61 11.73 11.88 \\\\
588 12.02 12.12 12.19 12.30 12.37 12.37 12.36 12.34 \\\\
589 12.28 12.22 12.29 12.45 12.59 12.70 12.77 12.82 \\\\
590 12.88 12.98 13.24 13.67 14.31 15.55 17.46 19.75
591 rd 0.1245
592 m reddish_cloth =
593 # 2-sided so we can observe it from behind
594 sides 2
595 c
596 cspec 400 700 28.62 27.96 27.86 28.28 29.28 30.49 31.61 \\\\
597 32.27 32.26 31.83 31.13 30.07 29.14 29.03 29.69 \\\\
598 30.79 32.30 33.90 34.56 34.32 33.85 33.51 33.30 \\\\
599 33.43 34.06 35.26 37.04 39.41 42.55 46.46 51.00
600 rd 0.3210
601 m burgundy_formica =
602 sides 1
603 c
604 cspec 400 700 3.86 3.74 3.63 3.51 3.34 3.21 3.14 \\\\
605 3.09 3.08 3.14 3.13 2.91 2.72 2.74 2.72 \\\\
606 2.60 2.68 3.40 4.76 6.05 6.65 6.75 6.68 \\\\
607 6.63 6.56 6.51 6.46 6.41 6.36 6.34 6.34
608 rd 0.0402
609 c
610 rs 0.0284 0.05000
611 m speckled_grey_formica =
612 sides 1
613 c
614 cspec 400 700 30.95 44.77 51.15 52.60 53.00 53.37 53.68 \\\\
615 54.07 54.33 54.57 54.85 55.20 55.42 55.51 55.54 \\\\
616 55.46 55.33 55.30 55.52 55.81 55.91 55.92 56.00 \\\\
617 56.22 56.45 56.66 56.72 56.58 56.44 56.39 56.39
618 rd 0.5550
619 c
620 rs 0.0149 0.15000
621
622 # 40' x 22' x 9' office space with no windows and one door
623
624 # All measurements are in inches, so enclose with a metric conversion:
625 xf -s .0254
626
627 # The room corner vertices:
628 v rc.xyz =
629 p 0 0 0
630 v rc.Xyz =
631 p 480 0 0
632 v rc.xYz =
633 p 0 264 0
634 v rc.xyZ =
635 p 0 0 108
636 v rc.XYz =
637 p 480 264 0
638 v rc.xYZ =
639 p 0 264 108
640 v rc.XyZ =
641 p 480 0 108
642 v rc.XYZ =
643 p 480 264 108
644
645 # The floor:
646 # Push object name
647 o floor
648 # Get previously defined carpet material
649 m mottled_carpet
650 # Polygonal face using defined vertices
651 f rc.xyz rc.Xyz rc.XYz rc.xYz
652 # Pop object name
653 o
654
655 # The ceiling:
656 o ceiling
657 m ceiling_tile
658 f rc.xyZ rc.xYZ rc.XYZ rc.XyZ
659 o
660
661 # The door outline vertices:
662 v do.xz =
663 p 216 0 0
664 v do.Xz =
665 p 264 0 0
666 v do.xZ =
667 p 216 0 84
668 v do.XZ =
669 p 264 0 84
670
671 # The walls:
672 o wall
673 m beige_paint
674 o x
675 f rc.xyz rc.xYz rc.xYZ rc.xyZ
676 o
677 o X
678 f rc.Xyz rc.XyZ rc.XYZ rc.XYz
679 o
680 o y
681 f rc.xyz rc.xyZ rc.XyZ rc.Xyz do.Xz do.XZ do.xZ do.xz
682 o
683 o Y
684 f rc.xYz rc.XYz rc.XYZ rc.xYZ
685 o
686 o
687
688 # The door and jam vertices:
689 v djo.xz =
690 p 216 .5 0
691 v djo.xZ =
692 p 216 .5 84
693 v djo.XZ =
694 p 264 .5 84
695 v djo.Xz =
696 p 264 .5 0
697 v dji.Xz =
698 p 262 .5 0
699 v dji.XZ =
700 p 262 .5 82
701 v dji.xZ =
702 p 218 .5 82
703 v dji.xz =
704 p 218 .5 0
705 v door.xz =
706 p 218 0 0
707 v door.xZ =
708 p 218 0 82
709 v door.XZ =
710 p 262 0 82
711 v door.Xz =
712 p 262 0 0
713
714 # The door, jam and knob
715 o door
716 m burgundy_formica
717 f door.xz door.xZ door.XZ door.Xz
718 o jam
719 m beige_paint
720 f djo.xz djo.xZ djo.XZ djo.Xz dji.Xz dji.XZ dji.xZ dji.xz
721 f djo.xz do.xz do.xZ djo.xZ
722 f djo.xZ do.xZ do.XZ djo.XZ
723 f djo.Xz djo.XZ do.XZ do.Xz
724 f dji.xz dji.xZ door.xZ door.xz
725 f dji.xZ dji.XZ door.XZ door.xZ
726 f dji.Xz door.Xz door.XZ dji.XZ
727 o
728 o knob
729 m stainless_steel
730 # Define vertices needed for curved geometry
731 v kb1 =
732 p 257 0 36
733 v kb2 =
734 p 257 .25 36
735 n 0 1 0
736 v kb3 =
737 p 257 2 36
738 # 1" diameter cylindrical base from kb1 to kb2
739 cyl kb1 1 kb2
740 # Ring at base of knob stem
741 ring kb2 .4 1
742 # Knob stem
743 cyl kb2 .4 kb3
744 # Spherical knob
745 sph kb3 .85
746 o
747 o
748
749 # Six file cabinets (36" wide each)
750 # ("filecab.inc" was given as an earlier example in Section 1.2)
751 o filecab.x
752 # include a file as an array of three 36" apart
753 i filecab.inc -t -36 0 0 -rz -90 -t 1 54 0 -a 3 -t 0 36 0
754 o
755 o filecab.X
756 # the other three cabinets
757 i filecab.inc -rz 90 -t 479 54 0 -a 3 -t 0 36 0
758 o
759
760 # End of transform from inches to meters:
761 xf
762
763 # The 10 recessed fluorescent ceiling fixtures
764 ies hlrs2gna.ies -t 1.2192 2.1336 2.74 -a 5 -t 2.4384 0 0 -a 2 -t 0 2.4384 0
765 .DE
766 .bp
767 .NH
768 MGF Entity Reference
769 .LP
770 There are currently 28 entities in the MGF specification.
771 For ease of reference we have broken these into five categories:
772 .IP 1.
773 General
774 .TS
775 lw(.75i) lw(1.75i) lw(3i).
776 # [anything ...] a comment
777 o [name] begin/end object context
778 xf [xform] begin/end transformation context
779 i pathname [xform] include file (with transformation)
780 ies pathname [-m f][xform] include IES luminaire (with transformation)
781 .TE
782 .IP 2.
783 Color
784 .TS
785 lw(.75i) lw(1.75i) lw(3i).
786 c [id [= [template]]] get/set color context
787 cxy x y set CIE (x,y) chromaticity for current color
788 cspec l_min l_max v1 v2 ... set relative spectrum for current color
789 cct temperature set spectrum based on black body temperature
790 cmix w1 c1 w2 c2 ... mix named colors to make current color
791 .TE
792 .IP 3.
793 Material
794 .TS
795 lw(.75i) lw(1.75i) lw(3i).
796 m [id [= [template]]] get/set material context
797 sides {1|2} set number of sides for current material
798 rd rho_d set diffuse reflectance for current material
799 td tau_d set diffuse transmittance for current material
800 ed epsilon_d set diffuse emittance for current material
801 rs rho_s alpha_r set specular reflectance for current material
802 ts tau_s alpha_t set specular transmittance for current material
803 ir n_real n_imag set index of refraction for current material
804 .TE
805 .IP 4.
806 Vertex
807 .TS
808 lw(.75i) lw(1.75i) lw(3i).
809 v [id [= [template]]] get/set vertex context
810 p x y z set point position for current vertex
811 n dx dy dz set surface normal for current vertex
812 .TE
813 .IP 5.
814 Geometry
815 .TS
816 lw(.75i) lw(1.75i) lw(3i).
817 f v1 v2 v3 ... polygon using current material, spec. vertices
818 sph vc radius sphere
819 cyl v1 radius v2 truncated right cylinder (open-ended)
820 cone v1 rad1 v2 rad2 truncated right cone (open-ended)
821 prism v1 v2 v3 ... length truncated right prism (closed solid)
822 ring vc rmin rmax circular ring with inner and outer radii
823 torus vc rmin rmax circular torus with inner and outer radii
824 .TE
825 .ds LH General Entities
826 .ds RH #
827 .bp
828 .SH
829 NAME
830 .LP
831 # - a comment
832 .SH
833 SYNOPSIS
834 .LP
835 .B #
836 [
837 .I anything
838 ]
839 .SH
840 DESCRIPTION
841 .LP
842 A comment is a bit of text explanation.
843 Since it is an entity like any other (except that it has no effect),
844 there must be at least one space between the keyword (which is a
845 pound sign) and the "arguments," and the end of line may be escaped
846 as usual with the backslash character ('\\').
847 .LP
848 A comment may actually be used to hold auxiliary information such as
849 view parameters, which may be interpreted by some destination program.
850 Care should be taken under such circumstances that the user does not
851 inadvertently mung or mimic this information in other comments, and
852 it is therefore advisable to use an additional set of identifying
853 characters to distinguish such data.
854 .SH
855 EXAMPLE
856 .DS
857 # The following include file is in inches, so convert to meters
858 i cubgeom.inc -s .0254
859 # Stuff we don't want to see at the moment:
860 # i person.mgf -t 3 2 0
861 # ies hlrs3gna.ies -rz 90 -t 1.524 1.8288 2.74 \\\\
862 -a 6 -t 1.8288 0 0 -a 2 -t 0 3.048 0
863 .DE
864 .ds RH O
865 .bp
866 .SH
867 NAME
868 .LP
869 o - begin or end object context
870 .SH
871 SYNOPSIS
872 .LP
873 .B o
874 [
875 .I name
876 ]
877 .SH
878 DESCRIPTION
879 .LP
880 If
881 .I name
882 is given, we push a new object context onto the stack, which is to
883 say that we begin a new subobject by this name\(dg.
884 .FS
885 \(dgA name is any sequence of printing, non-white ASCII characters
886 beginning with a letter.
887 .FE
888 If the
889 .UL o
890 keyword is given by itself, then we pop the last object context off
891 the stack, which means that we leave the current subobject.
892 .LP
893 All geometry between the start of an object context and its matching
894 end statement is associated with the given name.
895 This may be used in modeling software to help identify objects and
896 subobjects, or it may be ignored altogether.
897 .LP
898 Object begin and end statements should be balanced in a file, and
899 care should be taken not to overlap transform
900 .UL (xf)
901 contexts with object contexts, especially when arrays are involved.
902 This is because the standard parser will assign object contexts to
903 instanced geometry, which can get confused with other object
904 contexts if a clear enclosure is not maintained.
905 .SH
906 EXAMPLE
907 .DS
908 o body
909 o torso
910 i torso.mgf
911 o
912 o arm
913 o left
914 i leftarm.mgf
915 o
916 o right
917 i leftarm.mgf -mx
918 o
919 o
920 o
921 .DE
922 .SH
923 SEE ALSO
924 .LP
925 .UL xf
926 .ds RH XF
927 .bp
928 .SH
929 NAME
930 .LP
931 xf - begin or end transformation context
932 .SH
933 SYNOPSIS
934 .LP
935 .B xf
936 [
937 .I transform
938 ]
939 .SH
940 DESCRIPTION
941 .LP
942 If a set of
943 .I transform
944 arguments are given, we push a new transformation context onto the
945 stack.
946 If the
947 .UL xf
948 keyword is given by itself, then we pop the last transformation
949 context off the stack.
950 The total transformation in effect at any given time is
951 computed by prepending each set subcontext arguments onto those of
952 its enclosing context.
953 This and other details about transformation specifications
954 are explained in some detail in section 2.2.2.
955 .LP
956 The following transformation flags and
957 parameters are defined:
958 .TS
959 center;
960 l l.
961 -t dx dy dz translate objects along the given vector
962 -rx degrees rotate objects about the X-axis
963 -ry degrees rotate objects about the Y-axis
964 -rz degrees rotate objects about the Z-axis
965 -s scalefactor scale objects by the given factor
966 -mx mirror objects about the Y-Z plane
967 -my mirror objects about the X-Z plane
968 -mz mirror objects about the X-Y plane
969 -i N repeat the following arguments N times
970 -a N make an array of N geometric instances
971 .TE
972 .SH
973 EXAMPLE
974 .DS
975 # Create 3x5 array of evenly-spaced spheres (grid size = 3)
976 v vc =
977 p 0 0 0
978 xf -t 1 1 10 -a 3 -t 3 0 0 -a 5 -t 0 3 0
979 sph vc .5
980 xf
981 .DE
982 .SH
983 SEE ALSO
984 .LP
985 .UL i,
986 .UL ies,
987 .UL o
988 .ds RH I
989 .bp
990 .SH
991 NAME
992 .LP
993 i - include MGF data file
994 .SH
995 SYNOPSIS
996 .LP
997 .B i
998 .I pathname
999 [
1000 .I transform
1001 ]
1002 .SH
1003 DESCRIPTION
1004 .LP
1005 Include the information contained in the file
1006 .I pathname.
1007 If a
1008 .I transform
1009 specification is given, then it will be applied as though the
1010 include statement were enclosed by beginning and ending
1011 .UL xf
1012 entities with this transformation.
1013 .LP
1014 The
1015 .I pathname
1016 will be interpreted relative to the enclosing MGF file.
1017 That is, if the file containing the include statement is in some
1018 parent or subdirectory, then the given pathname is appended to this
1019 directory.
1020 It is illegal to specify a
1021 .I pathname
1022 relative to the root directory, and the MGF standard requires that
1023 all filenames adhere to the ISO-9660 8.3 name format for maximum
1024 portability between systems.
1025 The directory separator is defined to be slash ('/'), and drive
1026 specifications (such as "c:") are not allowed.
1027 All pathnames should be given in lower case, and will be converted to
1028 upper case on systems that require it.
1029 (That way, there are no accidental name collisions.)\0
1030 .LP
1031 The suggested suffix for MGF-adherent files is ".mgf".
1032 Files that are not in metric units but are in MGF may be given any
1033 suffix, but we suggest using ".inc" as a convention.
1034 .SH
1035 EXAMPLE
1036 .DS
1037 # Define vertices for 62x30" partition
1038 i pv62x30.inc
1039 # Insert 2 62x30" partitions
1040 o cpart1
1041 i partn.inc -t 75 130.5 0
1042 o
1043 o cpart3
1044 i partn.inc -t 186 130.5 0
1045 o
1046 # Define vertices for 62x36" partition
1047 i pv62x36.inc
1048 # Insert 62x36" partition
1049 o cpart2
1050 i partn.inc -t 105 130.5 0
1051 o
1052 .DE
1053 .SH
1054 SEE ALSO
1055 .LP
1056 .UL ies,
1057 .UL o,
1058 .UL xf
1059 .ds RH IES
1060 .bp
1061 .SH
1062 NAME
1063 .LP
1064 ies - include IESNA luminaire file
1065 .SH
1066 SYNOPSIS
1067 .LP
1068 .B ies
1069 .I pathname
1070 [
1071 .B \-m
1072 .I multiplier
1073 ]
1074 [
1075 .I transform
1076 ]
1077 .SH
1078 DESCRIPTION
1079 .LP
1080 Load the IES standard luminaire information contained in the file
1081 .I pathname.
1082 If a
1083 .I multiplier
1084 is given, all candela values will be multiplied by this factor.
1085 (This option must appear first if present.)\0
1086 If a
1087 .I transform
1088 specification is given, then it will be applied as though the
1089 statement were enclosed by beginning and ending
1090 .UL xf
1091 entities with this transformation.
1092 .LP
1093 The
1094 .I pathname
1095 will be interpreted relative to the enclosing MGF file, and all
1096 restrictions discussed under the
1097 .UL i
1098 entity also apply to the IES file name.
1099 The suggested suffix is ".ies", but this has not been followed
1100 consistently by lighting manufacturers.
1101 .SH
1102 EXAMPLE
1103 .DS
1104 # Insert 10 2x4' fluorescent troffers in two groups
1105 ies cf9pr240.ies -t 3.6576 2.1336 2.74 -a 3 -t 2.4384 0 0 -a 2 -t 0 2.4384 0
1106 ies cf9pr240.ies -rz 90 -t 1.2192 1.8288 2.74 \\\\
1107 -a 2 -t 9.7536 0 0 -a 2 -t 0 3.048 0
1108 .DE
1109 .SH
1110 SEE ALSO
1111 .LP
1112 .UL i,
1113 .UL o,
1114 .UL xf
1115 .ds LH Color Entities
1116 .ds RH C
1117 .bp
1118 .SH
1119 NAME
1120 .LP
1121 c - get or set the current color context
1122 .SH
1123 SYNOPSIS
1124 .LP
1125 .B c
1126 [
1127 .I id
1128 [
1129 .B =
1130 [
1131 .I template
1132 ]
1133 ]
1134 ]
1135 .SH
1136 DESCRIPTION
1137 .LP
1138 If the
1139 .UL c
1140 keyword is given by itself, then it establishes the unnamed color
1141 context, which is neutral (i.e. equal-energy) grey.
1142 This context may be modified, but the changes will not be saved.
1143 .LP
1144 If the keyword is followed by an identifier
1145 .I id,
1146 then it reestablishes a previous context.
1147 If the specified context was never defined, an error will result.
1148 .LP
1149 If the entity is given with an identifier
1150 followed by an equals sign ('='), then a new context is established,
1151 and cleared to the default neutral grey.
1152 (Note that the equals sign must be separated from other
1153 arguments by white space to be properly recognized.)\0
1154 If the equals sign is followed by a second identifier
1155 .I template,
1156 then this previously defined color will be used as a source of
1157 default values rather than grey.
1158 This is most useful for establishing a color alias.
1159 .SH
1160 EXAMPLE
1161 .DS
1162 # Define the color "red32"
1163 c red32 =
1164 cxy .42 .15
1165 # Make "cabinet_color" an alias for "red32"
1166 c cabinet_color = red32
1167
1168 # Later in another part of the description...
1169
1170 # Get our cabinet color
1171 c cabinet_color
1172 # Get the geometry
1173 i cabgeom.mgf
1174 .DE
1175 .SH
1176 SEE ALSO
1177 .LP
1178 .UL cct,
1179 .UL cmix,
1180 .UL cspec,
1181 .UL cxy,
1182 .UL m
1183 .ds RH CXY
1184 .bp
1185 .SH
1186 NAME
1187 .LP
1188 cxy - set the CIE (x,y) chromaticity for the current color
1189 .SH
1190 SYNOPSIS
1191 .LP
1192 .B cxy
1193 .I "x y"
1194 .SH
1195 DESCRIPTION
1196 .LP
1197 This entity sets the current color using (x,y) chromaticity
1198 coordinates for the 1931 CIE standard 2 degree observer.
1199 Legal values for
1200 .I x
1201 and
1202 .I y
1203 are greater than zero and sum to less than one, and more
1204 specifically they must fit within the curve of the visible spectrum.
1205 The
1206 .I x
1207 coordinate roughly corresponds to the red part of the spectrum and
1208 the
1209 .I y
1210 coordinate corresponds to the green.
1211 The CIE z coordinate is implicit, since it is equal to (1-x-y).
1212 .LP
1213 All colors in MGF are absolute, thus colorimeter measurements should
1214 be conducted the same for surfaces as for light sources.
1215 Applying a standard illuminant calculation is redundant and
1216 introduces inaccuracies, and should therefore be avoided if
1217 possible.
1218 .LP
1219 Conversion between CIE colors and those more commonly used in
1220 computer graphics are described in the application notes section
1221 6.1.1.
1222 .SH
1223 EXAMPLE
1224 .DS
1225 # Set unnamed color context
1226 c
1227 # Set CIE chromaticity to a bluish hue
1228 cxy .15 .2
1229 # Apply color to diffuse reflectance of 15%
1230 rd .15
1231 .DE
1232 .SH
1233 SEE ALSO
1234 .LP
1235 .UL c,
1236 .UL cct,
1237 .UL cmix,
1238 .UL cspec
1239 .ds RH CSPEC
1240 .bp
1241 .SH
1242 NAME
1243 .LP
1244 cspec - set the relative spectrum for the current color
1245 .SH
1246 SYNOPSIS
1247 .LP
1248 .B cspec
1249 .I "l_min l_max o1 o2 ... oN"
1250 .SH
1251 DESCRIPTION
1252 .LP
1253 Assign a relative spectrum measured between
1254 .I l_min
1255 and
1256 .I l_max
1257 nanometers at evenly spaced intervals.
1258 The first value,
1259 .I o1
1260 corresponds to the measurement at
1261 .I l_min,
1262 and the last value,
1263 .I oN
1264 corresponds to the measurement at
1265 .I l_max.
1266 Values in between are separated by
1267 .I "(l_max-l_min)/(N-1)"
1268 nanometers.
1269 All values must be non-negative, and the spectrum outside of the
1270 specified range is assumed to be zero.
1271 (The visible range is 380 to 780 nm.)\0
1272 The actual units and scale of the measurements do not matter,
1273 since the total will be
1274 normalized according to whatever the color is modifying
1275 (e.g. photometric reflectance or emittance).
1276 .SH
1277 EXAMPLE
1278 .DS
1279 # Color measured at 10 nm increments from 400 to 700
1280 m reddish_cloth =
1281 c
1282 cspec 400 700 28.62 27.96 27.86 28.28 29.28 30.49 31.61 \\\\
1283 32.27 32.26 31.83 31.13 30.07 29.14 29.03 29.69 \\\\
1284 30.79 32.30 33.90 34.56 34.32 33.85 33.51 33.30 \\\\
1285 33.43 34.06 35.26 37.04 39.41 42.55 46.46 51.00
1286 rd 0.3210
1287 .DE
1288 .SH
1289 SEE ALSO
1290 .LP
1291 .UL c,
1292 .UL cct,
1293 .UL cmix,
1294 .UL cxy
1295 .ds RH CCT
1296 .bp
1297 .SH
1298 NAME
1299 .LP
1300 cct - set the current color to a black body spectrum
1301 .SH
1302 SYNOPSIS
1303 .LP
1304 .B cct
1305 .I temperature
1306 .SH
1307 DESCRIPTION
1308 .LP
1309 The
1310 .UL cct
1311 entity sets the current color to the spectrum of an ideal
1312 black body radiating at
1313 .I temperature
1314 degrees Kelvin.
1315 This is often the most convenient way to set the color of an
1316 incandescent light source, but it is not recommended for
1317 fluorescent lamps or other materials that do not fit a
1318 black body spectrum.
1319 .SH
1320 EXAMPLE
1321 .DS
1322 # Define an incandescent source material at 3000 degrees K
1323 m incand3000k =
1324 c
1325 cct 3000
1326 ed 1500
1327 .DE
1328 .SH
1329 SEE ALSO
1330 .LP
1331 .UL c,
1332 .UL cmix,
1333 .UL cspec,
1334 .UL cxy
1335 .ds RH CMIX
1336 .bp
1337 .SH
1338 NAME
1339 .LP
1340 cmix - mix two or more named colors to make the current color
1341 .SH
1342 SYNOPSIS
1343 .LP
1344 .B cmix
1345 .I "w1 c1 w2 c2 ..."
1346 .SH
1347 DESCRIPTION
1348 .LP
1349 The
1350 .UL cmix
1351 entity sums together two or more named colors using specified
1352 weighting coefficients, which correspond to the relative
1353 photometric brightness of each.
1354 As in all color specifications, the result is normalized so the
1355 absolute scale of the weights does not matter, only their relative
1356 values.
1357 .LP
1358 If any of the colors is a spectral quantity (i.e. from a
1359 .UL cspec
1360 or
1361 .UL cct
1362 entity), then all the colors are first converted to spectral
1363 quantities.
1364 This is done with an approximation for CIE (x,y) chromaticities,
1365 which may be problematic depending on their values.
1366 In general, it is safest to add together colors that are either
1367 all spectral quantities or all CIE quantities.
1368 .SH
1369 EXAMPLE
1370 .DS
1371 # Define RGB primaries for a standard color monitor
1372 c R =
1373 cxy 0.640 0.330
1374 c G =
1375 cxy 0.290 0.600
1376 c B =
1377 cxy 0.150 0.060
1378 # Mix them together in appropriate amounts for white
1379 c white =
1380 cmix 0.265 R 0.670 G 0.065 B
1381 .DE
1382 .SH
1383 SEE ALSO
1384 .LP
1385 .UL c,
1386 .UL cct,
1387 .UL cspec,
1388 .UL cxy
1389 .ds LH Material Entities
1390 .ds RH M
1391 .bp
1392 .SH
1393 NAME
1394 .LP
1395 m - get or set the current material context
1396 .SH
1397 SYNOPSIS
1398 .LP
1399 .B m
1400 [
1401 .I id
1402 [
1403 .B =
1404 [
1405 .I template
1406 ]
1407 ]
1408 ]
1409 .SH
1410 DESCRIPTION
1411 .LP
1412 If the
1413 .UL m
1414 keyword is given by itself, then it establishes
1415 the unnamed material context, which is a perfect two-sided black absorber.
1416 This context may be modified, but the changes will not be saved.
1417 .LP
1418 If the keyword is followed by an identifier
1419 .I id,
1420 then it reestablishes a previous context.
1421 If the specified context was never defined, an error will result.
1422 .LP
1423 If the entity is given with an identifier
1424 followed by an equals sign ('='), then a new context is established,
1425 and cleared to the default material.
1426 (Note that the equals sign must be separated from other
1427 arguments by white space to be properly recognized.)\0
1428 If the equals sign is followed by a second identifier
1429 .I template,
1430 then this previously defined material will be used as a source of
1431 default values instead.
1432 This may be used to establish a material alias, or to modify an
1433 existing material and give it a new name.
1434 .LP
1435 The sum of the diffuse and specular reflectances and transmittances
1436 must not be greater than one (with no negative values, obviously).
1437 These values are assumed to be measured at normal incidence.
1438 If an index of refraction is given, this may modify the balance between
1439 diffuse and specular reflectance at other incident angles.
1440 If the
1441 material is one-sided (see
1442 .UL sides
1443 entity), then it may be a dielectric interface.
1444 In this case, the specular transmittance given is that which would be
1445 measured at normal incidence for a pane of the material 5 mm thick.
1446 This is important for figuring the actual transmittance for non-planar
1447 geometries assuming a uniformly absorbing medium.
1448 (Diffuse transmittance will not be affected by thickness.)\0
1449 If the index of
1450 refraction has an imaginary part, then the surface is a metal and this
1451 implies other properties as well.
1452 The default index of refraction is that of a vacuum, i.e. (1,0).
1453 .SH
1454 EXAMPLE
1455 .DS
1456 # Define a blue enamel paint
1457 m blue_enamel =
1458 c
1459 cxy 0.2771 0.2975
1460 rd 0.5011
1461 c
1462 rs 0.0100 0.0350
1463 # Assign blue_enamel to be the color of the south wall
1464 m swall_mat = blue_enamel
1465 # ...
1466 # South wall face
1467 m swall_mat
1468 f sv1 sv2 sv3 sv4
1469 .DE
1470 .SH
1471 SEE ALSO
1472 .LP
1473 .UL ed,
1474 .UL ir,
1475 .UL rd,
1476 .UL rs,
1477 .UL sides,
1478 .UL td,
1479 .UL ts
1480 .ds RH SIDES
1481 .bp
1482 .SH
1483 NAME
1484 .LP
1485 sides - set the number of sides for the current material
1486 .SH
1487 SYNOPSIS
1488 .LP
1489 .B sides
1490 {
1491 .B 1
1492 |
1493 .B 2
1494 }
1495 .SH
1496 DESCRIPTION
1497 .LP
1498 The
1499 .UL sides
1500 entity is used to set the number of sides for the current material.
1501 If a surface is two-sided, then it will appear
1502 identical when viewed from either the front or the back.
1503 If a surface is one-sided,
1504 then it appears invisible when viewed from the back side.
1505 This means
1506 that a transmitting object will affect the light coming in through the
1507 front surface and ignore the characteristics of the back surface,
1508 unless the index of refraction is set.
1509 If the index of refraction is set, then the object will act as a
1510 solid piece of dielectric material.
1511 In either case, the transmission properties of the exiting surface
1512 should be the same as the incident surface for the model to be
1513 physically valid.
1514 .LP
1515 The default number of sides is two.
1516 .SH
1517 EXAMPLE
1518 .DS
1519 # Describe a blue crystal ball
1520 m blue_crystal =
1521 ir 1.650000 0
1522 # Solid dielectrics must use one-sided materials
1523 sides 1
1524 c
1525 rs 0.0602 0
1526 c
1527 cxy 0.3127 0.2881
1528 ts 0.6425 0
1529 v sc =
1530 p 10 15 1.5
1531 sph sc .02
1532 .DE
1533 .SH
1534 SEE ALSO
1535 .LP
1536 .UL ed,
1537 .UL ir,
1538 .UL m,
1539 .UL rd,
1540 .UL rs,
1541 .UL td,
1542 .UL ts
1543 .ds RH RD
1544 .bp
1545 .SH
1546 NAME
1547 .LP
1548 rd - set the diffuse reflectance for the current material
1549 .SH
1550 SYNOPSIS
1551 .LP
1552 .B rd
1553 .I rho_d
1554 .SH
1555 DESCRIPTION
1556 .LP
1557 Set the diffuse reflectance for the current material to
1558 .I rho_d
1559 using the current color to determine the spectral characteristics.
1560 This is the fraction of visible light that is reflected from a
1561 surface equally in all directions according to Lambert's law, and is
1562 often called the "Lambertian component."
1563 Photometric reflectance is measured according to v(lambda)
1564 response function of the 1931 CIE standard 2
1565 degree observer, and assumes an equal-energy white light source.
1566 The value must be between zero and one, and may be further
1567 restricted by the luminosity of the selected color.
1568 (I.e. it is impossible to have a violet material with a photometric
1569 reflectance close to one since the eye is less sensitive in this part
1570 of the spectrum.)\0
1571 .LP
1572 The default diffuse reflectance is zero.
1573 .SH
1574 EXAMPLE
1575 .DS
1576 # An off-white paint with 70% reflectance
1577 m flat_white70 =
1578 c
1579 cxy .3632 .3420
1580 rd .70
1581 .DE
1582 .SH
1583 SEE ALSO
1584 .LP
1585 .UL c,
1586 .UL ed,
1587 .UL ir,
1588 .UL m,
1589 .UL rs,
1590 .UL sides,
1591 .UL td,
1592 .UL ts
1593 .ds RH TD
1594 .bp
1595 .SH
1596 NAME
1597 .LP
1598 td - set the diffuse transmittance for the current material
1599 .SH
1600 SYNOPSIS
1601 .LP
1602 .B td
1603 .I tau_d
1604 .SH
1605 DESCRIPTION
1606 .LP
1607 Set the diffuse transmittance for the current material to
1608 .I tau_d
1609 using the current color to determine the spectral characteristics.
1610 This is the fraction of visible light that is transmitted through a
1611 surface equally in all (transmitted) directions.
1612 Like reflectance, transmittance is measured according to the
1613 standard v(lambda) curve, and assumes an equal-energy white light source.
1614 It is probably not possible to create a material with a diffuse
1615 transmittance above 50%, since well-diffused light will be reflected
1616 as well.
1617 .LP
1618 The default diffuse transmittance is zero.
1619 .SH
1620 EXAMPLE
1621 .DS
1622 # Model a perfect spherical diffuser, i.e. light hitting \
1623 either side will be scattered equally in all directions
1624 m wonderland_diffuser =
1625 c
1626 td .5
1627 rd .5
1628 .DE
1629 .SH
1630 SEE ALSO
1631 .LP
1632 .UL c,
1633 .UL ed,
1634 .UL ir,
1635 .UL m,
1636 .UL rd,
1637 .UL rs,
1638 .UL sides,
1639 .UL ts
1640 .ds RH ED
1641 .bp
1642 .SH
1643 NAME
1644 .LP
1645 ed - set the diffuse emittance for the current material
1646 .SH
1647 SYNOPSIS
1648 .LP
1649 .B ed
1650 .I epsilon_d
1651 .SH
1652 DESCRIPTION
1653 .LP
1654 Set the diffuse emittance for the current material to
1655 .I epsilon_d
1656 lumens per square meter using the current color to determine the
1657 spectral characteristics.
1658 Note that this is emittance rather than exitance, and therefore
1659 does not include reflected or transmitted light, which is a function
1660 of the other material settings and the illuminated environment.
1661 .LP
1662 The total lumen output of a convex emitting object
1663 is the radiating area of that object multiplied by its emittance.
1664 Therefore, one can compute the appropriate
1665 .I epsilon_d
1666 value for an emitter by dividing the total lumen output by the
1667 radiating area (in square meters).
1668 .LP
1669 The default emittance is zero.
1670 .SH
1671 EXAMPLE
1672 .DS
1673 # A 100-watt incandescent bulb (1600 lumens) modeled as a sphere
1674 m
1675 c
1676 cct 3000
1677 ed 87712
1678 v cent =
1679 p 0 0 0
1680 sph cent .0381
1681 .DE
1682 .SH
1683 SEE ALSO
1684 .LP
1685 .UL c,
1686 .UL ir,
1687 .UL m,
1688 .UL rd,
1689 .UL rs,
1690 .UL sides,
1691 .UL td,
1692 .UL ts
1693 .ds RH RS
1694 .bp
1695 .SH
1696 NAME
1697 .LP
1698 rs - set the specular reflectance for the current material
1699 .SH
1700 SYNOPSIS
1701 .LP
1702 .B rs
1703 .I "rho_s alpha_r"
1704 .SH
1705 DESCRIPTION
1706 .LP
1707 Set the specular reflectance for the current material to
1708 .I rho_s
1709 using the current color to determine the spectral characteristics.
1710 The surface roughness parameter is set to
1711 .I alpha_r,
1712 which is the RMS height of surface variations over the
1713 autocorrelation distance (equivalent to RMS facet slope).
1714 A roughness value of zero means a perfectly smooth surface, and
1715 values greater than 0.2 are unusual.
1716 (See application notes section 6.1.2 for a comparison between the
1717 roughness parameter and Phong specular power.)\0
1718 .LP
1719 The default specular reflectance is zero.
1720 .SH
1721 EXAMPLE
1722 .DS
1723 # Define a slightly rough brass metallic surface
1724 m rough_brass =
1725 c
1726 cxy .3820 .4035
1727 # 30% specular, 9% diffuse
1728 rs .30 .08
1729 rd .09
1730 .DE
1731 .SH
1732 SEE ALSO
1733 .LP
1734 .UL c,
1735 .UL ed,
1736 .UL ir,
1737 .UL m,
1738 .UL rd,
1739 .UL sides,
1740 .UL td,
1741 .UL ts
1742 .ds RH TS
1743 .bp
1744 .SH
1745 NAME
1746 .LP
1747 ts - set the specular transmittance for the current material
1748 .SH
1749 SYNOPSIS
1750 .LP
1751 .B ts
1752 .I "tau_s alpha_t"
1753 .SH
1754 DESCRIPTION
1755 .LP
1756 Set the specular transmittance for the current material to
1757 .I tau_s
1758 using the current color to determine the spectral characteristics.
1759 The effective surface roughness is set to
1760 .I alpha_t.
1761 Rays will be transmitted with the same distribution as they would
1762 have been reflected with if this roughness value were given to the
1763 .UL rs
1764 entity.
1765 .LP
1766 The default specular transmittance is zero.
1767 .SH
1768 EXAMPLE
1769 .DS
1770 # Define a green glass material (58% transmittance)
1771 m glass =
1772 sides 2
1773 ir 1.52 0
1774 c
1775 rs 0.0725 0
1776 c
1777 cxy .23 .38
1778 ts 0.5815 0
1779 # Define an uncolored translucent plastic (40% transmittance)
1780 m translucent =
1781 sides 2
1782 ir 1.4 0
1783 c
1784 rs .045 0
1785 ts .40 .05
1786 .DE
1787 .SH
1788 SEE ALSO
1789 .LP
1790 .UL c,
1791 .UL ed,
1792 .UL ir,
1793 .UL m,
1794 .UL rd,
1795 .UL rs,
1796 .UL sides,
1797 .UL td
1798 .ds RH IR
1799 .bp
1800 .SH
1801 NAME
1802 .LP
1803 ir - set the complex index of refraction for the current material
1804 .SH
1805 SYNOPSIS
1806 .LP
1807 .B ir
1808 .I "n_real n_imag"
1809 .SH
1810 DESCRIPTION
1811 .LP
1812 Set the index of refraction for the current material to
1813 .I (n_real,n_imag).
1814 If the material is a dielectric (as opposed to metallic), then
1815 .I n_imag
1816 should be zero.
1817 For solid dielectric objects, the material should be made one-sided.
1818 If it is being used for thin objects, then a two-sided
1819 material is appropriate.
1820 (See the
1821 .UL sides
1822 entity.)\0
1823 .LP
1824 The default index of refraction is that of a vacuum, (1,0).
1825 .SH
1826 EXAMPLE
1827 .DS
1828 # Define polished aluminum material
1829 m polished_aluminum =
1830 # Complex index of refraction (from physics table)
1831 ir .770058 6.08351
1832 c
1833 rs .75 0
1834 .DE
1835 .SH
1836 SEE ALSO
1837 .LP
1838 .UL c,
1839 .UL ed,
1840 .UL m,
1841 .UL rd,
1842 .UL rs,
1843 .UL sides,
1844 .UL td,
1845 .UL ts
1846 .ds LH Vertex Entities
1847 .ds RH V
1848 .bp
1849 .SH
1850 NAME
1851 .LP
1852 v - get or set the current vertex context
1853 .SH
1854 SYNOPSIS
1855 .LP
1856 .B v
1857 [
1858 .I id
1859 [
1860 .B =
1861 [
1862 .I template
1863 ]
1864 ]
1865 ]
1866 .SH
1867 DESCRIPTION
1868 .LP
1869 If the
1870 .UL v
1871 keyword is given by itself, then it establishes
1872 the unnamed vertex context, which is the origin with no normal.
1873 This context may be modified, but the changes will not be saved.
1874 (The unnamed vertex is never used except as a source of default
1875 values since all geometric entities call their vertices by name.)\0
1876 .LP
1877 If the keyword is followed by an identifier
1878 .I id,
1879 then it reestablishes a previous context.
1880 If the specified context was never defined, an error will result.
1881 .LP
1882 If the entity is given with an identifier
1883 followed by an equals sign ('='), then a new context is established,
1884 and cleared to the default vertex (the origin).
1885 (Note that the equals sign must be separated from other
1886 arguments by white space to be properly recognized.)\0
1887 If the equals sign is followed by a second identifier
1888 .I template,
1889 then this previously defined vertex will be used as a source of
1890 default values instead.
1891 This may be used to establish a vertex alias, or to modify an
1892 existing vertex and give it a new name.
1893 .LP
1894 A non-zero vertex normal must be given for
1895 certain entities, specifically
1896 .UL ring
1897 and
1898 .UL torus
1899 require a normal direction.
1900 An
1901 .UL f
1902 entity will interpolate vertex normals if given, and
1903 use the polygon plane normal otherwise.
1904 See the
1905 .UL prism
1906 entry for an explanation of how it interprets and uses vertex
1907 normals.
1908 The other entities ignore vertex normals if present.
1909 .LP
1910 The actual position and normal direction for a vertex is determined
1911 at the time of use by a geometric entity.
1912 Specifically, the transformation in effect at the time the vertex is
1913 defined is irrelevant.
1914 The only transformation that matters is the one that is applied to
1915 the geometry itself.
1916 This prevents double-transformation of vertices and allows one set
1917 of vertices to be used for multiple purposes, e.g. the front and
1918 back sides of a drawer.
1919 .SH
1920 EXAMPLE
1921 .DS
1922 # Make a capped cylinder
1923 v end1 =
1924 p 0 0 0
1925 n 0 0 -1
1926 v end2 =
1927 p 0 0 1
1928 cyl end1 1.2 end2
1929 # Forgot normal for end2
1930 v end2
1931 n 0 0 1
1932 ring end1 0 1.2
1933 ring end2 0 1.2
1934 .DE
1935 .SH
1936 SEE ALSO
1937 .LP
1938 .UL cone,
1939 .UL cyl,
1940 .UL f,
1941 .UL n,
1942 .UL p,
1943 .UL prism,
1944 .UL ring,
1945 .UL sph,
1946 .UL torus
1947 .ds RH P
1948 .bp
1949 .SH
1950 NAME
1951 .LP
1952 p - set the point location for the current vertex
1953 .SH
1954 SYNOPSIS
1955 .LP
1956 .B p
1957 .I "px py pz"
1958 .SH
1959 DESCRIPTION
1960 .LP
1961 Set the 3-dimensional position for the current vertex to
1962 .I (px,py,pz).
1963 The actual position of the vertex will be determined by the
1964 transformation in effect at the time the vertex is applied to a
1965 geometric surface entity.
1966 The transform current when the position is set is irrelevant.
1967 .LP
1968 The default vertex position is the origin, (0,0,0).
1969 .SH
1970 EXAMPLE
1971 .DS
1972 # Make a small circle of 6 spheres
1973 v scent =
1974 p 1 0 0
1975 xf -a 6 -rz 60
1976 sph scent .05
1977 xf
1978 .DE
1979 .SH
1980 SEE ALSO
1981 .LP
1982 .UL cone,
1983 .UL cyl,
1984 .UL f,
1985 .UL n,
1986 .UL prism,
1987 .UL ring,
1988 .UL sph,
1989 .UL torus,
1990 .UL v
1991 .ds RH N
1992 .bp
1993 .SH
1994 NAME
1995 .LP
1996 n - set the surface normal direction for the current vertex
1997 .SH
1998 SYNOPSIS
1999 .LP
2000 .B n
2001 .I "dx dy dz"
2002 .SH
2003 DESCRIPTION
2004 .LP
2005 Set the 3-dimensional surface normal for the current vertex to the
2006 normalized vector along
2007 .I (dx,dy,dz).
2008 If this vector is zero, then the surface normal is effectively
2009 unset.
2010 The actual surface normal orientation of the vertex will be determined
2011 by the transformation in effect at the time the vertex is applied to a
2012 geometric surface entity.
2013 The current transform when the normal is set is irrelevant.
2014 .LP
2015 The default vertex normal is the zero vector (i.e. no normal).
2016 .SH
2017 EXAMPLE
2018 .DS
2019 # Make a chain of 10 interlocking doughnuts
2020 v tcent =
2021 p 0 0 0
2022 n 0 1 0
2023 xf -a 10 -rx 90 -t .2 0 0
2024 torus tcent .1 .2
2025 xf
2026 .DE
2027 .SH
2028 SEE ALSO
2029 .LP
2030 .UL f,
2031 .UL p,
2032 .UL prism,
2033 .UL ring,
2034 .UL torus,
2035 .UL v
2036 .ds LH Geometric Entities
2037 .ds RH F
2038 .bp
2039 .SH
2040 NAME
2041 .LP
2042 f - create an N-sided polygonal face
2043 .SH
2044 SYNOPSIS
2045 .LP
2046 .B f
2047 .I "v1 v2 ... vN"
2048 .SH
2049 DESCRIPTION
2050 .LP
2051 Create a polygonal face made of the current material
2052 by connecting the named vertices in order, and connecting the last
2053 vertex to the first.
2054 There must be at least three vertices, and if any vertex is undefined,
2055 an error will result.
2056 .LP
2057 The surface orientation is determined by the right-hand rule; when
2058 the curl of the fingers follows the given order of the vertices, the
2059 surface normal points in the thumb direction.
2060 Face vertices should be coplanar, though this is difficult to guarantee
2061 in a 3-dimensional specification.
2062 .LP
2063 If any vertices have associated surface normals, they will be used
2064 instead of the average plane normal, though it is safest to specify
2065 either all normals or no normals, and to stick with triangles
2066 when normals are used.
2067 Also, specified normals should point in the general direction of the
2068 surface for best results.
2069 .LP
2070 There is no explicit representation of holes in MGF. A hole must be
2071 represented implicitly by connecting vertices to form "seams." For
2072 example, a wall with a window in it might look as shown in Figure 1.
2073 In many systems, the wall itself would be represented with the first
2074 list of vertices, (v1,v2,v3,v4) and the hole associated with that
2075 wall as a second set of vertices (v5,v6,v7,v8). In MGF, we must
2076 give the whole thing as a single polygon, connecting the vertices so
2077 as to create a "seam," as shown in Figure 2.
2078 This could be written in MGF as "f v1 v2 v3 v4 v5 v6 v7 v8 v5 v4".
2079 .LP
2080 It is very important that the order of the hole be opposite to the
2081 order of the outer perimeter, otherwise the polygon will be
2082 "twisted" on top of itself. Note also that the seam was traversed
2083 in both directions, once going from v4 to v5, and again returning
2084 from v5 to v4. This is a necessary condition for a proper seam.
2085 .LP
2086 The choice of vertices to make into a seam is somewhat arbitrary, but
2087 some rendering systems may not give sane results if you cross over a
2088 hole with part of your seam. If we had chosen to create the seam
2089 between v2 and v5 in the above example instead of v4 and v5, the seam
2090 would cross our hole and may not render correctly\(dg.
2091 .FS
2092 \(dgFor systems that
2093 are sensitive to this, it is probably safest for their MGF
2094 loader/translator to re-expresses seams in terms of holes again, which can
2095 be done easily so long as vertices are shared in the fashion shown.
2096 .FE
2097 .bp
2098 Replace this page with the first page from "figures.ps".
2099 .bp
2100 .SH
2101 EXAMPLE
2102 .DS
2103 # Make a pyramid
2104 v apex =
2105 p 1 1 1
2106 v base0 =
2107 p 0 0 0
2108 v base1 =
2109 p 0 2 0
2110 v base2 =
2111 p 2 2 0
2112 v base3 =
2113 p 2 0 0
2114 # Bottom
2115 f base0 base1 base2 base3
2116 # Sides
2117 f base0 apex base1
2118 f base1 apex base2
2119 f base2 apex base3
2120 f base3 apex base0
2121 .DE
2122 .SH
2123 SEE ALSO
2124 .LP
2125 .UL cone,
2126 .UL cyl,
2127 .UL m,
2128 .UL prism,
2129 .UL ring,
2130 .UL sph,
2131 .UL torus,
2132 .UL v
2133 .ds RH SPH
2134 .bp
2135 .SH
2136 NAME
2137 .LP
2138 sph - create a sphere
2139 .SH
2140 SYNOPSIS
2141 .LP
2142 .B sph
2143 .I "vc rad"
2144 .SH
2145 DESCRIPTION
2146 .LP
2147 Create a sphere made of the current material with its center at the
2148 named vertex
2149 .I vc
2150 and a radius of
2151 .I rad.
2152 If the vertex is undefined an error will result.
2153 .LP
2154 The surface normal is usually directed outward, but will be directed
2155 inward if the given radius is negative.
2156 (This typically matters only for one-sided materials.)\0
2157 A zero radius is illegal.
2158 .SH
2159 EXAMPLE
2160 .DS
2161 # Create a thick glass sphere with a hollow inside
2162 m glass =
2163 sides 1
2164 ir 1.52 0
2165 c
2166 rs .06 0
2167 ts .88 0
2168 v cent =
2169 p 0 0 1.1
2170 # The outer shell
2171 sph cent .1
2172 # The inner bubble
2173 sph cent -.08
2174 .DE
2175 .SH
2176 SEE ALSO
2177 .LP
2178 .UL cone,
2179 .UL cyl,
2180 .UL f,
2181 .UL m,
2182 .UL prism,
2183 .UL ring,
2184 .UL torus,
2185 .UL v
2186 .ds RH CYL
2187 .bp
2188 .SH
2189 NAME
2190 .LP
2191 cyl - create an open-ended, truncated right cylinder
2192 .SH
2193 SYNOPSIS
2194 .LP
2195 .B cyl
2196 .I "v1 rad v2"
2197 .SH
2198 DESCRIPTION
2199 .LP
2200 Create a truncated right cylinder of radius
2201 .I rad
2202 using the current material, starting at the named vertex
2203 .I v1
2204 and continuing to
2205 .I v2.
2206 The ends will be open, but may be capped using the
2207 .UL ring
2208 entity if desired.
2209 .LP
2210 The surface normal will usually be directed outward, but may be
2211 directed inward by giving a negative value for
2212 .I rad.
2213 A zero radius is illegal, and
2214 .I v1
2215 cannot equal
2216 .I v2.
2217 .SH
2218 EXAMPLE
2219 .DS
2220 # A stylus with one rounded and one pointed end
2221 o stylus
2222 v vtip0 =
2223 p 0 0 0
2224 v vtip1 =
2225 p 0 0 .005
2226 v vend =
2227 p 0 0 .05
2228 cyl vtip1 .0015
2229 sph vend .0015
2230 cone vtip0 0 vtip1 .0015
2231 o
2232 .DE
2233 .SH
2234 SEE ALSO
2235 .LP
2236 .UL cone,
2237 .UL f,
2238 .UL m,
2239 .UL prism,
2240 .UL ring,
2241 .UL sph,
2242 .UL torus,
2243 .UL v
2244 .ds RH CONE
2245 .bp
2246 .SH
2247 NAME
2248 .LP
2249 cone - create an open-ended, truncated right cone
2250 .SH
2251 SYNOPSIS
2252 .LP
2253 .B cone
2254 .I "v1 rad1 v2 rad2"
2255 .SH
2256 DESCRIPTION
2257 .LP
2258 Create a truncated right cone using the current material.
2259 The starting radius is
2260 .I rad1
2261 at
2262 .I v1
2263 and the ending radius is
2264 is
2265 .I rad2
2266 at
2267 .I v2.
2268 The ends will be open, but may be capped using the
2269 .UL ring
2270 entity if desired.
2271 .LP
2272 The surface normal will usually be directed outward, but may be
2273 directed inward by giving negative values for both radii.
2274 (It is illegal for the signs of the two radii to disagree.)\0
2275 One but not both radii may be zero, indicating that the cone comes
2276 to a point.
2277 .LP
2278 Although it is not strictly forbidden to have equal cone radii, the
2279 .UL cyl
2280 entity should be used in such cases.
2281 Likewise, the
2282 .UL ring
2283 entity must be used if
2284 .I v1
2285 and
2286 .I v2
2287 are equal.
2288 .SH
2289 EXAMPLE
2290 .DS
2291 # A parasol
2292 o parasol
2293 v v1 =
2294 p 0 0 0
2295 v v2 =
2296 p 0 0 .75
2297 v v3 =
2298 p 0 0 .7
2299 m handle_mat
2300 cyl v1 .002 v2
2301 m parasol_paper
2302 cyl v2 0 v3 .33
2303 o
2304 .DE
2305 .SH
2306 SEE ALSO
2307 .LP
2308 .UL cyl,
2309 .UL f,
2310 .UL m,
2311 .UL prism,
2312 .UL ring,
2313 .UL sph,
2314 .UL torus,
2315 .UL v
2316 .ds RH PRISM
2317 .bp
2318 .SH
2319 NAME
2320 .LP
2321 prism - create a closed right prism
2322 .SH
2323 SYNOPSIS
2324 .LP
2325 .B prism
2326 .I "v1 v2 ... vN length"
2327 .SH
2328 DESCRIPTION
2329 .LP
2330 Create a closed right prism using the current material.
2331 One end face will be enclosed by the named vertices, and the
2332 opposite end face will be a mirror image at a distance
2333 .I length
2334 from the original.
2335 The edges will be extruded into N quadrilaterals connecting
2336 the two end faces.
2337 .LP
2338 The order of vertices determines the original face orientation
2339 according to the right-hand rule as explained for the
2340 .UL f
2341 entity.
2342 Normally, the prism is extruded in the direction opposite to the
2343 original surface normal, resulting in faces that all point outward.
2344 If the specified
2345 .I length
2346 is negative, the prism will be extruded above the original face
2347 and all surface normals will point inward.
2348 .LP
2349 If the vertices have associated normals, they are applied to the
2350 side faces only, and should generally point in the appropriate
2351 direction (i.e. in or out depending on whether
2352 .I length
2353 is negative or positive).
2354 .SH
2355 EXAMPLE
2356 .DS
2357 # Make a unit cube starting at the origin and \\\\
2358 extending to the positive octant
2359 v cv0 =
2360 p 0 0 0
2361 v cv1 =
2362 p 0 1 0
2363 v cv2 =
2364 p 1 1 0
2365 v cv3 =
2366 p 1 0 0
2367 # Right hand rule has original face looking in -Z direction
2368 prism cv0 cv1 cv2 cv3 1
2369 .DE
2370 .SH
2371 SEE ALSO
2372 .LP
2373 .UL cyl,
2374 .UL cone,
2375 .UL f,
2376 .UL m,
2377 .UL ring,
2378 .UL sph,
2379 .UL torus,
2380 .UL v
2381 .ds RH RING
2382 .bp
2383 .SH
2384 NAME
2385 .LP
2386 ring - create a circular ring with inner and outer radii
2387 .SH
2388 SYNOPSIS
2389 .LP
2390 .B cyl
2391 .I "vc rmin rmax"
2392 .SH
2393 DESCRIPTION
2394 .LP
2395 Create a circular face of the current material centered on the named
2396 vertex
2397 .I vc
2398 with an inner radius of
2399 .I rmin
2400 and an outer radius of
2401 .I rmax.
2402 The surface orientation is determined by the normal vector
2403 associated with
2404 .I vc.
2405 If this vertex is undefined or has no normal, an error will result.
2406 The minimum radius may be equal to but not less than zero, and the
2407 maximum radius must be strictly greater than the minimum.
2408 .SH
2409 EXAMPLE
2410 .DS
2411 # The proverbial brass ring
2412 o brass_ring
2413 m brass
2414 v end1 =
2415 p 0 -.005 0
2416 n 0 -1 0
2417 v end2 =
2418 p 0 .005 0
2419 n 0 1 0
2420 ring end1 .02 .03
2421 cyl end1 .03 end2
2422 ring end2 .02 .03
2423 cyl end2 -.02 end1
2424 o
2425 .DE
2426 .SH
2427 SEE ALSO
2428 .LP
2429 .UL cyl,
2430 .UL cone,
2431 .UL f,
2432 .UL m,
2433 .UL prism,
2434 .UL sph,
2435 .UL torus,
2436 .UL v
2437 .ds RH TORUS
2438 .bp
2439 .SH
2440 NAME
2441 .LP
2442 torus - create a regular torus
2443 .SH
2444 SYNOPSIS
2445 .LP
2446 .B torus
2447 .I "vc rmin rmax"
2448 .SH
2449 DESCRIPTION
2450 .LP
2451 Create a torus of the current material centered on the named vertex
2452 .I vc
2453 with an inner radius of
2454 .I rmin
2455 and an outer radius of
2456 .I rmax.
2457 The plane of the torus will be perpendicular to the normal vector
2458 associated with
2459 .I vc.
2460 If this vertex is undefined or has no normal, an error will result.
2461 .LP
2462 If a torus with an inward facing surface normal is desired,
2463 .I rmin
2464 and
2465 .I rmax
2466 may be negative.
2467 The minimum radius may be zero, but may not be negative when
2468 .I rmax
2469 is positive or vice versa.
2470 The magnitude or
2471 .I rmax
2472 must always be strictly greater than that of
2473 .I rmin.
2474 .SH
2475 EXAMPLE
2476 .DS
2477 # The proverbial brass ring -- easy grip version
2478 o brass_ring
2479 m brass
2480 v center =
2481 p 0 0 0
2482 n 0 1 0
2483 torus center .02 .03
2484 o
2485 .DE
2486 .SH
2487 SEE ALSO
2488 .LP
2489 .UL cyl,
2490 .UL cone,
2491 .UL f,
2492 .UL m,
2493 .UL prism,
2494 .UL ring,
2495 .UL sph,
2496 .UL v
2497 .ds RH
2498 .ds LH
2499 .bp
2500 .NH
2501 MGF Translators
2502 .LP
2503 Initially, there are four translators for MGF data, but only
2504 one of these is distributed with the MGF parser itself,
2505 .I mgfilt.
2506 Two of the other translators,
2507 .I mgf2rad
2508 and
2509 .I rad2mgf
2510 convert between MGF and the Radiance scene description language,
2511 and are distributed for free with the rest of the Radiance
2512 package\(dg.
2513 .FS
2514 \(dgRadiance is available by anonymous ftp from hobbes.lbl.gov and
2515 nestor.epfl.ch, or by WWW from
2516 "http://radsite.lbl.gov/radiance/HOME.html"
2517 .FE
2518 A third translator,
2519 .I mgf2meta,
2520 converts to a 2-dimensional line plot, and is also
2521 distributed with Radiance.
2522 .LP
2523 Mgfilt is a simple but useful utility that takes MGF on its input
2524 and produces MGF on its output.
2525 It uses the parser to convert entities that are not wanted or
2526 understood, and produces only the requested ones.
2527 This is useful for seeing what exactly a program must understand
2528 when it supports a given set of entities, and may serve as a
2529 substitute for linking to the parser library for programmers who
2530 wish to interpret the ASCII input directly but without all the
2531 unwanted entities.
2532 In future releases of MGF, this utility will also be handy for
2533 taking new entities and producing older versions of MGF for
2534 translators that have not yet been updated properly.
2535 .ds LH Translators
2536 .ds RH MGFILT
2537 .bp
2538 .SH
2539 NAME
2540 .LP
2541 mgfilt - get usable MGF entities from input
2542 .SH
2543 SYNOPSIS
2544 .LP
2545 .B mgfilt
2546 .B version
2547 [
2548 .B input ..
2549 ]
2550 .br
2551 or
2552 .br
2553 .B mgfilt
2554 .B "e1,e2,.."
2555 [
2556 .B input ..
2557 ]
2558 .SH
2559 DESCRIPTION
2560 .LP
2561 .I Mgfilt
2562 takes one or more MGF input files and converts all the entities to
2563 the types listed.
2564 In the first form, a single integer is given for the
2565 .I version
2566 of MGF that is to be produced.
2567 Since MGF is in its first major release, this is not yet a useful
2568 form, but it will be when the second major release comes out.
2569 .LP
2570 In the second form,
2571 .I mgfilt
2572 produces only the entities listed in the first argument, which must
2573 be comma-separated.
2574 The listed entity order is not important, but all entities given
2575 must be defined in the current version of MGF.
2576 Unknown entities will be summarily discarded on the input, and a
2577 warning message will be printed to the standard error.
2578 .SH
2579 EXAMPLES
2580 .LP
2581 To take an MGF version 3 file and send it to a version 2
2582 translator:
2583 .IP
2584 mgfilt 2 input.mgf | mgf2rad > input.rad
2585 .LP
2586 To take an MGF file and produce only flat polygonal faces
2587 with no materials:
2588 .IP
2589 mgfilt f,v,p,xf input.mgf > flatpoly.mgf
2590 .SH
2591 SEE ALSO
2592 .LP
2593 mgf2rad, rad2mgf
2594 .ds RH MGF2RAD
2595 .bp
2596 .SH
2597 NAME
2598 .LP
2599 mgf2rad - convert Materials and Geometry Format file to RADIANCE description
2600 .SH
2601 SYNOPSIS
2602 .LP
2603 .B mgf2rad
2604 [
2605 .B "\-m matfile"
2606 ][
2607 .B "\-e mult"
2608 ][
2609 .B "\-g dist"
2610 ]
2611 [
2612 .B input ..
2613 ]
2614 .SH
2615 DESCRIPTION
2616 .LP
2617 .I Mgf2rad
2618 converts one or more Materials and Geometry Format (MGF)
2619 files to a RADIANCE scene description.
2620 By definition, all output dimensions are in meters.
2621 The material names and properties
2622 for the surfaces will be those assigned in MGF.
2623 Any materials not defined in MGF will result in an error during
2624 translation.
2625 Light sources are described inline as IES luminaire files, and
2626 .I mgf2rad
2627 calls the program
2628 .I ies2rad(1)
2629 to translate these files.
2630 If an IES file in turn contains an MGF description of the local
2631 fixture geometry, this may result in a recursive call to
2632 .I mgf2rad,
2633 which is normal and should be transparent.
2634 The only side-effect of this additional translation is the
2635 appearance of other RADIANCE scene and data files produced
2636 automatically by
2637 .I ies2rad.
2638 .LP
2639 The
2640 .I \-m
2641 option may be used to put all the translated materials into a separate
2642 RADIANCE file.
2643 This is not always advisable, as any given material name may be
2644 reused at different points in the MGF description, and writing them
2645 to a separate file loses the contextual association between
2646 materials and surfaces.
2647 As long as unique material names are used throughout the MGF
2648 description and material properties are not redefined, there
2649 will be no problem.
2650 Note that this is the only way to get all the translated materials
2651 into a single file, since no output is produced for unreferenced
2652 materials; i.e. translating just the MGF materials does not work.
2653 .LP
2654 The
2655 .I \-e
2656 option may be used to multiply all the emission values by the
2657 given
2658 .I mult
2659 factor.
2660 The
2661 .I \-g
2662 option may be used to establish a glow distance (in meters)
2663 for all emitting surfaces.
2664 These two options are employed principally by
2665 .I ies2rad,
2666 and are not generally useful to most users.
2667 .SH
2668 EXAMPLES
2669 .LP
2670 To translate two MGF files into one RADIANCE materials file and
2671 one geometry file:
2672 .IP
2673 mgf2rad -m materials.rad building1.mgf building2.mgf > building1+2.rad
2674 .LP
2675 To create an octree directly from two MGF files and one RADIANCE
2676 file:
2677 .IP
2678 oconv '\\!mgf2rad materials.mgf scene.mgf' source.rad > scene.oct
2679 .SH
2680 FILES
2681 .LP
2682 tmesh.cal Used to smooth polygonal geometry
2683 .br
2684 *.rad RADIANCE source descriptions created by ies2rad
2685 .br
2686 *.dat RADIANCE source data created by ies2rad
2687 .br
2688 source.cal Used for IES source coordinates
2689 .SH
2690 AUTHOR
2691 .LP
2692 Greg Ward
2693 .SH
2694 SEE ALSO
2695 .LP
2696 ies2rad(1), mgf2meta(1), obj2rad(1), oconv(1), rad2mgf(1), xform(1)
2697 .ds RH RAD2MGF
2698 .bp
2699 .SH
2700 NAME
2701 .LP
2702 rad2mgf - convert RADIANCE scene description to Materials and Geometry Format
2703 .SH
2704 SYNOPSIS
2705 .LP
2706 .B rad2mgf
2707 [
2708 .B \-dU
2709 ]
2710 [
2711 .B input ..
2712 ]
2713 .SH
2714 DESCRIPTION
2715 .LP
2716 .I Rad2mgf
2717 converts one or more RADIANCE scene files
2718 to the Materials and Geometry Format (MGF).
2719 Input units are specified with the
2720 .I \-mU
2721 option, where
2722 .I U
2723 is one of 'm' (meters), 'c' (centimeters), 'f' (feet) or 'i'
2724 (inches).
2725 The assumed unit is meters, which is the required output unit for
2726 MGF (thus the need to know).
2727 If the input dimensions are in none of these units, then the user
2728 should apply
2729 .I xform(1)
2730 with the
2731 .I \-s
2732 option to bring the units into line prior to translation.
2733 .LP
2734 The MGF material names and properties
2735 for the surfaces will be those assigned in RADIANCE.
2736 If a referenced material has not been defined, then its name will
2737 be invoked in the MGF output without definition, and the description
2738 will be incomplete.
2739 .SH
2740 LIMITATIONS
2741 .LP
2742 Although MGF supports all of the geometric types and the most
2743 common material types used in RADIANCE, there is currently no
2744 support for advanced BRDF materials, patterns, textures or mixtures.
2745 Also, the special types "source" and "antimatter" are not supported,
2746 and all light source materials are converted to simple diffuse emitters
2747 (except "illum" materials, which are converted to their alternates).
2748 These primitives are reproduced as comments in the output and
2749 must be replaced manually if necessary.
2750 .LP
2751 The RADIANCE "instance" type is treated specially.
2752 .I Rad2mgf
2753 converts each instance to an MGF include statement, using the corresponding
2754 transformation and a file name derived from the octree name.
2755 (The original octree suffix is replaced by ".mgf".)\0
2756 For this to work, the user must separately create the referenced
2757 MGF files from the original RADIANCE descriptions.
2758 The description file names can usually be determined using the
2759 .I getinfo(1)
2760 command run on the octrees in question.
2761 .SH
2762 EXAMPLES
2763 .LP
2764 To convert three RADIANCE files (in feet) to one MGF file:
2765 .IP
2766 mgf2rad -df file1.rad file2.rad file3.rad > scene.mgf
2767 .LP
2768 To translate a RADIANCE materials file to MGF:
2769 .IP
2770 mgf2rad materials.rad > materials.mgf
2771 .SH
2772 AUTHOR
2773 .LP
2774 Greg Ward
2775 .SH
2776 SEE ALSO
2777 .LP
2778 getinfo(1), ies2rad(1), mgf2meta(1), mgf2rad(1), obj2rad(1), oconv(1), xform(1)
2779 .ds RH MGF2META
2780 .bp
2781 .SH
2782 NAME
2783 .LP
2784 mgf2meta - convert Materials and Geometry Format file to Metafile graphics
2785 .SH
2786 SYNOPSIS
2787 .LP
2788 .B mgf2meta
2789 [
2790 .B "-t threshold"
2791 ]
2792 .B "{x|y|z} xmin xmax ymin ymax zmin zmax"
2793 [
2794 .B input ..
2795 ]
2796 .SH
2797 DESCRIPTION
2798 .LP
2799 .I Mgf2meta
2800 converts one or more Materials and Geometry Format (MGF)
2801 files to a 2-D orthographic projection along the selected axis in the
2802 .I metafile(1)
2803 graphics format.
2804 All geometry is clipped to the specified bounding box, and the
2805 resulting orientation is as follows:
2806 .sp .5
2807 .nf
2808 Projection Orientation
2809 ======= ========
2810 x Y-axis right, Z-axis up
2811 y Z-axis right, X-axis up
2812 z X-axis right, Z-axis up
2813 .fi
2814 .LP
2815 If multiple input files are given, the first file prints in black,
2816 the second prints in red, the third in green and the fourth in blue.
2817 If more than four input files are given, they cycle through the
2818 colors again in three other line types: dashed, dotted and
2819 dot-dashed.
2820 .LP
2821 The
2822 .I \-t
2823 option may be used to randomly throw out line segments that are
2824 shorter than the given
2825 .I threshold
2826 (given as a fraction of the plot width).
2827 Segments are included with a
2828 probability equal to the square of the line length over the square
2829 of the threshold.
2830 This can greatly reduce the number of lines in the drawing (and
2831 therefore improve the drawing speed) with only a modest loss in
2832 quality.
2833 A typical value for this parameter is 0.005.
2834 .LP
2835 All MGF material information is ignored on the input.
2836 .SH
2837 EXAMPLES
2838 .LP
2839 To project two MGF files along the Z-axis and display them under
2840 X11:
2841 .IP
2842 mgf2meta z 0 10 0 15 0 9 building1.mgf building2.mgf | x11meta
2843 .LP
2844 To convert a RADIANCE scene to a line drawing in RADIANCE picture
2845 format:
2846 .IP
2847 rad2mgf scene.rad | mgf2meta x `getbbox -h scene.rad` | meta2tga |
2848 ra_t8 -r > scene.pic
2849 .SH
2850 AUTHOR
2851 .LP
2852 Greg Ward
2853 .SH
2854 SEE ALSO
2855 .LP
2856 getbbox(1), meta2tga(1), metafile(5), mgf2rad(1), pflip(1),
2857 protate(1), psmeta(1), ra_t8(1), rad2mgf(1), t4014(1), x11meta(1)
2858 .ds RH
2859 .ds LH
2860 .bp
2861 .NH
2862 MGF Parser Library
2863 .LP
2864 The principal motivation for creating a standard parser library for
2865 MGF is to make it easy for software developers to offer some base
2866 level of compliance.
2867 The key to making MGF easy to support in fact is the parser, which
2868 has the ability to express higher order entities in terms of
2869 lower order ones.
2870 For example, tori are part of the MGF specification, but if a given
2871 program or translator does not support them, the parser will convert
2872 them to cones.
2873 If cones are not supported either, it will convert them further into
2874 smoothed polygons.
2875 If smoothing (vertex normal information) is not supported, it will
2876 be ignored and the program will just get flat polygons.
2877 This is done in such a way that future versions of the standard may
2878 include new entities that old software does not even have to know
2879 about, and they will be converted appropriately.
2880 Forward compatibility is thus built right into the parser loading
2881 mechanism itself -- the programmer simply links to the new code and
2882 the new standard is supported without any further changes.
2883 .SH
2884 Language
2885 .LP
2886 The provided MGF parser is written in ANSI-C.
2887 This language was chosen for reasons of portability and efficiency.
2888 Almost all systems support some form of ANSI-compatible C, and many
2889 languages can cross-link to C libraries without modification.
2890 Backward compatibility to Kernighan and Ritchie C is achieved by
2891 compiling with the -DNOPROTO flag.
2892 .LP
2893 All of the data structures and prototypes needed for the library
2894 are in the header file "parser.h".
2895 This file is the best resource for the parser and is updated with
2896 each MGF release.
2897 .SH
2898 Mechanism
2899 .LP
2900 The parser works by a simple callback mechanism to routines that
2901 actually interpret the individual entities.
2902 Some of these routines will belong to the calling program, and some
2903 will be entity support routines included in the library itself.
2904 There is a global array of function pointers, called
2905 .I mg_ehand.
2906 It is defined thus:
2907 .DS
2908 extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
2909 .DE
2910 Before parsing begins, this dispatch table is initialized to point to the
2911 routines that will handle each supported entity.
2912 Every entity handler has the same basic prototype, which is the
2913 same as the
2914 .I main
2915 function, i.e:
2916 .DS
2917 extern int \f2handler\f1(int argc, char **argv);
2918 .DE
2919 The first argument is the number of words in the MGF entity
2920 (counting the entity itself) and the second argument is an array of
2921 nul-terminated strings with the entity and its arguments.
2922 The function should return zero or one of the error
2923 codes defined in "parser.h".
2924 A non-zero return value causes the parser to abort, returning the
2925 error up through its call stack to the entry function, usually
2926 .I mg_load.
2927 .LP
2928 A special function pointer for undefined entities is
2929 defined as follows:
2930 .DS
2931 extern int (*mg_uhand)(int argc, char **argv);
2932 .DE
2933 By default, this points to the library function
2934 .I mg_defuhand,
2935 which prints an error message on the first unknown entity and keeps a
2936 count from then on, which is stored in the global unsigned integer
2937 .I mg_nunknown.
2938 If the
2939 .I mg_uhand
2940 pointer is assigned a value of NULL instead, parsing will abort at the
2941 first unrecognized entity.
2942 The reason this is not the default action is that ignoring unknown entities
2943 offers a certain base level of forward compatibility.
2944 Ignoring things one does not understand is not the best approach, but it
2945 is usually better than quitting with an error message if the input is
2946 in fact valid, but is a later version of the standard.
2947 The real solution is to update the interpreter by linking to a new version
2948 of the parser, or use a new version of the
2949 .I mgfilt
2950 command to convert the new MGF input to an older standard.
2951 .LP
2952 The
2953 .I mg_uhand
2954 pointer may also be used to customize the language for a particular
2955 application by adding entities, though this is discouraged because it
2956 tends to weaken the standard.
2957 .LP
2958 The skeletal framework for an MGF loader or translator is to assign
2959 function pointers to the
2960 .I mg_ehand
2961 array, call the parser initialization function
2962 .I mg_init,
2963 then call the file loader function
2964 .I mg_load
2965 once for each input file.
2966 This will in turn make calls back to the functions assigned to
2967 .I mg_ehand.
2968 To give a simple example, let us look at a
2969 translator that understands only flat polygonal faces, putting out
2970 vertex locations immediately after each "face" keyword:
2971 .DS
2972 #include <stdio.h>
2973 #include "parser.h"
2974
2975 int
2976 myfaceh(ac, av) /* face handling routine */
2977 int ac;
2978 char **av;
2979 {
2980 C_VERTEX *vp; /* vertex structure pointer */
2981 FVECT vert; /* vertex point location */
2982 int i;
2983
2984 if (ac < 4) /* check # arguments */
2985 return(MG_EARGC);
2986 printf("face\\\\n"); /* begin face output */
2987 for (i = 1; i < ac; i++) {
2988 if ((vp = c_getvert(av[i])) == NULL) /* vertex from name */
2989 return(MG_EUNDEF);
2990 xf_xfmpoint(vert, vp->p); /* apply transform */
2991 printf("%15.9f %15.9f %15.9f\\\\n",
2992 vert[0], vert[1], vert[2]); /* output vertex */
2993 }
2994 printf(";\\\\n"); /* end of face output */
2995 return(MG_OK); /* normal exit */
2996 }
2997
2998 main(argc, argv) /* translate MGF file(s) */
2999 int argc;
3000 char **argv;
3001 {
3002 int i;
3003 /* initialize dispatch table */
3004 mg_ehand[MG_E_FACE] = myfaceh; /* ours */
3005 mg_ehand[MG_E_VERTEX] = c_hvertex; /* parser lib */
3006 mg_ehand[MG_E_POINT] = c_hvertex; /* parser lib */
3007 mg_ehand[MG_E_XF] = xf_handler; /* parser lib */
3008 mg_init(); /* initialize parser */
3009 for (i = 1; i < argc; i++) /* load each file argument */
3010 if (mg_load(argv[i]) != MG_OK) /* and check for error */
3011 exit(1);
3012 exit(0); /* all done! */
3013 }
3014 .DE
3015 Hopefully, this example demonstrates just how easy it is to
3016 write an MGF translator.
3017 Of course, translators get more complicated the more entity
3018 types they support, but the point is that one does not
3019 .I have
3020 to support every entity -- the parser handles what the translator
3021 does not.
3022 Also, the library includes many general entity handlers,
3023 further reducing the burden on the programmer.
3024 This same principle means that it is not necessary to modify an
3025 existing program to accommodate a new version of MGF -- one need only
3026 link to the new parser library to comply with the new standard.
3027 .SH
3028 Division of Labor
3029 .LP
3030 As seen in the previous example, there are two parser routines that
3031 are normally called directly in an MGF translator or loader program.
3032 The first is
3033 .I mg_init,
3034 which takes no arguments but relies on the program having
3035 initialized those parts of the global
3036 .I mg_ehand
3037 array it cares about.
3038 The second routine is
3039 .I mg_load,
3040 which is called once on each input file.
3041 (A third routine,
3042 .I mg_clear,
3043 may be called to free the parser data structures after each file or
3044 after all files, if the program plans to continue rather than
3045 exit.)\0
3046 .LP
3047 The rest of the routines in a translator or loader program are
3048 called indirectly through the
3049 .I mg_ehand
3050 dispatch table, and they are the ones that do the real work of
3051 supporting the MGF entities.
3052 In addition to converting or discarding entities that the calling
3053 program does not know or care about, the parser library includes a
3054 set of context handlers that greatly simplify the translation
3055 process.
3056 There are three handlers for each of the three named contexts and
3057 their constituents, and two handlers for the two hierarchical
3058 context entities.
3059 To use these handlers, one simply sets the appropriate positions in the
3060 .I mg_ehand
3061 dispatch table to point to these functions.
3062 Additional functions and global data structures provide convenient
3063 access to the relevant contexts, and all of these are detailed in
3064 the following manual pages.
3065 .ds LH Basic Parser Routines
3066 .ds RH MG_INIT
3067 .bp
3068 .SH
3069 NAME
3070 .LP
3071 mg_init, mg_ehand, mg_uhand - initialize MGF entity handlers
3072 .SH
3073 SYNOPSIS
3074 .LP
3075 #include "parser.h"
3076 .LP
3077 .B void
3078 mg_init(
3079 .B void
3080 )
3081 .LP
3082 .B int
3083 mg_defuhand(
3084 .B int
3085 argc,
3086 .B char
3087 **argv )
3088 .LP
3089 .B "extern int"
3090 (*mg_ehand[MG_NENTITIES])(
3091 .B int
3092 argc,
3093 .B char
3094 **argv )
3095 .LP
3096 .B "extern int"
3097 (*mg_uhand)(
3098 .B int
3099 argc,
3100 .B char
3101 **argv )
3102 .LP
3103 .B "extern unsigned"
3104 mg_nunknown
3105 .SH
3106 DESCRIPTION
3107 .LP
3108 The parser dispatch table,
3109 .I mg_ehand
3110 is initially set to all NULL pointers, and it
3111 is the duty of the calling program to assign entity handler functions to
3112 each of the supported entity positions in the array.
3113 The entities are given in the include file "parser.h" as the
3114 following:
3115 .DS
3116 #define MG_E_COMMENT 0 /* # */
3117 #define MG_E_COLOR 1 /* c */
3118 #define MG_E_CCT 2 /* cct */
3119 #define MG_E_CONE 3 /* cone */
3120 #define MG_E_CMIX 4 /* cmix */
3121 #define MG_E_CSPEC 5 /* cspec */
3122 #define MG_E_CXY 6 /* cxy */
3123 #define MG_E_CYL 7 /* cyl */
3124 #define MG_E_ED 8 /* ed */
3125 #define MG_E_FACE 9 /* f */
3126 #define MG_E_INCLUDE 10 /* i */
3127 #define MG_E_IES 11 /* ies */
3128 #define MG_E_IR 12 /* ir */
3129 #define MG_E_MATERIAL 13 /* m */
3130 #define MG_E_NORMAL 14 /* n */
3131 #define MG_E_OBJECT 15 /* o */
3132 #define MG_E_POINT 16 /* p */
3133 #define MG_E_PRISM 17 /* prism */
3134 #define MG_E_RD 18 /* rd */
3135 #define MG_E_RING 19 /* ring */
3136 #define MG_E_RS 20 /* rs */
3137 #define MG_E_SIDES 21 /* sides */
3138 #define MG_E_SPH 22 /* sph */
3139 #define MG_E_TD 23 /* td */
3140 #define MG_E_TORUS 24 /* torus */
3141 #define MG_E_TS 25 /* ts */
3142 #define MG_E_VERTEX 26 /* v */
3143 #define MG_E_XF 27 /* xf */
3144
3145 #define MG_NENTITIES 28 /* total # entities */
3146 .DE
3147 .LP
3148 Once the
3149 .I mg_ehand
3150 array has been set by the program, the
3151 .I mg_init
3152 routine must be called to complete the initialization process.
3153 This should be done once and only once per invocation, before any other
3154 parser routines are called.
3155 .LP
3156 The
3157 .I mg_uhand
3158 variable points to the current handler for unknown entities
3159 encountered on the input.
3160 Its default value points to the
3161 .I mg_defuhand
3162 function, which simply increments the global variable
3163 .I mg_nunknown,
3164 printing a warning message on the standard error on the first
3165 offense.
3166 (This message may be avoided by incrementing
3167 .I mg_nunknown
3168 before processing begins.)\0
3169 If
3170 .I mg_uhand
3171 is assigned a value of NULL, then an unknown entity will return an
3172 .I MG_EUNK
3173 error, which will cause the parser to abort.
3174 (See the
3175 .I mg_load
3176 page for a list of errors.)\0
3177 If the
3178 .I mg_uhand
3179 pointer is assigned to another function, that function will receive
3180 any unknown entities and their arguments, and the parsing will
3181 abort if the new function returns a non-zero error value.
3182 This offers a convenient way to customize the language by adding
3183 non-standard entities.
3184 .SH
3185 DIAGNOSTICS
3186 .LP
3187 If an inconsistent set of entities has been set for support, the
3188 .I mg_init
3189 routine will print an informative message to standard error and abort
3190 the calling program with a call to
3191 .I exit.
3192 This is normally unacceptable behavior for a library routine, but since
3193 such an error indicates a fault with the calling program itself,
3194 recovery is impossible.
3195 .SH
3196 SEE ALSO
3197 .LP
3198 mg_load, mg_handle
3199 .ds RH MG_LOAD
3200 .bp
3201 .SH
3202 NAME
3203 .LP
3204 mg_load, mg_clear, mg_file, mg_err - load MGF file, clear data structures
3205 .SH
3206 SYNOPSIS
3207 .LP
3208 #include "parser.h"
3209 .LP
3210 .B int
3211 mg_load(
3212 .B char
3213 *filename )
3214 .LP
3215 .B void
3216 mg_clear(
3217 .B void
3218 )
3219 .LP
3220 .B extern
3221 MG_FCTXT *mg_file
3222 .LP
3223 .B "extern char"
3224 *mg_err[MG_NERRS]
3225 .SH
3226 DESCRIPTION
3227 .LP
3228 The
3229 .I mg_load
3230 function loads the named file, or standard input if
3231 .I filename
3232 is the NULL pointer.
3233 Calls back to the appropriate MGF handler routines are made through the
3234 .I mg_ehand
3235 dispatch table.
3236 .LP
3237 The global
3238 .I mg_file
3239 variable points to the current file context structure, which
3240 may be useful for the interpretation of certain entities, such as
3241 .UL ies,
3242 which must know the directory path of the enclosing file.
3243 This structure is of the defined type
3244 .I MG_FCTXT,
3245 given in "parser.h" as:
3246 .DS
3247 typedef struct mg_fctxt {
3248 char fname[96]; /* file name */
3249 FILE *fp; /* stream pointer */
3250 int fid; /* unique file context id */
3251 char inpline[4096]; /* input line */
3252 int lineno; /* line number */
3253 struct mg_fctxt *prev; /* previous context */
3254 } MG_FCTXT;
3255 .DE
3256 .SH
3257 DIAGNOSTICS
3258 .LP
3259 If an error is encountered during parsing,
3260 .I mg_load
3261 will print an appropriate error message to the standard error stream
3262 and return one of the non-zero values from "parser.h" listed below:
3263 .DS
3264 #define MG_OK 0 /* normal return value */
3265 #define MG_EUNK 1 /* unknown entity */
3266 #define MG_EARGC 2 /* wrong number of arguments */
3267 #define MG_ETYPE 3 /* argument type error */
3268 #define MG_EILL 4 /* illegal argument value */
3269 #define MG_EUNDEF 5 /* undefined reference */
3270 #define MG_ENOFILE 6 /* cannot open input file */
3271 #define MG_EINCL 7 /* error in included file */
3272 #define MG_EMEM 8 /* out of memory */
3273 #define MG_ESEEK 9 /* file seek error */
3274 #define MG_EBADMAT 10 /* bad material specification */
3275
3276 #define MG_NERRS 11
3277 .DE
3278 If it is inappropriate to send output to standard error, the calling
3279 program should use the routines listed under
3280 .I mg_open
3281 for better control over the parsing process.
3282 .LP
3283 The
3284 .I mg_err
3285 array contains error messages corresponding to each of the values
3286 listed above in the native country's language.
3287 .SH
3288 SEE ALSO
3289 .LP
3290 mg_fgetpos, mg_handle, mg_init, mg_open
3291 .ds RH MG_OPEN
3292 .bp
3293 .SH
3294 NAME
3295 .LP
3296 mg_open, mg_read, mg_parse, mg_close - MGF file loading subroutines
3297 .SH
3298 SYNOPSIS
3299 .LP
3300 #include "parser.h"
3301 .LP
3302 .B int
3303 mg_open( MG_FCTXT *fcp,
3304 .B char
3305 *filename )
3306 .LP
3307 .B int
3308 mg_read(
3309 .B void
3310 )
3311 .LP
3312 .B int
3313 mg_parse(
3314 .B void
3315 )
3316 .LP
3317 .B void
3318 mg_close(
3319 .B void
3320 )
3321 .SH
3322 DESCRIPTION
3323 .LP
3324 Most loaders and translators will call the
3325 .I mg_load
3326 routine to handle the above operations, but some programs or
3327 entity handlers require tighter control over the loading process.
3328 .LP
3329 The
3330 .I mg_open
3331 routine takes an uninitialized
3332 .I MG_FCTXT
3333 structure and a file name as its arguments.
3334 If
3335 .I filename
3336 is the NULL pointer, the standard input is "opened."
3337 The
3338 .I fcp
3339 structure will be set by
3340 .I mg_open
3341 prior to its return, and the global
3342 .I mg_file
3343 pointer will be assigned to point to it.
3344 This variable must not be destroyed until after the file is closed
3345 with a call to
3346 .I mg_close.
3347 (See the
3348 .I mg_load
3349 page for a definition of
3350 .I mg_file
3351 and the
3352 .I MG_FCTXT
3353 type.)\0
3354 .LP
3355 The
3356 .I mg_read
3357 function reads the next input line from the current file,
3358 returning the number of characters in the line, or zero if the
3359 end of file is reached or there is a file error.
3360 The function skips over escaped newlines, and keeps track of the
3361 line number in the current file context
3362 .I mg_file,
3363 which also contains the line that was read.
3364 .LP
3365 The
3366 .I mg_parse
3367 function breaks the current line in the
3368 .I mg_file
3369 structure into words and calls the appropriate handler routine, if
3370 any.
3371 Blank lines and unsupported entities cause a quick return.
3372 .LP
3373 The
3374 .I mg_close
3375 routine closes the current input file (unless it is the standard
3376 input) and returns to the previous file context (if any).
3377 .SH
3378 DIAGNOSTICS
3379 .LP
3380 The
3381 .I mg_open
3382 function returns
3383 .I MG_OK
3384 (0) normally, or
3385 .I MG_ENOFILE
3386 if the open fails for some reason.
3387 .LP
3388 The
3389 .I mg_parse
3390 function returns
3391 .I MG_OK
3392 if the current line was successfully interpreted, or one of the
3393 defined error values if there is a problem.
3394 (See the
3395 .I mg_load
3396 page for the defined error values.)\0
3397 .SH
3398 SEE ALSO
3399 .LP
3400 mg_fgetpos, mg_handle, mg_init, mg_load
3401 .ds RH MG_FGETPOS
3402 .bp
3403 .SH
3404 NAME
3405 .LP
3406 mg_fgetpos, mg_fgoto - get current file position and seek to pointer
3407 .SH
3408 SYNOPSIS
3409 .LP
3410 #include "parser.h"
3411 .LP
3412 .B void
3413 mg_fgetpos( MG_FPOS *pos )
3414 .LP
3415 .B int
3416 mg_fgoto( MG_FPOS *pos )
3417 .SH
3418 DESCRIPTION
3419 .LP
3420 The
3421 .I mg_fgetpos
3422 gets the current MGF file position and loads it into the passed
3423 .I MG_FPOS
3424 structure,
3425 .I pos.
3426 .LP
3427 The
3428 .I mg_fgoto
3429 function seeks to the position
3430 .I pos,
3431 taken from a previous call to
3432 .I mg_fgetpos.
3433 .SH
3434 DIAGNOSTICS
3435 .LP
3436 If
3437 .I mg_fgoto
3438 is passed an illegal pointer or one that does not correspond to the
3439 current
3440 .I mg_file
3441 context, it will return the
3442 .I MG_ESEEK
3443 error value.
3444 Normally, it returns
3445 .I MG_OK
3446 (0).
3447 .SH
3448 SEE ALSO
3449 .LP
3450 mg_load, mg_open
3451 .ds RH MG_HANDLE
3452 .bp
3453 .SH
3454 NAME
3455 .LP
3456 mg_handle, mg_entity, mg_ename, mg_nqcdivs - entity assistance and control
3457 .SH
3458 SYNOPSIS
3459 .LP
3460 .B int
3461 mg_handle(
3462 .B int
3463 en,
3464 .B int
3465 ac,
3466 .B char
3467 *av )
3468 .LP
3469 .B int
3470 mg_entity(
3471 .B char
3472 *name )
3473 .LP
3474 .B "extern char"
3475 mg_ename[MG_NENTITIES][MG_MAXELEN]
3476 .LP
3477 .B "extern int"
3478 mg_nqcdivs
3479 .SH
3480 DESCRIPTION
3481 .LP
3482 The
3483 .I mg_handle
3484 routine may be used to pass entities back to the parser
3485 to be redirected through the
3486 .I mg_ehand
3487 dispatch table.
3488 This method is recommended rather than calling through
3489 .I mg_ehand
3490 directly, since the parser sometimes has its own support routines
3491 that it needs to call for specific entities.
3492 The first argument,
3493 .I en,
3494 is the corresponding entity number, or -1 if
3495 .I mg_handle
3496 should figure it out from the first
3497 .I av
3498 argument.
3499 .LP
3500 The
3501 .I mg_entity
3502 function gets an entity number from its name, using a hash
3503 table on the
3504 .I mg_ename
3505 list.
3506 .LP
3507 The
3508 .I mg_ename
3509 table contains the string names corresponding to each MGF entity in
3510 the designated order.
3511 (See the
3512 .I mg_init
3513 page for the list of MGF entities.)\0
3514 .LP
3515 The global integer variable
3516 .I mg_nqcdivs
3517 tells the parser how many subdivisions to use per quarter circle (90
3518 degrees) when tesselating curved geometry.
3519 The default value is 5, and it may be reset at any time by the
3520 calling program.
3521 .SH
3522 DIAGNOSTICS
3523 .LP
3524 The
3525 .I mg_handle
3526 function returns
3527 .I MG_OK
3528 if the entity is handled correctly, or one of the predefined error
3529 values if there is a problem.
3530 (See the
3531 .I mg_load
3532 page for a list of error values.)\0
3533 .LP
3534 The
3535 .I mg_entity
3536 function returns -1 if the passed name does not appear in the
3537 .I mg_ename
3538 list.
3539 .SH
3540 SEE ALSO
3541 .LP
3542 mg_init, mg_load, mg_open
3543 .ds RH ISINT, ISFLT, ISNAME
3544 .bp
3545 .SH
3546 NAME
3547 .LP
3548 isint, isflt, isname - determine if string fits integer or real format,
3549 or is legal identifier
3550 .SH
3551 SYNOPSIS
3552 .LP
3553 .B int
3554 isint(
3555 .B char
3556 *str )
3557 .LP
3558 .B int
3559 isflt(
3560 .B char
3561 *str )
3562 .LP
3563 .B int
3564 isname(
3565 .B char
3566 *str )
3567 .SH
3568 DESCRIPTION
3569 .LP
3570 The
3571 .I isint
3572 function checks to see if the passed string
3573 .I str
3574 matches a decimal integer format (positive or negative),
3575 and returns 1 or 0 based on whether it does or does not.
3576 .LP
3577 The
3578 .I isflt
3579 function checks to see if the passed string
3580 .I str
3581 matches a floating point format (positive or negative with optional
3582 exponent), and returns 1 or 0 based on whether it does or does not.
3583 .LP
3584 The
3585 .I isname
3586 function checks to see if the passed string
3587 .I str
3588 is a legal identifier name.
3589 In MGF, a legal identifier must begin with a letter and contain only
3590 visible ASCII characters (those between decimal 33 and 127 inclusive).
3591 The one caveat to this is that names may begin with one or more
3592 underscores ('_'), but this is a trick employed by the parser to
3593 maintain a separate name space from the user, and is not legal usage
3594 otherwise.
3595 .LP
3596 Note that a string that matches an integer format is also a valid
3597 floating point value.
3598 Conversely, a string that is not a floating point number cannot be a
3599 valid integer.
3600 .LP
3601 These routines are useful for checking arguments passed to entity
3602 handlers that certain types in certain positions.
3603 If an invalid argument is passed, the handler should return an
3604 .I MG_ETYPE
3605 error.
3606 .SH
3607 SEE ALSO
3608 .LP
3609 mg_init, mg_load
3610 .ds LH Entity Support Routines
3611 .ds RH C_HVERTEX
3612 .bp
3613 .SH
3614 NAME
3615 .LP
3616 c_hvertex, c_getvert, c_cvname, c_cvertex - vertex entity support
3617 .SH
3618 SYNOPSIS
3619 .LP
3620 #include "parser.h"
3621 .LP
3622 .B int
3623 c_hvertex(
3624 .B int
3625 argc,
3626 .B char
3627 **argv )
3628 .LP
3629 C_VERTEX *c_getvert(
3630 .B char
3631 *name )
3632 .LP
3633 .B "extern char"
3634 *c_vname
3635 .LP
3636 .B extern
3637 C_VERTEX *c_cvertex
3638 .SH
3639 DESCRIPTION
3640 .LP
3641 The
3642 .I c_hvertex
3643 function handles the MGF vertex entities,
3644 .UL v,
3645 .UL p
3646 and
3647 .UL n.
3648 If either
3649 .UL p
3650 or
3651 .UL n
3652 is supported, then
3653 .UL v
3654 must be also.
3655 The assignments are normally made to the
3656 .I mg_ehand
3657 array prior to parser initialization, like so:
3658 .DS
3659 mg_ehand[MG_E_VERTEX] = c_hvertex; /* support "v" entity */
3660 mg_ehand[MG_E_POINT] = c_hvertex; /* support "p" entity */
3661 mg_ehand[MG_E_NORMAL] = c_hvertex; /* support "n" entity */
3662 /* other entity handler assignments... */
3663 mg_init(); /* initialize parser */
3664 .DE
3665 If vertex normals are not understood by any of the program-supported
3666 entities, then the
3667 .I MG_E_NORMAL
3668 entry may be left with its original NULL assignment.
3669 .LP
3670 The
3671 .I c_getvert
3672 call takes the name of a defined vertex and returns a pointer to its
3673 .I C_VERTEX
3674 structure, defined in "parser.h" as:
3675 .DS
3676 typedef FLOAT FVECT[3]; /* a 3-d real vector */
3677
3678 typedef struct {
3679 int clock; /* incremented each change -- resettable */
3680 FVECT p, n; /* point and normal */
3681 } C_VERTEX; /* vertex context */
3682 .DE
3683 The
3684 .I clock
3685 member will be incremented each time the value gets changed by a
3686 .UL p
3687 or
3688 .UL n
3689 entity, and may be reset by the controlling program if desired.
3690 This is a convenient way to keep track of whether or not a vertex has
3691 changed since its last use.
3692 To link identical vertices, one must also check that the current
3693 transform has not changed, which is uniquely identified by the
3694 global
3695 .I xf_context->xid
3696 variable, but only if one is using the parser libraries transform
3697 handler.
3698 (See the
3699 .I xf_handler
3700 page.)\0
3701 .LP
3702 It is possible but not recommended to alter the contents of the
3703 vertex structure returned by
3704 .I c_getvert.
3705 Normally it is read during the
3706 interpretation of entities using named vertices.
3707 .LP
3708 The name of the current vertex is given by the global
3709 .I c_cvname
3710 variable, which is set to NULL if the unnamed vertex is current.
3711 The current vertex value is pointed to by the global variable
3712 .I c_cvertex,
3713 which should never be NULL.
3714 .SH
3715 DIAGNOSTICS
3716 .LP
3717 The
3718 .I c_hvertex
3719 function returns
3720 .I MG_OK
3721 (0) if the vertex is handled correctly, or one of the predefined
3722 error values if there is a problem.
3723 (See the
3724 .I mg_load
3725 page for a list of errors.)\0
3726 .LP
3727 The
3728 .I c_getvert
3729 function returns NULL if the specified vertex name is undefined, at
3730 which point the calling function should return an
3731 .I MG_EUNDEF
3732 error.
3733 .SH
3734 SEE ALSO
3735 .LP
3736 c_hcolor, c_hmaterial, mg_init, mg_load, xf_handler
3737 .ds RH C_HCOLOR
3738 .bp
3739 .SH
3740 NAME
3741 .LP
3742 c_hcolor, c_getcolor, c_ccname, c_ccolor, c_ccvt, c_isgrey -
3743 color entity support
3744 .SH
3745 SYNOPSIS
3746 .LP
3747 #include "parser.h"
3748 .LP
3749 .B int
3750 c_hcolor(
3751 .B int
3752 argc,
3753 .B char
3754 **argv )
3755 .LP
3756 C_COLOR *c_getcolor(
3757 .B char
3758 *name )
3759 .LP
3760 .B "extern char"
3761 *c_ccname
3762 .LP
3763 .B extern
3764 C_COLOR *c_ccolor
3765 .LP
3766 .B void
3767 c_ccvt( C_COLOR *cvp,
3768 .B int
3769 cflags )
3770 .LP
3771 .B int
3772 c_isgrey( C_COLOR *cvp )
3773 .SH
3774 DESCRIPTION
3775 .LP
3776 The
3777 .I c_hcolor
3778 function supports the MGF entities,
3779 .UL c,
3780 .UL cxy,
3781 .UL cspec,
3782 .UL cct
3783 and
3784 .UL cmix.
3785 It is an error to support any of the color field entities without
3786 supporting the
3787 .UL c
3788 entity itself.
3789 The assignments are normally made to the
3790 .I mg_ehand
3791 array prior to parser initialization, like so:
3792 .DS
3793 mg_ehand[MG_E_COLOR] = c_hcolor; /* support "c" entity */
3794 mg_ehand[MG_E_CXY] = c_hcolor; /* support "cxy" entity */
3795 mg_ehand[MG_E_CSPEC] = c_hcolor; /* support "cspec" entity */
3796 mg_ehand[MG_E_CCT] = c_hcolor; /* support "cct" entity */
3797 mg_ehand[MG_E_CMIX] = c_hcolor; /* support "cmix" entity */
3798 /* other entity handler assignments... */
3799 mg_init(); /* initialize parser */
3800 .DE
3801 If the loader/translator has no use for spectral data, the entries for
3802 .UL cspec
3803 and
3804 .UL cct
3805 may be left with their original NULL assignments and these entities will
3806 be re-expressed appropriately as tristimulus values.
3807 .LP
3808 The
3809 .I c_getcolor
3810 function takes the name of a defined color and returns a pointer to its
3811 .I C_COLOR
3812 structure, defined in "parser.h" as:
3813 .DS
3814 #define C_CMINWL 380 /* minimum wavelength */
3815 #define C_CMAXWL 780 /* maximum wavelength */
3816 #define C_CNSS 41 /* number of spectral samples */
3817 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
3818 #define C_CMAXV 10000 /* nominal maximum sample value */
3819 #define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
3820
3821 typedef struct {
3822 int clock; /* incremented each change */
3823 short flags; /* what's been set */
3824 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
3825 long ssum; /* straight sum of spectral values */
3826 float cx, cy; /* xy chromaticity value */
3827 float eff; /* efficacy (lumens/watt) */
3828 } C_COLOR; /* color context */
3829 .DE
3830 The
3831 .I clock
3832 member will be incremented each time the value gets changed by a
3833 color field entity, and may be reset by the calling program if
3834 desired.
3835 This is a convenient way to keep track of whether or not a color has
3836 changed since its last use.
3837 The
3838 .I flags
3839 member indicates which color representations have been assigned,
3840 and is an inclusive OR of one or more of the following:
3841 .DS
3842 #define C_CSSPEC 01 /* flag if spectrum is set */
3843 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
3844 #define C_CSXY 04 /* flag if xy is set */
3845 #define C_CDXY 010 /* flag if defined w/ xy */
3846 #define C_CSEFF 020 /* flag if efficacy set */
3847 .DE
3848 .LP
3849 It is possible but not recommended to alter the contents of the
3850 color structure returned by
3851 .I c_getcolor.
3852 Normally, this routine is never called directly, since there are no
3853 entities that access colors by name other than
3854 .UL c.
3855 .LP
3856 The global variable
3857 .I c_ccname
3858 points to the name of the current color, or NULL if it is unnamed.
3859 The variable
3860 .I c_ccolor
3861 points to the current color value, which should never be NULL.
3862 .LP
3863 The
3864 .I c_ccvt
3865 routine takes a
3866 .I C_COLOR
3867 structure and a set of desired flag settings and computes the
3868 missing color representation(s).
3869 .LP
3870 The
3871 .I c_isgrey
3872 function returns 1 if the passed color is very close to neutral
3873 grey, or 0 otherwise.
3874 .SH
3875 DIAGNOSTICS
3876 .LP
3877 The
3878 .I c_hcolor
3879 function returns
3880 .I MG_OK
3881 (0) if the color is handled correctly, or one of the predefined
3882 error values if there is a problem.
3883 (See the
3884 .I mg_load
3885 page for a list of errors.)\0
3886 .LP
3887 The
3888 .I c_getcolor
3889 function returns NULL if the specified color name is undefined, at
3890 which point the calling function should return an
3891 .I MG_EUNDEF
3892 error.
3893 .SH
3894 SEE ALSO
3895 .LP
3896 c_hmaterial, c_hvertex, mg_init, mg_load
3897 .ds RH C_HMATERIAL
3898 .bp
3899 .SH
3900 NAME
3901 .LP
3902 c_hmaterial, c_getmaterial, c_cmname, c_cmaterial -
3903 material entity support
3904 .SH
3905 SYNOPSIS
3906 .LP
3907 #include "parser.h"
3908 .LP
3909 .B int
3910 c_hmaterial(
3911 .B int
3912 argc,
3913 .B char
3914 **argv )
3915 .LP
3916 C_MATERIAL *c_getmaterial(
3917 .B char
3918 *name )
3919 .LP
3920 .B "extern char"
3921 *c_cmname
3922 .LP
3923 .B extern
3924 C_MATERIAL *c_cmaterial
3925 .SH
3926 DESCRIPTION
3927 .LP
3928 The
3929 .I c_hmaterial
3930 function supports the MGF entities,
3931 .UL m,
3932 .UL ed,
3933 .UL ir,
3934 .UL rd,
3935 .UL rs,
3936 .UL sides,
3937 .UL td,
3938 and
3939 .UL ts.
3940 It is an error to support any of the material field entities without
3941 supporting the
3942 .UL m
3943 entity itself.
3944 The assignments are normally made to the
3945 .I mg_ehand
3946 array prior to parser initialization, like so:
3947 .DS
3948 mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* support "m" entity */
3949 mg_ehand[MG_E_ED] = c_hmaterial; /* support "ed" entity */
3950 mg_ehand[MG_E_IR] = c_hmaterial; /* support "ir" entity */
3951 mg_ehand[MG_E_RD] = c_hmaterial; /* support "rd" entity */
3952 mg_ehand[MG_E_RS] = c_hmaterial; /* support "rs" entity */
3953 mg_ehand[MG_E_SIDES] = c_hmaterial; /* support "sides" entity */
3954 mg_ehand[MG_E_TD] = c_hmaterial; /* support "td" entity */
3955 mg_ehand[MG_E_TS] = c_hmaterial; /* support "ts" entity */
3956 /* other entity handler assignments... */
3957 mg_init(); /* initialize parser */
3958 .DE
3959 Any of the above entities besides
3960 .UL m
3961 may be unsupported, but the parser will not attempt to include their
3962 effect into other members, e.g. an unsupported
3963 .UL rs
3964 component will not be added back into the
3965 .UL rd
3966 member.
3967 It is therefore safer to support all of the relevant material
3968 entities and make final approximations from the complete
3969 .I C_MATERIAL
3970 structure.
3971 .LP
3972 The
3973 .I c_getmaterial
3974 function takes the name of a defined material and returns a pointer to its
3975 .I C_MATERIAL
3976 structure, defined in "parser.h" as:
3977 .DS
3978 #define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
3979
3980 typedef struct {
3981 int clock; /* incremented each change -- resettable */
3982 int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
3983 float nr, ni; /* index of refraction, real and imaginary */
3984 float rd; /* diffuse reflectance */
3985 C_COLOR rd_c; /* diffuse reflectance color */
3986 float td; /* diffuse transmittance */
3987 C_COLOR td_c; /* diffuse transmittance color */
3988 float ed; /* diffuse emittance */
3989 C_COLOR ed_c; /* diffuse emittance color */
3990 float rs; /* specular reflectance */
3991 C_COLOR rs_c; /* specular reflectance color */
3992 float rs_a; /* specular reflectance roughness */
3993 float ts; /* specular transmittance */
3994 C_COLOR ts_c; /* specular transmittance color */
3995 float ts_a; /* specular transmittance roughness */
3996 } C_MATERIAL; /* material context */
3997 .DE
3998 The
3999 .I clock
4000 member will be incremented each time the value gets changed by a
4001 material field entity, and may be reset by the calling program if
4002 desired.
4003 This is a convenient way to keep track of whether or not a material has
4004 changed since its last use.
4005 .LP
4006 All reflectance and transmittance values correspond to normal
4007 incidence, and may vary as a function of angle depending on the
4008 index of refraction.
4009 A solid object is normally represented with a one-sided material.
4010 A two-sided material is most appropriate for thin surfaces, though
4011 it may be used also when the surface normal orientations in a model
4012 are unreliable.
4013 .LP
4014 If a transparent or translucent surface is one-sided, then the
4015 absorption will change as a function of distance through the
4016 material, and a single value for diffuse or specular transmittance is
4017 ambiguous.
4018 We therefore define a standard thickness,
4019 .I C_1SIDEDTHICK,
4020 which is the object thickness to which the given values correspond,
4021 so that one may compute the isotropic absorptance of the material.
4022 .LP
4023 It is possible but not recommended to alter the contents of the
4024 material structure returned by
4025 .I c_getmaterial.
4026 Normally, this routine is never called directly, since there are no
4027 entities that access materials by name other than
4028 .UL m.
4029 .LP
4030 The global variable
4031 .I c_cmname
4032 points to the name of the current material, or NULL if it is unnamed.
4033 The variable
4034 .I c_cmaterial
4035 points to the current material value, which should never be NULL.
4036 .SH
4037 DIAGNOSTICS
4038 .LP
4039 The
4040 .I c_hmaterial
4041 function returns
4042 .I MG_OK
4043 (0) if the color is handled correctly, or one of the predefined
4044 error values if there is a problem.
4045 (See the
4046 .I mg_load
4047 page for a list of errors.)\0
4048 .LP
4049 The
4050 .I c_getmaterial
4051 function returns NULL if the specified material name is undefined, at
4052 which point the calling function should return an
4053 .I MG_EUNDEF
4054 error.
4055 .SH
4056 SEE ALSO
4057 .LP
4058 c_hcolor, c_hvertex, mg_init, mg_load
4059 .ds RH OBJ_HANDLER
4060 .bp
4061 .SH
4062 NAME
4063 .LP
4064 obj_handler, obj_clear, obj_nnames, obj_name - object name support
4065 .SH
4066 SYNOPSIS
4067 .LP
4068 .B int
4069 obj_handler(
4070 .B int
4071 argc,
4072 .B char
4073 **argv )
4074 .LP
4075 .B void
4076 obj_clear(
4077 .B void
4078 )
4079 .LP
4080 .B "extern int"
4081 obj_nnames
4082 .LP
4083 .B "extern char"
4084 **obj_name
4085 .SH
4086 DESCRIPTION
4087 .LP
4088 The
4089 .I obj_handler
4090 routine should be assigned to the
4091 .I MG_E_OBJECT
4092 entry of the parser's
4093 .I mg_ehand
4094 array prior to calling
4095 .I mg_load
4096 if the loader/translator wishes to support hierarchical object
4097 names.
4098 .LP
4099 The
4100 .I obj_clear
4101 function may be used to clear the object name stack and free any
4102 associated memory, but this is usually not necessary since
4103 .UL o
4104 begin and end entities are normally balanced in the input.
4105 .LP
4106 The global
4107 .I obj_nnames
4108 variable indicates the number of names currently in the object
4109 stack, and the
4110 .I obj_name
4111 list contains the name strings in the same order as they were
4112 encountered on the input.
4113 (I.e. the most recently pushed name is last.)\0
4114 .SH
4115 DIAGNOSTICS
4116 .LP
4117 The
4118 .I obj_handler
4119 function returns
4120 .I MG_OK
4121 (0) if the color is handled correctly, or one of the predefined
4122 error values if there is a problem.
4123 (See the
4124 .I mg_load
4125 page for a list of errors.)\0
4126 .SH
4127 SEE ALSO
4128 .LP
4129 mg_init, mg_load, xf_handler
4130 .ds RH XF_HANDLER
4131 .bp
4132 .SH
4133 NAME
4134 .LP
4135 xf_handler, xf_clear, xf_context, xf_argend - transformation support
4136 .SH
4137 SYNOPSIS
4138 .LP
4139 .B int
4140 xf_handler(
4141 .B int
4142 argc,
4143 .B char
4144 **argv )
4145 .LP
4146 .B void
4147 xf_clear(
4148 .B void
4149 )
4150 .LP
4151 .B extern
4152 XF_SPEC *xf_context
4153 .LP
4154 .B "extern char"
4155 **xf_argend
4156 .SH
4157 DESCRIPTION
4158 .LP
4159 The
4160 .I xf_handler
4161 routine should be assigned to the
4162 .I MG_E_XF
4163 entry of the parser's
4164 .I mg_ehand
4165 array prior to calling
4166 .I mg_load
4167 if the loader/translator wishes to support hierarchical
4168 transformations.
4169 (Note that all MGF geometric entities require this support.)\0
4170 .LP
4171 The
4172 .I xf_clear
4173 function may be used to clear the transform stack and free any
4174 associated memory, but this is usually not necessary since
4175 .UL xf
4176 begin and end entities are normally balanced in the input.
4177 .LP
4178 The global
4179 .I xf_context
4180 variable points to the current transformation context, which is of
4181 the type
4182 .I XF_SPEC,
4183 described in "parser.h":
4184 .DS
4185 typedef struct xf_spec {
4186 long xid; /* unique transform id */
4187 short xac; /* context argument count */
4188 short rev; /* boolean true if vertices reversed */
4189 XF xf; /* cumulative transformation */
4190 struct xf_array *xarr; /* transformation array pointer */
4191 struct xf_spec *prev; /* previous transformation context */
4192 } XF_SPEC; /* followed by argument buffer */
4193 .DE
4194 The
4195 .I xid
4196 member is a identifier associated with this transformation,
4197 which should be the same for identical transformations, as an aid to
4198 vertex sharing.
4199 (See also the
4200 .I c_hvertex
4201 page.)\0
4202 The
4203 .I xac
4204 member indicates the total number of transform arguments, and is
4205 used to indicate the position of the first argument relative to the
4206 last one pointed to by the global
4207 .I xf_argend
4208 variable.
4209 .LP
4210 The first transform argument starts at
4211 .I xf_argv,
4212 which is a macro defined in "parser.h" as:
4213 .DS
4214 #define xf_argv (xf_argend - xf_context->xac)
4215 .DE
4216 Note that accessing this macro will result in a segmentation violation
4217 if the current context is NULL, so one should first test the second macro
4218 .I xf_argc
4219 against zero.
4220 This macro is defined as:
4221 .DS
4222 #define xf_argc (xf_context==NULL ? 0 : xf_context->xac)
4223 .DE
4224 .LP
4225 Normally, neither of these macros will be used, since there are
4226 routines for transforming points, vectors and scalars directly based
4227 on the current transformation context.
4228 (See the
4229 .I xf_xfmpoint
4230 page for details.)\0
4231 .LP
4232 The
4233 .I rev
4234 member of the
4235 .I XF_SPEC
4236 structure indicates whether or not this transform reverses the order
4237 of polygon vertices.
4238 This member will be 1 if the transformation mirrors about an odd
4239 number of coordinate axes, thus inverting faces.
4240 The usual thing to do in this circumstance is to interpret the
4241 vertex arguments in the reverse order, so as to bring the face back
4242 to its original orientation in the new position.
4243 .LP
4244 The
4245 .I xf
4246 member contains the transformation scalefactor (in xf.sca)
4247 and 4x4 homogeneous matrix (in xf.xfm), but these will usually not
4248 be accessed directly.
4249 Likewise, the
4250 .I xarr
4251 and
4252 .I prev
4253 members point to data that should not be needed by the calling
4254 program.
4255 .SH
4256 DIAGNOSTICS
4257 .LP
4258 The
4259 .I xf_handler
4260 function returns
4261 .I MG_OK
4262 (0) if the color is handled correctly, or one of the predefined
4263 error values if there is a problem.
4264 (See the
4265 .I mg_load
4266 page for a list of errors.)\0
4267 .SH
4268 SEE ALSO
4269 .LP
4270 mg_init, mg_load, obj_handler, xf_xfmpoint
4271 .ds RH XF_XFMPOINT
4272 .bp
4273 .SH
4274 NAME
4275 .LP
4276 xf_xfmpoint, xf_xfmvect, xf_rotvect, xf_scale - apply current
4277 transformation
4278 .SH
4279 SYNOPSIS
4280 .LP
4281 .B void
4282 xf_xfmpoint( FVECT pnew, FVECT pold )
4283 .LP
4284 .B void
4285 xf_xfmvect( FVECT vnew, FVECT vold )
4286 .LP
4287 .B void
4288 xf_rotvect( FVECT nnew, FVECT nold )
4289 .LP
4290 .B double
4291 xf_scale(
4292 .B double
4293 sold )
4294 .SH
4295 DESCRIPTION
4296 .LP
4297 The
4298 .I xf_xfmpoint
4299 routine applies the current transformation defined by
4300 .I xf_context
4301 to the point
4302 .I pold,
4303 scaling, rotating and moving it to its proper location, which is put in
4304 .I pnew.
4305 (As for
4306 .I xf_xfmvect
4307 and
4308 .I xf_rotvect,
4309 the two arguments may point to the same vector.)\0
4310 .LP
4311 The
4312 .I xf_xfmvect
4313 routine applies the current transformation to the vector
4314 .I vold,
4315 scaling and rotating it to its proper location, which is put in
4316 .I vnew.
4317 The only difference between
4318 .I xf_xfmpoint
4319 and
4320 .I xf_xfmvect
4321 is that in the latter, the final translation is not applied.
4322 .LP
4323 The
4324 .I xf_rotvect
4325 routine rotates the vector
4326 .I nold
4327 using the current transformation, and stores the result in
4328 .I nnew.
4329 No translation or scaling is applied, which is the appropriate
4330 action for surface normal vectors for example.
4331 .LP
4332 The
4333 .I xf_scale
4334 function takes a scalar argument
4335 .I sold
4336 and applies the current scale factor, returning the result.
4337 .SH
4338 SEE ALSO
4339 .LP
4340 xf_handler
4341 .ds LH
4342 .ds RH
4343 .bp
4344 .NH
4345 Application Notes
4346 .NH 2
4347 Relation to Standard Practices in Computer Graphics
4348 .LP
4349 For those coming from a computer graphics background, some of the
4350 choices in the material model may seem strange or even capricious.
4351 Why not simply stick with RGB colors and a Phong specular component
4352 like everyone else?
4353 What is the point in choosing the number of sides to a material?
4354 .LP
4355 In the real world, a surface can have only one side,
4356 defining the interface between one volume and another.
4357 Many object-space rendering packages (e.g. z-buffer algorithms) take
4358 advantage of this fact by culling back-facing polygons and thus saving
4359 as much as 50% of the preprocessing time.
4360 However, many models rely on an
4361 approximation whereby a single surface is used to represent a very thin
4362 volume, such as a pane of glass, and this also can provide significant
4363 calculational savings in an image-space algorithm (such as
4364 ray-tracing).
4365 Also, many models are created in such a way that the front vs. back
4366 information is lost or confused, so that the back side of one or
4367 more surfaces may have to serve as the front side during rendering.
4368 (AutoCAD is one easily identified culprit in this department.)\0
4369 Since both types of surface models are useful and any
4370 rendering algorithm may ultimately be applied, MGF provides a way
4371 to specify sidedness rather than picking one interpretation or the other.
4372 .LP
4373 The problem with RGB is that there is no accepted standard, and even
4374 if we were to set one it would either be impossible to realize (i.e.
4375 impossible to create phosphors with the chosen colors) or it would
4376 have a gamut that excludes many saturated colors.
4377 The CIE color system was very carefully conceived and developed,
4378 and is the standard to which all photometric measurements adhere.
4379 It is therefore the logical choice in any standard format, though it
4380 has been too often ignored by the computer graphics community.
4381 .LP
4382 Regarding Phong shading, this was never a physical model and making it
4383 behave basic laws of reciprocity and energy balance is difficult.
4384 More to the point, specular power has almost nothing to do with
4385 surface microstructure, and is difficult to set properly
4386 even if every physical characteristic of a material has
4387 been carefully measured.
4388 This is the ultimate indictment of any physical model -- that it
4389 is incapable of reproducing any measurement whatsoever.
4390 .LP
4391 Admittedly, the compliment of diffuse and specular component plus
4392 surface roughness and index of refraction used in MGF is less than a
4393 perfect model, but it is serviceable for most materials and
4394 relatively simple to incorporate into a rendering algorithm.
4395 In the long term, MGF shall probably include full spectral
4396 scattering functions, though the sheer quantity of data involved
4397 makes this burdensome from both the measurement side and the
4398 simulation side.
4399 .NH 3
4400 Converting between Phong Specular Power and Gaussian Roughness
4401 .LP
4402 So-called specular reflection and transmission are modeled using a
4403 Gaussian distribution of surface facets.
4404 The roughness parameters to the
4405 .UL rs
4406 and
4407 .UL ts
4408 entities specify
4409 the root-mean-squared (RMS) surface facet slope, which varies from 0
4410 for a perfectly smooth surface to around .2 for a fairly rough one.
4411 The effect this will have on the reflected component distribution is
4412 well-defined, but predicting the behavior of the transmitted
4413 component requires further assumptions.
4414 We assume that the surface
4415 scatters light passing through it just as much as it scatters
4416 reflected light.
4417 This assumption is approximately correct for a
4418 two-sided transparent material with an index of refraction of 1.5
4419 (like glass) and both sides having the given RMS facet slope.
4420 .LP
4421 Oftentimes, one is translating from a Phong exponent on the cosine
4422 of the half-vector-to-normal angle to the more physical but less
4423 familiar Gaussian model of MGF.
4424 The hardest part is translating the specular power to a roughness value.
4425 For this, we recommend the following approximation:
4426 .IP
4427 roughness = 0.6/sqrt(specular_power)
4428 .LP
4429 It is not a perfect correlation, but it is about as close as one can get.
4430 .NH 3
4431 Converting between RGB and CIE Colors
4432 .LP
4433 Unlike most graphics languages, MGF does not use an RGB color model,
4434 simply because there is no recognized definition for this model.
4435 It is based on computer monitor phosphors, which vary from one
4436 CRT to the next.
4437 (There is an RGB standard defined in the TV
4438 industry, but this has a rather poor correlation to most computer
4439 monitors and it is impossible to express many real-world colors
4440 within its limited gamut.)\0
4441 .LP
4442 MGF uses two alternative, well-defined standards, spectral power
4443 distributions and the 1931 CIE 2 degree standard observer.
4444 With the CIE standard, any viewable
4445 color may be exactly represented as an (x,y) chromaticity value.
4446 Unfortunately, the interaction between
4447 colors (i.e. colored light sources and interreflections) cannot be
4448 specified exactly with any finite coordinate set, including CIE
4449 chromaticities.
4450 So, MGF offers the ability to give reflectance,
4451 transmittance or emittance as a function of wavelength over the visible
4452 spectrum.
4453 This function is still discretized, but at a user-selectable
4454 resolution.
4455 Furthermore, spectral colors may be mixed, providing (nearly)
4456 arbitrary basis functions, which can produce more accurate results in
4457 some cases and are merely a convenience for translation in others.
4458 .LP
4459 Conversion back and forth between CIE chromaticity coordinates and spectral
4460 samples is provided within the MGF parser.
4461 Unfortunately, conversion
4462 to and from RGB values depends on a particular RGB definition, and as we
4463 have said, there is no recognized standard.
4464 We therefore recommend that
4465 you decide yourself what chromaticity values to use for each RGB primary,
4466 and adopt the following code to convert between CIE and RGB coordinates.
4467 .LP
4468 .nf
4469 #ifdef NTSC
4470 #define CIE_x_r 0.670 /* standard NTSC primaries */
4471 #define CIE_y_r 0.330
4472 #define CIE_x_g 0.210
4473 #define CIE_y_g 0.710
4474 #define CIE_x_b 0.140
4475 #define CIE_y_b 0.080
4476 #define CIE_x_w 0.3333 /* monitor white point */
4477 #define CIE_y_w 0.3333
4478 #else
4479 #define CIE_x_r 0.640 /* nominal CRT primaries */
4480 #define CIE_y_r 0.330
4481 #define CIE_x_g 0.290
4482 #define CIE_y_g 0.600
4483 #define CIE_x_b 0.150
4484 #define CIE_y_b 0.060
4485 #define CIE_x_w 0.3333 /* monitor white point */
4486 #define CIE_y_w 0.3333
4487 #endif
4488
4489 #define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \\
4490 CIE_x_g*(CIE_y_b - CIE_y_r) + \\
4491 CIE_x_b*(CIE_y_r - CIE_y_g) )
4492 #define CIE_C_rD ( (1./CIE_y_w) * \\
4493 ( CIE_x_w*(CIE_y_g - CIE_y_b) - \\
4494 CIE_y_w*(CIE_x_g - CIE_x_b) + \\
4495 CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) )
4496 #define CIE_C_gD ( (1./CIE_y_w) * \\
4497 ( CIE_x_w*(CIE_y_b - CIE_y_r) - \\
4498 CIE_y_w*(CIE_x_b - CIE_x_r) - \\
4499 CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) )
4500 #define CIE_C_bD ( (1./CIE_y_w) * \\
4501 ( CIE_x_w*(CIE_y_r - CIE_y_g) - \\
4502 CIE_y_w*(CIE_x_r - CIE_x_g) + \\
4503 CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) )
4504
4505 #define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
4506 #define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D)
4507 #define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D)
4508
4509 float xyz2rgbmat[3][3] = { /* XYZ to RGB */
4510 {(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
4511 (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
4512 (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD},
4513 {(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
4514 (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
4515 (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD},
4516 {(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
4517 (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
4518 (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD}
4519 };
4520
4521 float rgb2xyzmat[3][3] = { /* RGB to XYZ */
4522 {CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D},
4523 {CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D},
4524 {(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
4525 (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
4526 (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D}
4527 };
4528
4529
4530 cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB */
4531 register float *rgbcolor, *ciecolor;
4532 {
4533 register int i;
4534
4535 for (i = 0; i < 3; i++) {
4536 rgbcolor[i] = xyz2rgbmat[i][0]*ciecolor[0] +
4537 xyz2rgbmat[i][1]*ciecolor[1] +
4538 xyz2rgbmat[i][2]*ciecolor[2] ;
4539 if (rgbcolor[i] < 0.0) /* watch for negative values */
4540 rgbcolor[i] = 0.0;
4541 }
4542 }
4543
4544
4545 rgb_cie(ciecolor, rgbcolor) /* convert RGB to CIE */
4546 register float *ciecolor, *rgbcolor;
4547 {
4548 register int i;
4549
4550 for (i = 0; i < 3; i++)
4551 ciecolor[i] = rgb2xyzmat[i][0]*rgbcolor[0] +
4552 rgb2xyzmat[i][1]*rgbcolor[1] +
4553 rgb2xyzmat[i][2]*rgbcolor[2] ;
4554 }
4555 .fi
4556 .LP
4557 An alternative to adopting the above code is to use the MGF "cmix"
4558 entity to convert from RGB directly by naming the three primaries in
4559 terms of their chromaticities, e.g:
4560 .DS
4561 c R =
4562 cxy 0.640 0.330
4563 c G =
4564 cxy 0.290 0.600
4565 c B =
4566 cxy 0.150 0.060
4567 .DE
4568 .LP
4569 Then, converting from RGB to MGF colors is as simple as multiplying each
4570 component by its relative luminance in a cmix statement, for instance:
4571 .DS
4572 c white =
4573 cmix 0.265 R 0.670 G 0.065 B
4574 .DE
4575 .LP
4576 For the chosen RGB standard, the above specification would result a pure
4577 white.
4578 The reason the coefficients are not all 1 as you might expect is
4579 that cmix uses relative luminance as the standard for its weights.
4580 Since
4581 blue is less luminous for the same energy than red, which is in turn
4582 less luminous than green, the weights cannot be the same to achieve an
4583 even spectral balance.
4584 Unfortunately, computing these relative weights
4585 is not straightforward, though it is given in the above macros as CIE_rf,
4586 CIE_gf and CIE_bf.
4587 (The common factors in these macros may of course
4588 be removed since
4589 .UL cmix
4590 weights are all relative.)\0
4591 Alternatively, one could measure the actual full scale luminance of
4592 the phosphors with a luminance probe and get the same relative
4593 values.
4594 .NH 2
4595 Relation to IESNA LM-63 and Luminaire Catalogs
4596 .LP
4597 Recently, the Illuminating Engineering Society of North America
4598 (IESNA) adopted MGF as the official standard for
4599 representing luminaire geometry and materials.
4600 The way this works in an IES luminaire data file is through the
4601 addition of a keyword called LUMINOUSGEOMETRY, which is given on a
4602 line in the header portion of a file (before the TILT specification)
4603 like so:
4604 .LP
4605 .B [LUMINOUSGEOMETRY]
4606 .I mgf_file
4607 .LP
4608 The given MGF file must exist relative to the directory containing
4609 the IES file (i.e. the same stipulations and restrictions on pathnames
4610 apply as for the MGF
4611 .UL i
4612 entity).
4613 Furthermore, the position of the MGF geometry must be
4614 such that the gross geometric specification of emitting surfaces
4615 in the IES file completely
4616 blocks or encloses the luminous portions of the MGF description.
4617 Specifically, any ray traced towards the MGF geometry must strike
4618 the IES gross geometry before it strikes any luminous surface in the
4619 MGF description.
4620 This provides a convenient way of preventing overcounting in the
4621 illumination calculation, while still allowing for accurate fixture
4622 appearance.
4623 .LP
4624 To give two examples, let us consider first a recessed can, followed
4625 by a hanging direct/indirect fluorescent fixture.
4626 .LP
4627 The most appropriate IES geometric specification for the emitting
4628 area of a can light would be a circular disk.
4629 Since the IES gross geometry gives only the diameter of the disk, the
4630 actual 3-dimensional placement is implicitly defined as having a
4631 center at the origin, with the radiating disk facing in the
4632 negative Z direction (nadir, downwards).
4633 The MGF geometry would then be placed such that any luminous portion
4634 was above this disk, and no portion of it would obstruct the IES
4635 geometry.
4636 The most sensible position therefore has the IES disk flush with the
4637 MGF can opening, as shown in Figure 3.
4638 .bp
4639 Replace this page with the second page from "figures.ps".
4640 .bp
4641 .LP
4642 In the case of a direct/indirect fluorescent fixture, light will
4643 exit both the top and the bottom sides, and the IES geometry must
4644 enclose the radiating portion of the fixture entirely.
4645 It is acceptable to have additional MGF geometry above the
4646 fixture so long as it does not radiate, which is what we must do if
4647 we wish to include the support rods, as shown in Figure 4.
4648 .LP
4649 Note that the origin is always in the exact center of the IES
4650 geometry.
4651 .LP
4652 Not all fixtures will fit the simple IES geometry specification so
4653 nicely.
4654 For odd-shaped fixtures, it may be necessary to use an IES geometry
4655 that does not match the radiating area terribly well in order that
4656 it completely block or enclose the required MGF specification.
4657 .LP
4658 The unit of length in the MGF file is always meters, regardless of
4659 the units specified in the enclosing IES file.
4660 However, any and all multipliers applied to the candlepower data in the
4661 IES file will also be applied to the emittance of surfaces in the
4662 MGF specification, so that one MGF file may serve similar
4663 luminaires that differ in their total output.
4664 .NH
4665 Credits
4666 .LP
4667 The MGF language grew out of a joint investigation into physical
4668 representations for rendering undertaken by the author
4669 (Greg Ward of LBL) and Holly Rushmeier of the National
4670 Institute of Standards and Technology.
4671 After deciding that a complete and robust specification was
4672 an extreme challenge, we shelved the project for another time.
4673 A few months later, the author spoke with Ian Ashdown and Robert
4674 Shakespeare, who are both members of the IES Computing Committee,
4675 about the need for extending the existing data standard to
4676 include luminaire geometry and near-field photometry.
4677 We then moved forward as a team towards a somewhat less ambitious
4678 approach to physical materials and geometry that had the advantage
4679 of simplicity and the possibility of support with a standard parser
4680 library.
4681 The author went to work over the next two months
4682 on the detailed design of the language
4683 and an ANSI-C parser, with regular feedback from the other three
4684 team members.
4685 Several months and several versions later, we arrived at release
4686 1.0, which is the occasion of this document's creation.
4687 .LP
4688 Funding for this work... would be nice.
