--- ray/src/cv/mgflib/mgfdoc.tr 1995/08/28 16:45:59 1.6 +++ ray/src/cv/mgflib/mgfdoc.tr 1995/11/08 09:53:41 1.8 @@ -2388,7 +2388,7 @@ ring - create a circular ring with inner and outer rad .SH SYNOPSIS .LP -.B cyl +.B ring .I "vc rmin rmax" .SH DESCRIPTION @@ -3273,8 +3273,9 @@ and return one of the non-zero values from "parser.h" #define MG_EMEM 8 /* out of memory */ #define MG_ESEEK 9 /* file seek error */ #define MG_EBADMAT 10 /* bad material specification */ +#define MG_ELINE 11 /* input line too long */ -#define MG_NERRS 11 +#define MG_NERRS 12 .DE If it is inappropriate to send output to standard error, the calling program should use the routines listed under @@ -3358,6 +3359,9 @@ The function reads the next input line from the current file, returning the number of characters in the line, or zero if the end of file is reached or there is a file error. +If the last character read in the input line is not a newline, +then the input line was too long, and you +should return an MG_ELINE error. The function skips over escaped newlines, and keeps track of the line number in the current file context .I mg_file,
