--- ray/src/cv/mgflib/mgfdoc.tr 1995/05/12 14:26:12 1.1 +++ ray/src/cv/mgflib/mgfdoc.tr 1995/11/08 09:53:41 1.8 @@ -431,7 +431,8 @@ Since the arguments are concise and self-explanatory, sufficient. The following transformation flags and parameters are defined: -.TS I +.TS +center; l l. -t dx dy dz translate objects along the given vector -rx degrees rotate objects about the X-axis @@ -546,6 +547,7 @@ Detailed MGF Example The following example of a simple room with a single door and six file cabinets shows MGF in action, with copious comments to help explain what's going on. +.LP .DS # "ceiling_tile" is a diffuse white surface with 75% reflectance: # Create new named material context and clear it @@ -744,9 +746,6 @@ o door o o - i cubfurn.inc -mx -t 405 133.5 0 -o - # Six file cabinets (36" wide each) # ("filecab.inc" was given as an earlier example in Section 1.2) o filecab.x @@ -772,7 +771,7 @@ There are currently 28 entities in the MGF specificati For ease of reference we have broken these into five categories: .IP 1. General -.TS I +.TS lw(.75i) lw(1.75i) lw(3i). # [anything ...] a comment o [name] begin/end object context @@ -782,7 +781,7 @@ ies pathname [-m f][xform] include IES luminaire (with .TE .IP 2. Color -.TS I +.TS lw(.75i) lw(1.75i) lw(3i). c [id [= [template]]] get/set color context cxy x y set CIE (x,y) chromaticity for current color @@ -1267,7 +1266,8 @@ corresponds to the measurement at Values in between are separated by .I "(l_max-l_min)/(N-1)" nanometers. -All values must be non-negative, and the spectrum outside of the +All values should be non-negative unless defining a component for +complementary color mixing, and the spectrum outside of the specified range is assumed to be zero. (The visible range is 380 to 780 nm.)\0 The actual units and scale of the measurements do not matter, @@ -2226,7 +2226,7 @@ o stylus p 0 0 .005 v vend = p 0 0 .05 - cyl vtip1 .0015 + cyl vtip1 .0015 vend sph vend .0015 cone vtip0 0 vtip1 .0015 o @@ -2388,7 +2388,7 @@ ring - create a circular ring with inner and outer rad .SH SYNOPSIS .LP -.B cyl +.B ring .I "vc rmin rmax" .SH DESCRIPTION @@ -2695,8 +2695,7 @@ Greg Ward SEE ALSO .LP ies2rad(1), mgf2meta(1), obj2rad(1), oconv(1), rad2mgf(1), xform(1) -.ds RH -RAD2MGF +.ds RH RAD2MGF .bp .SH NAME @@ -2985,15 +2984,15 @@ char **av; if (ac < 4) /* check # arguments */ return(MG_EARGC); - printf("face\n"); /* begin face output */ + printf("face\\\\n"); /* begin face output */ for (i = 1; i < ac; i++) { if ((vp = c_getvert(av[i])) == NULL) /* vertex from name */ return(MG_EUNDEF); xf_xfmpoint(vert, vp->p); /* apply transform */ - printf("%15.9f %15.9f %15.9f\n", + printf("%15.9f %15.9f %15.9f\\\\n", vert[0], vert[1], vert[2]); /* output vertex */ } - printf(";\\n"); /* end of face output */ + printf(";\\\\n"); /* end of face output */ return(MG_OK); /* normal exit */ } @@ -3122,12 +3121,12 @@ following: #define MG_E_CMIX 4 /* cmix */ #define MG_E_CSPEC 5 /* cspec */ #define MG_E_CXY 6 /* cxy */ -#define MG_E_CYL 7 /* cyl */ +#define MG_E_CYL 7 /* cyl */ #define MG_E_ED 8 /* ed */ #define MG_E_FACE 9 /* f */ #define MG_E_INCLUDE 10 /* i */ #define MG_E_IES 11 /* ies */ -#define MG_E_IR 12 /* ir */ +#define MG_E_IR 12 /* ir */ #define MG_E_MATERIAL 13 /* m */ #define MG_E_NORMAL 14 /* n */ #define MG_E_OBJECT 15 /* o */ @@ -3267,15 +3266,16 @@ and return one of the non-zero values from "parser.h" #define MG_EUNK 1 /* unknown entity */ #define MG_EARGC 2 /* wrong number of arguments */ #define MG_ETYPE 3 /* argument type error */ -#define MG_EILL 4 /* illegal argument value */ +#define MG_EILL 4 /* illegal argument value */ #define MG_EUNDEF 5 /* undefined reference */ #define MG_ENOFILE 6 /* cannot open input file */ #define MG_EINCL 7 /* error in included file */ #define MG_EMEM 8 /* out of memory */ #define MG_ESEEK 9 /* file seek error */ #define MG_EBADMAT 10 /* bad material specification */ +#define MG_ELINE 11 /* input line too long */ -#define MG_NERRS 11 +#define MG_NERRS 12 .DE If it is inappropriate to send output to standard error, the calling program should use the routines listed under @@ -3289,7 +3289,7 @@ listed above in the native country's language. .SH SEE ALSO .LP -mg_fgetpos, mg_handle, mg_init +mg_fgetpos, mg_handle, mg_init, mg_open .ds RH MG_OPEN .bp .SH @@ -3359,6 +3359,9 @@ The function reads the next input line from the current file, returning the number of characters in the line, or zero if the end of file is reached or there is a file error. +If the last character read in the input line is not a newline, +then the input line was too long, and you +should return an MG_ELINE error. The function skips over escaped newlines, and keeps track of the line number in the current file context .I mg_file, @@ -4275,7 +4278,7 @@ mg_init, mg_load, obj_handler, xf_xfmpoint .SH NAME .LP -xf_xfmpoint xf_xfmvect, xf_rotvect, xf_scale - apply current +xf_xfmpoint, xf_xfmvect, xf_rotvect, xf_scale - apply current transformation .SH SYNOPSIS @@ -4304,7 +4307,11 @@ to the point .I pold, scaling, rotating and moving it to its proper location, which is put in .I pnew. -(The two arguments may point to the same vector.)\0 +(As for +.I xf_xfmvect +and +.I xf_rotvect, +the two arguments may point to the same vector.)\0 .LP The .I xf_xfmvect @@ -4312,7 +4319,6 @@ routine applies the current transformation to the vect .I vold, scaling and rotating it to its proper location, which is put in .I vnew. -(The two arguments may point to the same vector.)\0 The only difference between .I xf_xfmpoint and @@ -4325,7 +4331,6 @@ routine rotates the vector .I nold using the current transformation, and stores the result in .I nnew. -(The two arguments may point to the same vector.)\0 No translation or scaling is applied, which is the appropriate action for surface normal vectors for example. .LP @@ -4486,20 +4491,20 @@ and adopt the following code to convert between CIE an #define CIE_y_w 0.3333 #endif -#define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \\\\ - CIE_x_g*(CIE_y_b - CIE_y_r) + \\\\ +#define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \\ + CIE_x_g*(CIE_y_b - CIE_y_r) + \\ CIE_x_b*(CIE_y_r - CIE_y_g) ) -#define CIE_C_rD ( (1./CIE_y_w) * \\\\ - ( CIE_x_w*(CIE_y_g - CIE_y_b) - \\\\ - CIE_y_w*(CIE_x_g - CIE_x_b) + \\\\ +#define CIE_C_rD ( (1./CIE_y_w) * \\ + ( CIE_x_w*(CIE_y_g - CIE_y_b) - \\ + CIE_y_w*(CIE_x_g - CIE_x_b) + \\ CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) ) -#define CIE_C_gD ( (1./CIE_y_w) * \\\\ - ( CIE_x_w*(CIE_y_b - CIE_y_r) - \\\\ - CIE_y_w*(CIE_x_b - CIE_x_r) - \\\\ +#define CIE_C_gD ( (1./CIE_y_w) * \\ + ( CIE_x_w*(CIE_y_b - CIE_y_r) - \\ + CIE_y_w*(CIE_x_b - CIE_x_r) - \\ CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) ) -#define CIE_C_bD ( (1./CIE_y_w) * \\\\ - ( CIE_x_w*(CIE_y_r - CIE_y_g) - \\\\ - CIE_y_w*(CIE_x_r - CIE_x_g) + \\\\ +#define CIE_C_bD ( (1./CIE_y_w) * \\ + ( CIE_x_w*(CIE_y_r - CIE_y_g) - \\ + CIE_y_w*(CIE_x_r - CIE_x_g) + \\ CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) ) #define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
