--- ray/src/cv/mgflib/mgfdoc.tr 1995/05/12 21:42:42 1.2 +++ ray/src/cv/mgflib/mgfdoc.tr 1995/12/01 11:07:51 1.11 @@ -746,9 +746,6 @@ o door o o - i cubfurn.inc -mx -t 405 133.5 0 -o - # Six file cabinets (36" wide each) # ("filecab.inc" was given as an earlier example in Section 1.2) o filecab.x @@ -1269,7 +1266,8 @@ corresponds to the measurement at Values in between are separated by .I "(l_max-l_min)/(N-1)" nanometers. -All values must be non-negative, and the spectrum outside of the +All values should be non-negative unless defining a component for +complementary color mixing, and the spectrum outside of the specified range is assumed to be zero. (The visible range is 380 to 780 nm.)\0 The actual units and scale of the measurements do not matter, @@ -2228,7 +2226,7 @@ o stylus p 0 0 .005 v vend = p 0 0 .05 - cyl vtip1 .0015 + cyl vtip1 .0015 vend sph vend .0015 cone vtip0 0 vtip1 .0015 o @@ -2390,7 +2388,7 @@ ring - create a circular ring with inner and outer rad .SH SYNOPSIS .LP -.B cyl +.B ring .I "vc rmin rmax" .SH DESCRIPTION @@ -2569,6 +2567,10 @@ In the first form, a single integer is given for the of MGF that is to be produced. Since MGF is in its first major release, this is not yet a useful form, but it will be when the second major release comes out. +This has the necessary side-effect of expanding all included files. +(See the +.UL i +entity.)\0 .LP In the second form, .I mgfilt @@ -2593,7 +2595,7 @@ mgfilt f,v,p,xf input.mgf > flatpoly.mgf .SH SEE ALSO .LP -mgf2rad, rad2mgf +i, mgf2rad, rad2mgf .ds RH MGF2RAD .bp .SH @@ -2697,8 +2699,7 @@ Greg Ward SEE ALSO .LP ies2rad(1), mgf2meta(1), obj2rad(1), oconv(1), rad2mgf(1), xform(1) -.ds RH -RAD2MGF +.ds RH RAD2MGF .bp .SH NAME @@ -3124,7 +3125,7 @@ following: #define MG_E_CMIX 4 /* cmix */ #define MG_E_CSPEC 5 /* cspec */ #define MG_E_CXY 6 /* cxy */ -#define MG_E_CYL 7 /* cyl */ +#define MG_E_CYL 7 /* cyl */ #define MG_E_ED 8 /* ed */ #define MG_E_FACE 9 /* f */ #define MG_E_INCLUDE 10 /* i */ @@ -3269,15 +3270,17 @@ and return one of the non-zero values from "parser.h" #define MG_EUNK 1 /* unknown entity */ #define MG_EARGC 2 /* wrong number of arguments */ #define MG_ETYPE 3 /* argument type error */ -#define MG_EILL 4 /* illegal argument value */ +#define MG_EILL 4 /* illegal argument value */ #define MG_EUNDEF 5 /* undefined reference */ #define MG_ENOFILE 6 /* cannot open input file */ #define MG_EINCL 7 /* error in included file */ #define MG_EMEM 8 /* out of memory */ #define MG_ESEEK 9 /* file seek error */ #define MG_EBADMAT 10 /* bad material specification */ +#define MG_ELINE 11 /* input line too long */ +#define MG_ECNTXT 12 /* unmatched context close */ -#define MG_NERRS 11 +#define MG_NERRS 13 .DE If it is inappropriate to send output to standard error, the calling program should use the routines listed under @@ -3291,7 +3294,7 @@ listed above in the native country's language. .SH SEE ALSO .LP -mg_fgetpos, mg_handle, mg_init +mg_fgetpos, mg_handle, mg_init, mg_open .ds RH MG_OPEN .bp .SH @@ -3361,7 +3364,10 @@ The function reads the next input line from the current file, returning the number of characters in the line, or zero if the end of file is reached or there is a file error. -The function skips over escaped newlines, and keeps track of the +If the value returned equals MG_MAXLINE-1, +then the input line was too long, and you +should return an MG_ELINE error. +The function keeps track of the line number in the current file context .I mg_file, which also contains the line that was read. @@ -4277,7 +4283,7 @@ mg_init, mg_load, obj_handler, xf_xfmpoint .SH NAME .LP -xf_xfmpoint xf_xfmvect, xf_rotvect, xf_scale - apply current +xf_xfmpoint, xf_xfmvect, xf_rotvect, xf_scale - apply current transformation .SH SYNOPSIS @@ -4490,20 +4496,20 @@ and adopt the following code to convert between CIE an #define CIE_y_w 0.3333 #endif -#define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \\\\ - CIE_x_g*(CIE_y_b - CIE_y_r) + \\\\ +#define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \\ + CIE_x_g*(CIE_y_b - CIE_y_r) + \\ CIE_x_b*(CIE_y_r - CIE_y_g) ) -#define CIE_C_rD ( (1./CIE_y_w) * \\\\ - ( CIE_x_w*(CIE_y_g - CIE_y_b) - \\\\ - CIE_y_w*(CIE_x_g - CIE_x_b) + \\\\ +#define CIE_C_rD ( (1./CIE_y_w) * \\ + ( CIE_x_w*(CIE_y_g - CIE_y_b) - \\ + CIE_y_w*(CIE_x_g - CIE_x_b) + \\ CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) ) -#define CIE_C_gD ( (1./CIE_y_w) * \\\\ - ( CIE_x_w*(CIE_y_b - CIE_y_r) - \\\\ - CIE_y_w*(CIE_x_b - CIE_x_r) - \\\\ +#define CIE_C_gD ( (1./CIE_y_w) * \\ + ( CIE_x_w*(CIE_y_b - CIE_y_r) - \\ + CIE_y_w*(CIE_x_b - CIE_x_r) - \\ CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) ) -#define CIE_C_bD ( (1./CIE_y_w) * \\\\ - ( CIE_x_w*(CIE_y_r - CIE_y_g) - \\\\ - CIE_y_w*(CIE_x_r - CIE_x_g) + \\\\ +#define CIE_C_bD ( (1./CIE_y_w) * \\ + ( CIE_x_w*(CIE_y_r - CIE_y_g) - \\ + CIE_y_w*(CIE_x_r - CIE_x_g) + \\ CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) ) #define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
