| 1 |
.\" SCCSid "$SunId$ LBL"
| 2 |
.nr PS 11
| 3 |
.ps 11
| 4 |
.nr VS 12
| 5 |
.vs 12
| 6 |
.nr PD .5v
| 7 |
.ds LF MGF
| 8 |
.ds RF Version 1.0
| 9 |
.DA May 1995
| 10 |
.TL
| 11 |
The Materials and Geometry Format
| 12 |
.AU
| 13 |
Greg Ward
| 14 |
.br
| 15 |
Lawrence Berkeley Laboratory
| 16 |
.NH
| 17 |
Introduction
| 18 |
.LP
| 19 |
The Materials and Geometry Format (referred to henceforth as MGF)
| 20 |
is a description language for 3-dimensional environments expressly
| 21 |
suited to visible light simulation and rendering.
| 22 |
The materials are physically-based and rely on standard and
| 23 |
well-accepted definitions of color, reflectance and transmittance
| 24 |
for good accuracy and reproducibility.
| 25 |
The geometry is based on boundary representation using simple
| 26 |
geometric primitives such as polygons, spheres and cones.
| 27 |
The file format itself is terse but human-readable ASCII text.
| 28 |
.NH 2
| 29 |
What makes MGF special?
| 30 |
.LP
| 31 |
There are three principal reasons to use MGF as an input language for
| 32 |
lighting simulation and physically-based rendering:
| 33 |
.RS
| 34 |
.IP 1.
| 35 |
It's the only existing format that describes materials physically.
| 36 |
.IP 2.
| 37 |
It is endorsed by the Illuminating Engineering Society of North
| 38 |
America (IESNA) as part of their LM-63-1995 standard for luminaire data.
| 39 |
.IP 3.
| 40 |
It's easy and fun to support since it comes with a standard parser
| 41 |
and sample scenes and objects at the web site,
| 42 |
"http://radsite.lbl.gov/mgf/HOME.html".
| 43 |
.RE
| 44 |
.LP
| 45 |
The standard parser provides both immediate and a long-term
| 46 |
benefits, since it presents a programming interface that is more
| 47 |
stable even than the language itself.
| 48 |
Unlike AutoCAD DXF and other de facto standards, a change to the
| 49 |
language will not break existing programs.
| 50 |
This is because the parser gives the calling software only those
| 51 |
entities it can handle.
| 52 |
If the translator understands only polygons, it will be given only
| 53 |
polygons.
| 54 |
If a new geometric primitive is included in a later version of the
| 55 |
standard, the new parser that comes with it will still be able to
| 56 |
express this entity as polygons.
| 57 |
Thus, the urgency of modifying code to support a changing standard
| 58 |
is removed, and long-term stability is assured.
| 59 |
.LP
| 60 |
This notion of
| 61 |
.I extensibility
| 62 |
is a cornerstone of the format, and it goes well beyond the
| 63 |
extensibility of other languages because is guarantees that new
| 64 |
versions of the standard will not break existing programs, and the
| 65 |
new information will be used as much as possible.
| 66 |
Other languages either require that all translators stay up to date
| 67 |
with the latest standard, or allow forward compatibility by simply
| 68 |
.I ignoring
| 69 |
new entities.
| 70 |
In MGF, if NURBS are added at some point and the translator or
| 71 |
loader does not handle them directly, the new version of the parser
| 72 |
will automatically convert them to smoothed polygons without
| 73 |
changing a single line of the calling program.
| 74 |
It is merely necessary to link to the new library, and all the new
| 75 |
entities are supported\(dg.
| 76 |
.FS
| 77 |
\(dgIf an old version of the parser encounters new entities it does
| 78 |
not recognize, the default action is to ignore them, printing a warning
| 79 |
message.
| 80 |
This may be overridden to support custom entities, but such
| 81 |
practice is discouraged because it weakens the standard.
| 82 |
.FE
| 83 |
.NH 2
| 84 |
What does MGF look like?
| 85 |
.LP
| 86 |
MGF has a simple entity-per-line structure, with a similar
| 87 |
appearance to Wavefront's .OBJ format.
| 88 |
Each entity is specified by a short keyword, and
| 89 |
arguments are separated by white space (tabs and/or spaces).
| 90 |
A newline may be escaped with a backslash ('\\'), in which case it
| 91 |
counts as a space.
| 92 |
Lines and continued lines may have up to 4096 characters, including
| 93 |
newlines, tabs and spaces.
| 94 |
A comment is an ignored entity whose keyword is the pound sign ('#').
| 95 |
.LP
| 96 |
Here is an MGF file that describes a simple two-drawer file cabinet:
| 97 |
.DS
| 98 |
# Conversion from inches to meters
| 99 |
xf -s .0254
| 100 |
# Surface material
| 101 |
m burgundy_formica =
| 102 |
c
| 103 |
cxy .362 .283
| 104 |
rd .0402
| 105 |
c
| 106 |
rs .0284 .05
| 107 |
sides 1
| 108 |
# Cabinet vertices
| 109 |
v fc.xy =
| 110 |
p .05 0 0
| 111 |
v fc.xY =
| 112 |
p .05 18 0
| 113 |
v fc.XY =
| 114 |
p 35.95 18 0
| 115 |
v fc.Xy =
| 116 |
p 35.95 0 0
| 117 |
# Cabinet
| 118 |
prism fc.xy fc.xY fc.XY fc.Xy 24
| 119 |
# Drawer vertices
| 120 |
v fcd.Xz =
| 121 |
p 34 0 0
| 122 |
v fcd.XZ =
| 123 |
p 34 0 10
| 124 |
v fcd.xZ =
| 125 |
p 0 0 10
| 126 |
v fcd.xz =
| 127 |
p 0 0 0
| 128 |
# Two drawers
| 129 |
o drawer
| 130 |
xf -t 1 18.1 2 -a 2 -t 0 0 11
| 131 |
prism fcd.xz fcd.Xz fcd.XZ fcd.xZ .9
| 132 |
xf
| 133 |
o
| 134 |
# End of units conversion
| 135 |
xf
| 136 |
.DE
| 137 |
.NH 2
| 138 |
MGF's place in the world of standards
| 139 |
.LP
| 140 |
MGF was developed initially to support detailed geometric
| 141 |
description of light fixtures for the IESNA luminaire data standard,
| 142 |
publication LM-63\(dg.
| 143 |
.FS
| 144 |
\(dgTo obtain the latest version of this standard, write to:
| 145 |
Illuminating Engineering Society of North America,
| 146 |
345 East 47th St.,
| 147 |
New York, NY 10017.
| 148 |
.FE
| 149 |
Existing standards for geometric description were either too
| 150 |
cumbersome (e.g.
| 151 |
.I Radiance)
| 152 |
or did not include physical materials (e.g. IGES).
| 153 |
It was noted early on that a standard able to fully describe
| 154 |
luminaires would necessarily be
| 155 |
capable of describing other objects as well; indeed whole
| 156 |
environments could be defined this way.
| 157 |
Since the descriptions would be physical, they could serve as input
| 158 |
to both lighting simulation and rendering software.
| 159 |
A standard language for describing the appearance of physical
| 160 |
objects has been lacking for some time, and current efforts in this
| 161 |
direction (i.e. STEP) seem several years away from fruition.
| 162 |
(There are other languages for describing realistic scenes
| 163 |
that deserve mention here, such as VRML and the Manchester Scene
| 164 |
Description Language, but none give specific attention to physical
| 165 |
material properties and are thus unsuitable for lighting
| 166 |
simulation.)\0
| 167 |
.LP
| 168 |
In short, we saw this as an opportunity to offer the lighting and
| 169 |
rendering community a simple and easy-to-support standard for
| 170 |
describing environments in a physically valid way.
| 171 |
Our hope is that this will promote sharing color, material and object
| 172 |
libraries as well as complete scene descriptions.
| 173 |
Sharing libraries is of obvious benefit to users and software
| 174 |
developers alike.
| 175 |
Sharing scenes should also permit
| 176 |
comparisons between rendering systems and
| 177 |
intervalidation of lighting calculations.
| 178 |
As anyone who works in this field knows, modeling is the most
| 179 |
difficult step in creating any simulation or rendering, and there is
| 180 |
no excuse for this data being held prisoner by a proprietary data
| 181 |
format.
| 182 |
.NH
| 183 |
MGF Basics
| 184 |
.LP
| 185 |
The default coordinate system in MGF is right-handed with
| 186 |
distances given in meters, though this can be effectively changed
| 187 |
by specifying a global transformation.
| 188 |
The transformation context is affected by the
| 189 |
.UL xf
| 190 |
entity, and the whole of MGF can be understood in terms of entities
| 191 |
and contexts.
| 192 |
.NH 2
| 193 |
Entities and Contexts
| 194 |
.LP
| 195 |
An
| 196 |
.I entity
| 197 |
in MGF is any non-blank line, which must be one of a finite set of
| 198 |
command keywords followed by zero or more arguments.
| 199 |
(As mentioned previously, an entity may continue over multiple lines
| 200 |
by escaping the newline with a backslash.)\0
| 201 |
Table 1 gives a list of entities and their expected arguments.
| 202 |
Section 3 gives more detailed information on each entity.
| 203 |
.KF
| 204 |
.TS
| 205 |
expand, box;
| 206 |
l l l.
| 207 |
Keyword Arguments Interpretation
| 208 |
| 209 |
# [anything ...] a comment
| 210 |
o [name] begin/end object context
| 211 |
xf [xform] begin/end transformation context
| 212 |
i pathname [xform] include file (with transformation)
| 213 |
ies pathname [-m f][xform] include IES luminaire (with transformation)
| 214 |
_ _ _
| 215 |
c [id [= [template]]] get/set color context
| 216 |
cxy x y set CIE (x,y) chromaticity for current color
| 217 |
cspec l_min l_max v1 v2 ... set relative spectrum for current color
| 218 |
cct temperature set spectrum based on black body temperature
| 219 |
cmix w1 c1 w2 c2 ... mix named colors to make current color
| 220 |
_ _ _
| 221 |
m [id [= [template]]] get/set material context
| 222 |
sides {1|2} set number of sides for current material
| 223 |
rd rho_d set diffuse reflectance for current material
| 224 |
td tau_d set diffuse transmittance for current material
| 225 |
ed epsilon_d set diffuse emittance for current material
| 226 |
rs rho_s alpha_r set specular reflectance for current material
| 227 |
ts tau_s alpha_t set specular transmittance for current material
| 228 |
ir n_real n_imag set index of refraction for current material
| 229 |
_ _ _
| 230 |
v [id [= [template]]] get/set vertex context
| 231 |
p x y z set point position for current vertex
| 232 |
n dx dy dz set surface normal for current vertex
| 233 |
_ _ _
| 234 |
f v1 v2 v3 ... polygon using current material, spec. vertices
| 235 |
sph vc radius sphere
| 236 |
cyl v1 radius v2 truncated right cylinder (open-ended)
| 237 |
cone v1 rad1 v2 rad2 truncated right cone (open-ended)
| 238 |
prism v1 v2 v3 ... length truncated right prism (closed solid)
| 239 |
ring vc rmin rmax circular ring with inner and outer radii
| 240 |
torus vc rmin rmax circular torus with inner and outer radii
| 241 |
.TE
| 242 |
.QP
| 243 |
.B "Table 1".
| 244 |
MGF entities and their arguments.
| 245 |
Arguments in brackets are optional.
| 246 |
Arguments in curly braces mean one of the given choices must
| 247 |
appear.
| 248 |
Ellipsis (...) mean that any number of arguments may be given.
| 249 |
.sp
| 250 |
.KE
| 251 |
.LP
| 252 |
A
| 253 |
.I context
| 254 |
describes the current state of the interpreter, and affects or is
| 255 |
affected by certain entities as they are read in.
| 256 |
MGF contexts can be divided into two types,
| 257 |
.I "hierarchical contexts"
| 258 |
and
| 259 |
.I "named contexts".
| 260 |
.LP
| 261 |
Hierarchical contexts are manipulated by a single entity and
| 262 |
have an associated "stack" onto which new
| 263 |
contexts are "pushed" using the entity.
| 264 |
The last context may be "popped" by giving the entity again with no
| 265 |
arguments.
| 266 |
The two hierarchical contexts in MGF are the current transformation,
| 267 |
manipulated with the
| 268 |
.UL xf
| 269 |
entity, and the current object, manipulated with the
| 270 |
.UL o
| 271 |
entity.
| 272 |
.KF
| 273 |
.TS
| 274 |
expand, allbox;
| 275 |
l c l l l.
| 276 |
Context Cntl. Entity Default Value Field Entities Affects
| 277 |
| 278 |
Object o - - -
| 279 |
Transform xf - - T{
| 280 |
f, sph, cyl, cone,
| 281 |
ring, torus, prism
| 282 |
T}
| 283 |
Material m 2-sided black T{
| 284 |
sides, rd, td,
| 285 |
ed, rs, ts
| 286 |
T} T{
| 287 |
f, sph, cyl, cone,
| 288 |
ring, torus, prism
| 289 |
T}
| 290 |
Color c neutral grey T{
| 291 |
cxy, cspec, cct, cmix
| 292 |
T} T{
| 293 |
rd, td, ed, rs, ts
| 294 |
T}
| 295 |
Vertex v T{
| 296 |
(0,0,0),
| 297 |
no normal
| 298 |
T} p, n T{
| 299 |
f, sph, cyl, cone,
| 300 |
ring, torus, prism
| 301 |
T}
| 302 |
.TE
| 303 |
.QP
| 304 |
.B "Table 2".
| 305 |
MGF contexts and their related entities and default values.
| 306 |
.sp
| 307 |
.KE
| 308 |
.LP
| 309 |
Named contexts in contrast hold sets of values that are swapped
| 310 |
in and out one at a time.
| 311 |
There are three named contexts in MGF, the current material, the
| 312 |
current color and the current vertex.
| 313 |
Each one may be associated with an identifier (any non-white
| 314 |
sequence of printing ASCII characters beginning with a letter),
| 315 |
and one of each is in effect at any given time.
| 316 |
Initially, these contexts are unnamed, and invoking an unnamed
| 317 |
context always returns to the original (default) values.
| 318 |
(See Table 2 for a list of contexts, their related
| 319 |
entities and defaults.)\0
| 320 |
.LP
| 321 |
It is easiest to think of a context as a "scratch space" where
| 322 |
values are written by some entities and read by others.
| 323 |
Naming a context allows us to reestablish the same scratch space
| 324 |
later, usually for reference but it can be altered as well.
| 325 |
Let us say we wanted to create a smooth blue plastic material with a
| 326 |
diffuse reflectance of 20% and a specular reflectance of 4%:
| 327 |
.DS
| 328 |
# Establish a new material context called "blue_plastic"
| 329 |
m blue_plastic =
| 330 |
# Reestablish a previous color context called "blue"
| 331 |
c blue
| 332 |
# Set the diffuse reflectance, which uses the above color
| 333 |
rd .20
| 334 |
# Get the unnamed color context (always starts out grey)
| 335 |
c
| 336 |
# Set the specular reflectance, which is uncolored
| 337 |
rs .04 0
| 338 |
# We're done, the current material context is now "blue_plastic"
| 339 |
.DE
| 340 |
Note that the above assumes that we have previously defined a color
| 341 |
context named "blue".
| 342 |
If we forgot to do that, the above description would generate an
| 343 |
"undefined" error.
| 344 |
The color context affects the material context indirectly because it
| 345 |
is read by the specular and diffuse reflectance entities, which are
| 346 |
in turn written to the current material.
| 347 |
It is not necessary to indent the entities that affect the material
| 348 |
definition, but it improves readability.
| 349 |
Note also that there is no explicit end to the material definition.
| 350 |
As long as a context remains in effect, its contents may be altered
| 351 |
by its field entities.
| 352 |
This will not affect previous uses of the context, however.
| 353 |
For example, a surface entity following the above definition will
| 354 |
have the specified color and reflectance, and later changes to the
| 355 |
material "blue_plastic" will have no effect on it.
| 356 |
.LP
| 357 |
Each of the three named contexts has an associated entity that
| 358 |
controls it.
| 359 |
The material context is controlled by the
| 360 |
.UL m
| 361 |
entity, the color context is controlled by the
| 362 |
.UL c
| 363 |
entity, and the vertex context is controlled by the
| 364 |
.UL v
| 365 |
entity.
| 366 |
There are exactly four forms for each entity.
| 367 |
The first form is the keyword by itself, which establishes
| 368 |
an unnamed context with predetermined default values.
| 369 |
This is a useful way to set values without worrying about saving
| 370 |
them for recall later.
| 371 |
The second form is to give the keyword with a previously defined
| 372 |
name.
| 373 |
This reestablishes a prior context for reuse.
| 374 |
The third form is to give the keyword with a name followed by an
| 375 |
equals sign.
| 376 |
(There must be a space between the name and the equals sign, since
| 377 |
it is a separate argument.)\0
| 378 |
This establishes a new context and assigns it the same default
| 379 |
values as the unnamed context.
| 380 |
The fourth and final form gives the keyword followed by a name then
| 381 |
an equals then the name of a previous context definition.
| 382 |
This establishes a new context for the first name, assigning the
| 383 |
values from the second named context rather than the usual defaults.
| 384 |
This is a convenient way create an alias or
| 385 |
to modify a context under a new name (i.e. "save as").
| 386 |
.NH 2
| 387 |
Hierarchical Contexts and Transformations
| 388 |
.LP
| 389 |
As mentioned in the last subsection, there are two hierarchical
| 390 |
contexts in MGF, the current object and the current transformation.
| 391 |
We will start by discussing the current object, since it is
| 392 |
the simpler of the two.
| 393 |
.NH 3
| 394 |
Objects
| 395 |
.LP
| 396 |
There is no particular need in lighting simulation or rendering to
| 397 |
name objects, but it may help the user
| 398 |
to know what object a particular surface is associated with.
| 399 |
The
| 400 |
.UL o
| 401 |
entity provides a convenient mechanism for associating names with
| 402 |
surfaces.
| 403 |
The basic use of this entity is as follows:
| 404 |
.DS
| 405 |
o object_name
| 406 |
[object entities...]
| 407 |
o subobject_name
| 408 |
[subobject entities...]
| 409 |
o
| 410 |
[more object entities and subobjects...]
| 411 |
o
| 412 |
.DE
| 413 |
The
| 414 |
.UL o
| 415 |
keyword by itself marks the end of an object context.
| 416 |
Any number of hierarchical context levels are supported, and there are no
| 417 |
rules governing the choice of object names except that they begin
| 418 |
with a letter and be made up of printing, non-white ASCII characters.
| 419 |
Indentation is not necessary of course, but it does improve
| 420 |
readability.
| 421 |
.NH 3
| 422 |
Transformations
| 423 |
.LP
| 424 |
MGF supports only rigid-body (i.e. non-distorting) transformations
| 425 |
with uniform scaling.
| 426 |
Unlike the other contexts, transformations have no associated
| 427 |
name, only arguments.
| 428 |
Thus, there is no way to reestablish a previous transformation other
| 429 |
than to give the same arguments over again.
| 430 |
Since the arguments are concise and self-explanatory, this was thought
| 431 |
sufficient.
| 432 |
The following transformation flags and
| 433 |
parameters are defined:
| 434 |
.TS
| 435 |
center;
| 436 |
l l.
| 437 |
-t dx dy dz translate objects along the given vector
| 438 |
-rx degrees rotate objects about the X-axis
| 439 |
-ry degrees rotate objects about the Y-axis
| 440 |
-rz degrees rotate objects about the Z-axis
| 441 |
-s scalefactor scale objects by the given factor
| 442 |
-mx mirror objects about the Y-Z plane
| 443 |
-my mirror objects about the X-Z plane
| 444 |
-mz mirror objects about the X-Y plane
| 445 |
-i N repeat the following arguments N times
| 446 |
-a N make an array of N geometric instances
| 447 |
.TE
| 448 |
Transform arguments have a cumulative effect.
| 449 |
That is, a rotation
| 450 |
about X of 20 degrees followed by a rotation about X of -50 degrees
| 451 |
results in a total rotation of -30 degrees.
| 452 |
However, if the two
| 453 |
rotations are separated by some translation vector, the cumulative
| 454 |
effect is quite different.
| 455 |
It is best to think of each argument as
| 456 |
acting on the included geometric objects, and each subsequent transformation
| 457 |
argument affects the objects relative to their new position/orientation.
| 458 |
.LP
| 459 |
For example, rotating an object about its center is most easily done
| 460 |
by translating
| 461 |
the object back to the origin, applying the desired rotation, and translating
| 462 |
it again back to its original position, like so:
| 463 |
.DS
| 464 |
# rotate an included object 20 degrees clockwise looking down
| 465 |
# an axis parallel to Y and passing through the point (15,0,-35)
| 466 |
xf -t -15 0 35 -ry -20 -t 15 0 -35
| 467 |
i object.mgf
| 468 |
xf
| 469 |
.DE
| 470 |
Note that the include entity,
| 471 |
.UL i,
| 472 |
permits a transformation to be given with it, so the above could
| 473 |
have been written more compactly as:
| 474 |
.DS
| 475 |
i object.mgf -t -15 0 35 -ry -20 -t 15 0 -35
| 476 |
.DE
| 477 |
.LP
| 478 |
Rotations are given in degrees counter-clockwise about a principal axis.
| 479 |
That is, with the thumb of the right hand pointing in the direction
| 480 |
of the axis, rotation follows the curl of the fingers.
| 481 |
.LP
| 482 |
The transform entity itself is cumulative, but in the reverse
| 483 |
order to its arguments.
| 484 |
That is, later transformations (i.e. enclosed transformations)
| 485 |
are prepended to existing (i.e. enclosing) ones.
| 486 |
A transform command
| 487 |
with no arguments is used to return to the previous condition.
| 488 |
It is
| 489 |
necessary that transforms and their end statements ("xf" by itself) be
| 490 |
balanced in a file, so that later or enclosing files are not affected.
| 491 |
.LP
| 492 |
Transformations apply only to geometric types, e.g. polygons, spheres, etc.
| 493 |
Vertices and the components that go into geometry are not directly affected.
| 494 |
This is to avoid confusion and the inadvertent multiple application of a
| 495 |
given transformation.
| 496 |
For example:
| 497 |
.DS
| 498 |
xf -t 5 0 0
| 499 |
v v1 =
| 500 |
p 0 10 0
| 501 |
n 0 0 1
| 502 |
xf -rx 180
| 503 |
# Transform now in effect is "-rx 180 -t 5 0 0"
| 504 |
ring v1 0 2
| 505 |
xf
| 506 |
xf
| 507 |
.DE
| 508 |
The final ring center is (5,-10,0) -- note that the vertex itself is
| 509 |
not affected by the transformation, only the geometry that calls on
| 510 |
it.
| 511 |
The normal orientation is (0,0,-1) due to the rotation about X,
| 512 |
which also reversed the sign of the central Y coordinate.
| 513 |
.NH 3
| 514 |
Arrays
| 515 |
.LP
| 516 |
The -a N transform specification causes the following transform
| 517 |
arguments to be repeated along with the contents of the included
| 518 |
objects N times.
| 519 |
The first instance of the geometry will be in its
| 520 |
initial location; the second instance will be repositioned according
| 521 |
to the named transformation; the third instance will be repositioned by
| 522 |
applying this transformation twice, and so on up to N-1 applications.
| 523 |
.LP
| 524 |
Multi-dimensional arrays may be specified with a single include
| 525 |
entity by giving multiple array commands separated by their
| 526 |
corresponding transforms.
| 527 |
A final transformation may be given
| 528 |
by preceding it with a -i 1 specification.
| 529 |
In other words, the
| 530 |
scope of an array command continues until the next -i or -a option.
| 531 |
.LP
| 532 |
The following MGF description places 60 spheres at a one unit spacing
| 533 |
in a 3x4x5 array, then moves the whole thing to an origin of
| 534 |
(15,30,45):
| 535 |
.DS
| 536 |
v v0 =
| 537 |
p 0 0 0
| 538 |
xf -a 3 -t 1 0 0 -a 4 -t 0 1 0 -a 5 -t 0 0 1 -i 1 -t 15 30 45
| 539 |
sph v0 0.1
| 540 |
xf
| 541 |
.DE
| 542 |
Note the "-i 1" in the specification, which marks the end of the
| 543 |
third array arguments before the final translation.
| 544 |
.NH 2
| 545 |
Detailed MGF Example
| 546 |
.LP
| 547 |
The following example of a simple room with a single door
| 548 |
and six file cabinets shows MGF in action, with copious comments to
| 549 |
help explain what's going on.
| 550 |
.LP
| 551 |
.DS
| 552 |
# "ceiling_tile" is a diffuse white surface with 75% reflectance:
| 553 |
# Create new named material context and clear it
| 554 |
m ceiling_tile =
| 555 |
# Specify one-sided material so we can see through from above
| 556 |
sides 1
| 557 |
# Set neutral color
| 558 |
c
| 559 |
# Set diffuse reflectance
| 560 |
rd .75
| 561 |
# "stainless_steel" is a mostly specular surface with 70% reflectance:
| 562 |
m stainless_steel =
| 563 |
sides 1
| 564 |
c
| 565 |
# Set specular reflectance to 50%, .08 roughness
| 566 |
rs .5 .08
| 567 |
# Other 20% reflectance is diffuse
| 568 |
rd .2
| 569 |
| 570 |
# The following materials were measured with a spectrophotometer:
| 571 |
m beige_paint =
| 572 |
sides 1
| 573 |
# Set diffuse spectral reflectance
| 574 |
c
| 575 |
# Spectrum measured in 10 nm increments from 400 to 700 nm
| 576 |
cspec 400 700 35.29 44.87 47.25 47.03 46.87 47.00 47.09 \\\\
| 577 |
47.15 46.80 46.17 46.26 48.74 51.08 51.31 51.10 \\\\
| 578 |
51.11 50.52 50.36 51.72 53.61 53.95 52.08 49.49 \\\\
| 579 |
48.30 48.75 49.99 51.35 52.75 54.44 56.34 58.00
| 580 |
rd 0.5078
| 581 |
# Neutral (grey) specular component
| 582 |
c
| 583 |
rs 0.0099 0.08000
| 584 |
m mottled_carpet =
| 585 |
sides 1
| 586 |
c
| 587 |
cspec 400 700 11.23 11.28 11.39 11.49 11.61 11.73 11.88 \\\\
| 588 |
12.02 12.12 12.19 12.30 12.37 12.37 12.36 12.34 \\\\
| 589 |
12.28 12.22 12.29 12.45 12.59 12.70 12.77 12.82 \\\\
| 590 |
12.88 12.98 13.24 13.67 14.31 15.55 17.46 19.75
| 591 |
rd 0.1245
| 592 |
m reddish_cloth =
| 593 |
# 2-sided so we can observe it from behind
| 594 |
sides 2
| 595 |
c
| 596 |
cspec 400 700 28.62 27.96 27.86 28.28 29.28 30.49 31.61 \\\\
| 597 |
32.27 32.26 31.83 31.13 30.07 29.14 29.03 29.69 \\\\
| 598 |
30.79 32.30 33.90 34.56 34.32 33.85 33.51 33.30 \\\\
| 599 |
33.43 34.06 35.26 37.04 39.41 42.55 46.46 51.00
| 600 |
rd 0.3210
| 601 |
| 602 |
sides 1
| 603 |
c
| 604 |
cspec 400 700 3.86 3.74 3.63 3.51 3.34 3.21 3.14 \\\\
| 605 |
3.09 3.08 3.14 3.13 2.91 2.72 2.74 2.72 \\\\
| 606 |
2.60 2.68 3.40 4.76 6.05 6.65 6.75 6.68 \\\\
| 607 |
6.63 6.56 6.51 6.46 6.41 6.36 6.34 6.34
| 608 |
rd 0.0402
| 609 |
c
| 610 |
rs 0.0284 0.05000
| 611 |
m speckled_grey_formica =
| 612 |
sides 1
| 613 |
c
| 614 |
cspec 400 700 30.95 44.77 51.15 52.60 53.00 53.37 53.68 \\\\
| 615 |
54.07 54.33 54.57 54.85 55.20 55.42 55.51 55.54 \\\\
| 616 |
55.46 55.33 55.30 55.52 55.81 55.91 55.92 56.00 \\\\
| 617 |
56.22 56.45 56.66 56.72 56.58 56.44 56.39 56.39
| 618 |
rd 0.5550
| 619 |
c
| 620 |
rs 0.0149 0.15000
| 621 |
| 622 |
# 40' x 22' x 9' office space with no windows and one door
| 623 |
| 624 |
# All measurements are in inches, so enclose with a metric conversion:
| 625 |
xf -s .0254
| 626 |
| 627 |
# The room corner vertices:
| 628 |
v rc.xyz =
| 629 |
p 0 0 0
| 630 |
v rc.Xyz =
| 631 |
p 480 0 0
| 632 |
v rc.xYz =
| 633 |
p 0 264 0
| 634 |
v rc.xyZ =
| 635 |
p 0 0 108
| 636 |
v rc.XYz =
| 637 |
p 480 264 0
| 638 |
v rc.xYZ =
| 639 |
p 0 264 108
| 640 |
v rc.XyZ =
| 641 |
p 480 0 108
| 642 |
v rc.XYZ =
| 643 |
p 480 264 108
| 644 |
| 645 |
# The floor:
| 646 |
# Push object name
| 647 |
o floor
| 648 |
# Get previously defined carpet material
| 649 |
m mottled_carpet
| 650 |
# Polygonal face using defined vertices
| 651 |
f rc.xyz rc.Xyz rc.XYz rc.xYz
| 652 |
# Pop object name
| 653 |
o
| 654 |
| 655 |
# The ceiling:
| 656 |
o ceiling
| 657 |
m ceiling_tile
| 658 |
f rc.xyZ rc.xYZ rc.XYZ rc.XyZ
| 659 |
o
| 660 |
| 661 |
# The door outline vertices:
| 662 |
v do.xz =
| 663 |
p 216 0 0
| 664 |
v do.Xz =
| 665 |
p 264 0 0
| 666 |
v do.xZ =
| 667 |
p 216 0 84
| 668 |
v do.XZ =
| 669 |
p 264 0 84
| 670 |
| 671 |
# The walls:
| 672 |
o wall
| 673 |
m beige_paint
| 674 |
o x
| 675 |
f rc.xyz rc.xYz rc.xYZ rc.xyZ
| 676 |
o
| 677 |
o X
| 678 |
f rc.Xyz rc.XyZ rc.XYZ rc.XYz
| 679 |
o
| 680 |
o y
| 681 |
f rc.xyz rc.xyZ rc.XyZ rc.Xyz do.Xz do.XZ do.xZ do.xz
| 682 |
o
| 683 |
o Y
| 684 |
f rc.xYz rc.XYz rc.XYZ rc.xYZ
| 685 |
o
| 686 |
o
| 687 |
| 688 |
# The door and jam vertices:
| 689 |
v djo.xz =
| 690 |
p 216 .5 0
| 691 |
v djo.xZ =
| 692 |
p 216 .5 84
| 693 |
v djo.XZ =
| 694 |
p 264 .5 84
| 695 |
v djo.Xz =
| 696 |
p 264 .5 0
| 697 |
v dji.Xz =
| 698 |
p 262 .5 0
| 699 |
v dji.XZ =
| 700 |
p 262 .5 82
| 701 |
v dji.xZ =
| 702 |
p 218 .5 82
| 703 |
v dji.xz =
| 704 |
p 218 .5 0
| 705 |
v door.xz =
| 706 |
p 218 0 0
| 707 |
v door.xZ =
| 708 |
p 218 0 82
| 709 |
v door.XZ =
| 710 |
p 262 0 82
| 711 |
v door.Xz =
| 712 |
p 262 0 0
| 713 |
| 714 |
# The door, jam and knob
| 715 |
o door
| 716 |
m burgundy_formica
| 717 |
f door.xz door.xZ door.XZ door.Xz
| 718 |
o jam
| 719 |
m beige_paint
| 720 |
f djo.xz djo.xZ djo.XZ djo.Xz dji.Xz dji.XZ dji.xZ dji.xz
| 721 |
f djo.xz do.xz do.xZ djo.xZ
| 722 |
f djo.xZ do.xZ do.XZ djo.XZ
| 723 |
f djo.Xz djo.XZ do.XZ do.Xz
| 724 |
f dji.xz dji.xZ door.xZ door.xz
| 725 |
f dji.xZ dji.XZ door.XZ door.xZ
| 726 |
f dji.Xz door.Xz door.XZ dji.XZ
| 727 |
o
| 728 |
o knob
| 729 |
m stainless_steel
| 730 |
# Define vertices needed for curved geometry
| 731 |
v kb1 =
| 732 |
p 257 0 36
| 733 |
v kb2 =
| 734 |
p 257 .25 36
| 735 |
n 0 1 0
| 736 |
v kb3 =
| 737 |
p 257 2 36
| 738 |
# 1" diameter cylindrical base from kb1 to kb2
| 739 |
cyl kb1 1 kb2
| 740 |
# Ring at base of knob stem
| 741 |
ring kb2 .4 1
| 742 |
# Knob stem
| 743 |
cyl kb2 .4 kb3
| 744 |
# Spherical knob
| 745 |
sph kb3 .85
| 746 |
o
| 747 |
o
| 748 |
| 749 |
i cubfurn.inc -mx -t 405 133.5 0
| 750 |
o
| 751 |
| 752 |
# Six file cabinets (36" wide each)
| 753 |
# ("filecab.inc" was given as an earlier example in Section 1.2)
| 754 |
o filecab.x
| 755 |
# include a file as an array of three 36" apart
| 756 |
i filecab.inc -t -36 0 0 -rz -90 -t 1 54 0 -a 3 -t 0 36 0
| 757 |
o
| 758 |
o filecab.X
| 759 |
# the other three cabinets
| 760 |
i filecab.inc -rz 90 -t 479 54 0 -a 3 -t 0 36 0
| 761 |
o
| 762 |
| 763 |
# End of transform from inches to meters:
| 764 |
xf
| 765 |
| 766 |
# The 10 recessed fluorescent ceiling fixtures
| 767 |
ies hlrs2gna.ies -t 1.2192 2.1336 2.74 -a 5 -t 2.4384 0 0 -a 2 -t 0 2.4384 0
| 768 |
.DE
| 769 |
.bp
| 770 |
.NH
| 771 |
MGF Entity Reference
| 772 |
.LP
| 773 |
There are currently 28 entities in the MGF specification.
| 774 |
For ease of reference we have broken these into five categories:
| 775 |
.IP 1.
| 776 |
General
| 777 |
.TS
| 778 |
lw(.75i) lw(1.75i) lw(3i).
| 779 |
| 780 |
| 781 |
| 782 |
| 783 |
| 784 |
.TE
| 785 |
.IP 2.
| 786 |
Color
| 787 |
.TS
| 788 |
| 789 |
| 790 |
| 791 |
| 792 |
| 793 |
| 794 |
.TE
| 795 |
.IP 3.
| 796 |
Material
| 797 |
.TS
| 798 |
| 799 |
| 800 |
| 801 |
| 802 |
| 803 |
| 804 |
| 805 |
| 806 |
| 807 |
.TE
| 808 |
.IP 4.
| 809 |
Vertex
| 810 |
.TS
| 811 |
| 812 |
| 813 |
| 814 |
| 815 |
.TE
| 816 |
.IP 5.
| 817 |
Geometry
| 818 |
.TS
| 819 |
| 820 |
| 821 |
| 822 |
| 823 |
| 824 |
| 825 |
| 826 |
| 827 |
.TE
| 828 |
.ds LH General Entities
| 829 |
.ds RH #
| 830 |
.bp
| 831 |
.SH
| 832 |
NAME
| 833 |
.LP
| 834 |
# - a comment
| 835 |
.SH
| 836 |
SYNOPSIS
| 837 |
.LP
| 838 |
.B #
| 839 |
| 840 |
.I anything
| 841 |
| 842 |
.SH
| 843 |
DESCRIPTION
| 844 |
.LP
| 845 |
A comment is a bit of text explanation.
| 846 |
Since it is an entity like any other (except that it has no effect),
| 847 |
there must be at least one space between the keyword (which is a
| 848 |
pound sign) and the "arguments," and the end of line may be escaped
| 849 |
as usual with the backslash character ('\\').
| 850 |
.LP
| 851 |
A comment may actually be used to hold auxiliary information such as
| 852 |
view parameters, which may be interpreted by some destination program.
| 853 |
Care should be taken under such circumstances that the user does not
| 854 |
inadvertently mung or mimic this information in other comments, and
| 855 |
it is therefore advisable to use an additional set of identifying
| 856 |
characters to distinguish such data.
| 857 |
.SH
| 858 |
EXAMPLE
| 859 |
.DS
| 860 |
# The following include file is in inches, so convert to meters
| 861 |
i cubgeom.inc -s .0254
| 862 |
# Stuff we don't want to see at the moment:
| 863 |
# i person.mgf -t 3 2 0
| 864 |
# ies hlrs3gna.ies -rz 90 -t 1.524 1.8288 2.74 \\\\
| 865 |
-a 6 -t 1.8288 0 0 -a 2 -t 0 3.048 0
| 866 |
.DE
| 867 |
.ds RH O
| 868 |
.bp
| 869 |
.SH
| 870 |
NAME
| 871 |
.LP
| 872 |
o - begin or end object context
| 873 |
.SH
| 874 |
SYNOPSIS
| 875 |
.LP
| 876 |
.B o
| 877 |
| 878 |
.I name
| 879 |
| 880 |
.SH
| 881 |
DESCRIPTION
| 882 |
.LP
| 883 |
If
| 884 |
.I name
| 885 |
is given, we push a new object context onto the stack, which is to
| 886 |
say that we begin a new subobject by this name\(dg.
| 887 |
.FS
| 888 |
\(dgA name is any sequence of printing, non-white ASCII characters
| 889 |
beginning with a letter.
| 890 |
.FE
| 891 |
If the
| 892 |
.UL o
| 893 |
keyword is given by itself, then we pop the last object context off
| 894 |
the stack, which means that we leave the current subobject.
| 895 |
.LP
| 896 |
All geometry between the start of an object context and its matching
| 897 |
end statement is associated with the given name.
| 898 |
This may be used in modeling software to help identify objects and
| 899 |
subobjects, or it may be ignored altogether.
| 900 |
.LP
| 901 |
Object begin and end statements should be balanced in a file, and
| 902 |
care should be taken not to overlap transform
| 903 |
.UL (xf)
| 904 |
contexts with object contexts, especially when arrays are involved.
| 905 |
This is because the standard parser will assign object contexts to
| 906 |
instanced geometry, which can get confused with other object
| 907 |
contexts if a clear enclosure is not maintained.
| 908 |
.SH
| 909 |
EXAMPLE
| 910 |
.DS
| 911 |
o body
| 912 |
o torso
| 913 |
i torso.mgf
| 914 |
o
| 915 |
o arm
| 916 |
o left
| 917 |
i leftarm.mgf
| 918 |
o
| 919 |
o right
| 920 |
i leftarm.mgf -mx
| 921 |
o
| 922 |
o
| 923 |
o
| 924 |
.DE
| 925 |
.SH
| 926 |
SEE ALSO
| 927 |
.LP
| 928 |
.UL xf
| 929 |
.ds RH XF
| 930 |
.bp
| 931 |
.SH
| 932 |
NAME
| 933 |
.LP
| 934 |
xf - begin or end transformation context
| 935 |
.SH
| 936 |
SYNOPSIS
| 937 |
.LP
| 938 |
.B xf
| 939 |
| 940 |
.I transform
| 941 |
| 942 |
.SH
| 943 |
DESCRIPTION
| 944 |
.LP
| 945 |
If a set of
| 946 |
.I transform
| 947 |
arguments are given, we push a new transformation context onto the
| 948 |
stack.
| 949 |
If the
| 950 |
.UL xf
| 951 |
keyword is given by itself, then we pop the last transformation
| 952 |
context off the stack.
| 953 |
The total transformation in effect at any given time is
| 954 |
computed by prepending each set subcontext arguments onto those of
| 955 |
its enclosing context.
| 956 |
This and other details about transformation specifications
| 957 |
are explained in some detail in section 2.2.2.
| 958 |
.LP
| 959 |
| 960 |
| 961 |
.TS
| 962 |
center;
| 963 |
l l.
| 964 |
| 965 |
| 966 |
| 967 |
| 968 |
| 969 |
| 970 |
| 971 |
| 972 |
| 973 |
| 974 |
.TE
| 975 |
.SH
| 976 |
EXAMPLE
| 977 |
.DS
| 978 |
# Create 3x5 array of evenly-spaced spheres (grid size = 3)
| 979 |
v vc =
| 980 |
p 0 0 0
| 981 |
xf -t 1 1 10 -a 3 -t 3 0 0 -a 5 -t 0 3 0
| 982 |
sph vc .5
| 983 |
xf
| 984 |
.DE
| 985 |
.SH
| 986 |
SEE ALSO
| 987 |
.LP
| 988 |
.UL i,
| 989 |
.UL ies,
| 990 |
.UL o
| 991 |
.ds RH I
| 992 |
.bp
| 993 |
.SH
| 994 |
NAME
| 995 |
.LP
| 996 |
i - include MGF data file
| 997 |
.SH
| 998 |
SYNOPSIS
| 999 |
.LP
| 1000 |
.B i
| 1001 |
.I pathname
| 1002 |
| 1003 |
.I transform
| 1004 |
| 1005 |
.SH
| 1006 |
DESCRIPTION
| 1007 |
.LP
| 1008 |
Include the information contained in the file
| 1009 |
.I pathname.
| 1010 |
If a
| 1011 |
.I transform
| 1012 |
specification is given, then it will be applied as though the
| 1013 |
include statement were enclosed by beginning and ending
| 1014 |
.UL xf
| 1015 |
entities with this transformation.
| 1016 |
.LP
| 1017 |
The
| 1018 |
.I pathname
| 1019 |
will be interpreted relative to the enclosing MGF file.
| 1020 |
That is, if the file containing the include statement is in some
| 1021 |
parent or subdirectory, then the given pathname is appended to this
| 1022 |
directory.
| 1023 |
It is illegal to specify a
| 1024 |
.I pathname
| 1025 |
relative to the root directory, and the MGF standard requires that
| 1026 |
all filenames adhere to the ISO-9660 8.3 name format for maximum
| 1027 |
portability between systems.
| 1028 |
The directory separator is defined to be slash ('/'), and drive
| 1029 |
specifications (such as "c:") are not allowed.
| 1030 |
All pathnames should be given in lower case, and will be converted to
| 1031 |
upper case on systems that require it.
| 1032 |
(That way, there are no accidental name collisions.)\0
| 1033 |
.LP
| 1034 |
The suggested suffix for MGF-adherent files is ".mgf".
| 1035 |
Files that are not in metric units but are in MGF may be given any
| 1036 |
suffix, but we suggest using ".inc" as a convention.
| 1037 |
.SH
| 1038 |
EXAMPLE
| 1039 |
.DS
| 1040 |
# Define vertices for 62x30" partition
| 1041 |
i pv62x30.inc
| 1042 |
# Insert 2 62x30" partitions
| 1043 |
o cpart1
| 1044 |
i partn.inc -t 75 130.5 0
| 1045 |
o
| 1046 |
o cpart3
| 1047 |
i partn.inc -t 186 130.5 0
| 1048 |
o
| 1049 |
# Define vertices for 62x36" partition
| 1050 |
i pv62x36.inc
| 1051 |
# Insert 62x36" partition
| 1052 |
o cpart2
| 1053 |
i partn.inc -t 105 130.5 0
| 1054 |
o
| 1055 |
.DE
| 1056 |
.SH
| 1057 |
SEE ALSO
| 1058 |
.LP
| 1059 |
.UL ies,
| 1060 |
.UL o,
| 1061 |
.UL xf
| 1062 |
.ds RH IES
| 1063 |
.bp
| 1064 |
.SH
| 1065 |
NAME
| 1066 |
.LP
| 1067 |
ies - include IESNA luminaire file
| 1068 |
.SH
| 1069 |
SYNOPSIS
| 1070 |
.LP
| 1071 |
.B ies
| 1072 |
.I pathname
| 1073 |
| 1074 |
.B \-m
| 1075 |
.I multiplier
| 1076 |
| 1077 |
| 1078 |
.I transform
| 1079 |
| 1080 |
.SH
| 1081 |
DESCRIPTION
| 1082 |
.LP
| 1083 |
Load the IES standard luminaire information contained in the file
| 1084 |
.I pathname.
| 1085 |
If a
| 1086 |
.I multiplier
| 1087 |
is given, all candela values will be multiplied by this factor.
| 1088 |
(This option must appear first if present.)\0
| 1089 |
If a
| 1090 |
.I transform
| 1091 |
| 1092 |
| 1093 |
.UL xf
| 1094 |
| 1095 |
.LP
| 1096 |
The
| 1097 |
.I pathname
| 1098 |
will be interpreted relative to the enclosing MGF file, and all
| 1099 |
restrictions discussed under the
| 1100 |
.UL i
| 1101 |
entity also apply to the IES file name.
| 1102 |
The suggested suffix is ".ies", but this has not been followed
| 1103 |
consistently by lighting manufacturers.
| 1104 |
.SH
| 1105 |
EXAMPLE
| 1106 |
.DS
| 1107 |
# Insert 10 2x4' fluorescent troffers in two groups
| 1108 |
ies cf9pr240.ies -t 3.6576 2.1336 2.74 -a 3 -t 2.4384 0 0 -a 2 -t 0 2.4384 0
| 1109 |
ies cf9pr240.ies -rz 90 -t 1.2192 1.8288 2.74 \\\\
| 1110 |
-a 2 -t 9.7536 0 0 -a 2 -t 0 3.048 0
| 1111 |
.DE
| 1112 |
.SH
| 1113 |
SEE ALSO
| 1114 |
.LP
| 1115 |
.UL i,
| 1116 |
.UL o,
| 1117 |
.UL xf
| 1118 |
.ds LH Color Entities
| 1119 |
.ds RH C
| 1120 |
.bp
| 1121 |
.SH
| 1122 |
NAME
| 1123 |
.LP
| 1124 |
c - get or set the current color context
| 1125 |
.SH
| 1126 |
SYNOPSIS
| 1127 |
.LP
| 1128 |
.B c
| 1129 |
| 1130 |
.I id
| 1131 |
| 1132 |
.B =
| 1133 |
| 1134 |
.I template
| 1135 |
| 1136 |
| 1137 |
| 1138 |
.SH
| 1139 |
DESCRIPTION
| 1140 |
.LP
| 1141 |
If the
| 1142 |
.UL c
| 1143 |
keyword is given by itself, then it establishes the unnamed color
| 1144 |
context, which is neutral (i.e. equal-energy) grey.
| 1145 |
This context may be modified, but the changes will not be saved.
| 1146 |
.LP
| 1147 |
If the keyword is followed by an identifier
| 1148 |
.I id,
| 1149 |
then it reestablishes a previous context.
| 1150 |
If the specified context was never defined, an error will result.
| 1151 |
.LP
| 1152 |
If the entity is given with an identifier
| 1153 |
followed by an equals sign ('='), then a new context is established,
| 1154 |
and cleared to the default neutral grey.
| 1155 |
(Note that the equals sign must be separated from other
| 1156 |
arguments by white space to be properly recognized.)\0
| 1157 |
If the equals sign is followed by a second identifier
| 1158 |
.I template,
| 1159 |
then this previously defined color will be used as a source of
| 1160 |
default values rather than grey.
| 1161 |
This is most useful for establishing a color alias.
| 1162 |
.SH
| 1163 |
EXAMPLE
| 1164 |
.DS
| 1165 |
# Define the color "red32"
| 1166 |
c red32 =
| 1167 |
cxy .42 .15
| 1168 |
# Make "cabinet_color" an alias for "red32"
| 1169 |
c cabinet_color = red32
| 1170 |
| 1171 |
# Later in another part of the description...
| 1172 |
| 1173 |
# Get our cabinet color
| 1174 |
c cabinet_color
| 1175 |
# Get the geometry
| 1176 |
i cabgeom.mgf
| 1177 |
.DE
| 1178 |
.SH
| 1179 |
SEE ALSO
| 1180 |
.LP
| 1181 |
.UL cct,
| 1182 |
.UL cmix,
| 1183 |
.UL cspec,
| 1184 |
.UL cxy,
| 1185 |
.UL m
| 1186 |
.ds RH CXY
| 1187 |
.bp
| 1188 |
.SH
| 1189 |
NAME
| 1190 |
.LP
| 1191 |
cxy - set the CIE (x,y) chromaticity for the current color
| 1192 |
.SH
| 1193 |
SYNOPSIS
| 1194 |
.LP
| 1195 |
.B cxy
| 1196 |
.I "x y"
| 1197 |
.SH
| 1198 |
DESCRIPTION
| 1199 |
.LP
| 1200 |
This entity sets the current color using (x,y) chromaticity
| 1201 |
coordinates for the 1931 CIE standard 2 degree observer.
| 1202 |
Legal values for
| 1203 |
.I x
| 1204 |
and
| 1205 |
.I y
| 1206 |
are greater than zero and sum to less than one, and more
| 1207 |
specifically they must fit within the curve of the visible spectrum.
| 1208 |
The
| 1209 |
.I x
| 1210 |
coordinate roughly corresponds to the red part of the spectrum and
| 1211 |
the
| 1212 |
.I y
| 1213 |
coordinate corresponds to the green.
| 1214 |
The CIE z coordinate is implicit, since it is equal to (1-x-y).
| 1215 |
.LP
| 1216 |
All colors in MGF are absolute, thus colorimeter measurements should
| 1217 |
be conducted the same for surfaces as for light sources.
| 1218 |
Applying a standard illuminant calculation is redundant and
| 1219 |
introduces inaccuracies, and should therefore be avoided if
| 1220 |
possible.
| 1221 |
.LP
| 1222 |
Conversion between CIE colors and those more commonly used in
| 1223 |
computer graphics are described in the application notes section
| 1224 |
6.1.1.
| 1225 |
.SH
| 1226 |
EXAMPLE
| 1227 |
.DS
| 1228 |
# Set unnamed color context
| 1229 |
c
| 1230 |
# Set CIE chromaticity to a bluish hue
| 1231 |
cxy .15 .2
| 1232 |
# Apply color to diffuse reflectance of 15%
| 1233 |
rd .15
| 1234 |
.DE
| 1235 |
.SH
| 1236 |
SEE ALSO
| 1237 |
.LP
| 1238 |
.UL c,
| 1239 |
.UL cct,
| 1240 |
.UL cmix,
| 1241 |
.UL cspec
| 1242 |
.ds RH CSPEC
| 1243 |
.bp
| 1244 |
.SH
| 1245 |
NAME
| 1246 |
.LP
| 1247 |
cspec - set the relative spectrum for the current color
| 1248 |
.SH
| 1249 |
SYNOPSIS
| 1250 |
.LP
| 1251 |
.B cspec
| 1252 |
.I "l_min l_max o1 o2 ... oN"
| 1253 |
.SH
| 1254 |
DESCRIPTION
| 1255 |
.LP
| 1256 |
Assign a relative spectrum measured between
| 1257 |
.I l_min
| 1258 |
and
| 1259 |
.I l_max
| 1260 |
nanometers at evenly spaced intervals.
| 1261 |
The first value,
| 1262 |
.I o1
| 1263 |
corresponds to the measurement at
| 1264 |
.I l_min,
| 1265 |
and the last value,
| 1266 |
.I oN
| 1267 |
| 1268 |
.I l_max.
| 1269 |
Values in between are separated by
| 1270 |
.I "(l_max-l_min)/(N-1)"
| 1271 |
nanometers.
| 1272 |
All values must be non-negative, and the spectrum outside of the
| 1273 |
specified range is assumed to be zero.
| 1274 |
(The visible range is 380 to 780 nm.)\0
| 1275 |
The actual units and scale of the measurements do not matter,
| 1276 |
since the total will be
| 1277 |
normalized according to whatever the color is modifying
| 1278 |
(e.g. photometric reflectance or emittance).
| 1279 |
.SH
| 1280 |
EXAMPLE
| 1281 |
.DS
| 1282 |
# Color measured at 10 nm increments from 400 to 700
| 1283 |
m reddish_cloth =
| 1284 |
c
| 1285 |
| 1286 |
| 1287 |
| 1288 |
| 1289 |
rd 0.3210
| 1290 |
.DE
| 1291 |
.SH
| 1292 |
SEE ALSO
| 1293 |
.LP
| 1294 |
.UL c,
| 1295 |
.UL cct,
| 1296 |
.UL cmix,
| 1297 |
.UL cxy
| 1298 |
.ds RH CCT
| 1299 |
.bp
| 1300 |
.SH
| 1301 |
NAME
| 1302 |
.LP
| 1303 |
cct - set the current color to a black body spectrum
| 1304 |
.SH
| 1305 |
SYNOPSIS
| 1306 |
.LP
| 1307 |
.B cct
| 1308 |
.I temperature
| 1309 |
.SH
| 1310 |
DESCRIPTION
| 1311 |
.LP
| 1312 |
The
| 1313 |
.UL cct
| 1314 |
entity sets the current color to the spectrum of an ideal
| 1315 |
black body radiating at
| 1316 |
.I temperature
| 1317 |
degrees Kelvin.
| 1318 |
This is often the most convenient way to set the color of an
| 1319 |
incandescent light source, but it is not recommended for
| 1320 |
fluorescent lamps or other materials that do not fit a
| 1321 |
black body spectrum.
| 1322 |
.SH
| 1323 |
EXAMPLE
| 1324 |
.DS
| 1325 |
# Define an incandescent source material at 3000 degrees K
| 1326 |
m incand3000k =
| 1327 |
c
| 1328 |
cct 3000
| 1329 |
ed 1500
| 1330 |
.DE
| 1331 |
.SH
| 1332 |
SEE ALSO
| 1333 |
.LP
| 1334 |
.UL c,
| 1335 |
.UL cmix,
| 1336 |
.UL cspec,
| 1337 |
.UL cxy
| 1338 |
.ds RH CMIX
| 1339 |
.bp
| 1340 |
.SH
| 1341 |
NAME
| 1342 |
.LP
| 1343 |
cmix - mix two or more named colors to make the current color
| 1344 |
.SH
| 1345 |
SYNOPSIS
| 1346 |
.LP
| 1347 |
.B cmix
| 1348 |
.I "w1 c1 w2 c2 ..."
| 1349 |
.SH
| 1350 |
DESCRIPTION
| 1351 |
.LP
| 1352 |
The
| 1353 |
.UL cmix
| 1354 |
entity sums together two or more named colors using specified
| 1355 |
weighting coefficients, which correspond to the relative
| 1356 |
photometric brightness of each.
| 1357 |
As in all color specifications, the result is normalized so the
| 1358 |
absolute scale of the weights does not matter, only their relative
| 1359 |
values.
| 1360 |
.LP
| 1361 |
If any of the colors is a spectral quantity (i.e. from a
| 1362 |
.UL cspec
| 1363 |
or
| 1364 |
.UL cct
| 1365 |
entity), then all the colors are first converted to spectral
| 1366 |
quantities.
| 1367 |
This is done with an approximation for CIE (x,y) chromaticities,
| 1368 |
which may be problematic depending on their values.
| 1369 |
In general, it is safest to add together colors that are either
| 1370 |
all spectral quantities or all CIE quantities.
| 1371 |
.SH
| 1372 |
EXAMPLE
| 1373 |
.DS
| 1374 |
# Define RGB primaries for a standard color monitor
| 1375 |
c R =
| 1376 |
cxy 0.640 0.330
| 1377 |
c G =
| 1378 |
cxy 0.290 0.600
| 1379 |
c B =
| 1380 |
cxy 0.150 0.060
| 1381 |
# Mix them together in appropriate amounts for white
| 1382 |
c white =
| 1383 |
cmix 0.265 R 0.670 G 0.065 B
| 1384 |
.DE
| 1385 |
.SH
| 1386 |
SEE ALSO
| 1387 |
.LP
| 1388 |
.UL c,
| 1389 |
.UL cct,
| 1390 |
.UL cspec,
| 1391 |
.UL cxy
| 1392 |
.ds LH Material Entities
| 1393 |
.ds RH M
| 1394 |
.bp
| 1395 |
.SH
| 1396 |
NAME
| 1397 |
.LP
| 1398 |
m - get or set the current material context
| 1399 |
.SH
| 1400 |
SYNOPSIS
| 1401 |
.LP
| 1402 |
.B m
| 1403 |
| 1404 |
.I id
| 1405 |
| 1406 |
.B =
| 1407 |
| 1408 |
.I template
| 1409 |
| 1410 |
| 1411 |
| 1412 |
.SH
| 1413 |
DESCRIPTION
| 1414 |
.LP
| 1415 |
If the
| 1416 |
.UL m
| 1417 |
| 1418 |
the unnamed material context, which is a perfect two-sided black absorber.
| 1419 |
| 1420 |
.LP
| 1421 |
| 1422 |
.I id,
| 1423 |
| 1424 |
| 1425 |
.LP
| 1426 |
| 1427 |
| 1428 |
and cleared to the default material.
| 1429 |
| 1430 |
| 1431 |
| 1432 |
.I template,
| 1433 |
then this previously defined material will be used as a source of
| 1434 |
default values instead.
| 1435 |
This may be used to establish a material alias, or to modify an
| 1436 |
existing material and give it a new name.
| 1437 |
.LP
| 1438 |
The sum of the diffuse and specular reflectances and transmittances
| 1439 |
must not be greater than one (with no negative values, obviously).
| 1440 |
These values are assumed to be measured at normal incidence.
| 1441 |
If an index of refraction is given, this may modify the balance between
| 1442 |
diffuse and specular reflectance at other incident angles.
| 1443 |
If the
| 1444 |
material is one-sided (see
| 1445 |
.UL sides
| 1446 |
entity), then it may be a dielectric interface.
| 1447 |
In this case, the specular transmittance given is that which would be
| 1448 |
measured at normal incidence for a pane of the material 5 mm thick.
| 1449 |
This is important for figuring the actual transmittance for non-planar
| 1450 |
geometries assuming a uniformly absorbing medium.
| 1451 |
(Diffuse transmittance will not be affected by thickness.)\0
| 1452 |
If the index of
| 1453 |
refraction has an imaginary part, then the surface is a metal and this
| 1454 |
implies other properties as well.
| 1455 |
The default index of refraction is that of a vacuum, i.e. (1,0).
| 1456 |
.SH
| 1457 |
EXAMPLE
| 1458 |
.DS
| 1459 |
# Define a blue enamel paint
| 1460 |
m blue_enamel =
| 1461 |
c
| 1462 |
cxy 0.2771 0.2975
| 1463 |
rd 0.5011
| 1464 |
c
| 1465 |
rs 0.0100 0.0350
| 1466 |
# Assign blue_enamel to be the color of the south wall
| 1467 |
m swall_mat = blue_enamel
| 1468 |
| 1469 |
# South wall face
| 1470 |
m swall_mat
| 1471 |
f sv1 sv2 sv3 sv4
| 1472 |
.DE
| 1473 |
.SH
| 1474 |
SEE ALSO
| 1475 |
.LP
| 1476 |
.UL ed,
| 1477 |
.UL ir,
| 1478 |
.UL rd,
| 1479 |
.UL rs,
| 1480 |
.UL sides,
| 1481 |
.UL td,
| 1482 |
.UL ts
| 1483 |
.ds RH SIDES
| 1484 |
.bp
| 1485 |
.SH
| 1486 |
NAME
| 1487 |
.LP
| 1488 |
sides - set the number of sides for the current material
| 1489 |
.SH
| 1490 |
SYNOPSIS
| 1491 |
.LP
| 1492 |
.B sides
| 1493 |
| 1494 |
.B 1
| 1495 |
| 1496 |
.B 2
| 1497 |
| 1498 |
.SH
| 1499 |
DESCRIPTION
| 1500 |
.LP
| 1501 |
The
| 1502 |
.UL sides
| 1503 |
entity is used to set the number of sides for the current material.
| 1504 |
If a surface is two-sided, then it will appear
| 1505 |
identical when viewed from either the front or the back.
| 1506 |
If a surface is one-sided,
| 1507 |
then it appears invisible when viewed from the back side.
| 1508 |
This means
| 1509 |
that a transmitting object will affect the light coming in through the
| 1510 |
front surface and ignore the characteristics of the back surface,
| 1511 |
unless the index of refraction is set.
| 1512 |
If the index of refraction is set, then the object will act as a
| 1513 |
solid piece of dielectric material.
| 1514 |
In either case, the transmission properties of the exiting surface
| 1515 |
should be the same as the incident surface for the model to be
| 1516 |
physically valid.
| 1517 |
.LP
| 1518 |
The default number of sides is two.
| 1519 |
.SH
| 1520 |
EXAMPLE
| 1521 |
.DS
| 1522 |
# Describe a blue crystal ball
| 1523 |
m blue_crystal =
| 1524 |
ir 1.650000 0
| 1525 |
# Solid dielectrics must use one-sided materials
| 1526 |
sides 1
| 1527 |
c
| 1528 |
rs 0.0602 0
| 1529 |
c
| 1530 |
cxy 0.3127 0.2881
| 1531 |
ts 0.6425 0
| 1532 |
v sc =
| 1533 |
p 10 15 1.5
| 1534 |
sph sc .02
| 1535 |
.DE
| 1536 |
.SH
| 1537 |
SEE ALSO
| 1538 |
.LP
| 1539 |
.UL ed,
| 1540 |
.UL ir,
| 1541 |
.UL m,
| 1542 |
.UL rd,
| 1543 |
.UL rs,
| 1544 |
.UL td,
| 1545 |
.UL ts
| 1546 |
.ds RH RD
| 1547 |
.bp
| 1548 |
.SH
| 1549 |
NAME
| 1550 |
.LP
| 1551 |
rd - set the diffuse reflectance for the current material
| 1552 |
.SH
| 1553 |
SYNOPSIS
| 1554 |
.LP
| 1555 |
.B rd
| 1556 |
.I rho_d
| 1557 |
.SH
| 1558 |
DESCRIPTION
| 1559 |
.LP
| 1560 |
Set the diffuse reflectance for the current material to
| 1561 |
.I rho_d
| 1562 |
using the current color to determine the spectral characteristics.
| 1563 |
This is the fraction of visible light that is reflected from a
| 1564 |
surface equally in all directions according to Lambert's law, and is
| 1565 |
often called the "Lambertian component."
| 1566 |
Photometric reflectance is measured according to v(lambda)
| 1567 |
response function of the 1931 CIE standard 2
| 1568 |
degree observer, and assumes an equal-energy white light source.
| 1569 |
The value must be between zero and one, and may be further
| 1570 |
restricted by the luminosity of the selected color.
| 1571 |
(I.e. it is impossible to have a violet material with a photometric
| 1572 |
reflectance close to one since the eye is less sensitive in this part
| 1573 |
of the spectrum.)\0
| 1574 |
.LP
| 1575 |
The default diffuse reflectance is zero.
| 1576 |
.SH
| 1577 |
EXAMPLE
| 1578 |
.DS
| 1579 |
# An off-white paint with 70% reflectance
| 1580 |
m flat_white70 =
| 1581 |
c
| 1582 |
cxy .3632 .3420
| 1583 |
rd .70
| 1584 |
.DE
| 1585 |
.SH
| 1586 |
SEE ALSO
| 1587 |
.LP
| 1588 |
.UL c,
| 1589 |
.UL ed,
| 1590 |
.UL ir,
| 1591 |
.UL m,
| 1592 |
.UL rs,
| 1593 |
.UL sides,
| 1594 |
.UL td,
| 1595 |
.UL ts
| 1596 |
.ds RH TD
| 1597 |
.bp
| 1598 |
.SH
| 1599 |
NAME
| 1600 |
.LP
| 1601 |
td - set the diffuse transmittance for the current material
| 1602 |
.SH
| 1603 |
SYNOPSIS
| 1604 |
.LP
| 1605 |
.B td
| 1606 |
.I tau_d
| 1607 |
.SH
| 1608 |
DESCRIPTION
| 1609 |
.LP
| 1610 |
Set the diffuse transmittance for the current material to
| 1611 |
.I tau_d
| 1612 |
| 1613 |
This is the fraction of visible light that is transmitted through a
| 1614 |
surface equally in all (transmitted) directions.
| 1615 |
Like reflectance, transmittance is measured according to the
| 1616 |
standard v(lambda) curve, and assumes an equal-energy white light source.
| 1617 |
It is probably not possible to create a material with a diffuse
| 1618 |
transmittance above 50%, since well-diffused light will be reflected
| 1619 |
as well.
| 1620 |
.LP
| 1621 |
The default diffuse transmittance is zero.
| 1622 |
.SH
| 1623 |
EXAMPLE
| 1624 |
.DS
| 1625 |
# Model a perfect spherical diffuser, i.e. light hitting \
| 1626 |
either side will be scattered equally in all directions
| 1627 |
m wonderland_diffuser =
| 1628 |
c
| 1629 |
td .5
| 1630 |
rd .5
| 1631 |
.DE
| 1632 |
.SH
| 1633 |
SEE ALSO
| 1634 |
.LP
| 1635 |
.UL c,
| 1636 |
.UL ed,
| 1637 |
.UL ir,
| 1638 |
.UL m,
| 1639 |
.UL rd,
| 1640 |
.UL rs,
| 1641 |
.UL sides,
| 1642 |
.UL ts
| 1643 |
.ds RH ED
| 1644 |
.bp
| 1645 |
.SH
| 1646 |
NAME
| 1647 |
.LP
| 1648 |
ed - set the diffuse emittance for the current material
| 1649 |
.SH
| 1650 |
SYNOPSIS
| 1651 |
.LP
| 1652 |
.B ed
| 1653 |
.I epsilon_d
| 1654 |
.SH
| 1655 |
DESCRIPTION
| 1656 |
.LP
| 1657 |
Set the diffuse emittance for the current material to
| 1658 |
.I epsilon_d
| 1659 |
lumens per square meter using the current color to determine the
| 1660 |
| 1661 |
Note that this is emittance rather than exitance, and therefore
| 1662 |
does not include reflected or transmitted light, which is a function
| 1663 |
of the other material settings and the illuminated environment.
| 1664 |
.LP
| 1665 |
The total lumen output of a convex emitting object
| 1666 |
is the radiating area of that object multiplied by its emittance.
| 1667 |
Therefore, one can compute the appropriate
| 1668 |
.I epsilon_d
| 1669 |
value for an emitter by dividing the total lumen output by the
| 1670 |
radiating area (in square meters).
| 1671 |
.LP
| 1672 |
The default emittance is zero.
| 1673 |
.SH
| 1674 |
EXAMPLE
| 1675 |
.DS
| 1676 |
# A 100-watt incandescent bulb (1600 lumens) modeled as a sphere
| 1677 |
m
| 1678 |
c
| 1679 |
cct 3000
| 1680 |
ed 87712
| 1681 |
v cent =
| 1682 |
p 0 0 0
| 1683 |
sph cent .0381
| 1684 |
.DE
| 1685 |
.SH
| 1686 |
SEE ALSO
| 1687 |
.LP
| 1688 |
.UL c,
| 1689 |
.UL ir,
| 1690 |
.UL m,
| 1691 |
.UL rd,
| 1692 |
.UL rs,
| 1693 |
.UL sides,
| 1694 |
.UL td,
| 1695 |
.UL ts
| 1696 |
.ds RH RS
| 1697 |
.bp
| 1698 |
.SH
| 1699 |
NAME
| 1700 |
.LP
| 1701 |
rs - set the specular reflectance for the current material
| 1702 |
.SH
| 1703 |
SYNOPSIS
| 1704 |
.LP
| 1705 |
.B rs
| 1706 |
.I "rho_s alpha_r"
| 1707 |
.SH
| 1708 |
DESCRIPTION
| 1709 |
.LP
| 1710 |
Set the specular reflectance for the current material to
| 1711 |
.I rho_s
| 1712 |
| 1713 |
The surface roughness parameter is set to
| 1714 |
.I alpha_r,
| 1715 |
which is the RMS height of surface variations over the
| 1716 |
autocorrelation distance (equivalent to RMS facet slope).
| 1717 |
A roughness value of zero means a perfectly smooth surface, and
| 1718 |
values greater than 0.2 are unusual.
| 1719 |
(See application notes section 6.1.2 for a comparison between the
| 1720 |
roughness parameter and Phong specular power.)\0
| 1721 |
.LP
| 1722 |
The default specular reflectance is zero.
| 1723 |
.SH
| 1724 |
EXAMPLE
| 1725 |
.DS
| 1726 |
# Define a slightly rough brass metallic surface
| 1727 |
m rough_brass =
| 1728 |
c
| 1729 |
cxy .3820 .4035
| 1730 |
# 30% specular, 9% diffuse
| 1731 |
rs .30 .08
| 1732 |
rd .09
| 1733 |
.DE
| 1734 |
.SH
| 1735 |
SEE ALSO
| 1736 |
.LP
| 1737 |
.UL c,
| 1738 |
.UL ed,
| 1739 |
.UL ir,
| 1740 |
.UL m,
| 1741 |
.UL rd,
| 1742 |
.UL sides,
| 1743 |
.UL td,
| 1744 |
.UL ts
| 1745 |
.ds RH TS
| 1746 |
.bp
| 1747 |
.SH
| 1748 |
NAME
| 1749 |
.LP
| 1750 |
ts - set the specular transmittance for the current material
| 1751 |
.SH
| 1752 |
SYNOPSIS
| 1753 |
.LP
| 1754 |
.B ts
| 1755 |
.I "tau_s alpha_t"
| 1756 |
.SH
| 1757 |
DESCRIPTION
| 1758 |
.LP
| 1759 |
Set the specular transmittance for the current material to
| 1760 |
.I tau_s
| 1761 |
| 1762 |
The effective surface roughness is set to
| 1763 |
.I alpha_t.
| 1764 |
Rays will be transmitted with the same distribution as they would
| 1765 |
have been reflected with if this roughness value were given to the
| 1766 |
.UL rs
| 1767 |
entity.
| 1768 |
.LP
| 1769 |
The default specular transmittance is zero.
| 1770 |
.SH
| 1771 |
EXAMPLE
| 1772 |
.DS
| 1773 |
# Define a green glass material (58% transmittance)
| 1774 |
m glass =
| 1775 |
sides 2
| 1776 |
ir 1.52 0
| 1777 |
c
| 1778 |
rs 0.0725 0
| 1779 |
c
| 1780 |
cxy .23 .38
| 1781 |
ts 0.5815 0
| 1782 |
# Define an uncolored translucent plastic (40% transmittance)
| 1783 |
m translucent =
| 1784 |
sides 2
| 1785 |
ir 1.4 0
| 1786 |
c
| 1787 |
rs .045 0
| 1788 |
ts .40 .05
| 1789 |
.DE
| 1790 |
.SH
| 1791 |
SEE ALSO
| 1792 |
.LP
| 1793 |
.UL c,
| 1794 |
.UL ed,
| 1795 |
.UL ir,
| 1796 |
.UL m,
| 1797 |
.UL rd,
| 1798 |
.UL rs,
| 1799 |
.UL sides,
| 1800 |
.UL td
| 1801 |
.ds RH IR
| 1802 |
.bp
| 1803 |
.SH
| 1804 |
NAME
| 1805 |
.LP
| 1806 |
ir - set the complex index of refraction for the current material
| 1807 |
.SH
| 1808 |
SYNOPSIS
| 1809 |
.LP
| 1810 |
.B ir
| 1811 |
.I "n_real n_imag"
| 1812 |
.SH
| 1813 |
DESCRIPTION
| 1814 |
.LP
| 1815 |
Set the index of refraction for the current material to
| 1816 |
.I (n_real,n_imag).
| 1817 |
If the material is a dielectric (as opposed to metallic), then
| 1818 |
.I n_imag
| 1819 |
should be zero.
| 1820 |
For solid dielectric objects, the material should be made one-sided.
| 1821 |
If it is being used for thin objects, then a two-sided
| 1822 |
material is appropriate.
| 1823 |
(See the
| 1824 |
.UL sides
| 1825 |
entity.)\0
| 1826 |
.LP
| 1827 |
The default index of refraction is that of a vacuum, (1,0).
| 1828 |
.SH
| 1829 |
EXAMPLE
| 1830 |
.DS
| 1831 |
# Define polished aluminum material
| 1832 |
m polished_aluminum =
| 1833 |
# Complex index of refraction (from physics table)
| 1834 |
ir .770058 6.08351
| 1835 |
c
| 1836 |
rs .75 0
| 1837 |
.DE
| 1838 |
.SH
| 1839 |
SEE ALSO
| 1840 |
.LP
| 1841 |
.UL c,
| 1842 |
.UL ed,
| 1843 |
.UL m,
| 1844 |
.UL rd,
| 1845 |
.UL rs,
| 1846 |
.UL sides,
| 1847 |
.UL td,
| 1848 |
.UL ts
| 1849 |
.ds LH Vertex Entities
| 1850 |
.ds RH V
| 1851 |
.bp
| 1852 |
.SH
| 1853 |
NAME
| 1854 |
.LP
| 1855 |
v - get or set the current vertex context
| 1856 |
.SH
| 1857 |
SYNOPSIS
| 1858 |
.LP
| 1859 |
.B v
| 1860 |
| 1861 |
.I id
| 1862 |
| 1863 |
.B =
| 1864 |
| 1865 |
.I template
| 1866 |
| 1867 |
| 1868 |
| 1869 |
.SH
| 1870 |
DESCRIPTION
| 1871 |
.LP
| 1872 |
If the
| 1873 |
.UL v
| 1874 |
| 1875 |
the unnamed vertex context, which is the origin with no normal.
| 1876 |
| 1877 |
(The unnamed vertex is never used except as a source of default
| 1878 |
values since all geometric entities call their vertices by name.)\0
| 1879 |
.LP
| 1880 |
| 1881 |
.I id,
| 1882 |
| 1883 |
| 1884 |
.LP
| 1885 |
| 1886 |
| 1887 |
and cleared to the default vertex (the origin).
| 1888 |
| 1889 |
| 1890 |
| 1891 |
.I template,
| 1892 |
then this previously defined vertex will be used as a source of
| 1893 |
| 1894 |
This may be used to establish a vertex alias, or to modify an
| 1895 |
existing vertex and give it a new name.
| 1896 |
.LP
| 1897 |
A non-zero vertex normal must be given for
| 1898 |
certain entities, specifically
| 1899 |
.UL ring
| 1900 |
and
| 1901 |
.UL torus
| 1902 |
require a normal direction.
| 1903 |
An
| 1904 |
.UL f
| 1905 |
entity will interpolate vertex normals if given, and
| 1906 |
use the polygon plane normal otherwise.
| 1907 |
See the
| 1908 |
.UL prism
| 1909 |
entry for an explanation of how it interprets and uses vertex
| 1910 |
normals.
| 1911 |
The other entities ignore vertex normals if present.
| 1912 |
.LP
| 1913 |
The actual position and normal direction for a vertex is determined
| 1914 |
at the time of use by a geometric entity.
| 1915 |
Specifically, the transformation in effect at the time the vertex is
| 1916 |
defined is irrelevant.
| 1917 |
The only transformation that matters is the one that is applied to
| 1918 |
the geometry itself.
| 1919 |
This prevents double-transformation of vertices and allows one set
| 1920 |
of vertices to be used for multiple purposes, e.g. the front and
| 1921 |
back sides of a drawer.
| 1922 |
.SH
| 1923 |
EXAMPLE
| 1924 |
.DS
| 1925 |
# Make a capped cylinder
| 1926 |
v end1 =
| 1927 |
p 0 0 0
| 1928 |
n 0 0 -1
| 1929 |
v end2 =
| 1930 |
p 0 0 1
| 1931 |
cyl end1 1.2 end2
| 1932 |
# Forgot normal for end2
| 1933 |
v end2
| 1934 |
n 0 0 1
| 1935 |
ring end1 0 1.2
| 1936 |
ring end2 0 1.2
| 1937 |
.DE
| 1938 |
.SH
| 1939 |
SEE ALSO
| 1940 |
.LP
| 1941 |
.UL cone,
| 1942 |
.UL cyl,
| 1943 |
.UL f,
| 1944 |
.UL n,
| 1945 |
.UL p,
| 1946 |
.UL prism,
| 1947 |
.UL ring,
| 1948 |
.UL sph,
| 1949 |
.UL torus
| 1950 |
.ds RH P
| 1951 |
.bp
| 1952 |
.SH
| 1953 |
NAME
| 1954 |
.LP
| 1955 |
p - set the point location for the current vertex
| 1956 |
.SH
| 1957 |
SYNOPSIS
| 1958 |
.LP
| 1959 |
.B p
| 1960 |
.I "px py pz"
| 1961 |
.SH
| 1962 |
DESCRIPTION
| 1963 |
.LP
| 1964 |
Set the 3-dimensional position for the current vertex to
| 1965 |
.I (px,py,pz).
| 1966 |
The actual position of the vertex will be determined by the
| 1967 |
transformation in effect at the time the vertex is applied to a
| 1968 |
geometric surface entity.
| 1969 |
The transform current when the position is set is irrelevant.
| 1970 |
.LP
| 1971 |
The default vertex position is the origin, (0,0,0).
| 1972 |
.SH
| 1973 |
EXAMPLE
| 1974 |
.DS
| 1975 |
# Make a small circle of 6 spheres
| 1976 |
v scent =
| 1977 |
p 1 0 0
| 1978 |
xf -a 6 -rz 60
| 1979 |
sph scent .05
| 1980 |
xf
| 1981 |
.DE
| 1982 |
.SH
| 1983 |
SEE ALSO
| 1984 |
.LP
| 1985 |
.UL cone,
| 1986 |
.UL cyl,
| 1987 |
.UL f,
| 1988 |
.UL n,
| 1989 |
.UL prism,
| 1990 |
.UL ring,
| 1991 |
.UL sph,
| 1992 |
.UL torus,
| 1993 |
.UL v
| 1994 |
.ds RH N
| 1995 |
.bp
| 1996 |
.SH
| 1997 |
NAME
| 1998 |
.LP
| 1999 |
n - set the surface normal direction for the current vertex
| 2000 |
.SH
| 2001 |
SYNOPSIS
| 2002 |
.LP
| 2003 |
.B n
| 2004 |
.I "dx dy dz"
| 2005 |
.SH
| 2006 |
DESCRIPTION
| 2007 |
.LP
| 2008 |
Set the 3-dimensional surface normal for the current vertex to the
| 2009 |
normalized vector along
| 2010 |
.I (dx,dy,dz).
| 2011 |
If this vector is zero, then the surface normal is effectively
| 2012 |
unset.
| 2013 |
The actual surface normal orientation of the vertex will be determined
| 2014 |
by the transformation in effect at the time the vertex is applied to a
| 2015 |
| 2016 |
The current transform when the normal is set is irrelevant.
| 2017 |
.LP
| 2018 |
The default vertex normal is the zero vector (i.e. no normal).
| 2019 |
.SH
| 2020 |
EXAMPLE
| 2021 |
.DS
| 2022 |
# Make a chain of 10 interlocking doughnuts
| 2023 |
v tcent =
| 2024 |
p 0 0 0
| 2025 |
n 0 1 0
| 2026 |
xf -a 10 -rx 90 -t .2 0 0
| 2027 |
torus tcent .1 .2
| 2028 |
xf
| 2029 |
.DE
| 2030 |
.SH
| 2031 |
SEE ALSO
| 2032 |
.LP
| 2033 |
.UL f,
| 2034 |
.UL p,
| 2035 |
.UL prism,
| 2036 |
.UL ring,
| 2037 |
.UL torus,
| 2038 |
.UL v
| 2039 |
.ds LH Geometric Entities
| 2040 |
.ds RH F
| 2041 |
.bp
| 2042 |
.SH
| 2043 |
NAME
| 2044 |
.LP
| 2045 |
f - create an N-sided polygonal face
| 2046 |
.SH
| 2047 |
SYNOPSIS
| 2048 |
.LP
| 2049 |
.B f
| 2050 |
.I "v1 v2 ... vN"
| 2051 |
.SH
| 2052 |
DESCRIPTION
| 2053 |
.LP
| 2054 |
Create a polygonal face made of the current material
| 2055 |
by connecting the named vertices in order, and connecting the last
| 2056 |
vertex to the first.
| 2057 |
There must be at least three vertices, and if any vertex is undefined,
| 2058 |
| 2059 |
.LP
| 2060 |
The surface orientation is determined by the right-hand rule; when
| 2061 |
the curl of the fingers follows the given order of the vertices, the
| 2062 |
surface normal points in the thumb direction.
| 2063 |
Face vertices should be coplanar, though this is difficult to guarantee
| 2064 |
in a 3-dimensional specification.
| 2065 |
.LP
| 2066 |
If any vertices have associated surface normals, they will be used
| 2067 |
instead of the average plane normal, though it is safest to specify
| 2068 |
either all normals or no normals, and to stick with triangles
| 2069 |
when normals are used.
| 2070 |
Also, specified normals should point in the general direction of the
| 2071 |
surface for best results.
| 2072 |
.LP
| 2073 |
There is no explicit representation of holes in MGF. A hole must be
| 2074 |
represented implicitly by connecting vertices to form "seams." For
| 2075 |
example, a wall with a window in it might look as shown in Figure 1.
| 2076 |
In many systems, the wall itself would be represented with the first
| 2077 |
list of vertices, (v1,v2,v3,v4) and the hole associated with that
| 2078 |
wall as a second set of vertices (v5,v6,v7,v8). In MGF, we must
| 2079 |
give the whole thing as a single polygon, connecting the vertices so
| 2080 |
as to create a "seam," as shown in Figure 2.
| 2081 |
This could be written in MGF as "f v1 v2 v3 v4 v5 v6 v7 v8 v5 v4".
| 2082 |
.LP
| 2083 |
It is very important that the order of the hole be opposite to the
| 2084 |
order of the outer perimeter, otherwise the polygon will be
| 2085 |
"twisted" on top of itself. Note also that the seam was traversed
| 2086 |
in both directions, once going from v4 to v5, and again returning
| 2087 |
from v5 to v4. This is a necessary condition for a proper seam.
| 2088 |
.LP
| 2089 |
The choice of vertices to make into a seam is somewhat arbitrary, but
| 2090 |
some rendering systems may not give sane results if you cross over a
| 2091 |
hole with part of your seam. If we had chosen to create the seam
| 2092 |
between v2 and v5 in the above example instead of v4 and v5, the seam
| 2093 |
would cross our hole and may not render correctly\(dg.
| 2094 |
.FS
| 2095 |
\(dgFor systems that
| 2096 |
are sensitive to this, it is probably safest for their MGF
| 2097 |
loader/translator to re-expresses seams in terms of holes again, which can
| 2098 |
be done easily so long as vertices are shared in the fashion shown.
| 2099 |
.FE
| 2100 |
.bp
| 2101 |
Replace this page with the first page from "figures.ps".
| 2102 |
.bp
| 2103 |
.SH
| 2104 |
EXAMPLE
| 2105 |
.DS
| 2106 |
# Make a pyramid
| 2107 |
v apex =
| 2108 |
p 1 1 1
| 2109 |
v base0 =
| 2110 |
p 0 0 0
| 2111 |
v base1 =
| 2112 |
p 0 2 0
| 2113 |
v base2 =
| 2114 |
p 2 2 0
| 2115 |
v base3 =
| 2116 |
p 2 0 0
| 2117 |
# Bottom
| 2118 |
f base0 base1 base2 base3
| 2119 |
# Sides
| 2120 |
f base0 apex base1
| 2121 |
f base1 apex base2
| 2122 |
f base2 apex base3
| 2123 |
f base3 apex base0
| 2124 |
.DE
| 2125 |
.SH
| 2126 |
SEE ALSO
| 2127 |
.LP
| 2128 |
.UL cone,
| 2129 |
.UL cyl,
| 2130 |
.UL m,
| 2131 |
.UL prism,
| 2132 |
.UL ring,
| 2133 |
.UL sph,
| 2134 |
.UL torus,
| 2135 |
.UL v
| 2136 |
.ds RH SPH
| 2137 |
.bp
| 2138 |
.SH
| 2139 |
NAME
| 2140 |
.LP
| 2141 |
sph - create a sphere
| 2142 |
.SH
| 2143 |
SYNOPSIS
| 2144 |
.LP
| 2145 |
.B sph
| 2146 |
.I "vc rad"
| 2147 |
.SH
| 2148 |
DESCRIPTION
| 2149 |
.LP
| 2150 |
Create a sphere made of the current material with its center at the
| 2151 |
named vertex
| 2152 |
.I vc
| 2153 |
and a radius of
| 2154 |
.I rad.
| 2155 |
If the vertex is undefined an error will result.
| 2156 |
.LP
| 2157 |
The surface normal is usually directed outward, but will be directed
| 2158 |
inward if the given radius is negative.
| 2159 |
(This typically matters only for one-sided materials.)\0
| 2160 |
A zero radius is illegal.
| 2161 |
.SH
| 2162 |
EXAMPLE
| 2163 |
.DS
| 2164 |
# Create a thick glass sphere with a hollow inside
| 2165 |
m glass =
| 2166 |
sides 1
| 2167 |
ir 1.52 0
| 2168 |
c
| 2169 |
rs .06 0
| 2170 |
ts .88 0
| 2171 |
v cent =
| 2172 |
p 0 0 1.1
| 2173 |
# The outer shell
| 2174 |
sph cent .1
| 2175 |
# The inner bubble
| 2176 |
sph cent -.08
| 2177 |
.DE
| 2178 |
.SH
| 2179 |
SEE ALSO
| 2180 |
.LP
| 2181 |
.UL cone,
| 2182 |
.UL cyl,
| 2183 |
.UL f,
| 2184 |
.UL m,
| 2185 |
.UL prism,
| 2186 |
.UL ring,
| 2187 |
.UL torus,
| 2188 |
.UL v
| 2189 |
.ds RH CYL
| 2190 |
.bp
| 2191 |
.SH
| 2192 |
NAME
| 2193 |
.LP
| 2194 |
cyl - create an open-ended, truncated right cylinder
| 2195 |
.SH
| 2196 |
SYNOPSIS
| 2197 |
.LP
| 2198 |
.B cyl
| 2199 |
.I "v1 rad v2"
| 2200 |
.SH
| 2201 |
DESCRIPTION
| 2202 |
.LP
| 2203 |
Create a truncated right cylinder of radius
| 2204 |
.I rad
| 2205 |
using the current material, starting at the named vertex
| 2206 |
.I v1
| 2207 |
and continuing to
| 2208 |
.I v2.
| 2209 |
The ends will be open, but may be capped using the
| 2210 |
.UL ring
| 2211 |
entity if desired.
| 2212 |
.LP
| 2213 |
The surface normal will usually be directed outward, but may be
| 2214 |
directed inward by giving a negative value for
| 2215 |
.I rad.
| 2216 |
A zero radius is illegal, and
| 2217 |
.I v1
| 2218 |
cannot equal
| 2219 |
.I v2.
| 2220 |
.SH
| 2221 |
EXAMPLE
| 2222 |
.DS
| 2223 |
# A stylus with one rounded and one pointed end
| 2224 |
o stylus
| 2225 |
v vtip0 =
| 2226 |
p 0 0 0
| 2227 |
v vtip1 =
| 2228 |
p 0 0 .005
| 2229 |
v vend =
| 2230 |
p 0 0 .05
| 2231 |
cyl vtip1 .0015
| 2232 |
sph vend .0015
| 2233 |
cone vtip0 0 vtip1 .0015
| 2234 |
o
| 2235 |
.DE
| 2236 |
.SH
| 2237 |
SEE ALSO
| 2238 |
.LP
| 2239 |
.UL cone,
| 2240 |
.UL f,
| 2241 |
.UL m,
| 2242 |
.UL prism,
| 2243 |
.UL ring,
| 2244 |
.UL sph,
| 2245 |
.UL torus,
| 2246 |
.UL v
| 2247 |
.ds RH CONE
| 2248 |
.bp
| 2249 |
.SH
| 2250 |
NAME
| 2251 |
.LP
| 2252 |
cone - create an open-ended, truncated right cone
| 2253 |
.SH
| 2254 |
SYNOPSIS
| 2255 |
.LP
| 2256 |
.B cone
| 2257 |
.I "v1 rad1 v2 rad2"
| 2258 |
.SH
| 2259 |
DESCRIPTION
| 2260 |
.LP
| 2261 |
Create a truncated right cone using the current material.
| 2262 |
The starting radius is
| 2263 |
.I rad1
| 2264 |
at
| 2265 |
.I v1
| 2266 |
and the ending radius is
| 2267 |
is
| 2268 |
.I rad2
| 2269 |
at
| 2270 |
.I v2.
| 2271 |
| 2272 |
.UL ring
| 2273 |
entity if desired.
| 2274 |
.LP
| 2275 |
| 2276 |
directed inward by giving negative values for both radii.
| 2277 |
(It is illegal for the signs of the two radii to disagree.)\0
| 2278 |
One but not both radii may be zero, indicating that the cone comes
| 2279 |
to a point.
| 2280 |
.LP
| 2281 |
Although it is not strictly forbidden to have equal cone radii, the
| 2282 |
.UL cyl
| 2283 |
entity should be used in such cases.
| 2284 |
Likewise, the
| 2285 |
.UL ring
| 2286 |
entity must be used if
| 2287 |
.I v1
| 2288 |
and
| 2289 |
.I v2
| 2290 |
are equal.
| 2291 |
.SH
| 2292 |
EXAMPLE
| 2293 |
.DS
| 2294 |
# A parasol
| 2295 |
o parasol
| 2296 |
v v1 =
| 2297 |
p 0 0 0
| 2298 |
v v2 =
| 2299 |
p 0 0 .75
| 2300 |
v v3 =
| 2301 |
p 0 0 .7
| 2302 |
m handle_mat
| 2303 |
cyl v1 .002 v2
| 2304 |
m parasol_paper
| 2305 |
cyl v2 0 v3 .33
| 2306 |
o
| 2307 |
.DE
| 2308 |
.SH
| 2309 |
SEE ALSO
| 2310 |
.LP
| 2311 |
.UL cyl,
| 2312 |
.UL f,
| 2313 |
.UL m,
| 2314 |
.UL prism,
| 2315 |
.UL ring,
| 2316 |
.UL sph,
| 2317 |
.UL torus,
| 2318 |
.UL v
| 2319 |
.ds RH PRISM
| 2320 |
.bp
| 2321 |
.SH
| 2322 |
NAME
| 2323 |
.LP
| 2324 |
prism - create a closed right prism
| 2325 |
.SH
| 2326 |
SYNOPSIS
| 2327 |
.LP
| 2328 |
.B prism
| 2329 |
.I "v1 v2 ... vN length"
| 2330 |
.SH
| 2331 |
DESCRIPTION
| 2332 |
.LP
| 2333 |
Create a closed right prism using the current material.
| 2334 |
One end face will be enclosed by the named vertices, and the
| 2335 |
opposite end face will be a mirror image at a distance
| 2336 |
.I length
| 2337 |
from the original.
| 2338 |
The edges will be extruded into N quadrilaterals connecting
| 2339 |
the two end faces.
| 2340 |
.LP
| 2341 |
The order of vertices determines the original face orientation
| 2342 |
according to the right-hand rule as explained for the
| 2343 |
.UL f
| 2344 |
entity.
| 2345 |
Normally, the prism is extruded in the direction opposite to the
| 2346 |
original surface normal, resulting in faces that all point outward.
| 2347 |
If the specified
| 2348 |
.I length
| 2349 |
is negative, the prism will be extruded above the original face
| 2350 |
and all surface normals will point inward.
| 2351 |
.LP
| 2352 |
If the vertices have associated normals, they are applied to the
| 2353 |
side faces only, and should generally point in the appropriate
| 2354 |
direction (i.e. in or out depending on whether
| 2355 |
.I length
| 2356 |
is negative or positive).
| 2357 |
.SH
| 2358 |
EXAMPLE
| 2359 |
.DS
| 2360 |
# Make a unit cube starting at the origin and \\\\
| 2361 |
extending to the positive octant
| 2362 |
v cv0 =
| 2363 |
p 0 0 0
| 2364 |
v cv1 =
| 2365 |
p 0 1 0
| 2366 |
v cv2 =
| 2367 |
p 1 1 0
| 2368 |
v cv3 =
| 2369 |
p 1 0 0
| 2370 |
# Right hand rule has original face looking in -Z direction
| 2371 |
prism cv0 cv1 cv2 cv3 1
| 2372 |
.DE
| 2373 |
.SH
| 2374 |
SEE ALSO
| 2375 |
.LP
| 2376 |
.UL cyl,
| 2377 |
.UL cone,
| 2378 |
.UL f,
| 2379 |
.UL m,
| 2380 |
.UL ring,
| 2381 |
.UL sph,
| 2382 |
.UL torus,
| 2383 |
.UL v
| 2384 |
.ds RH RING
| 2385 |
.bp
| 2386 |
.SH
| 2387 |
NAME
| 2388 |
.LP
| 2389 |
ring - create a circular ring with inner and outer radii
| 2390 |
.SH
| 2391 |
SYNOPSIS
| 2392 |
.LP
| 2393 |
.B cyl
| 2394 |
.I "vc rmin rmax"
| 2395 |
.SH
| 2396 |
DESCRIPTION
| 2397 |
.LP
| 2398 |
Create a circular face of the current material centered on the named
| 2399 |
vertex
| 2400 |
.I vc
| 2401 |
with an inner radius of
| 2402 |
.I rmin
| 2403 |
and an outer radius of
| 2404 |
.I rmax.
| 2405 |
The surface orientation is determined by the normal vector
| 2406 |
associated with
| 2407 |
.I vc.
| 2408 |
If this vertex is undefined or has no normal, an error will result.
| 2409 |
The minimum radius may be equal to but not less than zero, and the
| 2410 |
maximum radius must be strictly greater than the minimum.
| 2411 |
.SH
| 2412 |
EXAMPLE
| 2413 |
.DS
| 2414 |
# The proverbial brass ring
| 2415 |
o brass_ring
| 2416 |
m brass
| 2417 |
v end1 =
| 2418 |
p 0 -.005 0
| 2419 |
n 0 -1 0
| 2420 |
v end2 =
| 2421 |
p 0 .005 0
| 2422 |
n 0 1 0
| 2423 |
ring end1 .02 .03
| 2424 |
cyl end1 .03 end2
| 2425 |
ring end2 .02 .03
| 2426 |
cyl end2 -.02 end1
| 2427 |
o
| 2428 |
.DE
| 2429 |
.SH
| 2430 |
SEE ALSO
| 2431 |
.LP
| 2432 |
.UL cyl,
| 2433 |
.UL cone,
| 2434 |
.UL f,
| 2435 |
.UL m,
| 2436 |
.UL prism,
| 2437 |
.UL sph,
| 2438 |
.UL torus,
| 2439 |
.UL v
| 2440 |
.ds RH TORUS
| 2441 |
.bp
| 2442 |
.SH
| 2443 |
NAME
| 2444 |
.LP
| 2445 |
torus - create a regular torus
| 2446 |
.SH
| 2447 |
SYNOPSIS
| 2448 |
.LP
| 2449 |
.B torus
| 2450 |
.I "vc rmin rmax"
| 2451 |
.SH
| 2452 |
DESCRIPTION
| 2453 |
.LP
| 2454 |
Create a torus of the current material centered on the named vertex
| 2455 |
.I vc
| 2456 |
| 2457 |
.I rmin
| 2458 |
| 2459 |
.I rmax.
| 2460 |
The plane of the torus will be perpendicular to the normal vector
| 2461 |
associated with
| 2462 |
.I vc.
| 2463 |
| 2464 |
.LP
| 2465 |
If a torus with an inward facing surface normal is desired,
| 2466 |
.I rmin
| 2467 |
and
| 2468 |
.I rmax
| 2469 |
may be negative.
| 2470 |
The minimum radius may be zero, but may not be negative when
| 2471 |
.I rmax
| 2472 |
is positive or vice versa.
| 2473 |
The magnitude or
| 2474 |
.I rmax
| 2475 |
must always be strictly greater than that of
| 2476 |
.I rmin.
| 2477 |
.SH
| 2478 |
EXAMPLE
| 2479 |
.DS
| 2480 |
# The proverbial brass ring -- easy grip version
| 2481 |
o brass_ring
| 2482 |
m brass
| 2483 |
v center =
| 2484 |
p 0 0 0
| 2485 |
n 0 1 0
| 2486 |
torus center .02 .03
| 2487 |
o
| 2488 |
.DE
| 2489 |
.SH
| 2490 |
SEE ALSO
| 2491 |
.LP
| 2492 |
.UL cyl,
| 2493 |
.UL cone,
| 2494 |
.UL f,
| 2495 |
.UL m,
| 2496 |
.UL prism,
| 2497 |
.UL ring,
| 2498 |
.UL sph,
| 2499 |
.UL v
| 2500 |
.ds RH
| 2501 |
.ds LH
| 2502 |
.bp
| 2503 |
.NH
| 2504 |
MGF Translators
| 2505 |
.LP
| 2506 |
Initially, there are four translators for MGF data, but only
| 2507 |
one of these is distributed with the MGF parser itself,
| 2508 |
.I mgfilt.
| 2509 |
Two of the other translators,
| 2510 |
.I mgf2rad
| 2511 |
and
| 2512 |
.I rad2mgf
| 2513 |
convert between MGF and the Radiance scene description language,
| 2514 |
and are distributed for free with the rest of the Radiance
| 2515 |
package\(dg.
| 2516 |
.FS
| 2517 |
\(dgRadiance is available by anonymous ftp from hobbes.lbl.gov and
| 2518 |
nestor.epfl.ch, or by WWW from
| 2519 |
"http://radsite.lbl.gov/radiance/HOME.html"
| 2520 |
.FE
| 2521 |
A third translator,
| 2522 |
.I mgf2meta,
| 2523 |
converts to a 2-dimensional line plot, and is also
| 2524 |
distributed with Radiance.
| 2525 |
.LP
| 2526 |
Mgfilt is a simple but useful utility that takes MGF on its input
| 2527 |
and produces MGF on its output.
| 2528 |
It uses the parser to convert entities that are not wanted or
| 2529 |
understood, and produces only the requested ones.
| 2530 |
This is useful for seeing what exactly a program must understand
| 2531 |
when it supports a given set of entities, and may serve as a
| 2532 |
substitute for linking to the parser library for programmers who
| 2533 |
wish to interpret the ASCII input directly but without all the
| 2534 |
unwanted entities.
| 2535 |
In future releases of MGF, this utility will also be handy for
| 2536 |
taking new entities and producing older versions of MGF for
| 2537 |
translators that have not yet been updated properly.
| 2538 |
.ds LH Translators
| 2539 |
.ds RH MGFILT
| 2540 |
.bp
| 2541 |
.SH
| 2542 |
NAME
| 2543 |
.LP
| 2544 |
mgfilt - get usable MGF entities from input
| 2545 |
.SH
| 2546 |
SYNOPSIS
| 2547 |
.LP
| 2548 |
.B mgfilt
| 2549 |
.B version
| 2550 |
| 2551 |
.B input ..
| 2552 |
| 2553 |
.br
| 2554 |
or
| 2555 |
.br
| 2556 |
.B mgfilt
| 2557 |
.B "e1,e2,.."
| 2558 |
| 2559 |
.B input ..
| 2560 |
| 2561 |
.SH
| 2562 |
DESCRIPTION
| 2563 |
.LP
| 2564 |
.I Mgfilt
| 2565 |
takes one or more MGF input files and converts all the entities to
| 2566 |
the types listed.
| 2567 |
In the first form, a single integer is given for the
| 2568 |
.I version
| 2569 |
of MGF that is to be produced.
| 2570 |
Since MGF is in its first major release, this is not yet a useful
| 2571 |
form, but it will be when the second major release comes out.
| 2572 |
.LP
| 2573 |
In the second form,
| 2574 |
.I mgfilt
| 2575 |
produces only the entities listed in the first argument, which must
| 2576 |
be comma-separated.
| 2577 |
The listed entity order is not important, but all entities given
| 2578 |
must be defined in the current version of MGF.
| 2579 |
Unknown entities will be summarily discarded on the input, and a
| 2580 |
warning message will be printed to the standard error.
| 2581 |
.SH
| 2582 |
EXAMPLES
| 2583 |
.LP
| 2584 |
To take an MGF version 3 file and send it to a version 2
| 2585 |
translator:
| 2586 |
.IP
| 2587 |
mgfilt 2 input.mgf | mgf2rad > input.rad
| 2588 |
.LP
| 2589 |
To take an MGF file and produce only flat polygonal faces
| 2590 |
with no materials:
| 2591 |
.IP
| 2592 |
mgfilt f,v,p,xf input.mgf > flatpoly.mgf
| 2593 |
.SH
| 2594 |
SEE ALSO
| 2595 |
.LP
| 2596 |
mgf2rad, rad2mgf
| 2597 |
.ds RH MGF2RAD
| 2598 |
.bp
| 2599 |
.SH
| 2600 |
NAME
| 2601 |
.LP
| 2602 |
mgf2rad - convert Materials and Geometry Format file to RADIANCE description
| 2603 |
.SH
| 2604 |
SYNOPSIS
| 2605 |
.LP
| 2606 |
.B mgf2rad
| 2607 |
| 2608 |
.B "\-m matfile"
| 2609 |
| 2610 |
.B "\-e mult"
| 2611 |
| 2612 |
.B "\-g dist"
| 2613 |
| 2614 |
| 2615 |
.B input ..
| 2616 |
| 2617 |
.SH
| 2618 |
DESCRIPTION
| 2619 |
.LP
| 2620 |
.I Mgf2rad
| 2621 |
converts one or more Materials and Geometry Format (MGF)
| 2622 |
files to a RADIANCE scene description.
| 2623 |
By definition, all output dimensions are in meters.
| 2624 |
The material names and properties
| 2625 |
for the surfaces will be those assigned in MGF.
| 2626 |
Any materials not defined in MGF will result in an error during
| 2627 |
translation.
| 2628 |
Light sources are described inline as IES luminaire files, and
| 2629 |
.I mgf2rad
| 2630 |
calls the program
| 2631 |
.I ies2rad(1)
| 2632 |
to translate these files.
| 2633 |
If an IES file in turn contains an MGF description of the local
| 2634 |
fixture geometry, this may result in a recursive call to
| 2635 |
.I mgf2rad,
| 2636 |
which is normal and should be transparent.
| 2637 |
The only side-effect of this additional translation is the
| 2638 |
appearance of other RADIANCE scene and data files produced
| 2639 |
automatically by
| 2640 |
.I ies2rad.
| 2641 |
.LP
| 2642 |
The
| 2643 |
.I \-m
| 2644 |
option may be used to put all the translated materials into a separate
| 2645 |
RADIANCE file.
| 2646 |
This is not always advisable, as any given material name may be
| 2647 |
reused at different points in the MGF description, and writing them
| 2648 |
to a separate file loses the contextual association between
| 2649 |
materials and surfaces.
| 2650 |
As long as unique material names are used throughout the MGF
| 2651 |
description and material properties are not redefined, there
| 2652 |
will be no problem.
| 2653 |
Note that this is the only way to get all the translated materials
| 2654 |
into a single file, since no output is produced for unreferenced
| 2655 |
materials; i.e. translating just the MGF materials does not work.
| 2656 |
.LP
| 2657 |
The
| 2658 |
.I \-e
| 2659 |
option may be used to multiply all the emission values by the
| 2660 |
given
| 2661 |
.I mult
| 2662 |
factor.
| 2663 |
The
| 2664 |
.I \-g
| 2665 |
option may be used to establish a glow distance (in meters)
| 2666 |
for all emitting surfaces.
| 2667 |
These two options are employed principally by
| 2668 |
.I ies2rad,
| 2669 |
and are not generally useful to most users.
| 2670 |
.SH
| 2671 |
EXAMPLES
| 2672 |
.LP
| 2673 |
To translate two MGF files into one RADIANCE materials file and
| 2674 |
one geometry file:
| 2675 |
.IP
| 2676 |
mgf2rad -m materials.rad building1.mgf building2.mgf > building1+2.rad
| 2677 |
.LP
| 2678 |
To create an octree directly from two MGF files and one RADIANCE
| 2679 |
file:
| 2680 |
.IP
| 2681 |
oconv '\\!mgf2rad materials.mgf scene.mgf' source.rad > scene.oct
| 2682 |
.SH
| 2683 |
FILES
| 2684 |
.LP
| 2685 |
tmesh.cal Used to smooth polygonal geometry
| 2686 |
.br
| 2687 |
*.rad RADIANCE source descriptions created by ies2rad
| 2688 |
.br
| 2689 |
*.dat RADIANCE source data created by ies2rad
| 2690 |
.br
| 2691 |
source.cal Used for IES source coordinates
| 2692 |
.SH
| 2693 |
AUTHOR
| 2694 |
.LP
| 2695 |
Greg Ward
| 2696 |
.SH
| 2697 |
SEE ALSO
| 2698 |
.LP
| 2699 |
ies2rad(1), mgf2meta(1), obj2rad(1), oconv(1), rad2mgf(1), xform(1)
| 2700 |
.ds RH
| 2701 |
RAD2MGF
| 2702 |
.bp
| 2703 |
.SH
| 2704 |
NAME
| 2705 |
.LP
| 2706 |
rad2mgf - convert RADIANCE scene description to Materials and Geometry Format
| 2707 |
.SH
| 2708 |
SYNOPSIS
| 2709 |
.LP
| 2710 |
.B rad2mgf
| 2711 |
| 2712 |
.B \-dU
| 2713 |
| 2714 |
| 2715 |
.B input ..
| 2716 |
| 2717 |
.SH
| 2718 |
DESCRIPTION
| 2719 |
.LP
| 2720 |
.I Rad2mgf
| 2721 |
converts one or more RADIANCE scene files
| 2722 |
to the Materials and Geometry Format (MGF).
| 2723 |
Input units are specified with the
| 2724 |
.I \-mU
| 2725 |
option, where
| 2726 |
.I U
| 2727 |
is one of 'm' (meters), 'c' (centimeters), 'f' (feet) or 'i'
| 2728 |
(inches).
| 2729 |
The assumed unit is meters, which is the required output unit for
| 2730 |
MGF (thus the need to know).
| 2731 |
If the input dimensions are in none of these units, then the user
| 2732 |
should apply
| 2733 |
.I xform(1)
| 2734 |
with the
| 2735 |
.I \-s
| 2736 |
option to bring the units into line prior to translation.
| 2737 |
.LP
| 2738 |
The MGF material names and properties
| 2739 |
for the surfaces will be those assigned in RADIANCE.
| 2740 |
If a referenced material has not been defined, then its name will
| 2741 |
be invoked in the MGF output without definition, and the description
| 2742 |
will be incomplete.
| 2743 |
.SH
| 2744 |
LIMITATIONS
| 2745 |
.LP
| 2746 |
Although MGF supports all of the geometric types and the most
| 2747 |
common material types used in RADIANCE, there is currently no
| 2748 |
support for advanced BRDF materials, patterns, textures or mixtures.
| 2749 |
Also, the special types "source" and "antimatter" are not supported,
| 2750 |
and all light source materials are converted to simple diffuse emitters
| 2751 |
(except "illum" materials, which are converted to their alternates).
| 2752 |
These primitives are reproduced as comments in the output and
| 2753 |
must be replaced manually if necessary.
| 2754 |
.LP
| 2755 |
The RADIANCE "instance" type is treated specially.
| 2756 |
.I Rad2mgf
| 2757 |
converts each instance to an MGF include statement, using the corresponding
| 2758 |
transformation and a file name derived from the octree name.
| 2759 |
(The original octree suffix is replaced by ".mgf".)\0
| 2760 |
For this to work, the user must separately create the referenced
| 2761 |
MGF files from the original RADIANCE descriptions.
| 2762 |
The description file names can usually be determined using the
| 2763 |
.I getinfo(1)
| 2764 |
command run on the octrees in question.
| 2765 |
.SH
| 2766 |
EXAMPLES
| 2767 |
.LP
| 2768 |
To convert three RADIANCE files (in feet) to one MGF file:
| 2769 |
.IP
| 2770 |
mgf2rad -df file1.rad file2.rad file3.rad > scene.mgf
| 2771 |
.LP
| 2772 |
To translate a RADIANCE materials file to MGF:
| 2773 |
.IP
| 2774 |
mgf2rad materials.rad > materials.mgf
| 2775 |
.SH
| 2776 |
AUTHOR
| 2777 |
.LP
| 2778 |
Greg Ward
| 2779 |
.SH
| 2780 |
SEE ALSO
| 2781 |
.LP
| 2782 |
getinfo(1), ies2rad(1), mgf2meta(1), mgf2rad(1), obj2rad(1), oconv(1), xform(1)
| 2783 |
.ds RH MGF2META
| 2784 |
.bp
| 2785 |
.SH
| 2786 |
NAME
| 2787 |
.LP
| 2788 |
mgf2meta - convert Materials and Geometry Format file to Metafile graphics
| 2789 |
.SH
| 2790 |
SYNOPSIS
| 2791 |
.LP
| 2792 |
.B mgf2meta
| 2793 |
| 2794 |
.B "-t threshold"
| 2795 |
| 2796 |
.B "{x|y|z} xmin xmax ymin ymax zmin zmax"
| 2797 |
| 2798 |
.B input ..
| 2799 |
| 2800 |
.SH
| 2801 |
DESCRIPTION
| 2802 |
.LP
| 2803 |
.I Mgf2meta
| 2804 |
| 2805 |
files to a 2-D orthographic projection along the selected axis in the
| 2806 |
.I metafile(1)
| 2807 |
graphics format.
| 2808 |
All geometry is clipped to the specified bounding box, and the
| 2809 |
resulting orientation is as follows:
| 2810 |
.sp .5
| 2811 |
.nf
| 2812 |
Projection Orientation
| 2813 |
| 2814 |
x Y-axis right, Z-axis up
| 2815 |
y Z-axis right, X-axis up
| 2816 |
z X-axis right, Z-axis up
| 2817 |
.fi
| 2818 |
.LP
| 2819 |
If multiple input files are given, the first file prints in black,
| 2820 |
the second prints in red, the third in green and the fourth in blue.
| 2821 |
If more than four input files are given, they cycle through the
| 2822 |
colors again in three other line types: dashed, dotted and
| 2823 |
dot-dashed.
| 2824 |
.LP
| 2825 |
The
| 2826 |
.I \-t
| 2827 |
option may be used to randomly throw out line segments that are
| 2828 |
shorter than the given
| 2829 |
.I threshold
| 2830 |
(given as a fraction of the plot width).
| 2831 |
Segments are included with a
| 2832 |
probability equal to the square of the line length over the square
| 2833 |
of the threshold.
| 2834 |
This can greatly reduce the number of lines in the drawing (and
| 2835 |
therefore improve the drawing speed) with only a modest loss in
| 2836 |
quality.
| 2837 |
A typical value for this parameter is 0.005.
| 2838 |
.LP
| 2839 |
All MGF material information is ignored on the input.
| 2840 |
.SH
| 2841 |
EXAMPLES
| 2842 |
.LP
| 2843 |
To project two MGF files along the Z-axis and display them under
| 2844 |
X11:
| 2845 |
.IP
| 2846 |
mgf2meta z 0 10 0 15 0 9 building1.mgf building2.mgf | x11meta
| 2847 |
.LP
| 2848 |
To convert a RADIANCE scene to a line drawing in RADIANCE picture
| 2849 |
format:
| 2850 |
.IP
| 2851 |
rad2mgf scene.rad | mgf2meta x `getbbox -h scene.rad` | meta2tga |
| 2852 |
ra_t8 -r > scene.pic
| 2853 |
.SH
| 2854 |
AUTHOR
| 2855 |
.LP
| 2856 |
Greg Ward
| 2857 |
.SH
| 2858 |
SEE ALSO
| 2859 |
.LP
| 2860 |
getbbox(1), meta2tga(1), metafile(5), mgf2rad(1), pflip(1),
| 2861 |
protate(1), psmeta(1), ra_t8(1), rad2mgf(1), t4014(1), x11meta(1)
| 2862 |
.ds RH
| 2863 |
.ds LH
| 2864 |
.bp
| 2865 |
.NH
| 2866 |
MGF Parser Library
| 2867 |
.LP
| 2868 |
The principal motivation for creating a standard parser library for
| 2869 |
MGF is to make it easy for software developers to offer some base
| 2870 |
level of compliance.
| 2871 |
The key to making MGF easy to support in fact is the parser, which
| 2872 |
has the ability to express higher order entities in terms of
| 2873 |
lower order ones.
| 2874 |
For example, tori are part of the MGF specification, but if a given
| 2875 |
program or translator does not support them, the parser will convert
| 2876 |
them to cones.
| 2877 |
If cones are not supported either, it will convert them further into
| 2878 |
smoothed polygons.
| 2879 |
If smoothing (vertex normal information) is not supported, it will
| 2880 |
be ignored and the program will just get flat polygons.
| 2881 |
This is done in such a way that future versions of the standard may
| 2882 |
include new entities that old software does not even have to know
| 2883 |
about, and they will be converted appropriately.
| 2884 |
Forward compatibility is thus built right into the parser loading
| 2885 |
mechanism itself -- the programmer simply links to the new code and
| 2886 |
the new standard is supported without any further changes.
| 2887 |
.SH
| 2888 |
Language
| 2889 |
.LP
| 2890 |
The provided MGF parser is written in ANSI-C.
| 2891 |
This language was chosen for reasons of portability and efficiency.
| 2892 |
Almost all systems support some form of ANSI-compatible C, and many
| 2893 |
languages can cross-link to C libraries without modification.
| 2894 |
Backward compatibility to Kernighan and Ritchie C is achieved by
| 2895 |
compiling with the -DNOPROTO flag.
| 2896 |
.LP
| 2897 |
All of the data structures and prototypes needed for the library
| 2898 |
are in the header file "parser.h".
| 2899 |
This file is the best resource for the parser and is updated with
| 2900 |
each MGF release.
| 2901 |
.SH
| 2902 |
Mechanism
| 2903 |
.LP
| 2904 |
The parser works by a simple callback mechanism to routines that
| 2905 |
actually interpret the individual entities.
| 2906 |
Some of these routines will belong to the calling program, and some
| 2907 |
will be entity support routines included in the library itself.
| 2908 |
There is a global array of function pointers, called
| 2909 |
.I mg_ehand.
| 2910 |
It is defined thus:
| 2911 |
.DS
| 2912 |
extern int (*mg_ehand[MG_NENTITIES])(int argc, char **argv);
| 2913 |
.DE
| 2914 |
Before parsing begins, this dispatch table is initialized to point to the
| 2915 |
routines that will handle each supported entity.
| 2916 |
Every entity handler has the same basic prototype, which is the
| 2917 |
same as the
| 2918 |
.I main
| 2919 |
function, i.e:
| 2920 |
.DS
| 2921 |
extern int \f2handler\f1(int argc, char **argv);
| 2922 |
.DE
| 2923 |
The first argument is the number of words in the MGF entity
| 2924 |
(counting the entity itself) and the second argument is an array of
| 2925 |
nul-terminated strings with the entity and its arguments.
| 2926 |
The function should return zero or one of the error
| 2927 |
codes defined in "parser.h".
| 2928 |
A non-zero return value causes the parser to abort, returning the
| 2929 |
error up through its call stack to the entry function, usually
| 2930 |
.I mg_load.
| 2931 |
.LP
| 2932 |
A special function pointer for undefined entities is
| 2933 |
defined as follows:
| 2934 |
.DS
| 2935 |
extern int (*mg_uhand)(int argc, char **argv);
| 2936 |
.DE
| 2937 |
By default, this points to the library function
| 2938 |
.I mg_defuhand,
| 2939 |
which prints an error message on the first unknown entity and keeps a
| 2940 |
count from then on, which is stored in the global unsigned integer
| 2941 |
.I mg_nunknown.
| 2942 |
If the
| 2943 |
.I mg_uhand
| 2944 |
pointer is assigned a value of NULL instead, parsing will abort at the
| 2945 |
first unrecognized entity.
| 2946 |
The reason this is not the default action is that ignoring unknown entities
| 2947 |
offers a certain base level of forward compatibility.
| 2948 |
Ignoring things one does not understand is not the best approach, but it
| 2949 |
is usually better than quitting with an error message if the input is
| 2950 |
in fact valid, but is a later version of the standard.
| 2951 |
The real solution is to update the interpreter by linking to a new version
| 2952 |
of the parser, or use a new version of the
| 2953 |
.I mgfilt
| 2954 |
command to convert the new MGF input to an older standard.
| 2955 |
.LP
| 2956 |
The
| 2957 |
.I mg_uhand
| 2958 |
pointer may also be used to customize the language for a particular
| 2959 |
application by adding entities, though this is discouraged because it
| 2960 |
tends to weaken the standard.
| 2961 |
.LP
| 2962 |
The skeletal framework for an MGF loader or translator is to assign
| 2963 |
function pointers to the
| 2964 |
.I mg_ehand
| 2965 |
array, call the parser initialization function
| 2966 |
.I mg_init,
| 2967 |
then call the file loader function
| 2968 |
.I mg_load
| 2969 |
once for each input file.
| 2970 |
This will in turn make calls back to the functions assigned to
| 2971 |
.I mg_ehand.
| 2972 |
To give a simple example, let us look at a
| 2973 |
translator that understands only flat polygonal faces, putting out
| 2974 |
vertex locations immediately after each "face" keyword:
| 2975 |
.DS
| 2976 |
#include <stdio.h>
| 2977 |
#include "parser.h"
| 2978 |
| 2979 |
int
| 2980 |
myfaceh(ac, av) /* face handling routine */
| 2981 |
int ac;
| 2982 |
char **av;
| 2983 |
| 2984 |
C_VERTEX *vp; /* vertex structure pointer */
| 2985 |
FVECT vert; /* vertex point location */
| 2986 |
int i;
| 2987 |
| 2988 |
if (ac < 4) /* check # arguments */
| 2989 |
return(MG_EARGC);
| 2990 |
printf("face\\\\n"); /* begin face output */
| 2991 |
for (i = 1; i < ac; i++) {
| 2992 |
if ((vp = c_getvert(av[i])) == NULL) /* vertex from name */
| 2993 |
return(MG_EUNDEF);
| 2994 |
xf_xfmpoint(vert, vp->p); /* apply transform */
| 2995 |
printf("%15.9f %15.9f %15.9f\\\\n",
| 2996 |
vert[0], vert[1], vert[2]); /* output vertex */
| 2997 |
| 2998 |
printf(";\\\\n"); /* end of face output */
| 2999 |
return(MG_OK); /* normal exit */
| 3000 |
| 3001 |
| 3002 |
main(argc, argv) /* translate MGF file(s) */
| 3003 |
int argc;
| 3004 |
char **argv;
| 3005 |
| 3006 |
int i;
| 3007 |
/* initialize dispatch table */
| 3008 |
mg_ehand[MG_E_FACE] = myfaceh; /* ours */
| 3009 |
mg_ehand[MG_E_VERTEX] = c_hvertex; /* parser lib */
| 3010 |
mg_ehand[MG_E_POINT] = c_hvertex; /* parser lib */
| 3011 |
mg_ehand[MG_E_XF] = xf_handler; /* parser lib */
| 3012 |
mg_init(); /* initialize parser */
| 3013 |
for (i = 1; i < argc; i++) /* load each file argument */
| 3014 |
if (mg_load(argv[i]) != MG_OK) /* and check for error */
| 3015 |
exit(1);
| 3016 |
exit(0); /* all done! */
| 3017 |
| 3018 |
.DE
| 3019 |
Hopefully, this example demonstrates just how easy it is to
| 3020 |
write an MGF translator.
| 3021 |
Of course, translators get more complicated the more entity
| 3022 |
types they support, but the point is that one does not
| 3023 |
.I have
| 3024 |
to support every entity -- the parser handles what the translator
| 3025 |
does not.
| 3026 |
Also, the library includes many general entity handlers,
| 3027 |
further reducing the burden on the programmer.
| 3028 |
This same principle means that it is not necessary to modify an
| 3029 |
existing program to accommodate a new version of MGF -- one need only
| 3030 |
link to the new parser library to comply with the new standard.
| 3031 |
.SH
| 3032 |
Division of Labor
| 3033 |
.LP
| 3034 |
As seen in the previous example, there are two parser routines that
| 3035 |
are normally called directly in an MGF translator or loader program.
| 3036 |
The first is
| 3037 |
.I mg_init,
| 3038 |
which takes no arguments but relies on the program having
| 3039 |
initialized those parts of the global
| 3040 |
.I mg_ehand
| 3041 |
array it cares about.
| 3042 |
The second routine is
| 3043 |
.I mg_load,
| 3044 |
which is called once on each input file.
| 3045 |
(A third routine,
| 3046 |
.I mg_clear,
| 3047 |
may be called to free the parser data structures after each file or
| 3048 |
after all files, if the program plans to continue rather than
| 3049 |
exit.)\0
| 3050 |
.LP
| 3051 |
The rest of the routines in a translator or loader program are
| 3052 |
called indirectly through the
| 3053 |
.I mg_ehand
| 3054 |
dispatch table, and they are the ones that do the real work of
| 3055 |
supporting the MGF entities.
| 3056 |
In addition to converting or discarding entities that the calling
| 3057 |
program does not know or care about, the parser library includes a
| 3058 |
set of context handlers that greatly simplify the translation
| 3059 |
process.
| 3060 |
There are three handlers for each of the three named contexts and
| 3061 |
their constituents, and two handlers for the two hierarchical
| 3062 |
context entities.
| 3063 |
To use these handlers, one simply sets the appropriate positions in the
| 3064 |
.I mg_ehand
| 3065 |
dispatch table to point to these functions.
| 3066 |
Additional functions and global data structures provide convenient
| 3067 |
access to the relevant contexts, and all of these are detailed in
| 3068 |
the following manual pages.
| 3069 |
.ds LH Basic Parser Routines
| 3070 |
.ds RH MG_INIT
| 3071 |
.bp
| 3072 |
.SH
| 3073 |
NAME
| 3074 |
.LP
| 3075 |
mg_init, mg_ehand, mg_uhand - initialize MGF entity handlers
| 3076 |
.SH
| 3077 |
SYNOPSIS
| 3078 |
.LP
| 3079 |
#include "parser.h"
| 3080 |
.LP
| 3081 |
.B void
| 3082 |
mg_init(
| 3083 |
.B void
| 3084 |
| 3085 |
.LP
| 3086 |
.B int
| 3087 |
mg_defuhand(
| 3088 |
.B int
| 3089 |
argc,
| 3090 |
.B char
| 3091 |
**argv )
| 3092 |
.LP
| 3093 |
.B "extern int"
| 3094 |
| 3095 |
.B int
| 3096 |
argc,
| 3097 |
.B char
| 3098 |
**argv )
| 3099 |
.LP
| 3100 |
.B "extern int"
| 3101 |
(*mg_uhand)(
| 3102 |
.B int
| 3103 |
argc,
| 3104 |
.B char
| 3105 |
**argv )
| 3106 |
.LP
| 3107 |
.B "extern unsigned"
| 3108 |
mg_nunknown
| 3109 |
.SH
| 3110 |
DESCRIPTION
| 3111 |
.LP
| 3112 |
The parser dispatch table,
| 3113 |
.I mg_ehand
| 3114 |
is initially set to all NULL pointers, and it
| 3115 |
is the duty of the calling program to assign entity handler functions to
| 3116 |
each of the supported entity positions in the array.
| 3117 |
The entities are given in the include file "parser.h" as the
| 3118 |
following:
| 3119 |
.DS
| 3120 |
#define MG_E_COMMENT 0 /* # */
| 3121 |
#define MG_E_COLOR 1 /* c */
| 3122 |
#define MG_E_CCT 2 /* cct */
| 3123 |
#define MG_E_CONE 3 /* cone */
| 3124 |
#define MG_E_CMIX 4 /* cmix */
| 3125 |
#define MG_E_CSPEC 5 /* cspec */
| 3126 |
#define MG_E_CXY 6 /* cxy */
| 3127 |
#define MG_E_CYL 7 /* cyl */
| 3128 |
#define MG_E_ED 8 /* ed */
| 3129 |
#define MG_E_FACE 9 /* f */
| 3130 |
#define MG_E_INCLUDE 10 /* i */
| 3131 |
#define MG_E_IES 11 /* ies */
| 3132 |
#define MG_E_IR 12 /* ir */
| 3133 |
#define MG_E_MATERIAL 13 /* m */
| 3134 |
#define MG_E_NORMAL 14 /* n */
| 3135 |
#define MG_E_OBJECT 15 /* o */
| 3136 |
#define MG_E_POINT 16 /* p */
| 3137 |
#define MG_E_PRISM 17 /* prism */
| 3138 |
#define MG_E_RD 18 /* rd */
| 3139 |
#define MG_E_RING 19 /* ring */
| 3140 |
#define MG_E_RS 20 /* rs */
| 3141 |
#define MG_E_SIDES 21 /* sides */
| 3142 |
#define MG_E_SPH 22 /* sph */
| 3143 |
#define MG_E_TD 23 /* td */
| 3144 |
#define MG_E_TORUS 24 /* torus */
| 3145 |
#define MG_E_TS 25 /* ts */
| 3146 |
#define MG_E_VERTEX 26 /* v */
| 3147 |
#define MG_E_XF 27 /* xf */
| 3148 |
| 3149 |
#define MG_NENTITIES 28 /* total # entities */
| 3150 |
.DE
| 3151 |
.LP
| 3152 |
Once the
| 3153 |
.I mg_ehand
| 3154 |
array has been set by the program, the
| 3155 |
.I mg_init
| 3156 |
routine must be called to complete the initialization process.
| 3157 |
This should be done once and only once per invocation, before any other
| 3158 |
parser routines are called.
| 3159 |
.LP
| 3160 |
The
| 3161 |
.I mg_uhand
| 3162 |
variable points to the current handler for unknown entities
| 3163 |
encountered on the input.
| 3164 |
Its default value points to the
| 3165 |
.I mg_defuhand
| 3166 |
function, which simply increments the global variable
| 3167 |
.I mg_nunknown,
| 3168 |
printing a warning message on the standard error on the first
| 3169 |
offense.
| 3170 |
(This message may be avoided by incrementing
| 3171 |
.I mg_nunknown
| 3172 |
before processing begins.)\0
| 3173 |
If
| 3174 |
.I mg_uhand
| 3175 |
is assigned a value of NULL, then an unknown entity will return an
| 3176 |
.I MG_EUNK
| 3177 |
error, which will cause the parser to abort.
| 3178 |
(See the
| 3179 |
.I mg_load
| 3180 |
page for a list of errors.)\0
| 3181 |
If the
| 3182 |
.I mg_uhand
| 3183 |
pointer is assigned to another function, that function will receive
| 3184 |
any unknown entities and their arguments, and the parsing will
| 3185 |
abort if the new function returns a non-zero error value.
| 3186 |
This offers a convenient way to customize the language by adding
| 3187 |
non-standard entities.
| 3188 |
.SH
| 3189 |
DIAGNOSTICS
| 3190 |
.LP
| 3191 |
If an inconsistent set of entities has been set for support, the
| 3192 |
.I mg_init
| 3193 |
routine will print an informative message to standard error and abort
| 3194 |
the calling program with a call to
| 3195 |
.I exit.
| 3196 |
This is normally unacceptable behavior for a library routine, but since
| 3197 |
such an error indicates a fault with the calling program itself,
| 3198 |
recovery is impossible.
| 3199 |
.SH
| 3200 |
SEE ALSO
| 3201 |
.LP
| 3202 |
mg_load, mg_handle
| 3203 |
.ds RH MG_LOAD
| 3204 |
.bp
| 3205 |
.SH
| 3206 |
NAME
| 3207 |
.LP
| 3208 |
mg_load, mg_clear, mg_file, mg_err - load MGF file, clear data structures
| 3209 |
.SH
| 3210 |
SYNOPSIS
| 3211 |
.LP
| 3212 |
#include "parser.h"
| 3213 |
.LP
| 3214 |
.B int
| 3215 |
mg_load(
| 3216 |
.B char
| 3217 |
*filename )
| 3218 |
.LP
| 3219 |
.B void
| 3220 |
mg_clear(
| 3221 |
.B void
| 3222 |
| 3223 |
.LP
| 3224 |
.B extern
| 3225 |
MG_FCTXT *mg_file
| 3226 |
.LP
| 3227 |
.B "extern char"
| 3228 |
*mg_err[MG_NERRS]
| 3229 |
.SH
| 3230 |
DESCRIPTION
| 3231 |
.LP
| 3232 |
The
| 3233 |
.I mg_load
| 3234 |
function loads the named file, or standard input if
| 3235 |
.I filename
| 3236 |
is the NULL pointer.
| 3237 |
Calls back to the appropriate MGF handler routines are made through the
| 3238 |
.I mg_ehand
| 3239 |
dispatch table.
| 3240 |
.LP
| 3241 |
The global
| 3242 |
.I mg_file
| 3243 |
variable points to the current file context structure, which
| 3244 |
may be useful for the interpretation of certain entities, such as
| 3245 |
.UL ies,
| 3246 |
which must know the directory path of the enclosing file.
| 3247 |
This structure is of the defined type
| 3248 |
.I MG_FCTXT,
| 3249 |
given in "parser.h" as:
| 3250 |
.DS
| 3251 |
typedef struct mg_fctxt {
| 3252 |
char fname[96]; /* file name */
| 3253 |
FILE *fp; /* stream pointer */
| 3254 |
int fid; /* unique file context id */
| 3255 |
char inpline[4096]; /* input line */
| 3256 |
int lineno; /* line number */
| 3257 |
struct mg_fctxt *prev; /* previous context */
| 3258 |
} MG_FCTXT;
| 3259 |
.DE
| 3260 |
.SH
| 3261 |
DIAGNOSTICS
| 3262 |
.LP
| 3263 |
If an error is encountered during parsing,
| 3264 |
.I mg_load
| 3265 |
will print an appropriate error message to the standard error stream
| 3266 |
and return one of the non-zero values from "parser.h" listed below:
| 3267 |
.DS
| 3268 |
#define MG_OK 0 /* normal return value */
| 3269 |
#define MG_EUNK 1 /* unknown entity */
| 3270 |
#define MG_EARGC 2 /* wrong number of arguments */
| 3271 |
#define MG_ETYPE 3 /* argument type error */
| 3272 |
#define MG_EILL 4 /* illegal argument value */
| 3273 |
#define MG_EUNDEF 5 /* undefined reference */
| 3274 |
#define MG_ENOFILE 6 /* cannot open input file */
| 3275 |
#define MG_EINCL 7 /* error in included file */
| 3276 |
#define MG_EMEM 8 /* out of memory */
| 3277 |
#define MG_ESEEK 9 /* file seek error */
| 3278 |
#define MG_EBADMAT 10 /* bad material specification */
| 3279 |
| 3280 |
#define MG_NERRS 11
| 3281 |
.DE
| 3282 |
If it is inappropriate to send output to standard error, the calling
| 3283 |
program should use the routines listed under
| 3284 |
.I mg_open
| 3285 |
for better control over the parsing process.
| 3286 |
.LP
| 3287 |
The
| 3288 |
.I mg_err
| 3289 |
array contains error messages corresponding to each of the values
| 3290 |
listed above in the native country's language.
| 3291 |
.SH
| 3292 |
SEE ALSO
| 3293 |
.LP
| 3294 |
mg_fgetpos, mg_handle, mg_init
| 3295 |
.ds RH MG_OPEN
| 3296 |
.bp
| 3297 |
.SH
| 3298 |
NAME
| 3299 |
.LP
| 3300 |
mg_open, mg_read, mg_parse, mg_close - MGF file loading subroutines
| 3301 |
.SH
| 3302 |
SYNOPSIS
| 3303 |
.LP
| 3304 |
#include "parser.h"
| 3305 |
.LP
| 3306 |
.B int
| 3307 |
mg_open( MG_FCTXT *fcp,
| 3308 |
.B char
| 3309 |
*filename )
| 3310 |
.LP
| 3311 |
.B int
| 3312 |
mg_read(
| 3313 |
.B void
| 3314 |
| 3315 |
.LP
| 3316 |
.B int
| 3317 |
mg_parse(
| 3318 |
.B void
| 3319 |
| 3320 |
.LP
| 3321 |
.B void
| 3322 |
mg_close(
| 3323 |
.B void
| 3324 |
| 3325 |
.SH
| 3326 |
DESCRIPTION
| 3327 |
.LP
| 3328 |
Most loaders and translators will call the
| 3329 |
.I mg_load
| 3330 |
routine to handle the above operations, but some programs or
| 3331 |
entity handlers require tighter control over the loading process.
| 3332 |
.LP
| 3333 |
The
| 3334 |
.I mg_open
| 3335 |
routine takes an uninitialized
| 3336 |
.I MG_FCTXT
| 3337 |
structure and a file name as its arguments.
| 3338 |
If
| 3339 |
.I filename
| 3340 |
is the NULL pointer, the standard input is "opened."
| 3341 |
The
| 3342 |
.I fcp
| 3343 |
structure will be set by
| 3344 |
.I mg_open
| 3345 |
prior to its return, and the global
| 3346 |
.I mg_file
| 3347 |
pointer will be assigned to point to it.
| 3348 |
This variable must not be destroyed until after the file is closed
| 3349 |
with a call to
| 3350 |
.I mg_close.
| 3351 |
(See the
| 3352 |
.I mg_load
| 3353 |
page for a definition of
| 3354 |
.I mg_file
| 3355 |
and the
| 3356 |
.I MG_FCTXT
| 3357 |
type.)\0
| 3358 |
.LP
| 3359 |
The
| 3360 |
.I mg_read
| 3361 |
function reads the next input line from the current file,
| 3362 |
returning the number of characters in the line, or zero if the
| 3363 |
end of file is reached or there is a file error.
| 3364 |
The function skips over escaped newlines, and keeps track of the
| 3365 |
line number in the current file context
| 3366 |
.I mg_file,
| 3367 |
which also contains the line that was read.
| 3368 |
.LP
| 3369 |
The
| 3370 |
.I mg_parse
| 3371 |
function breaks the current line in the
| 3372 |
.I mg_file
| 3373 |
structure into words and calls the appropriate handler routine, if
| 3374 |
any.
| 3375 |
Blank lines and unsupported entities cause a quick return.
| 3376 |
.LP
| 3377 |
The
| 3378 |
.I mg_close
| 3379 |
routine closes the current input file (unless it is the standard
| 3380 |
input) and returns to the previous file context (if any).
| 3381 |
.SH
| 3382 |
DIAGNOSTICS
| 3383 |
.LP
| 3384 |
The
| 3385 |
.I mg_open
| 3386 |
function returns
| 3387 |
.I MG_OK
| 3388 |
(0) normally, or
| 3389 |
.I MG_ENOFILE
| 3390 |
if the open fails for some reason.
| 3391 |
.LP
| 3392 |
The
| 3393 |
.I mg_parse
| 3394 |
function returns
| 3395 |
.I MG_OK
| 3396 |
if the current line was successfully interpreted, or one of the
| 3397 |
defined error values if there is a problem.
| 3398 |
(See the
| 3399 |
.I mg_load
| 3400 |
page for the defined error values.)\0
| 3401 |
.SH
| 3402 |
SEE ALSO
| 3403 |
.LP
| 3404 |
mg_fgetpos, mg_handle, mg_init, mg_load
| 3405 |
.ds RH MG_FGETPOS
| 3406 |
.bp
| 3407 |
.SH
| 3408 |
NAME
| 3409 |
.LP
| 3410 |
mg_fgetpos, mg_fgoto - get current file position and seek to pointer
| 3411 |
.SH
| 3412 |
SYNOPSIS
| 3413 |
.LP
| 3414 |
#include "parser.h"
| 3415 |
.LP
| 3416 |
.B void
| 3417 |
mg_fgetpos( MG_FPOS *pos )
| 3418 |
.LP
| 3419 |
.B int
| 3420 |
mg_fgoto( MG_FPOS *pos )
| 3421 |
.SH
| 3422 |
DESCRIPTION
| 3423 |
.LP
| 3424 |
The
| 3425 |
.I mg_fgetpos
| 3426 |
gets the current MGF file position and loads it into the passed
| 3427 |
.I MG_FPOS
| 3428 |
structure,
| 3429 |
.I pos.
| 3430 |
.LP
| 3431 |
The
| 3432 |
.I mg_fgoto
| 3433 |
function seeks to the position
| 3434 |
.I pos,
| 3435 |
taken from a previous call to
| 3436 |
.I mg_fgetpos.
| 3437 |
.SH
| 3438 |
DIAGNOSTICS
| 3439 |
.LP
| 3440 |
If
| 3441 |
.I mg_fgoto
| 3442 |
is passed an illegal pointer or one that does not correspond to the
| 3443 |
current
| 3444 |
.I mg_file
| 3445 |
context, it will return the
| 3446 |
.I MG_ESEEK
| 3447 |
error value.
| 3448 |
Normally, it returns
| 3449 |
.I MG_OK
| 3450 |
(0).
| 3451 |
.SH
| 3452 |
SEE ALSO
| 3453 |
.LP
| 3454 |
mg_load, mg_open
| 3455 |
.ds RH MG_HANDLE
| 3456 |
.bp
| 3457 |
.SH
| 3458 |
NAME
| 3459 |
.LP
| 3460 |
mg_handle, mg_entity, mg_ename, mg_nqcdivs - entity assistance and control
| 3461 |
.SH
| 3462 |
SYNOPSIS
| 3463 |
.LP
| 3464 |
.B int
| 3465 |
mg_handle(
| 3466 |
.B int
| 3467 |
en,
| 3468 |
.B int
| 3469 |
ac,
| 3470 |
.B char
| 3471 |
*av )
| 3472 |
.LP
| 3473 |
.B int
| 3474 |
mg_entity(
| 3475 |
.B char
| 3476 |
*name )
| 3477 |
.LP
| 3478 |
.B "extern char"
| 3479 |
mg_ename[MG_NENTITIES][MG_MAXELEN]
| 3480 |
.LP
| 3481 |
.B "extern int"
| 3482 |
mg_nqcdivs
| 3483 |
.SH
| 3484 |
DESCRIPTION
| 3485 |
.LP
| 3486 |
The
| 3487 |
.I mg_handle
| 3488 |
routine may be used to pass entities back to the parser
| 3489 |
to be redirected through the
| 3490 |
.I mg_ehand
| 3491 |
dispatch table.
| 3492 |
This method is recommended rather than calling through
| 3493 |
.I mg_ehand
| 3494 |
directly, since the parser sometimes has its own support routines
| 3495 |
that it needs to call for specific entities.
| 3496 |
The first argument,
| 3497 |
.I en,
| 3498 |
is the corresponding entity number, or -1 if
| 3499 |
.I mg_handle
| 3500 |
should figure it out from the first
| 3501 |
.I av
| 3502 |
argument.
| 3503 |
.LP
| 3504 |
The
| 3505 |
.I mg_entity
| 3506 |
function gets an entity number from its name, using a hash
| 3507 |
table on the
| 3508 |
.I mg_ename
| 3509 |
list.
| 3510 |
.LP
| 3511 |
The
| 3512 |
.I mg_ename
| 3513 |
table contains the string names corresponding to each MGF entity in
| 3514 |
the designated order.
| 3515 |
(See the
| 3516 |
.I mg_init
| 3517 |
page for the list of MGF entities.)\0
| 3518 |
.LP
| 3519 |
The global integer variable
| 3520 |
.I mg_nqcdivs
| 3521 |
tells the parser how many subdivisions to use per quarter circle (90
| 3522 |
degrees) when tesselating curved geometry.
| 3523 |
The default value is 5, and it may be reset at any time by the
| 3524 |
calling program.
| 3525 |
.SH
| 3526 |
DIAGNOSTICS
| 3527 |
.LP
| 3528 |
The
| 3529 |
.I mg_handle
| 3530 |
function returns
| 3531 |
.I MG_OK
| 3532 |
if the entity is handled correctly, or one of the predefined error
| 3533 |
| 3534 |
(See the
| 3535 |
.I mg_load
| 3536 |
page for a list of error values.)\0
| 3537 |
.LP
| 3538 |
The
| 3539 |
.I mg_entity
| 3540 |
function returns -1 if the passed name does not appear in the
| 3541 |
.I mg_ename
| 3542 |
list.
| 3543 |
.SH
| 3544 |
SEE ALSO
| 3545 |
.LP
| 3546 |
mg_init, mg_load, mg_open
| 3547 |
.ds RH ISINT, ISFLT, ISNAME
| 3548 |
.bp
| 3549 |
.SH
| 3550 |
NAME
| 3551 |
.LP
| 3552 |
isint, isflt, isname - determine if string fits integer or real format,
| 3553 |
or is legal identifier
| 3554 |
.SH
| 3555 |
SYNOPSIS
| 3556 |
.LP
| 3557 |
.B int
| 3558 |
isint(
| 3559 |
.B char
| 3560 |
*str )
| 3561 |
.LP
| 3562 |
.B int
| 3563 |
isflt(
| 3564 |
.B char
| 3565 |
*str )
| 3566 |
.LP
| 3567 |
.B int
| 3568 |
isname(
| 3569 |
.B char
| 3570 |
*str )
| 3571 |
.SH
| 3572 |
DESCRIPTION
| 3573 |
.LP
| 3574 |
The
| 3575 |
.I isint
| 3576 |
function checks to see if the passed string
| 3577 |
.I str
| 3578 |
matches a decimal integer format (positive or negative),
| 3579 |
and returns 1 or 0 based on whether it does or does not.
| 3580 |
.LP
| 3581 |
The
| 3582 |
.I isflt
| 3583 |
| 3584 |
.I str
| 3585 |
matches a floating point format (positive or negative with optional
| 3586 |
exponent), and returns 1 or 0 based on whether it does or does not.
| 3587 |
.LP
| 3588 |
The
| 3589 |
.I isname
| 3590 |
| 3591 |
.I str
| 3592 |
is a legal identifier name.
| 3593 |
In MGF, a legal identifier must begin with a letter and contain only
| 3594 |
visible ASCII characters (those between decimal 33 and 127 inclusive).
| 3595 |
The one caveat to this is that names may begin with one or more
| 3596 |
underscores ('_'), but this is a trick employed by the parser to
| 3597 |
maintain a separate name space from the user, and is not legal usage
| 3598 |
otherwise.
| 3599 |
.LP
| 3600 |
Note that a string that matches an integer format is also a valid
| 3601 |
floating point value.
| 3602 |
Conversely, a string that is not a floating point number cannot be a
| 3603 |
valid integer.
| 3604 |
.LP
| 3605 |
These routines are useful for checking arguments passed to entity
| 3606 |
handlers that certain types in certain positions.
| 3607 |
If an invalid argument is passed, the handler should return an
| 3608 |
.I MG_ETYPE
| 3609 |
error.
| 3610 |
.SH
| 3611 |
SEE ALSO
| 3612 |
.LP
| 3613 |
mg_init, mg_load
| 3614 |
.ds LH Entity Support Routines
| 3615 |
.ds RH C_HVERTEX
| 3616 |
.bp
| 3617 |
.SH
| 3618 |
NAME
| 3619 |
.LP
| 3620 |
c_hvertex, c_getvert, c_cvname, c_cvertex - vertex entity support
| 3621 |
.SH
| 3622 |
SYNOPSIS
| 3623 |
.LP
| 3624 |
#include "parser.h"
| 3625 |
.LP
| 3626 |
.B int
| 3627 |
c_hvertex(
| 3628 |
.B int
| 3629 |
argc,
| 3630 |
.B char
| 3631 |
**argv )
| 3632 |
.LP
| 3633 |
C_VERTEX *c_getvert(
| 3634 |
.B char
| 3635 |
*name )
| 3636 |
.LP
| 3637 |
.B "extern char"
| 3638 |
*c_vname
| 3639 |
.LP
| 3640 |
.B extern
| 3641 |
C_VERTEX *c_cvertex
| 3642 |
.SH
| 3643 |
DESCRIPTION
| 3644 |
.LP
| 3645 |
The
| 3646 |
.I c_hvertex
| 3647 |
function handles the MGF vertex entities,
| 3648 |
.UL v,
| 3649 |
.UL p
| 3650 |
and
| 3651 |
.UL n.
| 3652 |
If either
| 3653 |
.UL p
| 3654 |
or
| 3655 |
.UL n
| 3656 |
is supported, then
| 3657 |
.UL v
| 3658 |
must be also.
| 3659 |
The assignments are normally made to the
| 3660 |
.I mg_ehand
| 3661 |
array prior to parser initialization, like so:
| 3662 |
.DS
| 3663 |
mg_ehand[MG_E_VERTEX] = c_hvertex; /* support "v" entity */
| 3664 |
mg_ehand[MG_E_POINT] = c_hvertex; /* support "p" entity */
| 3665 |
mg_ehand[MG_E_NORMAL] = c_hvertex; /* support "n" entity */
| 3666 |
/* other entity handler assignments... */
| 3667 |
| 3668 |
.DE
| 3669 |
If vertex normals are not understood by any of the program-supported
| 3670 |
entities, then the
| 3671 |
.I MG_E_NORMAL
| 3672 |
entry may be left with its original NULL assignment.
| 3673 |
.LP
| 3674 |
The
| 3675 |
.I c_getvert
| 3676 |
call takes the name of a defined vertex and returns a pointer to its
| 3677 |
.I C_VERTEX
| 3678 |
structure, defined in "parser.h" as:
| 3679 |
.DS
| 3680 |
typedef FLOAT FVECT[3]; /* a 3-d real vector */
| 3681 |
| 3682 |
typedef struct {
| 3683 |
int clock; /* incremented each change -- resettable */
| 3684 |
FVECT p, n; /* point and normal */
| 3685 |
} C_VERTEX; /* vertex context */
| 3686 |
.DE
| 3687 |
The
| 3688 |
.I clock
| 3689 |
member will be incremented each time the value gets changed by a
| 3690 |
.UL p
| 3691 |
or
| 3692 |
.UL n
| 3693 |
entity, and may be reset by the controlling program if desired.
| 3694 |
This is a convenient way to keep track of whether or not a vertex has
| 3695 |
changed since its last use.
| 3696 |
To link identical vertices, one must also check that the current
| 3697 |
transform has not changed, which is uniquely identified by the
| 3698 |
global
| 3699 |
.I xf_context->xid
| 3700 |
variable, but only if one is using the parser libraries transform
| 3701 |
handler.
| 3702 |
(See the
| 3703 |
.I xf_handler
| 3704 |
page.)\0
| 3705 |
.LP
| 3706 |
It is possible but not recommended to alter the contents of the
| 3707 |
vertex structure returned by
| 3708 |
.I c_getvert.
| 3709 |
Normally it is read during the
| 3710 |
interpretation of entities using named vertices.
| 3711 |
.LP
| 3712 |
The name of the current vertex is given by the global
| 3713 |
.I c_cvname
| 3714 |
variable, which is set to NULL if the unnamed vertex is current.
| 3715 |
The current vertex value is pointed to by the global variable
| 3716 |
.I c_cvertex,
| 3717 |
which should never be NULL.
| 3718 |
.SH
| 3719 |
DIAGNOSTICS
| 3720 |
.LP
| 3721 |
The
| 3722 |
.I c_hvertex
| 3723 |
function returns
| 3724 |
.I MG_OK
| 3725 |
(0) if the vertex is handled correctly, or one of the predefined
| 3726 |
| 3727 |
(See the
| 3728 |
.I mg_load
| 3729 |
| 3730 |
.LP
| 3731 |
The
| 3732 |
.I c_getvert
| 3733 |
function returns NULL if the specified vertex name is undefined, at
| 3734 |
which point the calling function should return an
| 3735 |
.I MG_EUNDEF
| 3736 |
error.
| 3737 |
.SH
| 3738 |
SEE ALSO
| 3739 |
.LP
| 3740 |
c_hcolor, c_hmaterial, mg_init, mg_load, xf_handler
| 3741 |
.ds RH C_HCOLOR
| 3742 |
.bp
| 3743 |
.SH
| 3744 |
NAME
| 3745 |
.LP
| 3746 |
c_hcolor, c_getcolor, c_ccname, c_ccolor, c_ccvt, c_isgrey -
| 3747 |
color entity support
| 3748 |
.SH
| 3749 |
SYNOPSIS
| 3750 |
.LP
| 3751 |
#include "parser.h"
| 3752 |
.LP
| 3753 |
.B int
| 3754 |
c_hcolor(
| 3755 |
.B int
| 3756 |
argc,
| 3757 |
.B char
| 3758 |
**argv )
| 3759 |
.LP
| 3760 |
C_COLOR *c_getcolor(
| 3761 |
.B char
| 3762 |
*name )
| 3763 |
.LP
| 3764 |
.B "extern char"
| 3765 |
*c_ccname
| 3766 |
.LP
| 3767 |
.B extern
| 3768 |
C_COLOR *c_ccolor
| 3769 |
.LP
| 3770 |
.B void
| 3771 |
c_ccvt( C_COLOR *cvp,
| 3772 |
.B int
| 3773 |
cflags )
| 3774 |
.LP
| 3775 |
.B int
| 3776 |
c_isgrey( C_COLOR *cvp )
| 3777 |
.SH
| 3778 |
DESCRIPTION
| 3779 |
.LP
| 3780 |
The
| 3781 |
.I c_hcolor
| 3782 |
function supports the MGF entities,
| 3783 |
.UL c,
| 3784 |
.UL cxy,
| 3785 |
.UL cspec,
| 3786 |
.UL cct
| 3787 |
and
| 3788 |
.UL cmix.
| 3789 |
It is an error to support any of the color field entities without
| 3790 |
supporting the
| 3791 |
.UL c
| 3792 |
entity itself.
| 3793 |
| 3794 |
.I mg_ehand
| 3795 |
| 3796 |
.DS
| 3797 |
mg_ehand[MG_E_COLOR] = c_hcolor; /* support "c" entity */
| 3798 |
mg_ehand[MG_E_CXY] = c_hcolor; /* support "cxy" entity */
| 3799 |
mg_ehand[MG_E_CSPEC] = c_hcolor; /* support "cspec" entity */
| 3800 |
mg_ehand[MG_E_CCT] = c_hcolor; /* support "cct" entity */
| 3801 |
mg_ehand[MG_E_CMIX] = c_hcolor; /* support "cmix" entity */
| 3802 |
| 3803 |
| 3804 |
.DE
| 3805 |
If the loader/translator has no use for spectral data, the entries for
| 3806 |
.UL cspec
| 3807 |
and
| 3808 |
.UL cct
| 3809 |
may be left with their original NULL assignments and these entities will
| 3810 |
be re-expressed appropriately as tristimulus values.
| 3811 |
.LP
| 3812 |
The
| 3813 |
.I c_getcolor
| 3814 |
function takes the name of a defined color and returns a pointer to its
| 3815 |
.I C_COLOR
| 3816 |
| 3817 |
.DS
| 3818 |
#define C_CMINWL 380 /* minimum wavelength */
| 3819 |
#define C_CMAXWL 780 /* maximum wavelength */
| 3820 |
#define C_CNSS 41 /* number of spectral samples */
| 3821 |
#define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
| 3822 |
#define C_CMAXV 10000 /* nominal maximum sample value */
| 3823 |
#define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
| 3824 |
| 3825 |
typedef struct {
| 3826 |
int clock; /* incremented each change */
| 3827 |
short flags; /* what's been set */
| 3828 |
short ssamp[C_CNSS]; /* spectral samples, min wl to max */
| 3829 |
long ssum; /* straight sum of spectral values */
| 3830 |
float cx, cy; /* xy chromaticity value */
| 3831 |
float eff; /* efficacy (lumens/watt) */
| 3832 |
} C_COLOR; /* color context */
| 3833 |
.DE
| 3834 |
The
| 3835 |
.I clock
| 3836 |
| 3837 |
color field entity, and may be reset by the calling program if
| 3838 |
desired.
| 3839 |
This is a convenient way to keep track of whether or not a color has
| 3840 |
| 3841 |
The
| 3842 |
.I flags
| 3843 |
member indicates which color representations have been assigned,
| 3844 |
and is an inclusive OR of one or more of the following:
| 3845 |
.DS
| 3846 |
#define C_CSSPEC 01 /* flag if spectrum is set */
| 3847 |
#define C_CDSPEC 02 /* flag if defined w/ spectrum */
| 3848 |
#define C_CSXY 04 /* flag if xy is set */
| 3849 |
#define C_CDXY 010 /* flag if defined w/ xy */
| 3850 |
#define C_CSEFF 020 /* flag if efficacy set */
| 3851 |
.DE
| 3852 |
.LP
| 3853 |
| 3854 |
color structure returned by
| 3855 |
.I c_getcolor.
| 3856 |
Normally, this routine is never called directly, since there are no
| 3857 |
entities that access colors by name other than
| 3858 |
.UL c.
| 3859 |
.LP
| 3860 |
The global variable
| 3861 |
.I c_ccname
| 3862 |
points to the name of the current color, or NULL if it is unnamed.
| 3863 |
The variable
| 3864 |
.I c_ccolor
| 3865 |
points to the current color value, which should never be NULL.
| 3866 |
.LP
| 3867 |
The
| 3868 |
.I c_ccvt
| 3869 |
routine takes a
| 3870 |
.I C_COLOR
| 3871 |
structure and a set of desired flag settings and computes the
| 3872 |
missing color representation(s).
| 3873 |
.LP
| 3874 |
The
| 3875 |
.I c_isgrey
| 3876 |
function returns 1 if the passed color is very close to neutral
| 3877 |
grey, or 0 otherwise.
| 3878 |
.SH
| 3879 |
DIAGNOSTICS
| 3880 |
.LP
| 3881 |
The
| 3882 |
.I c_hcolor
| 3883 |
function returns
| 3884 |
.I MG_OK
| 3885 |
(0) if the color is handled correctly, or one of the predefined
| 3886 |
| 3887 |
(See the
| 3888 |
.I mg_load
| 3889 |
| 3890 |
.LP
| 3891 |
The
| 3892 |
.I c_getcolor
| 3893 |
function returns NULL if the specified color name is undefined, at
| 3894 |
| 3895 |
.I MG_EUNDEF
| 3896 |
error.
| 3897 |
.SH
| 3898 |
SEE ALSO
| 3899 |
.LP
| 3900 |
c_hmaterial, c_hvertex, mg_init, mg_load
| 3901 |
.ds RH C_HMATERIAL
| 3902 |
.bp
| 3903 |
.SH
| 3904 |
NAME
| 3905 |
.LP
| 3906 |
c_hmaterial, c_getmaterial, c_cmname, c_cmaterial -
| 3907 |
material entity support
| 3908 |
.SH
| 3909 |
SYNOPSIS
| 3910 |
.LP
| 3911 |
#include "parser.h"
| 3912 |
.LP
| 3913 |
.B int
| 3914 |
c_hmaterial(
| 3915 |
.B int
| 3916 |
argc,
| 3917 |
.B char
| 3918 |
**argv )
| 3919 |
.LP
| 3920 |
C_MATERIAL *c_getmaterial(
| 3921 |
.B char
| 3922 |
*name )
| 3923 |
.LP
| 3924 |
.B "extern char"
| 3925 |
*c_cmname
| 3926 |
.LP
| 3927 |
.B extern
| 3928 |
C_MATERIAL *c_cmaterial
| 3929 |
.SH
| 3930 |
DESCRIPTION
| 3931 |
.LP
| 3932 |
The
| 3933 |
.I c_hmaterial
| 3934 |
| 3935 |
.UL m,
| 3936 |
.UL ed,
| 3937 |
.UL ir,
| 3938 |
.UL rd,
| 3939 |
.UL rs,
| 3940 |
.UL sides,
| 3941 |
.UL td,
| 3942 |
and
| 3943 |
.UL ts.
| 3944 |
It is an error to support any of the material field entities without
| 3945 |
supporting the
| 3946 |
.UL m
| 3947 |
entity itself.
| 3948 |
| 3949 |
.I mg_ehand
| 3950 |
| 3951 |
.DS
| 3952 |
mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* support "m" entity */
| 3953 |
mg_ehand[MG_E_ED] = c_hmaterial; /* support "ed" entity */
| 3954 |
mg_ehand[MG_E_IR] = c_hmaterial; /* support "ir" entity */
| 3955 |
mg_ehand[MG_E_RD] = c_hmaterial; /* support "rd" entity */
| 3956 |
mg_ehand[MG_E_RS] = c_hmaterial; /* support "rs" entity */
| 3957 |
mg_ehand[MG_E_SIDES] = c_hmaterial; /* support "sides" entity */
| 3958 |
mg_ehand[MG_E_TD] = c_hmaterial; /* support "td" entity */
| 3959 |
mg_ehand[MG_E_TS] = c_hmaterial; /* support "ts" entity */
| 3960 |
| 3961 |
| 3962 |
.DE
| 3963 |
Any of the above entities besides
| 3964 |
.UL m
| 3965 |
may be unsupported, but the parser will not attempt to include their
| 3966 |
effect into other members, e.g. an unsupported
| 3967 |
.UL rs
| 3968 |
component will not be added back into the
| 3969 |
.UL rd
| 3970 |
member.
| 3971 |
It is therefore safer to support all of the relevant material
| 3972 |
entities and make final approximations from the complete
| 3973 |
.I C_MATERIAL
| 3974 |
structure.
| 3975 |
.LP
| 3976 |
The
| 3977 |
.I c_getmaterial
| 3978 |
function takes the name of a defined material and returns a pointer to its
| 3979 |
.I C_MATERIAL
| 3980 |
| 3981 |
.DS
| 3982 |
#define C_1SIDEDTHICK 0.005 /* assumed thickness of 1-sided mat. */
| 3983 |
| 3984 |
typedef struct {
| 3985 |
| 3986 |
int sided; /* 1 if surface is 1-sided, 0 for 2-sided */
| 3987 |
float nr, ni; /* index of refraction, real and imaginary */
| 3988 |
float rd; /* diffuse reflectance */
| 3989 |
C_COLOR rd_c; /* diffuse reflectance color */
| 3990 |
float td; /* diffuse transmittance */
| 3991 |
C_COLOR td_c; /* diffuse transmittance color */
| 3992 |
float ed; /* diffuse emittance */
| 3993 |
C_COLOR ed_c; /* diffuse emittance color */
| 3994 |
float rs; /* specular reflectance */
| 3995 |
C_COLOR rs_c; /* specular reflectance color */
| 3996 |
float rs_a; /* specular reflectance roughness */
| 3997 |
float ts; /* specular transmittance */
| 3998 |
C_COLOR ts_c; /* specular transmittance color */
| 3999 |
float ts_a; /* specular transmittance roughness */
| 4000 |
} C_MATERIAL; /* material context */
| 4001 |
.DE
| 4002 |
The
| 4003 |
.I clock
| 4004 |
| 4005 |
material field entity, and may be reset by the calling program if
| 4006 |
desired.
| 4007 |
This is a convenient way to keep track of whether or not a material has
| 4008 |
| 4009 |
.LP
| 4010 |
All reflectance and transmittance values correspond to normal
| 4011 |
incidence, and may vary as a function of angle depending on the
| 4012 |
index of refraction.
| 4013 |
A solid object is normally represented with a one-sided material.
| 4014 |
A two-sided material is most appropriate for thin surfaces, though
| 4015 |
it may be used also when the surface normal orientations in a model
| 4016 |
are unreliable.
| 4017 |
.LP
| 4018 |
If a transparent or translucent surface is one-sided, then the
| 4019 |
absorption will change as a function of distance through the
| 4020 |
material, and a single value for diffuse or specular transmittance is
| 4021 |
ambiguous.
| 4022 |
We therefore define a standard thickness,
| 4023 |
.I C_1SIDEDTHICK,
| 4024 |
which is the object thickness to which the given values correspond,
| 4025 |
so that one may compute the isotropic absorptance of the material.
| 4026 |
.LP
| 4027 |
| 4028 |
material structure returned by
| 4029 |
.I c_getmaterial.
| 4030 |
| 4031 |
entities that access materials by name other than
| 4032 |
.UL m.
| 4033 |
.LP
| 4034 |
The global variable
| 4035 |
.I c_cmname
| 4036 |
points to the name of the current material, or NULL if it is unnamed.
| 4037 |
The variable
| 4038 |
.I c_cmaterial
| 4039 |
points to the current material value, which should never be NULL.
| 4040 |
.SH
| 4041 |
DIAGNOSTICS
| 4042 |
.LP
| 4043 |
The
| 4044 |
.I c_hmaterial
| 4045 |
function returns
| 4046 |
.I MG_OK
| 4047 |
| 4048 |
| 4049 |
(See the
| 4050 |
.I mg_load
| 4051 |
| 4052 |
.LP
| 4053 |
The
| 4054 |
.I c_getmaterial
| 4055 |
function returns NULL if the specified material name is undefined, at
| 4056 |
| 4057 |
.I MG_EUNDEF
| 4058 |
error.
| 4059 |
.SH
| 4060 |
SEE ALSO
| 4061 |
.LP
| 4062 |
c_hcolor, c_hvertex, mg_init, mg_load
| 4063 |
.ds RH OBJ_HANDLER
| 4064 |
.bp
| 4065 |
.SH
| 4066 |
NAME
| 4067 |
.LP
| 4068 |
obj_handler, obj_clear, obj_nnames, obj_name - object name support
| 4069 |
.SH
| 4070 |
SYNOPSIS
| 4071 |
.LP
| 4072 |
.B int
| 4073 |
obj_handler(
| 4074 |
.B int
| 4075 |
argc,
| 4076 |
.B char
| 4077 |
**argv )
| 4078 |
.LP
| 4079 |
.B void
| 4080 |
obj_clear(
| 4081 |
.B void
| 4082 |
| 4083 |
.LP
| 4084 |
.B "extern int"
| 4085 |
obj_nnames
| 4086 |
.LP
| 4087 |
.B "extern char"
| 4088 |
**obj_name
| 4089 |
.SH
| 4090 |
DESCRIPTION
| 4091 |
.LP
| 4092 |
The
| 4093 |
.I obj_handler
| 4094 |
routine should be assigned to the
| 4095 |
.I MG_E_OBJECT
| 4096 |
entry of the parser's
| 4097 |
.I mg_ehand
| 4098 |
array prior to calling
| 4099 |
.I mg_load
| 4100 |
if the loader/translator wishes to support hierarchical object
| 4101 |
names.
| 4102 |
.LP
| 4103 |
The
| 4104 |
.I obj_clear
| 4105 |
function may be used to clear the object name stack and free any
| 4106 |
associated memory, but this is usually not necessary since
| 4107 |
.UL o
| 4108 |
begin and end entities are normally balanced in the input.
| 4109 |
.LP
| 4110 |
The global
| 4111 |
.I obj_nnames
| 4112 |
variable indicates the number of names currently in the object
| 4113 |
stack, and the
| 4114 |
.I obj_name
| 4115 |
list contains the name strings in the same order as they were
| 4116 |
| 4117 |
(I.e. the most recently pushed name is last.)\0
| 4118 |
.SH
| 4119 |
DIAGNOSTICS
| 4120 |
.LP
| 4121 |
The
| 4122 |
.I obj_handler
| 4123 |
function returns
| 4124 |
.I MG_OK
| 4125 |
| 4126 |
| 4127 |
(See the
| 4128 |
.I mg_load
| 4129 |
| 4130 |
.SH
| 4131 |
SEE ALSO
| 4132 |
.LP
| 4133 |
| 4134 |
.ds RH XF_HANDLER
| 4135 |
.bp
| 4136 |
.SH
| 4137 |
NAME
| 4138 |
.LP
| 4139 |
xf_handler, xf_clear, xf_context, xf_argend - transformation support
| 4140 |
.SH
| 4141 |
SYNOPSIS
| 4142 |
.LP
| 4143 |
.B int
| 4144 |
xf_handler(
| 4145 |
.B int
| 4146 |
argc,
| 4147 |
.B char
| 4148 |
**argv )
| 4149 |
.LP
| 4150 |
.B void
| 4151 |
xf_clear(
| 4152 |
.B void
| 4153 |
| 4154 |
.LP
| 4155 |
.B extern
| 4156 |
XF_SPEC *xf_context
| 4157 |
.LP
| 4158 |
.B "extern char"
| 4159 |
**xf_argend
| 4160 |
.SH
| 4161 |
DESCRIPTION
| 4162 |
.LP
| 4163 |
The
| 4164 |
.I xf_handler
| 4165 |
| 4166 |
.I MG_E_XF
| 4167 |
| 4168 |
.I mg_ehand
| 4169 |
| 4170 |
.I mg_load
| 4171 |
| 4172 |
transformations.
| 4173 |
(Note that all MGF geometric entities require this support.)\0
| 4174 |
.LP
| 4175 |
The
| 4176 |
.I xf_clear
| 4177 |
function may be used to clear the transform stack and free any
| 4178 |
| 4179 |
.UL xf
| 4180 |
| 4181 |
.LP
| 4182 |
The global
| 4183 |
.I xf_context
| 4184 |
variable points to the current transformation context, which is of
| 4185 |
the type
| 4186 |
.I XF_SPEC,
| 4187 |
described in "parser.h":
| 4188 |
.DS
| 4189 |
typedef struct xf_spec {
| 4190 |
long xid; /* unique transform id */
| 4191 |
short xac; /* context argument count */
| 4192 |
short rev; /* boolean true if vertices reversed */
| 4193 |
XF xf; /* cumulative transformation */
| 4194 |
struct xf_array *xarr; /* transformation array pointer */
| 4195 |
struct xf_spec *prev; /* previous transformation context */
| 4196 |
} XF_SPEC; /* followed by argument buffer */
| 4197 |
.DE
| 4198 |
The
| 4199 |
.I xid
| 4200 |
member is a identifier associated with this transformation,
| 4201 |
which should be the same for identical transformations, as an aid to
| 4202 |
vertex sharing.
| 4203 |
(See also the
| 4204 |
.I c_hvertex
| 4205 |
page.)\0
| 4206 |
The
| 4207 |
.I xac
| 4208 |
member indicates the total number of transform arguments, and is
| 4209 |
used to indicate the position of the first argument relative to the
| 4210 |
last one pointed to by the global
| 4211 |
.I xf_argend
| 4212 |
variable.
| 4213 |
.LP
| 4214 |
The first transform argument starts at
| 4215 |
.I xf_argv,
| 4216 |
which is a macro defined in "parser.h" as:
| 4217 |
.DS
| 4218 |
#define xf_argv (xf_argend - xf_context->xac)
| 4219 |
.DE
| 4220 |
Note that accessing this macro will result in a segmentation violation
| 4221 |
if the current context is NULL, so one should first test the second macro
| 4222 |
.I xf_argc
| 4223 |
against zero.
| 4224 |
This macro is defined as:
| 4225 |
.DS
| 4226 |
#define xf_argc (xf_context==NULL ? 0 : xf_context->xac)
| 4227 |
.DE
| 4228 |
.LP
| 4229 |
Normally, neither of these macros will be used, since there are
| 4230 |
routines for transforming points, vectors and scalars directly based
| 4231 |
on the current transformation context.
| 4232 |
(See the
| 4233 |
.I xf_xfmpoint
| 4234 |
page for details.)\0
| 4235 |
.LP
| 4236 |
The
| 4237 |
.I rev
| 4238 |
member of the
| 4239 |
.I XF_SPEC
| 4240 |
structure indicates whether or not this transform reverses the order
| 4241 |
of polygon vertices.
| 4242 |
This member will be 1 if the transformation mirrors about an odd
| 4243 |
number of coordinate axes, thus inverting faces.
| 4244 |
The usual thing to do in this circumstance is to interpret the
| 4245 |
vertex arguments in the reverse order, so as to bring the face back
| 4246 |
to its original orientation in the new position.
| 4247 |
.LP
| 4248 |
The
| 4249 |
.I xf
| 4250 |
member contains the transformation scalefactor (in xf.sca)
| 4251 |
and 4x4 homogeneous matrix (in xf.xfm), but these will usually not
| 4252 |
be accessed directly.
| 4253 |
Likewise, the
| 4254 |
.I xarr
| 4255 |
and
| 4256 |
.I prev
| 4257 |
members point to data that should not be needed by the calling
| 4258 |
program.
| 4259 |
.SH
| 4260 |
DIAGNOSTICS
| 4261 |
.LP
| 4262 |
The
| 4263 |
.I xf_handler
| 4264 |
function returns
| 4265 |
.I MG_OK
| 4266 |
| 4267 |
| 4268 |
(See the
| 4269 |
.I mg_load
| 4270 |
| 4271 |
.SH
| 4272 |
SEE ALSO
| 4273 |
.LP
| 4274 |
mg_init, mg_load, obj_handler, xf_xfmpoint
| 4275 |
.ds RH XF_XFMPOINT
| 4276 |
.bp
| 4277 |
.SH
| 4278 |
NAME
| 4279 |
.LP
| 4280 |
xf_xfmpoint xf_xfmvect, xf_rotvect, xf_scale - apply current
| 4281 |
transformation
| 4282 |
.SH
| 4283 |
SYNOPSIS
| 4284 |
.LP
| 4285 |
.B void
| 4286 |
xf_xfmpoint( FVECT pnew, FVECT pold )
| 4287 |
.LP
| 4288 |
.B void
| 4289 |
xf_xfmvect( FVECT vnew, FVECT vold )
| 4290 |
.LP
| 4291 |
.B void
| 4292 |
xf_rotvect( FVECT nnew, FVECT nold )
| 4293 |
.LP
| 4294 |
.B double
| 4295 |
xf_scale(
| 4296 |
.B double
| 4297 |
sold )
| 4298 |
.SH
| 4299 |
DESCRIPTION
| 4300 |
.LP
| 4301 |
The
| 4302 |
.I xf_xfmpoint
| 4303 |
routine applies the current transformation defined by
| 4304 |
.I xf_context
| 4305 |
to the point
| 4306 |
.I pold,
| 4307 |
scaling, rotating and moving it to its proper location, which is put in
| 4308 |
.I pnew.
| 4309 |
(As for
| 4310 |
.I xf_xfmvect
| 4311 |
and
| 4312 |
.I xf_rotvect,
| 4313 |
the two arguments may point to the same vector.)\0
| 4314 |
.LP
| 4315 |
The
| 4316 |
.I xf_xfmvect
| 4317 |
routine applies the current transformation to the vector
| 4318 |
.I vold,
| 4319 |
scaling and rotating it to its proper location, which is put in
| 4320 |
.I vnew.
| 4321 |
The only difference between
| 4322 |
.I xf_xfmpoint
| 4323 |
and
| 4324 |
.I xf_xfmvect
| 4325 |
is that in the latter, the final translation is not applied.
| 4326 |
.LP
| 4327 |
The
| 4328 |
.I xf_rotvect
| 4329 |
routine rotates the vector
| 4330 |
.I nold
| 4331 |
using the current transformation, and stores the result in
| 4332 |
.I nnew.
| 4333 |
No translation or scaling is applied, which is the appropriate
| 4334 |
action for surface normal vectors for example.
| 4335 |
.LP
| 4336 |
The
| 4337 |
.I xf_scale
| 4338 |
function takes a scalar argument
| 4339 |
.I sold
| 4340 |
and applies the current scale factor, returning the result.
| 4341 |
.SH
| 4342 |
SEE ALSO
| 4343 |
.LP
| 4344 |
xf_handler
| 4345 |
.ds LH
| 4346 |
.ds RH
| 4347 |
.bp
| 4348 |
.NH
| 4349 |
Application Notes
| 4350 |
.NH 2
| 4351 |
Relation to Standard Practices in Computer Graphics
| 4352 |
.LP
| 4353 |
For those coming from a computer graphics background, some of the
| 4354 |
choices in the material model may seem strange or even capricious.
| 4355 |
Why not simply stick with RGB colors and a Phong specular component
| 4356 |
like everyone else?
| 4357 |
What is the point in choosing the number of sides to a material?
| 4358 |
.LP
| 4359 |
In the real world, a surface can have only one side,
| 4360 |
defining the interface between one volume and another.
| 4361 |
Many object-space rendering packages (e.g. z-buffer algorithms) take
| 4362 |
advantage of this fact by culling back-facing polygons and thus saving
| 4363 |
as much as 50% of the preprocessing time.
| 4364 |
However, many models rely on an
| 4365 |
approximation whereby a single surface is used to represent a very thin
| 4366 |
volume, such as a pane of glass, and this also can provide significant
| 4367 |
calculational savings in an image-space algorithm (such as
| 4368 |
ray-tracing).
| 4369 |
Also, many models are created in such a way that the front vs. back
| 4370 |
information is lost or confused, so that the back side of one or
| 4371 |
more surfaces may have to serve as the front side during rendering.
| 4372 |
(AutoCAD is one easily identified culprit in this department.)\0
| 4373 |
Since both types of surface models are useful and any
| 4374 |
rendering algorithm may ultimately be applied, MGF provides a way
| 4375 |
to specify sidedness rather than picking one interpretation or the other.
| 4376 |
.LP
| 4377 |
The problem with RGB is that there is no accepted standard, and even
| 4378 |
if we were to set one it would either be impossible to realize (i.e.
| 4379 |
impossible to create phosphors with the chosen colors) or it would
| 4380 |
have a gamut that excludes many saturated colors.
| 4381 |
The CIE color system was very carefully conceived and developed,
| 4382 |
and is the standard to which all photometric measurements adhere.
| 4383 |
It is therefore the logical choice in any standard format, though it
| 4384 |
has been too often ignored by the computer graphics community.
| 4385 |
.LP
| 4386 |
Regarding Phong shading, this was never a physical model and making it
| 4387 |
behave basic laws of reciprocity and energy balance is difficult.
| 4388 |
More to the point, specular power has almost nothing to do with
| 4389 |
surface microstructure, and is difficult to set properly
| 4390 |
even if every physical characteristic of a material has
| 4391 |
been carefully measured.
| 4392 |
This is the ultimate indictment of any physical model -- that it
| 4393 |
is incapable of reproducing any measurement whatsoever.
| 4394 |
.LP
| 4395 |
Admittedly, the compliment of diffuse and specular component plus
| 4396 |
surface roughness and index of refraction used in MGF is less than a
| 4397 |
perfect model, but it is serviceable for most materials and
| 4398 |
relatively simple to incorporate into a rendering algorithm.
| 4399 |
In the long term, MGF shall probably include full spectral
| 4400 |
scattering functions, though the sheer quantity of data involved
| 4401 |
makes this burdensome from both the measurement side and the
| 4402 |
simulation side.
| 4403 |
.NH 3
| 4404 |
Converting between Phong Specular Power and Gaussian Roughness
| 4405 |
.LP
| 4406 |
So-called specular reflection and transmission are modeled using a
| 4407 |
Gaussian distribution of surface facets.
| 4408 |
The roughness parameters to the
| 4409 |
.UL rs
| 4410 |
and
| 4411 |
.UL ts
| 4412 |
entities specify
| 4413 |
the root-mean-squared (RMS) surface facet slope, which varies from 0
| 4414 |
for a perfectly smooth surface to around .2 for a fairly rough one.
| 4415 |
The effect this will have on the reflected component distribution is
| 4416 |
well-defined, but predicting the behavior of the transmitted
| 4417 |
component requires further assumptions.
| 4418 |
We assume that the surface
| 4419 |
scatters light passing through it just as much as it scatters
| 4420 |
reflected light.
| 4421 |
This assumption is approximately correct for a
| 4422 |
two-sided transparent material with an index of refraction of 1.5
| 4423 |
(like glass) and both sides having the given RMS facet slope.
| 4424 |
.LP
| 4425 |
Oftentimes, one is translating from a Phong exponent on the cosine
| 4426 |
of the half-vector-to-normal angle to the more physical but less
| 4427 |
familiar Gaussian model of MGF.
| 4428 |
The hardest part is translating the specular power to a roughness value.
| 4429 |
For this, we recommend the following approximation:
| 4430 |
.IP
| 4431 |
roughness = 0.6/sqrt(specular_power)
| 4432 |
.LP
| 4433 |
It is not a perfect correlation, but it is about as close as one can get.
| 4434 |
.NH 3
| 4435 |
Converting between RGB and CIE Colors
| 4436 |
.LP
| 4437 |
Unlike most graphics languages, MGF does not use an RGB color model,
| 4438 |
simply because there is no recognized definition for this model.
| 4439 |
It is based on computer monitor phosphors, which vary from one
| 4440 |
CRT to the next.
| 4441 |
(There is an RGB standard defined in the TV
| 4442 |
industry, but this has a rather poor correlation to most computer
| 4443 |
monitors and it is impossible to express many real-world colors
| 4444 |
within its limited gamut.)\0
| 4445 |
.LP
| 4446 |
MGF uses two alternative, well-defined standards, spectral power
| 4447 |
distributions and the 1931 CIE 2 degree standard observer.
| 4448 |
With the CIE standard, any viewable
| 4449 |
color may be exactly represented as an (x,y) chromaticity value.
| 4450 |
Unfortunately, the interaction between
| 4451 |
colors (i.e. colored light sources and interreflections) cannot be
| 4452 |
specified exactly with any finite coordinate set, including CIE
| 4453 |
chromaticities.
| 4454 |
So, MGF offers the ability to give reflectance,
| 4455 |
transmittance or emittance as a function of wavelength over the visible
| 4456 |
spectrum.
| 4457 |
This function is still discretized, but at a user-selectable
| 4458 |
resolution.
| 4459 |
Furthermore, spectral colors may be mixed, providing (nearly)
| 4460 |
arbitrary basis functions, which can produce more accurate results in
| 4461 |
some cases and are merely a convenience for translation in others.
| 4462 |
.LP
| 4463 |
Conversion back and forth between CIE chromaticity coordinates and spectral
| 4464 |
samples is provided within the MGF parser.
| 4465 |
Unfortunately, conversion
| 4466 |
to and from RGB values depends on a particular RGB definition, and as we
| 4467 |
have said, there is no recognized standard.
| 4468 |
We therefore recommend that
| 4469 |
you decide yourself what chromaticity values to use for each RGB primary,
| 4470 |
and adopt the following code to convert between CIE and RGB coordinates.
| 4471 |
.LP
| 4472 |
.nf
| 4473 |
#ifdef NTSC
| 4474 |
#define CIE_x_r 0.670 /* standard NTSC primaries */
| 4475 |
#define CIE_y_r 0.330
| 4476 |
#define CIE_x_g 0.210
| 4477 |
#define CIE_y_g 0.710
| 4478 |
#define CIE_x_b 0.140
| 4479 |
#define CIE_y_b 0.080
| 4480 |
#define CIE_x_w 0.3333 /* monitor white point */
| 4481 |
#define CIE_y_w 0.3333
| 4482 |
#else
| 4483 |
#define CIE_x_r 0.640 /* nominal CRT primaries */
| 4484 |
| 4485 |
#define CIE_x_g 0.290
| 4486 |
#define CIE_y_g 0.600
| 4487 |
#define CIE_x_b 0.150
| 4488 |
#define CIE_y_b 0.060
| 4489 |
| 4490 |
| 4491 |
#endif
| 4492 |
| 4493 |
#define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \\\\
| 4494 |
CIE_x_g*(CIE_y_b - CIE_y_r) + \\\\
| 4495 |
CIE_x_b*(CIE_y_r - CIE_y_g) )
| 4496 |
#define CIE_C_rD ( (1./CIE_y_w) * \\\\
| 4497 |
( CIE_x_w*(CIE_y_g - CIE_y_b) - \\\\
| 4498 |
CIE_y_w*(CIE_x_g - CIE_x_b) + \\\\
| 4499 |
CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) )
| 4500 |
#define CIE_C_gD ( (1./CIE_y_w) * \\\\
| 4501 |
( CIE_x_w*(CIE_y_b - CIE_y_r) - \\\\
| 4502 |
CIE_y_w*(CIE_x_b - CIE_x_r) - \\\\
| 4503 |
CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) )
| 4504 |
#define CIE_C_bD ( (1./CIE_y_w) * \\\\
| 4505 |
( CIE_x_w*(CIE_y_r - CIE_y_g) - \\\\
| 4506 |
CIE_y_w*(CIE_x_r - CIE_x_g) + \\\\
| 4507 |
CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) )
| 4508 |
| 4509 |
#define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
| 4510 |
#define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D)
| 4511 |
#define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D)
| 4512 |
| 4513 |
float xyz2rgbmat[3][3] = { /* XYZ to RGB */
| 4514 |
{(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
| 4515 |
(CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
| 4516 |
(CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD},
| 4517 |
{(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
| 4518 |
(CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
| 4519 |
(CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD},
| 4520 |
{(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
| 4521 |
(CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
| 4522 |
(CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD}
| 4523 |
| 4524 |
| 4525 |
float rgb2xyzmat[3][3] = { /* RGB to XYZ */
| 4526 |
{CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D},
| 4527 |
{CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D},
| 4528 |
{(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
| 4529 |
(1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
| 4530 |
(1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D}
| 4531 |
| 4532 |
| 4533 |
| 4534 |
cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB */
| 4535 |
register float *rgbcolor, *ciecolor;
| 4536 |
| 4537 |
register int i;
| 4538 |
| 4539 |
for (i = 0; i < 3; i++) {
| 4540 |
rgbcolor[i] = xyz2rgbmat[i][0]*ciecolor[0] +
| 4541 |
xyz2rgbmat[i][1]*ciecolor[1] +
| 4542 |
xyz2rgbmat[i][2]*ciecolor[2] ;
| 4543 |
if (rgbcolor[i] < 0.0) /* watch for negative values */
| 4544 |
rgbcolor[i] = 0.0;
| 4545 |
| 4546 |
| 4547 |
| 4548 |
| 4549 |
rgb_cie(ciecolor, rgbcolor) /* convert RGB to CIE */
| 4550 |
register float *ciecolor, *rgbcolor;
| 4551 |
| 4552 |
register int i;
| 4553 |
| 4554 |
| 4555 |
ciecolor[i] = rgb2xyzmat[i][0]*rgbcolor[0] +
| 4556 |
rgb2xyzmat[i][1]*rgbcolor[1] +
| 4557 |
rgb2xyzmat[i][2]*rgbcolor[2] ;
| 4558 |
| 4559 |
.fi
| 4560 |
.LP
| 4561 |
An alternative to adopting the above code is to use the MGF "cmix"
| 4562 |
entity to convert from RGB directly by naming the three primaries in
| 4563 |
terms of their chromaticities, e.g:
| 4564 |
.DS
| 4565 |
c R =
| 4566 |
cxy 0.640 0.330
| 4567 |
c G =
| 4568 |
cxy 0.290 0.600
| 4569 |
c B =
| 4570 |
cxy 0.150 0.060
| 4571 |
.DE
| 4572 |
.LP
| 4573 |
Then, converting from RGB to MGF colors is as simple as multiplying each
| 4574 |
component by its relative luminance in a cmix statement, for instance:
| 4575 |
.DS
| 4576 |
c white =
| 4577 |
cmix 0.265 R 0.670 G 0.065 B
| 4578 |
.DE
| 4579 |
.LP
| 4580 |
For the chosen RGB standard, the above specification would result a pure
| 4581 |
white.
| 4582 |
The reason the coefficients are not all 1 as you might expect is
| 4583 |
that cmix uses relative luminance as the standard for its weights.
| 4584 |
Since
| 4585 |
blue is less luminous for the same energy than red, which is in turn
| 4586 |
less luminous than green, the weights cannot be the same to achieve an
| 4587 |
even spectral balance.
| 4588 |
Unfortunately, computing these relative weights
| 4589 |
is not straightforward, though it is given in the above macros as CIE_rf,
| 4590 |
CIE_gf and CIE_bf.
| 4591 |
(The common factors in these macros may of course
| 4592 |
be removed since
| 4593 |
.UL cmix
| 4594 |
weights are all relative.)\0
| 4595 |
Alternatively, one could measure the actual full scale luminance of
| 4596 |
the phosphors with a luminance probe and get the same relative
| 4597 |
values.
| 4598 |
.NH 2
| 4599 |
Relation to IESNA LM-63 and Luminaire Catalogs
| 4600 |
.LP
| 4601 |
Recently, the Illuminating Engineering Society of North America
| 4602 |
(IESNA) adopted MGF as the official standard for
| 4603 |
representing luminaire geometry and materials.
| 4604 |
The way this works in an IES luminaire data file is through the
| 4605 |
addition of a keyword called LUMINOUSGEOMETRY, which is given on a
| 4606 |
line in the header portion of a file (before the TILT specification)
| 4607 |
like so:
| 4608 |
.LP
| 4609 |
.B [LUMINOUSGEOMETRY]
| 4610 |
.I mgf_file
| 4611 |
.LP
| 4612 |
The given MGF file must exist relative to the directory containing
| 4613 |
the IES file (i.e. the same stipulations and restrictions on pathnames
| 4614 |
apply as for the MGF
| 4615 |
.UL i
| 4616 |
entity).
| 4617 |
Furthermore, the position of the MGF geometry must be
| 4618 |
such that the gross geometric specification of emitting surfaces
| 4619 |
in the IES file completely
| 4620 |
blocks or encloses the luminous portions of the MGF description.
| 4621 |
Specifically, any ray traced towards the MGF geometry must strike
| 4622 |
the IES gross geometry before it strikes any luminous surface in the
| 4623 |
MGF description.
| 4624 |
This provides a convenient way of preventing overcounting in the
| 4625 |
illumination calculation, while still allowing for accurate fixture
| 4626 |
appearance.
| 4627 |
.LP
| 4628 |
To give two examples, let us consider first a recessed can, followed
| 4629 |
by a hanging direct/indirect fluorescent fixture.
| 4630 |
.LP
| 4631 |
The most appropriate IES geometric specification for the emitting
| 4632 |
area of a can light would be a circular disk.
| 4633 |
Since the IES gross geometry gives only the diameter of the disk, the
| 4634 |
actual 3-dimensional placement is implicitly defined as having a
| 4635 |
center at the origin, with the radiating disk facing in the
| 4636 |
negative Z direction (nadir, downwards).
| 4637 |
The MGF geometry would then be placed such that any luminous portion
| 4638 |
was above this disk, and no portion of it would obstruct the IES
| 4639 |
geometry.
| 4640 |
The most sensible position therefore has the IES disk flush with the
| 4641 |
MGF can opening, as shown in Figure 3.
| 4642 |
.bp
| 4643 |
Replace this page with the second page from "figures.ps".
| 4644 |
.bp
| 4645 |
.LP
| 4646 |
In the case of a direct/indirect fluorescent fixture, light will
| 4647 |
exit both the top and the bottom sides, and the IES geometry must
| 4648 |
enclose the radiating portion of the fixture entirely.
| 4649 |
It is acceptable to have additional MGF geometry above the
| 4650 |
fixture so long as it does not radiate, which is what we must do if
| 4651 |
we wish to include the support rods, as shown in Figure 4.
| 4652 |
.LP
| 4653 |
Note that the origin is always in the exact center of the IES
| 4654 |
geometry.
| 4655 |
.LP
| 4656 |
Not all fixtures will fit the simple IES geometry specification so
| 4657 |
nicely.
| 4658 |
For odd-shaped fixtures, it may be necessary to use an IES geometry
| 4659 |
that does not match the radiating area terribly well in order that
| 4660 |
it completely block or enclose the required MGF specification.
| 4661 |
.LP
| 4662 |
The unit of length in the MGF file is always meters, regardless of
| 4663 |
the units specified in the enclosing IES file.
| 4664 |
However, any and all multipliers applied to the candlepower data in the
| 4665 |
IES file will also be applied to the emittance of surfaces in the
| 4666 |
MGF specification, so that one MGF file may serve similar
| 4667 |
luminaires that differ in their total output.
| 4668 |
.NH
| 4669 |
Credits
| 4670 |
.LP
| 4671 |
The MGF language grew out of a joint investigation into physical
| 4672 |
representations for rendering undertaken by the author
| 4673 |
(Greg Ward of LBL) and Holly Rushmeier of the National
| 4674 |
Institute of Standards and Technology.
| 4675 |
After deciding that a complete and robust specification was
| 4676 |
an extreme challenge, we shelved the project for another time.
| 4677 |
A few months later, the author spoke with Ian Ashdown and Robert
| 4678 |
Shakespeare, who are both members of the IES Computing Committee,
| 4679 |
about the need for extending the existing data standard to
| 4680 |
include luminaire geometry and near-field photometry.
| 4681 |
We then moved forward as a team towards a somewhat less ambitious
| 4682 |
approach to physical materials and geometry that had the advantage
| 4683 |
of simplicity and the possibility of support with a standard parser
| 4684 |
library.
| 4685 |
The author went to work over the next two months
| 4686 |
on the detailed design of the language
| 4687 |
and an ANSI-C parser, with regular feedback from the other three
| 4688 |
team members.
| 4689 |
Several months and several versions later, we arrived at release
| 4690 |
1.0, which is the occasion of this document's creation.
| 4691 |
.LP
| 4692 |
Funding for this work... would be nice.
