--- ray/src/cv/mgflib/mgfdoc.tr 1996/02/21 14:26:43 1.13 +++ ray/src/cv/mgflib/mgfdoc.tr 1997/03/21 12:32:30 1.18 @@ -233,6 +233,7 @@ p x y z set point position for current vertex n dx dy dz set surface normal for current vertex _ _ _ f v1 v2 v3 ... polygon using current material, spec. vertices +fh v1 v2 v3 - ... face with explicit holes sph vc radius sphere cyl v1 radius v2 truncated right cylinder (open-ended) cone v1 rad1 v2 rad2 truncated right cone (open-ended) @@ -278,14 +279,14 @@ Context Cntl. Entity Default Value Field Entities Affe = = = = = Object o - - - Transform xf - - T{ -f, sph, cyl, cone, +f, fh, sph, cyl, cone, ring, torus, prism T} Material m 2-sided black T{ sides, rd, td, -ed, rs, ts +ed, rs, ts, ir T} T{ -f, sph, cyl, cone, +f, fh, sph, cyl, cone, ring, torus, prism T} Color c neutral grey T{ @@ -297,7 +298,7 @@ Vertex v T{ (0,0,0), no normal T} p, n T{ -f, sph, cyl, cone, +f, fh, sph, cyl, cone, ring, torus, prism T} .TE @@ -816,6 +817,7 @@ Geometry .TS lw(.75i) lw(1.75i) lw(3i). f v1 v2 v3 ... polygon using current material, spec. vertices +fh v1 v2 v3 - ... face with explicit holes sph vc radius sphere cyl v1 radius v2 truncated right cylinder (open-ended) cone v1 rad1 v2 rad2 truncated right cone (open-ended) @@ -1675,7 +1677,7 @@ EXAMPLE # A 100-watt incandescent bulb (1600 lumens) modeled as a sphere m c - cct 3000 + cct 3000 ed 87712 v cent = p 0 0 0 @@ -1901,6 +1903,8 @@ and require a normal direction. An .UL f +or +.UL fh entity will interpolate vertex normals if given, and use the polygon plane normal otherwise. See the @@ -1940,6 +1944,7 @@ SEE ALSO .UL cone, .UL cyl, .UL f, +.UL fh, .UL n, .UL p, .UL prism, @@ -1984,6 +1989,7 @@ SEE ALSO .UL cone, .UL cyl, .UL f, +.UL fh, .UL n, .UL prism, .UL ring, @@ -2030,6 +2036,7 @@ xf SEE ALSO .LP .UL f, +.UL fh, .UL p, .UL prism, .UL ring, @@ -2069,15 +2076,22 @@ when normals are used. Also, specified normals should point in the general direction of the surface for best results. .LP -There is no explicit representation of holes in MGF. A hole must be -represented implicitly by connecting vertices to form "seams." For +There is no explicit representation of holes in this entity, but see +the +.UL fh +entity for an alternative specification. +.LP +A hole may be represented implicitly in a face entity +by connecting vertices to form "seams." +For example, a wall with a window in it might look as shown in Figure 1. In many systems, the wall itself would be represented with the first list of vertices, (v1,v2,v3,v4) and the hole associated with that -wall as a second set of vertices (v5,v6,v7,v8). In MGF, we must +wall as a second set of vertices (v5,v6,v7,v8). +Using the face entity, we must give the whole thing as a single polygon, connecting the vertices so as to create a "seam," as shown in Figure 2. -This could be written in MGF as "f v1 v2 v3 v4 v5 v6 v7 v8 v5 v4". +This could be written as "f v1 v2 v3 v4 v5 v6 v7 v8 v5 v4". .LP It is very important that the order of the hole be opposite to the order of the outer perimeter, otherwise the polygon will be @@ -2126,12 +2140,68 @@ SEE ALSO .LP .UL cone, .UL cyl, +.UL fh, .UL m, .UL prism, .UL ring, .UL sph, .UL torus, .UL v +.ds RH FH +.bp +.SH +NAME +.LP +fh - create a polygonal face with explicit holes +.SH +SYNOPSIS +.LP +.B fh +.I "p1 p2 ... - h1.1 h1.2 ... - h2.1 h2.2 ..." +.SH +DESCRIPTION +.LP +Create a polygonal face with optional holes made of the current material. +The first contour is the outer perimeter, with vertices given in +counter-clockwise order as seen from the front side (the same as the +.UL f +entity). +A hole is indicated by a hyphen ('-') followed by the hole's +vertices, given in clockwise order as seen from the front side. +Multiple hole contours are separated by additional hyphens. +There must be at least three vertices for each contour, and the +last vertex is implicitly connected to the first. +If any vertex is undefined, an error will result. +.LP +If any vertices have associated surface normals, they will be used +instead of the average plane normal, though it is safest to specify +either all normals or no normals, and to stick with triangles +when normals are used. +Also, specified normals should point in the general direction of the +surface for best results. +.LP +Vertices should not be shared between any two contours. +I.e., a hole should not share a vertex or edge with the perimeter or +another hole, or incorrect rendering may result. +.SH +EXAMPLE +.DS +# Make a wall with a window using an explicit hole. +# (See Figures 1 and 2.) +fh v1 v2 v3 v4 - v5 v6 v7 v8 +.DE +.SH +SEE ALSO +.LP +.UL cone, +.UL cyl, +.UL f, +.UL m, +.UL prism, +.UL ring, +.UL sph, +.UL torus, +.UL v .ds RH SPH .bp .SH @@ -2180,6 +2250,7 @@ SEE ALSO .UL cone, .UL cyl, .UL f, +.UL fh, .UL m, .UL prism, .UL ring, @@ -2237,6 +2308,7 @@ SEE ALSO .LP .UL cone, .UL f, +.UL fh, .UL m, .UL prism, .UL ring, @@ -2309,6 +2381,7 @@ SEE ALSO .LP .UL cyl, .UL f, +.UL fh, .UL m, .UL prism, .UL ring, @@ -2375,6 +2448,7 @@ SEE ALSO .UL cyl, .UL cone, .UL f, +.UL fh, .UL m, .UL ring, .UL sph, @@ -2431,6 +2505,7 @@ SEE ALSO .UL cyl, .UL cone, .UL f, +.UL fh, .UL m, .UL prism, .UL sph, @@ -2491,6 +2566,7 @@ SEE ALSO .UL cyl, .UL cone, .UL f, +.UL fh, .UL m, .UL prism, .UL ring, @@ -3434,7 +3510,7 @@ and return one of the non-zero values from "parser.h" #define MG_EUNK 1 /* unknown entity */ #define MG_EARGC 2 /* wrong number of arguments */ #define MG_ETYPE 3 /* argument type error */ -#define MG_EILL 4 /* illegal argument value */ +#define MG_EILL 4 /* illegal argument value */ #define MG_EUNDEF 5 /* undefined reference */ #define MG_ENOFILE 6 /* cannot open input file */ #define MG_EINCL 7 /* error in included file */ @@ -3444,7 +3520,7 @@ and return one of the non-zero values from "parser.h" #define MG_ELINE 11 /* input line too long */ #define MG_ECNTXT 12 /* unmatched context close */ -#define MG_NERRS 13 +#define MG_NERRS 13 .DE If it is inappropriate to send output to standard error, the calling program should use the routines listed under @@ -3867,7 +3943,7 @@ To link identical vertices, one must also check that t transform has not changed, which is uniquely identified by the global .I xf_context->xid -variable, but only if one is using the parser libraries transform +variable, but only if one is using the parser library's transform handler. (See the .I xf_handler @@ -4598,7 +4674,7 @@ familiar Gaussian model of MGF. The hardest part is translating the specular power to a roughness value. For this, we recommend the following approximation: .IP -roughness = 0.6/sqrt(specular_power) +roughness = sqrt(2/specular_power) .LP It is not a perfect correlation, but it is about as close as one can get. .NH 3
