| 1 |
greg |
1.1 |
#ifndef lint
| 2 |
greg |
1.4 |
static const char RCSid[] = "$Id: mgf2rad.c,v 1.3 2003/06/26 00:58:09 schorsch Exp $";
| 3 |
greg |
1.1 |
#endif
| 4 |
| 5 |
* Convert MGF (Materials and Geometry Format) to Radiance
| 6 |
| 7 |
| 8 |
#include <stdio.h>
| 9 |
#include <stdlib.h>
| 10 |
#include <math.h>
| 11 |
#include <string.h>
| 12 |
#include "mgflib/parser.h"
| 13 |
#include "color.h"
| 14 |
#include "tmesh.h"
| 15 |
| 16 |
#define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2])
| 17 |
| 18 |
#define invert (xf_context != NULL && xf_context->rev)
| 19 |
| 20 |
double glowdist = FHUGE; /* glow test distance */
| 21 |
| 22 |
double emult = 1.; /* emitter multiplier */
| 23 |
| 24 |
FILE *matfp; /* material output file */
| 25 |
| 26 |
int r_comment(), r_cone(), r_cyl(), r_face(), r_ies(), r_ring(), r_sph();
| 27 |
char *material(), *object(), *addarg();
| 28 |
| 29 |
| 30 |
main(argc, argv) /* convert files to stdout */
| 31 |
int argc;
| 32 |
char *argv[];
| 33 |
| 34 |
int i;
| 35 |
| 36 |
matfp = stdout;
| 37 |
/* print out parser version */
| 38 |
printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR);
| 39 |
/* initialize dispatch table */
| 40 |
mg_ehand[MG_E_COMMENT] = r_comment; /* we pass comments */
| 41 |
mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */
| 42 |
mg_ehand[MG_E_CONE] = r_cone; /* we do cones */
| 43 |
mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */
| 44 |
mg_ehand[MG_E_CSPEC] = c_hcolor; /* they get spectra */
| 45 |
mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */
| 46 |
mg_ehand[MG_E_CCT] = c_hcolor; /* they get color temp's */
| 47 |
mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */
| 48 |
mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */
| 49 |
mg_ehand[MG_E_FACE] = r_face; /* we do faces */
| 50 |
mg_ehand[MG_E_IES] = r_ies; /* we do IES files */
| 51 |
mg_ehand[MG_E_IR] = c_hmaterial; /* they get refractive index */
| 52 |
mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* they get materials */
| 53 |
mg_ehand[MG_E_NORMAL] = c_hvertex; /* they get normals */
| 54 |
mg_ehand[MG_E_OBJECT] = obj_handler; /* they track object names */
| 55 |
mg_ehand[MG_E_POINT] = c_hvertex; /* they get points */
| 56 |
mg_ehand[MG_E_RD] = c_hmaterial; /* they get diffuse refl. */
| 57 |
mg_ehand[MG_E_RING] = r_ring; /* we do rings */
| 58 |
mg_ehand[MG_E_RS] = c_hmaterial; /* they get specular refl. */
| 59 |
mg_ehand[MG_E_SIDES] = c_hmaterial; /* they get # sides */
| 60 |
mg_ehand[MG_E_SPH] = r_sph; /* we do spheres */
| 61 |
mg_ehand[MG_E_TD] = c_hmaterial; /* they get diffuse trans. */
| 62 |
mg_ehand[MG_E_TS] = c_hmaterial; /* they get specular trans. */
| 63 |
mg_ehand[MG_E_VERTEX] = c_hvertex; /* they get vertices */
| 64 |
mg_ehand[MG_E_XF] = xf_handler; /* they track transforms */
| 65 |
mg_init(); /* initialize the parser */
| 66 |
/* get our options & print header */
| 67 |
printf("## %s", argv[0]);
| 68 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) {
| 69 |
printf(" %s", argv[i]);
| 70 |
switch (argv[i][1]) {
| 71 |
case 'g': /* glow distance (meters) */
| 72 |
if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f"))
| 73 |
goto userr;
| 74 |
glowdist = atof(argv[++i]);
| 75 |
| 76 |
break;
| 77 |
case 'e': /* emitter multiplier */
| 78 |
| 79 |
goto userr;
| 80 |
emult = atof(argv[++i]);
| 81 |
| 82 |
break;
| 83 |
case 'm': /* materials file */
| 84 |
matfp = fopen(argv[++i], "a");
| 85 |
if (matfp == NULL) {
| 86 |
fprintf(stderr, "%s: cannot append\n", argv[i]);
| 87 |
exit(1);
| 88 |
| 89 |
| 90 |
break;
| 91 |
default:
| 92 |
goto userr;
| 93 |
| 94 |
| 95 |
putchar('\n');
| 96 |
if (i == argc) { /* convert stdin */
| 97 |
if (mg_load(NULL) != MG_OK)
| 98 |
exit(1);
| 99 |
if (mg_nunknown)
| 100 |
printf("## %s: %u unknown entities\n",
| 101 |
argv[0], mg_nunknown);
| 102 |
} else /* convert each file */
| 103 |
for ( ; i < argc; i++) {
| 104 |
printf("## %s %s ##############################\n",
| 105 |
argv[0], argv[i]);
| 106 |
if (mg_load(argv[i]) != MG_OK)
| 107 |
exit(1);
| 108 |
if (mg_nunknown) {
| 109 |
printf("## %s %s: %u unknown entities\n",
| 110 |
argv[0], argv[i], mg_nunknown);
| 111 |
mg_nunknown = 0;
| 112 |
| 113 |
| 114 |
exit(0);
| 115 |
userr:
| 116 |
fprintf(stderr, "Usage: %s [-g dist][-e mult][-m matf] [file.mgf] ..\n",
| 117 |
argv[0]);
| 118 |
exit(1);
| 119 |
| 120 |
| 121 |
| 122 |
int
| 123 |
r_comment(ac, av) /* repeat a comment verbatim */
| 124 |
register int ac;
| 125 |
register char **av;
| 126 |
| 127 |
putchar('#'); /* use Radiance comment character */
| 128 |
while (--ac) { /* pass through verbatim */
| 129 |
putchar(' ');
| 130 |
fputs(*++av, stdout);
| 131 |
| 132 |
putchar('\n');
| 133 |
return(MG_OK);
| 134 |
| 135 |
| 136 |
| 137 |
int
| 138 |
r_cone(ac, av) /* put out a cone */
| 139 |
int ac;
| 140 |
char **av;
| 141 |
| 142 |
static int ncones;
| 143 |
char *mat;
| 144 |
double r1, r2;
| 145 |
C_VERTEX *cv1, *cv2;
| 146 |
FVECT p1, p2;
| 147 |
int inv;
| 148 |
/* check argument count and type */
| 149 |
if (ac != 5)
| 150 |
return(MG_EARGC);
| 151 |
if (!isflt(av[2]) || !isflt(av[4]))
| 152 |
return(MG_ETYPE);
| 153 |
/* get the endpoint vertices */
| 154 |
if ((cv1 = c_getvert(av[1])) == NULL ||
| 155 |
(cv2 = c_getvert(av[3])) == NULL)
| 156 |
return(MG_EUNDEF);
| 157 |
xf_xfmpoint(p1, cv1->p); /* transform endpoints */
| 158 |
xf_xfmpoint(p2, cv2->p);
| 159 |
r1 = xf_scale(atof(av[2])); /* scale radii */
| 160 |
r2 = xf_scale(atof(av[4]));
| 161 |
inv = r1 < 0.; /* check for inverted cone */
| 162 |
if (r1 == 0.) { /* check for illegal radii */
| 163 |
if (r2 == 0.)
| 164 |
return(MG_EILL);
| 165 |
inv = r2 < 0.;
| 166 |
} else if (r2 != 0. && inv ^ r2 < 0.)
| 167 |
return(MG_EILL);
| 168 |
if (inv) {
| 169 |
r1 = -r1;
| 170 |
r2 = -r2;
| 171 |
| 172 |
if ((mat = material()) == NULL) /* get material */
| 173 |
return(MG_EBADMAT);
| 174 |
/* spit the sucker out */
| 175 |
printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone",
| 176 |
object(), ++ncones);
| 177 |
printf("0\n0\n8\n");
| 178 |
putv(p1);
| 179 |
putv(p2);
| 180 |
printf("%18.12g %18.12g\n", r1, r2);
| 181 |
return(MG_OK);
| 182 |
| 183 |
| 184 |
| 185 |
int
| 186 |
r_cyl(ac, av) /* put out a cylinder */
| 187 |
int ac;
| 188 |
char **av;
| 189 |
| 190 |
static int ncyls;
| 191 |
char *mat;
| 192 |
double rad;
| 193 |
| 194 |
FVECT p1, p2;
| 195 |
int inv;
| 196 |
| 197 |
if (ac != 4)
| 198 |
return(MG_EARGC);
| 199 |
if (!isflt(av[2]))
| 200 |
return(MG_ETYPE);
| 201 |
| 202 |
| 203 |
| 204 |
return(MG_EUNDEF);
| 205 |
| 206 |
| 207 |
rad = xf_scale(atof(av[2])); /* scale radius */
| 208 |
if ((inv = rad < 0.)) /* check for inverted cylinder */
| 209 |
rad = -rad;
| 210 |
| 211 |
return(MG_EBADMAT);
| 212 |
/* spit out the primitive */
| 213 |
printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder",
| 214 |
object(), ++ncyls);
| 215 |
printf("0\n0\n7\n");
| 216 |
putv(p1);
| 217 |
putv(p2);
| 218 |
printf("%18.12g\n", rad);
| 219 |
return(MG_OK);
| 220 |
| 221 |
| 222 |
| 223 |
int
| 224 |
r_sph(ac, av) /* put out a sphere */
| 225 |
int ac;
| 226 |
char **av;
| 227 |
| 228 |
static int nsphs;
| 229 |
char *mat;
| 230 |
double rad;
| 231 |
C_VERTEX *cv;
| 232 |
FVECT cent;
| 233 |
int inv;
| 234 |
| 235 |
if (ac != 3)
| 236 |
return(MG_EARGC);
| 237 |
if (!isflt(av[2]))
| 238 |
return(MG_ETYPE);
| 239 |
if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */
| 240 |
return(MG_EUNDEF);
| 241 |
xf_xfmpoint(cent, cv->p); /* transform center */
| 242 |
| 243 |
if ((inv = rad < 0.)) /* check for inversion */
| 244 |
rad = -rad;
| 245 |
| 246 |
return(MG_EBADMAT);
| 247 |
/* spit out primitive */
| 248 |
printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere",
| 249 |
object(), ++nsphs);
| 250 |
printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
| 251 |
cent[0], cent[1], cent[2], rad);
| 252 |
return(MG_OK);
| 253 |
| 254 |
| 255 |
| 256 |
int
| 257 |
r_ring(ac, av) /* put out a ring */
| 258 |
int ac;
| 259 |
char **av;
| 260 |
| 261 |
static int nrings;
| 262 |
char *mat;
| 263 |
double r1, r2;
| 264 |
C_VERTEX *cv;
| 265 |
FVECT cent, norm;
| 266 |
| 267 |
if (ac != 4)
| 268 |
return(MG_EARGC);
| 269 |
if (!isflt(av[2]) || !isflt(av[3]))
| 270 |
return(MG_ETYPE);
| 271 |
| 272 |
return(MG_EUNDEF);
| 273 |
if (is0vect(cv->n)) /* make sure we have normal */
| 274 |
return(MG_EILL);
| 275 |
| 276 |
xf_rotvect(norm, cv->n); /* rotate normal */
| 277 |
| 278 |
r2 = xf_scale(atof(av[3]));
| 279 |
if (r1 < 0. | r2 <= r1)
| 280 |
return(MG_EILL);
| 281 |
| 282 |
return(MG_EBADMAT);
| 283 |
| 284 |
printf("\n%s ring %sr%d\n", mat, object(), ++nrings);
| 285 |
| 286 |
putv(cent);
| 287 |
putv(norm);
| 288 |
| 289 |
return(MG_OK);
| 290 |
| 291 |
| 292 |
| 293 |
int
| 294 |
r_face(ac, av) /* convert a face */
| 295 |
int ac;
| 296 |
char **av;
| 297 |
| 298 |
static int nfaces;
| 299 |
int myi = invert;
| 300 |
char *mat;
| 301 |
register int i;
| 302 |
register C_VERTEX *cv;
| 303 |
FVECT v;
| 304 |
int rv;
| 305 |
| 306 |
if (ac < 4)
| 307 |
return(MG_EARGC);
| 308 |
| 309 |
return(MG_EBADMAT);
| 310 |
if (ac <= 5) { /* check for smoothing */
| 311 |
C_VERTEX *cva[5];
| 312 |
for (i = 1; i < ac; i++) {
| 313 |
if ((cva[i-1] = c_getvert(av[i])) == NULL)
| 314 |
return(MG_EUNDEF);
| 315 |
if (is0vect(cva[i-1]->n))
| 316 |
break;
| 317 |
| 318 |
if (i < ac)
| 319 |
i = ISFLAT;
| 320 |
else
| 321 |
i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p,
| 322 |
cva[0]->n, cva[1]->n, cva[2]->n);
| 323 |
if (i == DEGEN)
| 324 |
return(MG_OK); /* degenerate (error?) */
| 325 |
if (i == RVBENT) {
| 326 |
myi = !myi;
| 327 |
i = ISBENT;
| 328 |
} else if (i == RVFLAT) {
| 329 |
myi = !myi;
| 330 |
i = ISFLAT;
| 331 |
| 332 |
if (i == ISBENT) { /* smoothed triangles */
| 333 |
do_tri(mat, cva[0], cva[1], cva[2], myi);
| 334 |
if (ac == 5)
| 335 |
do_tri(mat, cva[2], cva[3], cva[0], myi);
| 336 |
return(MG_OK);
| 337 |
| 338 |
| 339 |
/* spit out unsmoothed primitive */
| 340 |
printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces);
| 341 |
printf("0\n0\n%d\n", 3*(ac-1));
| 342 |
for (i = 1; i < ac; i++) { /* get, transform, print each vertex */
| 343 |
if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL)
| 344 |
return(MG_EUNDEF);
| 345 |
xf_xfmpoint(v, cv->p);
| 346 |
putv(v);
| 347 |
| 348 |
return(MG_OK);
| 349 |
| 350 |
| 351 |
| 352 |
int
| 353 |
r_ies(ac, av) /* convert an IES luminaire file */
| 354 |
int ac;
| 355 |
char **av;
| 356 |
| 357 |
int xa0 = 2;
| 358 |
char combuf[128];
| 359 |
char fname[48];
| 360 |
char *oname;
| 361 |
register char *op;
| 362 |
register int i;
| 363 |
/* check argument count */
| 364 |
if (ac < 2)
| 365 |
return(MG_EARGC);
| 366 |
/* construct output file name */
| 367 |
if ((op = strrchr(av[1], '/')) != NULL)
| 368 |
op++;
| 369 |
else
| 370 |
op = av[1];
| 371 |
(void)strcpy(fname, op);
| 372 |
if ((op = strrchr(fname, '.')) == NULL)
| 373 |
op = fname + strlen(fname);
| 374 |
(void)strcpy(op, ".rad");
| 375 |
/* see if we need to run ies2rad */
| 376 |
if (access(fname, 0) == -1) {
| 377 |
(void)strcpy(combuf, "ies2rad");/* build ies2rad command */
| 378 |
op = combuf + 7; /* get -m option (first) */
| 379 |
if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) {
| 380 |
if (!isflt(av[xa0+1]))
| 381 |
return(MG_ETYPE);
| 382 |
op = addarg(addarg(op, "-m"), av[xa0+1]);
| 383 |
xa0 += 2;
| 384 |
| 385 |
*op++ = ' '; /* build IES filename */
| 386 |
i = 0;
| 387 |
if (mg_file != NULL &&
| 388 |
(oname = strrchr(mg_file->fname,'/')) != NULL) {
| 389 |
i = oname - mg_file->fname + 1;
| 390 |
(void)strcpy(op, mg_file->fname);
| 391 |
| 392 |
(void)strcpy(op+i, av[1]);
| 393 |
if (access(op, 0) == -1) /* check for file existence */
| 394 |
return(MG_ENOFILE);
| 395 |
system(combuf); /* run ies2rad */
| 396 |
if (access(fname, 0) == -1) /* check success */
| 397 |
return(MG_EINCL);
| 398 |
| 399 |
printf("\n!xform"); /* put out xform command */
| 400 |
oname = object();
| 401 |
if (*oname) {
| 402 |
printf(" -n ");
| 403 |
for (op = oname; op[1]; op++) /* remove trailing separator */
| 404 |
putchar(*op);
| 405 |
| 406 |
for (i = xa0; i < ac; i++)
| 407 |
printf(" %s", av[i]);
| 408 |
if (ac > xa0 && xf_argc > 0)
| 409 |
printf(" -i 1");
| 410 |
for (i = 0; i < xf_argc; i++)
| 411 |
printf(" %s", xf_argv[i]);
| 412 |
printf(" %s\n", fname);
| 413 |
return(MG_OK);
| 414 |
| 415 |
| 416 |
| 417 |
do_tri(mat, cv1, cv2, cv3, iv) /* put out smoothed triangle */
| 418 |
char *mat;
| 419 |
C_VERTEX *cv1, *cv2, *cv3;
| 420 |
int iv;
| 421 |
| 422 |
static int ntris;
| 423 |
BARYCCM bvecs;
| 424 |
schorsch |
1.3 |
RREAL bcoor[3][3];
| 425 |
greg |
1.1 |
C_VERTEX *cvt;
| 426 |
FVECT v1, v2, v3;
| 427 |
FVECT n1, n2, n3;
| 428 |
register int i;
| 429 |
| 430 |
if (iv) { /* swap vertex order if inverted */
| 431 |
cvt = cv1;
| 432 |
cv1 = cv3;
| 433 |
cv3 = cvt;
| 434 |
| 435 |
xf_xfmpoint(v1, cv1->p);
| 436 |
xf_xfmpoint(v2, cv2->p);
| 437 |
xf_xfmpoint(v3, cv3->p);
| 438 |
/* compute barycentric coords. */
| 439 |
if (comp_baryc(&bvecs, v1, v2, v3) < 0)
| 440 |
return; /* degenerate triangle! */
| 441 |
printf("\n%s texfunc T-nor\n", mat); /* put out texture */
| 442 |
printf("4 dx dy dz %s\n0\n", TCALNAME);
| 443 |
xf_rotvect(n1, cv1->n);
| 444 |
xf_rotvect(n2, cv2->n);
| 445 |
xf_rotvect(n3, cv3->n);
| 446 |
for (i = 0; i < 3; i++) {
| 447 |
bcoor[i][0] = n1[i];
| 448 |
bcoor[i][1] = n2[i];
| 449 |
bcoor[i][2] = n3[i];
| 450 |
| 451 |
put_baryc(&bvecs, bcoor, 3);
| 452 |
/* put out triangle */
| 453 |
printf("\nT-nor polygon %st%d\n", object(), ++ntris);
| 454 |
printf("0\n0\n9\n");
| 455 |
putv(v1);
| 456 |
putv(v2);
| 457 |
putv(v3);
| 458 |
| 459 |
| 460 |
| 461 |
char *
| 462 |
material() /* get (and print) current material */
| 463 |
| 464 |
char *mname = "mat";
| 465 |
COLOR radrgb, c2;
| 466 |
double d;
| 467 |
register int i;
| 468 |
| 469 |
if (c_cmname != NULL)
| 470 |
mname = c_cmname;
| 471 |
if (!c_cmaterial->clock)
| 472 |
return(mname); /* already current */
| 473 |
/* else update output */
| 474 |
c_cmaterial->clock = 0;
| 475 |
if (c_cmaterial->ed > .1) { /* emitter */
| 476 |
cvtcolor(radrgb, &c_cmaterial->ed_c,
| 477 |
emult*c_cmaterial->ed/(PI*WHTEFFICACY));
| 478 |
if (glowdist < FHUGE) { /* do a glow */
| 479 |
fprintf(matfp, "\nvoid glow %s\n0\n0\n", mname);
| 480 |
fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED),
| 481 |
colval(radrgb,GRN),
| 482 |
colval(radrgb,BLU), glowdist);
| 483 |
} else {
| 484 |
fprintf(matfp, "\nvoid light %s\n0\n0\n", mname);
| 485 |
fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED),
| 486 |
colval(radrgb,GRN),
| 487 |
colval(radrgb,BLU));
| 488 |
| 489 |
return(mname);
| 490 |
| 491 |
d = c_cmaterial->rd + c_cmaterial->td +
| 492 |
c_cmaterial->rs + c_cmaterial->ts;
| 493 |
if (d < 0. | d > 1.)
| 494 |
return(NULL);
| 495 |
/* check for glass/dielectric */
| 496 |
if (c_cmaterial->nr > 1.1 &&
| 497 |
c_cmaterial->ts > .25 && c_cmaterial->rs <= .125 &&
| 498 |
c_cmaterial->td <= .01 && c_cmaterial->rd <= .01 &&
| 499 |
c_cmaterial->rs_a <= .01 && c_cmaterial->ts_a <= .01) {
| 500 |
cvtcolor(radrgb, &c_cmaterial->ts_c,
| 501 |
c_cmaterial->ts + c_cmaterial->rs);
| 502 |
if (c_cmaterial->sided) { /* dielectric */
| 503 |
colval(radrgb,RED) = pow(colval(radrgb,RED),
| 504 |
1./C_1SIDEDTHICK);
| 505 |
colval(radrgb,GRN) = pow(colval(radrgb,GRN),
| 506 |
1./C_1SIDEDTHICK);
| 507 |
colval(radrgb,BLU) = pow(colval(radrgb,BLU),
| 508 |
1./C_1SIDEDTHICK);
| 509 |
fprintf(matfp, "\nvoid dielectric %s\n0\n0\n", mname);
| 510 |
fprintf(matfp, "5 %g %g %g %f 0\n", colval(radrgb,RED),
| 511 |
colval(radrgb,GRN), colval(radrgb,BLU),
| 512 |
c_cmaterial->nr);
| 513 |
return(mname);
| 514 |
| 515 |
/* glass */
| 516 |
fprintf(matfp, "\nvoid glass %s\n0\n0\n", mname);
| 517 |
| 518 |
| 519 |
c_cmaterial->nr);
| 520 |
return(mname);
| 521 |
| 522 |
/* check for trans */
| 523 |
if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) {
| 524 |
double ts, a5, a6;
| 525 |
| 526 |
| 527 |
ts = sqrt(c_cmaterial->ts); /* approximate */
| 528 |
a5 = .5;
| 529 |
} else {
| 530 |
ts = c_cmaterial->ts;
| 531 |
a5 = 1.;
| 532 |
| 533 |
/* average colors */
| 534 |
d = c_cmaterial->rd + c_cmaterial->td + ts;
| 535 |
cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d);
| 536 |
cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d);
| 537 |
addcolor(radrgb, c2);
| 538 |
cvtcolor(c2, &c_cmaterial->ts_c, ts/d);
| 539 |
| 540 |
if (c_cmaterial->rs + ts > .0001)
| 541 |
a5 = (c_cmaterial->rs*c_cmaterial->rs_a +
| 542 |
ts*a5*c_cmaterial->ts_a) /
| 543 |
(c_cmaterial->rs + ts);
| 544 |
a6 = (c_cmaterial->td + ts) /
| 545 |
(c_cmaterial->rd + c_cmaterial->td + ts);
| 546 |
if (a6 < .999)
| 547 |
d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6);
| 548 |
else
| 549 |
d = c_cmaterial->td + ts;
| 550 |
scalecolor(radrgb, d);
| 551 |
fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname);
| 552 |
fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED),
| 553 |
colval(radrgb,GRN), colval(radrgb,BLU));
| 554 |
fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6,
| 555 |
ts/(ts + c_cmaterial->td));
| 556 |
return(mname);
| 557 |
| 558 |
/* check for plastic */
| 559 |
if (c_cmaterial->rs < .1) {
| 560 |
| 561 |
c_cmaterial->rd/(1.-c_cmaterial->rs));
| 562 |
fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname);
| 563 |
fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED),
| 564 |
| 565 |
c_cmaterial->rs, c_cmaterial->rs_a);
| 566 |
return(mname);
| 567 |
| 568 |
/* else it's metal */
| 569 |
| 570 |
cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd);
| 571 |
cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs);
| 572 |
| 573 |
fprintf(matfp, "\nvoid metal %s\n0\n0\n", mname);
| 574 |
| 575 |
| 576 |
c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs),
| 577 |
c_cmaterial->rs_a);
| 578 |
return(mname);
| 579 |
| 580 |
| 581 |
| 582 |
cvtcolor(radrgb, ciec, intensity) /* convert a CIE XYZ color to RGB */
| 583 |
COLOR radrgb;
| 584 |
register C_COLOR *ciec;
| 585 |
double intensity;
| 586 |
| 587 |
static COLOR ciexyz;
| 588 |
| 589 |
c_ccvt(ciec, C_CSXY); /* get xy representation */
| 590 |
ciexyz[1] = intensity;
| 591 |
ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1];
| 592 |
ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0];
| 593 |
cie_rgb(radrgb, ciexyz);
| 594 |
| 595 |
| 596 |
| 597 |
char *
| 598 |
object() /* return current object name */
| 599 |
| 600 |
static char objbuf[64];
| 601 |
register int i;
| 602 |
register char *cp;
| 603 |
int len;
| 604 |
/* tracked by obj_handler */
| 605 |
i = obj_nnames - sizeof(objbuf)/16;
| 606 |
if (i < 0)
| 607 |
i = 0;
| 608 |
for (cp = objbuf; i < obj_nnames &&
| 609 |
cp + (len=strlen(obj_name[i])) < objbuf+sizeof(objbuf)-1;
| 610 |
i++, *cp++ = '.') {
| 611 |
strcpy(cp, obj_name[i]);
| 612 |
cp += len;
| 613 |
| 614 |
*cp = '\0';
| 615 |
return(objbuf);
| 616 |
| 617 |
| 618 |
| 619 |
char *
| 620 |
addarg(op, arg) /* add argument and advance pointer */
| 621 |
register char *op, *arg;
| 622 |
| 623 |
*op = ' ';
| 624 |
while (*++op = *arg++)
| 625 |
| 626 |
return(op);
| 627 |
