--- ray/src/cv/mgflib/mgf2inv.c 1995/12/04 12:01:31 1.2 +++ ray/src/cv/mgflib/mgf2inv.c 1995/12/05 10:34:12 1.3 @@ -18,16 +18,46 @@ static char SCCSid[] = "$SunId$ LBL"; #include "parser.h" +#include "lookup.h" + #define O_INV1 1 /* Inventor 1.0 output */ #define O_INV2 2 /* Inventor 2.0 output */ #define O_VRML 3 /* VRML output */ +#define MAXID 48 /* maximum identifier length */ + +#define VERTFMT "%+16.9e %+16.9e %+16.9e\n%+6.3f %+6.3f %+6.3f" +#define VZVECT "+0.000 +0.000 +0.000" +#define VFSEPPOS 50 /* position of newline in above */ +#define VFLEN 72 /* total vertex string length */ +#define MAXVERT 10240 /* maximum cached vertices */ + +#define setvkey(k,v) sprintf(k,VERTFMT,(v)->p[0],(v)->p[1],(v)->p[2],\ + (v)->n[0],(v)->n[1],(v)->n[2]); + +char vlist[MAXVERT][VFLEN]; /* our vertex cache */ +int nverts; /* current cache size */ + +LUTAB vert_tab = LU_SINIT(NULL,NULL); + +struct face { + struct face *next; /* next face in list */ + short nv; /* number of vertices */ + short vl[3]; /* vertex index list (variable) */ +} *flist, *flast; /* our face cache */ + +#define newface(n) (struct face *)malloc(sizeof(struct face) + \ + ((n) > 3 ? (n)-3 : 0)*sizeof(short)) +#define freeface(f) free((MEM_PTR)f) + #define TABSTOP 8 /* assumed number of characters per tab */ #define SHIFTW 2 /* nesting shift width */ #define MAXIND 15 /* maximum indent level */ char tabs[MAXIND*SHIFTW+1]; /* current tab-in string */ +#define curmatname (c_cmname == NULL ? "mat" : to_id(c_cmname)) + int outtype = O_INV2; /* output format */ extern int i_comment(), i_object(), i_xf(), @@ -114,7 +144,8 @@ char *argv[]; printf("## %s %s: %u unknown entities\n", argv[0], argv[i], mg_nunknown); } - printf("}\n"); /* close root node */ + flush_cache(); /* flush face cache, just in case */ + printf("}\n"); /* close root node */ exit(0); userr: fprintf(stderr, "%s: [-1|-2|-vrml] [file] ..\n", argv[0]); @@ -165,6 +196,7 @@ char **av; { static int objnest; + flush_cache(); /* flush cached objects */ if (ac == 2) { /* start group */ printf("%sDEF %s Group {\n", tabs, to_id(av[1])); indent(1); @@ -191,6 +223,7 @@ char **av; static long xfid; register XF_SPEC *spec; + flush_cache(); /* flush cached objects */ if (ac == 1) { /* end of transform */ if ((spec = xf_context) == NULL) return(MG_ECNTXT); @@ -284,17 +317,15 @@ register XF_SPEC *spec; int put_material() /* put out current material */ { - char *mname = "mat"; + char *mname = curmatname; float rgbval[3]; - if (c_cmname != NULL) - mname = c_cmname; if (!c_cmaterial->clock) { /* current, just use it */ - printf("%sUSE %s\n", tabs, to_id(mname)); + printf("%sUSE %s\n", tabs, mname); return(0); } /* else update definition */ - printf("%sDEF %s Group {\n", tabs, to_id(mname)); + printf("%sDEF %s Group {\n", tabs, mname); indent(1); printf("%sMaterial {\n", tabs); indent(1); @@ -334,65 +365,48 @@ i_face(ac, av) /* translate an N-sided face */ int ac; char **av; { - C_VERTEX *vl[MG_MAXARGC-1]; - int donorms = 1; + static char lastmat[MAXID]; + struct face *newf; + register C_VERTEX *vp; + register LUENT *lp; register int i; if (ac < 4) return(MG_EARGC); - printf("%sSeparator {\n", tabs); - indent(1); - /* put out current material */ - if (put_material() < 0) - return(MG_EBADMAT); + if ( strcmp(lastmat, curmatname) || c_cmaterial->clock || + nverts == 0 || nverts+ac-1 >= MAXVERT) { + flush_cache(); /* new cache */ + lu_init(&vert_tab, MAXVERT); + printf("%sSeparator {\n", tabs); + indent(1); + if (put_material() < 0) /* put out material */ + return(MG_EBADMAT); + (void)strcpy(lastmat, curmatname); + } + /* allocate new face */ + if ((newf = newface(ac-1)) == NULL) + return(MG_EMEM); + newf->nv = ac-1; /* get vertex references */ - for (i = 0; i < ac-1; i++) { - if ((vl[i] = c_getvert(av[i+1])) == NULL) + for (i = 0; i < newf->nv; i++) { + if ((vp = c_getvert(av[i+1])) == NULL) return(MG_EUNDEF); - if (is0vect(vl[i]->n)) - donorms = 0; + setvkey(vlist[nverts], vp); + lp = lu_find(&vert_tab, vlist[nverts]); + if (lp == NULL) + return(MG_EMEM); + if (lp->key == NULL) + lp->key = (char *)vlist[nverts++]; + newf->vl[i] = ((char (*)[VFLEN])lp->key - vlist); } - /* put out normal coordinates */ - if (donorms) { - printf("%sNormal {\n", tabs); - indent(1); - printf("%svector [ %5.3g %5.3g %5.3g", tabs, - vl[0]->n[0], vl[0]->n[1], vl[0]->n[2]); - for (i = 1; i < ac-1; i++) - printf(",\n%s %5.3g %5.3g %5.3g", tabs, - vl[i]->n[0], vl[i]->n[1], vl[i]->n[2]); - indent(0); - printf(" ]\n%s}\n", tabs); - } else - printf("%sNormal { }\n", tabs); - /* put out vertex coordinates */ - printf("%sCoordinate3 {\n", tabs); - indent(1); - printf("%spoint [ %13.9g %13.9g %13.9g", tabs, - vl[0]->p[0], vl[0]->p[1], vl[0]->p[2]); - for (i = 1; i < ac-1; i++) - printf(",\n%s %13.9g %13.9g %13.9g", tabs, - vl[i]->p[0], vl[i]->p[1], vl[i]->p[2]); - indent(0); - printf(" ]\n%s}\n", tabs); - /* put out actual face */ - printf("%sIndexedFaceSet {\n", tabs); - indent(1); - if (donorms) { - printf("%snormalIndex [ 0", tabs); - for (i = 1; i < ac-1; i++) - printf(", %d", i); - printf(" ]\n"); - } - printf("%scoordIndex [ 0", tabs); - for (i = 1; i < ac-1; i++) - printf(", %d", i); - printf(" ]\n"); - indent(0); - printf("%s}\n", tabs); - indent(0); - printf("%s}\n", tabs); - return(MG_OK); + /* add to face list */ + newf->next = NULL; + if (flist == NULL) + flist = newf; + else + flast->next = newf; + flast = newf; + return(MG_OK); /* we'll actually put it out later */ } @@ -405,6 +419,7 @@ char **av; if (ac != 3) return(MG_EARGC); + flush_cache(); /* flush vertex cache */ printf("%sSeparator {\n", tabs); indent(1); /* put out current material */ @@ -436,6 +451,7 @@ char **av; if (ac != 4) return(MG_EARGC); + flush_cache(); /* flush vertex cache */ printf("%sSeparator {\n", tabs); indent(1); /* put out current material */ @@ -471,14 +487,82 @@ char * to_id(name) /* make sure a name is a valid Inventor ID */ register char *name; { - static char id[32]; + static char id[MAXID]; register char *cp; - for (cp = id; cp < id+sizeof(id)-1 && *name; name++) + for (cp = id; *name && cp < MAXID-1+id; name++) if (isalnum(*name) || *name == '_') *cp++ = *name; else *cp++ = '_'; *cp = '\0'; return(id); +} + + +flush_cache() /* put out cached faces */ +{ + int donorms = 0; + register struct face *f; + register int i; + + if (nverts == 0) + return; + /* put out coordinates */ + printf("%sCoordinate3 {\n", tabs); + indent(1); + vlist[0][VFSEPPOS] = '\0'; + printf("%spoint [ %s", tabs, vlist[0]); + for (i = 1; i < nverts; i++) { + vlist[i][VFSEPPOS] = '\0'; + printf(",\n%s %s", tabs, vlist[i]); + if (strcmp(VFSEPPOS+1+vlist[i], VZVECT)) + donorms++; + } + indent(0); + printf(" ]\n%s}\n", tabs); + if (donorms) { /* put out normals */ + printf("%sNormal {\n", tabs); + indent(1); + printf("%svector [ %s", tabs, VFSEPPOS+1+vlist[0]); + for (i = 1; i < nverts; i++) + printf(",\n%s %s", tabs, VFSEPPOS+1+vlist[i]); + indent(0); + printf(" ]\n%s}\n", tabs); + } + /* put out faces */ + printf("%sIndexedFaceSet {\n", tabs); + indent(1); + f = flist; /* coordinate indices */ + printf("%scoordIndex [ %d", tabs, f->vl[0]); + for (i = 1; i < f->nv; i++) + printf(", %d", f->vl[i]); + for (f = f->next; f != NULL; f = f->next) { + printf(", -1,\n%s %d", tabs, f->vl[0]); + for (i = 1; i < f->nv; i++) + printf(", %d", f->vl[i]); + } + printf(" ]\n"); + if (donorms) { + f = flist; /* normal indices */ + printf("%snormalIndex [ %d", tabs, f->vl[0]); + for (i = 1; i < f->nv; i++) + printf(", %d", f->vl[i]); + for (f = f->next; f != NULL; f = f->next) { + printf(", -1,\n%s %d", tabs, f->vl[0]); + for (i = 1; i < f->nv; i++) + printf(", %d", f->vl[i]); + } + printf(" ]\n"); + } + indent(0); /* close IndexedFaceSet */ + printf("%s}\n", tabs); + indent(0); /* close face group */ + printf("%s}\n", tabs); + while ((f = flist) != NULL) { /* free face list */ + flist = f->next; + freeface(f); + } + lu_done(&vert_tab); /* clear lookup table */ + nverts = 0; }
