root/radiance/ray/src/cv/mgflib/mgf2inv.c
Revision 1.13
Tue Feb 22 15:58:42 2011 UTC (14 years, 2 months ago) by greg
FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
Fri Jan 14 05:46:12 2011 UTC (14 years, 4 months ago) by greg
Diff to previous 1.11 , to selected 1.4
Eliminated unnecessary MEM_PTR
Sat Nov 15 17:54:06 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.10: +54 -34 lines
Diff to previous 1.10 , to selected 1.4
Tue Aug 5 20:40:16 2003 UTC (21 years, 9 months ago) by greg
Changes since 1.9: +3 -2 lines
Diff to previous 1.9 , to selected 1.4
Fixed minor bug in mgf2inv where faceType was not specified as unknown
Sun Jul 27 22:12:02 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 1.8 , to selected 1.4
Fri Feb 28 20:11:29 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.7: +3 -4 lines
Diff to previous 1.7 , to selected 1.4
Updates for 3.5 release
Thu May 22 08:41:04 1997 UTC (27 years, 11 months ago) by gregl
Changes since 1.6: +4 -4 lines
Diff to previous 1.6 , to selected 1.4
small correction in VRML 1.0 header
Tue Mar 18 11:05:43 1997 UTC (28 years, 2 months ago) by greg
Diff to previous 1.5 , to selected 1.4
added fh entity and general cleanup
Wed Feb 5 14:53:33 1997 UTC (28 years, 3 months ago) by greg
Changes since 1.4: +6 -1 lines
Diff to previous 1.4
fixed floating point error due to round-off passed to acos()
Revision 1.4 - (view) (download) (annotate) - [selected]
Tue Dec 5 10:59:27 1995 UTC (29 years, 5 months ago) by greg
Diff to previous 1.3
changed shininess setting to a slightly better (at least different) guess
Tue Dec 5 10:34:12 1995 UTC (29 years, 5 months ago) by greg
Changes since 1.2: +144 -60 lines
Diff to previous 1.2 , to selected 1.4
added vertex caching for better normal generation in IndexedFaceSet
Mon Dec 4 12:01:31 1995 UTC (29 years, 5 months ago) by greg
Changes since 1.1: +90 -139 lines
Diff to previous 1.1 , to selected 1.4
had to remove include file interpretation, which didn't work
added identifier filtering
other bug fixes
Mon Dec 4 09:59:57 1995 UTC (29 years, 5 months ago) by greg
Diff to selected 1.4
