root/radiance/ray/src/cv/mgflib/lookup.h
Revision: 1.8
Committed: Tue Mar 18 11:05:34 1997 UTC (27 years, 2 months ago) by greg
Changes since 1.7: +0 -2 lines
added fh entity and general cleanup
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for general associative table lookup routines
7 */
8
9 typedef struct {
10 char *key; /* key name */
11 long hval; /* key hash value (for efficiency) */
12 char *data; /* pointer to client data */
13 } LUENT;
14
15 #ifdef NOPROTO
16 typedef struct {
17 long (*hashf)(); /* key hash function */
18 int (*keycmp)(); /* key comparison function */
19 void (*freek)(); /* free a key */
20 void (*freed)(); /* free the data */
21 int tsiz; /* current table size */
22 LUENT *tabl; /* table, if allocated */
23 int ndel; /* number of deleted entries */
24 } LUTAB;
25 #else
26 typedef struct {
27 long (*hashf)(); /* key hash function */
28 int (*keycmp)(const char *, const char *); /* key comparison function */
29 void (*freek)(char *); /* free a key */
30 void (*freed)(char *); /* free the data */
31 int tsiz; /* current table size */
32 LUENT *tabl; /* table, if allocated */
33 int ndel; /* number of deleted entries */
34 } LUTAB;
35 #endif
36
37 #define LU_SINIT(fk,fd) {lu_shash,strcmp,(void (*)())(fk),\
38 (void (*)())(fd),0,NULL,0}
39
40 /*
41 * The lu_init routine is called to initialize a table. The number of
42 * elements passed is not a limiting factor, as a table can grow to
43 * any size permitted by memory. However, access will be more efficient
44 * if this number strikes a reasonable balance between default memory use
45 * and the expected (minimum) table size. The value returned is the
46 * actual allocated table size (or zero if there was insufficient memory).
47 *
48 * The hashf, keycmp, freek and freed member functions must be assigned
49 * separately. If the hash value is sufficient to guarantee equality
50 * between keys, then the keycmp pointer may be NULL. Otherwise, it
51 * should return 0 if the two passed keys match. If it is not necessary
52 * (or possible) to free the key and/or data values, then the freek and/or
53 * freed member functions may be NULL.
54 *
55 * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
56 * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
57 * The LU_SINIT macro provides a convenient static declaration for character
58 * string keys.
59 *
60 * The lu_find routine returns the entry corresponding to the given
61 * key. If the entry does not exist, the corresponding key field will
62 * be NULL. If the entry has been previously deleted but not yet freed,
63 * then only the data field will be NULL. It is the caller's
64 * responsibility to (allocate and) assign the key and data fields when
65 * creating a new entry. The only case where lu_find returns NULL is when
66 * the system has run out of memory.
67 *
68 * The lu_delete routine frees an entry's data (if any) by calling
69 * the freed member function, but does not free the key field. This
70 * will be freed later during (or instead of) table reallocation.
71 * It is therefore an error to reuse or do anything with the key
72 * field after calling lu_delete.
73 *
74 * The lu_done routine calls the given free function once for each
75 * assigned table entry (i.e. each entry with an assigned key value).
76 * The user must define these routines to free the key and the data
77 * in the LU_TAB structure. The final action of lu_done is to free the
78 * allocated table itself.
79 */
80
81 #ifdef NOPROTO
82 extern int lu_init();
83 extern LUENT *lu_find();
84 extern void lu_delete();
85 extern void lu_done();
86 extern long lu_shash();
87 #else
88 extern int lu_init(LUTAB *, int);
89 extern LUENT *lu_find(LUTAB *, char *);
90 extern void lu_delete(LUTAB *, char *);
91 extern void lu_done(LUTAB *);
92 extern long lu_shash(char *);
93 #endif
