root/radiance/ray/src/cv/mgflib/lookup.h
Revision: 1.12
Committed: Sat Nov 15 17:54:06 2003 UTC (21 years, 8 months ago) by schorsch
CVS Tags: rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad3R7P2
Changes since 1.11: +33 -21 lines
1 /* RCSid $Id: lookup.h,v 2.11 2003/07/30 10:11:06 schorsch Exp $ */
2 /*
3 * Header file for general associative table lookup routines
4 */
5 #ifndef _RAD_LOOKUP_H_
6 #define _RAD_LOOKUP_H_
7
8 #include <string.h> /* strcmp() */
9
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 typedef void lut_free_t(void*);
15
16 typedef struct {
17 char *key; /* key name */
18 unsigned long hval; /* key hash value (for efficiency) */
19 char *data; /* pointer to client data */
20 } LUENT;
21
22 typedef struct {
23 unsigned long (*hashf)(char*); /* key hash function */
24 int (*keycmp)(const char*, const char*); /* key comparison function */
25 lut_free_t *freek; /* free a key */
26 lut_free_t *freed; /* free the data */
27 int tsiz; /* current table size */
28 LUENT *tabl; /* table, if allocated */
29 int ndel; /* number of deleted entries */
30 } LUTAB;
31
32 #undef strcmp
33 #define LU_SINIT(fk,fd) {lu_shash,strcmp,fk,\
34 fd,0,NULL,0}
35
36 /*
37 * The lu_init routine is called to initialize a table. The number of
38 * elements passed is not a limiting factor, as a table can grow to
39 * any size permitted by memory. However, access will be more efficient
40 * if this number strikes a reasonable balance between default memory use
41 * and the expected (minimum) table size. The value returned is the
42 * actual allocated table size (or zero if there was insufficient memory).
43 *
44 * The hashf, keycmp, freek and freed member functions must be assigned
45 * separately. If the hash value is sufficient to guarantee equality
46 * between keys, then the keycmp pointer may be NULL. Otherwise, it
47 * should return 0 if the two passed keys match. If it is not necessary
48 * (or possible) to free the key and/or data values, then the freek and/or
49 * freed member functions may be NULL.
50 *
51 * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
52 * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
53 * The LU_SINIT macro provides a convenient static declaration for character
54 * string keys.
55 *
56 * The lu_find routine returns the entry corresponding to the given
57 * key. If the entry does not exist, the corresponding key field will
58 * be NULL. If the entry has been previously deleted but not yet freed,
59 * then only the data field will be NULL. It is the caller's
60 * responsibility to (allocate and) assign the key and data fields when
61 * creating a new entry. The only case where lu_find returns NULL is when
62 * the system has run out of memory.
63 *
64 * The lu_delete routine frees an entry's data (if any) by calling
65 * the freed member function, but does not free the key field. This
66 * will be freed later during (or instead of) table reallocation.
67 * It is therefore an error to reuse or do anything with the key
68 * field after calling lu_delete.
69 *
70 * The lu_doall routine loops through every filled table entry, calling
71 * the given function once on each entry. If a NULL pointer is passed
72 * for this function, then lu_doall simply returns the total number of
73 * active entries. Otherwise, it returns the sum of all the function
74 * evaluations.
75 *
76 * The lu_done routine calls the given free function once for each
77 * assigned table entry (i.e. each entry with an assigned key value).
78 * The user must define these routines to free the key and the data
79 * in the LU_TAB structure. The final action of lu_done is to free the
80 * allocated table itself.
81 */
82
83 extern int lu_init(LUTAB *tbl, int nel);
84 extern unsigned long lu_shash(char *s);
85 extern LUENT *lu_find(LUTAB *tbl, char *key);
86 extern void lu_delete(LUTAB *tbl, char *key);
87 extern int lu_doall(LUTAB *tbl, int (*f)(LUENT*));
88 extern void lu_done(LUTAB *tbl);
89
90
91 #ifdef __cplusplus
92 }
93 #endif
94 #endif /* _RAD_LOOKUP_H_ */
95
