root/Development/ray/src/cv/mgflib/lookup.h
Revision: 1.11
Committed: Sat Jun 7 01:11:17 2003 UTC (22 years, 7 months ago) by schorsch
Changes since 1.10: +13 -20 lines
Removed NOPROTO sections.
1 /* RCSid: $Id: lookup.h,v 1.10 2003/02/28 20:11:29 greg Exp $ */
2 /*
3 * Header file for general associative table lookup routines
4 */
5 #ifndef _MGF_LOOKUP_H_
6 #define _MGF_LOOKUP_H_
7 #ifdef __cplusplus
8 extern "C" {
9 #endif
10
11
12 typedef struct {
13 char *key; /* key name */
14 long hval; /* key hash value (for efficiency) */
15 char *data; /* pointer to client data */
16 } LUENT;
17
18 typedef struct {
19 unsigned long (*hashf)(char *); /* key hash function */
20 int (*keycmp)(const char *, const char *); /* key comparison function */
21 void (*freek)(char *); /* free a key */
22 void (*freed)(char *); /* free the data */
23 int tsiz; /* current table size */
24 LUENT *tabl; /* table, if allocated */
25 int ndel; /* number of deleted entries */
26 } LUTAB;
27
28 #define LU_SINIT(fk,fd) {lu_shash,strcmp,(void (*)())(fk),\
29 (void (*)())(fd),0,NULL,0}
30
31 /*
32 * The lu_init routine is called to initialize a table. The number of
33 * elements passed is not a limiting factor, as a table can grow to
34 * any size permitted by memory. However, access will be more efficient
35 * if this number strikes a reasonable balance between default memory use
36 * and the expected (minimum) table size. The value returned is the
37 * actual allocated table size (or zero if there was insufficient memory).
38 *
39 * The hashf, keycmp, freek and freed member functions must be assigned
40 * separately. If the hash value is sufficient to guarantee equality
41 * between keys, then the keycmp pointer may be NULL. Otherwise, it
42 * should return 0 if the two passed keys match. If it is not necessary
43 * (or possible) to free the key and/or data values, then the freek and/or
44 * freed member functions may be NULL.
45 *
46 * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
47 * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
48 * The LU_SINIT macro provides a convenient static declaration for character
49 * string keys.
50 *
51 * The lu_find routine returns the entry corresponding to the given
52 * key. If the entry does not exist, the corresponding key field will
53 * be NULL. If the entry has been previously deleted but not yet freed,
54 * then only the data field will be NULL. It is the caller's
55 * responsibility to (allocate and) assign the key and data fields when
56 * creating a new entry. The only case where lu_find returns NULL is when
57 * the system has run out of memory.
58 *
59 * The lu_delete routine frees an entry's data (if any) by calling
60 * the freed member function, but does not free the key field. This
61 * will be freed later during (or instead of) table reallocation.
62 * It is therefore an error to reuse or do anything with the key
63 * field after calling lu_delete.
64 *
65 * The lu_done routine calls the given free function once for each
66 * assigned table entry (i.e. each entry with an assigned key value).
67 * The user must define these routines to free the key and the data
68 * in the LU_TAB structure. The final action of lu_done is to free the
69 * allocated table itself.
70 */
71
72 extern int lu_init(LUTAB *, int);
73 extern LUENT *lu_find(LUTAB *, char *);
74 extern void lu_delete(LUTAB *, char *);
75 extern void lu_done(LUTAB *);
76 extern unsigned long lu_shash(char *);
77
78
79 #ifdef __cplusplus
80 }
81 #endif
82 #endif /* _MGF_LOOKUP_H_ */
83
