root/radiance/ray/src/cv/mgflib/lookup.h
Revision: 1.12
Committed: Sat Nov 15 17:54:06 2003 UTC (20 years, 7 months ago) by schorsch
CVS Tags: rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad3R7P2
Changes since 1.11: +33 -21 lines
# User Rev Content
1 schorsch 1.12 /* RCSid $Id: lookup.h,v 2.11 2003/07/30 10:11:06 schorsch Exp $ */
2 greg 1.1 /*
3 greg 1.4 * Header file for general associative table lookup routines
4 greg 1.1 */
5 schorsch 1.12 #ifndef _RAD_LOOKUP_H_
6     #define _RAD_LOOKUP_H_
7
8     #include <string.h> /* strcmp() */
9
10 schorsch 1.11 #ifdef __cplusplus
11     extern "C" {
12     #endif
13
14 schorsch 1.12 typedef void lut_free_t(void*);
15 greg 1.1
16     typedef struct {
17 schorsch 1.12 char *key; /* key name */
18     unsigned long hval; /* key hash value (for efficiency) */
19     char *data; /* pointer to client data */
20 greg 1.1 } LUENT;
21
22 greg 1.6 typedef struct {
23 schorsch 1.12 unsigned long (*hashf)(char*); /* key hash function */
24     int (*keycmp)(const char*, const char*); /* key comparison function */
25     lut_free_t *freek; /* free a key */
26     lut_free_t *freed; /* free the data */
27     int tsiz; /* current table size */
28     LUENT *tabl; /* table, if allocated */
29     int ndel; /* number of deleted entries */
30 greg 1.6 } LUTAB;
31 greg 1.1
32 schorsch 1.12 #undef strcmp
33     #define LU_SINIT(fk,fd) {lu_shash,strcmp,fk,\
34     fd,0,NULL,0}
35 greg 1.2
36 greg 1.1 /*
37     * The lu_init routine is called to initialize a table. The number of
38     * elements passed is not a limiting factor, as a table can grow to
39     * any size permitted by memory. However, access will be more efficient
40     * if this number strikes a reasonable balance between default memory use
41     * and the expected (minimum) table size. The value returned is the
42     * actual allocated table size (or zero if there was insufficient memory).
43     *
44 greg 1.4 * The hashf, keycmp, freek and freed member functions must be assigned
45     * separately. If the hash value is sufficient to guarantee equality
46     * between keys, then the keycmp pointer may be NULL. Otherwise, it
47     * should return 0 if the two passed keys match. If it is not necessary
48     * (or possible) to free the key and/or data values, then the freek and/or
49     * freed member functions may be NULL.
50 greg 1.1 *
51 greg 1.4 * It isn't fully necessary to call lu_init to initialize the LUTAB structure.
52     * If tsiz is 0, then the first call to lu_find will allocate a minimal table.
53     * The LU_SINIT macro provides a convenient static declaration for character
54     * string keys.
55     *
56 greg 1.1 * The lu_find routine returns the entry corresponding to the given
57 greg 1.4 * key. If the entry does not exist, the corresponding key field will
58     * be NULL. If the entry has been previously deleted but not yet freed,
59     * then only the data field will be NULL. It is the caller's
60     * responsibility to (allocate and) assign the key and data fields when
61     * creating a new entry. The only case where lu_find returns NULL is when
62     * the system has run out of memory.
63 greg 1.1 *
64 greg 1.2 * The lu_delete routine frees an entry's data (if any) by calling
65     * the freed member function, but does not free the key field. This
66     * will be freed later during (or instead of) table reallocation.
67 greg 1.5 * It is therefore an error to reuse or do anything with the key
68     * field after calling lu_delete.
69 greg 1.2 *
70 schorsch 1.12 * The lu_doall routine loops through every filled table entry, calling
71     * the given function once on each entry. If a NULL pointer is passed
72     * for this function, then lu_doall simply returns the total number of
73     * active entries. Otherwise, it returns the sum of all the function
74     * evaluations.
75     *
76 greg 1.1 * The lu_done routine calls the given free function once for each
77     * assigned table entry (i.e. each entry with an assigned key value).
78 greg 1.3 * The user must define these routines to free the key and the data
79 greg 1.2 * in the LU_TAB structure. The final action of lu_done is to free the
80 greg 1.1 * allocated table itself.
81     */
82
83 schorsch 1.12 extern int lu_init(LUTAB *tbl, int nel);
84     extern unsigned long lu_shash(char *s);
85     extern LUENT *lu_find(LUTAB *tbl, char *key);
86     extern void lu_delete(LUTAB *tbl, char *key);
87     extern int lu_doall(LUTAB *tbl, int (*f)(LUENT*));
88     extern void lu_done(LUTAB *tbl);
89 schorsch 1.11
90
91     #ifdef __cplusplus
92     }
93 greg 1.1 #endif
94 schorsch 1.12 #endif /* _RAD_LOOKUP_H_ */
95 schorsch 1.11
