--- ray/src/cv/mgflib/lookup.h 1994/06/23 07:48:35 1.2 +++ ray/src/cv/mgflib/lookup.h 1994/07/07 14:03:13 1.5 @@ -3,23 +3,27 @@ /* SCCSid "$SunId$ LBL" */ /* - * Header file for table lookup routines + * Header file for general associative table lookup routines */ typedef struct { - char *key; /* key name (dynamically allocated) */ + char *key; /* key name */ + long hval; /* key hash value (for efficiency) */ char *data; /* pointer to client data */ } LUENT; typedef struct { - void (*freek)(); /* free entry key */ - void (*freed)(); /* free entry data */ + long (*hashf)(); /* key hash function */ + int (*keycmp)(); /* key comparison function */ + void (*freek)(); /* free a key */ + void (*freed)(); /* free the data */ int tsiz; /* current table size */ LUENT *tabl; /* table, if allocated */ int ndel; /* number of deleted entries */ } LUTAB; -#define LU_SINIT(fk,fd) {(void (*)())(fk),(void (*)())(fd),0,NULL,0} +#define LU_SINIT(fk,fd) {lu_shash,strcmp,(void (*)())(fk),\ + (void (*)())(fd),0,NULL,0} /* * The lu_init routine is called to initialize a table. The number of @@ -29,27 +33,35 @@ typedef struct { * and the expected (minimum) table size. The value returned is the * actual allocated table size (or zero if there was insufficient memory). * - * It isn't fully necessary to initialize the LUTAB structure. If it - * is cleared (tsiz = 0, tabl = NULL), then the first call to lu_find - * will allocate a minimal table. If key and data free functions are - * to be used, the LU_SINIT macro provides a convenient declaration. + * The hashf, keycmp, freek and freed member functions must be assigned + * separately. If the hash value is sufficient to guarantee equality + * between keys, then the keycmp pointer may be NULL. Otherwise, it + * should return 0 if the two passed keys match. If it is not necessary + * (or possible) to free the key and/or data values, then the freek and/or + * freed member functions may be NULL. * + * It isn't fully necessary to call lu_init to initialize the LUTAB structure. + * If tsiz is 0, then the first call to lu_find will allocate a minimal table. + * The LU_SINIT macro provides a convenient static declaration for character + * string keys. + * * The lu_find routine returns the entry corresponding to the given - * key (any nul-terminated string). If the entry does not exist, the - * corresponding key field will be NULL. If the entry has been - * previously deleted but not yet freed, then only the data field - * will be NULL. It is the caller's responsibility to (allocate and) - * assign the key and data fields when creating a new entry. - * The only case where lu_find returns NULL is when the system - * has run out of memory. + * key. If the entry does not exist, the corresponding key field will + * be NULL. If the entry has been previously deleted but not yet freed, + * then only the data field will be NULL. It is the caller's + * responsibility to (allocate and) assign the key and data fields when + * creating a new entry. The only case where lu_find returns NULL is when + * the system has run out of memory. * * The lu_delete routine frees an entry's data (if any) by calling * the freed member function, but does not free the key field. This * will be freed later during (or instead of) table reallocation. + * It is therefore an error to reuse or do anything with the key + * field after calling lu_delete. * * The lu_done routine calls the given free function once for each * assigned table entry (i.e. each entry with an assigned key value). - * The user must define this routines to free the key and the data + * The user must define these routines to free the key and the data * in the LU_TAB structure. The final action of lu_done is to free the * allocated table itself. */ @@ -59,11 +71,13 @@ extern int lu_init(); extern LUENT *lu_find(); extern void lu_delete(); extern void lu_done(); -extern int lu_hash(); +extern long lu_shash(); #else extern int lu_init(LUTAB *, int); extern LUENT *lu_find(LUTAB *, char *); extern void lu_delete(LUTAB *, char *); extern void lu_done(LUTAB *); -extern int lu_hash(char *); +extern long lu_shash(char *); #endif + +extern int strcmp();
