--- ray/src/cv/mgflib/lookup.h 1994/06/25 09:47:57 1.3 +++ ray/src/cv/mgflib/lookup.h 2003/11/15 17:54:06 1.12 @@ -1,25 +1,37 @@ -/* Copyright (c) 1994 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: lookup.h,v 1.12 2003/11/15 17:54:06 schorsch Exp $ */ /* - * Header file for table lookup routines + * Header file for general associative table lookup routines */ +#ifndef _RAD_LOOKUP_H_ +#define _RAD_LOOKUP_H_ +#include /* strcmp() */ + +#ifdef __cplusplus +extern "C" { +#endif + +typedef void lut_free_t(void*); + typedef struct { - char *key; /* key name (dynamically allocated) */ - char *data; /* pointer to client data */ + char *key; /* key name */ + unsigned long hval; /* key hash value (for efficiency) */ + char *data; /* pointer to client data */ } LUENT; typedef struct { - void (*freek)(); /* free entry key */ - void (*freed)(); /* free entry data */ - int tsiz; /* current table size */ - LUENT *tabl; /* table, if allocated */ - int ndel; /* number of deleted entries */ + unsigned long (*hashf)(char*); /* key hash function */ + int (*keycmp)(const char*, const char*); /* key comparison function */ + lut_free_t *freek; /* free a key */ + lut_free_t *freed; /* free the data */ + int tsiz; /* current table size */ + LUENT *tabl; /* table, if allocated */ + int ndel; /* number of deleted entries */ } LUTAB; -#define LU_SINIT(fk,fd) {(void (*)())(fk),(void (*)())(fd),0,NULL,0} +#undef strcmp +#define LU_SINIT(fk,fd) {lu_shash,strcmp,fk,\ + fd,0,NULL,0} /* * The lu_init routine is called to initialize a table. The number of @@ -29,24 +41,38 @@ typedef struct { * and the expected (minimum) table size. The value returned is the * actual allocated table size (or zero if there was insufficient memory). * - * It isn't fully necessary to initialize the LUTAB structure. If it - * is cleared (tsiz = 0, tabl = NULL), then the first call to lu_find - * will allocate a minimal table. If key and data free functions are - * to be used, the LU_SINIT macro provides a convenient declaration. + * The hashf, keycmp, freek and freed member functions must be assigned + * separately. If the hash value is sufficient to guarantee equality + * between keys, then the keycmp pointer may be NULL. Otherwise, it + * should return 0 if the two passed keys match. If it is not necessary + * (or possible) to free the key and/or data values, then the freek and/or + * freed member functions may be NULL. * + * It isn't fully necessary to call lu_init to initialize the LUTAB structure. + * If tsiz is 0, then the first call to lu_find will allocate a minimal table. + * The LU_SINIT macro provides a convenient static declaration for character + * string keys. + * * The lu_find routine returns the entry corresponding to the given - * key (any nul-terminated string). If the entry does not exist, the - * corresponding key field will be NULL. If the entry has been - * previously deleted but not yet freed, then only the data field - * will be NULL. It is the caller's responsibility to (allocate and) - * assign the key and data fields when creating a new entry. - * The only case where lu_find returns NULL is when the system - * has run out of memory. + * key. If the entry does not exist, the corresponding key field will + * be NULL. If the entry has been previously deleted but not yet freed, + * then only the data field will be NULL. It is the caller's + * responsibility to (allocate and) assign the key and data fields when + * creating a new entry. The only case where lu_find returns NULL is when + * the system has run out of memory. * * The lu_delete routine frees an entry's data (if any) by calling * the freed member function, but does not free the key field. This * will be freed later during (or instead of) table reallocation. + * It is therefore an error to reuse or do anything with the key + * field after calling lu_delete. * + * The lu_doall routine loops through every filled table entry, calling + * the given function once on each entry. If a NULL pointer is passed + * for this function, then lu_doall simply returns the total number of + * active entries. Otherwise, it returns the sum of all the function + * evaluations. + * * The lu_done routine calls the given free function once for each * assigned table entry (i.e. each entry with an assigned key value). * The user must define these routines to free the key and the data @@ -54,16 +80,16 @@ typedef struct { * allocated table itself. */ -#ifdef NOPROTO -extern int lu_init(); -extern LUENT *lu_find(); -extern void lu_delete(); -extern void lu_done(); -extern int lu_hash(); -#else -extern int lu_init(LUTAB *, int); -extern LUENT *lu_find(LUTAB *, char *); -extern void lu_delete(LUTAB *, char *); -extern void lu_done(LUTAB *); -extern int lu_hash(char *); +extern int lu_init(LUTAB *tbl, int nel); +extern unsigned long lu_shash(char *s); +extern LUENT *lu_find(LUTAB *tbl, char *key); +extern void lu_delete(LUTAB *tbl, char *key); +extern int lu_doall(LUTAB *tbl, int (*f)(LUENT*)); +extern void lu_done(LUTAB *tbl); + + +#ifdef __cplusplus +} #endif +#endif /* _RAD_LOOKUP_H_ */ +
