root/radiance/ray/src/cv/mgflib/lookup.h
Sat Nov 15 17:54:06 2003 UTC (20 years, 5 months ago) by schorsch
Changes since 1.11: +33 -21 lines
Diff to previous 1.11 , to selected 1.7
Sat Jun 7 01:11:17 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 1.10: +13 -20 lines
Diff to previous 1.10 , to selected 1.7
Removed NOPROTO sections.
Fri Feb 28 20:11:29 2003 UTC (21 years, 2 months ago) by greg
Changes since 1.9: +1 -4 lines
Diff to previous 1.9 , to selected 1.7
Updates for 3.5 release
Fri Sep 4 09:05:09 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 1.8: +4 -4 lines
Diff to previous 1.8 , to selected 1.7
changed lookup routines to use unsigned long hash values
Tue Mar 18 11:05:34 1997 UTC (27 years, 1 month ago) by greg
Changes since 1.7: +0 -2 lines
Diff to previous 1.7
added fh entity and general cleanup
Revision 1.7 - (view) (download) (annotate) - [selected]
Mon Jun 24 09:14:36 1996 UTC (27 years, 10 months ago) by greg
Diff to previous 1.6
fixed prototype of strcmp() for RS/6000
Fri Mar 10 14:50:50 1995 UTC (29 years, 2 months ago) by greg
Changes since 1.5: +12 -0 lines
fixed prototype for LUTAB
Thu Jul 7 14:03:13 1994 UTC (29 years, 10 months ago) by greg
added comment about reusing key field following lu_delete
Sat Jun 25 16:34:50 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.3: +30 -18 lines
enhancements for general (non-string) associations
Sat Jun 25 09:47:57 1994 UTC (29 years, 10 months ago) by greg
minor fixes and enhancements
Thu Jun 23 07:48:35 1994 UTC (29 years, 10 months ago) by greg
Changes since 1.1: +24 -10 lines
improved table lookup routines with new delete function
Tue Jun 21 14:45:40 1994 UTC (29 years, 10 months ago) by greg
Diff to selected 1.7
