root/radiance/ray/src/cv/mgflib/lookup.h
Revision: 1.1
Committed: Tue Jun 21 14:45:40 1994 UTC (31 years ago) by greg
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for table lookup routines
7 */
8
9 typedef struct {
10 char *key; /* key name (dynamically allocated) */
11 char *data; /* pointer to client data */
12 } LUENT;
13
14 typedef struct {
15 int tsiz; /* current table size */
16 LUENT *tabl; /* table, if allocated */
17 } LUTAB;
18
19 /*
20 * The lu_init routine is called to initialize a table. The number of
21 * elements passed is not a limiting factor, as a table can grow to
22 * any size permitted by memory. However, access will be more efficient
23 * if this number strikes a reasonable balance between default memory use
24 * and the expected (minimum) table size. The value returned is the
25 * actual allocated table size (or zero if there was insufficient memory).
26 *
27 * It isn't fully necessary to initialize the LUTAB structure. If it
28 * is cleared (tsiz = 0, tabl = NULL), then the first call to lu_find
29 * will allocate a minimal table.
30 *
31 * The lu_find routine returns the entry corresponding to the given
32 * key (any nul-terminated string). If the entry does not exist, the
33 * corresponding key field will be NULL. It is the caller's responsibility
34 * to (allocate and) assign the key field when creating a new entry.
35 * If an entry exists, the corresponding data field indicates whether
36 * or not it contains data, and this, too, is subject to user control
37 * and interpretation. The only case where lu_find returns NULL is
38 * when the system has run out of memory.
39 *
40 * The lu_done routine calls the given free function once for each
41 * assigned table entry (i.e. each entry with an assigned key value).
42 * The user must define this routine to free the key and the data
43 * as appropriate. The final action of lu_done is to free the
44 * allocated table itself.
45 */
46
47 #ifdef NOPROTO
48 extern int lu_init();
49 extern LUENT *lu_find();
50 extern void lu_done();
51 #else
52 extern int lu_init(LUTAB *, int);
53 extern LUENT *lu_find(LUTAB *, char *);
54 extern void lu_done(LUTAB *, void (*)(LUENT *));
55 #endif
