1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Table lookup routines |
9 |
10 |
11 |
#include <stdio.h> |
12 |
#include "lookup.h" |
13 |
14 |
#ifndef MEM_PTR |
15 |
#define MEM_PTR void * |
16 |
#endif |
17 |
18 |
extern MEM_PTR calloc(); |
19 |
20 |
21 |
int |
22 |
lu_init(tbl, nel) /* initialize tbl for at least nel elements */ |
23 |
register LUTAB *tbl; |
24 |
int nel; |
25 |
26 |
static int hsiztab[] = { |
27 |
31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381, 0 |
28 |
29 |
register int *hsp; |
30 |
31 |
nel += nel>>1; /* 66% occupancy */ |
32 |
for (hsp = hsiztab; *hsp; hsp++) |
33 |
if (*hsp > nel) |
34 |
break; |
35 |
if (!(tbl->tsiz = *hsp)) |
36 |
tbl->tsiz = nel*2 + 1; /* not always prime */ |
37 |
tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT)); |
38 |
if (tbl->tabl == NULL) |
39 |
tbl->tsiz = 0; |
40 |
tbl->ndel = 0; |
41 |
return(tbl->tsiz); |
42 |
43 |
44 |
45 |
long |
46 |
lu_shash(s) /* hash a nul-terminated string */ |
47 |
register char *s; |
48 |
49 |
register int i = 0; |
50 |
register long h = 0; |
51 |
52 |
while (*s) |
53 |
h ^= (long)(*s++ & 0xff) << (i++ & 15); |
54 |
return(h); |
55 |
56 |
57 |
58 |
LUENT * |
59 |
lu_find(tbl, key) /* find a table entry */ |
60 |
61 |
char *key; |
62 |
63 |
long hval; |
64 |
int i; |
65 |
register int ndx; |
66 |
register LUENT *oldtabl; |
67 |
/* look up object */ |
68 |
hval = (*tbl->hashf)(key); |
69 |
tryagain: |
70 |
for (i = 0; i < tbl->tsiz; i++) { |
71 |
ndx = (hval + i*i) % tbl->tsiz; |
72 |
if (tbl->tabl[ndx].key == NULL) { |
73 |
tbl->tabl[ndx].hval = hval; |
74 |
return(&tbl->tabl[ndx]); |
75 |
76 |
if ( tbl->tabl[ndx].hval == hval && (tbl->keycmp == NULL || |
77 |
!(*tbl->keycmp)(tbl->tabl[ndx].key, key)) ) |
78 |
79 |
80 |
/* table is full, reallocate */ |
81 |
oldtabl = tbl->tabl; |
82 |
ndx = tbl->tsiz; |
83 |
i = tbl->ndel; |
84 |
if (!lu_init(tbl, ndx-i)) { /* no more memory! */ |
85 |
tbl->tabl = oldtabl; |
86 |
tbl->tsiz = ndx; |
87 |
tbl->ndel = i; |
88 |
return(NULL); |
89 |
90 |
if (!ndx) |
91 |
goto tryagain; |
92 |
93 |
* The following code may fail if the user has reclaimed many |
94 |
* deleted entries and the system runs out of memory in a |
95 |
* recursive call to lu_find(). |
96 |
97 |
while (ndx--) |
98 |
if (oldtabl[ndx].key != NULL) |
99 |
if (oldtabl[ndx].data != NULL) |
100 |
*lu_find(tbl, oldtabl[ndx].key) = oldtabl[ndx]; |
101 |
else if (tbl->freek != NULL) |
102 |
(*tbl->freek)(oldtabl[ndx].key); |
103 |
free((MEM_PTR)oldtabl); |
104 |
goto tryagain; /* should happen only once! */ |
105 |
106 |
107 |
108 |
void |
109 |
lu_delete(tbl, key) /* delete a table entry */ |
110 |
111 |
char *key; |
112 |
113 |
register LUENT *le; |
114 |
115 |
if ((le = lu_find(tbl, key)) == NULL) |
116 |
return; |
117 |
if (le->key == NULL || le->data == NULL) |
118 |
return; |
119 |
if (tbl->freed != NULL) |
120 |
(*tbl->freed)(le->data); |
121 |
le->data = NULL; |
122 |
tbl->ndel++; |
123 |
124 |
125 |
126 |
void |
127 |
lu_done(tbl) /* free table and contents */ |
128 |
129 |
130 |
register LUENT *tp; |
131 |
132 |
if (!tbl->tsiz) |
133 |
return; |
134 |
for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; ) |
135 |
if (tp->key != NULL) { |
136 |
137 |
(*tbl->freek)(tp->key); |
138 |
if (tp->data != NULL && tbl->freed != NULL) |
139 |
(*tbl->freed)(tp->data); |
140 |
141 |
free((MEM_PTR)tbl->tabl); |
142 |
tbl->tabl = NULL; |
143 |
tbl->tsiz = 0; |
144 |
tbl->ndel = 0; |
145 |
