root/radiance/ray/src/cv/mgflib/lookup.c
Revision: 1.11
Committed: Fri Nov 21 07:15:29 2003 UTC (20 years, 7 months ago) by greg
CVS Tags: rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad3R7P2
Changes since 1.10: +1 -3 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.11 static const char RCSid[] = "$Id: lookup.c,v 1.10 2003/11/15 17:54:06 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * Table lookup routines
6     */
7 schorsch 1.10
8 greg 1.1 #include <stdio.h>
9 greg 1.8 #include <stdlib.h>
10 schorsch 1.10
11 greg 1.1 #include "lookup.h"
12
13
14     int
15     lu_init(tbl, nel) /* initialize tbl for at least nel elements */
16     register LUTAB *tbl;
17     int nel;
18     {
19     static int hsiztab[] = {
20 gregl 1.6 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
21     32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
22     4194301, 8388593, 0
23 greg 1.1 };
24     register int *hsp;
25
26 greg 1.2 nel += nel>>1; /* 66% occupancy */
27 greg 1.1 for (hsp = hsiztab; *hsp; hsp++)
28     if (*hsp > nel)
29     break;
30     if (!(tbl->tsiz = *hsp))
31     tbl->tsiz = nel*2 + 1; /* not always prime */
32     tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
33     if (tbl->tabl == NULL)
34     tbl->tsiz = 0;
35 greg 1.2 tbl->ndel = 0;
36 greg 1.1 return(tbl->tsiz);
37     }
38
39
40 gwlarson 1.7 unsigned long
41 greg 1.4 lu_shash(s) /* hash a nul-terminated string */
42 gregl 1.6 char *s;
43 greg 1.1 {
44 gregl 1.6 static unsigned char shuffle[256] = {
45     0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
46     191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
47     126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
48     61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
49     252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
50     187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
51     122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
52     57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
53     248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
54     183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
55     118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
56     53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
57     244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
58     179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
59     114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
60     49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
61     240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
62     175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
63     110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
64     45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
65     236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
66     171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
67     106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
68     41, 198, 99
69     };
70 greg 1.4 register int i = 0;
71 gwlarson 1.7 register unsigned long h = 0;
72 gregl 1.6 register unsigned char *t = (unsigned char *)s;
73 greg 1.1
74 gregl 1.6 while (*t)
75 schorsch 1.10 h ^= (unsigned long)shuffle[*t++] << ((i+=11) & 0xf);
76 gregl 1.6
77 greg 1.1 return(h);
78     }
79
80
81     LUENT *
82     lu_find(tbl, key) /* find a table entry */
83     register LUTAB *tbl;
84     char *key;
85     {
86 gwlarson 1.7 unsigned long hval;
87 gregl 1.6 int i, n;
88 greg 1.4 register int ndx;
89 gregl 1.6 register LUENT *le;
90 greg 1.1 /* look up object */
91 gwlarson 1.7 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
92     return(NULL);
93 greg 1.4 hval = (*tbl->hashf)(key);
94 greg 1.1 tryagain:
95 gregl 1.6 ndx = hval % tbl->tsiz;
96     for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
97 gwlarson 1.7 le = &tbl->tabl[ndx];
98 gregl 1.6 if (le->key == NULL) {
99     le->hval = hval;
100     return(le);
101 greg 1.4 }
102 gregl 1.6 if (le->hval == hval &&
103     (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
104     return(le);
105     }
106 gwlarson 1.7 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
107 gregl 1.6 ndx = ndx % tbl->tsiz;
108 greg 1.1 }
109     /* table is full, reallocate */
110 gregl 1.6 le = tbl->tabl;
111 greg 1.1 ndx = tbl->tsiz;
112 greg 1.2 i = tbl->ndel;
113 greg 1.5 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
114 gregl 1.6 tbl->tabl = le;
115 greg 1.1 tbl->tsiz = ndx;
116 greg 1.2 tbl->ndel = i;
117 greg 1.1 return(NULL);
118     }
119 greg 1.3 /*
120     * The following code may fail if the user has reclaimed many
121     * deleted entries and the system runs out of memory in a
122     * recursive call to lu_find().
123     */
124 greg 1.1 while (ndx--)
125 schorsch 1.9 if (le[ndx].key != NULL) {
126 gregl 1.6 if (le[ndx].data != NULL)
127 schorsch 1.10 *lu_find(tbl,le[ndx].key) = le[ndx];
128 greg 1.2 else if (tbl->freek != NULL)
129 gregl 1.6 (*tbl->freek)(le[ndx].key);
130 schorsch 1.9 }
131 schorsch 1.10 free((void *)le);
132 greg 1.1 goto tryagain; /* should happen only once! */
133     }
134
135
136     void
137 greg 1.2 lu_delete(tbl, key) /* delete a table entry */
138     register LUTAB *tbl;
139     char *key;
140 greg 1.1 {
141 greg 1.2 register LUENT *le;
142
143     if ((le = lu_find(tbl, key)) == NULL)
144     return;
145     if (le->key == NULL || le->data == NULL)
146     return;
147     if (tbl->freed != NULL)
148     (*tbl->freed)(le->data);
149     le->data = NULL;
150     tbl->ndel++;
151     }
152
153
154 schorsch 1.10 int
155     lu_doall(tbl, f) /* loop through all valid table entries */
156     register LUTAB *tbl;
157     int (*f)(LUENT *);
158     {
159     int rval = 0;
160     register LUENT *tp;
161
162     for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
163     if (tp->data != NULL) {
164     if (f != NULL)
165     rval += (*f)(tp);
166     else
167     rval++;
168     }
169     return(rval);
170     }
171
172
173 greg 1.2 void
174     lu_done(tbl) /* free table and contents */
175     register LUTAB *tbl;
176     {
177 greg 1.1 register LUENT *tp;
178
179     if (!tbl->tsiz)
180     return;
181 greg 1.2 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
182     if (tp->key != NULL) {
183     if (tbl->freek != NULL)
184     (*tbl->freek)(tp->key);
185     if (tp->data != NULL && tbl->freed != NULL)
186     (*tbl->freed)(tp->data);
187     }
188 schorsch 1.10 free((void *)tbl->tabl);
189 greg 1.1 tbl->tabl = NULL;
190     tbl->tsiz = 0;
191 greg 1.2 tbl->ndel = 0;
192 greg 1.1 }
