1 |
/* Copyright (c) 1994 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Table lookup routines |
9 |
10 |
11 |
#include <stdio.h> |
12 |
#include "lookup.h" |
13 |
14 |
#ifndef MEM_PTR |
15 |
#define MEM_PTR void * |
16 |
#endif |
17 |
18 |
extern MEM_PTR calloc(); |
19 |
20 |
21 |
int |
22 |
lu_init(tbl, nel) /* initialize tbl for at least nel elements */ |
23 |
register LUTAB *tbl; |
24 |
int nel; |
25 |
26 |
static int hsiztab[] = { |
27 |
31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381, 0 |
28 |
29 |
register int *hsp; |
30 |
31 |
nel += nel>>1; /* 66% occupancy */ |
32 |
for (hsp = hsiztab; *hsp; hsp++) |
33 |
if (*hsp > nel) |
34 |
break; |
35 |
if (!(tbl->tsiz = *hsp)) |
36 |
tbl->tsiz = nel*2 + 1; /* not always prime */ |
37 |
tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT)); |
38 |
if (tbl->tabl == NULL) |
39 |
tbl->tsiz = 0; |
40 |
tbl->ndel = 0; |
41 |
return(tbl->tsiz); |
42 |
43 |
44 |
45 |
int |
46 |
lu_hash(s) /* hash a nul-terminated string */ |
47 |
register char *s; |
48 |
49 |
register int h = 0; |
50 |
51 |
while (*s) |
52 |
h = (h<<1 & 0x7fff) ^ (*s++ & 0xff); |
53 |
return(h); |
54 |
55 |
56 |
57 |
LUENT * |
58 |
lu_find(tbl, key) /* find a table entry */ |
59 |
60 |
char *key; |
61 |
62 |
int hval, i; |
63 |
register int ndx; |
64 |
register LUENT *oldtabl; |
65 |
/* look up object */ |
66 |
hval = lu_hash(key); |
67 |
tryagain: |
68 |
for (i = 0; i < tbl->tsiz; i++) { |
69 |
ndx = (hval + i*i) % tbl->tsiz; |
70 |
if (tbl->tabl[ndx].key == NULL || |
71 |
!strcmp(tbl->tabl[ndx].key, key)) |
72 |
return(&tbl->tabl[ndx]); |
73 |
74 |
/* table is full, reallocate */ |
75 |
oldtabl = tbl->tabl; |
76 |
ndx = tbl->tsiz; |
77 |
i = tbl->ndel; |
78 |
if (!lu_init(tbl, ndx-i)) { /* no more memory! */ |
79 |
tbl->tabl = oldtabl; |
80 |
tbl->tsiz = ndx; |
81 |
tbl->ndel = i; |
82 |
return(NULL); |
83 |
84 |
if (!ndx) |
85 |
goto tryagain; |
86 |
87 |
* The following code may fail if the user has reclaimed many |
88 |
* deleted entries and the system runs out of memory in a |
89 |
* recursive call to lu_find(). |
90 |
91 |
while (ndx--) |
92 |
if (oldtabl[ndx].key != NULL) |
93 |
if (oldtabl[ndx].data != NULL) |
94 |
*lu_find(tbl, oldtabl[ndx].key) = oldtabl[ndx]; |
95 |
else if (tbl->freek != NULL) |
96 |
(*tbl->freek)(oldtabl[ndx].key); |
97 |
free((MEM_PTR)oldtabl); |
98 |
goto tryagain; /* should happen only once! */ |
99 |
100 |
101 |
102 |
void |
103 |
lu_delete(tbl, key) /* delete a table entry */ |
104 |
105 |
char *key; |
106 |
107 |
register LUENT *le; |
108 |
109 |
if ((le = lu_find(tbl, key)) == NULL) |
110 |
return; |
111 |
if (le->key == NULL || le->data == NULL) |
112 |
return; |
113 |
if (tbl->freed != NULL) |
114 |
(*tbl->freed)(le->data); |
115 |
le->data = NULL; |
116 |
tbl->ndel++; |
117 |
118 |
119 |
120 |
void |
121 |
lu_done(tbl) /* free table and contents */ |
122 |
123 |
124 |
register LUENT *tp; |
125 |
126 |
if (!tbl->tsiz) |
127 |
return; |
128 |
for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; ) |
129 |
if (tp->key != NULL) { |
130 |
131 |
(*tbl->freek)(tp->key); |
132 |
if (tp->data != NULL && tbl->freed != NULL) |
133 |
(*tbl->freed)(tp->data); |
134 |
135 |
free((MEM_PTR)tbl->tabl); |
136 |
tbl->tabl = NULL; |
137 |
tbl->tsiz = 0; |
138 |
tbl->ndel = 0; |
139 |
