root/radiance/ray/src/cv/mgflib/lookup.c
Revision: 1.8
Committed: Fri Feb 28 20:11:29 2003 UTC (21 years, 3 months ago) by greg
Changes since 1.7: +2 -6 lines
Updates for 3.5 release
5 * Table lookup routines
6 */
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include "lookup.h"
11
12 #ifndef MEM_PTR
13 #define MEM_PTR void *
14 #endif
15
16
17 int
18 lu_init(tbl, nel) /* initialize tbl for at least nel elements */
19 register LUTAB *tbl;
20 int nel;
21 {
22 static int hsiztab[] = {
23 31, 61, 127, 251, 509, 1021, 2039, 4093, 8191, 16381,
24 32749, 65521, 131071, 262139, 524287, 1048573, 2097143,
25 4194301, 8388593, 0
26 };
27 register int *hsp;
28
29 nel += nel>>1; /* 66% occupancy */
30 for (hsp = hsiztab; *hsp; hsp++)
31 if (*hsp > nel)
32 break;
33 if (!(tbl->tsiz = *hsp))
34 tbl->tsiz = nel*2 + 1; /* not always prime */
35 tbl->tabl = (LUENT *)calloc(tbl->tsiz, sizeof(LUENT));
36 if (tbl->tabl == NULL)
37 tbl->tsiz = 0;
38 tbl->ndel = 0;
39 return(tbl->tsiz);
40 }
41
42
43 unsigned long
44 lu_shash(s) /* hash a nul-terminated string */
45 char *s;
46 {
47 static unsigned char shuffle[256] = {
48 0, 157, 58, 215, 116, 17, 174, 75, 232, 133, 34,
49 191, 92, 249, 150, 51, 208, 109, 10, 167, 68, 225,
50 126, 27, 184, 85, 242, 143, 44, 201, 102, 3, 160,
51 61, 218, 119, 20, 177, 78, 235, 136, 37, 194, 95,
52 252, 153, 54, 211, 112, 13, 170, 71, 228, 129, 30,
53 187, 88, 245, 146, 47, 204, 105, 6, 163, 64, 221,
54 122, 23, 180, 81, 238, 139, 40, 197, 98, 255, 156,
55 57, 214, 115, 16, 173, 74, 231, 132, 33, 190, 91,
56 248, 149, 50, 207, 108, 9, 166, 67, 224, 125, 26,
57 183, 84, 241, 142, 43, 200, 101, 2, 159, 60, 217,
58 118, 19, 176, 77, 234, 135, 36, 193, 94, 251, 152,
59 53, 210, 111, 12, 169, 70, 227, 128, 29, 186, 87,
60 244, 145, 46, 203, 104, 5, 162, 63, 220, 121, 22,
61 179, 80, 237, 138, 39, 196, 97, 254, 155, 56, 213,
62 114, 15, 172, 73, 230, 131, 32, 189, 90, 247, 148,
63 49, 206, 107, 8, 165, 66, 223, 124, 25, 182, 83,
64 240, 141, 42, 199, 100, 1, 158, 59, 216, 117, 18,
65 175, 76, 233, 134, 35, 192, 93, 250, 151, 52, 209,
66 110, 11, 168, 69, 226, 127, 28, 185, 86, 243, 144,
67 45, 202, 103, 4, 161, 62, 219, 120, 21, 178, 79,
68 236, 137, 38, 195, 96, 253, 154, 55, 212, 113, 14,
69 171, 72, 229, 130, 31, 188, 89, 246, 147, 48, 205,
70 106, 7, 164, 65, 222, 123, 24, 181, 82, 239, 140,
71 41, 198, 99
72 };
73 register int i = 0;
74 register unsigned long h = 0;
75 register unsigned char *t = (unsigned char *)s;
76
77 while (*t)
78 h ^= (long)shuffle[*t++] << ((i+=11) & 0xf);
79
80 return(h);
81 }
82
83
84 LUENT *
85 lu_find(tbl, key) /* find a table entry */
86 register LUTAB *tbl;
87 char *key;
88 {
89 unsigned long hval;
90 int i, n;
91 register int ndx;
92 register LUENT *le;
93 /* look up object */
94 if (tbl->tsiz == 0 && !lu_init(tbl, 1))
95 return(NULL);
96 hval = (*tbl->hashf)(key);
97 tryagain:
98 ndx = hval % tbl->tsiz;
99 for (i = 0, n = 1; i < tbl->tsiz; i++, n += 2) {
100 le = &tbl->tabl[ndx];
101 if (le->key == NULL) {
102 le->hval = hval;
103 return(le);
104 }
105 if (le->hval == hval &&
106 (tbl->keycmp == NULL || !(*tbl->keycmp)(le->key, key))) {
107 return(le);
108 }
109 if ((ndx += n) >= tbl->tsiz) /* this happens rarely */
110 ndx = ndx % tbl->tsiz;
111 }
112 /* table is full, reallocate */
113 le = tbl->tabl;
114 ndx = tbl->tsiz;
115 i = tbl->ndel;
116 if (!lu_init(tbl, ndx-i+1)) { /* no more memory! */
117 tbl->tabl = le;
118 tbl->tsiz = ndx;
119 tbl->ndel = i;
120 return(NULL);
121 }
122 /*
123 * The following code may fail if the user has reclaimed many
124 * deleted entries and the system runs out of memory in a
125 * recursive call to lu_find().
126 */
127 while (ndx--)
128 if (le[ndx].key != NULL)
129 if (le[ndx].data != NULL)
130 *lu_find(tbl, le[ndx].key) = le[ndx];
131 else if (tbl->freek != NULL)
132 (*tbl->freek)(le[ndx].key);
133 free((MEM_PTR)le);
134 goto tryagain; /* should happen only once! */
135 }
136
137
138 void
139 lu_delete(tbl, key) /* delete a table entry */
140 register LUTAB *tbl;
141 char *key;
142 {
143 register LUENT *le;
144
145 if ((le = lu_find(tbl, key)) == NULL)
146 return;
147 if (le->key == NULL || le->data == NULL)
148 return;
149 if (tbl->freed != NULL)
150 (*tbl->freed)(le->data);
151 le->data = NULL;
152 tbl->ndel++;
153 }
154
155
156 void
157 lu_done(tbl) /* free table and contents */
158 register LUTAB *tbl;
159 {
160 register LUENT *tp;
161
162 if (!tbl->tsiz)
163 return;
164 for (tp = tbl->tabl + tbl->tsiz; tp-- > tbl->tabl; )
165 if (tp->key != NULL) {
166 if (tbl->freek != NULL)
167 (*tbl->freek)(tp->key);
168 if (tp->data != NULL && tbl->freed != NULL)
169 (*tbl->freed)(tp->data);
170 }
171 free((MEM_PTR)tbl->tabl);
172 tbl->tabl = NULL;
173 tbl->tsiz = 0;
174 tbl->ndel = 0;
175 }
