root/radiance/ray/src/cv/mgflib/lookup.c
Revision 1.12
Tue Feb 22 15:58:41 2011 UTC (13 years, 3 months ago) by greg
FILE REMOVED
Finish of code reorg, moving MGF library into src/cv and src/common
Fri Nov 21 07:15:29 2003 UTC (20 years, 6 months ago) by greg
Changes since 1.10: +1 -3 lines
Diff to previous 1.10 , to selected 1.8
Sat Nov 15 17:54:06 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 1.9: +27 -9 lines
Diff to previous 1.9 , to selected 1.8
Diff to previous 1.8
Revision 1.8 - (view) (download) (annotate) - [selected]
Fri Feb 28 20:11:29 2003 UTC (21 years, 3 months ago) by greg
Changes since 1.7: +2 -6 lines
Diff to previous 1.7
Updates for 3.5 release
Fri Sep 4 09:05:09 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 1.6: +7 -12 lines
Diff to previous 1.6 , to selected 1.8
changed lookup routines to use unsigned long hash values
Wed Oct 8 11:16:58 1997 UTC (26 years, 8 months ago) by gregl
Changes since 1.5: +60 -21 lines
Diff to previous 1.5 , to selected 1.8
Added Philippe Bekaert's improvements to lu_hash() and lu_find()
Tue Apr 11 13:33:27 1995 UTC (29 years, 2 months ago) by greg
Diff to previous 1.4 , to selected 1.8
minor mods
Sat Jun 25 16:33:07 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.3: +16 -10 lines
Diff to previous 1.3 , to selected 1.8
bug fixes and enhancements
Thu Jun 23 08:48:28 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.2: +6 -1 lines
Diff to previous 1.2 , to selected 1.8
change in comment
Thu Jun 23 07:48:41 1994 UTC (29 years, 11 months ago) by greg
Changes since 1.1: +38 -15 lines
Diff to previous 1.1 , to selected 1.8
improved table lookup routines with new delete function
Tue Jun 21 14:45:45 1994 UTC (29 years, 11 months ago) by greg
Diff to selected 1.8
