root/Development/ray/src/cv/mgflib/iesnotes.txt
Revision: 1.2
Committed: Fri Feb 28 20:19:26 2003 UTC (22 years, 9 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, rad3R5, HEAD
Fixed RCSid's
1 Enclosing IES File Notes
2 RCSid "$Id$"
3
4 The following notes describe how MGF data is to be referred to by
5 an enclosing IES luminaire file, and these notes are in a state of flux.
6
7 The basic method for specifying an MGF geometry file within an IES
8 file is a single line immediately preceeding the TILT= line, which reads:
9
10 GEOM=file.mgf
11
12 where "file.mgf" is replaced by the name of the relevant MGF file.
13
14 IES data file contains simplified geometry, which must completely
15 enclose the detailed geometry specified by the "GEOM=file.mgf" line.
16 This detailed geometry file is always in meters, whatever the units of
17 the enclosing IES file, and must have its origin at the center of the
18 simplified geometry. The X-axis corresponds to the 0-180 degree plane,
19 the Y-axis corresponds to the 90-270 degree plane, and the Z-axis
20 corresponds to the up direction. (This is a right-handed coordinate
21 system.)
22
23 The emission values in the MGF file will be multiplied by the usual
24 IES luminaire factors, i.e. the tilt factors (if any), the candela
25 multiplier, the ballast factor and the ballast lamp factor. Thus,
26 the MGF file emissions should correspond to those of the as-tested
27 luminaire configuration.
