--- ray/src/cv/mgflib/examp1.ies 1994/07/22 10:35:24 1.1 +++ ray/src/cv/mgflib/examp1.ies 1995/04/27 13:29:40 1.2 @@ -1,62 +1,53 @@ -IESNA94 +IESNA95 SCCSid "$SunId$ LBL" -[TEST] 38705 ITL -[MANUFAC] LEDALITE ARCHITECTURAL PRODUCTS, LTD. -[LUMCAT] APEX TYPE #2 -[LUMINAIRE] EXTRUDED ALUMINUM BODY, FABRICATED SPECULAR REFLECTOR WITH -[MORE] PARABOLIC CROSS LOUVERS, OPEN TOP. -[MORE] SUSPENDED/DIRECT/INDIRECT -[LAMP] TWO F032T8/41K, EACH RATED 2900 LUMENS. -[BALLAST] VALMONT 8G4126W -[OTHER] DATE: 11-14-1991 -[MORE] TOTAL INPUT WATTS= 80.0 AT 120.0 VOLTS -[MORE] LUMEN TO CANDELA RATIO USED= 9.17 -[MORE] THE 0 DEGREE PLANE IS PARALLEL WITH THE LAMPS. -GEOM=examp1.mgf +[TEST] 2100101; +[MANUFAC] Ledalite Architectural Products 604-888-6811 +[LUMCAT] 251602SN-12EO +[DATE] 02/21/95 +[FIXT] Extruded aluminum housing +[OPTC] S,N +[LUMINOUSGEOMETRY] examp1.mgf +[LAMP] FO32T8 (EO) +[BALL] +[PROJECT] APEX 55 +[ALGN] SYMMETRIC--0 degree plane parallel to lamps +[WATT] 63.7 TILT=NONE -2 2900 1 73 5 1 1 0.85 4.1 0.3 -1 1 80 -0 2.5 5 7.5 10 12.5 15 17.5 20 22.5 25 27.5 30 32.5 35 37.5 40 42.5 45 47.5 -50 - 52.5 55 57.5 60 62.5 65 67.5 70 72.5 75 77.5 80 82.5 85 87.5 90 92.5 95 -97.5 - 100 102.5 105 107.5 110 112.5 115 117.5 120 122.5 125 127.5 130 132.5 135 - 137.5 140 142.5 145 147.5 150 152.5 155 157.5 160 162.5 165 167.5 170 -172.5 - 175 177.5 180 +2 2900 1.0 73 5 1 1 0.85 4.04 .292 +1.0 1.0 63.7 +0 2.5 5 7.5 10 12.5 15 17.5 20 22.5 25 27.5 30 32.5 35 37.5 40 42.5 45 47.5 50 + 52.5 55 57.5 60 62.5 65 67.5 70 72.5 75 77.5 80 82.5 85 87.5 90 + 92.5 95 97.5 100 102.5 105 107.5 110 112.5 115 117.5 120 122.5 125 127.5 + 130 132.5 135 137.5 140 142.5 145 147.5 150 152.5 155 157.5 160 162.5 165 + 167.5 170 172.5 175 177.5 180 0 22.5 45 67.5 90 -829 833 830 826 817 806 791 777 755 732 710 684 658 628 585 530 452 364 277 -191 - 115 65 30 11 5 4 4 4 4 2 1 2 2 2 2 2 2 11 28 50 74 100 129 154 184 219 251 -283 - 315 349 380 410 442 471 501 521 547 572 596 619 640 660 678 691 706 716 -728 - 734 739 744 746 748 741 -829 831 833 836 838 837 834 831 824 817 811 803 792 772 739 690 617 536 437 -320 - 230 139 75 32 9 4 4 4 3 2 1 3 2 2 2 2 9 71 166 223 260 286 308 321 339 363 -388 - 412 438 463 488 513 536 561 582 600 621 638 659 673 689 701 713 721 731 -736 - 741 742 746 746 744 746 741 -829 835 847 863 879 897 916 930 944 959 972 975 969 944 896 826 736 639 533 -411 - 297 199 120 65 24 9 6 5 4 2 2 3 3 2 2 2 12 72 165 302 428 483 522 539 559 -579 - 598 610 616 621 632 644 655 666 678 688 702 716 731 744 755 763 769 770 -771 - 770 766 763 759 754 747 744 741 -829 832 849 877 906 940 973 1000 1027 1051 1069 1084 1083 1037 953 845 731 -616 - 503 387 259 149 76 31 14 10 9 6 5 3 2 3 3 2 2 2 16 88 176 295 449 585 660 -694 - 719 730 740 750 762 771 775 771 769 771 773 775 776 777 781 788 795 801 -805 - 802 800 794 786 778 768 758 746 741 741 -829 837 862 889 924 962 1003 1029 1059 1082 1108 1133 1111 1046 946 821 685 -572 - 465 318 196 103 38 15 12 9 8 7 6 3 3 4 3 3 2 2 18 84 170 280 427 582 691 -736 - 775 785 794 801 813 823 830 830 821 817 816 813 810 807 807 807 810 814 -818 - 815 810 803 792 782 769 758 746 738 741 +778.4 777.6 774.9 769.9 763.2 754.1 741.0 726.1 711.6 692.2 672.3 651.0 628.4 + 600.0 553.8 472.5 369.4 267.7 186.3 120.3 62.4 21.7 4.1 0.0 0.0 0.0 0.0 0.0 + 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 + 3.6 18.1 38.5 63.4 91.9 124.5 159.4 195.6 230.0 264.4 297.9 332.8 366.8 400.3 + 432.0 464.6 494.9 525.2 553.3 580.5 605.8 631.6 654.3 676.5 695.0 714.0 + 730.8 745.7 759.8 771.5 781.5 789.6 795.5 798.7 802.3 801.4 +778.4 778.7 776.9 774.8 771.9 766.9 761.0 755.2 748.8 742.7 736.8 729.4 719.0 + 702.5 674.4 625.3 546.6 443.5 330.7 225.9 140.2 71.0 23.7 3.2 0.0 0.0 0.0 + 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 + 57.8 155.7 216.5 254.2 295.6 325.4 346.4 364.7 386.9 414.0 442.2 470.9 498.0 + 524.2 550.0 575.1 599.0 621.4 642.6 661.6 680.8 697.1 713.6 728.3 741.8 + 754.5 765.3 774.6 782.7 789.1 793.4 797.0 798.8 799.5 801.0 801.4 +778.4 777.1 778.5 782.7 791.7 805.9 820.4 836.8 851.0 869.2 891.6 913.0 918.8 + 904.6 869.6 811.2 746.8 666.6 558.6 423.5 283.6 165.0 83.3 32.3 9.7 0.7 0.0 + 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 + 64.5 152.0 291.8 436.1 502.7 544.2 579.3 615.7 663.4 688.6 697.6 703.2 706.3 + 709.5 719.6 732.6 744.8 757.1 768.6 779.4 789.7 798.9 807.3 814.0 819.0 + 818.5 818.3 817.8 817.4 816.5 815.1 814.5 810.6 805.0 802.1 801.4 +778.4 778.3 783.3 795.2 819.5 846.5 876.2 913.4 956.8 999.8 1028.8 1037.1 + 1010.8 976.4 934.3 862.9 780.3 695.5 586.1 458.0 304.8 169.0 76.5 28.4 12.6 + 7.9 2.9 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 + 65.2 150.2 262.3 425.6 584.0 679.6 721.4 757.6 790.4 823.5 868.2 907.1 908.7 + 903.0 895.6 885.5 876.5 876.1 879.9 883.0 878.3 876.7 876.3 874.3 872.2 + 869.1 865.0 855.6 846.8 837.8 830.0 822.8 814.9 807.9 801.9 801.4 +778.4 779.3 786.1 803.0 829.8 862.6 900.8 949.1 1002.3 1042.9 1065.2 1059.2 + 1037.8 1019.2 963.7 895.8 828.0 738.8 627.7 460.2 282.7 137.9 51.0 20.5 18.7 + 11.4 6.4 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 + 66.5 152.5 258.6 414.8 590.1 724.9 780.5 819.6 849.2 881.6 912.1 959.0 984.0 + 976.7 966.3 953.1 934.4 916.2 912.5 913.0 909.8 908.9 905.2 899.3 894.8 + 887.9 882.0 872.9 860.2 847.9 837.4 828.7 819.2 811.0 804.6 801.4
